b-parasite Bluetooth LE plant sensor gets Zigbee support
rbaron’s b-parasite is an open-source hardware Bluetooth LE plant watering sensor that can measure soil...
T-Head XuanTie C908 RISC-V core targets AIoT applications
We’ve seen two announcements of high-end RISC-V cores this week with the SiFive P670 and...
MeLE PCG02 Pro mini PC stick supports M.2 NVMe or SATA SSD
MeLE PCG02 Pro is a mini PC stick / PC-on-a-stick powered by either an Intel...
Andes unveils AndesCore AX65 Out-of-Order RISC-V core for compute intensive applications
Andes Technology has unveiled the high-end AndesCore AX60 series out-of-order 64-bit RISC-V processors at the...
Axiomtek iNA200 DIN-Rail cybersecurity gateway offers 6x Ethernet ports up to 2.5GbE
Axiomtek iNA200 is a DIN-rail mountable cybersecurity gateway powered by a choice of Elkhart Lake...
Learn soldering and programming with the Arduino Make Your UNO Kit
Arduino Make Your UNO Kit is a kit with two boards, one for the microcontroller...
DongshanPI-D1s – An Allwinner D1s RISC-V development board designed to teach programming
The DongshanPI-D1s development board is comprised of a soldered-on Allwinner D1s RISC-V system-on-module board (SoM)...
Quadric Chimera GPNPU IP combines NPU, DSP, and real-time CPU into one single programmable core
A typical chip for AI or ML inference would include an NPU, a DSP, a...
SiFive P670 and P470 RISC-V processors feature RISC-V Vector Extensions
SiFive has announced two new RISC-V Performance cores with the P670 and P470 processors with...
System-on-module combines NXP i.MX 8M Mini Arm CPU and Xilinx Artix-7 FPGA
MYIR Tech has launched the MYC-JX8MMA7 system-on-module combining an NXP i.MX 8M Mini quad-core Arm...
Review of myCobot 280 Pi robotic arm with Python and visual programming
myCobot 280 Pi is a versatile robotic arm with a 6 degree of freedom design....
TinyML-CAM pipeline enables 80 FPS image recognition on ESP32 using just 1 KB RAM
The challenge with TinyML is to extract the maximum performance/efficiency at the lowest footprint for...
SMLIGHT SLZB-06 – A Zigbee 3.0 to Ethernet, USB, and WiFi adapter with PoE support
Startup SMLIGHT has launched the SLZB-06 Zigbee 3.0 to Ethernet, USB, and WiFi adapter with...
LILYGO T7-S3 ESP32-S3 board with 16MB flash, 8MB PSRAM, LiPo battery support sells for under $10 (Promo)
LILYGO has launched another ESP32-S3 development board. The T7-S3 is equipped with an ESP32-S3-WROOM-1 module...
SONOFF NSPanel Pro control panel review with Zigbee modules, CAM Slim WiFi camera
ITEAD has sent us a Smart Home kit for review including the SONOFF NSPanel Pro...
LOLIN C3 Pico is a tiny ESP32-C3 board with battery charging support
LOLIN C3 Pico is a tiny (25.4×25.4mm) ESP32-C3 RISC-V board with 2.4 GHz WiFi and...
NanoPi R6S – A Rockchip RK3588S router and mini PC with dual 2.5GbE, GbE, and… HDMI 2.1
FriendlyELEC has launched its sixth generation router with the NanoPi R6S equipped with a Rockchip...
Easily add face detection to your project with the Person Sensor module
It’s now much easier to AI features to your project thanks to better tools, but...
WiFi HaLow IoT gateway is based on Morse Micro MM6108 802.11ah chip
Most WiFi HaLow hardware platforms we’ve seen so far are based on Newracom chips, but...
WBZ451 Curiosity Board features Microchip PIC32CX-BZ2 BLE and Zigbee 3.0 microcontroller
Microchip WBZ451 Curiosity Board features the company’s Microchip’s WBZ451PE Bluetooth Low Energy 5.2 and Zigbee...
Rockchip RK3588S industrial mini PC features CAN Bus, RS485 & RS232 interfaces, relay, and more
Firefly EC-R3588SPC industrial mini PC is based on the Rockchip RK3588S octa-core Cortex-A76/A55 processor and...
Brume 2 – OpenWrt “security gateway” with MediaTek MT7981B SoC supports WireGuard VPN
GL.inet Brume 2 is an OpenWrt router, or rather a “security gateway” as the company...
uConsole is a modular Arm or RISC-V handheld computer with optional 4G connectivity
Clockwork’s uConsole is a modular handheld computer with a 5-inch display, a built-in keyboard, and...
Adapters convert Raspberry Pi Zero 2 W into Raspberry Pi 3 or 4
Spotpear’s Raspberry Pi Zero 2 W to Raspberry Pi 3/4 adapters would not exist in...
$600 Windows Dev Kit 2023 is powered by Qualcomm Snapdragon 8cx Gen 3 processor
Microsoft has just introduced the Windows Dev Kit 2023, that’s basically a Windows 11 Arm...
Elecrow – Make Your Making Easier (Sponsored)
Elecrow was officially founded in 2014, and is located in Shenzhen city. Elecrow is a...
Automation 2040 W board supports 6V to 40V I/Os, ships with Raspberry Pi Pico W
Pimoroni Automation 2040 W is an industrial/automation controller based on the Raspberry Pi Pico W...
T-Dongle-S3 USB dongle combines ESP32-S3 wireless MCU with optional color display
LilyGO T-Dongle-S3 is a USB dongle based on ESP32-S3 dual-core microcontroller with WiFi 4 and...
Miniature Raspberry Pi CM4 carrier board only exposes USB-C port and 40-pin GPIO header
Mirek Folejewski’s (aka Mirko Electronics) PicoBerry is an open-source hardware, miniature Raspberry Pi CM4 carrier...
Innodisk releases USB camera modules for AI applications
Innodisk, better known for its industrial storage solutions and embedded peripherals, has recently announced a...
10 cents CH32V003 RISC-V MCU offers 2KB SRAM, 16KB flash in SOP8 to QFN20 packages
WCH CH32V003 is a new ultra-cheap RISC-V microcontroller (MCU) clocked at 48 MHz with 2KB...
MS2130 based “4K” HDMI to USB 3.0 video capture dongle sells for $19
4K HDMI to USB 3.0 dongles based on Macrosilicon MS2130 video and audio acquisition chip...
RP2040 firmware converts Raspberry Pi Pico into a an I2C to USB bridge
Nicolai Electronics’ rp2040-ic2-interface open-source firmware for the Raspberry Pi Pico (or other Raspberry Pi RP2040...
Giveaway Week – NanoPi R5S router
It’s that time of year… CNX Software giveaway week! For the 9th edition, we’ll have...
Beelink SEi12 Alder Lake mini PC review with Windows 11, Ubuntu 22.04
Beelink have launched their first Intel Alder Lake mini PC calling it the SEi12. Featuring...
Getting started with e-CAM20_CURB camera for Raspberry Pi 4
e-con Systems e-CAM20_CURB is a 2.3 MP fixed focus global shutter color camera designed for...
Weibu N10 Review – An OEM Mini PC tested with Ubuntu 22.04, Windows 11
Weibu is a B2B company offering total solutions and OEM/ODM services. Their target clients are...
MediaTek unveils Dimensity 9200 Octa-core Cortex-X3/A710/A510 5G mobile processor
MediaTek has just launched the Dimensity 9200 octa-core flagship 5G mobile processor with one Cortex-X3...
Giveaway Week 2022 – Sonoff NSPanel Pro and Zigbee modules
The fourth prize of Giveaway Week 2022 is the Sonoff NSPanel Pro control panel with...
GL.iNet GL-MT2500A security gateway review – Part 1: Unboxing and teardown
The Brume 2 security gateway/router is powered by a MediaTek MT7981B (Filogic 820) dual-core processor...
Giveaway Week 2022 – Pico:ed Smart Cutebot Kit
The third prize of this year’s giveaway week comes courtesy of ELECFREAKS which offers a...
AXERA AX620A 4K AI SoC delivers up to 14.4 TOPS for computer vision applications
AXERA AX620A is a high-performance, low-power AI SoC with a quad-core Arm Cortex-A7 processor and...
ODROID-N2L is a smaller, low-cost variant of ODROID-N2+ Arm SBC
ODROID-N2L SBC is a smaller and cheaper version of the ODROID-N2+ single board computer powered...
T8-Pro Celeron N5095 mini PC offers triple HDMI output, dual Gigabit Ethernet
T8-Pro is a low-cost mini PC powered by an Intel Celeron N5095 Jasper Lake processor...
Giveaway Week – e-con Systems e-CAM20_CURB camera
Today, we’re giving away the e-con Systems e-CAM20_CURB is a 2.3MP color camera with a...
Starfish PnP machine control board combines Raspberry Pi RP2040 MCU wi
We’ve already seen the Raspberry Pi RP2040 MCU in a 3D printer controller board, so...
NVIDIA Jetson Nano based AI camera devkit enables rapid computer vision prototyping
ADLINK “AI Camera Dev Kit” is a pocket-sized NVIDIA Jetson Nano devkit with an 8MP...
MediaTek Kompanio 520 and Kompanio 528 processors targets entry-level Chromebooks
MediaTek Kompanio 520 and Kompanio 528 octa-core Arm processors are designed for entry-level Chromebooks with...
DIY air quality monitor is based on Wemos D1 mini ESP8266 board, Sensirion SGP41 TVOC sensor
Open AirGradient is a DIY air quality monitor based on the Wemos D1 mini ESP8266...
International Black Friday 2022 deals and coupons
We’ve been writing about international Black Friday and Cyber Monday deals and coupons since 2014,...
Arduino Opta is a micro PLC for industrial IoT applications
Arduino has recently announced the Opta micro PLC with industrial IoT capabilities adding yet another...
GOLE 1 R mini PC offers Rockchip RK3588 CPU, 5.5-inch touchscreen display
HIGOLE introduced the GOLE1 mini PC with a touchscreen display in 2015 mostly to get...
Giveaway Week 2022 winners announced!
CNX Software’s Giveaway Week 2022 has just ended, and it’s time to announce the winners....
FNIRSI 1013D teardown and mini review – A portable oscilloscope based on Allwinner CPU & Anlogic FGPA
The FNIRSI 1013D is a dual-channel flat-panel oscilloscope with a rich set of features. It...
Partaker J6412 is a fanless network appliance/mini PC with 3x 2.5GbE, 3x video outputs
We wrote about the low-cost T8-Pro Celeron N5095 mini PC with three HDMI outputs and...
Matter compatible ESP-ZeroCode modules enable plug-and-play automation solutions
Espressif Systems has just announced the Matter-compatible ESP-ZeroCode modules with Wi-Fi and/or Thread (802.15.4) wireless...
AMD unveils low-cost Artix UltraScale+ AU7P FPGA and Zynq UltraScale+ ZU3T MPSoC
AMD has added two new low-cost, low-power members to its UltraScale+ family with the Artix...
This is what a 100 µAh micro-battery looks like
Electronic components have shrunk a lot over the year, but batteries are usually one of...
Sipeed M1s & M0sense – Low-cost BL808 & BL702 based AI modules (Crowdfunding)
Sipeed has launched the M1s and M0Sense AI modules. Designed for AIoT application, the Sipeed...
Giveaway Week – Mekotronics R58 mini PC
Let’s end Giveaway Week 2022 with a bang, and more exactly a rather powerful Rockchip...
NanoPi R6S Review – Part 1: Unboxing, Teardown, OpenWrt 22.03, and iperf3
NanoPi R6S is a Rockchip RK3588S powered device that can not only work as a...
Giveaway Week – GL.iNet GL-S10 BLE to MQTT Gateway
The sixth prize of this year’s Giveaway Week will be GL.iNET GL-S10 BLE to MQTT...
Arduino Lab for MicroPython – An experimental cross-platform MicroPython IDE for Arduino boards
Arduino boards have traditionally been programmed with C-like language in the Arduino IDE, but with...
Orange Pi 5 Rockchip RK3588S SBC launched for $60 and up
Orange Pi 5 (LTS) is a single board computer powered by Rockchip RK3588S cost-down octa-core...
Giveaway Week – RAK Developer Kit (Air Quality Kit)
RAKwireless joined CNX Software’s Giveaway Week last year with the WisBlock Kit 2 LoRa-based GPS...
Bluetooth LE to support 6 GHz frequency band
So far, the popular Bluetooth wireless communication protocol would only rely on the 2.4 GHz...
Radxa E25 modular 2.5GbE router supports WiFi 6 and 4G/5G cellular connectivity
Radxa E25 is a modular router with two 2.5GbE ports based on the Radxa CM3...
Air32F103 is a clone of STM32F103 clocked at up to 216 MHz
Air32F103 is yet another clone of the STM32F103 microcontroller that can be faster if needed...
Elephant Robotics Black Friday 2022 Sales (Sponsored)
Here is the detail information about the Black Friday big sales in our official stores....
LinkStar H68K – A Rockchip RK3568 “multimedia” router with dual 2.5GbE, dual Gigabit Ethernet, WiFi 6
Linkstar H68K is a Rockchip RK3568 multimedia router with two 2.5GbE ports, two Gigabit Ethernet...
Optimize your thermal design with code_saturne open-source CFD softwar
code_saturne is a free, open-source computational fluid dynamics (CFD) software developed primarily by EDF that...
Banana Pi BPI-M6 SBC features SenaryTech SN3680 quad-core Cortex-A73 AI processor
Banana Pi BPI-M6 is an upcoming credit-card single board computer based on SenaryTech SN3680 SoC...
Innodisk EXMU-X261FPGA Machine Vision Platform is based on AMD Xilinx Kria K26 SoM
Innodisk, better known for its embedded storage and memory chips, had announced its intention to...
Qualcomm Snapdragon 8 Gen 2 SoC gets upstream Linux support
Qualcomm unveiled the Snapdragon 8 Gen 2 mobile platform just a few days ago, but...
EsPiFF board combines ESP32 module with RP2040 MCU in the Raspberry Pi 4 form factor (Crowdfunding)
The EsPiFF board may look like a Raspberry Pi 4 Linux SBC but it is...
Allwinner T3 automotive-grade processor powers industrial-grade SoM
Allwinner T3 is a quad-core Cortex-A7 automotive-grade processor that supports a wide industrial temperature range...
Creality CR-Scan Lizard Review – An easy-to-use 3D scanner
Hey, Karl here, and today we are going to review Creality’s CR-Scan Lizard. This device...
Bedrock V3000 Basic fanless industrial computer is powered by an AMD Ryzen Embedded V3000 processor
SolidRun Bedrock V3000 Basic is an industrial fanless computer based on the new AMD Ryzen...
Orange Pi OS – An Android-based desktop OS with Windows 11’s look and feel
The manufacturer of Orange Pi boards, Shenzhen Xunlong Software, has formally announced the release of...
Godeal24’s Black Friday: Get Genuine Windows 10 from $5.62, Office 2021 as low as $13.05! (Sponsored)
The annual Black Friday sale has come. Are you still looking for cheap and genuine...
MarsCat Elephants Robotics is selling some of its educational robotic kits and toys as part...
Brume 2 router review with WireGuard, OpenVPN, Tor, and Adguard Home
We started the review of GL.inet GL-MT2500A security gateway, aka Brume 2, with an unboxing...
RAK2560 WisNode LoRaWAN & BLE Sensor Hub ships with a choice for sensor modules
RAKwireless RAK2560 WisNode Sensor Hub is a modular sensor gateway based on the RAK4630 WisDuo...
AIoTBOX-3568GK industrial control box offers six USB ports, RS232, RS485, CAN Bus, LVDS, and more
SMDT AIoTBOX-3568GK is an industrial control PC powered by a Rockchip RK3568 quad-core Cortex-A55 AIoT...
TinyLlama x86 retro computer uses the Raspberry Pi Zero 2 W as a MIDI synthesizer
The TinyLlama x86 retro computer board is designed to run DOS games on a DM&P...
Sony ALT1350 5G cellular IoT chip supports NTN connectivity, integrates sub-GHz and 2.4GHz radios
Sony ALT1350 is a new ultra-low-power 5G LPWA LTE-M/NB-IoT chip that supports Non-Terrestrial Networks (NTN)...
Rikomagic RKM V7 – A Rockchip RK3568-powered Android 11 HDMI TV stick
Rikomagic RKM V7 is an HDMI TV stick running Android 11 on a Rockchip RK3568...
AMD Ryzen Embedded V2516/V2718 mini PC supports three 4K displays, 2.5GbE, RS232/RS422/RS485
AAEON PICO-V2K4-SEMI mini PC, powered by an AMD Ryzen Embedded V2516 or V2718 processor, can...
Radxa Taco – A Raspberry Pi CM4 carrier board made for NAS with 5x SATA ports
The Radxa Taco is a carrier board for Raspberry Pi CM4 and compatible system-on-modules that...
JX1 Intel Celeron N5105 mini PC places all ports on the rear panel
There’s a plethora of mini PCs on the market, but due to their size, the...
Allwinner V3LP gets low voltage RAM, should replace Allwinner V3S dual camera SoC
Allwinner V3LP is a single-core Cortex-A7 processor for dual-camera systems with the exact same specifications...
MSI MS-98M3 3.5-inch SBC is made for autonomous mobile robots
MSI is better known for its consumer-grade motherboard and mini PCs, but they also have...
Raspberry Pi RP2040 development board doubles as a magnetic rotary encoder
PICO DEV M3 is a round-shaped development board based on a Raspberry Pi RP2040 dual-core...
LOLIN S3 Pro ESP32-S3 board offers display port, MicroSD card slot
LOLIN S3 Pro is a WiFi & Bluetooth LE IoT board built around the ESP32-S3-WROOM-1...
Orange Pi launches 14-inch portable monitor for $59
Shenzhen Xunlong Software, better known under the Orange Pi brand, has launched a 14-inch Full...
RAK2560 WisNode LoRaWAN & BLE Sensor Hub ships with a choice of sensor modules
Innodisk EXMU-X261 FPGA Machine Vision Platform is based on AMD Xilinx Kria K26 SoM
PiTalk 4G HAT for Raspberry Pi / 4G USB dongle targets M2M and IoT app
PiTalk is a 4G cellular connectivity solution based on Quectel EG25-G LTE Cat 4 module...
PineBuds Pro ANC & TWS Bluetooth earbuds with open-source firmware launched for $70
Pine64 has just started taking orders for the PineBuds Pro ANC (Active Noise Cancellation) &...
Arducam OCam AI camera adds context to video streams in real-time with the PhysicO platform
Arducam OCam, whose name stands for Object Camera, is an AI camera with 3 TOPS...
$6 Pine64 Ox64 SBC features BL808 64-bit/32-bit RISC-V multi-protocol WiSoC with 64MB RAM
Pine64 Ox64 is a single board computer powered by Bouffalo Lab BL808 dual-core 64-bit/32-bit RISC-V...
Inkplate 2 is a 2.13-inch WiFi ePaper display programmable with Arduino or MicroPython (Crowdfunding)
Inkplate 2 wireless ePaper display is by far the smallest display from Soldered Electronics with...
NanoPi R5C mini router features two 2.5GbE ports, supports M.2 wireless modules
FriendlyElec NanoPi R5C is a smaller version of the NanoPi R5S router with the same...
Sipeed Maix-III devkit features AXERA AX620A SoC for AI vision applications
Sipeed Maix-III development kit is composed of a core board equipped with AXERA AX620A AI...
MeLE PCG02 Pro Review – A Fanless Intel Celeron J4125 / N5105 mini PC
MeLE has launched a new ‘stick’ mini PC called the PCG02 Pro. It comes in...
Armbian 22.11 released with 64-bit RISC-V UEFI, ultra minimal images support
Armbian 22.11 has just been released with three new SBCs, support for 64-bit RISC-V UEFI,...
$200 Swarm M138 kit enables two-way satellite connectivity for IoT projects
Sparkfun has launched a Satellite Transceiver Kit based on the Swarm M138 satellite and GNSS...
UniHiker education platform teaches STEM with Mind+ and Jupyter (in China)
DFRobot UniHiker is a STEM education platform with a 2.8-inch touchscreen display, a Rockchip RK3308...
GEEKOM’s Christmas promotion – Save $50 on Jasper Lake mini PCs (Sponsored)
Black Friday and Cyber Monday are done, but GEEKOM has started a Christmas promotion for...
DFI EC70A-TGU embedded computer promises long-term support until 2035 (at least)
Some industries require long-term support of hardware, and DFI’s EC70A-TGU rugged embedded computer could fit...
Getting Started with CrowBot BOLT smart robot car
CrowBot BOLT is a smart robot car based on an ESP32 wireless microcontroller and designed...
Cool Pi 4 Model B – A much faster alternative to Raspberry Pi 4 SBC
Cool Pi 4 Model B is a powerful alternative to Raspberry Pi 4 SBC with...
Mekotronics R58X-4G – A Rockchip RK3588 mini PC with 4G LTE and PoE su
Mekotronics R58X-4G is an update to the company’s R58X Rockchip RK3588 mini PC with support...
Lattice Avant mid-range FPGA platform features up to 500K logic cells, 25 Gbps SERDES, Hard PCIe Gen4
Lattice Avant is a new low-power and small form factor mid-range FPGA platform, manufactured with...
Bee Motion S3 – An ESP32-S3 board with a PIR motion sensor (Crowdfunding)
The Bee Motion S3 is an ESP32-S3 WiFi and Bluetooth IoT board with a PIR...
Gowin R86S mini PC offers 2.5GbE and 10GbE networking for $310 and up
Gowin R86S (aka GW-R86S) is an affordable Intel Celeron N5100 or Pentium N6005 Jasper Lake...
Arduino PLC IDE released for the Portenta Machine Control unit, and soon Opta micro PLC
The newly released Arduino PLC IDE supports the five languages defined by the IEC 61131-3...
Hand Gesture Recognition on ESP32-S3 with the ESP-DL library
Ali Hassan Shah has deployed a deep learning model for hand gesture recognition on the...
Add an ePaper display to Raspberry Pi Pico W with EnkPi 2.9-inch to 7.5-inch displays (Crowdfunding)
SB Components is running another crowdfunding campaign with the EnkPi ePaper display powered by a...
UP Xtreme i12 Alder Lake SBC supports up to four 4K displays @ 60 Hz, Raspberry Pi HATs
AAEON has just introduced the UP Xtreme i12 single board computer (SBC) with Intel 12th...
Aetina launches ASIC-based Edge AI system with a 16 TOPS Blaize P1600
Aetina AIE-CP1A-A1 is a compact, ASIC-based Edge AI system powered by the Blaize Pathfinder P1600...
Jlink WiFi 6 router sells for just $35 (Promo)
If you are interested in upgrading your wireless network to WiFi 6 but don’t want...
MeLE PCG02 Pro and Quieter3C Mini PCs giveaway
Giveaway Week 2022 ended about a month ago, but we’ve got a new surprise for...
Credit card-sized COM-HPC Mini modules to support PCIe Gen4 and Gen5 interfaces
PICMG has announced that the COM-HPC Mini form factor’s pinout and dimensions definitions were finalized,...
Alif Ensemble Cortex-A32 & Cortex-M55 chips feature Ethos-U55 AI accelerator
Alif Semiconductor’s Ensemble is a family of processors and microcontrollers based on Arm Cortex-A32 and/or...
Google ADT-4 could be a hybrid Android TV developer Kit with ATSC 3.0 and DVB-S2 TV tuners
Google is allegedly about to release the ADT-4 hybrid developer kit for Android TV based...
TwoTrees TS2 laser engraver review – Part 1: Unboxing and teardown
TwoTrees TS2 is a laser engraver with a 10W laser, and the company sent us...
Olimex AgonLight2 8-bit open-source hardware computer sells for 50 Euros
Olimex has started to take pre-orders for the AgonLight2, a customized version of the Agon...
Business card-sized SBC ships with Intel Core Tiger Lake or AMD Ryzen V2000 processor
We’ve recently reviewed the UP 4000 SBC as a more powerful x86 alternative to Raspberry...
JetHome JetHub D1+ automation controller runs Armbian with mainline Linux, supports Home Assistant
Earlier this year, we noted the addition of the JetHome JetHub D1 Linux-based home automation...
Sipeed LM4A – T-Head TH1520 RISC-V module to power Raspberry Pi 4 competitor and cluster board
Sipeed LM4A is a quad-core RISC-V system-on-module based on the T-Head TH1520 SoC found in...
Rockchip RK3588 system-on-module exposes 400 pins through high-density connectors
Forlinx FET3588-C is a relatively compact Rockchip RK3588 system-on-module measuring 68x50mm and exposing many of...
Open AI Lab EAIDK-610 devkit targets computer vision education with OpenCV
Open AI Lab EAIDK-610 is an embedded AI development kit powered by a Rockchip RK3399...
Raspberry Pi availability improves, “unlimited supplies” expected by H2 2023
The Raspberry Pi SBCs have been in short supply for a couple of years, especially...
Linux 6.1 LTS release – Main changes, Arm, RISC-V and MIPS architectures
Linus Torvalds announced the release of Linux 6.1, likely to be an LTS kernel, last...
OpenPLC open-source Programmable Logic Controller Suite works with Ard
OpenPLC is an open-source, free-to-use Programmable Logic Controller Suite, compliant with the IEC 61131-3 standard,...
TOOCA Laser L1 review – An affordable 5W laser engraver
ELECFREAKS’ TOOCA Laser L1 is an affordable 5W laser engraver with a sturdy yet lightweight...
LapPi 2.0 – A DIY laptop for Raspberry Pi 4 and other single board computers (Crowdfunding)
The LapPi 2.0 is a DIY laptop kit with an acrylic enclosure, a UPS HAT...
Elephant Robotics Christmas 2022 sales (Sponsored)
Elephant Robotics is back with another promotional event for Christmas 2022 selling educational robotic kits...
SpinQ quantum computers target the education market
Quantum computing promise a leap in the performance of applications relying upon parallelism using the...
PineTab2 Linux tablet to feature Rockchip RK3566 SoC, up to 8GB RAM, 128GB eMMC flash
The PineTab2 is an upcoming 10.1-inch Linux tablet based on the 1.8 GHz Rockchip RK3566...
Qualcomm QCX216 LTE Cat1 bis IoT-optimized modem integrates WiFi-based
Qualcomm QCX216 is a new IoT-optimized LTE Cat1 bis modem with a data rate of...
EdgeBox-ESP-100 – An ESP32-S3 industrial controller with RS485, CAN Bus, DIO, 4G LTE, and more
We’ve previously covered the EdgeBox-RPi4 industrial controller powered by a Raspberry Pi Compute Module 4...
ArduCam Mega – A 3MP or 5MP SPI camera for microcontrollers (Crowdfunding)
ArduCam Mega is a 3MP or 5MP camera specifically designed for microcontrollers with an SPI...
T-Camera S3 – An ESP32-S3 board with camera, display, PIR motion sensor, and microphone
LilyGO has launched a new ESP32-S3 WiFi & BLE camera board with the T-Camera S3...
$96+ Banana Pi BPI-M2S Amlogic A311D/S922X SBC offers dual GbE, optional PoE and WiFi 5
The Banana Pi PPI-M2S is a single board computer (SBC) powered by either Amlogic A311D...
Linux 6.2 exFAT update to improve performance when creating files and directories
The exFAT file system is about to get faster in Linux 6.2, at least when...
Pinecil V2 Bluetooth LE soldering iron gets a web interface
It’s now possible to make use of the Pinecil V2 soldering iron‘s Bluetooth LE connectivity...
TopTon TP-X4F mini PC with four 2.5GbE ports features up to AMD Ryzen 7 5825U processor
TopTon TP-X4F is a mini PC and network appliance equipped with four 2.5GbE ports and...
M5Stack T-Lite Wi-Fi thermal camera integrates 1.14-inch color display
M5Stack T-Lite is a Wi-Fi thermal imager with the same MLX90640 IR array thermal camera...
Adding an external serial console port to NanoPi R6S
I had no trouble with my first experience with NanoPi R6S while installing and running...
Merlot is an open-source hardware tricolor wireless E-paper display
paperd.ink Merlot is a tricolor E-paper display with an open-source hardware control board based on...
LEGO brick with Raspberry Pi RP2040 runs Doom
James Brown (aka Ancient) has built a tiny computer inside a LEGO brick with a...
Meadow F7v2 Feather STM32F7 MCU board supports .NET, C# programing
Wilderness Labs Meadow F7v2 Feather is an STM32F7 Arm Cortex-M7 development board following the Adafruit...
DROPLET irrigation system works with ESPhome and Home assistant
When PricelessToolkit failed to find an affordable (indoor) irrigation system that works with Home Assistant...
Banana BPI-Bit-S2 BBC Micro:bit compatible board supports WiFi
Banana BPI-Bit-S2 is a board for the education market that’s compatible with the BBC Micro:bit...
SONOFF ZBMINI Extreme tiny Zigbee smart switch does not require a neut
SONOFF ZBMINI Extreme (aka ZBMINI-L2) is an ultra-compact Zigbee smart switch that can control home...
AAEON RTC-710AP rugged tablet features hot-swappable battery for continuous operation
AAEON RTC-710AP is a 7-inch rugged tablet powered by an Intel Celeron N3350 or Pentium...
Lichee Pi 4A RISC-V SBC takes on Raspberry Pi 4 with TH1520 processor
Lichee Pi 4A is a single board computer (SBC) powered by Alibaba T-Head TH1520 quad-core...
Geniatech DS-3566 digital signage board is powered by a Rockchip RK3566 SoC
Geniatech DS-3566 is a board based on Rockchip RK3566 designed for digital signage applications with...
Achronix Speedster7t AC7t1500 FPGA is now available for high-bandwidth applications
Achronix Semiconductor has recently announced the general availability of the Speedster7t AC7t1500 FPGA designed for...
Khadas VIM1S review – Ubuntu 22.04 tested on an Amlogic S905Y4 SBC
In this review of Khadas VIM1S SBC, we’ll install Ubuntu 22.04, and report our experience...
Pironman review – A Raspberry Pi 4 enclosure with M.2 SATA, safe power off, RGB LED strip, and more
SunFounder Pironman is a Raspberry Pi 4 enclosure inspired by Michael Klement’s DIY Raspberry Pi...
Bouffalo Lab BL616/BL618 RISC-V MCU supports WiFi 6, Bluetooth 5.2, and Zigbee
Bouffalo Lab BL616/BL618 is a 32-bit RISC-V wireless microcontroller with support for 2.4 GHz WiFi...
Pico-ITX SBC features NXP i.MX 93 LGA system-on-module
iWave Sytems iW-RainboW-G50M is an NXP i.MX 93 OSM-L compliant LGA module with up to...
Banana Pi BPI-Pico-RP2040 – Raspberry Pi Pico replica gets USB-C port, I2C connector, and RGB LED
Banana Pi BPI-Pico-RP2040 is basically a clone of the original Raspberry Pi Pico, but with...
$4 DshanMCU Pitaya Lite board comes with MM32 Arm Cortex-M3 microcontroller
DshanMCU Pitaya Lite is an MCU development board based on yet another STM32 alternative: MindMotion...
$150 Axelera M.2 AI accelerator module claims to deliver up to 214 TOP
Axelera M.2 AI accelerator module is said to deliver up to 214 TOPS of AI...
MECOOL KM7 Plus runs Google TV OS on Amlogic S905Y4 SoC
MECOOL KM7 Plus is a TV box powered by an Amlogic S905Y4 quad-core Cortex-A35 processor...
Walter ESP32-S3 board supports NB-IoT, LTE-M, and GPS
QuickSpot Walter is an ESP32-S3 development board with built-in WiFi 4 and Bluetooth LE/Mesh connectivity,...
Year 2022 in review – Top 10 posts and statistics
It’s the last day of the year and the time to look at some of...
Banana Pi BPI-CM4 Amlogic A311D system-on-module launched for $95
Banana Pi BPI-CM4 system-on-module powered by an Amlogic A311D hexa-core Cortex-A73/A53 processor and compatible with...
MSI Cubi N ADL – An Intel Processor N100/N200 Alder Lake-N mini PC
MSI Cubi N ADL is one of the first mini PCs based on the Alder...
NXP i.MX 95 processor features Cortex-A55, Cortex-M33, and Cortex-M7 cores, eIQ Neutron NPU
NXP i.MX 95 is an upcoming Arm processor family for automotive, industrial, and IoT applications...
Raspberry Pi Pico W to get Bluetooth LE support very soon
The Raspberry Pi Pico W board was launched with a WiFi 4 and Bluetooth 5.2...
Forlinx FET-MX9352-C – An NXP i.MX 9352 system-on-module for industrial AIoT applications
Forlinx FET-MX9352-C is a system-on-module based on NXP i.MX 9352 dual Cortex-A55 processor with Cortex-M33...
ASRock NUC 1300 BOX/ NUCS 1300 BOX mini PCs are powered by Intel Raptor Lake-P mobile processors
ASRock Industrial NUC 1300 BOX and NUCS 1300 BOX series mini PCs are equipped with...
Meet Intel Processor and Core-i3 N-series “Alder Lake N-series” processors
Pentium and Celeron brands are officially dead with Intel introducing the Alder Lake-N family comprised...
COM Express & COM-HPC modules features Intel 13th gen Raptor Lake embedded processors
ADLINK has just announced the Express-RLP COM Express Type 6 and COM-HPC-cRLS COM-HPC size C...
MediaTek Genio 700 Cortex-A78/A55 IoT processor targets industrial and Smart Home applications
MediaTek Genio 700 is an octa-core Arm processor with two Cortex-A78 cores, six Cortex-A55 cores,...
