Oscam-1.00-svn5001
r5001 | Deas | 2011-04-14 11:21:31 +0200 (Do, 14 Apr 2011) | 1 line
fix compile error - change suggested by Admin here: [Only registered and activated users can see links. Click Here To Register...]
r5000 | schlocke | 2011-04-14 10:15:44 +0200 (Do, 14 Apr 2011) | 2 lines
webif/cccam: sharelist limited to 500 shares, next/prev function
r4999 | neoen | 2011-04-14 08:32:12 +0200 (Do, 14 Apr 2011) | 1 line
small type fix and small nds emm fix
r4998 | Admin | 2011-04-14 02:41:42 +0200 (Do, 14 Apr 2011) | 1 line
Some more adjustments for a stricter variable size definition.
r4997 | Admin | 2011-04-14 00:37:03 +0200 (Do, 14 Apr 2011) | 1 line
Fix wrong auto-replacement for some libusb code
r4996 | Admin | 2011-04-14 00:11:21 +0200 (Do, 14 Apr 2011) | 1 line
Changes introduced in r4982 could lead to some disabled clients getting recognized as anonymous on some plattforms.
r4995 | alno | 2011-04-13 23:30:04 +0200 (Mi, 13 Apr 2011) | 1 line
WebIf: cccam blockwise entitlement 2nd try
r4994 | Admin | 2011-04-13 23:19:59 +0200 (Mi, 13 Apr 2011) | 1 line
I noticed that monitor encryption is not working on 64bit plattforms due to other sizes of long on this plattform. This patch converts all numeric types like long to portable types like uint32_t. This is not complete yet (only base folder up to r4987, changes thereafter might be incompletely converted). If you encounter problems through this patch please report in forum.
r4993 | schlocke | 2011-04-13 23:03:54 +0200 (Mi, 13 Apr 2011) | 2 lines
small typo fix
Oscam-1.00-svn5014
r5014 | Admin | 2011-04-15 02:43:52 +0200 (Fri, 15 Apr 2011) | 1 line
Add extra message on disabled user login. Log a bit more info on killing threads and clean up ourselves when thread doesnt do so within 500ms. Please report when you get such messages in log.
r5013 | Admin | 2011-04-15 01:07:39 +0200 (Fri, 15 Apr 2011) | 1 line
WebIf: Let http thread be displayed as http instead of monitor.
r5012 | Admin | 2011-04-15 00:27:30 +0200 (Fri, 15 Apr 2011) | 1 line
disableuserfile now defaults to 1 and is automatically set to 1 if userfile is empty. You may use disableuserfile to quickly change between enabled/disabled while keeping the variable userfile filled. Furthermore, it saves some performance if it is disabled (thats also the reason for automatically setting it to 1 if userfile is empty).
r5011 | Admin | 2011-04-14 23:58:50 +0200 (Thu, 14 Apr 2011) | 1 line
Fix: You always need to set a logfile, so this defaults now to CS_LOGFILE (plattform dependend, mostly /var/log/oscam.log). If you really want to disable logging, set disablelog=1 and logfile to stdout.
r5010 | Admin | 2011-04-14 23:10:04 +0200 (Thu, 14 Apr 2011) | 1 line
Show IP address of active connection on users page (only displayed when connected/online as this info isn't available otherwise).
r5009 | alno | 2011-04-14 22:30:21 +0200 (Thu, 14 Apr 2011) | 1 line
WebIf: prepare new parameter 'httpenhancedstatuscccam=0|1' (default 0) Because several parts in statusview related to cccam cards can have influence to main performance. User must opt-in in the future.
r5008 | Admin | 2011-04-14 22:22:56 +0200 (Thu, 14 Apr 2011) | 1 line
Do not save port in monitor section anymore when it is 0. The monitor section is somewhat special in config as some parameters are shared with WebIf and so need to be saved even when monitor itself is not active.
r5007 | schlocke | 2011-04-14 22:06:20 +0200 (Thu, 14 Apr 2011) | 2 lines
Anticascader: tryfix?
r5006 | landlord | 2011-04-14 20:55:49 +0200 (Thu, 14 Apr 2011) | 1 line
Some small updates in documentation.
r5005 | Admin | 2011-04-14 20:34:09 +0200 (Thu, 14 Apr 2011) | 1 line
Fix restart error when using dvbapi and a compiler error on tuxbox ppc, see [Only registered and activated users can see links. Click Here To Register...]
r5004 | Admin | 2011-04-14 20:18:57 +0200 (Thu, 14 Apr 2011) | 1 line
Fix missing includes for coolapi since r4998.
r5003 | alno | 2011-04-14 19:59:04 +0200 (Thu, 14 Apr 2011) | 1 line
revert #5002
r5002 | alno | 2011-04-14 19:34:15 +0200 (Thu, 14 Apr 2011) | 1 line
Try fix for webif restart
Oscam-1.00-svn5016
r5016 | landlord | 2011-04-15 12:51:56 +0200 (Fri, 15 Apr 2011) | 1 line
Added new paramter 'httpenhancedstatuscccam' to documentation.
r5015 | schlocke | 2011-04-15 12:01:52 +0200 (Fri, 15 Apr 2011) | 2 lines
small cleanup fix
Oscam-1.00-svn5021
r5021 | Admin | 2011-04-15 22:00:03 +0200 (Fri, 15 Apr 2011) | 1 line
Fix incomplete cs_auth_client() validation in newcamd module.
r5020 | landlord | 2011-04-15 20:31:33 +0200 (Fri, 15 Apr 2011) | 1 line
Highlight hint for memory consumption 'oscam.srvid'.
r5019 | landlord | 2011-04-15 20:27:26 +0200 (Fri, 15 Apr 2011) | 1 line
Added hint for pay-per-view services in 'oscam.dvbapi'.
r5018 | Deas | 2011-04-15 20:20:49 +0200 (Fri, 15 Apr 2011) | 1 line
fix typo on last commit, change wording a little bit...
Oscam-1.00-svn5023
r5023 | Deas | 2011-04-15 23:13:17 +0200 (Fri, 15 Apr 2011) | 1 line
update wording of service-id?\194?\180s count message.
r5022 | Admin | 2011-04-15 22:53:51 +0200 (Fri, 15 Apr 2011) | 1 line
Fix: Don't save l_port and slot anymore for readers where this is invalid (if httpsavefullcfg=1)
Oscam-1.00-svn5025
r5025 | Admin | 2011-04-16 02:12:28 +0200 (Sat, 16 Apr 2011) | 1 line
Fix wrong display of expired and disabled users count in log when userdb is reloaded.
r5024 | Admin | 2011-04-16 02:01:12 +0200 (Sat, 16 Apr 2011) | 1 line
Fix a bug reported in #1726: Nmap scans on WebIf port could crash OSCam because of malformed requests being sent.
Oscam-1.00-svn5028
r5028 | _network | 2011-04-16 19:45:36 +0200 (Sat, 16 Apr 2011) | 2 lines
fix small bug from r5026
r5027 | _network | 2011-04-16 18:39:30 +0200 (Sat, 16 Apr 2011) | 2 lines
irdeto: add possible fix for nova card
r5026 | _network | 2011-04-16 15:22:24 +0200 (Sat, 16 Apr 2011) | 2 lines
split up srvid list for faster searches
r5029 | alno | 2011-04-16 22:46:13 +0200 (Sat, 16 Apr 2011) | 1 line
Monitor: fix AU status (THX @ FlatTV @ Streamboard)
r5030 | alno | 2011-04-16 23:13:12 +0200 (Sat, 16 Apr 2011) | 1 line
WebIf: Add No. localhops to status (depending on 'httpenhancedstatuscccam')
r5031 | schlocke | 2011-04-17 12:30:20 +0200 (Sun, 17 Apr 2011) | 2 lines
loadbalancer: fixed lb_noproviderforcaid
Oscam-1.00-svn5034
r5034 | Admin | 2011-04-17 16:57:26 +0200 (Sun, 17 Apr 2011) | 1 line
WebIf: Allow using maxlogsize=0 (unlimited logsize). This got lost some time ago when a check for value validity was inserted. Beware that you only should set it to 0 if you know what you're doing as it may take up huge space and OSCam might crash when it reaches max size for files (probably at around 4 GB).
r5033 | Admin | 2011-04-17 16:36:51 +0200 (Sun, 17 Apr 2011) | 1 line
Explicitly initialize itused variable with 0.
r5032 | _network | 2011-04-17 15:53:45 +0200 (Sun, 17 Apr 2011) | 2 lines
fix crash when loading malformed srvid file
Oscam-1.00-svn5041
r5041 | landlord | 2011-04-18 14:09:18 +0200 (Mon, 18 Apr 2011) | 1 line
Removed parameter 'httpenhancedstatuscccam' from documentation.
r5040 | schlocke | 2011-04-18 08:23:02 +0200 (Mon, 18 Apr 2011) | 3 lines
loadbalancer: new parameter lb_max_readers to limit the amount of
readers during learning
r5039 | alno | 2011-04-17 23:25:56 +0200 (Sun, 17 Apr 2011) | 1 line
WebIf: some eyecandy for hops ;-)
r5038 | schlocke | 2011-04-17 23:09:26 +0200 (Sun, 17 Apr 2011) | 3 lines
cccam/webif: removed httpenhancedstatuscccam parameter, now default.
Also added mouseover informations.
r5037 | schlocke | 2011-04-17 22:36:17 +0200 (Sun, 17 Apr 2011) | 2 lines
cccam: preparing hop status for webif
r5036 | _network | 2011-04-17 20:03:00 +0200 (Sun, 17 Apr 2011) | 3 lines
fix #1796;
cryptoworks: define all parts of assembled shared emm as shared
r5035 | Admin | 2011-04-17 19:50:06 +0200 (Sun, 17 Apr 2011) | 1 line
Fix: AU parameter in users section wasn't correctly matched to readers as the string wasn't compared in full length. This also led to duplicates if one reader exists where the name is the same as the beginning of the other.
r5042 | schlocke | 2011-04-18 14:55:46 +0200 (Mon, 18 Apr 2011) | 9 lines
loadbalancer: added lb_noproviderforcaid=18,17 for full system support
loadbalancer: fixed switching of nonresponding readers
--This line, and thosel below, will be ignored--
M module-datastruct-llist.c
M module-datastruct-llist.h
M module-stat.c
M oscam-http.c
Oscam-1.00-svn5043
r5043 | schlocke | 2011-04-18 15:53:20 +0200 (Mon, 18 Apr 2011) | 3 lines
cccam/webif: added number of reshareable cards with no reshare / reshare=1 /
reshare=2 and reshare >2
r5045 | schlocke | 2011-04-18 18:20:01 +0200 (Mon, 18 Apr 2011) | 3 lines
added thread locks reader/client start/stop
cccam: added cleanip locks fix
r5044 | landlord | 2011-04-18 17:05:36 +0200 (Mon, 18 Apr 2011) | 1 line
Added new parameter 'lb_max_readers' to documentation.
Oscam-1.00-svn5047
r5047 | Deas | 2011-04-18 19:10:50 +0200 (Mon, 18 Apr 2011) | 1 line
forgot to remove variable on last commit...
r5046 | Deas | 2011-04-18 19:09:48 +0200 (Mon, 18 Apr 2011) | 1 line
3rd try with service-id?\194?\180s log message... ;)
