Acer's Portable and Gaming Monitor Lineup at Computex 2025
At Computex 2025, Acer showcased its monitor lineup that spans from dual-screen portable displays to ultra-fast 500 Hz gaming monitors, and we couldn't miss the opportunity to take a quick look at these products. We start with the Nitro PG271K, a 27-inch "portable" gaming monitor (as much as a 27-inch monitor can be portable) with an IPS panel with dual-resolution modes. You can make it run at 4K (3840 x 2160) resolution with 72 Hz refresh rate, or you can change it to FHD (1920 x 1080) with 144 Hz refresh rate with 0.5 ms response time for some gaming sessions. It has a kickstand and VESA mount holes for different mounting options and include USB-C and HDMI connections.
In the same portable section we founded Acer PD243YE. This is a dual-screen portable monitor with two 23.5-inch screens stacked on top of each other. Both screens are 1080p IPS panels. The top screen tilts from 0 to 315 degrees on hinges, which gives you a lot of setup flexibility. Connects via USB-C or HDMI.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Acer Showcases Predator Gaming Laptops, Swift and Aspire Copilot+ PCs
In Acer's booth at Computex 2025 we've encountered their updated lineup of gaming laptops from the Predator series as well as an extensive range from the newly announced Swift Edge, Swift Go, Swift X and Aspire Copilot+ PCs. The new Predator Triton 14 AI is a lightweight 14.5-inch gaming laptop weighing 1.6 kg with a slim 17.31 mm aluminium chassis. It features an Intel Core Ultra 9 288V processor and up to an NVIDIA GeForce RTX 5070 laptop GPU, cooled by Acer's 6th Gen Dual AeroBlade 3D cooling system and graphene thermal interface materials. It also supports up to 32 GB LPDDR5X RAM and 2 TB PCIe Gen 4 storage. The 14.5-inch display is a Calman Verified OLED WQXGA+ touchscreen panel running at 2880x1800 resolution with 100% DCI-P3 color coverage, 120 Hz refresh rate, and a 1 ms response time. Since Acer is also targeting creative users it includes a haptic Gorilla Glass touchpad with a bundled active stylus. It will be available in Europe this July starting at €2,999.
Right next to this we saw the Predator Helios 18 AI gaming laptop with its 18-inch Mini LED 4K display, not exactly a novelty since it was announced in February. However, it does pack a punch with up to a Core Ultra 9 275HX processor, up to GeForce RTX 5090 laptop GPU, and MagKey 4.0 swappable mechanical switches. Available from April in Europe starting at €3,699, May in North America at $2999.99.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
aboStudio Shows CNC-Machined Cases at Computex 2025
At Computex 2025, the smaller case brand aboStudio stole some of the spotlight from countless others. While the show floor teemed with flashy AI demos and next-generation robotics, aboStudio reminded visitors that solid hardware design still matters. Their Container L case drew early crowds. Crafted from sand-blasted anodized aluminium, it can house Micro ATX or Mini ITX motherboards and can fit graphics cards up to 330 mm long. Builders who care about cooling will appreciate its support for 280 mm radiators and the four internal bays for 2.5-inch drives. The front-mounted ATX power supply design and side panel window give it a clean, straightforward look without sacrificing performance.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Raidmax Unveils New PC Cases and CPU Coolers at Computex 2025
For Computex 2025, Raidmax quietly refreshed its case lineup across three distinct series: VECTOR, INFINITA, and MESHIAN. Each family now spans everything from compact, minimalist designs to full-tower workhorses, promising builders both style and substance. The newly highlighted V217 and V300 full towers are engineered for extreme hardware, with support for triple-radiator liquid loops and GPUs up to 350 mm long. Just below them sits the V213 M, which balances expandability and a tempered-glass showcase, while the mid-tower V212 wins praise for its mesh-front panel and four pre-installed RGB fans. Even space-sensitive setups aren't forgotten: the V158, V155, and the ultra-compact V152 and V153 all deliver surprisingly roomy interiors, clean cable management channels, and flexible drive mounts. Enthusiasts also have their eyes on the yet-to-appear V210, teased as a hybrid between the V213 M's showcase and the V158's streamlined profile.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Acer Arc B580/A380 and Radeon RX 9060 XT Graphics Cards Pictured
Acer released four new graphics cards in the Intel Arc and AMD Radeon lineups, and we found them on display in Acer's booth here at Computex 2025. The Acer Nitro Intel Arc B580 OC is now available in white, with 2x FrostBlade fans (alongside the existing black version). It features 12 GB memory running at up to 2,740 MHz with Intel Xe2 architecture, supporting 1440p gaming and 8K displays (1x HDMI 2.1 and 3x DisplayPort 2.1 outputs) with ray tracing, XeSS frame generation, and low latency technology. The Intel Nitro Arc A380 LP is a low-profile card with 6 GB memory, powered by one 8-pin PCIe connector and 2,000 MHz clocks, built on Xe architecture with DirectX 12 Ultimate support, ray tracing capabilities, and XeSS upscaling for content creation and gaming.
The two Acer Nitro Radeon RX 9060 XT OC models come in 16 GB and 8 GB variants, both delivering boost clocks up to 3,320 MHz and game clocks up to 2,780 MHz. Both models came in a two-slot format with dual-fans, metal backplates and 1x HDMI 2.1a and 2x DP 2.1 outputs.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Einarex Showcases Its Full Lineup of New Cases, Coolers and PSUs at Co
Einarex is a young company that seems to put a lot of effort into building its reputation. Since we saw them this year at CES Las Vegas, we stopped at their Computex booth to see what they've created since then. It seems that aside from the Prisma, Pulse, and Zenith PC case series, they have quite a few more interesting items, such as new cases, air and liquid coolers, fans and even power supplies under the Nexus and Apex series.
The Snow is a spacious tower case with full front and side glass panels. If you prefer a more classic design you can take a look at the Rack series that features a grille-style front panel, a glass side panel and a large display at the bottom. The Prisma series received the SM501D—slightly less inspired naming than Snow—a case that offers a panoramic view in a more compact format. Pulse series received a surprisingly good-looking PM200 "Small Frame, Big Game" case with perforated panels all over. Of course, their booth had the shiny-reflective Prisma S800 and the elegant Pulse PM400 with its wooden grille front panel up on display as we already saw them in January.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Wooting Brings its Latest 60HE v2 Keyboard to Computex
Wooting, the Hall effect keyboard specialist, brought its latest generation of keyboards to Computex 2025. We begin our tour with the new Wooting 60HE v2, which as its name suggests, is the second generation of its 60% keyboard with Hall effect key switches. In charge of the job are the new Lekker Tikken medium key switches, with a friction-fit mounting style, sitting on the company's FR4 switch plate, and encased in an aluminium body. The keyboard comes in black, white, and bright silver colors, and its electronics support 8,000 Hz polling. The keyboard measures 305 mm x 115 mm x 28.08 mm, weighing 960 g. The Wooting 60HE v2 is expected to release in Q4 2025.
The company also showcased its selection of knobs. A knob in this context is a keycap replacement that holds the Hall effect key switch in a precise actuated position as it is turned up or down along threading. The Wooting Big Knob measures 4U in size (covers four key spaces), while the small one measures a single key space. Both are expected to release in Q1 2026. Lastly, Wooting also showcased their Wooting x Optimum keyset, and aluminium-magnesium alloy (AL5052) casing.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
HAVN Showcases New Metal-core Fans and BF360 Low-noise Case
At Computex 2025, HAVN showcased its newest line of high-end case fans under the H-series. Features include a triple-groove fluid dynamic bearing in a metal alloy core; a harmonized impeller design that reduces the gap between the fan blade and the bore of the frame, to maximize axial airflow, frames as thick as 40 mm (for the 180 mm model), and impellers made from 30% fiberglass reinforced composite. There's even a male-to-female connection on the fan to help with cable management.
Next up, is the HAVN BF360, a premium ATX mid-tower case designed to minimize noise output while also balancing it with high airflow and a side window. The front of the case comes with vents for two large 180 mm intake fans hidden behind a dust filter. The drive bays have vibration dampening. The SSD and HDD mounts are detachable. The case includes a GPU bracket, and the 180 mm fans ensure positive internal air pressure. The area behind the motherboard tray is spacious, giving you ample room for cable management even with some of the thicker cables that are otherwise hard to bend.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
More pictures follow.[Only registered and activated users can see links. Click Here To Register...]
Framework Presents AI Mini PC Cluster and Customizable Laptops at Comp
At Computex 2025 in Taipei, Framework Computer highlighted the growing importance of compact, serviceable hardware by unveiling an AI cluster built entirely from its new Framework Desktop mini PCs. Each 4.5-liter unit is equipped with an AMD Ryzen AI Max+ 395 processor, which combines 16 Zen 5 cores running up to 5.1 GHz and a Radeon 8060S graphics engine with up to 128 GB of unified LPDDR5x memory. In a striking demonstration, four of these desktops were mounted side by side in a 10-inch half-rack enclosure, creating a scalable cluster that delivers up to 200 TOPS of on-device AI performance from the XDNA 2 NPUs alone, before the 8060S comes into play. The rack features integrated Wi-Fi 7 and 5 GbE networking, while its modular expansion card slots allow users to tailor ports to their exact needs. By packaging powerful inference capability into a compact, repairable chassis with efficient cooling and low power draw, Framework is making it simpler for research labs, small businesses, and edge-computing enthusiasts to deploy AI solutions outside traditional data centers.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Valkyrie Shows Off Coolers, Cases and Peripherals at Computex 2025
We couldn't miss Valkyrie's colorful booth at this year's Computex where they showcased new and updated liquid and air CPU coolers, a new case, and some peripherals that are for the moment in the final stages of development. Let's start with the V360 and V240 AIOs, which feature a large rectangular 3.5-inch IPS display integrated into the pump. The coolers are equipped with Valkyrie's latest B12 series 120 mm ARGB fans—three on the V360 and two on the V240. These 25 mm thick fans operate at speeds ranging from 800 to 2150 RPM, offering a maximum airflow of 81.68 CFM, a noise level of up to 30.5 dB(A), and a static pressure of 4.0 mm H₂O. As for pricing, the V360 is set to retail at €249.90, while the V240 will be priced at €219.90. Also on display were other recently launched AIOs from Valkyrie's V Lite and A series.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
EK's Latest AIO: Pump, Reservoir, & Dual 120 mm Radiators in One Packa
EK Water Blocks showed us an exciting solution at their Computex 2025 booth, with the unveiling of its Quantum Surface Kinetics 240, an all-in-one liquid‐cooling kit that marries two 120 mm Quantum Surface radiators with the company's signature Quantum Kinetic pump-and-reservoir module. The dual‐radiator array leverages a thin, high‐density micro-fin design to allow for ample heat dissipation while remaining just 30 mm thick—ideal for cramped mid-tower builds or even ITX systems. At the heart of the loop sits EK's Quantum Kinetic DDC pump and reservoir combo, now showcased in a newly refined, transparent acrylic housing. The integrated fill port and machined aluminium top cap feature customizable RGB channels, while the visible coolant pathways highlight EK's precision flow engineering. EK has pegged the Quantum Surface Kinetics 240 at an MSRP of $360. While not being like a traditional AIO design, it will allow PC enthusiasts to get much more creative with their water-cooling setups and both and reduce the setup difficulty of custom loops.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) SK hynix Presents Groundbreaking AI & Server Memory Solutions at
SK hynix presented its leading memory solutions optimized for AI servers and AI PCs at Dell Technologies World (DTW) 2025 in Las Vegas from May 19-22. Hosted by Dell Technologies, DTW is an annual conference which introduces future technology trends. In line with DTW 2025's theme of "Accelerate from Ideas to Innovation," a wide range of products and technologies aimed at driving AI innovation was showcased at the event.
Based on its close partnership with Dell, SK hynix has participated in the event every year to reinforce its leadership in AI. This year, the company organized its booth into six sections: HBM, CMM (CXL Memory Module)-DDR5, server DRAM, PC DRAM, eSSDs, and cSSDs. Featuring products with strong competitiveness across all areas of DRAM and NAND flash for the AI server, storage and PC markets, the booth garnered strong attention from visitors.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Synology Announces PAS7700, Active-Active NVMe Storage for Enterp
Synology today unveiled PAS7700, an active-active NVMe all-flash storage solution engineered to deliver uninterrupted high-performance services for enterprise mission-critical workloads. Combining dual-controllers with 48 NVMe SSD bays in a space-efficient 4U chassis, PAS7700 scales seamlessly to 1.65 PB of raw capacity with the addition of seven expansion units. PAS7700 features comprehensive support for a range of file and block protocols including NVMe-oF. With redundant memory upgradable to 2,048 GB across both controllers and support for high-speed 100GbE networking, PAS7700 delivers exceptional performance, availability, and scalability to meet enterprise storage demands.
"PAS7700 is the culmination of Synology's 25 years of engineering experience in data management and storage," said Kenneth Hsu, Director of the System Group at Synology. "By combining our deep software and hardware development expertise with close collaboration with partners and enterprise customers, we've engineered PAS7700 to deliver ultra-high performance at a price point previously unseen in the enterprise storage market."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Biwin Showcases its Latest Memory and Storage Products at Computex 202
Biwin over the years has emerged as a major OEM of DRAM and NAND flash consumer products, selling innovative new hardware not just under its own brand, but also supplying them for top-tier PC OEMs, such as Acer and HP. At Computex 2025, we went hands on with their latest products that they directly sell under the Biwin marquee. Starting off things, is the Biwin X570, a high-end M.2 NVMe Gen 5 SSD that comes in capacities of 1 TB, 2 TB, and 4 TB, with sequential performance of up to 14.5 GB/s reads, with up to 11 GB/s writes. Next up, is the X570 PRO, a step up from the regular X570, which offers increased sequential write speeds and NAND flash endurance.
While the regular X570 does up to 14.5 GB/s reads with up to 11 GB/s writes, the X570 PRO offers up to 14 GB/s reads, with up to 13 GB/s writes. It also comes with increased endurance of 750 TBW, 1500 TBW, and 3000 TBW for the 1 TB, 2 TB, and 4 TB variants, respectively, compared to the 600/1200/2400 TBW respectively, of the regular X570. The X570H PRO is basically the same drive, but with an added heatsink.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Jonsbo Reveals Small Form Factor Cases and More Cases at Computex 2025
Here in Jonsbo's booth at Computex 2025 we discovered two new Small Form Factor ITX NAS "style" cases, the NV10 and N10. These compact cases support ITX motherboards and Flex PSUs up to 150 mm. The NV10 is oriented more towards users who want to build a compact PC by offering support for a dual-slot graphics card. The N10, on the other hand is focusing on storage with support for four 2.5-inch drives and cooling fans for SSDs. Another SFF-oriented case is the V12, a microATX case with three-sided glass panels and wood accents.
From Jonsbo's T series they showcased the T9 that sports a modular design with removable metal and wood panels. Going further down the series there are also the T7 and T6, both following a similar design, with the T6 being a compact micro ATX model.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Silicon Motion Showcases a Fast DRAMless SSD Controller and More at Co
Silicon Motion at the 2025 Computex showed off its latest SSD and flash storage controller products. The star-attraction is the company's new SM2504XT, a DRAMless client NVMe SSD controller. The chip is built on the TSMC 6 nm process, with a power draw of just 2.4 W when active, and 1 mW when idling. The controller features 4 flash channels with 16 control elements, each with up to 3600 MT/s transfer speeds. It supports 3D TLC and 3D QLC NAND flash types from popular vendors. The reference SSD based on the SM2504XT was shown offering maximum sequential read speeds of 11.5 GB/s, and max sequential writes of 11 GB/s; with 1.7 million IOPS 4K random reads, with up to 2 million IOPS 4K random writes.
Next up, is the SM8366 enterprise SSD controller designed for PCI-Express Gen 5 x4 host interface across popular form-factors such as U.2, E1.S, and E3.S, including some extreme capacity drives. A demo drive showcased in the Silicon Motion booth had the NAND flash components spanning two PCBs that are interconnected by a ribbon cable. There are other interesting onboard devices such as DRAM cache, and capacitor-based power-loss protection. This controller was shown posting sequential read speeds of 14710 MB/s with QD128, and sequential writes of 3444 MB/s with QD128; and a sensational 3 million IOPS 4K random reads at QD512.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Pictures of the SM8366 and its performance follow.[Only registered and activated users can see links. Click Here To Register...]
AeroCool Debuts Three New PC Cases at Computex 2025
AeroCool unveiled three new PC cases at Computex 2025 and our team was at their booth to get a first look at them. The lineup includes the D520A, P500A, and P500B-Digi, all featuring support for reverse connector motherboards and enhanced airflow. The P500B-Digi is built with full tempered glass panels (front and side with quick-release) and features an integrated pixel display that monitors system parameters like time, CPU and GPU temperatures, and power consumption. The case supports dual 360 mm AIO radiators on top and on the side, accommodates up to ten 120 mm fans, and comes preinstalled with three side-mounted reverse ARGB PWM fans and one rear standard fan. It can house GPUs up to 418 mm and CPU air coolers up to 165 mm.
The D520A stands out with twelve fan slots and ventilated metal grill panel, while the P500A offers a more streamlined nine fan slots with dual curved glass panels. Both models include four APNX ARGB fans, airflow-optimized PSU shroud designs, and GPU support brackets to handle heavy graphics cards. They offer removable panel design across front, top, and side sections provides easy access for installation and maintenance.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Sapphire China Opens Up Radeon RX 9060 XT 16/8 GB Card Pre-orders, Sta
Prior to AMD's official unveiling of the Radeon RX 9060 XT series, [Only registered and activated users can see links. Click Here To Register...] a forthcoming lineup of custom graphics card options. Hours later, the TechPowerUp crew inspected [Only registered and activated users can see links. Click Here To Register...]. To the surprise of many, the Hong Kong-based manufacturer is readying a premium [Only registered and activated users can see links. Click Here To Register...] NITRO+ SKU for launch time (on June 5). The usual suspects—in PULSE and PURE guises—were also exhibited within the walls of the Taipei Nangang Exhibition Centre. Not long after the closing of ceremonies, Sapphire China's JD.com store has opened up pre-orders for six launch day products.
Yesterday, a VideoCardz investigative piece delved into pre-release price points (including VAT). Keen potential customers can secure finalized retail units via a deposit system; demanding a 50 RMB (~$7 USD) upfront fee. Unsurprisingly, the largest tag is affixed to Sapphire's triple-fan 16 GB NITRO+ model—3299 RMB (~$458 USD). This top-tier option sits 800 RMB above Team Red's suggested guideline. The AIB's barebones dual-fan Radeon RX 9060 XT PULSE [Only registered and activated users can see links. Click Here To Register...] package adheres to official MSRP: 2499 RMB (~$347 USD). Their PULSE 16 GB model sits almost in the middle of the lineup—in terms of pricing—at 2899 RMB (~$402 USD). VideoCardz believes that another PULSE color/finish variant will emerge, at some point post-launch—bringing the total number of items up to seven distinct products.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) NVIDIA DLSS 4 Comes to F1 25 and More Games
More than 700 games and applications feature RTX technologies, and each week new games integrating NVIDIA DLSS, NVIDIA Reflex, and advanced ray-traced effects are released or announced, delivering the definitive PC experience for GeForce RTX players.
As of today, DLSS 4 with Multi Frame Generation is now available in Avowed, EVERSPACE 2, F1 25, STORROR Parkour Pro, The Last of Us Part II Remastered, Torque Drift 2, and Wreckfest 2, multiplying frame rates for GeForce RTX 50 Series gamers, and enabling other GeForce RTX gamers to accelerate performance with DLSS Frame Generation and DLSS Super Resolution. Additionally, Game of Thrones: Kingsroad and Revenge of the Savage Planet are available now with DLSS Super Resolution.[Only registered and activated users can see links. Click Here To Register...]
(PR) Corsair Launches New Corsair ONE i600 PC
Corsair, a leading global developer and manufacturer of high-performance gear and technology for gamers, content creators, and PC enthusiasts, is proud to launch the Corsair ONE i600 PC, the latest compact powerhouse PC in the award-winning Corsair ONE PC line. Building on the success of the Corsair ONE i500, the new i600 delivers even more power, efficiency, and thermal performance—perfect for creators, AI developers, and gamers who demand cutting-edge capability in a space-saving form factor.
The Corsair ONE i600 takes performance to a new level with the GeForce RTX 5080 graphics with 16 GB VRAM and Intel Core Ultra 9 processor—both kept cool by individual 240 mm liquid coolers that deliver quiet operation and brilliant performance. Equipped with 64 GB DDR5 memory and 4 TB NVMe SSD storage, the Corsair ONE i600 minimizes load times, streamlines AI workflows, and delivers seamless 4K gaming experience—encased in a sleek aluminium chassis that complements any modern setup.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
