r4920 | landlord | 2011-04-04 22:51:41 +0200 (Mon, 04 Apr 2011) | 1 line
Update documentation for 'port' parameter in 'cs378x' section.
r4919 | landlord | 2011-04-04 22:34:13 +0200 (Mon, 04 Apr 2011) | 1 line
Reviewed 'mgclient' parameter documentation.
Oscam-1.00-svn4927
r4927 | landlord | 2011-04-05 08:35:12 +0200 (Tue, 05 Apr 2011) | 1 line
Added 'suppresscmd08' in txt documentation for camd3 3.5 TCP cs378x, too.
r4926 | landlord | 2011-04-05 08:34:38 +0200 (Tue, 05 Apr 2011) | 1 line
Added 'suppresscmd08' in documentation for camd3 3.5 TCP cs378x, too.
r4925 | landlord | 2011-04-05 08:28:03 +0200 (Tue, 05 Apr 2011) | 1 line
Documentation update for DVB API parameter 'ignore' and 'priority'.
r4924 | alno | 2011-04-05 08:14:49 +0200 (Tue, 05 Apr 2011) | 1 line
Config reading suppresscamd08 in camd35 tcp config
r4923 | landlord | 2011-04-05 08:06:39 +0200 (Tue, 05 Apr 2011) | 1 line
Small documentation updates again.
r4922 | landlord | 2011-04-05 08:05:54 +0200 (Tue, 05 Apr 2011) | 1 line
Small documentation updates.
r4921 | alno | 2011-04-05 07:59:45 +0200 (Tue, 05 Apr 2011) | 1 line
WebIf: re-implement suppresscamd08 in camd35 TCP section
r4929 | hapeba | 2011-04-05 15:57:13 +0200 (Tue, 05 Apr 2011) | 1 line
write "suppresscmd08" (TCP) to config file
r4928 | landlord | 2011-04-05 13:12:02 +0200 (Tue, 05 Apr 2011) | 1 line
Update doc for 'suppresscmd08' enable/disable mismatch.
r4933 | alno | 2011-04-05 22:07:05 +0200 (Tue, 05 Apr 2011) | 1 line
WebIf: fix possible memleak in services parsing
r4932 | alno | 2011-04-05 21:50:30 +0200 (Tue, 05 Apr 2011) | 1 line
Config: fix small issue with default value in account suppresscmd08
r4934 | Admin | 2011-04-06 00:14:04 +0200 (Wed, 06 Apr 2011) | 1 line
Add speaking error messages using strerror() to all errors containing errno.
r4935 | Admin | 2011-04-06 03:38:22 +0200 (Wed, 06 Apr 2011) | 1 line
If the current system time is smaller than (build date - 1 day), OSCam waits up to a minute (in 5s steps) for the time to correct. After that, OSCam starts up with a warning message.
r4936 | landlord | 2011-04-06 08:05:59 +0200 (Wed, 06 Apr 2011) | 1 line
Added documentation for global, UDP and TCP camd3 suppresscmd08 option.
r4937 | schlocke | 2011-04-06 09:11:43 +0200 (Wed, 06 Apr 2011) | 3 lines
fixed memleak in protocol-t1, fixed compile error in oscam-http, added
signal handler for startup
r4938 | schlocke | 2011-04-06 09:38:02 +0200 (Wed, 06 Apr 2011) | 2 lines
reverted protocol_t1 changes
------------------------------------------------------------------------[Only registered and activated users can see links. Click Here To Register...]
r4939 | schlocke | 2011-04-06 10:56:59 +0200 (Wed, 06 Apr 2011) | 2 lines
memleak fixed in protocol_t1
Oscam-1.00-svn4941
r4941 | schlocke | 2011-04-06 14:42:28 +0200 (Wed, 06 Apr 2011) | 2 lines
loadbalancer: added another method for blocking non-responding readers
r4940 | schlocke | 2011-04-06 13:47:14 +0200 (Wed, 06 Apr 2011) | 3 lines
loadbalancer: better blocking of non-responding readers (camd35 udp,
newcamd)
r4942 | schlocke | 2011-04-06 17:28:59 +0200 (Wed, 06 Apr 2011) | 2 lines
loadbalancer: thanks to stesu for another idea to block timeout readers
r4946 | alno | 2011-04-06 20:51:02 +0200 (Wed, 06 Apr 2011) | 1 line
WebIf: link cccam number cards to entitlement of this reader
r4945 | Admin | 2011-04-06 20:41:49 +0200 (Wed, 06 Apr 2011) | 1 line
Fix wrong cw rate shown after user reinit. Futhermore, remove some unnecessary memsets in oscam-config as cs_malloc already takes care of this.
r4948 | schlocke | 2011-04-06 23:28:41 +0200 (Wed, 06 Apr 2011) | 3 lines
loadbalancer option to control early or late reopening of blocker
readers
r4947 | Admin | 2011-04-06 23:26:52 +0200 (Wed, 06 Apr 2011) | 1 line
Implement a safer thread cleanup mechanism: Client and reader threads now call cleanup_thread themselves automatically.
r4951 | schlocke | 2011-04-07 09:21:45 +0200 (Thu, 07 Apr 2011) | 2 lines
fixed new thread cleanup management
r4950 | landlord | 2011-04-07 08:02:45 +0200 (Thu, 07 Apr 2011) | 1 line
Fixed small typo for parameter 'ident' in 'oscam.server'.
Oscam-1.00-svn4956
r4956 | neoen | 2011-04-07 23:43:34 +0200 (Thu, 07 Apr 2011) | 1 line
Fixed syslog parameters
r4955 | schlocke | 2011-04-07 23:29:24 +0200 (Thu, 07 Apr 2011) | 2 lines
cleanup code
r4954 | schlocke | 2011-04-07 23:27:02 +0200 (Thu, 07 Apr 2011) | 2 lines
fixed reader restart
r4953 | Admin | 2011-04-07 21:43:45 +0200 (Thu, 07 Apr 2011) | 1 line
Replace strptime() through own parsing code as strptime() makes problems on systems with broken (or not matching) toolchains
r4952 | schlocke | 2011-04-07 21:41:12 +0200 (Thu, 07 Apr 2011) | 2 lines
fixed memory leak in nagra reader ticket #1750
r4957 | Admin | 2011-04-08 01:20:20 +0200 (Fri, 08 Apr 2011) | 1 line
Fix for #1649: Don't clear aes list on reader thread cleanup anymore.
r4958 | alno | 2011-04-08 01:45:56 +0200 (Fri, 08 Apr 2011) | 1 line
WebIf: related to a suggestion of Vogi (SB) changing behavior of link in status column LB_Value. Before the link clears the stats without feedback. Now the link calls the reader statspage first. In statspage submenu a 'reset stats' link is added
Oscam-1.00-svn4963
r4963 | schlocke | 2011-04-08 20:28:47 +0200 (Fri, 08 Apr 2011) | 2 lines
loadbalancer: another fix: log/save/load
r4962 | schlocke | 2011-04-08 20:23:20 +0200 (Fri, 08 Apr 2011) | 2 lines
loadbalancer: caid-prov-sid-ecmlen handling fixed
r4961 | alno | 2011-04-08 20:09:30 +0200 (Fri, 08 Apr 2011) | 1 line
WebIf: add column in readerstats 'ECM Length'
r4960 | schlocke | 2011-04-08 19:59:54 +0200 (Fri, 08 Apr 2011) | 2 lines
loadbalancer: prepared ecmlen for webif
r4959 | schlocke | 2011-04-08 19:52:20 +0200 (Fri, 08 Apr 2011) | 2 lines
loadbalancer now adds ecmlen to the statistics
