cu ocazia asta ai alt ban pentru clona!Quote:
Originally Posted by dreambox80 [Only registered and activated users can see links. Click Here To Register...]
blocarea in faza de reboot am intilnit-o si eu si este oarecum aleatoare ( functie de versiunea gemini )
off
@dreambox80 nu este clona , @instalatorul nu cred ca mai este activ
am instalat-o cu dreamup, i-am dat erase flash si apoi flash
apoi am pus cccam 2.1.3 si cccam.cfg. numai atat, am incercat de cateva ori si de fiecare data la fel, nu o sa mai dau reboot si nu sunt probleme.
Gemini 4.70 DM500 Maxvar CCcam 2.1.4 vali II non time bomb by Borsalino
NOVEDADES:
Cita:
-this image non time bomb (tested 100/100 in my clone)
-Valid image of the original and clone dream 500s
- bootlogo (hd)
-You can check program : dm500_clone_bomb_checker_v1[1].0
-Emu: CCcam 2.1.4 inside (start with image..in blue panel withe volume button for the built-Emu )
-supported viaccess 2.6
-open all channel ...... 2.6 incluido los arabes
-please send Cccam.cfg in var/etc withe ftp
-add CCcaminfo v 1.1
-add ecminfo
-add grab recording
-update teletext ok
-add Vali IIskns update
-add of ............ 2.6 all channel ok
-add ....biss channelle
-longage english & franch in demarage
-Now you can change the form of a channel presntation withe button help
- add new server addons Borsalino
-scereenshote fixed inside grabe in image
-add option DVR withe help botton
-big var naw 83% Free espace withe cccam 2.1.4
-option pvr ok withe this modifecation image
-add grab inside in image ok screenshot fixed
-Fast image to open channels with Cccam2.1.4
-send this image withe dreamup or falshwizare
din pacate si la imaginea asta apare problema cu decalajul in minus cu 2 a orei
@marcghi,problema cu reboot-ul e de la sursa de alimentare.
imaginile max var sunt de teste
nu sunt de recomandat pentru utilizarea decat pentru a descoperii minusuri
pe langa faza cu ora nu are nici webIF corect , nu aparea telecomanda ...remote control nu se incarca corect
se bloca cand vroiam sa schimb din blue panelversiunea de cccam
MaxVAR nu sint imagini de teste.
MaxVAR sint imagini care nu au pluginuri pe care nu le poti dezinstala.
Sint imagini exceptionale, doar maxvar folosesc, intr-adevar cea prezentata de tine cred ca are acele probleme apar. E vorba de o imagine Borsalino, si eu am testat cateva dar am renuntat complet la imaginiile ui, care sint extrem de aspectuase, au spatiu in var, ca scoate tot ce apuca din imagini, de multe ori si ce nu trebuie.
Incearca o imagine originala, descarcata de pe site-ul producatorului (producatorul imaginii !) si ai sa vezi imaginiile MaxVAR cat de stabile sint, si fara bug-uri.
Eu recomand Pli Jade 3 MaxVAR [Only registered and activated users can see links. Click Here To Register...], o imagine care mi-a mers la suflet sau de ce nu GP 4.6, dar asta trebuie instalata cu deosebita atentie la adresa MAC a receptorului, poate provoca surprize neplacute.
Bafta !
am incercat cu alta sursa de 2A si ramane aceiasi problema, cred ca din imagine e ceva in neregula.Quote:
Originally Posted by daradici [Only registered and activated users can see links. Click Here To Register...]
sunt imagini de teste Levy
tocmai asta e vorba , sa testeze userii anumite lucruri pe ele
si apoi apare oficial imaginea mai buna fara problemele aparute
am pus si eu 4.70 dar avea o multime de probleme fata de 4.60
maxvar -ul asta e curatit de multe lucruri utile si de aici apar problemele... un exemplu la imaginea asta maxvar a lui Borsalino ccam 2.1.4 pornea din bin direct nu din /var/bin...deci este un test , nu? sa ne arate ca cccam-ul merge si direct din bin fara a fi pus in var/bin dar iti spun ca se bloca cccam-ul si era mai bine sa iti instalezi cccam-ul manual nu sa fie direct in imagine
MaxVAR=spatiu maxim posibil in /var
adica imaginea nu are si alte tampenii pe care nu le poti dezinstala, care ti se incarca automat cand ai incarcat imaginea pe receptor.
Folosesc intotdeauna doar MAXVAR, ca oricum dm 500 are spatiul destul de limitat in VAR, atunci de ce sa nu incarc doar ce vreau in acest spatiu, care si asa este asa de mic ???
Imaginile care nu sint MaxVAR au de obicei 1.8 MB spatiu liber in var dupa instalarea imaginii, cele MaxVAR au de regula 2.8 MB. Diferenta este de 1 MB doar insa la o cantitate asa de mica de spatiu conteaza si acel MB. Nu e 1.8 este 2.8.
Cele Borsalino sint imagini MaxVAR, din care tipu' scoate tot ce vrea muschiul lui, si face o imagine mai maxvar decat orice MaxVAR original, dar si plin de BUG-uri, am testat cateva imagini facute de el, dar prefer cele de la producator. Oricine poate sa schimbe imaginea de Boot sau minunile pe care le face. In plus instaleaza emulatoarele intotdeauna in asa fel incat nu poti pune o alta versiune, sau nu poti folosi un alt limbaj la meniu sau teletext la unele. Cred ca astea sint cerinte minime de la o imagine si nu e normal sa renunti la ele pentru a mari spatiul.
Parerea mea este ca imaginile de pe paginile producatorilor de imagini intotdeauna sint mai bune decat cele in care umbla diversi specialisti.
:cheers:
testat 4.70 aproape 3 saptamani mult mai fiabila si stabila(parerea mea)nu am observat sa aiba prosti mai multe decat 4.60 zic eu e la fel,sa umblat un pic cred la "culori" atat la meniu cat si la redarea programelor,sant mai vi,mai colorate(poate mi se pare mie)se misca mai bine cu h-h(asta era lucru ce ma durea cel mai tare la 4.60)asta am observat eu,detalii tehnice si dedesubturi nu le cunosc destul de bine:)
maxvar din cate stiu eu e o imagine cu varu marit,nu este o imagine de test.sant doua variante,maxvar si imaginea propriuzisa,o instalezi pe care vrei doar ca maxvar iti mai permite sa mai pui una alta
pai horatiu e normal sa ai buguri si probleme daca pui tot felu de imagini busite de sadam,berlusconi si care naiba or mai fi
pune tu un maxvar facut de gemini si parerea ta se va schimba(cred):)
Va salut pe toti.Quote:
Sunt posesor DM500 clona, gata configurat diji. Inainte de a face pasul la cartela am hotarat sa testez inainte. Acum am Boom cu 3 receivere si nu sunt multumit deloc (scump, programe neinteresante, putine, receiver neversatil...etc)
Acum, cu speranta ca nu voi deranja pe cineva, am cateva intrebari.
Incep prin a te cita si te intreb : Sunt intru totul de acord ca nu are rost sa incarcam imaginea cu programe care sa "streseze" aparatul, dar de ce majoritatea utilizatorilor folosesc GP?
Daca ma conectez prin interfata web la aparat si butonez putin prin setari, volum etc. aparatul nu mai raspunde la telecomanda (nu intotdeauna) si sunt nevoit sa-l rebootez.
Acuma, avand aparatul configurat, nu vreau sa umblu la ce nu stiu, dar in primul moment cand se vor schimba "key-le" voi testa si eu diverse.
Desi am citit prin forum foarte mult, totusi nu inteleg foarte bine pasii care trebuie urmati.
Mi-am facut cablu serial si am salvat imaginea actuala din dream.
Am inteles ca ridic imaginea noua pe dream, fac setarile din aparat (cele uzuale).
Urmeaza partea cu key-le, programele necesare la care nu am gasit raspuns pas cu pas. Sa va dau un exemplu: As vrea sa ma pun pe un alt satelit decat thor. De ce as avea nevoie? Ce se poate receptiona fara card in afara de diji si "free to air" si ce softuri aferente sunt necesare?
Ar mai fi destule intrebari, dar , pentru moment, as fi fericit daca m-ati putea lumina cu cele ce am intrebat mai sus.
Va multumesc, si nu uitati ca nimeni nu s-a nascut invatat. Incercati sa fiti toleranti, daca puteti.
Despre asta vorbeam si eu !Quote:
Imagine facuta de producatori, nu de amatori !
Cea mai buna imagine gemini "prelucrata" este [Only registered and activated users can see links. Click Here To Register...]
confirm ... am folosit cel putin un am gp4.6 drhg si nu am avut probleme pe o clona
Ai aici [Only registered and activated users can see links. Click Here To Register...] tutorial.Ai aici [Only registered and activated users can see links. Click Here To Register...] liste cu sateliti/frecvente/programe si pe 1W poti vedea astea [Only registered and activated users can see links. Click Here To Register...] ,cele cu galben sunt FTA.Scanarea pe receptor e explicata in manualul lui.Alte intrebarile te rog sa le pui intr-un topic nou,il poti dechide la Coltul Pufanului.Quote:
Originally Posted by LUC1K [Only registered and activated users can see links. Click Here To Register...]
am patit si eu faza asta , dar de cand am trecut la imaginea sif nu am mai avut problema astaQuote:
Originally Posted by marcghi [Only registered and activated users can see links. Click Here To Register...]
PS: eu am o clona cumparata de la elstar oradea
La Gemini 4.70 DM500 Maxvar CCcam 2.1.4 vali II non time bomb by Borsalino
Doua limbi sint instalate engleza si franceza, te lasa sa instalezi si alta limba dar nu functioneaza.
la imaginile prelucrate nu poti sa faci mare branza,o iei asa cum e:)
