r5070 | schlocke | 2011-04-22 21:46:57 +0200 (Fri, 22 Apr 2011) | 2 lines
betatunnel-output of first 12bytes with -d1
r5069 | schlocke | 2011-04-22 21:09:23 +0200 (Fri, 22 Apr 2011) | 2 lines
loadbalancer: fixed memleak
Oscam-1.00-svn5071
r5071 | alno | 2011-04-23 13:08:42 +0200 (Sat, 23 Apr 2011) | 1 line
XMLApi: repair status output
Oscam-1.00-svn5072
r5072 | Admin | 2011-04-23 22:20:46 +0200 (Sat, 23 Apr 2011) | 1 line
WebIf internal change: Continuation of #5057: Get completely rid of uint64ToBitchar function.
r5075 | schlocke | 2011-04-25 12:38:56 +0200 (Mon, 25 Apr 2011) | 3 lines
loadbalancer: added pending ecm count of reader to loadbalancer value,
added better timeouthandling of readers
r5074 | merek | 2011-04-25 10:40:05 +0200 (Mon, 25 Apr 2011) | 1 line
Revert changes in oscam-config.h
r5076 | Admin | 2011-04-25 17:34:51 +0200 (Mon, 25 Apr 2011) | 1 line
Fix segfault when changing loghistsize. Note that the log is not preserved when shrinking loghist.
Oscam-1.00-svn5078
r5078 | Admin | 2011-04-25 18:09:52 +0200 (Mon, 25 Apr 2011) | 1 line
Fix memleak
r5077 | Admin | 2011-04-25 18:07:52 +0200 (Mon, 25 Apr 2011) | 1 line
Remove a line from last commit which prevented restoring loghistory correctly when growing it.
r5079 | Admin | 2011-04-25 19:37:41 +0200 (Mon, 25 Apr 2011) | 1 line
Adjust login time of first client when waiting was necessary on startup for the time to correct.
Fix memleak
r5080 | schlocke | 2011-04-26 00:13:54 +0200 (Tue, 26 Apr 2011) | 3 lines
cccam: node definition for vplug/Hadu
loadbalancer: better timeout handling of readers
r5082 | cogsi | 2011-04-26 13:41:28 +0200 (Tue, 26 Apr 2011) | 1 line
gbox: checksum calc
r5081 | cogsi | 2011-04-26 13:37:05 +0200 (Tue, 26 Apr 2011) | 1 line
gbox: client improvements
Oscam-1.00-svn5083
r5083 | cogsi | 2011-04-26 14:58:14 +0200 (Tue, 26 Apr 2011) | 1 line
gbox: further initial work for local card support
Oscam-1.00-svn5084
r5084 | schlocke | 2011-04-26 23:15:11 +0200 (Tue, 26 Apr 2011) | 2 lines
loadbalancer with auto-betatunnel (option)
Oscam-1.00-svn5098
r5098 | schlocke | 2011-04-27 18:58:13 +0200 (Wed, 27 Apr 2011) | 2 lines
cccam: added some debugoutput
r5097 | landlord | 2011-04-27 13:59:53 +0200 (Wed, 27 Apr 2011) | 1 line
Added example for 'caid' mask parameter.
r5096 | landlord | 2011-04-27 13:43:47 +0200 (Wed, 27 Apr 2011) | 1 line
Small update for 'caid' parameter in 'oscam.user' and 'oscam.server' documentation.
r5095 | landlord | 2011-04-27 11:21:36 +0200 (Wed, 27 Apr 2011) | 1 line
Removed unnecessary Betatunnel CAIDs from 'lb_auto_betatunnel'.
---------- Post added at 22:59 ---------- Previous post was at 22:55 ----------
r5100 | schlocke | 2011-04-27 21:31:50 +0200 (Wed, 27 Apr 2011) | 2 lines
added debug output
r5099 | _network | 2011-04-27 21:26:32 +0200 (Wed, 27 Apr 2011) | 2 lines
camd35: fix delay for cache answers after cmd05
r5101 | schlocke | 2011-04-28 11:34:29 +0200 (Thu, 28 Apr 2011) | 3 lines
loadbalancer: betatunnel fix
loadbalancer: handling of readers with services and timeout stats fixed
added debug output
Oscam-1.00-svn5102
r5102 | landlord | 2011-04-28 13:11:12 +0200 (Thu, 28 Apr 2011) | 1 line
Added new parameter 'lb_reopen_mode' to documentation.
r5103 | _network | 2011-04-28 17:45:37 +0200 (Thu, 28 Apr 2011) | 2 lines
dvbapi: allow multiple length filter per channel
