COM Express Type 10 Tiger Lake UP3 module targets embedded mobile appl
AAEON NanoCOM-TGU is a COM Express Type 10 module powered by the 11th generation Intel...[Only registered and activated users can see links. Click Here To Register...]
Mico – A USB microphone based on Raspberry Pi RP2040 MCU
Raspberry Pi RP2040 dual-core Cortex-M0+ microcontroller has found its way into Mico, a compact USB...[Only registered and activated users can see links. Click Here To Register...]
Indoor positioning BU01 development board can detect tiny body movements (Sponsored)
GPS is available for outdoor positioning, what about indoors? There is a positioning technology that...[Only registered and activated users can see links. Click Here To Register...]
Sipeed Lichee RV RISC-V module gets $5+ carrier board with HDMI and USB ports, optional WiFi
Sipeed introduced the Lichee RV Allwinner D1 Linux RISC-V board going for just $17 with...[Only registered and activated users can see links. Click Here To Register...]
CH583 RISC-V microcontroller supports Bluetooth 5.3 LE
Following up on the CH572 RISC-V BLE microcontroller with 10KB SRAM, WCH has now introduced...[Only registered and activated users can see links. Click Here To Register...]
10,000 mAh Graphene power bank fully charges in 27 minutes (Sponsored)
Most power banks are made of Lithium batteries that charge in 3 to 4 hours...[Only registered and activated users can see links. Click Here To Register...]
Raspberry Pi UPS HAT takes two 18650 batteries (Crowdfunding)
Raspberry Pi UPS solutions have been available for years with products like PiJuice Zero, PiVoyager,...[Only registered and activated users can see links. Click Here To Register...]
OS and Memory Impact on Mini PC Gaming Performance
This article looks at what the effect of running a different operating system or having...[Only registered and activated users can see links. Click Here To Register...]
NOVELDA UWB X4 sensor can detect submillimeter movements
We’ve just written about an ESP32 UWB board equipped with an ultra-wideband module designed for...[Only registered and activated users can see links. Click Here To Register...]
NanoPi R2C Plus dual GbE router board adds 8GB eMMC flash
NanoPi R2C Plus is a variation of NanoPi R2C dual Gigabit Ethernet SBC powered by...[Only registered and activated users can see links. Click Here To Register...]
Phased out Raspberry PI CM4 quad SATA carrier board becomes open-source hardware
Wiretrustee carrier board for Raspberry Pi CM4 was unveiled about one year ago with four...[Only registered and activated users can see links. Click Here To Register...]
$1.8 XT-ZB1 Zigbee & BLE devkit features BL702 RISC-V module
Bouffalo Labs BL702 is a 32-bit RISC-V microcontroller with a 2.4 GHz radio for Zigbee...[Only registered and activated users can see links. Click Here To Register...]
MIPI CSI-2 v4.0 adds features for always-on, low power machine vision
While MIPI CSI-2 standard was first introduced in 2005 as a high-speed protocol for the...[Only registered and activated users can see links. Click Here To Register...]
Raspberry Pi 4 to support Network install to a blank MicroSD card
The Raspberry Pi 4 will soon be able to install Raspberry Pi OS without the...[Only registered and activated users can see links. Click Here To Register...]
Fitlet3 is a compact, fanless Elkhart Lake mini PC for IoT and industrial applications
Fitlet3 fanless mini PC based on a choice of three Atom or Celeron Elkhart Lake...[Only registered and activated users can see links. Click Here To Register...]
MutantW V1 – An open-source ESP32 smartwatch designed with Autodesk Fusion 360 and EAGLE
Rahmanshaber is known for its DIY Raspberry Pi handheld PCs such as MutantC v4, but...[Only registered and activated users can see links. Click Here To Register...]
CLEAR is an open-source FPGA ASIC provided by Efabless’ chipIgnite
Open-source SoC designs are available to run on FPGA hardware, but few make it to...[Only registered and activated users can see links. Click Here To Register...]
Intel to invest $1 billion in foundry innovation, becomes RISC-V International member
Intel has just announced a $1 billion fund to support companies bringing innovations and new...[Only registered and activated users can see links. Click Here To Register...]
Add four PCIe x1 slots to Raspberry Pi CM4 IO with Waveshare PCIe-Packet-Switch-4P board
The 1-lane PCIe Gen 2 interface in Broadcom BCM2711 processor is exposed in Raspberry Pi...[Only registered and activated users can see links. Click Here To Register...]
CHUWI LarkBox X mini PC is powered by an AMD Ryzen 7 3700U mobile processor
CHUWI LarkBox X is an affordable mini PC based on a 15W AMD Ryzen 7...[Only registered and activated users can see links. Click Here To Register...]
Qualcomm IPQ8076A WiFi 6E access point offers dual 10GbE, supports PoE++
Lanner LWR-X8460 is an enterprise-grade 12-stream, tri-band Wi-Fi 6E access point powered by Qualcomm IPQ8076A...[Only registered and activated users can see links. Click Here To Register...]
Review of GL.inet GL-S10 BLE to MQTT gateway with MQTT X open-source client
I started the review of GL.inet GL-S10 BLE to MQTT gateway in December by doing...[Only registered and activated users can see links. Click Here To Register...]
Lantronix G520 cellular gateways target industrial communication, cybersecurity, and transportation
Lantronix G520-series 4G LTE Cat 4 and 5G cellular gateways are designed to address challenges...[Only registered and activated users can see links. Click Here To Register...]
Amlogic S905C2 quad-core Cortex-A55 processor supports digital TV tuners, CAS
Amlogic S905C2 quad-core Cortex-A55 processor has been showing up in some Android 11 set-top boxes...[Only registered and activated users can see links. Click Here To Register...]
India goes RISC-V with VEGA processors
One of the main advantages of RISC-V architecture is that it is open, so any...[Only registered and activated users can see links. Click Here To Register...]
Beelink GTi11 modding – PCIe Gen 4.0 M.2 slot, tweaking power limits, and eGPU
Previously I reviewed Beelink’s new GTi11 Intel Tiger Lake mini PC running Windows 11 and...[Only registered and activated users can see links. Click Here To Register...]
Foldable, portable laser cutter & engraver comes with built-in fume filtration (Crowdfunding)
If you’d wish you could easily carry your laser engraver or cutter around, conveniently store...[Only registered and activated users can see links. Click Here To Register...]
More Allwinner F1C200s ARM9 boards: MangoPi R3 and CherryPi-F1C200S
I wrote about the Widora TINY200 board based on Allwinner F1C200s ARM9 processor with 64MB...[Only registered and activated users can see links. Click Here To Register...]
Raspberry Pi OS 64-bit officially released
The Raspberry Pi Foundation has now officially released Raspberry Pi OS 64-bit about two years...[Only registered and activated users can see links. Click Here To Register...]
Golioth IoT development platform offers Zephyr SDK, support for nRF9160, ESP32, and over 100 other platforms
There are already plenty of IoT development platforms, but here’s another one with Golioth that...[Only registered and activated users can see links. Click Here To Register...]
Tiny Core Linux 13.0 released for older or lower-end x86 hardware
Tiny Core Linux 13.0 has just been released for 32-bit and 64-bit x86 systems with...[Only registered and activated users can see links. Click Here To Register...]
Craob X – An ultrathin, portless laptop with a wireless charger & dock
They’ve already taken out our audio jacks, and many laptops don’t come with an Ethernet...[Only registered and activated users can see links. Click Here To Register...]
JetHome JetHub D1 is a Linux automation controller based on Amlogic A1
I discovered JetHome Jethub D1 and Jethub H1 Linux automation controller based on respectively Amlogic...[Only registered and activated users can see links. Click Here To Register...]
4K digital signage player drives up to four displays, offers 2.5GbE networking
Axiomtek DSP511 is a Tiger Lake UP3 based digital signage player with four 4K-capable HDMI...[Only registered and activated users can see links. Click Here To Register...]
DeskPi Lite – A Raspberry Pi 4 enclosure with full HDMI ports, two extra USB ports
In 2020, we wrote about the DeskPi Pro enclosure for Raspberry Pi 4 with 2.5-inch...[Only registered and activated users can see links. Click Here To Register...]
KrakenSDR is a 5-channel software-defined radio based on RTL-SDR
KrakenRF KrakenSDR is a software-defined radio (SDR) with five coherently-operated receive channels that’s basically the...[Only registered and activated users can see links. Click Here To Register...]
Maker Nano RP2040 offers Arduino Nano, Grove and Qwiic modules compatibility
Cytron Maker Nano RP2040 is board similar to Raspberry Pi Pico but with Arduino Nano...[Only registered and activated users can see links. Click Here To Register...]
Wappsto:bit GO – An ESP32 board with plenty of sensors, Micro:bit compatibility (Crowdfunding)
Wappsto:bit GO is an ESP32 board compatible with BBC Micro:bit accessories thanks to a compatible...[Only registered and activated users can see links. Click Here To Register...]
Arduino Portenta gets an LTE Cat. M1/NB IoT GNSS shield
Arduino PRO Portenta family of industrial boards is getting a new LTE Cat. M1/NB-IoT GNSS...[Only registered and activated users can see links. Click Here To Register...]
Speeding up open-source GPU driver development with unit tests, drm-shim, and code reuse
Getting an Arm platform that works with mainline Linux may take several years as the...[Only registered and activated users can see links. Click Here To Register...]
MediaTek Kompanio 1380 Cortex-A78/55 processor is designed for premium Chromebooks
MediaTek Kompanio 1380 is a 6nm octa-core Cortex-A78/A55 processor clocked at up to 3.0 GHz...[Only registered and activated users can see links. Click Here To Register...]
The Eclipse Oniro Project aims to deliver consumer & IoT software that works across multiple platforms
Several of the embedded talks at FOSDEM 2022 mention the “Eclipse Oniro Project”. I had...[Only registered and activated users can see links. Click Here To Register...]
Allwinner F1C100s handheld computer should cost $15 to manufacture
Brian Benchoff’s “minimum viable computer'” is a Linux handheld computer powered by an Allwinner F1C100s...[Only registered and activated users can see links. Click Here To Register...]
BTT SKR Pico – A Raspberry Pi RP2040 based 3D printer control board
BigTreeTech BTT SKR Pico V1.0 is a 3D printer controller board based on Raspberry Pi...[Only registered and activated users can see links. Click Here To Register...]
Round color LCD board comes in Raspberry Pi RP2040 or ESP8266 flavor (
Roundy is a board with a 1.28-inch round color LCD with 240 x 240 resolution...[Only registered and activated users can see links. Click Here To Register...]
Android 13 virtualization lets Pixel 6 run Windows 11, Linux distributions
The first Android 13 developer preview may have felt a bit underwhelming, but there’s a...[Only registered and activated users can see links. Click Here To Register...]
RISC-V or Arm? This tiny 4x4cm Linux board with WiFi offers both options
Last fall, we wrote about Allwinner D1s/F133-A RISC-V processor and the upcoming MangoPi MQ1, a...[Only registered and activated users can see links. Click Here To Register...]
Allwinner T113-S3 dual-core Cortex-A7 SoC features 128MB DDR3, targets automotive and industrial applications
Allwinner T113-S3 is a dual-core Cortex-A7 processor with 128MB DDR3 on-chip memory that is designed...[Only registered and activated users can see links. Click Here To Register...]
Orange Pi R1 Plus LTS sells with metal enclosure for $35.99
Shenzhen Xunlong Software previously launched the Orange Pi R1 Plus LTS router board powered by...[Only registered and activated users can see links. Click Here To Register...]
ICARUS Elkhart Lake Pico-ITX board targets IoT, AIoT, and computer vision applications
SECO ICARUS is a Pico-ITX single board computer based on Intel Atom x6000E, Celeron, and...[Only registered and activated users can see links. Click Here To Register...]
Android 13 developer preview released with privacy, security, and productivity improvements
Android 12 was only released in October 2021 and Google has already released the first...[Only registered and activated users can see links. Click Here To Register...]
Low-power Alder Lake-N processors coming to Chromebooks, embedded systems
Intel Alder Lake-N processors succeeding Jasper Lake processors are likely to soon show up in...[Only registered and activated users can see links. Click Here To Register...]
Basler prB-IMX8MP embedded vision processing kit supports BCON for MIPI, GigE Vision, and USB3 Vision cameras
Basler prB-IMX8MP is a Linux-based, NXP i.MX 8M Plus powered embedded vision processing kit working...[Only registered and activated users can see links. Click Here To Register...]
TTGO T-Block modular ESP32 devkit supports “Trolley” covers acting as display, buttons, sensor, proto area, etc…
When I first LilyGO TTGO T-Block ESP32 devkit with an enclosure and a display it...[Only registered and activated users can see links. Click Here To Register...]
Inkplate 6COLOR – A 5.8-inch e-paper color wireless display (Crowdfunding)
Inkplate 6COLOR is a 5.8-inch color e-paper display equipped with ESP32 WiSoC to provide WiFi...[Only registered and activated users can see links. Click Here To Register...]
Lichee RV-86 RISC-V Linux 4-inch panel targets home automation, HMI ap
When Sipeed first introduced the Lichee RV module with Allwinner D1 RISC-V SoC last November,... [Only registered and activated users can see links. Click Here To Register...]
ARIES Embedded unveils OSM modules based on Renesas Arm or RISC-V microprocessor
In another case of “Arm or RISC-V? Why not both“, ARIES Embedded has introduced “MSRZG2UL”... [Only registered and activated users can see links. Click Here To Register...]
4K USB AI camera is powered by Rockchip RV1126 SoC with 2.0 TOPS NPU
ThinkCore TC-RV1126 is a USB AI camera powered by Rockchip RV1126 quad-core Cortex-A7 processor with... [Only registered and activated users can see links. Click Here To Register...]
Raspberry Pi RP2040 board comes with 0.42-inch display, Qwicc I2C connector
We’ve recently written about ESP32-C3-0.42LCD board with ESP32-C3 wireless microcontroller, a 0.42-inch display, and a... [Only registered and activated users can see links. Click Here To Register...]
NanoPi R5S Rockchip RK3568 mini router launched for $59 and up
The Rockchip RK3568-powered NanoPi R5S SBC with two 2.5GbE ports, one Gigabit Ethernet port, and... [Only registered and activated users can see links. Click Here To Register...]
Khadas VIM4 SBC review – Part 3: Ubuntu 22.04
Here’s the last part of Khadas VIM4 review with Ubuntu 22.04 “Jammy Jellyfish”. You may... [Only registered and activated users can see links. Click Here To Register...]
RZBoard V2L – A business card-sized Renesas RZ/V2L SBC for AI vision applications
Avnet RZBoard V2L is an Arm Linux SBC for AI vision applications that’s about the... [Only registered and activated users can see links. Click Here To Register...]
Lightweight wireless AR Smart Viewer reference design is powered by Snapdragon XR2 platform
Qualcomm unveiled a new Wireless AR Smart Viewer Reference Design powered by the Snapdragon XR2... [Only registered and activated users can see links. Click Here To Register...]
DepthVista USB 3D ToF camera supports close range depth measurement, far-range object detection
DepthVista is a USB Time-of-Flight (ToF) camera designed for precise 3D depth measurement in close... [Only registered and activated users can see links. Click Here To Register...]
hm-panelizer – A KiCad companion GUI tool for panelizing PCBs
Gerard (aka halfmarble) has released hm-panelizer open-source software allowing for a panelization of PCBs via... [Only registered and activated users can see links. Click Here To Register...]
Rockchip RK3588 CPU module exposes more I/Os through four board-to-board connectors
We’ve already seen several Rockchip RK3588 modules with Firefly Core-3588J, Turing RK1, and Banana Pi... [Only registered and activated users can see links. Click Here To Register...]
Ultra compact GaN ATX power supply delivers up to 250 Watts
To me, an ATX power supply is one of those big boxes delivering 500W+ inside... [Only registered and activated users can see links. Click Here To Register...]
x86 system-on-module features 1GHz DM&P Vortex86DX3 processor
DM&P Vortex86DX3 is an x86 embedded processor launched in 2015 that we’ve previously found in... [Only registered and activated users can see links. Click Here To Register...]
$150 InkPalm Plus eReader features RK3566 SoC, 5.84-inch display
Xiaomi Moaan InkPalm Plus is a 5.84-inch eReader powered by the same Rockchip RK3566 processor... [Only registered and activated users can see links. Click Here To Register...]
Raspberry Pi CM4 compatible module coming soon with Amlogic A311D CPU
Despite assurances by Eben Upton that there’s no supply shortage of Raspberry Pi CM4 modules... [Only registered and activated users can see links. Click Here To Register...]
Microchip SAMA7G54 is a single-core Arm Cortex-A7 microprocessor for low power AI camera & audio applications
Microchip has just announced the 1 GHz SAMA7G54 single-core Arm Cortex-A7 microprocessor (MPU) with MIPI... [Only registered and activated users can see links. Click Here To Register...]
Beelink SEi8/SER3 review – Intel Core i3-8109U and AMD Ryzen 3 3200U mini PCs face off in Windows 11 (part 1)
In the past, new mini PCs were released as a result of new processors coming... [Only registered and activated users can see links. Click Here To Register...]
DongShanPi One – A SigmaStar SSD202D system-on-module with a mini PCIe edge connector for GPIO, Ethernet…
DongShanPi One system-on-module features SigmaStar SSD202D Arm Cortex-A7 processor with 128MB on-chip RAM, a 128MB... [Only registered and activated users can see links. Click Here To Register...]
Digi IX30 is a cellular router for Industry 4.0, public safety, harsh environments
Digi IX30 is a 4G LTE cellular router for industry 4.0 designed for distribution and... [Only registered and activated users can see links. Click Here To Register...]
Get a Windows 10 lifetime license for $15 or Microsoft Office for $28 in May! (Sponsored)
vip-scdkey.com, a platform where customers have been able to purchase game and software keys since... [Only registered and activated users can see links. Click Here To Register...]
CherryUSB – A lightweight USB device/host stack for embedded systems
CherryUSB is a lightweight open-source USB device/host stack for embedded systems with one or more... [Only registered and activated users can see links. Click Here To Register...]
MediaTek Filogic 880 and Filogic 380 to power WiFi 7 access points and clients
I first heard about WiFi 7 (802.11be) when MediaTek demonstrated some unknown Filogic solutions to... [Only registered and activated users can see links. Click Here To Register...]
Linux 5.18 release – Main changes, Arm, RISC-V, and MIPS architectures
Linux 5.18 is out! Linus Torvalds has just announced the release on lkml: No unexpected... [Only registered and activated users can see links. Click Here To Register...]
Linux hardware video encoding on Amlogic A311D2 processor
I’ve spent a bit more time with Ubuntu 22.04 on Khadas VIM4 Amogic A311D2 SBC,... [Only registered and activated users can see links. Click Here To Register...]
Clicker 4 for TMPM4K board targets motor control with Toshiba M4K microcontroller
Toshiba and Mikroelektronika have launched the Clicker 4 for TMPM4K development board equipped with Toshiba... [Only registered and activated users can see links. Click Here To Register...]
LilyGO T-HC32 board with the world’s smallest Arm MCU (HC32L110B6) is now available for $9
HC32L110 Arm Cortex-M0+ MCU is found in a minuscule 1.59 x 1.436 mm CSP16 package... [Only registered and activated users can see links. Click Here To Register...]
5G RedCap leverages 5G features, limits bandwidth to 85Mbps for industrial IoT applications
5G is often associated with Gigabit speeds when found in mobile handsets or connected laptops,... [Only registered and activated users can see links. Click Here To Register...]
Rockchip RK3588 Pico-ITX board launched with four-node cluster box (Crowdfunding)
The Mixtile Blade 3 Pico-ITX single board computer (SBC) powered by Rockchip RK3588 processor has... [Only registered and activated users can see links. Click Here To Register...]
Geniatech launches OSM Size-L modules with Renesas RZ/G2L, Rockchip RK3566
Geniatech has introduced LGA system-on-modules compliant with the SGET OSM (Open Standard Module) Size-L standard... [Only registered and activated users can see links. Click Here To Register...]
$30 compact multi-sensor board works with any microcontroller with I2C (Crowdfunding)
SENSE is a compact multi-sensor board supporting measurement of air quality, sound, light intensity, temperature,... [Only registered and activated users can see links. Click Here To Register...]
DeskMini UM350 Manjaro Edition is a Linux mini PC powered by an AMD Ryzen 5 3550H SoC
Most mini PCs are offered with Windows 10 or 11 operating systems, but MinisForum DeskMini... [Only registered and activated users can see links. Click Here To Register...]
Exo Sense RP – A Raspberry Pi RP2040-based multi sensor module
Sfera Labs Exo Sense RP is a multi-sensor module with a Raspberry Pi RP2040 microcontroller... [Only registered and activated users can see links. Click Here To Register...]
Forlinx introduces Renesas RZ/G2L system-on-module and development boa
Renesas RZ/G2L or RZ/V2L Cortex-A55/M33 processors have found their way into several system-on-modules and single... [Only registered and activated users can see links. Click Here To Register...]
Fingerbot Sense Zigbee or Bluetooth LE button pusher adds touchless control (Crowdfunding)
When we first wrote about Fingerbot Bluetooth mechanical button pusher to add automation control to... [Only registered and activated users can see links. Click Here To Register...]
GEEKOM MiniAir 11 Celeron N5095 mini PC sells for $200 with 8GB RAM, 256GB SSD
GEEKOM MiniAir 11 is a mini PC powered by a Celeron N5095 Jasper Lake mini... [Only registered and activated users can see links. Click Here To Register...]
Is your Smart Home product being shutdown? Just buy the company!
With Smart Home products connecting to the cloud, if a company decides to end support... [Only registered and activated users can see links. Click Here To Register...]
T-Relay-8 – An ESP32 board with 8 relays
LilyGo T-Relay-8 is an ESP32 WiFi & BLE board equipped with eight 5V relays supporting... [Only registered and activated users can see links. Click Here To Register...]
Light sensors add “lift and learn” feature to digital signage player
Light sensors are used to turn on/off lights, adjust the brightness of displays, and more.... [Only registered and activated users can see links. Click Here To Register...]
STMicro VL53L8 multi-zone direct Time-of-Flight (dToF) sensor improves range and efficiency
STMicro VL53L8 multi-zone direct Time-of-Flight (dToF) sensor doubles the ranging performance of VL53L5 sensor –... [Only registered and activated users can see links. Click Here To Register...]
ShaRPiKeebo handheld Linux computer based on Raspberry Pi Zero (2) W ships with a LoRa radio (Crowdfunding)
Morpheans ShaRPiKeebo is a portable Linux computer based on Raspberry Pi Zero W or Zero... [Only registered and activated users can see links. Click Here To Register...]
LimeSDR Mini 2.0 USB SDR board gets an upgrade to Lattice Semi ECP5 FPGA (Crowdfunding)
The LimeSDR Mini is an open-source hardware full-duplex USB SDR board based on Intel Altera... [Only registered and activated users can see links. Click Here To Register...]
Kodi 20 “Nexus” Alpha 1 gets AV1 hardware decoding, DietPi 8.5 released
I’ll combine two unrelated short news about software releases for TV boxes, Raspberry Pi, and... [Only registered and activated users can see links. Click Here To Register...]
Bluetooth Auracast broadcast audio is the new name for Bluetooth LE audio sharing
Multi-stream and broadcast audio features part of the Bluetooth LE Audio standard have been given... [Only registered and activated users can see links. Click Here To Register...]
Use your favorite laptop keyboard with the Techlabz Keybox (Sponsored)
The Techlabz Keybox allows you to re-use your favorite laptop keyboard over USB or Bluetooth.... [Only registered and activated users can see links. Click Here To Register...]
Renesas RZ/T2M dual Arm Cortex-R52 MPU delivers high-precision servo motor control
Built around two Arm Cortex-R52 cores clocked at up to 800 MHz, Renesas RZ/T2M microprocessor... [Only registered and activated users can see links. Click Here To Register...]
u-blox XPLR-IOT-1 explorer kit embeds cellular IoT, Wi-Fi, BLE, GNSS, and sensors for IoT evaluation
u-blox XPLR-IOT-1 explorer kit is an all-in-one IoT evaluation platform with cellular IoT, Wi-Fi, Bluetooth... [Only registered and activated users can see links. Click Here To Register...]
MYIR MYC-J1028X CPU module features NXP LS1028A dual Cortex-A72 SoC with time-sensitive networking (TSN)
MYIR has introduced the MYC-J1028X CPU module based on NXP LS1028A dual Cortex-A72 processor with... [Only registered and activated users can see links. Click Here To Register...]
TI Sitara AM623 & AM625 Cortex-A53 SoCs offer low-power AI for HMI and IoT applications
Texas Instruments has just launched the new Sitara AM62 family with AM623 and AM625 single... [Only registered and activated users can see links. Click Here To Register...]
OSM Size-0 solder-on LGA module comes with ESP32 WiFi & BLE MCU
German embedded systems company iesy’s ESP32 OSM-0F is an ESP32-based solder-on LGA system-on-module that complies... [Only registered and activated users can see links. Click Here To Register...]
Panfrost now offers a fully-conformant OpenGL ES 3.1 implementation for Mali-G57 (Valhall) GPU
The Mali-G57 GPU part of the Valhall family, and found in several Arm processors such... [Only registered and activated users can see links. Click Here To Register...]
X1501 Pico SoM – MIPS, Linux in a 16x16mm module
We’ve just written about the Notkia phone repurposing Nokia 168x phones with a new PCB... [Only registered and activated users can see links. Click Here To Register...]
MechArm Pi 270 is a desktop robotic arm powered by a Raspberry Pi 4 SBC
Elephant Robotics MechArm Pi 270 is a six-axis robotic arm with a 270mm working radius,... [Only registered and activated users can see links. Click Here To Register...]
Robot cat girl doll leverages Khadas VIM3 SBC for AI-accelerated objec
While Khadas VIM4 board has just been launched, the earlier Khadas VIM3 SBC has the... [Only registered and activated users can see links. Click Here To Register...]
NanoPi R5S preview – Part 2: Ubuntu 20.04 (FriendlyCore)
I started the NanoPi R5S review with an unboxing, a teardown, a quick try of... [Only registered and activated users can see links. Click Here To Register...]
Orange Pi 800 Keyboard PC – A Raspberry Pi 400 alternative powered by Rockchip RK3399
There’s now a Raspberry Pi 400 alternative with the Orange Pi 800 Keyboard PC that... [Only registered and activated users can see links. Click Here To Register...]
MeLE Quieter3Q Review – Ultra-thin fanless mini PC tested with Windows 11, Ubuntu 22.04
MeLE has released a new and updated version of the Quieter mini PC called the... [Only registered and activated users can see links. Click Here To Register...]
Armbian 22.05 release adds support for Orange Pi R1 Plus LTS, Radxa Zero & Rock 3A, DevTerm A06
The latest release of Armbian, version 22.05, is now out with hundreds of Linux kernel... [Only registered and activated users can see links. Click Here To Register...]
Nokia 1680 phone gets new PCB with MIPS SoC, runs mainline Linux
Reimu NotMoe has designed the “Notkia” PCB based on Ingenic X1000E MIPS processor with 64MB... [Only registered and activated users can see links. Click Here To Register...]
ZeroKey Quantum RTLS enables indoor location with millimeter-level accuracy
ZeroKey’s Quantum RTLS is a 3D real-time location system (RTLS) for millimeter-level accuracy designed for... [Only registered and activated users can see links. Click Here To Register...]
NanoPi R5S router review – Part 1: Unboxing, OpenWrt, and iperf3 benchmarking
FriendlyElec has just launched the NanoPi R5S mini router powered by a Rockchip RK3568 processor,... [Only registered and activated users can see links. Click Here To Register...]
FastRhino R68s router offers 4GB RAM, dual 2.5GbE, dual Gigabit Ethernet for $80 (in China)
Rockchip RK3568-powered NanoPi R5S router has gotten a direct competitor courtesy of FastRhino R68s with... [Only registered and activated users can see links. Click Here To Register...]
PICO-V2K4 – A Pico-ITX board with AMD Ryzen Embedded V2000 processor
AAEON PICO-V2K4 is a Pico-ITX board powered by an AMD Ryzen Embedded V2000 processor with... [Only registered and activated users can see links. Click Here To Register...]
Quartz64 Model B SBC with 4GB RAM is now available for $59.99
While it may be hard to buy a Raspberry Pi these days, there are various... [Only registered and activated users can see links. Click Here To Register...]
How to use a ToF laser ranging sensor with Arduino and Wisblock
The WisBlock RAK12014 ToF sensor module adopts ST VL53L0X, the world’s smallest ToF ranging sensor... [Only registered and activated users can see links. Click Here To Register...]
AMD unveils Ryzen Embedded R2000 Series processors with up to four cor
As expected, AMD has now launched the Ryzen Embedded R2000 series processors that build up... [Only registered and activated users can see links. Click Here To Register...]
Sipeed Lichee RV Dock Pro RISC-V SBC adds MIPI/RGB LCD connector, dual MIC, and BL702 JTAG+UART debugger
Sipeed has launched the Lichee RV Dock Pro kit for the company’s Lichee RV Allwinner... [Only registered and activated users can see links. Click Here To Register...]
Ingenic T31-based WiFi AI camera development kit promises over a year of battery life
We’ve previously seen WiFi security cameras promising a year of battery life with products like... [Only registered and activated users can see links. Click Here To Register...]
Vecow unveils MediaTek Genio 350, Genio 500, and Genio 1200 system-on-modules and development kits
Vecow has announced a series of new system-on-modules and development kits based on Mediatek Genio... [Only registered and activated users can see links. Click Here To Register...]
Cavli Wireless C42GM module offers cellular IoT and Sigfox connectivity, optional GNSS and CAN Bus
Selecting an LPWAN IoT module usually means selecting a particular LPWAN standard, but Cavli Wireless... [Only registered and activated users can see links. Click Here To Register...]
Think Silicon NEOX RISC-V GPU offers 3D graphics or AI acceleration
Think Silicon NEOX GPU family with models optimized for graphics (NEOX|G) or artificial intelligence (NEOX|A)... [Only registered and activated users can see links. Click Here To Register...]
Hybrid Time-of-Flight (ToF) 3D range image sensor offers up to 30-meter range
We’ve written about STMicro Time-of-Flight ranging sensors several times over the year, including the latest... [Only registered and activated users can see links. Click Here To Register...]
Iono RP D16 industrial IO module features Raspberry Pi RP2040 MCU
Sfera Labs has launched another Raspberry Pi RP2040-based hardware platform with the Iono RP D16... [Only registered and activated users can see links. Click Here To Register...]
BP Doctor PRO review – A 2-in-1 smartwatch and blood pressure monitor
So far, If I wanted to monitor my blood pressure monitor and overall fitness, I’d... [Only registered and activated users can see links. Click Here To Register...]
Mixtile reveals U.2 to PCIe/SATA breakout board for Rockchip RK3588 cluster
Mixtile Blade 3 is a Rockchip RK3588 SBC with up to 32GB RAM designed for... [Only registered and activated users can see links. Click Here To Register...]
u-blox unveils miniature MIA-M10 GPS module
u-blox has introduced what could be the world’s smallest GNSS module with the 4.5×4.5mm u-blox... [Only registered and activated users can see links. Click Here To Register...]
SONOFF POW Elite ESP32 WiFi power meter switch handles up to 20A load
SONOFF POW Elite is an ESP32-powered smart power meter switch that can handle up to... [Only registered and activated users can see links. Click Here To Register...]
Beelink SER3 & SEi8 mini PCs review – Part 2: Ubuntu 22.04
Previously, I reviewed Beelink’s new SEi8 and SER3 mini PCs running Windows 11, so in... [Only registered and activated users can see links. Click Here To Register...]
CrowPi L is a $200 laptop shell for Raspberry Pi 4
Two years ago, we reviewed CrowPi 2 Raspberry Pi 4 laptop designed for STEM education... [Only registered and activated users can see links. Click Here To Register...]
Ubuntu Core 22 released for IoT devices and embedded systems
Canonical has just released Ubuntu Core 22, a containerized variant of Ubuntu 22.04 LTS, optimized... [Only registered and activated users can see links. Click Here To Register...]
MECOOL KP1 smart projector runs Android 11 for TV on Amlogic S805X2 TV Stick
MECOOL KP1 is a Full HD projector equipped with the MECOOL KD5 HDMI dongle powered... [Only registered and activated users can see links. Click Here To Register...]
MediaTek Genio 1200 Linux system-on-module powers Cortex-A78/A55 AIoT development kit
ADLINK Technology has just unveiled the SMARC 2.1 compliant LEC-MTK-I12000 system-on-module (SoM) powered by MediaTek... [Only registered and activated users can see links. Click Here To Register...]
KIOXIA XFMEXPRESS XT2 tiny 18x14mm removable NVMe SSD complies with XFM DEVICE standard
KIOXIA Corporation, previously known as, Toshiba Memory Corporation, has started sampling of the XFMEXPRESS XT2... [Only registered and activated users can see links. Click Here To Register...]
Nordic Thingy:53 is a dual-core Arm Cortex-M33 platform for IoT prototyping
As one should have expected after Nordic Thingy:52 and Thingy:91 IoT devkits were introduced in... [Only registered and activated users can see links. Click Here To Register...]
BeagleBone AI-64 SBC features TI TDA4VM Cortex-A72/R5F SoC with 8 TOPS AI accelerator
BeagleBone AI-64 is a single board computer (SBC) powered by a Texas Instruments TDA4VM dual-core... [Only registered and activated users can see links. Click Here To Register...]
Open-source hardware USB Type-C industrial camera features Lattice Cro
Gaurav Singh, acting as Circuit Valley, has designed an open-source hardware USB 3.0 Type-C industrial... [Only registered and activated users can see links. Click Here To Register...]
NXP unveils MCX general-purpose Arm MCU family with 30x faster machine learning performance
NXP has announced a new MCX general-purpose Arm Cortex-M MCU family designed for advanced industrial... [Only registered and activated users can see links. Click Here To Register...]
Raspberry Pi Compute Module 3E (CM3E) features Raspberry Pi RP3A0 SiP found in Pi Zero 2 W
After the Raspberry Pi Compute Module 4S which we discovered in April, it appears Raspberry... [Only registered and activated users can see links. Click Here To Register...]
What is PVTM? Or why your Rockchip RK3588 CPU may not reach 2.4 GHz
While the Rockchip RK3588 processor is advertised as reaching 2.4 GHz, not all RK3588 chips...
CANDuino v3 – A Microchip ATmega168PA board with CAN bus, Arduino Nano form factor
CANduino v3 is the third revision of MassiveButDynamic’s CAN bus board with Arduino Nano form...
ASRock Industrial iEPF-9010S/iEP-9010E Edge AIoT platforms feature Alder lake S CPU, up to 128GB RAM
ASRock Industrial has released the iEPF-9010S and iEP-9010E high-end, rugged Edge AIoT platforms powered by...
Orange Pi 5 could be the most affordable Rockchip RK3588S SBC
Orange Pi 5 (LTS) is an upcoming single board computer powered by Rockchip RK3588S cost-down...
YD-CH32V307VCT6 RISC-V MCU board comes with Ethernet and plenty of I/Os
At the beginning of the year, we wrote about WCH CH32V307 RISC-V microcontroller and a...
can2040 project adds software CAN bus to Raspberry Pi RP2040 microcontroller
The can2040 project is a software CAN bus implementation for the Raspberry Pi RP2040 microcontroller...
Arduino-based MIDI controller brings Minimoog Model D synthesizer back to life (Crowdfunding)
ΔMIDI 001:model D is an Arduino-based MIDI controller inspired by the Minimoog Model D synthesizer...
Pixel Pump is an open-source, manual pick-and-place machine (Crowdfunding)
Pixel Pump is an open-source hardware vacuum pump that should be easier to use than...
WeAct RP2040 board adds 16MB flash, USB-C port to Raspberry Pi Pico form factor
If the Raspberry Pi Pico’s 2MB of QSPI flash is not quite sufficient for your...
Mekotronics R58 review – Part 2: Android 12 on Rockchip RK3588 CPU
I’ve written the first part of Mekotronics R58 review last month with an unboxing, teardown,...
Benchmarks comparison between UP 4000, Raspberry Pi 4, UP board, and Jetson Nano
We wrote about the UP 4000 SBC with an Intel Apollo Lake processor and Raspberry...
Using Raspberry Pi Pico as a logic analyzer
MCU boards, including the $1.5 BluePill board, have been used as cheap logic analyzers for...
4K wireless display adapter supports 3840×2160 resolution @ 60 Hz, HDR (Sponsored)
ProScreenCast SC01 is a 4K wireless display adapter supporting 3840×2160 resolution at up to 60...
MECOOL KP1 smart projector review – Part 1: Unboxing and first try
I’ve just received a review sample of the MECOOL KP1 smart projector with Full HD...
Arduino “launches” WisGate Edge LoRaWAN gateways in collaboration with RAKwireless
Arduino was already involved in LoRaWAN with its MKR WAN 1300 board, but now the...
UP 4000 SBC is a Raspberry Pi lookalike with an Intel Apollo Lake processor
AAEON has unveiled the UP 4000 single board computer with a form factor and ports...
Espressif unveils “One-Stop Matter Solution” for ESP32 wireless SoC’s
Espressif Systems have announced their one-stop Matter solution that features their ESP32, ESP32-C, and ESP32-S...
GEEKOM MiniAir 11 Review – A Jasper Lake Mini PC with plenty of ports
The GEEKOM MiniAir 11 is not just another mini PC powered by an Intel Jasper...
Banana Pi BPI-Leaf-S3 ESP32-S3 board launched for $7.5
Banana Pi is better known for its Arm Linux boards, but the company’s Banana Pi...
RISC-X? Top Chinese scientist discusses potential for RISC-V fork in extreme case
Is RISC-X next? Bao Yungang, a professor and scientist at the Chinese Academy of Sciences...
Seeed Studio outs $5 XIAO ESP32C3 board with WiFi and BLE, battery support
Seeed Studio’s XIAO family of tiny MCU boards expands with the XIAO ESP32C3 board equipped...
Intel Meteor Lake mobile processor highlights leaked
Intel Meteor Lake processor family is supposed to succeed the 13th generation Raptor Lake chips...
Flashchip FCM32 is yet another alternative to STM32 microcontroller
Once upon a time, people tried to avoid STM32 fakes and clones, but in a...
CANBed M4 SAM E51 development board features MCP2542FD CAN transceiver
CANBed M4 development board based on Microchip SAM E51 Cortex-M4 microcontroller and MCP2542FD CAN transceiver...
Silabs EFM32-based HydroMoth enables underwater acoustic data recordings
Open Acoustic Devices’ HydroMoth is the underwater equivalent of the AudioMoth full-spectrum acoustic device that...
Firefly ITX-3568JQ – A Mini-ITX motherboard with Rockchip RK3568 CPU
Firefly ITX3588J mini-ITX motherboard with Rockchip RK3588 SoC now has a little sister/brother based on...
Texas Instruments AM6254 powered industrial SBC features dual GbE, CAN Bus, RS485, optional 4G/5G cellular networking
Texas Instruments Sitara AM623 and AM625 Arm Cortex-A53 AIoT processors were just introduced last month,...
LILYGO T-QT V1.1 – A cute little board with ESP32-S3 and a 0.85-inch color display
LILYGO must be churning out at least one new “ESP32” board every month, but I...
ROCK 5B developer edition preview – Part 1: Unboxing and first boot to Debian 11
Radxa ROCK5 Model B (aka ROCK 5B) is one of the most anticipated Rockchip RK3588...
Mini review of ORICO “USB 4.0” M.2 NVMe SSD enclosure
ORICO has sent me a sample of a USB 4.0 M.2 NVMe SSD enclosure for...
STEPFPGA FPGA board is programmable with a Web IDE (Crowdfunding)
STEPFPGA MXO2Core miniature FPGA development board is based on Lattice MXO2-4000 FPGA, and designed for...
Compact3566 – A Rockchip RK3566 SBC that closely follows Raspberry Pi
We’ve very recently written about Geniatech XPI-3566 SBC powered by Rockchip RK3566 CPU that somewhat...
EM PRO mini – An AMD Ryzen Embedded R1102G fanless mini PC
E.E.P.D. EM PRO mini “eNUC-BoxPC” is a mini PC powered by a 6-watt AMD Ryzen...
NanoPi R4SE dual Gigabit Ethernet router adds 32GB eMMC flash
NanoPi R4SE is a variant of the Rockchip RK3399-powered NanoPi R4S dual Gigabit Ethernet router...
Business card-sized SBC ships with Intel Core Tiger Lake or AMD Ryzen V2000 processor
We’ve already written about the UP 4000 SBC as a more powerful x86 alternative to...
Acromag XMC-7A50-AP323 – An XMC module based on AMD Xilinx Artix-7 FPGA
Acromag XMC-7A50-AP323 is an XMC (Switched Mezzanine Card) module based on a Xilinx Artix-7 FPGA...
Theengs open-source tools to decode BLE sensors work on ESP32, Raspberry Pi, Android phone, etc…
Theengs is a manufacturer agnostic open-source set of tools to decode BLE sensors and integrate...
Banana Pi BPI-W3 – An RK3588 SBC with dual Gigabit Ethernet, SATA, PCIe x4 slot
Banana Pi BPI-W3 is yet another upcoming Rockchip RK3588 SBC but with a different set...
XRF16 Gen3 SOM features Xilinx Zynq UltraScale+ ZU49DR RFSoC with up to 6GHz bandwidth
We’ve written about Xilinx Zynq UltraScale+ MPSoCs that combine Arm Cortex-A53/R5 cores and Mali-400 GPU...
OSM Size M SiP Integrates STM32MP1 MPU for industrial & IoT applications
ARIES Embedded MSMP1 OSM-compatible system-in-package (SiP) based on STM32MP1 CortexA7/M4 microcontroller for Industrial and IoT...
PIX NII is a pocket-sized mini PC powered by an Intel Pentium N6005 processor (Crowdfunding)
PIX NII pocket-sized mini PC features an Intel Pentium N6005 Gemini Jasper Lake processor that...
Rock 5B RK3588 SBC preview – What works, what doesn’t in Debian 11
I’ve recently received an early sample of Radxa ROCK5 Model B (aka ROCK 5B) SBC...
Qualcomm Snapdragon W5+ and W5 wearables platforms promise higher efficiency and performance
It’s been a while since Qualcomm released a new platform for wearables. More exactly, the...
Nano-U12P – An 8K digital signage player powered by an Intel Alder Lake processor
Alder Lake processors were first formally announced at the end of 2021 with the most...
CrowPi L Raspberry Pi 4 laptop review – Part 1: Unboxing and teardown
Elecrow CrowPi L is an 11.6-inch laptop shell based on Raspberry Pi 4 designed for...
Easily work around components shortage with WIN SOURCE (Sponsored)
The electronics industry and the severe shortage of components have had a huge impact on the electronics sector, disrupting the way products are...
Libre Computer ROC-RK3328-CC now supports Ubuntu 22.04 with Linux 5.18.2
Libre Computer’s latest Ubuntu 22.04 desktop and server images for ROC-RK3328-CC board are based on...
Geniatech XPI-3566 is a business-card sized Rockchip R3566 SBC
Geniatech has added a new member to its XPI SBC family with the business card-sized...
DEBIX Model A – A Raspberry Pi-inspired NXP i.MX 8M Plus SBC for AI applications
DEBIX Model A is a single board computer powered by an NXP i.MX 8M Plus...
ASRock Industrial iEPF-9010S/iEP-9010E Edge AIoT platforms feature Alder Lake S CPU, up to 128GB RAM
Elecrow’s Raspberry Pi Pico Advanced Kit ships with 32 electronics mod
We’ve just reviewed the Raspberry Pi 4-powered CrowPi L laptop and Crowtail Starter kit used...
Nordic Semi nRF7002 is a dual-band WiFi 6 companion IC for nRF52, nRF53, and nRF91 wireless chips
Nordic Semiconductor nRF7002 dual-band WiFi 6 companion chip is the first WiFi chip from the...
TinyMaix is a lightweight machine learning library for microcontrollers
Sipeed TinyMaix open-source machine learning library is designed for microcontrollers, and lightweight enough to run...
NVIDIA Jetpack 5.0.2 release supports Ubuntu 20.04, Jetson AGX Orin
The NVIDIA Jetpack 5.0.2 production release is out with Ubuntu 20.04, the Jetson Linux 35.1...
myBuddy 280 dual arm robot features Raspberry Pi 4 SBC and ESP32 controllers
Elephants Robotics myBuddy 280, aka myBuddy 280 Pi, is a dual-arm collaborative robot for education...
Android 13 released, source code pushed to AOSP
Android 13 has just been released rolling out to Google Pixel devices initially, and later...
Thin Mini-ITX networking board features six 2.5GbE ports, Celeron J6412 Elkhart Lake SoC
Powered by an Intel Celeron J6412 quad-core Elkhart Lake processor, the Jetway MI05-0XK thin mini-ITX...
OPS-compliant digital signage player features Amlogic S905X3 CPU (Sponsored)
DataMax DM29 is a digital signage player and mini PC compliant with the OPS (Open...
AAEON EPIC-TGH7 SBC supports up to Intel Xeon W-11865MRE (Tiger Lake H) processor
It’s not often we come across an Intel Xeon SBC, but that’s just what AAEON...
BITBLAZE Titan BM15 Arm Linux laptop features Baikal-M1 processor
Russian company Prombit has unveiled the BITBLAZE Titan BM15 Arm Linux Laptop equipped with Baikal-M1...
Beelink U59 Pro review – A Jasper Lake mini PC with faster GPU performance
Beelink’s newly launched U59 Pro addresses the weak graphical performance offered by the original Beelink...
LattePanda 3 Delta SBC combines Jasper Lake processor and Arduino compatible microcontroller
The LattePanda 3 Delta single board computer with an Intel Celeron N5105 Jasper Lake processor...
SONOFF NSPanel Pro Android control panel doubles as WiFi & Zigbee Smart Home gateway
ITEAD has introduced the SONOFF NSPanel Pro Smart Home control panel running Android 8.1 on...
$4.9 CAN bus module features GD32E103 Cortex-M4 microcontroller
Seeed Studio has introduced a new CAN Bus Grove module based on 120 MHz Gigadevice...
CrowPi L Review – Part 2: Learn programming and electronics with a Raspberry Pi 4 laptop
In the first part of our review of CrowPi L Raspberry Pi 4 laptop for...
AquaPing is an open-source, battery powered acoustic water leak detector module (Crowdfunding)
The AquaPing is an open-source hardware, ultra-low power acoustic water leak detector sensor based on...
ESP32 board with rotary encoder gets 2-key keypad shield
LILYGO TTGO T-Encoder, a round-shaped ESP32 board with a built-in rotary encoder, has gotten a...
Renesas RZ/N2L Arm Cortex-R52 MPU targets industrial Ethernet and TSN
Renesas RZ/N2L is an Arm Cortex-R52 microprocessor (MPU) family for industrial Ethernet communication equipped with...
Another consequence of supply shortage: mass production mishaps
Chips may suddenly disappear from the supply chain or get really expensive due to the...
Beelink SER5 Review – An AMD Ryzen 5 5600H mini PC tested with Windows 11, Ubuntu 22.04
New to arrive in the Beelink SER lineup is the SER5 marketed as a ‘SER...
Raspberry Pi 4 gets Vulkan 1.2 conformance, Android Vulkan support
Iglia has done more work on the graphics driver for the VideoCore VI GPU found...
ACTAMID M8S – An Intel Pentium N6005 palm-sized PC with dual Gigabit Ethernet, 3x HDMI ports (Crowdfunding)
ACTAMID M8S is a palm-sized 3.4-inch mini PC powered by an Intel Pentium N6005 Jasper...
Arylic A50+ wireless stereo amplifier supports 50W speakers (Sponsored)
Acrylic A50+ is a multi-functional wireless stereo amplifier that can stream a variety of sources...
Conclusive Engineering WHLE-LS1 networking SBC offers 4x GbE, 2x 10GbE SFP+ cages
Conclusive Engineering WHLE-LS1 is a networking SBC powered by a choice of NXP Layerscape LS1xx8A...
23.8-inch touch screen system with EDLA GMS for sports, healthcare, education, advertising, and home appliances (Sponsored)
DataMax DP03F touch screen system comes with a 23.8-inch Full HD touchscreen display with anti-bacterial...
ESP-WIFI-CSI detects humans with WiFi signals only, no sensor needed
Espressif ESP-WIFI-CSI software relies on the disturbance in the force WiFi signals between one or...
Orange Pi 4 SBC gets 10.1-inch LCD touchscreen
Shenzhen Xunlong Software has released a 10.1-inch LCD touchscreen for the company’s Orange Pi 4...
TTGO T4 ESP32 board features 2.4-inch color display, IP5306 battery charging IC
LilyGO has launched yet another ESP32 board with an integrated color display. The TTGO T4...
Firefly Station M3 – A Rockchip RK3588S mini PC with up to 16GB RAM
Firefly Station M3 is a mini PC powered by Rockchip RK3588S octa-core Cortex-A76/A55 processor, the...
Sonoff ZBDongle-E Zigbee 3.0 USB dongle features EFR32MG21 MCU with +20dBm radio
ITEAD has just released a new “ZBDongle-E” Zigbee 3.0 USB adapter with Silicon Labs Mighty...
Renesas RZ/A3UL Cortex-A55 CPU runs RTOS for HMI with quick startup times
Renesas RZ/A3UL is a single-core Cortex-A55 processor clocked at up to 1 GHz designed to...
52Pi CM4 Router Board also features HDMI, 40-pin Raspberry Pi HAT header, and OLED display
We’ve already seen compact Raspberry Pi CM4 based router boards with two Ethernet ports from...
StarFive JH7110 RISC-V processor specifications released
With the Star64 and VisionFive 2 single board computers, we’ve already got two hardware platforms...
SyncBot educational mobile robot supports NVIDIA Xavier NX or Intel Tiger Lake controller
Syncbotic Syncbot is a four-wheel autonomous mobile robot (AMR) platform for research and education that...
Pine64 Star64 SBC to feature StarFive JH7110 quad-core RISC-V processor with Imagination GPU
Pine64 Star64 is an upcoming single board computer (SBC) powered by StarFive JH7110 quad-core 64-bit...
$7 Lolin S3 ESP32-S3 board ships with MicroPython firmware
Lolin S3 is the first ESP32-S3 board from the company, but instead of using the...
Beware of fake ELM327 OBD-II Bluetooth adapters
Cheap ELM327 compatible OBD-II Bluetooth adapters that connect to your car for diagnostics and retrieve...
WAFER-TGL-U 3.5-inch Tiger Lake SBC offers 3x 2.5GbE ports, SATA, 4x display interfaces
IEI’s WAFER-TGL-U is a 3.5-inch SBC based on a choice of Intel Tiger Lake UP3...
Chipsee AIO-CM4-156 – A 15.6-inch industrial All-in-One computer with Raspberry Pi CM4
Chipsee AIO-CM4-156 is an industrial All-in-One computer powered by a Raspberry Pi CM4 module and...
HiPo batteryless NFC-powered 3.52-inch e-Paper display also comes with an SPI interface (Crowdfunding)
HiPo is a 3.52-inch black and white e-Paper Display that can be updated through NFC...
ODROID-Go Ultra portable gaming console and devkit coming soon with Amlogic S922X SoC
Hardkernel is working on the ODROID-Go Ultra (OGU), their latest portable gaming console and devkit,...
UP Squared 2 is a compact Elkhart Lake SBC with Celeron N6210 or Pentium J6426 processor
UP Squared 2 is a compact single board computer powered by either an Intel Celeron...
Robustel industrial IoT gateways run Debian-based OS, offer 5G, 4G LTE, LoRaWAN connectivity
Robustel has launched three Arm-based industrial IoT gateways namely the EG5100, EG5120, and LG5100 that...
DeskPi Super6C mini-ITX board takes up to 6x Raspberry Pi CM4 modules
You may remember the Turing Pi 2 mini-ITX cluster board that supports up to four...
WiCAN ESP32-C3 CAN Bus platform is available in USB-CAN and OBD-II form factors (Crowdfunding)
WiCAN is an ESP32-C3 CAN bus adapter that works over USB, Wi-Fi, and Bluetooth LE,...
Trigkey Speed S3 mini PC review – Part 1: Unboxing and teardown
Trigkey Speed S3 is a compact mini PC powered by AMD Ryzen 5 3550H quad-core/eight-thread...
StarFive VisionFive 2 quad-core RISC-V SBC launched for $46 and up (Crowdfunding)
As expected, StarFive has officially unveiled the JH7110 quad-core RISC-V processor with 3D GPU and...
LeapFive NB2 quad-core RISC-V processor comes with GPU, NPU, and DSP
After SiFive and StarFive, here comes LeapFive RISC-V silicon vendor offering the NB2 quad-core 64-bit...
$29 Inovato Quadra Arm mini PC runs Armbian on Allwinner H6 processor
Inovato Quadra is an Arm Linux mini PC based on Allwinner H6 quad-core Cortex-A53 processor...
AI, computer vision meet LoRaWAN with SenseCAP K1100 sensor prototype kit
CNXSoft: This is another tutorial using SenseCAP K1100 sensor prototype kit translated from CNX Software...
Femto is a tiny 12x12mm Raspberry Pi RP2040 module
Mirek Folejewski has designed the ridiculously tiny Femto module based on the Raspberry Pi RP2040...
ProScreenCast SC02 is a 4K wireless HDMI transmitter & receiver kit (Sponsored)
ProScreenCast SC02 is a kit that can add wireless HDMI to any hardware with HDMI...
Wireless M-Bus & LTE Cat 1 sensor board also supports Zigbee 3.0, Z-Wave, Bluetooth LE 5.0, LoRa…
Geniatech SCB32IM is a sensor board based on Silicon Labs EFR32FG14 Arm Cortex-M4 microcontroller with...
BMAX B3 Plus Review – An Intel Celeron N5095 mini PC with two Gigabit Ethernet ports
BMAX have relaunched their B3 Plus mini PC, aka MaxMini B3 Plus, with an upgraded...
Making a DIY 10.1-inch All-in-One PC out of AMR5 Ryzen 5 gaming mini PC
Hey Karl here. The first thing I need to do is thank the manufacturer of...
Raspberry Pi Zero 2 W board gets Raspberry Pi CM3 adapter
A couple of months ago, we wrote about the Raspberry Pi Compute Module 3E (CM3E)...
Radair mini gateway – A 3-in-1 LoRaWAN gateway, Helium miner, and environmental monitoring station
Radair mini gateway is a multiple-purpose gateway with LoRaWAN, WiFi 6E, Bluetooth and Ethernet connectivity,...
Sparrow is a sensor-to-cloud LoRaWAN solution based on STM32WLE5 microcontroller
Blues Wireless Sparrow is a LoRaWAN solution designed to connect a group of low-cost, low-power...
Android 13 is already working on Qualcomm Robotics RB3 and RB5 platforms
Qualcomm Robotics RB3 (aka DragonBoard 845c) and Robotics RB5 boards can already support Android 13,...
Getting Started with LoRaWAN on SenseCAP K1100 sensor prototype kit (Part 1)
CNXSoft: This getting started guide/review of the SenseCAP K1100 sensor prototype kit is a translation...
StarFive VisionFive V1 RISC-V SBC gets Ubuntu 22.04.1 Server image from Canonical
Canonical has been working on RISC-V support for Ubuntu for a while and released Ubuntu...
MediaTek T830 to power 5G FWA routers and mobile hotspots
MediaTek T830 is a consumer premise equipment (CPE) SoC with a quad-core Cortex-A53 processor, an...
MaxLinear AnyWAN URX850, URX851, and MxL25641 Intel Atom SoCs target b
MaxLinear has just announced the availability of the first three AnyWAN broadband SoCs featuring Intel...
Khadas VIM1S low-profile SBC features Amlogic S905Y4 quad-core Cortex-A35 SoC
Khadas VIM1S is an upcoming low-profile single board computer powered by an Amlogic S905Y4 quad-core...
GENE-ADP6 – An 3.5-inch SBC with Intel 12th Gen Alder Lake-P processor, DDR5 RAM
AAEON GENE-ADP6 is a 3.5-inch SBC equipped with a choice of Intel 12th Gen Alder...
Fanless rugged controller offers 2.5GbE networking, 5G cellular, 9-36V wide power input
ARBOR ARES-1980 is a fanless rugged industrial controller powered by an Intel 11th Gen Tiger...
Radxa CM5 – A Rockchip RK3588S module (somewhat) compatible with Raspberry Pi CM4
Radxa has been working on the ROCK 5 Compute Module (aka Radxa CM5) system-on-module compatible...
How to check TDP (PL1 and PL2 power limits) in Windows and Linux
A TDP (Thermal Design Power) value in Watts will usually be provided for Intel and...
Beelink SEi11 Pro Review – An Intel Core i5-11320H mini PC tested with Windows 11, Ubuntu 22.04
The latest mini PC marketed in the ‘Pro’ range from Beelink is the SEi11 Pro...
Odyssey Blue mini PC bundle ships with Frigate open-source NVR, Coral USB AI accelerator
Odyssey Blue mini PC based on the ODYSSEY-X86J4125 SBC is now offered as part of...
OpenWrt 22.03 released with Firewall4, now supports over 1,580 embedded devices
OpenWrt 22.03 open-source Linux operating system for routers and entry-level embedded devices has just been...
PureThermal 3 board embeds FLIR Lepton FS thermal camera for $200
Groupgets PureThermal 3 (PT3) is a hackable thermal webcam that ships with the low-cost FLIR...
Sensirion SCD40 CO2 sensor units for makers: M5Stack UNIT CO2 and TeHyBug ESP8285 device
We just wrote about the Infineon XENSIV PAS CO2 Shield2Go board to measure carbon dioxide...
Topton N1 dual-bay NAS features AMD Athlon 3050e CPU, four Ethernet ports
Powered by an AMD Athlon Silver 3050e dual-core processor, Topton N1 (aka TP-N1) NAS comes...
Banana Pi BPI-R3 WiFi 6 router board features MediaTek Filogic 830/MT7986 SoC
I first noticed the MediaTek MT7986 WiFi router processor in Linux 5.17 changelog. MT7986 is...
NVIDIA Jetson Xavier NX fanless embedded box PC features four HDMI input ports
AAEON BOXER-8256AI is a fanless embedded box PC equipped with an NVIDIA Jetson Xavier NX...
Telink energy harvesting wireless module to enable batteryless remote controls
Telink TLSR8273-M-EH is a multi-protocol wireless connectivity module with energy harvesting capabilities implemented through Nowi’s...
Wi-SUN: An LPWAN standard for Smart Cities, Smart Agriculture, large scale IoT deployments
Wi-SUN is a standard (IEEE 802.15.4g) managed by the Wi-SUN Alliance and designed for Smart...
Intel Loihi 2 high-efficiency neuromorphic chip works with the Lava open-source framework
Neuromorphic AI accelerator chips relying on spiking neural networks (SNN), which we’ve seen from companies...
AAEON launches UP Xtreme i11 & UP Squared 6000 robotic development kits
AAEON’s UP Bridge the Gap community has partnered with Intel to release two robotic development...
USB4 Version 2.0 to enable speeds of up to 80 Gbps, introduce “active” USB cables
The USB Promoter Group has just pushed a press release about the “pending release” of...
Kubuntu Focus NX is a Linux mini PC with a Tiger Lake processor, two Thunderbolt 3 ports
Kubuntu Focus NX is a mini PC running Kubuntu Focus Linux operating system on an...
Trigkey Speed S3 review – Part 2: AMD Ryzen 5 3550H mini PC tested with Windows 11 Pro
After checking out Trigkey Speed S3 mini PC hardware in the first part of the...
$5 CH347 board is a USB 2.0 bridge to I2C, SPI, UART, JTAG, and GPIO
MuseLab USB-HS-Bridge is an inexpensive ($5) board based on WCH CH347 chip with a USB...
Arducam ToF camera adds depth sensing to Raspberry Pi for $30 (Crowdfunding)
Arducam has launched of Time-of-Flight (ToF) camera module for Raspberry Pi that enables depth sensing...
ESPHome compatible ESP32-S2 module offers six 32A latch relays in a DIN Rail enclosure
EasySensors “6Gang30AmpsLatchRelayEspHomeReady” (now that’s a product name!) is a DIN Rail mountable, ESP32-S2-based automation device...
Infineon XENSIV PAS CO2 Shield2Go board enables carbon dioxide measurements
Infineon has added new a shied to its Shield2Go ecosystem with the XENSIV PAS CO2...
DAQiFi Nyquist 1 – A battery-powered Wi-Fi IoT data acquisition system (Crowdfunding)
DAQiFi Nyquist 1 is a battery-powered IoT data acquisition (DAQ) device that works over an...
ESP32 board supports 2.4Ghz LoRa with SX1280 RF transceiver
We’ve seen plenty of ESP32 LoRa boards with the traditional 433 MHz, 868 MHz, or...
MangoPi MQ Quad SBC – Allwinner H616 meets Raspberry Pi Zero W form factor
MangoPi MQ Quad is an Allwinner H616 quad-core Arm Cortex-A53 SBC following Raspberry Pi Zero...
MeLE Quieter3C fanless mini PC review with Ubuntu 22.04, Windows 11
MeLE’s newly launched Quieter3C is an update to their earlier Quieter3Q product which replaces one...
ChipWhisperer-Husky is a palm-sized power analysis and fault injection
NewAE Technology’s ChipWhisperer-Husky is a compact tool designed for side-channel power analysis and fault injection...
Ochin Raspberry Pi CM4 carrier board is made for drones and robots
There are plenty of carrier boards for Raspberry Pi CM4, but the Ochin looks a...
OpenHarmony development board borrows BBC Micro:bit edge connector
HopeRun’s HiHope development board features a HiSilicon Hi3861V100 32-bit RISC-V microcontroller compatible with OpenHarmony OS...
Add 18650 batteries underneath Raspberry Pi with the Red Reactor board (Crowdfunding)
Pascal Herczog’s Red Reactor is a battery power supply project that adds two 18650 batteries...
Luxonis OAK-D series 2 USB and PoE cameras integrate 3D depth and AI for robotics applications
Luxonis OAK-D Series 2 are the second-generation of USB or PoE cameras with 3D depth...
Yuzuki Chameleon – A Raspberry Pi Model A shaped SBC with Allwinner H616 CPU
Yuzuki Chameleon is an open-source hardware single board computer powered by an Allwinner H616 quad-core...
Beetle RP2040 is a tiny Raspberry Pi RP2040 board with easily solderable pads
DFRobot Beetle RP2040 joins other miniature Raspberry Pi RP2040 developments boards such as Pimoroni Tiny...
SiFive unveils Automotive E6-A, X280-A, and S7-A RISC-V processors
RISC-V is coming to your car too, with the introduction of SiFive Automotive E6-A, X280-A,...
DeNova Detect natural gas alarm works with Amazon Sidewalk network
New Cosmos’ DeNova Detect is a wireless natural gas alarm that works with the Amazon...
Geeetech THUNDER Kickstarter campaign starts, high-speed 3D printer up to 300mm/s from $399 (Sponsored)
3D printing has always been time-consuming and challenging. But in 2022, with the advent of...
ModBerry 500 R1 industrial computer replaces Raspberry Pi CM4 with Radxa CM3 module
The ModBerry 500 R1 industrial computer features a Radxa CM3 system-on-module that follows the Raspberry...
Realtek RTD1319D STB processor supports 4K H.266 and AV1 video decoding
Realtek RTD1319D is the first set-top box processor to support H.266 (aka Versatile Video Coding)...
MeLE Quieter HD3Q Review – A fanless mini PC with dual-channel memory, 2.5-inch SATA bay
MeLE has launched a new range of passive mini PCs known as the ‘Quieter HD...
Arduino IDE 2.0 is now officially released
The first stable release of Arduino IDE 2.0 is now out. Based on the Eclipse...
Mini-ITX motherboard combines AMD Ryzen Embedded R2314 SoC with two InferX X1 AI accelerators
Flex Logix has just announced the InferX Hawk mini-ITX motherboard equipped with an AMD Ryzen...
Silicon Labs FG25 Arm Cortex-M33 SoC targets Wi-SUN FAN networks
Silicon Labs announced various new products at its annual Works With Developer Conference including the...
Picamera2 Python camera library for Raspberry Pi leverages libcamera open-source framework
Raspberry Pi Trading released a new version of Raspberry Pi OS last week with the...
ESP-Hosted simplifies adding WiFi connectivity to legacy Linux or MCU-based products
Most of the ESP8266 and ESP32 projects and products we cover here use the Espressif...
Khadas Edge2 ultra thin SBC is powered by Rockchip RK3588S processor
As noted in the Khadas VIM1S announcement, the company is also preparing to launch the...
Geniatech DB982 – An 8K TV motherboard with Amlogic T982 CPU, ATSC 3.0 TV tuner
Geniatech DB982 is a development board/motherboard powered by an Amlogic T982 quad-core Cortex-A55 processor designed...
Ztachip open-source RISC-V AI accelerator performs up to 50 times faster
Ztachip is an open-source RISC-V accelerator for vision and AI edge applications running on low-end...
8K TV box powered by Amlogic S928X Cortex-A76/A55 processor showcased at IBC 2022
Amlogic S928X multi-core Cortex-A76/A55 8K media processor, which may have been initially known as S908X,...
Sipeed MetaSense RGB ToF 3D depth cameras are made for MCUs & ROS Robots (Crowfunding)
We’ve just written about the Arducam ToF camera to add depth sensing to Raspberry Pi,...
$60 Raspberry Pi Mini Tower NAS kit takes one M.2 SATA SSD
Last year, Michael Klements made a nice-looking DIY Raspberry Pi 4 mini server with an...
Buy mini PCs at a discount during GEEKOM 19th anniversary party (Spons
GEEKOM is a Taiwanese company with 19 years of experience in the development and design...
Olimex ESP32-C3-DevKit-Lipo is a tiny RISC-V board with WiFi 4, Bluetooth 5.0, and a LiPo battery charger
Olimex has just launched the ESP32-C3-DevKit-Lipo board based on ESP32-C3 RISC-V wireless microcontroller offering WiFI...
ODROID-Go Ultra Amlogic S922X portable gaming console and devkit launched for $111
Hardkernel ODROID-Go Ultra (OGU) portable gaming console and devkit is powered by the same Amlogic...
UP Element i12 Edge embedded computer is equipped with Intel’s NUC 12 Compute Element
AAEON’s UP Bridge the Gap has announced the UP Element i12 Edge fanless embedded computer based...
Ubuntu Pro becomes free for individuals and small companies
Canonical has launched free Ubuntu Pro subscriptions for individuals and small companies for up to...
Allwinner V851S/V851SE low-cost camera SoC embeds 64MB DDR2, a 0.5 TOPS NPU
Allwinner V851S/V851SE is a single-core Arm Cortex-A7 SoC with a RISC-V core, an H.265/H.264 video...
Unexpected Maker TinyS3, FeatherS3 and ProS3 boards feature ESP32-S3 dual-core wireless MCU
Seon Rozenblum, better known as Unexpected Maker, has launched upgrades to its ESP32-S2 boards such...
RelayFi – A Tasmota compatible 4-channel relay board (Crowdfunding)
CoreData Global, a Singapore-based research and development firm, has just introduced the RelayFi 4-channel relay...
Renesas RZ/V2MA microprocessor embeds AI & OpenCV accelerators for image processing
Renesas has launched the RZ/V2MA dual-core Arm Cortex-A53 microprocessor with a low-power (1TOPS/W) DRP-AI accelerator...
The BBC has released a new web-based Python editor for the micro:bit board
There are already Python editors such as Thonny, but the BBC thought those were not...
Alibaba T-Head TH1520 RISC-V processor to power the ROMA laptop
The ROMA RISC-V laptop was announced this summer with an unnamed RISC-V processor with GPU...
AI Thinker Ai-WB2 modules feature BL602 RISC-V MCU with WiFi and BLE connectivity
AI Thinker has just introduced a new family of wireless IoT modules with the Ai-WB2...
Khadas Edge2 review with Android 12
We’ve already reviewed Khadas Edge2 Pro with Ubuntu 22.04, and I’ve now had time to...
ANAVI Macro Pad 10 & Knobs input devices run KMK firmware on Raspberry Pi RP2040 (Crowdfunding)
ANAVI Macro Pad 10, Knobs 3, and Knob 1 are open-source hardware input devices based...
Lyra V2 open-source audio codec gets faster, higher quality and compatible with more platforms
Lyra V2 is an update to the open-source Lyra audio codec introduced last year by...
Linux 6.0 release – Main changes, Arm, RISC-V, and MIPS architectures
Linux 6.0 has just been released by Linus Torvalds: So, as is hopefully clear to...
Beelink SEi12 mini PC features an Intel Core i5-1235U Alder Lake CPU
Beelink SEi12 mini PC is powered by an Intel Core i5-1235W Alder Lake U-Series 10-core...
Using SenseCraft firmware for no-code programming on Wio Terminal
In the conclusion of our SenseCAP K1100 Sensor Prototype kit review with LoRaWAN and Vision...
T-Embed is a battery powered WiFi controller with display and rotary encoder
LilyGo has launched yet another product based on the ESP32 family of microcontrollers with the...
ESP32 DevKitC V4 IoT development board ships with ESP32-WROOM-DA dual antenna module
The ESP32 DevKitC V4 is now selling with the ESP32-WROOM-DA module with two PCB antennas...
Nuvoton NuMicro MA35D1 Arm Cortex-A35/M4 microprocessor to power Linux edge IIoT gateways
Novoton NuMicro MA35D1 microprocessor features two Arm Cortex-A35 cores, one Arm Cortex-M4 real-time core, and...
ELLO LC1 – A 2mm thin DIY “computer” based on Microchip PIC18 8-bit MCU
We often write about business card or credit card-sized boards, but it’s only true for...
Geniatech unveils SMARC 2.1 compliant Rockchip RK3568 system-on-module
We’ve seen Rockchip RK3568 system-on-modules before, but the Geniatech SOM-3568-SMARC core board is the first...
Amlogic POP1-G octa-core Cortex-A73/A53 processor shows up in Amazon Fire TV Cube 2022
Amazon has just launched the “all new” Fire TV Cube streaming device with an Amlogic...
Raspberry Pi RP2040 gets into BBC Micro:bit lookalike board
ELECFREAKS Pico:ed V2 is a Raspberry Pi RP2040 board heavily inspired by the BBC Micro:bit...
3D game running on FPGA shown to be 50x more efficient than on x86 hardware
Sphery vs. shapes is an open-source 3D raytraced game written in C and translated into...
AMD launches Ryzen Embedded V3000 Zen3 processors for storage and networking applications
AMD has just launched the Ryzen Embedded V3000 family of processors with four to eight...
LiLyGo T-SIMCAM ESP32-S3 camera development board supports optional 4G LTE connectivity
ESP32-S3 has been in the news recently and we just wrote about the Bee S3...
Banana Pi BPI-M2 Ultra SBC is now offered with Allwinner A40i industrial-grade processor
The Allwinner A40i and A60i industrial-grade quad-core and hexa-core Cortex-A7 processors were first introduced in...
PCBWay – A community-focused PCB manufacturer (Sponsored)
There are many PCB manufacturers in China, but PCBWay has been around for over a...
Arylic A50+ review – An entry-level wireless stereo amplifier
The Arylic A50+ is a stereo audio streamer with a built-in power amplifier and support...
$5.5 Banana Pi BPI-PicoW-S3 ESP32-S3 board follows Raspberry Pi Pico W form factor
Banana Pi’s BPI-PicoW-S3 is a development board following the Raspberry Pi Pico W form factor,...
Everactive launches batteryless IoT devkit using Evernet low-power pro
Everactive has launched a batteryless IoT devkit to let engineers evaluate its ultra-low-power energy harvesting...
LOLIN C3 Pico is a tiny ESP32-C3 board with battery charging support
LOLIN C3 Pico is a tiny (25.4×25.4mm) ESP32-C3 RISC-V board with 2.4 GHz WiFi and...
NanoPi R6S – A Rockchip RK3588S router and mini PC with dual 2.5GbE, GbE, and… HDMI 2.1
FriendlyELEC has launched its sixth generation router with the NanoPi R6S equipped with a Rockchip...
Easily add face detection to your project with the Person Sensor module
It’s now much easier to AI features to your project thanks to better tools, but...
WiFi HaLow IoT gateway is based on Morse Micro MM6108 802.11ah chip
Most WiFi HaLow hardware platforms we’ve seen so far are based on Newracom chips, but...
WBZ451 Curiosity Board features Microchip PIC32CX-BZ2 BLE and Zigbee 3.0 microcontroller
Microchip WBZ451 Curiosity Board features the company’s Microchip’s WBZ451PE Bluetooth Low Energy 5.2 and Zigbee...
Rockchip RK3588S industrial mini PC features CAN Bus, RS485 & RS232 interfaces, relay, and more
Firefly EC-R3588SPC industrial mini PC is based on the Rockchip RK3588S octa-core Cortex-A76/A55 processor and...
Brume 2 – OpenWrt “security gateway” with MediaTek MT7981B SoC supports WireGuard VPN
GL.inet Brume 2 is an OpenWrt router, or rather a “security gateway” as the company...
uConsole is a modular Arm or RISC-V handheld computer with optional 4G connectivity
Clockwork’s uConsole is a modular handheld computer with a 5-inch display, a built-in keyboard, and...
Adapters convert Raspberry Pi Zero 2 W into Raspberry Pi 3 or 4
Spotpear’s Raspberry Pi Zero 2 W to Raspberry Pi 3/4 adapters would not exist in...
$600 Windows Dev Kit 2023 is powered by Qualcomm Snapdragon 8cx Gen 3 processor
Microsoft has just introduced the Windows Dev Kit 2023, that’s basically a Windows 11 Arm...
Elecrow – Make Your Making Easier (Sponsored)
Elecrow was officially founded in 2014, and is located in Shenzhen city. Elecrow is a...
Automation 2040 W board supports 6V to 40V I/Os, ships with Raspberry Pi Pico W
Pimoroni Automation 2040 W is an industrial/automation controller based on the Raspberry Pi Pico W...
T-Dongle-S3 USB dongle combines ESP32-S3 wireless MCU with optional color display
LilyGO T-Dongle-S3 is a USB dongle based on ESP32-S3 dual-core microcontroller with WiFi 4 and...
Miniature Raspberry Pi CM4 carrier board only exposes USB-C port and 40-pin GPIO header
Mirek Folejewski’s (aka Mirko Electronics) PicoBerry is an open-source hardware, miniature Raspberry Pi CM4 carrier...
Innodisk releases USB camera modules for AI applications
Innodisk, better known for its industrial storage solutions and embedded peripherals, has recently announced a...
10 cents CH32V003 RISC-V MCU offers 2KB SRAM, 16KB flash in SOP8 to QFN20 packages
WCH CH32V003 is a new ultra-cheap RISC-V microcontroller (MCU) clocked at 48 MHz with 2KB...
Ubuntu 22.10 released with MicroPython and improved Raspberry Pi display support
Canonical has just released Ubuntu 22.10 “Kinetic Kudu” with improved desktop usability and performance, upgrade...
WisGate Connect Raspberry Pi CM4 gateway supports 2.5GbE, WiFi 6, BLE, LoRaWAN, 4G, 5G, and more
RAKwireless has just introduced the WisGate Connect gateway based on Raspberry Pi CM4 system-on-module with...
MobileTrans – A secure phone-to-phone transfer solution (Sponsored)
If you have just purchased a new phone and feel daunted by the task of...
ZPE Nodegrid mini SR Intel Linux cloud gateway targets IoT and OT applications
ZPE Systems Nodegrid Mini SR is a compact cloud-orchestrated gateway designed for the secure management...
Making a weather station with Maker Pi Pico Mini board and SparkFun SerLCD display
Cytron’s Maker Pi Pico Mini comes with a Raspberry Pi Pico or Raspberry Pi Pico...
BIGTREETECH CB1 – A Raspberry Pi CM4 compatible Allwinner H616 system-on-module
The BIGTREETECH CB1 core board is an Allwinner H616 quad-core Arm Cortex-A53 system-on-module (SoM) that...
Mini Pupper 2 – Raspberry Pi 4 / CM4 robot dog adds ESP32, ROS2 support, servo feedback (Crowdfunding)
Mini Pupper 2 is an improved version of the Mini Pupper robot dog powered by...
MaxLinear unveils MxL31712 & MxL31708 Wi-Fi 7 chips for gateways, routers and access points
MaxLinear has unveiled its first Wi-Fi 7 SoCs with the MxL31712 and the MxL31708 single-chip...
Google KataOS – A secure OS for embedded systems written in Rust (mostly)
Google Research has been working on its own Rust-based operating system called KataOS and designed...
Espressif ESP8684 RISC-V WiFi & BLE MCU embeds up to 4MB flash in a 4x4mm package
Espressif Systems ESP8684 is a single-core RISC-V microcontroller with 2.4 GHz WiFi 4 and Bluetooth...
UP 4000 x86 SBC review with Ubuntu 22.04
The UP 4000 is a credit-card / Raspberry Pi-sized single board computer based on an...
roboBeats – Interactive music robot doubles as Bluetooth speaker (Sponsored)
Elephant Robotics just launched roboBeats interactive music robot & Bluetooth speaker on Kickstarter. The robot...
Zynq UltraScale+ SoM with up to 12GB RAM targets LiDAR applications
iWave Systems iW-RainboW-G30M is a system-on-module (SoM) based on AMD Xilinx Zynq UltraScale+ ZU4/ZU5/ZU7 FPGA...
$858 Linux mini PC features NVIDIA Jetson Xavier NX 8GB module, 128GB NVMe SSD
Seeed Studio is now selling the “A203 Mini PC” industrial Linux mini PC based on...
Create your own private cellular data network with Ukama (Crowdfunding)
Ukama is an open-source hardware solution enabling users to create their own private 4G LTE...
