Is it possible to play Youtube videos on this enigma?
Thanks for the help so far.Quote:
It is working now. First it was my problem to start reading this thread from the bottom...
I must not start upgrading oscam 3520 to a newer version but just stick to the tools you build within the image. And If I read more carefully:
Download the emu AND download the config files from the menu.
Then change the oscam.server to your needs...
Second, stop sharing on the other sat tuner...
My cccam-server won't log me in a second time.
After I stoped the dm800hd in the living room, the Amiko in the bedroom, were i was practicing the amiko, worked.
Thanks again and keep up the good work!
Dupa multe chinuri si batai de cap am ajuns la un rezultat Amiko isi merita toti banii daca faci setarile bine se comporta ca un drem
am inteles ca are ceva si in plus fata de drem si anume oscam . In e2 l am configurat si se comporta foarte bine , dar mai este de
studiat anumite aspecte. Tin sa le mulumesc tuturor celor care ne au invatat pasi mihaip,zildan,stargate si care au avut rabdarea de
a ne invata .Dupa 2 ani am reusit sa mi vad visul,in afara de forum nu am avut cu cine discuta.
Inca o data va multumesc si va doresc SARBATORI FERICITE?
---------- Post added at 23:25 ---------- Previous post was at 23:00 ----------
PS Sa editati un forum numai in engleza separat
ma bucur bogdane ca esti multumit de extraterestru
Am incarcat imaginea...si apare Loading Modules...o eternitate...apoi iar boot...si tot asa...schimb cu spark e ok...vreau sa pun sa ruleze enigma 2 iar Loading Modules si nu apare nimic pe tv...
Am pus enigma 2 cu cisco TFTP Server
Vezi ca exista si v1 la aceasta imagine.
V1 este aparuta special pentru aparatele cu problema reboot!
Am mai facut ceva...si mi-a aparut o telecomanda pe tv...am pus e2_Alien_RSP200_G1987.rar...ce trebuie sa mai fac? Am dat reboot...apare doar scris pe receptor: rSP...imagine neagra pe tv.
P.S: Am reusit. Multumiri lui @stargate.
Mda...incep problemele...
1. E imposibil sa configurez Nameserver...eu pun 192...el imi zice ca pun 112...orice pun el pune alte cifre..eu pun un singur 1 el pune doua cifre de 1....ce imi place !!
:comp:
Mi-nu-nat!
@Meridian
Editeaza cu ceva care nu schimba tipul fisierului (din unix in DoS) :
/usr/lib/enigma2/python/Plugins/Extensions/Fantastic/addons.sh
schimba :
ping -c 1 [Only registered and activated users can see links. Click Here To Register...]
cu
echo ok
THX @ZILDAN (CENTURA NEAGRA):clap::clap:
@Meridian
E un bug in drivere la ultima imagine publica.
Editeaza fila /etc/resolv.conf si scapi de problema de la NS
Hi, i've also the new version RSP 1987 in my Edisio Pingulux and i've a Tivusat card but i don't know how configure the interbal reader. What i've to do to use this card in my Pingulux like the other decoder certified for TIVUSAT?
Thanks !!!!!
ElCubano
Under E2 ... not yet ! but you can use it under Spark using Oscam without problems ~!
Ce setari trebuie facute sa functioneze in DiSEqC1.2, pe modul avansat este bine?
raspuns : Este OK ! dupa care te duci si aloci LNB1 tuturor satellitilor pe care-i doresti
alegi pentru acest LNB modul de comanda DiseqC 1.2 si rand pe rand atribui pozitia
corespunzatore fiecarui satelit ...pozitie anterior memorata sau care urmeaza s-o memorezi !
multumesc
O chestie ciudata daca las pe modul singular merg toate canalele iar cand trec pe modul avansat
nu imi mai merg anumite canale
raspuns : manifestarea pe care o relatezi nu are nici o legatura cu modul antenei !!!
reflecta doua situatii diferite de acces la acele canale ! "nu merg" nu spune nimic !!!
nu au semnal ? nu se decodeaza ? ... daca au semnal ...nu modul antenei este vinovat !
look at this can help somehowQuote:
greetings and thanks
Dupa un timp mai lung imi dispare imaginea am semnal pe toate canalele si trebuie sa il opresc de la butonul din spate.Am setat asa:
[dvbapi]
enabled = 1
au = 1
boxtype = dreambox
user = kathy
pmt_mode = 1
Daca instalez iar softu trebuie sa memorez iar toti satelitii?
Foloseste modul video 720p ! in 1080i sint proleme ...una este cea semnalata de tine !
@bogdan007
Pe 720p sau 1080p e mult mai stabil aparatul.
Nu trebuia sa il opresti de la buton, puteai sa dai un restart din meniu.
Pot sa va anunt ca urmatoarea imagine va avea player2 191, (mult mai stabil, eu nu am mai reusit pe 720p sa il blochez) ceasul hardware si deep standby.
Am dat reset la router...si mi-a luat ip automat. Intrebare: unde pun oscam.config? De unde iau oscam?
Friends, after choose hd_glass16 skin in menu the Amiko Alien stop at booting screen and doesn't boot. Any suggestions how to run enigma2?
killall -9 enigma2 doesn't work during booting
EDIT:
Ok, I deleted hd_glass16 folder by FTP and now is ok. But this skin still doesn't work for me.
