Oscam-1.00-svn3563
Changeset #3558:
Message: oscam.c No need to search for reader, simplified code
Changeset #3559:
Message: unlimited readers step 1: put readers in list
Changeset #3560:
Message: max amount of groups extended from 32 to 64
Changeset #3561:
Message: add an extra test on cw crc before doing an AES decrypt as some CW aren't encrypted even if the D2 nano is present)
Changeset #3562:
Message: anticascader small fix
Changeset #3563:
r3571 | schlocke | 2010-10-16 15:07:47 -0700 (Sat, 16 Oct 2010) | 2 lines
fixed small cleanup bug: crash on user disconnect
r3570 | rorothetroll | 2010-10-16 14:23:22 -0700 (Sat, 16 Oct 2010) | 1 line
fix provider id extraction for cw emm-g
Oscam-1.00-svn3590
Changeset #3572:
Message: monitor: fix missing lines
Changeset #3573:
Message: unlimited readers step 2: oscam.c remove some CS_MAXREADER loops
Changeset #3574:
Message: unlimited readers step 3: oscam.c remove some more CS_MAXREADER loops
Changeset #3575:
Message: unlimited readers step 4: oscam.c remove last CS_MAXREADER loops
Changeset #3576:
Message: unlimited readers step 5: oscam-config.c remove CS_MAXREADER loops
Changeset #3577:
Message: New threadsafe singularly linked list data structure header
Changeset #3578:
Message: fixed small cleanup bug
Changeset #3579:
Message: Adding LogHistory? to config script
Changeset #3580:
Message: oscam-config.c: Optimize examining reader type
Changeset #3581:
Message: dvbapi: move priority settings to a separate file
Changeset #3582:
Message: unlimited readers step 6: oscam-http.c remove CS_MAXREADER loops
Changeset #3583:
Message: unlimited readers step 7: cccam remove CS_MAXREADER loops
Changeset #3584:
Message: LLIST updated
Changeset #3585:
Message: unlimited readers step 8: newcamd remove some CS_MAXREADER loops
Changeset #3586:
Message: unlimited readers step 9: newcamd remove last CS_MAXREADER loops
Changeset #3587:
Message: according to iso7816-3 if no TD1 then only protocol TO is available, so do not attempted PPS if there is no TD1, fix prevents PPS being attempted on some cards that do not have PPS
Changeset #3588:
Message: fix emm cache bug
Changeset #3589:
Message: unlimited readers step 10: module-stat.c remove CS_MAXREADER loops
Changeset #3590:
Message: loadbalancer: fixed "retrying reader" message
Oscam-1.00-svn3599
Changeset #3591
Message: correction of small error re bit 8 in TA2, thanks dingo
Changeset #3592
Message: Rename of LLIST->LLIST_D_ is preparation for new (safe) LLIST code swtichover
Changeset #3593
Message: New LLIST routines (still needs valgrind checking
Changeset #3594
Message: Memleak fixes for new LLIST code (valgrind passed)
Changeset #3595
Message: struct name change because of conflicts with new llist code
Changeset #3596
Message: llist: insert_at fcn
Changeset #3597
Message: rename llist source files for build
Changeset #3598
Message: llist fixes
Changeset #3599
Message: WebIf: fix for readerview
r3601 | cogsi | 2010-10-17 09:01:21 -0700 (Sun, 17 Oct 2010) | 1 line
stat now uses now llist
r3600 | cogsi | 2010-10-17 08:50:19 -0700 (Sun, 17 Oct 2010) | 1 line
cccam module now uses new threadsafe llist (expect this to be broken at various points)
r3606 | rorothetroll | 2010-10-17 19:26:33 -0700 (Sun, 17 Oct 2010) | 1 line
fix a typo in a debug message
r3605 | rorothetroll | 2010-10-17 19:21:32 -0700 (Sun, 17 Oct 2010) | 1 line
added oscam-datastruct-llist.[c,h] to XCode project for OS X
r3604 | rebdog | 2010-10-17 17:07:47 -0700 (Sun, 17 Oct 2010) | 1 line
add a few new atrs, closes #751
r3610 | merek | 2010-10-18 02:44:17 -0700 (Mon, 18 Oct 2010) | 1 line
Fix Maketype
r3609 | merek | 2010-10-18 02:42:56 -0700 (Mon, 18 Oct 2010) | 1 line
Rename datastruct-llist, as CMakeFile includes module-* as csmodules
r3608 | _network | 2010-10-18 02:01:21 -0700 (Mon, 18 Oct 2010) | 2 lines
dvbapi: fix #1084
Oscam-1.00-svn3615
Changeset #3611
Message: ll_iter_peek()
Changeset #3612
Message: fix for cccam: next_card
Changeset #3613
Message: fixed segfault in ll_insert_at()
Changeset #3614
Message: unlimited readers step 11: replace client->ridx by client->reader
Changeset #3615
Message: reader-nagra.c : remove duplication of code, switch keynr 01 and 00 for NA
Oscam-1.00-svn3619
Changeset #3616
Message: cccam: fixed version overflow
Changeset #3617
Message: WebIf: fixed reader re-start from webif side. Attention the reader becomes restarted but becomes doubled in reader list. This have to be fixed in void restart_cardreader(struct s_reader *rdr, int restart) the killed reader must removed from readerlist.
Because dingo restructures the readers this moment I'll don't touch his code to avoid conflicts
Changeset #3618
Message: fix write_server() removing protocol from disabled reader
Changeset #3619
Message: fix for last commit
r3624 | rorothetroll | 2010-10-18 14:50:39 -0700 (Mon, 18 Oct 2010) | 1 line
fixing a small typo in the list_smargo message
r3623 | rorothetroll | 2010-10-18 14:46:14 -0700 (Mon, 18 Oct 2010) | 1 line
path for list_smargo. you can now pass an out endpoint value : list_smargo 0x81 . If no value is passed, it'll use the default 0x82 out endpoint address
r3622 | rorothetroll | 2010-10-18 14:24:43 -0700 (Mon, 18 Oct 2010) | 1 line
more fix for smartreader code for Infinity smart usb on windows
r3629 | dingo35 | 2010-10-19 05:53:47 -0700 (Tue, 19 Oct 2010) | 1 line
reader-nagra.c : Add 0x29 command for N3_NA
r3628 | dingo35 | 2010-10-19 01:11:52 -0700 (Tue, 19 Oct 2010) | 1 line
reader-nagra.c: Add do_ecm for N3_NA
Oscam-1.00-svn3633
Changeset #3630
Message: fixed (t1094) - no LB statistics in Reader-Section of WebIf
Changeset #3631
Message: fixed loadbalancer, fixed cccam
Changeset #3632
Message: named trunk versions as unstable - remove before release
Changeset #3633
Message: fix newcamd crash #1101
r3640 | rorothetroll | 2010-10-19 16:41:29 -0700 (Tue, 19 Oct 2010) | 2 lines
some viaccess emm processing changes. Patch provided by Hot. Tested by him and working on his card.
r3639 | alno | 2010-10-19 14:46:21 -0700 (Tue, 19 Oct 2010) | 1 line
WebIf: removed last reader[ridx] fragments from http.c
r3641 | dingo35 | 2010-10-20 02:35:26 -0700 (Wed, 20 Oct 2010) | 1 line
reader-nagra.c : simplify N3 code
Oscam-1.00-svn3642
Changeset #3642
Message: fix for ticket 1114
