http server in DVB Viewer
Tocmai am descoperit si eu in folderele DVB Viewer o arhiva zip http server v1.5.0
Intrebare de incepator:acesta este cumva un newcs?
Se poate conecta cu el cumva la servere de sharing free sau se poate face cardsharing printr-o configurare corespunzatoare?
In acest caz,ce altceva ar mai trebui descarcat in plugin sa functioneze?
Multumesc
Format 16:9 in DVB Viewer pt HD chanels
Cum se pot face in DVB Viewer ca programele HD transmise in 4:3 sa poata fii vizionate in 16:9?Pentru ca pentru programele SD transmise in 4:3 merge daca te duci in Option--Display-- si de acolo setezi 16:9,dar nu reusesc deloc sa le fac pe alea HD sa poata fii vizionate pe tot ecranul.
Multumesc
Latest Version of DVB Viewer
DVBViewer Pro 4.9.6.20
The changelog:
- Fix: ATSC/AC3 Detection: Added several fixes for ATSC AC3 detection.
- Fix: 125% Font size: Added support for 125% font size to the status bar and the playback control window.
- Fix: EPG Window / Timeline: The Timeline display is updated correctly now if the splitter between timeline and EPG details is moved.
- Fix: EPG Window / Timeline: Fixed the flickering on redrawing the timeline.
- Fix: EPG Window / Timeline: The row height and count is now calculated based on the font size.
- Fix: EPG Window / Timeline: Added support for 125% font size.
- Change: EPG Fenster: Converted the filter popup menu into a select list.
- Fix: EPG-Parser: Fixed wrongly as Japanese interpreted EPG with the language indicator "jpn" but English content.
- Change: EPG Display: The "exclude from EPG" flag is obsolete.
- Change: Channel List Editor: Removed the "exclude from EPG" check box.
- Change: Channel List Editor: Added a RDS check box.
- Update: Transponder lists: Updated the Astra 19.2 E transponder list.
- Update: Default SAT Channel list: Added the new German HD channels.
dvbviewer ultima versiune
Arunca o privire >>[Only registered and activated users can see links. Click Here To Register...]<<.
