MSI Shows off its QD-OLED Displays at CES
Back at Computex 2022, MSI first announced the <a href="https://www.techpowerup.com/295274/msi-reveals-the-meg-342c-qd-oled-display-at-computex-2022" target="_blank">MEG 342C QD-OLED</a> display, which finally appears to be ready to hit retail, as the company was showing off it, alongside its upcoming <a href="https://www.techpowerup.com/301435/msi-teases-49-inch-super-ultra-wide-qd-oled-monitor" target="_blank">MEG 491C QD-OLED</a> display, which was teased back in November. MSI revealed some additional details of the 34-inch MEG 342C QD-OLED, beyond the fact that it's using a curved 1800R, 3440 x 1440 resolution panel with a 175 Hz refresh rate. As such, we now know the monitor has an unspecified DisplayPort input, a pair of HDMI 2.1 inputs, a USB Type-C input with DP Alt mode support and 65 W USB Power Delivery support, as well as a USB-B upstreams port and four USB-A downstreams ports. MSI has also kitted out the monitor with OLED Care, which the company claims reduces image sticking and burn-in. Other features include a built in KVM, PBP and PIP support as well as a VESA DisplayHDR True Black 400 certification, although the monitor has a peak brightness of 1000 nits. The MEG 342C QD-OLED is said to have an MSRP of around US$800.<br />
<br />
The MEG 491C QD-OLED appears to be based on the same QD-OLED panel as Samsung's OLED G9. The model on display at CES was apparently non functional, which suggests that we might have to wait another six months before it becomes available, if the MEG 342C QD-OLED is anything to go by. The monitor sports the same 1800R curvature as the Samsung OLED G9 and obviously has the same 5120 x 1440 resolution and 240 Hz refresh rate. MSI didn't share much else in terms of specifications, so we're going to have to wait for the actual launch to find out more, including what will probably be a prohibitively high price tag.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OhpYJ5TJBc3TxPB9.jpg" target="_blank" data-width="1280" data-height="658" ><img src="https://tpucdn.com/img/OhpYJ5TJBc3TxPB9_thm.jpg" width="253" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Fhnr9zUdq1SbOKXK.jpg" target="_blank" data-width="1280" data-height="943" ><img src="https://tpucdn.com/img/Fhnr9zUdq1SbOKXK_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/okYlGhr5AYA3BjAx.jpg" target="_blank" data-width="1126" data-height="681" ><img src="https://tpucdn.com/img/okYlGhr5AYA3BjAx_thm.jpg" width="215" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303415/msi-shows-off-its-qd-oled-displays-at-ces">Read full story</a></div>
iBuyPower Trace Gaming Case and Peripherals at CES Hands On
At the 2023 International CES, the lifestyle PC case brand HYTE shared its booth with its parent brand iBuyPower, a leading prebuilt gaming PC vendor, which showed off a premium mid-tower case under its own marquee rather than under HYTE. The new iBuyPower Trace 7 Mesh can be purchased as a standalone case, or you can buy prebuilt gaming desktops featuring it. The ATX mid-tower features a conventional horizontally-partitioned layout with an airy mesh front-panel. The case is tested to support many of the newer-generation graphics cards with 3+ slot thickness and 16-18 cm height. Among the fan-vents included with the case are three 120 mm along the front, with room for a 360 mm radiator, two 120 mm top exhausts that can hold onto a 240 mm radiator, and a 120 mm rear exhaust. <br />
<br />
Among the two new gaming peripherals released by iBuyPower are the Chimera K7 gaming keyboard, and the Chimera M7 gaming mouse. The two will be part of the Chimera KM7 combo, which can be added to your iBuyPower build, or sold piecemeal. The Chimera K7 is a membrane-type gaming keyboard with 24 RGB lighting zones that can be controlled via the HYTE Nexus software; while the Chimera M7 is a palm grip-optimized pseudo-ambidextrous wired mouse with an RGB diffuser that makes up the top grip. The HYTE Nexus software is used for fine-tuning the performance and lighting of this mouse.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vmhDAghZ8JSwCn9V.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/vmhDAghZ8JSwCn9V_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Dx9JhmAO38LSwaX1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Dx9JhmAO38LSwaX1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XWsBD6ffuyqfZJri.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XWsBD6ffuyqfZJri_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FAanjd2kvQkXiJMg.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/FAanjd2kvQkXiJMg_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Level Up Ethernet Connectivity with NEXCOM's New High-Performance Network Appliance
NEXCOM, a leading supplier of network appliances, launched a new platform based on the 4th Gen Intel Xeon Scalable processor - the NSA 7160. This high-performance 2U rackmount is a long-awaited enhancement of NEXCOM's well-established cyber security product line. NSA 7160 is equipped with the latest Intel technologies, featuring eight PCIe Gen5 extension slots for LAN modules, built-in accelerators, CXL1.1 and supports installation of RunBMC module & full-height full-length (FHFL) card.<br />
<br />
NEXCOM's NSA 7160 is intended for network security and 5G network applications, with cutting-edge features like multi-core computing performance, high memory capacity, high-speed I/O interface, and improved Intel QuickAssist Technology (Intel QAT) hardware acceleration for both enterprise and telecommunication applications. By leveraging 4th Gen Intel Xeon Scalable processors, NSA 7160 accelerates performance across the fastest-growing workloads and delivers value across multiple applications.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/9AXuGI4PsuRfTTjL.jpg" target="_blank" data-width="1000" data-height="854" ><img src="https://tpucdn.com/img/9AXuGI4PsuRfTTjL_thm.jpg" width="152" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303410/level-up-ethernet-connectivity-with-nexcoms-new-high-performance-network-appliance">Read full story</a></div>
(PR) Lenovo Unveils Next Generation of Intel-Based Smart Infrastructure Solutions to Accelerate IT Modernization
Today, Lenovo unveiled 25 new ThinkSystem and ThinkAgile server and hyperconverged solutions powered by Intel's 4th Generation Xeon Scalable Processors as part of its recently announced Infrastructure Solutions V3 portfolio. Designed to help accelerate global IT modernization for organizations of all sizes, the integrated solutions deliver advanced performance, efficiency and management capabilities specifically optimized for complex workloads, including mission-critical, AI, HPC and containerized applications.<br />
<br />
"In today's competitive business climate, modern infrastructure solutions that generate faster insights and more efficiently enable complex workloads from the edge to the cloud are critical across every major industry," said Kamran Amini, Vice President and General Manager of Server & Storage, Lenovo Infrastructure Solutions Group. "With the performance and management improvements of the Intel-based ThinkSystem V3 portfolio, customers can reduce their IT footprint by up to three times to achieve greater ROI and more easily transform their infrastructure with one seamless platform designed for today's AI, virtualization, multi-cloud and sustainable computing demands."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CWWS7cn0D7v1a8UX.jpg" target="_blank" data-width="2000" data-height="960" ><img src="https://tpucdn.com/img/CWWS7cn0D7v1a8UX_thm.jpg" width="271" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303409/lenovo-unveils-next-generation-of-intel-based-smart-infrastructure-solutions-to-accelerate-it-modernization">Read full story</a></div>
HYTE Y40 Up Close: Truly a Next-Gen Case for Next-Gen Hardware
At first glance, the HYTE Y40 may seem like a short and stout Micro-ATX tower, but up close, it's actually an ATX mid-tower that just so happens to look stout, and ready for the latest generation of CPU cooling solutions and 4-odd slot graphics cards. The Y40 retains HYTE's essential design language of making sure the front-left panel seems like a contiguous glasshouse. The case is horizontally partitioned, with the bottom compartment having the PSU- and drive bays, while the upper compartment has a spacious motherboard tray. This is where things get very interesting.<br />
<br />
The HYTE Y40 is unconventional in that all the 7 expansion slots of its motherboard tray are half-height (low-profile), while there are four full-height vertical slots, which is where you're supposed to install your graphics card. HYTE includes a PCI-Express 4.0 x16 riser with the case. All other expansion cards need to be half-height. Most aftermarket non-graphics add-on cards these days, such as WLAN cards, 10 GbE cards, USB/Thunderbolt cards, or even some sound cards, are half-height and include low-profile brackets anyway. The case is much longer than the motherboard tray itself, which opens up room for a 280 mm radiator mount along the plane of the motherboard tray. The Y40 offers clearance for graphics cards up to 4 slots thick, up to 94 mm tall, and up to 42.2 cm in length (the ASUS ROG Strix RTX 4090 should fit). There's also room for CPU coolers up to 18.3 cm in height.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/l8fjPaDuQ7d6cLml.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/l8fjPaDuQ7d6cLml_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6xpT6ESrZaiAUbbL.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/6xpT6ESrZaiAUbbL_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vFBdsZlfB4agWlRz.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/vFBdsZlfB4agWlRz_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UQwM729loYfmj6nA.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/UQwM729loYfmj6nA_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XXavERcL7zu9u4td.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XXavERcL7zu9u4td_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303408/hyte-y40-up-close-truly-a-next-gen-case-for-next-gen-hardware">Read full story</a></div>
innocn Shows Off Mini-LED, Fast IPS, and Curved OLED Gaming Monitors at CES
New entrant innocn showed off five new gaming monitors at the 2023 International CES, of various shapes and sizes, and with various display panel technologies. The 27B8U is a stunning, no-nonsense, 27-inch planar monitor with 4K Ultra HD (3840 x 2160 pixels) resolution, standard 60 Hz refresh rate, and 0.03 ms response time from its OLED panel. The 32A6U is another planar beauty, albeit larger at 31.5-inch panel size. It features an IPS panel with mini-LED backlighting, and 2,304 local dimming zones. This one, too, has a 60 Hz refresh-rate. The S48A8V-S is a 48-inch "large-format" gaming monitor with an OLED planar panel that has 4K Ultra HD resolution, 138 Hz refresh-rate, and 0.03 ms response time.<br />
<br />
Things get interesting with the company's curved gaming monitors, starting with the 45E3R, a 44.5-inch curved super-ultrawide monitor with 32:9 aspect ratio for the VA panel that has a native resolution of 5120 x 1440 pixels, 1500R curvature, and 120 Hz refresh-rate. The 34E7R has a more conservative 21:9 aspect ratio on its 34-inch, 1500R curved panel, but a much faster VA panel with mini-LED illumination that offers 2,304 LDZs, and 165 Hz refresh-rate. The 34E9R is the most advanced curved gaming monitor from the lot, with a 34-inch 1800R-curved OLED panel, 3440 x 1440 pixels resolution, 175 Hz refresh-rate, and 0.03 ms response time.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Z5z5Qu6SuA8CLXdO.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Z5z5Qu6SuA8CLXdO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fRcwtlh7PazjjigW.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/fRcwtlh7PazjjigW_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2JPf19yF6IF9N6cb.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/2JPf19yF6IF9N6cb_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BxsbHFST259I9Zk0.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/BxsbHFST259I9Zk0_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XmfantxlHFwLJY9Z.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XmfantxlHFwLJY9Z_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8oiaJyLJxx3JACoa.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/8oiaJyLJxx3JACoa_thm.jpg" width="173" height="130" alt="" /></a></div>
HYTE Unleashes the Potential of its Unique Y60 Case Design with Touchs
HYTE started out as a DIY retail channel brand for the unique case and peripheral designs of gaming PC builder iBuyPower, but has grown into a unique brand on its own. Their most iconic product, the Y60 case, stands out for its "corner plot" design, where the front-left corner of the case has been carved out into a corner-facing side. In most trims of the Y60, this would be a tempered glass panel; and some of the newer themed variants, this is an additional surface for air—either decals or stained-glass/prints. At the 2023 International CES, the company unlocked two unique uses for this corner panel.<br />
<br />
The first of these is a touchscreen that spans the entire height of the panel, and connects to your graphics card like any other display, and takes up a USB header for the touch input. The possibilities for this screen are endless—scroll through Windows 11 Start widgets, use a hardware monitoring app, as a game HUD, or what have you. The second of these is a really groovy distro-plate + pump device designed by iBuyPower. You no longer need to cover the entire front-panel with one of these, can they can take up the corner panel. The coolant ports of the plate are optimally located for builds using this case. The company even designed HYTE branded fittings to go with these.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UJMKLAibv8dKBPQB.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/UJMKLAibv8dKBPQB_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SqWj2CoB3uRBwgV8.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/SqWj2CoB3uRBwgV8_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WDjcAKHPD3qTvjq6.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/WDjcAKHPD3qTvjq6_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sq0DL5e93p7bw2dA.jpg" target="_blank" data-width="907" data-height="904" ><img src="https://tpucdn.com/img/sq0DL5e93p7bw2dA_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jynYYdy5Er0nIp1f.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/jynYYdy5Er0nIp1f_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yDp2yeWXrTFaVRrV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/yDp2yeWXrTFaVRrV_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Team Group Announces JEDEC-standard DDR5-6400 Memory with Client Clock Drivers
World-leading memory brand, Team Group, has announced new breakthroughs in the Team Group ELITE U-DIMM DDR5 Standard Memory. To ensure compatibility with next-generation platforms, Team Group has pioneered the first high-performance 6400 MHz spec per JEDEC definitions for consumers to enjoy upgraded performances with ease in the DDR5 generation. <br />
<br />
To ensure a stable performance of 6400 MHz and above of the DDR5, Team Group has adopted the new CKD (client clock driver) components designed to strengthen, buffer, and steadily output high-frequency signals from the CPU to DDR5 memory kits, effectively ensuring high frequencies while supporting reliable high-speed transmissions. Team Group is dedicated to R&D and working simultaneously with motherboard manufacturers for rigorous compatibility testing, offering high-quality and highly compatible memory products for desktops and laptops to consumers around the world, fulfilling user demands for PC, laptops, or other small systems.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DpHKmekAt7eLhn24.jpg" target="_blank" data-width="919" data-height="568" ><img src="https://tpucdn.com/img/DpHKmekAt7eLhn24_thm.jpg" width="210" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/M92q6etjfqUy7tu2.jpg" target="_blank" data-width="800" data-height="435" ><img src="https://tpucdn.com/img/M92q6etjfqUy7tu2_thm.jpg" width="239" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303401/team-group-announces-jedec-standard-ddr5-6400-memory-with-client-clock-drivers">Read full story</a></div>
Wizmax Micronics PC Cooling at CES: MA Frigate and MA Falcon CPU Coolers, Warp Shield Heatsinks
Wizmax by Micronics introduced a handful new CPU coolers and purpose-build heatsinks at the 2023 International CES. The CPU cooler lineup is led by the MA Frigate series. The MA4 Frigate, a thick single aluminium fin-stack tower-type cooler. Five 6 mm-thick copper heatpipes make direct contact with the CPU at the base, conveying heat through a thick aluminium fin-stack, which is ventilated by a custom-design 130 mm fan. With this fan in place, the cooler measures 132 mm x 95 mm x 156.4 mm (WxDxH), weighing 990 g. The fan turns at speeds of up to 1,500 RPM, pushing up to 71.7 CFM of airflow at 1.9 mm H₂O static-pressure. The MA4 Frigate is rated for handling thermal loads of up to 210 W.<br />
<br />
The Wizmax MA6 Frigate is the larger sibling, with a type-D dual fin-stack design. Six 6 mm-thick nickel-plated copper heatpipes make indirect contact with the CPU through a copper base, conveying heat to two fin-stacks, which are ventilated by a pair of 140 mm fans in push-pull arrangement. One-third of the fins in the two fin-stacks are made of copper, and the rest aluminium. Each of the two 140 mm fans turns at speeds of up to 1,500 RPM, pushing up to 83 CFM of airflow at 2.2 mm H₂O. With the fans in place, the cooler measures 146 mm x 165 mm x 165 mm (WxDxH), weighing 1.6 kg. The MA6 Frigate is rated for 250 W thermal loads. Both coolers support the latest CPU socket types, including AM5 and LGA1700.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/m2M6GywsapvOAZA8.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/m2M6GywsapvOAZA8_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/24KdeaIKJR8Bc2ek.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/24KdeaIKJR8Bc2ek_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Sfa3mCARBzKRPFPr.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Sfa3mCARBzKRPFPr_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/exozmxYWEl4DVcar.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/exozmxYWEl4DVcar_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4oWqE9nRQsFXuUOA.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4oWqE9nRQsFXuUOA_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303400/wizmax-micronics-pc-cooling-at-ces-ma-frigate-and-ma-falcon-cpu-coolers-warp-shield-heatsinks">Read full story</a></div>
Wizmax Micronics New 2023 Power Supplies at CES: Amped Up for ATX 3.0 and PCIe Gen 5
Wizmax by Micronics showed off four new PSU lines at the 2023 International CES. At the top of the stack is the Astro II Gold, a monstrous high-end PSU with 1650 W continuous output, 80 Plus Gold switching efficiency, ATX 3.0 and PCIe Gen 5 standards compliance, and a patented digital-VRM voltage controller by Micronics. Other internal features include DC-to-DC switching a 135 mm fluid-dynamic bearing fan Zero RPM mode up to a certain electrical load, and fully-modular connectivity that includes two 16-pin ATX 12VHPWR connectors with 600 W continuous output each, twelve 6+2 pin PCIe power, two 4+4 pin EPS, and fourteen SATA power connectors.<br />
<br />
The Astro II Platinum is technically positioned a notch below the Astro II Gold 1650 W, but is more efficient. The Astro II Platinum comes in 1300 W, 1000 W, and 850 W variants. The 1300 W variant offers two 16-pin 12VHPWR connectors (each 600 W), while the 1000 W and 850 W ones offer one such 16-pin connector. The three get their names from the 80 Plus Platinum switching efficiency on offer, besides a feature-packed AC receptacle with Surge 4K and ESD 15K tolerance, and fluid-dynamic bearing fans with zero RPM up to a certain load.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JrBPugFpwAUFQtSy.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/JrBPugFpwAUFQtSy_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Heb8t32kDJzOR9lb.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Heb8t32kDJzOR9lb_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eK7r5f19EwtgWPal.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/eK7r5f19EwtgWPal_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fQMc1N7SVs2swGnO.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/fQMc1N7SVs2swGnO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lWbgMnOtWevvumhf.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/lWbgMnOtWevvumhf_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303399/wizmax-micronics-new-2023-power-supplies-at-ces-amped-up-for-atx-3-0-and-pcie-gen-5">Read full story</a></div>
An Introduction to Wizmax, a New Gaming PC Hardware Brand Storming the
Wizmax is a brand that came out of nowhere, with a strong presence at the 2023 International CES, debuting several new DIY gaming PC products, spanning cases, CPU coolers, case fans, peripherals, and power supplies. Wizmax is making inroads to western markets, and has its origins in South Korea, where it was started as a DIY channel brand by electronics OEM giant Micronics, which has been in business since 1996. While it works to set up a more organized distribution network, Wizmax is selling through a brand store on Amazon, with their lineup currently focused on gaming peripherals.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FseBT03m5Jv7IPvJ.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/FseBT03m5Jv7IPvJ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8isjccLBKgWMn9xV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/8isjccLBKgWMn9xV_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/88s32WEDMJZ1fDNB.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/88s32WEDMJZ1fDNB_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MOZhEM1zfHHl3tOs.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/MOZhEM1zfHHl3tOs_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) EK Pro Releases 4th Gen Intel Xeon Scalable CPU Water Blocks
EK, the leading liquid cooling gear manufacturer, is announcing the availability of two high-performance liquid cooling solutions for the Intel "Sapphire Rapids" processor family. These single-socket LGA4677 water blocks are specifically designed to cool the 4th Gen Intel Xeon Scalable CPUs that are optimized for advanced workstation professionals and go up to 60 cores. <br />
<br />
EK is quite experienced with demanding needs of heavily threaded, I/O intensive workloads across the industries like Architecture, Engineering and Construction, Media and Entertainment, and Artificial Intelligence and Machine Learning. This enabled them to create the EK-Pro CPU WB 4677, a water block designed to provide sufficient thermal headroom to maximize the performance benefits of Intel Turbo Boost Technology while maintaining healthy processor operating temperatures. EK aimed to create a liquid cooling solution that enables customers to operate at peak performance unrestricted by any thermals.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Sb6QtVwCIP5fZXKv.jpg" target="_blank" data-width="1303" data-height="588" ><img src="https://tpucdn.com/img/Sb6QtVwCIP5fZXKv_thm.jpg" width="288" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3x38TBXPsCgoEn41.jpg" target="_blank" data-width="1311" data-height="632" ><img src="https://tpucdn.com/img/3x38TBXPsCgoEn41_thm.jpg" width="270" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ISXXnoR2Csv478JH.jpg" target="_blank" data-width="1201" data-height="675" ><img src="https://tpucdn.com/img/ISXXnoR2Csv478JH_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/px0aJwELL0g4T7AP.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/px0aJwELL0g4T7AP_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303396/ek-pro-releases-4th-gen-intel-xeon-scalable-cpu-water-blocks">Read full story</a></div>
KeysOff Winter Sale: Get Jaw Dropping Prices on Genuine Software
KeysOff Winter Sale is live! Get some of the hottest discounts on the coolest software to help you maximize your PC building budget. Get Genuine Windows 10 Pro at just $6.22 when you buy a 2-PC pack, or $7.35 on its own. The latest and greatest Windows 11 Pro can be had for $10.45. Save big on annual 365 subscriptions by picking up Office 2021 Professional for just $26.25. Better yet, combine it with your preferred edition of Windows to save even more.<br />
<br />
<a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-32-64-bit-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro at $7.35</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-32-64-bit-2-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro 2-PC at $12.45</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-3-keys.html?kso=sks11" target="_blank">Buy Windows 10 Pro 3-PC at $21.67</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-5-keys.html?kso=sks11" target="_blank">Buy Windows 10 Pro 5-PC at $34.18</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-home-cd-key-32-64-bit-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Home at $7.25</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-cd-key-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro at $10.45</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-home-key.html?kso=sks11" target="_blank">Buy Windows 11 Home at $10.25</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2021-pro-plus-1-pc.html?kso=sks11" target="_blank">Buy Office 2021 Professional at $26.25</a> | <a rel="nofollow" href="https://www.keysoff.com/2-office-2021-pro-plus-keys-pack.html?kso=sks11" target="_blank">Buy Office 2021 Professional 2-PC at $41.25</a> | <a rel="nofollow" href="https://www.keysoff.com/3-office-2021-pro-plus-keys-pack.html?kso=sks11" target="_blank">Buy Office 2021 Professional 3-PC at $58.25</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2021-pro-plus-key-5-pcs.html?kso=sks11" target="_blank">Buy Office 2021 Professional 5-PC at $69.25</a> | <a rel="nofollow" href="https://www.keysoff.com/office-2019-professional-plus-1-pc.html?kso=sks11" target="_blank">Buy Office 2019 Professional at $24.25</a> | <a rel="nofollow" href="https://www.keysoff.com/ms-office-2016-prol-plus.html?kso=sks11" target="_blank">Buy Office 2016 Professional Plus at $18.99</a><br />
<br />
Please use the coupon code <b>SKK62</b> on the following items to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-office-2021-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $34.99</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-office-2019-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $31.99</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-pro-office-2021-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $31.76</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-pro-office-2019-pro-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $28.69</a> | <a rel="nofollow" href="https://www.keysoff.com/office-2021-home-and-business-for-mac.html?kso=sks11" target="_blank">Buy Office 2021 Home and Business for Mac at $68.66</a> | <a rel="nofollow" href="https://www.keysoff.com/office-home-and-business-2019-for-mac-cd-key-global.html?kso=sks11" target="_blank">Buy Office 2019 Home and Business for Mac at $66.22</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/QVPuKAUOhVqpHwpM.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/QVPuKAUOhVqpHwpM_thm.jpg" width="231" height="130" alt="" /></a> </div>Please check out great deals on system utilities.<div class="readmore"><a href="https://www.techpowerup.com/303544/keysoff-winter-sale-get-jaw-dropping-prices-on-genuine-software">Read full story</a></div>
ASUS Announces its Latest Vivobook Classic Series
ASUS today announced six of the latest models in its popular Vivobook Classic series of everyday laptops, led by the updated Vivobook 14 OLED (X1405), Vivobook 15 OLED (X1505) and Vivobook 16 (X1605). These are accompanied by new versions of the affordable Vivobook 14 (X1404), Vivobook 15 (X1504) and Vivobook 17 (X1704).<br />
<br />
Smooth performance is delivered by up to 13th Gen Intel Core H-series processors with 16 GB RAM and up to a 1 TB SSD. Quiet and efficient cooling is provided by the dual-vented cooling system with an IceBlade fan and up to two heat pipes. The long-lasting up to 50 Wh battery gives users more freedom, and there's up to WiFi 6E for ultrafast connectivity. Other helpful design features include the latest ASUS AI noise-canceling audio technology for crystal-clear communications, and there are bundled productivity-enhancing ASUS apps including GlideX, MyASUS and ScreenXpert.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YM2oyCPqWb5SK9ch.jpg" target="_blank" data-width="1280" data-height="860" ><img src="https://tpucdn.com/img/YM2oyCPqWb5SK9ch_thm.jpg" width="193" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3n6iMT7Z9oFRaF2K.jpg" target="_blank" data-width="1280" data-height="847" ><img src="https://tpucdn.com/img/3n6iMT7Z9oFRaF2K_thm.jpg" width="196" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BApFo5U8qTasy7J2.jpg" target="_blank" data-width="1280" data-height="656" ><img src="https://tpucdn.com/img/BApFo5U8qTasy7J2_thm.jpg" width="254" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7l0aJOengahEIA5W.jpg" target="_blank" data-width="1280" data-height="893" ><img src="https://tpucdn.com/img/7l0aJOengahEIA5W_thm.jpg" width="186" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VtAstvBvihif4Hy4.jpg" target="_blank" data-width="1280" data-height="744" ><img src="https://tpucdn.com/img/VtAstvBvihif4Hy4_thm.jpg" width="224" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303540/asus-announces-its-latest-vivobook-classic-series">Read full story</a></div>
XGIMI at the 2023 International CES: RS Pro 2 and MoGo 2 Pro
Home- and portable projectors specialist XGIMI showed off its two bestselling compact short-throw projectors at the 2023 International CES, the RS Pro 2, and the MoGo 2 Pro. The RS Pro 2 is designed for premium home-projection needs, with 2,200 ANSI lumens brightness, a lossless optical zooming mechanism, 4K Ultra HD native resolution, automated keystone adjustments, and smart TV features. The projector is designed for screen-sizes ranging between 30-inch to 300-inch (100-inch recommended by the manufacturer). The projector also integrates a 2.1-channel speaker set designed by Harman-Kardon. On sale now, the RS Pro 2 can be had around the $1,449-mark but it currently just planned for the Asian market. The MoGo 2 Pro is the latest version of XGIMI's award-winning ultraportable projectors. It packs a 350 ANSI Lumens LED light source, and can project Full HD (1920 x 1080) video with autofocus and keystone adjustments, onto a small-medium size screen.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8guUP4ONxGyKC21G.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/8guUP4ONxGyKC21G_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vPmR68Ze5ZOtn0Ta.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/vPmR68Ze5ZOtn0Ta_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/L9Jof8BsyrZ2kzEF.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/L9Jof8BsyrZ2kzEF_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IdztZYR1e5fMd3xn.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/IdztZYR1e5fMd3xn_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2mKA2K7o9tQXyrd5.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/2mKA2K7o9tQXyrd5_thm.jpg" width="98" height="130" alt="" /></a></div>
Cooler Master Shows Off Cooling X, a Unique Prebuilt with Whole-body Liquid Cooling
Cooler Master at the 2023 International CES showed off the Cooling X, a patent-pending unique desktop PC architecture by the company where the liquid cooling of the CPU and GPU isn't confined to a couple of closed loop AIOs, but rather a giant liquid-cooling loop that even involves the side-panels of the case itself, that double up as additional heat-dissipation surfaces. Notice how some compact fanless cases use extruded-aluminium body panels that double up as heatsinks, to cool the hot components? The Cooling X re-imagines this, where instead of dissipating heat from a heatpipe, the extruded-aluminium body panels have coolant channels, so some of the heat from the liquid-cooling loop is dissipated. These panels supplement a conventional liquid-cooling radiator that's located along the rear panel, which has active ventilation. The liquid-cooling loop cools the processor and GPU.<br />
<br />
For its compact dimensions of just 266 mm x 149 mm x 371 mm (LxWxH), the Cooling X prebuilt packs some mighty high-end hardware—an AMD Ryzen 9 5950X 16-core processor, and a Radeon RX 6800 XT GPU up to 64 GB of dual-channel DDR4-3200 memory, two 2 TB M.2 NVMe SSDs, and a homebrew 850 W 80 Plus Gold SFX power supply. For now Cooling X is just a codename, and Cooler Master intends to take this concept forward with high-performance gaming/creator prebuilt desktops sold under its own marquee.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/PlfXZazAzTMMn8q8.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/PlfXZazAzTMMn8q8_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yPRk02ZpyhpKft8S.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/yPRk02ZpyhpKft8S_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NaUPxFck9LcL1PHR.jpg" target="_blank" data-width="785" data-height="586" ><img src="https://tpucdn.com/img/NaUPxFck9LcL1PHR_thm.jpg" width="174" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hQg6gDJaP6NvCfbB.jpg" target="_blank" data-width="765" data-height="677" ><img src="https://tpucdn.com/img/hQg6gDJaP6NvCfbB_thm.jpg" width="147" height="130" alt="" /></a></div>
Cooler Master Keyboards at 2023 CES: MasterKeys MK770 and CK721 in New Colors
Cooler Master introduced several new color schemes of its MasterKeys MK770 and CK721 mechanical gaming keyboards at the 2023 International CES. The MK770 has a unique 99-key layout that retains the Numpad, squeezes the arrow keys between the main QWERTY key-cluster and the Numpad, and relocates the insert/delete/home/end/page-up/page-down cluster. This is essentially a full-size keyboard, but only 38 cm in length (comparable to some TKL keyboards). The MK770 supports three kinds of connectivity—USB (including type-C), wireless over Bluetooth 5.1, or wireless over a low-latency proprietary 2.4 GHz RF.<br />
<br />
The MK770 comes with hot-swappable Kailh Box V2 mechanical switches, a gasket mounted construction, PBT doubleshot keycaps with four distinct colors per color-set; and pre-lubed stabilizers for the keycaps. You get individual-key RGB lighting, a multi-function customizable wheel, and a 4000 mAh battery (the company didn't mention battery life on a full charge). In the USB and 2.4 GHz RF mode, the keyboard offers a 1000 Hz interface polling-rate, which drops down to 125 Hz in Bluetooth mode. A 512 KB onboard memory stores lighting and macro data. The four color sets the MK770 are offered in are: cyan+magenta+gray; mint-green+forest green+off-white; an Attack on Titan theme; and Fruity Pebbles theme. The CK721 Sakura Limited Edition is a 65% format mechanical gaming keyboard that uses TTC mechanical switches, PBT doubleshot keycaps, a 3-way digital dial, RGB lighting for each key, and triple interface just like MK770 (USB, Bluetooth, and 2.4 GHz RF). A 2,000 mAh battery provides up to 73 hours of use without lighting.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Jc8pVnInpY95sxvn.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Jc8pVnInpY95sxvn_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MwSa8r5ZpqzLEcoB.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/MwSa8r5ZpqzLEcoB_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gofPc2OI6jZgUS3E.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/gofPc2OI6jZgUS3E_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tZ8SyQizwJ3C1dmG.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/tZ8SyQizwJ3C1dmG_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZdNL9CGkuIxXv0nu.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/ZdNL9CGkuIxXv0nu_thm.jpg" width="173" height="130" alt="" /></a></div>
Cooler Master New Case Fans at 2023 CES: MasterFan Halo2 and Mobius Se
Cooler Master at the 2023 International CES introduced several new case fans for various use-cases—case ventilation, air-heatsinks, and liquid-cooling radiators. The MasterFan Halo2 is the brightest and most striking of these, and the company is including them with some of their latest Hyper-series CPU coolers. They will be sold in standalone kits, too. The Halo2 gets its name from its two ARGB LED lighting zones—one along the bore of the frame, and the other inside the impeller hub. There are a couple of upgrades of the original MasterFan Halo series from 2020, including enlarged fan blades, a redesigned hybrid frame structure that minimizes frame footprint without sacrificing the fan's axial airflow; and updated motor driver IC. The MF Halo2 comes in 120 mm and 140 mm sizes; and in black- and white color trims. Both sizes feature rifle bearings that are rated for over 160,000 hours of operation.<br />
<br />
The MasterFan MF140 Halo2 features up to 1,600 RPM of speed, up to 58.5 CFM airflow, at up to 2.53 mm H₂O static pressure, and up to 27 dBA noise output. The MF120 Halo2 turns at speeds of up to 2,050 RPM, pushing up to 51.88 CFM of airflow, at up to 2.89 mm H₂O static pressure, and up to 27 dBA noise output. The fans take 4-pin PWM for their main function, and 3-pin Gen 2 ARGB for both their lighting zones.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hQsdTjw23dVlh9Hv.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hQsdTjw23dVlh9Hv_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4aLtREvkSyQQUCyE.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4aLtREvkSyQQUCyE_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8hKRWJrdLSO0bpFx.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/8hKRWJrdLSO0bpFx_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9C7mPSjk9wJUEK0m.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/9C7mPSjk9wJUEK0m_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TSrSXg3bbCz4vg8o.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/TSrSXg3bbCz4vg8o_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303529/cooler-master-new-case-fans-at-2023-ces-masterfan-halo2-and-mobius-series">Read full story</a></div>
Cooler Master MasterLiquid Atmos AIO Liquid CPU Cooler Features User-replaceable Block Covers
At the 2023 International CES, Cooler Master showed off a unique all-in-one liquid closed-loop CPU cooler that features user-replaceable pump-block covers, the MasterLiquid Atmos. The top cover of the pump-block comes off, so you can replace it with something with a different shape or color. Examples of these covers include a frosty-white cover made of recycled plastic resin, or a tinted acrylic diffuser. Underneath is a white silicone diffuser for an ARGB lighting element. The lighting extends to the included Cooler Master Sickleflow ARGB fans.<br />
<br />
The MasterLiquid Atmos model shown at CES was the ML360 Atmos, featuring a 360 mm x 120 mm radiator with a trio of Sickleflow ARGB fans. These fans come pre-installed on the radiator, to minimize packaging waste. The ML360 Atmos uses a dual-chamber pump-block, which features CM's Gen 2 ARGB lighting. The company didn't go into the technical details of the fan, but mentioned its top speed to be 2,400 RPM. The MasterLiquid Atmos series comes in two variants, 240 mm and 360 mm. Among the CPU socket types supported are LGA1700, LGA1200, AM5, and AM4.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NdbgyuTB4dEymn7Q.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/NdbgyuTB4dEymn7Q_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nQhsKDgCFkNVdSAF.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/nQhsKDgCFkNVdSAF_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hDRnwgdfln0dFmjT.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hDRnwgdfln0dFmjT_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) MINISFORUM HX99G 6900HX + RX 6600M Mini PC Goes on Sale
Minisforum introduced a new variant called HX99G in its Neptune portfolio today. It is an upgraded version of the first member, the HX90G (5900HX processor + RX6600M GPU), which was announced in May 2022 before going up for sale in September 2022. The Neptune HX99G looks practically identical to the HX90G. Measuring 205 x 203 x 69 mm (8.1" x 8" x 2.7"), both models feature 45 watts, 8-cores/16-threads graphics and the same laptop-class discrete GPU. However, it updates the Ryzen 9 5900HX with a faster Ryzen 9 6900HX and replaces the two DP ports with two speedier USB4 ports. <br />
<br />
R9 6900HX integrates all eight cores based on the Zen 3+ microarchitecture. It's clocked at 3.3 (guaranteed base clock) to 4.9 GHz (max boost). Ryzen 6000 brings a slew of technological advancements, like support for USB 4, PCI-E Gen 4, DDR5-4800MT/s, WIFI 6 and Bluetooth 5.2. The other AMD performance component is the RDNA 2 graphics architecture Radeon RX 6600M (GDDR6 8 GB) with a TDP of up to 100 watts. Users can expect to utilize the full performance of this dedicated GPU to handle professional-class photo and video editing as well as content creation. Also, this GPU packs enough firepower to hit 60 frames per second at 1080p (depending on the specific game and settings).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JH5K3stGb62xtXs7.jpg" target="_blank" data-width="1515" data-height="1000" ><img src="https://tpucdn.com/img/JH5K3stGb62xtXs7_thm.jpg" width="197" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/h7lYIQWXavdEBoQe.jpg" target="_blank" data-width="1218" data-height="1000" ><img src="https://tpucdn.com/img/h7lYIQWXavdEBoQe_thm.jpg" width="158" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9idd1aqdItau1jWo.jpg" target="_blank" data-width="1276" data-height="1000" ><img src="https://tpucdn.com/img/9idd1aqdItau1jWo_thm.jpg" width="166" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vYCIGwYTG1JCs5RQ.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/vYCIGwYTG1JCs5RQ_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303517/minisforum-hx99g-6900hx-rx-6600m-mini-pc-goes-on-sale">Read full story</a></div>
(PR) NZXT Announces H9 Series ATX Cases, C1200 PSU, and Duo RGB Fan
NZXT, a leader in PC gaming hardware and services, today announces mid-tower ATX cases, the H9 Flow and H9 Elite, the C1200 power supply, and the RGB Duo fans. The H9 Series features two new ATX compatible cases that will be the latest and largest options featured in NZXT's mid-tower lineup; they feature enough room for up to ten fans and direct airflow to cool off the most powerful video cards. The H9 Flow and H9 Elite are flexible to suit any type of build due to their large size, radiator support, and color schemes. For people who want to focus on thermal performance, the H9 Flow is designed to give you optimized cooling thanks to a mesh top panel. The H9 Elite is designed for people who want to build an RGB focused PC with some additional benefits, such as NZXT CAM support and a glass top panel to show off RGB lighting components.<br />
<br />
A perforated mesh top panel gives the H9 a greater focus on cooling performance. In addition, the case comes equipped with four 120 mm F Series Quiet Airflow fans to supplement airflow further. With superior airflow, the H9 Flow is the perfect case for people who want to build a system with the latest components with greater cooling requirements. The H9 Elite is an elegant way to accommodate builders who want a large tempered glass enclosure to show off their RGB builds, whether they want to share their setup on social media or their stream. With tempered glass on three sides for an uninterrupted look, a top radiator/fan, and with three included RGB Duo fans with an NZXT RGB and Fan controller V2, it is a perfect case to show off premium components.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vymNHTlzrKo0TtTs.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/vymNHTlzrKo0TtTs_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303516/nzxt-announces-h9-series-atx-cases-c1200-psu-and-duo-rgb-fan">Read full story</a></div>
Cooler Master Power Supplies at 2023 International CES: GX III, V Gold, V SFX Gold, and V SFX Platinum
Cooler Master brought a wealth of new power supplies at the 2023 International CES, to match the anticipated growth in PSU upgrades with the advent of the ATX 3.0 and PCIe Gen 5 standards. The GX III series will be the main workhorse for Cooler Master in its gaming-grade modular PSU lineup. Boasting 80 Plus Gold efficiency, the GX III comes in capacities ranging between 550 W and 1250 W, and cram in a half-bridge APFC, DC-to-DC switching, LLC, and a fan which offers zero-RPM mode up to a certain load. The 650 W, 750 W, 850 W, 1050 W, and 1250 W models include a 600 W-rated 12VHPWR connector, while the 550 W model includes a 450 W-rated 12VHPWR. Two EPS (CPU power) connectors are standard across all models. Depending on the model, you get two to six 6+2 pin PCIe power connectors. Cooler Master is backing the GX III series PSUs (along with most other PSU models it's launching at CES), with a 10-year warranty.<br />
<br />
The V Gold i series features an interesting brushed-gold design element on the body. These 80 Plus Gold-rated modular PSUs come in 750 W and 850 W models. What sets these apart from the GX III series is their semi-digital control, with the PSUs interfacing with the MasterPlus software over USB, for real-time monitoring and basic control. Both models include one 16-pin 12VHPWR connector capable of 600 W continuous power, two 8-pin EPS, three 6+2 pin PCIe power, twelve SATA power, and a couple of legacy power connectors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hTh0eZzF7WaECNHe.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hTh0eZzF7WaECNHe_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/k2Cug2bhXB5EOkH1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/k2Cug2bhXB5EOkH1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a1NRQ0h9pfb25USV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/a1NRQ0h9pfb25USV_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/53bXQzaK3RiQJOUD.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/53bXQzaK3RiQJOUD_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xtyWT8YuBdUy2Nuy.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/xtyWT8YuBdUy2Nuy_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303512/cooler-master-power-supplies-at-2023-international-ces-gx-iii-v-gold-v-sfx-gold-and-v-sfx-platinum">Read full story</a></div>
Cooler Master Hyper 212 Halo Series Brings the Iconic 212 up to 2023 Standards
The Cooler Master Hyper 212 series over the years has become synonymous with aftermarket CPU cooling, as possibly the most popular custom CPU cooler. The company modernized it over the years with new heatsink and fan technologies, and it's has undergone a major design- and tech overhaul with the new Hyper 212 Halo. It retains the conventional aluminium fin-stack (type-U) design, with four 6 mm-thick copper heatpipes making direct contact with the CPU at the base, conveying heat to an aluminium fin-stack heatsink that's been capped off with a die-cast aluminium top-plate. The included 120 mm Halo fan features rifle-bearings rated for over 160,000 hours, and features two sets of addressable-RGB LEDs—along the bore of the fan-frame, and the impeller hub. The fan turns at speeds ranging between 650 to 2,050 RPM, pushing up to 51.88 CFM of airflow at 2.89 mm H₂O static-pressure, and 27 dBA maximum noise output. As part of its design modernization, the Hyper 212 Halo gets support for the latest Sockets LGA1700 and AM5.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/HuiqjsU1nkEJodEw.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/HuiqjsU1nkEJodEw_thm.jpg" width="173" height="130" alt="" /></a></div>
NexiGo Aurora PJ90 is a Unique Ultra Short-Throw Projector for Space-C
NexiGo Aurora PJ90 is one of the few jaw-dropping UST (ultra short-throw) projectors we've come across at the 2023 International CES. This device can project onto a screen as large as 150-inch, from a very short throw distance (think a TV console right underneath the screen), with a very sophisticated automated keystone adjustment mechanism. What you get is a pristine 4K Ultra HD with HDR10 projection at up to 120 Hz refresh-rate, up to 2,500 ANSI lumens brightness, and in-built 60 W (RMS) Dolby Audio 2.1 speakers; along with a fully-fledged Android TV package, and HDMI 2.0 input. If you're in a space-constrained environment like a studio apartment, this is the one to get; however, get ready to fork out USD $2,100.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BL8QW65nc4XKP54w.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/BL8QW65nc4XKP54w_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2nvA7RTInT2Ob6Af.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/2nvA7RTInT2Ob6Af_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uM6VwTSLcNdi44pI.jpg" target="_blank" data-width="774" data-height="539" ><img src="https://tpucdn.com/img/uM6VwTSLcNdi44pI_thm.jpg" width="187" height="130" alt="" /></a></div>
Audio-Technica Makes a Big Push into the Game Streaming and Competitive Gaming Audio Segments
Known more for its audiophile-grade headphones, Audio-Technica this CES announced a big push into two distinct markets—the creator market led by game streamers; and the competitive gaming market. For creators and game streamers, the company announced variants of its popular headphones such as the ATH-M50x, with attached 10 mm condenser microphones, turning them into streaming-grade headsets, such as the ATH-M50xSTS (analog) and the ATH-M50xSTS-USB (USB). The company also revealed standalone microphones for streaming sets, in the form of the ATR-2100x-USB, the AT2020USB-X. For the podcasting and radio-show communities, the company launched the AT2040 and AT02020, a set of boom armature-suspended high-grade mics.<br />
<br />
Gamers are in for a treat, as Audio-Technica is now firmly into the gaming headset territory, with the ATH-G1 (wired analog) and ATH-G1WL (wireless). Both feature 45 mm high-end drivers from the ATH-M40x, a sound-stage that's tuned for a variety of gaming use-cases, weight reductions wherever possible, to improve extended use, and an in-line volume stock. The wireless version comes with buttons on the earcup, uses a proprietary 2.4 GHz RF wireless tech, and its battery offers 15 hours of use on a full charge. The ATH-G1 is priced at $169, and the ATH-G1WL at $249. The ATH-GDL3 is a wired analog headset for console gaming, with similar 45 mm drivers and a gaming soundstage, but is considerably lighter, and priced at $129.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Xv9gDxMK2ttg2a2T.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/Xv9gDxMK2ttg2a2T_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aVmzmHNUqI79zXAH.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/aVmzmHNUqI79zXAH_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/73qop0kwTjtBEean.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/73qop0kwTjtBEean_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NlxL17cmsuUdKEtT.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/NlxL17cmsuUdKEtT_thm.jpg" width="173" height="130" alt="" /></a></div>
Audio-Technica Unveils ATH-WB2022 Flagship Wireless Headphones with Wooden Chambers
Premium personal audio solutions maker Audio-Technica at the 2022 International CES showed off its flagship wireless headphones, the ATH-WB2022. This $2,700 pair of ultra-luxury headphones features wired + wireless dual-use mode, a 9-hour wireless playback ability on a full-charge, and the company's most premium 45 mm drivers. A high-end integrated DAC + OPAMP circuit power the headphones in wireless mode. The ATH-WB2022 is technically a headset, and packs a 10 mm condenser microphone. It's most striking aspect has to be its true-wood chamber design that helps produce more natural sounding notes. Positioned as a 60th Anniversary limited-edition product, the ATH-WB2022 could make it to lifestyle catalogs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FaVxncrPhEcEqkE2.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/FaVxncrPhEcEqkE2_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) EK Announces Direct Die Cooling for Intel 12th and 13th Gen Core Processors
EK, the premium liquid cooling hardware manufacturer, is launching the Direct Die product series aimed at delidding and achieving the ultimate cooling of the LGA 1700 socket-based Intel CPUs from the 12th generation Alder Lake and 13th gen Raptor Lake families. Kitguru teamed up with EK to investigate the potential benefits of direct die cooling for Intel's Alder Lake CPUs to achieve the best possible thermal performance on a daily basis. After publishing the first video announcing this collaboration, EK was overwhelmed by the response from Kitguru's audience. In order to bring these products to market, EK reached out to Der8auer, a renowned expert in delidding and direct die applications.<br />
<br />
EK has prepared a total of four products to start this Direct Die series: two CPU water blocks (one Limited Edition), a delidding tool, and an upgrade kit for existing EK-Quantum Vector² LGA1700 water blocks. So far, these products are aimed at Intel's LGA1700 socket and 12th and 13th-generation Intel Core CPUs. Delidding is the process of removing the integrated heatspreader (IHS) to reduce the distance between the CPU core die and the coldplate of the CPU cooler. Another benefit involves the removal of an entire layer of thermal transfer from the CPU die to the IHS. The delidding process enables a direct heat transfer from the CPU core to the water block. All this results in a significant reduction in overall thermals and less thermal difference between CPU cores. The procedure is typically performed by experienced enthusiasts because it involves a physical modification of the product that voids the CPU warranty. For a more in-depth explanation, please refer to this EK's blog post on delidding.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OSBL2iEmXqDNYsud.jpg" target="_blank" data-width="1200" data-height="676" ><img src="https://tpucdn.com/img/OSBL2iEmXqDNYsud_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5wIuKMrVTdsnKYwq.jpg" target="_blank" data-width="651" data-height="675" ><img src="https://tpucdn.com/img/5wIuKMrVTdsnKYwq_thm.jpg" width="125" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2IN2zHhAMdzW21g5.jpg" target="_blank" data-width="776" data-height="675" ><img src="https://tpucdn.com/img/2IN2zHhAMdzW21g5_thm.jpg" width="149" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/poGkSbk9lfagKmt9.jpg" target="_blank" data-width="871" data-height="675" ><img src="https://tpucdn.com/img/poGkSbk9lfagKmt9_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/x25972u5zfxKJZJU.jpg" target="_blank" data-width="1023" data-height="675" ><img src="https://tpucdn.com/img/x25972u5zfxKJZJU_thm.jpg" width="197" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303489/ek-announces-direct-die-cooling-for-intel-12th-and-13th-gen-core-processors">Read full story</a></div>
(PR) MSI Launches the Clutch GM31 Lightweight Wireless Gaming Mouse
MSI, a leading global computer brand for gamers, has announced 2 new additions in the lightweight gaming mouse series—Clutch GM31 Lightweight Wireless and Clutch GM31 Lightweight (wired version). As the successor of the award-winning Clutch GM41 Lightweight Wireless, the Clutch GM31 Lightweight Wireless is a better fit for gamers with small to medium-sized hands. The Clutch GM31 Lightweight Wireless is packed with a ton of features including state-of-the-art low latency wireless technology, up to 110 hours of battery life, a charging dock, and other various features that provide performance boosts to your gameplay.<br />
<br />
<b>Lightweight, Small, yet Ergonomic</b><br />
Utilizing the same lightweight plastic material as its predecessor, the Clutch GM31 Lightweight Wireless weighs in at an ultra-light 73 g. This results in rapid yet effortless movement, delivering outstanding gameplay with each move. The small ergonomic chassis makes the mouse a better choice for gamers with small to medium-sized hands and provides excellent comfort in most grip styles. It also features gaming grade 100% pure PTFE mouse skates which have a single-directional surface texture and double-cut edges that make each move faster and more precise.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qxCgDpHKk1RNxnuC.jpg" target="_blank" data-width="960" data-height="365" ><img src="https://tpucdn.com/img/qxCgDpHKk1RNxnuC_thm.jpg" width="342" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1ZPeBTETQmojTsOn.jpg" target="_blank" data-width="1029" data-height="960" ><img src="https://tpucdn.com/img/1ZPeBTETQmojTsOn_thm.jpg" width="139" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303487/msi-launches-the-clutch-gm31-lightweight-wireless-gaming-mouse">Read full story</a></div>
(PR) Synology Unveils DiskStation DS723+, a Capable Storage Device with a Small Footprint
Synology today announced the new 2-bay Synology DiskStation DS723+, the smallest expandable option in its lineup of all-in-one solutions for home offices and small businesses. Powered by the versatile Synology DiskStation Manager (DSM) operating system, the DS723+ offers comprehensive solutions to protect and manage business data, easily collaborate on documents, access files remotely, and monitor physical assets, all within a compact desktop format. <br />
<br />
"This new unit delivers impressive performance and capability for its size," said Michael Wang, Product Manager at Synology. "With its extremely compact form factor, it will certainly appeal to those that have smaller storage requirements but don't want to give up on the convenience of centralized storage and the possibility to scale in the future."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YB9p72JCjImudA9p.jpg" target="_blank" data-width="816" data-height="740" ><img src="https://tpucdn.com/img/YB9p72JCjImudA9p_thm.jpg" width="143" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KKsa24oXlmzioSNA.jpg" target="_blank" data-width="486" data-height="764" ><img src="https://tpucdn.com/img/KKsa24oXlmzioSNA_thm.jpg" width="83" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UwqextAIGaiYcIHJ.jpg" target="_blank" data-width="928" data-height="703" ><img src="https://tpucdn.com/img/UwqextAIGaiYcIHJ_thm.jpg" width="172" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yhIfqQ5Wua2eIGk0.jpg" target="_blank" data-width="908" data-height="718" ><img src="https://tpucdn.com/img/yhIfqQ5Wua2eIGk0_thm.jpg" width="164" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303481/synology-unveils-diskstation-ds723-a-capable-storage-device-with-a-small-footprint">Read full story</a></div>
(PR) QNAP Introduces TVS-h874 NAS with 12th Gen Intel Core i9 Sixteen-
QNAP Systems, Inc., a leading computing, networking, and storage solution innovator, today launched new high-performance TVS-h874 QuTS hero NAS models that incorporate 12th Gen Intel Core i9 sixteen-core, i7 twelve-core multi-thread processors with Intel Core Hybrid Technology for optimal computing performance and smooth multiple virtual machine (VM) operation. Integrating the reliable ZFS-based operating system, PCIe Gen 4 expandability, M.2 NVMe SSD caching, and 2.5GbE/10GbE connectivity, the TVS-h874 assists businesses in building high-performance storage environments for hosting multiple VM, application servers, and running business data backup/restore applications.<br />
<br />
"The new TVS-h874 models adopt Intel Core Hybrid Technology, combining Performance-cores and Efficient-cores," said Andy Chuang, Product Manager of QNAP, adding "The Performance Hybrid Architecture intelligently allocates CPU cores to different tasks, thus increasing the performance of the new TVS-h874 models by 3.55 times compared with previous models."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ZK3aulSgXolqcMcl.jpg" target="_blank" data-width="800" data-height="420" ><img src="https://tpucdn.com/img/ZK3aulSgXolqcMcl_thm.jpg" width="248" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Zg4gfr4i7GbYC7t9.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/Zg4gfr4i7GbYC7t9_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MHcD7ybIg0gYfhFn.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/MHcD7ybIg0gYfhFn_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/RzCjNHTauiOium2I.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/RzCjNHTauiOium2I_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303480/qnap-introduces-tvs-h874-nas-with-12th-gen-intel-core-i9-sixteen-core-i7-twelve-core-processor-and-intel-core-hybrid-technology">Read full story</a></div>
Intel Launches Core i9-13900KS 8P+16E Flagship Processor at $700
Intel today formally launched the Core i9-13900KS "Raptor Lake" flagship desktop processor. At an MSRP of USD $700, the i9-13900KS is positioned a notch above the $590 i9-13900K, which it replaces as the top 13th Gen Core desktop part you can buy. The i9-13900KS features the same 8P+16E core-configuration as the i9-13900K, but at increased clock speeds and power limits. It is the world's first 6 GHz processor, with its maximum boost frequency set at exactly 6.00 GHz, up from 5.80 GHz of the i9-13900K. This is not just a minor +200 MHz speed bump, but backed by increased power-limits, which enable improved multi-threaded boost-frequency spread thanks to the Adaptive Boost Technology carried over from the previous-generation i9-12900KS.<br />
<br />
The 8 "Raptor Cove" P-cores of the i9-13900KS are clocked at 3.00 GHz base with up to 6.00 GHz boost, compared to 3.00/5.80 GHz of the i9-13900K, while the E-core frequencies are left untouched at 2.20 GHz base and up to 4.30 GHz boost. The big change here is the processor base power value, which is now set at 150 W, compared to 125 W of the i9-13900K, and while the maximum turbo power value is the same 253 W, Intel has changed the way its power headroom is utilized to support improved boost frequency spread across the P-cores. It seems like Intel hasn't sampled tech publications this processor, and the handful publications that have posted their reviews today using processors sourced from friendly retailers, report increased power-draw, and the need for large aftermarket cooling solutions even at stock frequencies. The i9-13900KS is being offered as an overclocking-friendly chip to those who know what they're doing and can handle extreme cooling solutions.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lHP52KkC4Cyy45yr.jpg" target="_blank" data-width="1086" data-height="583" ><img src="https://tpucdn.com/img/lHP52KkC4Cyy45yr_thm.jpg" width="242" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Uv3hu5VkdhlKWlcE.jpg" target="_blank" data-width="735" data-height="607" ><img src="https://tpucdn.com/img/Uv3hu5VkdhlKWlcE_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gAGEips2xZq7WYdf.jpg" target="_blank" data-width="833" data-height="565" ><img src="https://tpucdn.com/img/gAGEips2xZq7WYdf_thm.jpg" width="192" height="130" alt="" /></a></div>
Corsair RMx Shift Series PSU Reimagines the Modular PSU
It's scary how nobody else thought of this. Imagine a modular PSU whose connectors are not at its tail end, but one of the sides that usually face right side-panel of your case, vastly minimizing cable clutter. That's the new Corsair RMx Shift series. All of the PSU's modular connections, including a 24-pin ATX, a couple of 4+4 pin EPS, a 16-pin 12VHPWR, six-odd 6+2 pin PCIe power, and a dozen SATA power connections, all wire out from the longer right side panel of the PSU (when oriented with its intake fan facing down). In most "cases," this would open up the connectors right below the motherboard tray, from where you can easily access them, without having to wrestle with them as you would on conventional modular PSUs. The RMx Shift includes new Corsair type-5 modular cables, and we expect these to be right angled, so further minimize cable clutter from having to bend these cables against the side-panel of your case. Pictured below are the RM1200x Shift, a 1200 W model with 80 Plus Gold efficiency, and the shorter RM850x Shift, its 850-Watt sibling.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CBCYzSwo0Y2X2oJJ.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/CBCYzSwo0Y2X2oJJ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6iPJvZ03gOiW3zak.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/6iPJvZ03gOiW3zak_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dUAducI39dheZt8X.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/dUAducI39dheZt8X_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/joTWjl2m9rFPdOXO.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/joTWjl2m9rFPdOXO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WaLAEvPWekwnDc9o.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/WaLAEvPWekwnDc9o_thm.jpg" width="173" height="130" alt="" /></a></div>
This Week in Gaming (Week 3)
Three weeks into the new year and another week without any big game releases, although SEGA/Atlus is about to release updated versions of Personal 3 and 4, which ends up being the most well known game releases this coming week. That said, there are a couple of other potentially interesting games coming out, so check out the full list for more details on those.<br />
<br />
<b><a rel="nofollow" href="https://www.madnetic-games.com/ww2-rebuilder.html" target="_blank">WW2 Rebuilder</a> / Monday January 16</b><br />
It's 1945. It's the end of World War II, the war that left a mark. Now people like you have to leave their hometowns to rebuild their countries. Motivated by different reasons, they get set on the same quest - to repair and renovate places completely destroyed during the war.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ihd7FrLVseXqRaJT.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/ihd7FrLVseXqRaJT_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AwRH7FgnvbExEuhQ.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/AwRH7FgnvbExEuhQ_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gmR5F6PkQXdzT1h7.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/gmR5F6PkQXdzT1h7_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TK61EkJ6I6PQgTfP.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/TK61EkJ6I6PQgTfP_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303591/this-week-in-gaming-week-3">Read full story</a></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
(PR) Apple introduces new Mac mini with M2 and M2 Pro—more powerful, c
Apple today unveiled the new Mac mini, supercharged by M2 and the all-new M2 Pro. With the M2 chip, Mac mini is even more powerful, capable, and affordable with a new starting price of just $599. The new M2 Pro chip delivers pro-level performance to Mac mini for the first time, enabling users to run high-performance workflows that were previously unimaginable in such a compact design. Mac mini with M2 and M2 Pro delivers faster performance, even more unified memory, and advanced connectivity, including support for up to two displays on the M2 model, and up to three displays on the M2 Pro model. Paired with Studio Display and Magic accessories, along with the power and ease of macOS Ventura, Mac mini provides a phenomenal desktop experience that will take users' productivity and creativity to the next level. Customers can order the new Mac mini models today, with availability beginning Tuesday, January 24.<br />
<br />
"With incredible capabilities and a wide array of connectivity in its compact design, Mac mini is used in so many places, in so many different ways. Today, we're excited to take it even further with M2 and M2 Pro," said Greg Joswiak, Apple's senior vice president of Worldwide Marketing. "Bringing even more performance and a lower starting price, Mac mini with M2 is a tremendous value. And for users who need powerful pro performance, Mac mini with M2 Pro is unlike any other desktop in its class."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/RWAc9CfRNvCgnSrn.jpg" target="_blank" data-width="980" data-height="551" ><img src="https://tpucdn.com/img/RWAc9CfRNvCgnSrn_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bYTPKtJFdf7Vpxq0.jpg" target="_blank" data-width="980" data-height="551" ><img src="https://tpucdn.com/img/bYTPKtJFdf7Vpxq0_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/so0YEVbPvJfByDQL.jpg" target="_blank" data-width="980" data-height="661" ><img src="https://tpucdn.com/img/so0YEVbPvJfByDQL_thm.jpg" width="193" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8ulP7pjLEncMFSfG.jpg" target="_blank" data-width="980" data-height="661" ><img src="https://tpucdn.com/img/8ulP7pjLEncMFSfG_thm.jpg" width="193" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303744/apple-introduces-new-mac-mini-with-m2-and-m2-pro-more-powerful-capable-and-versatile-than-ever">Read full story</a></div>
(PR) Next-Generation Dell PowerEdge Servers Deliver Advanced Performance and Energy Efficient Design
Dell Technologies expands the industry's top selling server portfolio, with an additional 13 next-generation Dell PowerEdge servers, designed to accelerate performance and reliability for powerful computing across core data centers, large-scale public clouds and edge locations. Next-generation rack, tower and multi-node PowerEdge servers, with 4th Gen Intel Xeon Scalable processors, include Dell software and engineering advancements, such as a new Smart Flow design, to improve energy and cost efficiency. Expanded Dell APEX capabilities will help organizations take an as-a-Service approach, allowing for more effective IT operations that make the most of compute resources while minimizing risk.<br />
<br />
"Customers come to Dell for easily managed yet sophisticated and efficient servers with advanced capabilities to power their business-critical workloads," said Jeff Boudreau, president and general manager, Infrastructure Solutions Group, Dell Technologies. "Our next-generation Dell PowerEdge servers offer unmatched innovation that raises the bar in power efficiency, performance and reliability while simplifying how customers can implement a Zero Trust approach for greater security throughout their IT environments."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FAJSIXWzhI1rb2ls.jpg" target="_blank" data-width="1030" data-height="608" ><img src="https://tpucdn.com/img/FAJSIXWzhI1rb2ls_thm.jpg" width="220" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303743/next-generation-dell-poweredge-servers-deliver-advanced-performance-and-energy-efficient-design">Read full story</a></div>
(PR) ViewSonic Revolutionizes Video Conferencing with Its New Webcam Docking Monitors
ViewSonic Corp, a leading global provider of visual solutions, announces the launch of the VG56V Series, a collection of premium webcam-docking monitors that elevates the video conferencing experience. Crafted to be versatile and functional for the home and office, the VG2456V and VG2756V-2K displays deliver next-level video conferencing capabilities with a pop-up webcam that features built-in LED fill lights and a two-way AI noise reduction function for both input and output audios.<br />
<br />
"As more of us move towards a hybrid mode of working and collaborating across different regions, online video conferences will increasingly become more universal for working professionals. That's why we focused on designing our latest VG56V series with cutting-edge video conferencing features," said Oscar Lin, General Manager of the Monitor Business Unit at ViewSonic. "With an intuitive design and simple set-up, these user-centric monitors are the perfect tool to escalate the video conferencing experience."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2dazWQ8nvm5GqJ2A.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/2dazWQ8nvm5GqJ2A_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303742/viewsonic-revolutionizes-video-conferencing-with-its-new-webcam-docking-monitors">Read full story</a></div>
(PR) ASUS Announces Vivobook S 16 Flip OLED
ASUS today announced Vivobook S 16 Flip OLED (TP3604), a convertible 16-inch laptop that's just 19.6 mm slim and 1.9 kg light. It's designed to give users the 360° of freedom they need to explore all the possibilities. Available in stylish Midnight Black or Cool Silver, this exciting laptop is built to be tough, undergoing the world's strictest US military-grade durability testing regime, and features the formidable power of the latest 13th Gen Intel Core H-series processors and a long-lasting 70 Wh battery.<br />
<br />
Users can treat their eyes to the gorgeous visuals on the 3.2K 120 Hz OLED NanoEdge touchscreen with its Corning Gorilla Glass NBT scratch-resistant covering, and capture all their greatest ideas using the optional ASUS Pen 2.0, an MPP 2.0 stylus with 4096 pressure levels. Built with hygiene in mind, ASUS Vivobook S 16 Flip OLED uses ASUS Antimicrobial Guard Plus to inhibit the growth of viruses and bacteria by up to 99% on frequently-touched surfaces. Its environmental credentials are solid, too: it uses 30% post-consumer recycled (PCR) plastics in its construction, and is shipped in 100% recyclable packaging.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/nghIzlwJk6iLVpHo.jpg" target="_blank" data-width="1280" data-height="856" ><img src="https://tpucdn.com/img/nghIzlwJk6iLVpHo_thm.jpg" width="194" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AUj3v3Sr3pKjPF32.jpg" target="_blank" data-width="1280" data-height="909" ><img src="https://tpucdn.com/img/AUj3v3Sr3pKjPF32_thm.jpg" width="183" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SmPoMs2IkKD1J7If.jpg" target="_blank" data-width="1280" data-height="844" ><img src="https://tpucdn.com/img/SmPoMs2IkKD1J7If_thm.jpg" width="197" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CN1UTPovMLUEM4s6.jpg" target="_blank" data-width="1280" data-height="1143" ><img src="https://tpucdn.com/img/CN1UTPovMLUEM4s6_thm.jpg" width="146" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303740/asus-announces-vivobook-s-16-flip-oled">Read full story</a></div>
(PR) Apple Unveils MacBook Pro Laptops with M2 Pro and M2 Max Processors
Apple today announced the new 14- and 16-inch MacBook Pro featuring <a href="https://www.techpowerup.com/303734/apple-unveils-m2-pro-and-m2-max-next-generation-chips-for-next-level-workflows" target="_blank">M2 Pro and M2 Max</a>, Apple's next-generation pro silicon that brings even more power-efficient performance and battery life to pro users. With M2 Pro and M2 Max—the world's most powerful and efficient chip for a pro laptop—MacBook Pro tackles demanding tasks, like effects rendering, which is up to 6x faster than the fastest Intel-based MacBook Pro, and color grading, which is up to 2x faster. Building on the unprecedented power efficiency of Apple silicon, battery life on MacBook Pro is now up to 22 hours—the longest battery life ever in a Mac. For enhanced connectivity, the new MacBook Pro supports Wi-Fi 6E, which is up to twice as fast as the previous generation, as well as advanced HDMI, which supports 8K displays for the first time. With up to 96 GB of unified memory in the M2 Max model, creators can work on scenes so large that PC laptops can't even run them. Rounding out the unrivaled features of MacBook Pro are its renowned Liquid Retina XDR display, extensive array of connectivity, 1080p FaceTime HD camera, six-speaker sound system, and studio-quality mics. When combined with macOS Ventura, the MacBook Pro user experience is unrivaled. Customers can order the new 14- and 16-inch MacBook Pro today, with availability beginning Tuesday, January 24.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/VULTB4DY3GrIBV2x.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/VULTB4DY3GrIBV2x_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mufXvnZ1j9EeLRAq.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/mufXvnZ1j9EeLRAq_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303736/apple-unveils-macbook-pro-laptops-with-m2-pro-and-m2-max-processors">Read full story</a></div>
(PR) Apple Unveils M2 Pro and M2 Max: Next-generation chips for Next-level Workflows
Apple today announced M2 Pro and M2 Max, two next-generation SoCs (systems on a chip) that take the breakthrough power-efficient performance of Apple silicon to new heights. M2 Pro scales up the architecture of M2 to deliver an up to 12-core CPU and up to 19-core GPU, together with up to 32 GB of fast unified memory. M2 Max builds on the capabilities of M2 Pro, including an up to 38-core GPU, double the unified memory bandwidth, and up to 96 GB of unified memory. Its industry-leading performance per watt makes it the world's most powerful and power-efficient chip for a pro laptop. Both chips also feature enhanced custom technologies, including a faster 16-core Neural Engine and Apple's powerful media engine. M2 Pro brings pro performance to Mac mini for the first time, while M2 Pro and M2 Max take the game-changing performance and capabilities of the 14-inch and 16-inch MacBook Pro even further.<br />
<br />
"Only Apple is building SoCs like M2 Pro and M2 Max. They deliver incredible pro performance along with industry-leading power efficiency," said Johny Srouji, Apple's senior vice president of Hardware Technologies. "With an even more powerful CPU and GPU, support for a larger unified memory system, and an advanced media engine, M2 Pro and M2 Max represent astonishing advancements in Apple silicon."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/SwTk4wNeZo61gTfd.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/SwTk4wNeZo61gTfd_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vXmvg4eglVfFyHpK.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/vXmvg4eglVfFyHpK_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xvArSTRnyvuFNkUh.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/xvArSTRnyvuFNkUh_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303734/apple-unveils-m2-pro-and-m2-max-next-generation-chips-for-next-level-workflows">Read full story</a></div>
(PR) CORSAIR Launches TC100 RELAXED Gaming Chair
CORSAIR, a world leader in enthusiast components for gamers, creators, and PC builders, today announced the newest addition to its growing lineup of gaming chairs. Debuting the new RELAXED Series, the CORSAIR TC100 RELAXED offers wider seating and ergonomic contact points for the support you need to sit in comfort for hours, available in either soft fabric or plush leatherette exterior with a stylish racing-inspired design.<br />
<br />
The TC100 RELAXED's wide bolstering provides a roomy seat with a comfortable width of 375 mm and full-body support whether you lean forward in the heat of battle or recline after the victory. Regardless of your choice between fabric and leatherette exteriors, a detachable high-density foam lumbar pillow and memory foam neck pillow are included to help you maintain a healthy posture while gaming.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8405AzdPmMev0JF6.jpg" target="_blank" data-width="1059" data-height="858" ><img src="https://tpucdn.com/img/8405AzdPmMev0JF6_thm.jpg" width="160" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303731/corsair-launches-tc100-relaxed-gaming-chair">Read full story</a></div>
(PR) BIOSTAR Outs the B760M-SILVER Motherboard
BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today, is delighted to announce the brand new B760M-SILVER motherboard. Constructed around the INTEL LGA1700 socket, which supports 12th / 13th Generation Intel Core processors, the B760M-SILVER carries BIOSTAR's RACING pedigree, with visual flair and innovative features strategically picked to enhance the user's overall experience.<br />
<br />
The B760M-SILVER features the MicroATX form factor, which makes it ideal for space and cost-conscious applications, coupled with the BIOSTAR-certified 10+1+1 Phase / 70 A power delivery solution great for gaming and entertainment builds. It comes further equipped with BIOSTAR's DIGITAL PWM technology, which provides exceptionally precise power delivery across all its components.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DrJBfo5mIj49FmcM.jpg" target="_blank" data-width="1024" data-height="656" ><img src="https://tpucdn.com/img/DrJBfo5mIj49FmcM_thm.jpg" width="203" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303729/biostar-outs-the-b760m-silver-motherboard">Read full story</a></div>
(PR) GELID Intros the Nexus Premium Headset Stand
Tech innovator GELID Solutions uncovers the new NEXUS Premium Headset Holder as a product of GELID Solutions product line. The new Premium Headset Holder includes a flexible design. The hook holder is attached to a rotatable arm that can easily move 360° in, out, left and right according to your needs. The two clip cable organizers are integrated to hold cables in place, preventing them from dragging to the ground and keep your desk organized. The stand comes with five expansion ports. Three USB ports for high-speed data transfer and charging, one TF and one SD expansion port to facilitate your audio enjoyment.<br />
<br />
NEXUS can be attached to desks up to 42 mm thickness and as narrow as 10 mm for a near universal fit on most desks. The spring clamp is easy to remove and reattach with its non-slip silicone pad. The detachable design makes it easy to clean and install. GELID Solutions hands a 1 year warranty.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6Bo5bnLj6fTN89SU.jpg" target="_blank" data-width="1288" data-height="1066" ><img src="https://tpucdn.com/img/6Bo5bnLj6fTN89SU_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FKyrMP6N2d3A0Nnw.jpg" target="_blank" data-width="1396" data-height="1056" ><img src="https://tpucdn.com/img/FKyrMP6N2d3A0Nnw_thm.jpg" width="172" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EDnBFRbVLdZGvAH5.jpg" target="_blank" data-width="1668" data-height="1212" ><img src="https://tpucdn.com/img/EDnBFRbVLdZGvAH5_thm.jpg" width="179" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4tlRuoHQaXOCYXzT.jpg" target="_blank" data-width="1393" data-height="1000" ><img src="https://tpucdn.com/img/4tlRuoHQaXOCYXzT_thm.jpg" width="181" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303726/gelid-intros-the-nexus-premium-headset-stand">Read full story</a></div>
(PR) Notebook Shipments for 1Q23 Are Projected Reach 10-Year Low for First-Quarter Result, Says TrendForce
Due to the various major events that affected the global economy and politics, the overall demand for consumer electronics made a sharp downward turn in 2022, and global shipments of notebook (laptop) computers began to fall over the quarters. TrendForce's latest analysis finds that global shipments of notebook computers (from ODMs) reached just around 186 million units for 2022, showing a YoY drop of 24.5%. As for 2023, the outlook on the performance of the notebook computer market remains uncertain at this moment. TrendForce expects the YoY decline to moderate to about 7.8%, but shipments are projected to total only 171 million units.<br />
<br />
Because market demand was anemic in 4Q22, promotional activities related to the traditional year-end peak season did not generate a lot of sales momentum. Looking at regional markets, notebook brands (PC OEMs) slashed prices in the US and China, but their sales results still did not meet expectations. This development was mainly attributed to factors such as high inflation suppressing consumers' disposable income. Since the sales results for 4Q22 were lackluster, efforts to get rid of the existing stockpile of whole devices might continue through 2Q23. Furthermore, order placements from channels are going to be much more restrained.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6hRluipzE5UA6nES.jpg" target="_blank" data-width="533" data-height="355" ><img src="https://tpucdn.com/img/6hRluipzE5UA6nES_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303725/notebook-shipments-for-1q23-are-projected-reach-10-year-low-for-first-quarter-result-says-trendforce">Read full story</a></div>
(PR) Alphacool Released Water Blocks for Radeon RX 7900 series and RTX 4080
Even more performance for RTX 4080 Suprim/Strix and RX 7900XT (X) GPUs! Alphacool presents new and innovative solutions for active water cooling of NVIDIA's GeForce RTX 4080 as well as AMD Radeon RX 7900XT (X) graphics cards with the Eisblock Aurora coolers.<br />
<br />
In order to dissipate the enormous waste heat of the new graphics card generations in the best possible way, numerous optimizations were implemented on the water cooler compared to the previous models of these coolers. The fin structure has been modified and allows an optimal water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures the best possible distribution of water on the cooling fins. The fully chrome-plated copper base is resistant to acids, scratches and damage. In addition, the chrome plating provides homogeneity and shine that cannot be achieved by nickel plating.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/eb0TL583n8V03iez.jpg" target="_blank" data-width="1286" data-height="1000" ><img src="https://tpucdn.com/img/eb0TL583n8V03iez_thm.jpg" width="167" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2GPXmnQfBEdgn8Sz.jpg" target="_blank" data-width="1200" data-height="1000" ><img src="https://tpucdn.com/img/2GPXmnQfBEdgn8Sz_thm.jpg" width="156" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fzNBWIwFby2nASCd.jpg" target="_blank" data-width="1181" data-height="1000" ><img src="https://tpucdn.com/img/fzNBWIwFby2nASCd_thm.jpg" width="154" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fHpdK8c8RfYNzmgb.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/fHpdK8c8RfYNzmgb_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/GJ8STcou4jsM8Hxf.jpg" target="_blank" data-width="1686" data-height="1000" ><img src="https://tpucdn.com/img/GJ8STcou4jsM8Hxf_thm.jpg" width="219" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303724/alphacool-released-water-blocks-for-radeon-rx-7900-series-and-rtx-4080">Read full story</a></div>
(PR) Antec Rolls Out P20C and P20CE Mid-tower Cases
With a massive mesh front and metal panel design and flexible configuration options, Antec Inc. presents the latest two additions to the Antec Performance Series: the P20C (with glass side panel) and the P20CE (with sound-dampening side panel). Both versions are now commercially available from 124,99€ (suggested retail price including VAT).<br />
<br />
The P20C / P20CE allows limitless possibilities for building a show case. The new flagship is ready to provide users with a more flexible layout as it features seven reusable PCI-E slots for vertical GPU installation. By supporting dual CPU motherboards with a width of up to 330 mm, the P20C / P20CE is the evolution of compatibility. The new chassis adopts a unique metal design, providing a massive airflow. With the full-size dust filter, the case reaches the balance between cooling and easy maintenance. The pin-type metal front panel is effortlessly removable, and the clip-on dust filters make the cleaning process a walk in the park.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vhtMivSvDuK9Lp6Z.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/vhtMivSvDuK9Lp6Z_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Irj99jwmfNRI4xgU.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/Irj99jwmfNRI4xgU_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2sjiCPXqoCyQIbEG.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/2sjiCPXqoCyQIbEG_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Wl9fdhDPCFhp1roB.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/Wl9fdhDPCFhp1roB_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/87MfoYu3DPNBmpRb.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/87MfoYu3DPNBmpRb_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303723/antec-rolls-out-p20c-and-p20ce-mid-tower-cases">Read full story</a></div>
Intel "Lunar Lake" a Ground-Up Architecture Designed to Dominate the 15W Segment
Intel faces its stiffest long-term challenge not from AMD in the client desktop and server segments, but from the likes of Apple and Qualcomm in the ultraportable notebook SoC market. The company is looking to meet the challenge head-on with not just its current Hybrid architecture-based "Rocket Lake-U" processors, but the upcoming "Meteor Lake" and "Arrow Lake" architectures, which disaggregate the processor into chiplets build on various foundry nodes, including ones that are external to Intel. The move here is to keep Intel ahead of the curve with Moore's Law buckling. The real ace up Intel's sleeves is "Lunar Lake."<br />
<br />
Slated for "beyond 2024" (which could mean 2025 or later), "Lunar Lake" is reportedly a fresh ground-up design for not just the SoC, but also the CPU microarchitecture, with a design focus on performance/Watt, and a focus on mobile devices. This, according to a statement to Dr Ian Cutress. Intel has already brought Hybrid CPU cores to the PC, and with Arm partners loading their SoCs with three or more kinds of CPU cores; Intel could possibly give "Lunar Lake" even more [kinds of] Hybrid processing capabilities. Another hint on the direction in which Intel is heading comes from unlikely quarters—"Sapphire Rapids." Intel's latest enterprise processors attempt to overcome the CPU core-count deficit to AMD, by incorporating various on-die accelerators—these are fixed-function hardware that accelerate specific kinds of enterprise workloads. Intel could give us another lick about "Lunar Lake" in its January 26 Q4-2022 Financial Disclosures Day.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XcbZ1VjhnLv4O1Ua.jpg" target="_blank" data-width="1160" data-height="632" ><img src="https://tpucdn.com/img/XcbZ1VjhnLv4O1Ua_thm.jpg" width="239" height="130" alt="" /></a></div>
(PR) EK-Quantum Velocity² Water Blocks for LGA1700 get an ILM Replacement (Contact Frame)
EK, the premium liquid cooling gear manufacturer, is releasing the EK-Quantum Velocity² ILM Replacement - 1700, a product that replaces the motherboard's Integrated Loading Mechanism (ILM) with a frame that bolsters the structural rigidity of the socket, motherboard, and even the CPU. It is used for cooling 12th and 13th generation Intel Core CPUs with regular EK-Quantum Vector² CPU water blocks, not Direct Die models.<br />
<br />
Due to the rectangular and elongated design of these CPUs and the way the stock ILM holds the CPU down, the Intel 12th and 13th-gen CPUs are prone to warping caused by uneven pressure. The new contact frame from EK mitigates this issue as it prevents any warping or bending of the CPU and its surrounding area. This improves the cooling efficiency due to more even pressure applied on the CPU. As a result, the bending is removed and the CPU's center that contains the heat source is no longer concave, enabling improved contact with the cooler.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/9ymWqVesyeQl2aml.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/9ymWqVesyeQl2aml_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XtAkac213hY3fGPd.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/XtAkac213hY3fGPd_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303709/ek-quantum-velocity-water-blocks-for-lga1700-get-an-ilm-replacement-contact-frame">Read full story</a></div>
MSI Announces GeForce RTX 4090 SUPRIM X Classic—Reuses RTX 30-series SUPRIM X Cooler
MSI quietly rolled out the GeForce RTX 4090 SUPRIM X Classic. Positioned alongside its air-cooled flagship graphics card, the RTX 4090 SUPRIM X, the new SUPRIM X Classic appears to be reusing the older version of MSI's SUPRIM X cooling solution that the company shipped with RTX 30-series "Ampere" graphics cards, such as the RTX 3090 Ti SUPRIM X. The older cooler should capable of handling the thermal loads of the RTX 4090, as it has <a href="https://www.techpowerup.com/review/msi-geforce-rtx-4090-suprim-x/39.html" target="_blank">much lower</a> power-draw than the RTX 3090 Ti. This isn't the only "Classic" graphics card from MSI, with the company planning <a href="https://www.techpowerup.com/303155/msi-finally-has-radeon-rx-7900-series-products-to-show" target="_blank">Radeon RX 7900 series Gaming X Classic</a> graphics cards that reuse the Tri Frozr III cooling solution that the company used with its RX 6900 series Gaming X products. Besides the cooler and product-design there don't appear to be any other difference in specs for the SUPRIM X Classic compared to the RTX 4090 SUPRIM X.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hatsUQOqFrEsfNwz.jpg" target="_blank" data-width="979" data-height="783" ><img src="https://tpucdn.com/img/hatsUQOqFrEsfNwz_thm.jpg" width="163" height="130" alt="" /></a></div>
AMD Entry-level A620 Chipset Nears Launch, Promises Motherboards Start
AMD's entry-level A620 chipset for Socket AM5 motherboards is nearing launch, as manufacturers such as GIGABYTE and ASUS have started regulatory filing their upcoming products with the Eurasian Economic Commission (EEC). These would hopefully bring the starting prices of AM5 motherboards down to the USD $125 figure AMD promised. AMD will sufficiently differentiate A620 from the B650, using specs such as the lack of CPU overclocking capabilities, only a handful PCIe Gen 3 downstream lanes, and the lack of PCIe Gen 5 on both the PEG and CPU-attached M.2 slots (which could at least be limited to Gen 4 if not Gen 3). <br />
<br />
While the motherboards themselves may be cheap, the overall platform costs may still end up higher than Intel's H610 or upcoming H710 chipsets; as Socket AM5 lacks DDR4 memory support, and even at the entry-level you'll be forced to buy DDR5. That said, what A620 promises is platform longevity, that the platform will support future processor generations that launch even beyond 2025. AMD dropped a major hint on A620 chipset motherboards availability in its 2023 CES Keynote address, when it pointed to "65 W CPUs and entry-level motherboards" alongside each other. The 65 W Ryzen 7000 series processors are already out, which means A620 should be just around the corner. February 2023 is when AMD looks to launch its high-end Ryzen 7000X3D processors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kGuIuFzcXnXlgQQW.jpg" target="_blank" data-width="1908" data-height="640" ><img src="https://tpucdn.com/img/kGuIuFzcXnXlgQQW_thm.jpg" width="388" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rUjRFYFXNqm4Yw08.jpg" target="_blank" data-width="708" data-height="382" ><img src="https://tpucdn.com/img/rUjRFYFXNqm4Yw08_thm.jpg" width="241" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/drzgaerTcDHhQzRd.jpg" target="_blank" data-width="756" data-height="403" ><img src="https://tpucdn.com/img/drzgaerTcDHhQzRd_thm.jpg" width="244" height="130" alt="" /></a></div>
(PR) QNAP Introduces the Half-width Rackmount QSW-M2106R-2S2T 2.5GbE & 10GbE L2 Web Managed Switch
QNAP Systems, Inc., a leading computing, networking, and storage solutions innovator, today released the Half-width Rackmount QSW-M2106R-2S2T 10-port Layer 2 Web managed Switch. Supporting 2.5GbE, 10GbE and practical Layer 2 management functions, the QSW-M2106R-2S2T satisfies high-bandwidth requirements of servers and LAN infrastructure for SMBs. With its half-width design, the QSW-M2106R-2S2T is an ideal networking solution for server rooms in small businesses and organizations.<br />
<br />
"Compared with the previous QSW-M2108R-2C, the QNAP QSW-M2106R-2S2T includes two 10GbE SFP+ and two 10GbE RJ45 ports," said Ricky Ho, Product Manager of QNAP, adding "the half-width rackmount design also allows IT administrator to make efficient space utilization of server racks and cabinets, fulfilling high-bandwidth applications at a cost-optimized price."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OS30ivst5FZRutmQ.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/OS30ivst5FZRutmQ_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LJHoT3mj5ePm1sl4.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/LJHoT3mj5ePm1sl4_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/f5Rjk6i4IhKhevgU.jpg" target="_blank" data-width="1020" data-height="960" ><img src="https://tpucdn.com/img/f5Rjk6i4IhKhevgU_thm.jpg" width="138" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/arpgcd3Vu6MHIP0R.jpg" target="_blank" data-width="1088" data-height="612" ><img src="https://tpucdn.com/img/arpgcd3Vu6MHIP0R_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303690/qnap-introduces-the-half-width-rackmount-qsw-m2106r-2s2t-2-5gbe-10gbe-l2-web-managed-switch">Read full story</a></div>
(PR) UMC Reports Fourth Quarter 2022 Results
United Microelectronics Corporation ("UMC" or "The Company"), a leading global semiconductor foundry, today announced its consolidated operating results for the fourth quarter of 2022. Fourth quarter consolidated revenue was NT$67.84 billion, decreasing 10.0% QoQ from NT$75.39 billion in 3Q22. Compared to a year ago, 4Q22 revenue grew 14.8% YoY from NT$59.10 billion in 4Q21. Consolidated gross margin for 4Q22 was 42.9%. Net income attributable to the shareholders of the parent was NT$19.1 billion, with earnings per ordinary share of NT$1.54.<br />
<br />
Jason Wang, co-president of UMC, said, "In the fourth quarter, due to a significant slowdown across most of our end markets and inventory correction in the semiconductor industry, our wafer shipments fell 14.8% QoQ while overall fab utilization rate dropped to 90%. Average selling price increased slightly during the quarter as a result of our ongoing product mix optimization efforts, moderating the decline in revenue."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CEeRmarBZqcllBkZ.jpg" target="_blank" data-width="1254" data-height="476" ><img src="https://tpucdn.com/img/CEeRmarBZqcllBkZ_thm.jpg" width="342" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303689/umc-reports-fourth-quarter-2022-results">Read full story</a></div>
(PR) Yealink Reveals the BH7X Bluetooth Headsets, the New Standard for Hybrid Work
Yealink, a leading global provider of enterprise communication and collaboration solutions, held an online demo to showcase the brand-new BH7X Series Bluetooth headsets on Jan. 12th, including the Brand-new BH71 mono Bluetooth headset, especially designed for hybrid working, the upgraded BH72 essential Bluetooth headset for daily usage, and the BH76 premium Bluetooth headset, featuring exceptional active noise cancellation (ANC) abilities.<br />
<br />
During some demonstration, Yealink showed it to the world how the crystal-clear sound quality, sleek design and seamless collaboration with united communication (UC) devices and platforms deliver an intuitive experience for hybrid workers in the post-pandemic era, delivering a reliable performance in day-to-day life, against the challenges of different environments, long-time wearing and multi-device collaboration.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/PZm6IKnbajvGgwjR.jpg" target="_blank" data-width="627" data-height="938" ><img src="https://tpucdn.com/img/PZm6IKnbajvGgwjR_thm.jpg" width="87" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nMyuMniZHO0yz8Ah.jpg" target="_blank" data-width="960" data-height="738" ><img src="https://tpucdn.com/img/nMyuMniZHO0yz8Ah_thm.jpg" width="169" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/M5Iahrj8HzRRVsEG.jpg" target="_blank" data-width="628" data-height="800" ><img src="https://tpucdn.com/img/M5Iahrj8HzRRVsEG_thm.jpg" width="102" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303682/yealink-reveals-the-bh7x-bluetooth-headsets-the-new-standard-for-hybrid-work">Read full story</a></div>
CAMM to Replace the Decades-old SO-DIMM Laptop Memory, JEDEC and Dell Argue
Laptop memory has been a controversial topic for many years. Its proprietary standard, SO-DIMM, has shown signs of aging as the decades-old JEDEC standard didn't adapt to other expanding capacities and speed trends. Today, JEDEC and Dell think that the future of laptop memory is in <a href="https://www.techpowerup.com/294240/dells-ddr5-camm-appears-in-more-detail-comes-in-several-shapes-wont-be-proprietary" target="_blank">the new CAMM</a> standard that both companies are working on. The introduction of CAMM comes from Dell, whose Senior Distinguished Engineer Tom Schnell is working on it. "We have unanimous approval of the 0.5 spec," said Mr. Schnell for PCWorld. One of the problems that SO-DIMM is facing is the capacity and speed issue, where the current DDR5 SO-DIMM memory stops at around 6400 MT/s. CAMM, on the other hand, starts from that speed and works its way up to offer higher capacities as well.<br />
<br />
With Dell introducing CAMM in its laptops, it had no intentions of creating a proprietary solution but rather an expandable and upgradable memory platform with various benefits. With JEDEC's involvement in finalizing this, the CAMM standard is slowly on its way to becoming a viable option for different laptop manufacturers. Dell's Tom Schnell didn't reveal what companies are in the process of creating the final specification; however, we know that 32 of them are present, including Apple. If others join, the standard could take over future laptop designs and offer higher speeds and higher capacities, especially in the mobile workstation space where it matters. Below is an example of a CAMM memory module with a patent showing the SO-DIMM (upper left) versus CAMM (lower right) and CAMM's smaller trace path. With smaller tracing, the latency is also going down, so the new standard will bring additional efficiency. Additionally, devices that are based on LPDDR memory could have an upgrade path with the installment of CAMM.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/C0L8hqLjmnBn28vA.jpg" target="_blank" data-width="1200" data-height="849" ><img src="https://tpucdn.com/img/C0L8hqLjmnBn28vA_thm.jpg" width="184" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3MRmY7E3wmpciZ7p.jpg" target="_blank" data-width="1200" data-height="598" ><img src="https://tpucdn.com/img/3MRmY7E3wmpciZ7p_thm.jpg" width="261" height="130" alt="" /></a></div>
(PR) Philips Announces the Evnia 27M2C5500W Gaming Monitor
Today's gamers have higher expectations than ever. They're looking for a truly immersive experience that engages their senses and allows them to enjoy the full thrill of the game. They want a setup with cutting-edge specs, but these gamers also want the emotion of gaming. Seeking to give gamers the excitement they're looking for, Philips monitors has developed a range of monitors and accessories designed to ensure rich and rewarding gaming experiences for players of all tastes and all ages. The latest member of the Evnia family to be released is the Philips Evnia 27M2C5500W, a 27" Quad HD gaming monitor that combines a lightning fast 240 Hz refresh rate with a compact, ergonomic design and a rich variety of high-performance features, ensuring that every gaming session is nothing less than epic.<br />
<br />
"Reflecting Evnia's mission to provide today's gamers with the equipment they need to get the most enjoyment out of every gaming session, the Philips Evnia monitors combine smooth gameplay, visual fidelity, and rapid response times in one elegantly designed package. We're proud of this irresistible model, of Evnia and what it stands for." said Xeni Bairaktari, Global Marketing Lead and Senior Brand Manager EU at MMD Monitors & Displays.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/U0yWFVJDqXisF7OF.jpg" target="_blank" data-width="1070" data-height="1000" ><img src="https://tpucdn.com/img/U0yWFVJDqXisF7OF_thm.jpg" width="139" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1Daip6jNhohQ3JWm.jpg" target="_blank" data-width="1000" data-height="780" ><img src="https://tpucdn.com/img/1Daip6jNhohQ3JWm_thm.jpg" width="167" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gpHKc9ax3NcC342b.jpg" target="_blank" data-width="946" data-height="714" ><img src="https://tpucdn.com/img/gpHKc9ax3NcC342b_thm.jpg" width="172" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZXnQICHo8Ei0hLYd.jpg" target="_blank" data-width="1200" data-height="996" ><img src="https://tpucdn.com/img/ZXnQICHo8Ei0hLYd_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bqeC9zqS1JuP1aui.jpg" target="_blank" data-width="1085" data-height="1000" ><img src="https://tpucdn.com/img/bqeC9zqS1JuP1aui_thm.jpg" width="141" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303811/philips-announces-the-evnia-27m2c5500w-gaming-monitor">Read full story</a></div>
(PR) Alphacool Unveils Core Distro Plate Series
The new Core Distro Plate from Alphacool is a must-have for every performance-oriented custom water cooling system. It greatly simplifies the planning, construction and maintenance of complex water loops. The Distro Plate features an integrated reservoir with pump top for VPP/D5 pumps. Due to the arrangement of the G1/4" connections, confusing and complicated tubing paths will be a thing of the past. Therefore, the Core Distro Plate is ideally suited for custom water loops in which CPU and graphics card(s) are to be cooled simultaneously. <br />
<br />
A beautiful and elegant element of the Core Distro Plate are the chrome-plated, brass G1/4" connectors. Recessed into the acrylic and fitted with an O-ring, the connectors are absolutely leak-proof and support the clean and functional look of the Alphacool Core Design series. The connections are not screwed directly into the acrylic to prevent cracking and resulting leakage.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lIuRDBcRVcYdzLxE.jpg" target="_blank" data-width="721" data-height="559" ><img src="https://tpucdn.com/img/lIuRDBcRVcYdzLxE_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pzzGs49R3K8cmJRC.jpg" target="_blank" data-width="724" data-height="551" ><img src="https://tpucdn.com/img/pzzGs49R3K8cmJRC_thm.jpg" width="171" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303808/alphacool-unveils-core-distro-plate-series">Read full story</a></div>
(PR) Foundry Revenue is Forecasted to Drop by 4% YoY for 2023, TrendForce Notes
TrendForce's recent analysis of the foundry market reveals that demand continues to slide for all types of mature and advanced nodes. The major IC design houses have cut wafer input for 1Q23 and will likely scale back further for 2Q23. Currently, foundries are expected to maintain a lower-than-ideal level of capacity utilization rate in the first two quarters of this year. Some nodes could experience a steeper demand drop in 2Q23 as there are still no signs of a significant rebound in wafer orders. Looking ahead to the second half of this year, orders will likely pick up for some components that underwent an inventory correction at an earlier time. However, the state of the global economy will remain the largest variable that affect demand, and the recovery of individual foundries' capacity utilization rates will not occur as quickly as expected. Taking these factors into account, TrendForce currently forecasts that global foundry revenue will drop by around 4% YoY for 2023. The projected decline for 2023 is more severe when compared with the one that was recorded for 2019.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2oxlOMe0pDZQUXLC.jpg" target="_blank" data-width="531" data-height="405" ><img src="https://tpucdn.com/img/2oxlOMe0pDZQUXLC_thm.jpg" width="170" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303807/foundry-revenue-is-forecasted-to-drop-by-4-yoy-for-2023-trendforce-notes">Read full story</a></div>
About 300 MSI Motherboard Models Have a Faulty Secure Boot Implementation with Certain UEFI Firmware Versions
The UEFI Secure Boot feature is designed to prevent malicious code from executing during the system boot process, and has been a cybersecurity staple since the late-2000s, when software support was introduced with Windows 8. Dawid Potocki, a New Zealand-based IT student and cybersecurity researcher, discovered that as many as 300 motherboard models by MSI have a faulty Secure Boot implementation with certain versions of their UEFI firmware, which allows just about any boot image to load. This is, however, localized to only certain UEFI firmware versions, that are released as beta versions.<br />
<br />
Potocki stumbled upon this when he found that his PRO Z790-A WiFi motherboard failed to verify the cryptographic signature boot-time binaries at the time of system boot. "I have found that my firmware was… accepting every OS image I gave it, no matter if it was trusted or not." He then began examining other motherboard models, and discovered close to 300 MSI motherboard models with a broken Secure Boot implementation. He clarified that MSI laptops aren't affected, and only their desktop motherboards are. Potocki says that affected MSI motherboards have an "always execute" policy set for Secure Boot, which makes the mechanism worthless, and theorized a possible reason. "I suspect this is because they probably knew that Microsoft wouldn't approve of it and/or that they get less tickets about Secure Boot causing issues for their users."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cRpq8wXB9O9B0qvM.jpg" target="_blank" data-width="577" data-height="364" ><img src="https://tpucdn.com/img/cRpq8wXB9O9B0qvM_thm.jpg" width="206" height="130" alt="" /></a></div>
NVIDIA GeForce RTX 4060 Ti Possible Specs Surface—160 W Power, Debuts AD106 Silicon
NVIDIA's next GeForce RTX 40-series "Ada" graphics card launch is widely expected to be the GeForce RTX 4070 (non-Ti), and as we approach Spring 2023, the company is expected to ramp up to the meat of its new generation, with xx60-segment, beginning with the GeForce RTX 4060 Ti. This new performance-segment SKU debuts the 4 nm "AD106" silicon. A set of leaks by kopite7kimi, a reliable source with NVIDIA leaks, shed light on possible specifications.<br />
<br />
The RTX 4060 Ti is based on the AD106 silicon, which is expected to be much smaller than the AD104 powering the RTX 4070 series. The reference board developed at NVIDIA, codenamed PG190, is reportedly tiny, and yet it features the 16-pin ATX 12VHPWR connector. This is probably set for 300 W at its signal pins, and adapters included with graphics cards could convert two 8-pin PCIe into one 300 W 16-pin connector. The RTX 4060 Ti is expected to come with a typical graphics power value of 160 W.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/H8Iv6N1SfZmXm9I6.jpg" target="_blank" data-width="602" data-height="372" ><img src="https://tpucdn.com/img/H8Iv6N1SfZmXm9I6_thm.jpg" width="210" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303804/nvidia-geforce-rtx-4060-ti-possible-specs-surface-160-w-power-debuts-ad106-silicon">Read full story</a></div>
AMD RX 7900 XTX OC Does Cross 3 GHz Barrier, But in Non-Gaming Workloads
AMD's Radeon RX 7900 XTX RDNA3 graphics card does cross the 3 GHz engine clocks barrier, but not in gaming use-cases, finds a ComputerBase.de article, in which the German publication compares the overclocking experience between the RX 7000-series RDNA3 and NVIDIA RTX 40-series "Ada" architectures. The RX 7900 XTX was found to hit engine clock speeds as high as 3455 MHz, but when handling the Blender rendering benchmark, and not typical gaming workloads. <br />
<br />
The GPU could even be pushed to 3548 MHz with a power-draw of around 400 W, but it wasn't stable, the article notes. The top frequencies the GPUs could hit with gaming workloads were around 2.90 GHz. We could be happening with games is that more of the GPU's hardware resources are tapping into its power-limit (such as the memory controllers, caches, and other special SIMD functions, which could be impacting the engine clock boosting headroom. ComputerBase.de used a Sapphire RX 7900 XTX NITRO+ custom-design graphics card in its testing, which comes with three 8-pin PCIe power connectors, and a higher overclocking headroom than what the reference-design cards are capable of.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/1tCroxFsqfUBBrax.jpg" target="_blank" data-width="679" data-height="633" ><img src="https://tpucdn.com/img/1tCroxFsqfUBBrax_thm.jpg" width="139" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qHzm4M1Hi9aGunsk.jpg" target="_blank" data-width="662" data-height="581" ><img src="https://tpucdn.com/img/qHzm4M1Hi9aGunsk_thm.jpg" width="148" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pgGi3CzKuntOF1iy.jpg" target="_blank" data-width="658" data-height="509" ><img src="https://tpucdn.com/img/pgGi3CzKuntOF1iy_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hlm8Tft8qewkUDqG.jpg" target="_blank" data-width="684" data-height="880" ><img src="https://tpucdn.com/img/hlm8Tft8qewkUDqG_thm.jpg" width="101" height="130" alt="" /></a></div>
Chips are the New Oil with Geopolitics: Intel CEO
Intel CEO Pat Gelsinger, in an interview with CNN at WEF Davos, stated that semiconductor chip supply chains will have a greater influence on geopolitics than oil supply-chains over the next 50 years. Modern civilization is increasingly digitized, and most modern conveniences are "chipped" and connected in some form, which would put the chip-producing nations, or entities producing/supplying the chips at a distinct geopolitical advantage, similar to the oil-producing ones today. The location of "oil reserves [has] defined geopolitics for the last five decades," Gelsinger said; "where the technology supply chains are, and where semiconductors are built, is more important for the next 5 decades," he added.<br />
<br />
We caught a taste of exactly what he meant when global semiconductor supply chains buckled around 2020-onward, hitting a multitude of other industries, including automobiles, construction, remote-work, consumer electronics, and much more. Unlike oil, which is a geographically constrained being a natural resource, chips can be manufactured almost anywhere, dictated only by geopolitical, trade, and IP barriers. Gelsinger calls for a much wider geographic spread of chip-production, so the supply-chains get resilient to disruptions due to unforeseen events. "We need this geographically balanced, resilient supply chain," he said. Gelsinger is at the forefront of advocating semiconductor manufacturing on U.S. soil to not only meet local demand, but also contribute to global supply-chain resilience. The CHIPS Act passed by U.S. Congress in 2022 will oversee more than $200 billion in public investments on semiconductor manufacturing and tech-research in the U.S.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FDnOzaaT83ejCprz.jpg" target="_blank" data-width="965" data-height="551" ><img src="https://tpucdn.com/img/FDnOzaaT83ejCprz_thm.jpg" width="228" height="130" alt="" /></a></div>
(PR) Synology Announces Highly Scalable SA6400 Storage System
Synology today announced the availability of the 12-bay SA6400, its most versatile general-purpose storage system designed to provide enterprises and large studios with lightning-fast data transfer speeds and on-demand capacity expansion. "SA6400 is the ideal solution to tackle today's ever-increasing amounts of unstructured data," said Julien Chen, Product Manager at Synology. "Its ability to quickly scale as data demands grow makes it suitable to serve as file or backup storage in agile and dynamic environments, getting businesses ready for future data growth."<br />
<br />
Storage capacity is seamlessly expandable by adding up to 8 RX1223RP expansion units for a total of 108 drive bays, making room for over 1.9 petabytes on a single system—9 times the original capacity. With a throughput of over 6,500/4,000 MB/s sequential read/write, SA6400 ensures smooth operations even in the most demanding scenarios, including enterprise data centers, large production studios, and applications in the retail or hospitality sectors. Performance can be further boosted to accommodate more streams or tackle specialized applications by upgrading the built-in 10 GbE networking to 25 or even 40 GbE.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kG4qFoJvpZjzK0RX.jpg" target="_blank" data-width="650" data-height="302" ><img src="https://tpucdn.com/img/kG4qFoJvpZjzK0RX_thm.jpg" width="280" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303801/synology-announces-highly-scalable-sa6400-storage-system">Read full story</a></div>
(PR) Apple Introduces the New HomePod with Breakthrough Sound and Intelligence
pple today announced HomePod (2nd generation), a powerful smart speaker that delivers next-level acoustics in a gorgeous, iconic design. Packed with Apple innovations and Siri intelligence, HomePod offers advanced computational audio for a groundbreaking listening experience, including support for immersive Spatial Audio tracks. With convenient new ways to manage everyday tasks and control the smart home, users can now create smart home automations using Siri, get notified when a smoke or carbon monoxide alarm is detected in their home, and check temperature and humidity in a room—all hands-free.<br />
<br />
The new HomePod is available to order online and in the Apple Store app starting today, with availability beginning Friday, February 3. "Leveraging our audio expertise and innovations, the new HomePod delivers rich, deep bass, natural mid-range, and clear, detailed highs," said Greg Joswiak, Apple's senior vice president of Worldwide Marketing. "With the popularity of HomePod mini, we've seen growing interest in even more powerful acoustics achievable in a larger HomePod. We're thrilled to bring the next generation of HomePod to customers around the world."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JiytrghpsjYU39da.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/JiytrghpsjYU39da_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Ph14WHgET3qaWuy0.jpg" target="_blank" data-width="653" data-height="653" ><img src="https://tpucdn.com/img/Ph14WHgET3qaWuy0_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sOh7T3keYyY4NBJE.jpg" target="_blank" data-width="980" data-height="634" ><img src="https://tpucdn.com/img/sOh7T3keYyY4NBJE_thm.jpg" width="201" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Qqh3T9XT6k3pbpFJ.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/Qqh3T9XT6k3pbpFJ_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303786/apple-introduces-the-new-homepod-with-breakthrough-sound-and-intelligence">Read full story</a></div>
(PR) LG's Newest UltraGear Gaming Monitor Named Official Display of LE
LG Electronics' (LG) latest UltraGear gaming monitor (model 25GR75FG) has been named the official display of the League of Legends EMEA Championship (LEC) 2023. The new monitor will make its debut during the upcoming LEC season, which begins this weekend, supporting players from the region's top teams as they battle it out for tournament honors. LG UltraGear is proud to continue its strong partnership with LEC, one of the world's most popular esports leagues, and remains committed to fostering the growth of esports internationally.<br />
<br />
Designed for competitive esports, the latest LG UltraGear gaming monitor delivers outstanding picture quality and speed thanks to a 24.5-inch Full-HD (1,920 x 1,080) IPS display with a 360 Hz refresh rate and 1 millisecond Gray-to-Gray (GTG) response time. The performance of LG's new gaming display is further boosted by the integration of NVIDIA G-SYNC technology, which minimizes screen-tearing for seamless visuals, and NVIDIA Reflex, which helps to reduce click-to-display latency for more precise control of the onscreen action. VESA Display HDR 400 certified, the 25GR75FG also ensures bright, clear images and has a 3-sided borderless design that helps increase players' sense of immersion, making it easier to focus during fierce competition.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/QKxjLokeprZy8KJM.jpg" target="_blank" data-width="914" data-height="960" ><img src="https://tpucdn.com/img/QKxjLokeprZy8KJM_thm.jpg" width="124" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XM2Cs2XTpcEbjdGL.jpg" target="_blank" data-width="1000" data-height="960" ><img src="https://tpucdn.com/img/XM2Cs2XTpcEbjdGL_thm.jpg" width="135" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2gGUhWlShYMuHPOM.jpg" target="_blank" data-width="1331" data-height="960" ><img src="https://tpucdn.com/img/2gGUhWlShYMuHPOM_thm.jpg" width="180" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XSSvdAFf9cEQz3sn.jpg" target="_blank" data-width="458" data-height="866" ><img src="https://tpucdn.com/img/XSSvdAFf9cEQz3sn_thm.jpg" width="69" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sKvxbdldgNTG93iQ.jpg" target="_blank" data-width="1358" data-height="960" ><img src="https://tpucdn.com/img/sKvxbdldgNTG93iQ_thm.jpg" width="184" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303785/lgs-newest-ultragear-gaming-monitor-named-official-display-of-lec-2023">Read full story</a></div>
(PR) ASUS Announces All-New ExpertCenter Tower Desktops for 2023
ASUS today announced the latest additions to its business-friendly range of ExpertCenter desktop PCs—the all-new ExpertCenter D5 Tower (D500TE) and ExpertCenter D7 Tower (D700TE) models.<br />
<br />
Powered by up to the latest 13th Generation Intel Core i9 processor and professional-grade NVIDIA graphics, these new ExpertCenter desktops benefit from a voluminous 27-liter case for maximum expandability. Embracing the ExpertCenter ethos, the new models are meticulously engineered to deliver professional performance, easy maintenance, enterprise-grade security and manageability. They're also built to and tested to military-grade standards of strength and resilience. Sustainability and efficiency are also cornerstones of the ExpertCenter design, from manufacturing and packaging to daily use—achieving multiple certifications for their environmental consideration.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/grxvhTFweiHtBAbg.jpg" target="_blank" data-width="640" data-height="640" ><img src="https://tpucdn.com/img/grxvhTFweiHtBAbg_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wxkAR5ZY0JUqJqHW.jpg" target="_blank" data-width="1138" data-height="640" ><img src="https://tpucdn.com/img/wxkAR5ZY0JUqJqHW_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303784/asus-announces-all-new-expertcenter-tower-desktops-for-2023">Read full story</a></div>
(PR) ASUS IoT Announces the PE3000G with Discrete GPU Support via MXM Module
SUS IoT, the global AIoT solution provider, today announced PE3000G—the industry's first edge AI system to support Mobile PCI Express Module (MXM) GPUs from both NVIDIA and Intel. Specifically, the all-new industrial PC works seamlessly with NVIDIA Ampere/Turing or Intel Arc A-series MXM GPUs. Powered by a 12th Gen Intel Core processor and up to 64 GB of DDR5 4800 MHz memory, and combining a proven power design, guaranteed and fanless thermal performance, and superior physical and mechanical ruggedness, PE3000G brings unprecedented longevity, computing power, flexibility and reliability to AI computing at the edge—making it an ideal option for scenarios where resilience, longevity and both CPU and GPU scalability are paramount.<br />
<br />
"PE3000G is ASUS IoT's response to the burgeoning demand for accelerating AI inference and extreme deployment in industrial settings," commented KuoWei Chao, General Manager of the ASUS IoT business unit. "With robust power, thermal and mechanical design, it pushes versatile edge-AI-inference applications to business-critical applications. PE3000G is an ideal fit to accelerate edge AI inference in SWaP-constrained applications, such as machine vision in factory automation, outdoor surveillance system and AI-inference systems for autonomous vehicles."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/uDfsBSZy3yaDv6HP.jpg" target="_blank" data-width="640" data-height="640" ><img src="https://tpucdn.com/img/uDfsBSZy3yaDv6HP_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303783/asus-iot-announces-the-pe3000g-with-discrete-gpu-support-via-mxm-module">Read full story</a></div>
Intel Reincarnates VROC Functionality for Xeon Processors
Intel's Xeon processors feature a wide range of embedded functionalities that the company has developed over the years. One such is the Virtual RAID on CPU (VROC) that enabled the functionality of an NVMe RAID card on the CPU, simplifying the installation, cost, and maintenance of high-performance storage arrays. Debuting in 2017, it is present in some consumer-facing Core models and Xeon Scalable platforms where it sees the highest usage. However, on January 6, Intel posted a product change notice that notified the users that the VROC function would be discontinued, with the last orders being placed on January 23 and the last shipping with VROC being made on March 31. This caused confusion, especially in the enterprise sector, which utilizes Intel Xeon processors for their workloads and storage arrays.<br />
<br />
Tom's Hardware has reached out to Intel for clarification and got the following statement:<blockquote><small>Intel Spokesperson</small>The PCN [Product Change Notice] was prematurely posted while the decision was under evaluation. After discussing with the ecosystem and customers we realize there is significant demand for this product and intend to continue to support it.</blockquote><div class="imgcontainer"><a href="https://www.techpowerup.com/img/BLLdX03Jn9KnB8ay.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/BLLdX03Jn9KnB8ay_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303775/intel-reincarnates-vroc-functionality-for-xeon-processors">Read full story</a></div>
Microsoft to Reduce its Workforce by 5%, Almost 11,000 Jobs Impacted
Amidst the global economic downturns, Microsoft is reportedly joining other tech giants in reducing the amount of the company's working staff. According to Sky News, citing its sources, Microsoft will lay off as many as 5% of its workers. The company's massive team of over 220,000 employees will affect a large group estimated to be close to 11,000 people. In addition, Sky News' Wall Street Analyst source suggests that the people familiar with the matter would not be surprised if the reported figure is higher. If finalized, the decision is expected to be made official by Microsoft's chairman and CEO, Satya Nadella, on January 24.<br />
<br />
The company's current market capitalization is $1.79 trillion, making it one of the world's most valuable companies. However, more than the investment in expanding Azure cloud services is needed to offset the stagnating consumer segment where Microsoft dominates with its Windows and Office services, so the company is forced to cut a part of its workforce. We don't have exact details on which segment is getting the highest deduction in staff; however, we expect to hear more at the company's Q4 2022 results call on January 24.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2okuxDe27GrfoqP4.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/2okuxDe27GrfoqP4_thm.jpg" width="231" height="130" alt="" /></a></div>
GALAX GeForce RTX 4070 (non-Ti) Graphics Cards Pictured
Marketing pictures of two custom-design GeForce RTX 4070 "Ada" (non-Ti) graphics card models by GALAX, were leaked to the web. The more simple-looking of the two is very likely the GALAX RTX 4070 EX Gamer White; while the other more flashy of the two, could be the GALAX RTX 4070 SG White. What's interesting is that both cards are triple-slot, including with their I/O brackets, for what is supposed to be a mid performance-segment product positioned below the recently launched RTX 4070 Ti.<br />
<br />
Rumored specifications of the RTX 4070 (non-Ti) have it, that the SKU is based on the same 4 nm "AD104" silicon as the RTX 4070 Ti, albeit significantly cut-down, with only 46 out of 60 streaming multiprocessors (SM) on the silicon being enabled (that's 76% of the available SIMD machinery). This works out to 5,888 CUDA cores, 46 RT cores, and 184 Tensor cores. The card might get the same 12 GB memory size, across the 192-bit GDDR6X memory bus of the AD104, with the same 21 Gbps memory speed, working out to 504 GB/s bandwidth. One reason why GALAX's cards look this buff could have to do with NVIDIA's partners reusing their RTX 4070 Ti board designs for their premium RTX 4070 cards.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DWDTjJFkkMcQMovD.jpg" target="_blank" data-width="1362" data-height="1000" ><img src="https://tpucdn.com/img/DWDTjJFkkMcQMovD_thm.jpg" width="177" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1wXUgzUDkYD5Gul9.jpg" target="_blank" data-width="1289" data-height="1000" ><img src="https://tpucdn.com/img/1wXUgzUDkYD5Gul9_thm.jpg" width="168" height="130" alt="" /></a></div>
HiCookie and GIGABYTE Achieve DDR5-11316 Memory OC
Professional overclocker HiCookie and GIGABYTE partnered to smash the memory overclocking record out of the park, with a jaw-dropping DDR5-11316 memory OC (5567.5 MHz memory clock). This memory OC record was achieved in a single-channel (single module) configuration, on a GIGABYTE Z790 AORUS Tachyon motherboard that has a 1DPC (one DIMM per channel) memory slot topology; while the processor in charge was a Core i9-13900K. A single 16 GB GIGABYTE AORUS DDR5 memory module was used, and the DDR5-11316 speed was achieved at timings of 64-127-127-127-127, with 2T command-rate; although the DRAM voltage remains unknown. The CPUID validation can be found <a rel="nofollow" href="https://valid.x86.fr/g7qe3q" target="_blank">here</a>, and the HWBOT listing <a rel="nofollow" href="https://hwbot.org/submission/5174984_" target="_blank">here</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/czreUZ9pTMOMsGdE.jpg" target="_blank" data-width="1260" data-height="1071" ><img src="https://tpucdn.com/img/czreUZ9pTMOMsGdE_thm.jpg" width="153" height="130" alt="" /></a></div>
(PR) Logitech Brio 300 Series Webcams Affordably Enhance Video Experiences
Today, Logitech unveiled its Brio 300 series, a line of compact, plug-and-play webcams with Full-HD 1080p resolution, auto light correction and a noise-reducing mic, for more natural and productive video call experiences at an attractive price. "We surveyed more than 3,000 remote workers and found that most non-webcam users struggle with poor lighting conditions, unflattering camera angles, and low-quality sound from their laptop speakers. Brio 300 series webcams are perfect for those who want to make the easy but substantial jump to significantly improve their video meeting experiences with an external webcam," said Scott Wharton, general manager of Logitech B2B. "And for companies who need to provide certified, simple-to-use webcams to employees' home or office workstations, Brio 305 is that budget-friendly option."<br />
<br />
The Brio 300 series (Brio 300 and Brio 305) are Full-HD 1080p webcams with high dynamic contrast, auto light correction, and a single digital microphone with noise reduction, so users are seen and heard clearly despite poor lighting and background noise. With a reliable meeting experience every time, users can join video calls feeling confident and engaged. The webcams connect to computers through a USB-C port, making it simple to join video meetings. Afterward, a quick spin of the built-in privacy shutter gives users assurance the camera lens is blocked and no longer showing their workspace.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LVvl0vUQzbIIaSgy.jpg" target="_blank" data-width="1103" data-height="686" ><img src="https://tpucdn.com/img/LVvl0vUQzbIIaSgy_thm.jpg" width="209" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303767/logitech-brio-300-series-webcams-affordably-enhance-video-experiences">Read full story</a></div>
Fractal Ridge Case PCIe Riser Has Trouble Running in PCIe Gen 4 Mode, Company Outs Workaround
The Fractal Design Ridge SFF tower-type case won critical praise <a href="https://www.techpowerup.com/review/fractal-design-ridge/" target="_blank">including from us</a>, for its unique design, well-planned interiors, and room for even triple-slot graphics cards with a little adjustments. The case relies on a PCIe riser cable to maintain its SFF form, since the graphics card has to be oriented vertically. The riser included with the case meets PCI-Express 4.0 standards, but end-users started experiencing problems running their latest-generation PCIe Gen 4 graphics cards with this case, with the problem being localized to the riser cable. Fractal investigated this issue, and confirmed the issue.<br />
<br />
Apparently, the PCIe riser included with the Fractal Ridge, while rated for PCIe Gen 4, has a design flaw that affects signal integrity. The riser is found to be only stable with PCIe Gen 3 or lower. The company is recommending a workaround for end-users while it works on a solution: to confine PCIe to Gen 3 mode using the motherboard's UEFI setup program (BIOS setup program), in which you can restrict the x16 PEG slot to Gen 3 mode. "We are developing a solution to enable full PCIe 4.0 compatibility, but until that is ready, we will update our listings to reflect that only PCIe 3.0 compatibility is guaranteed," the company said in a statement.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ONmhvwPRSZ7dRTMK.jpg" target="_blank" data-width="1024" data-height="768" ><img src="https://tpucdn.com/img/ONmhvwPRSZ7dRTMK_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ICorKItzwoeS7BiW.jpg" target="_blank" data-width="1024" data-height="768" ><img src="https://tpucdn.com/img/ICorKItzwoeS7BiW_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UKS9cQIjnVrovahZ.jpg" target="_blank" data-width="1024" data-height="768" ><img src="https://tpucdn.com/img/UKS9cQIjnVrovahZ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9548azTFceKcjmNS.jpg" target="_blank" data-width="1024" data-height="768" ><img src="https://tpucdn.com/img/9548azTFceKcjmNS_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/D6Y1PzcQVDgo2JVj.jpg" target="_blank" data-width="1024" data-height="768" ><img src="https://tpucdn.com/img/D6Y1PzcQVDgo2JVj_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303760/fractal-ridge-case-pcie-riser-has-trouble-running-in-pcie-gen-4-mode-company-outs-workaround">Read full story</a></div>
