r4888 | Admin | 2011-04-02 15:30:28 +0200 (Sat, 02 Apr 2011) | 1 line
WebIf: Add missing </a>-Tags
r4887 | Admin | 2011-04-02 15:14:51 +0200 (Sat, 02 Apr 2011) | 1 line
WebIf: Use ON/OFF for crypted on status page
Oscam-1.00-svn4891
r4891 | Admin | 2011-04-02 17:50:00 +0200 (Sat, 02 Apr 2011) | 1 line
Re-Add lost [4883] patch
r4890 | Admin | 2011-04-02 17:44:41 +0200 (Sat, 02 Apr 2011) | 1 line
WebIf: Fix some parameters which were saved even if they were default. Update documentation for inactivitytimeout and reconnecttimeout.
r4889 | Admin | 2011-04-02 17:05:51 +0200 (Sat, 02 Apr 2011) | 1 line
WebIf: Let more digits be inserted in aulow-field. Add fix9993 parameter to WebIf and only save it when it differs from default.
Oscam-1.00-svn4895
r4895 | alno | 2011-04-02 21:08:53 +0200 (Sat, 02 Apr 2011) | 2 lines
WebIf: mini fix in embedded CSS style
@Skin Builders: please review your skins and use the additional 3 lines, on end of embedded css, in your skins too. Otherwise optic goes banana
r4894 | Admin | 2011-04-02 20:13:29 +0200 (Sat, 02 Apr 2011) | 1 line
WebIf: Fix duplicating entries in au parameter of users when editing via WebIf
r4893 | Deas | 2011-04-02 20:11:09 +0200 (Sat, 02 Apr 2011) | 1 line
fix compile error #1735
r4892 | Admin | 2011-04-02 19:25:17 +0200 (Sat, 02 Apr 2011) | 2 lines
Big update of oscam-config.c: Extend saving of only the necessary parameters, fully support httpsavefullcfg=1, remove strcpy, use strToIntVal where possible
r4896 | Admin | 2011-04-02 23:26:47 +0200 (Sat, 02 Apr 2011) | 1 line
Replace all occurences of strcpy and sprintf by their safe variants (please report in the forum if anything broke by this revision!). Prevent future usage of these functions through globals.h
r4900 | Admin | 2011-04-03 02:27:39 +0200 (Sun, 03 Apr 2011) | 1 line
Revert r4896 and fix the real issue for stapi: snprintf behaves different than sprintf when it copies a string onto itself.
r4899 | Admin | 2011-04-03 01:27:35 +0200 (Sun, 03 Apr 2011) | 1 line
Fix MacOS redefinition error
r4901 | Admin | 2011-04-03 12:10:28 +0200 (Sun, 03 Apr 2011) | 1 line
WebIf: User status (online/connected) now depends from lastecm/login so that keepalive-packets are not respected anymore. Furthermore, cwrate is now calculated correct (earliest login over all clients/(cwok+cwnot+cwcache)) if the account has multiple connections. Furthermore fix a bug introduced in r4896 preventing cccam ext to work.
r4902 | schlocke | 2011-04-03 15:24:46 +0200 (Sun, 03 Apr 2011) | 3 lines
cccam: removed diagnostic message "client timeout user x", because if
keepalive is active, no disconnect happens
Oscam-1.00-svn4903
r4903 | Admin | 2011-04-03 16:15:58 +0200 (Sun, 03 Apr 2011) | 4 lines
WebIf:
- Show detailed protocol information on users page
- Fix problem with protocol and last channel on users page
- Change behaviour of cwrate: The normal value is time_since_first_login_of_account / (cwok_account+cwnok_account+cwcache_account). If there is an active client ("online"), a second value is shown in brackets which is time_since_login_of_active_client / (cwok_act_client+cwnok_act_client+cwcache_act_client).
r4906 | neoen | 2011-04-03 18:35:02 +0200 (Sun, 03 Apr 2011) | 1 line
small fix to [#r4904]
r4905 | schlocke | 2011-04-03 18:05:13 +0200 (Sun, 03 Apr 2011) | 2 lines
added some code to avoid segfaults
Oscam-1.00-svn4907
r4907 | schlocke | 2011-04-03 20:38:23 +0200 (Sun, 03 Apr 2011) | 2 lines
fixed segfault with monitor and threads/saving loadbalancer stats
Oscam-1.00-svn4909
r4908 | schlocke | 2011-04-04 09:12:54 +0200 (Mon, 04 Apr 2011) | 2 lines
LLIST: added more locks to get threadsafer
r4909 | landlord | 2011-04-04 11:31:52 +0200 (Mon, 04 Apr 2011) | 1 line
Checked README.
Oscam-1.00-svn4911
r4911 | Deas | 2011-04-04 18:23:08 +0200 (Mon, 04 Apr 2011) | 1 line
web-if: small modification to r4910 - better handling and avoid error message on console if parameter is empty. change suggested by Alno.
r4910 | Deas | 2011-04-04 17:55:20 +0200 (Mon, 04 Apr 2011) | 1 line
web-if: set au parameter only when a value is set. removes "au=" from config when saving. change suggested------------------------------------------------------------------------
r4916 | Admin | 2011-04-04 20:40:40 +0200 (Mon, 04 Apr 2011) | 1 line
WebIf: Try to show number of cards for CCCam readers on status page. Please test and report in the forum as I don't have CCCam readers.
r4915 | Admin | 2011-04-04 19:39:24 +0200 (Mon, 04 Apr 2011) | 1 line
Fix for last commit...
Oscam-1.00-svn4918
r4918 | landlord | 2011-04-04 21:51:34 +0200 (Mon, 04 Apr 2011) | 1 line
Updated some camd3 txt documentation now, too.
r4917 | landlord | 2011-04-04 21:50:16 +0200 (Mon, 04 Apr 2011) | 1 line
Updated some camd3 documentation.
r4919 | landlord | 2011-04-04 22:34:13 +0200 (Mon, 04 Apr 2011) | 1 line
Reviewed 'mgclient' parameter documentation.
