r3606 | rorothetroll | 2010-10-17 19:26:33 -0700 (Sun, 17 Oct 2010) | 1 line
fix a typo in a debug message
r3605 | rorothetroll | 2010-10-17 19:21:32 -0700 (Sun, 17 Oct 2010) | 1 line
added oscam-datastruct-llist.[c,h] to XCode project for OS X
r3604 | rebdog | 2010-10-17 17:07:47 -0700 (Sun, 17 Oct 2010) | 1 line
add a few new atrs, closes #751
r3610 | merek | 2010-10-18 02:44:17 -0700 (Mon, 18 Oct 2010) | 1 line
Fix Maketype
r3609 | merek | 2010-10-18 02:42:56 -0700 (Mon, 18 Oct 2010) | 1 line
Rename datastruct-llist, as CMakeFile includes module-* as csmodules
r3608 | _network | 2010-10-18 02:01:21 -0700 (Mon, 18 Oct 2010) | 2 lines
dvbapi: fix #1084
Oscam-1.00-svn3615
Changeset #3611
Message: ll_iter_peek()
Changeset #3612
Message: fix for cccam: next_card
Changeset #3613
Message: fixed segfault in ll_insert_at()
Changeset #3614
Message: unlimited readers step 11: replace client->ridx by client->reader
Changeset #3615
Message: reader-nagra.c : remove duplication of code, switch keynr 01 and 00 for NA
Oscam-1.00-svn3619
Changeset #3616
Message: cccam: fixed version overflow
Changeset #3617
Message: WebIf: fixed reader re-start from webif side. Attention the reader becomes restarted but becomes doubled in reader list. This have to be fixed in void restart_cardreader(struct s_reader *rdr, int restart) the killed reader must removed from readerlist.
Because dingo restructures the readers this moment I'll don't touch his code to avoid conflicts
Changeset #3618
Message: fix write_server() removing protocol from disabled reader
Changeset #3619
Message: fix for last commit
r3624 | rorothetroll | 2010-10-18 14:50:39 -0700 (Mon, 18 Oct 2010) | 1 line
fixing a small typo in the list_smargo message
r3623 | rorothetroll | 2010-10-18 14:46:14 -0700 (Mon, 18 Oct 2010) | 1 line
path for list_smargo. you can now pass an out endpoint value : list_smargo 0x81 . If no value is passed, it'll use the default 0x82 out endpoint address
r3622 | rorothetroll | 2010-10-18 14:24:43 -0700 (Mon, 18 Oct 2010) | 1 line
more fix for smartreader code for Infinity smart usb on windows
r3629 | dingo35 | 2010-10-19 05:53:47 -0700 (Tue, 19 Oct 2010) | 1 line
reader-nagra.c : Add 0x29 command for N3_NA
r3628 | dingo35 | 2010-10-19 01:11:52 -0700 (Tue, 19 Oct 2010) | 1 line
reader-nagra.c: Add do_ecm for N3_NA
Oscam-1.00-svn3633
Changeset #3630
Message: fixed (t1094) - no LB statistics in Reader-Section of WebIf
Changeset #3631
Message: fixed loadbalancer, fixed cccam
Changeset #3632
Message: named trunk versions as unstable - remove before release
Changeset #3633
Message: fix newcamd crash #1101
r3640 | rorothetroll | 2010-10-19 16:41:29 -0700 (Tue, 19 Oct 2010) | 2 lines
some viaccess emm processing changes. Patch provided by Hot. Tested by him and working on his card.
r3639 | alno | 2010-10-19 14:46:21 -0700 (Tue, 19 Oct 2010) | 1 line
WebIf: removed last reader[ridx] fragments from http.c
r3641 | dingo35 | 2010-10-20 02:35:26 -0700 (Wed, 20 Oct 2010) | 1 line
reader-nagra.c : simplify N3 code
Oscam-1.00-svn3642
Changeset #3642
Message: fix for ticket 1114
Oscam-1.00-svn3643
Changeset #3642
Message: WebIf: fix segfault on saving reader config
Oscam-1.00-svn3647
Changeset #3644
Message: try to solve the auprovid problem for cw emm
Changeset #3645
Message: Removed 'pidfile' from doc and examples.
Changeset #3646
Message: Added documentation for 'oscam.dvbapi'.
Changeset #3647
Message: Added documentation for list_smargo parameter 'endpoint address'.
r3649 | landlord | 2010-10-20 23:11:19 -0700 (Wed, 20 Oct 2010) | 1 line
Documentation update for 'oscam.dvbapi' priority.
r3648 | alno | 2010-10-20 15:52:27 -0700 (Wed, 20 Oct 2010) | 1 line
WebIf: try fix 'protocol' in status - untested I don't have cccam connections
r3659 | dingo35 | 2010-10-21 05:57:58 -0700 (Thu, 21 Oct 2010) | 1 line
Turn acocunt->au from index to pointer aureader
r3658 | dingo35 | 2010-10-21 04:56:25 -0700 (Thu, 21 Oct 2010) | 1 line
oscam-config.c : remote some reader[] statements
Oscam-1.00-svn3665
Changeset #3660
Message: Move s_ecm reader from index to pointer
Changeset #3661
Message: cccam: fixed segfaults
webif: fixed segfaults
tcp-connect now has an incrementing delay to avoid getting blocked by os
or remote server
Changeset #3662
Message: Revert 3660 this was a bad idea
Changeset #3663
Message: increase emmcache
Changeset #3664
Message: oscam-http.c: Fix account->au
Changeset #3665
Message: monitor: fix possible segfault
Oscam-1.00-svn3669
Changeset #3666
Message: put the call to pthread_attr_setstacksize in an ifdef as it's not define in the dreambox glibc-2.3.90, even though it's supposed to be available after glibc-2.3.3
Changeset #3667
Message: WebIf: re- enable Add Reader functionality
Changeset #3668
Message: cccam: changed some emm handling
Changeset #3669
Message: WebIf: some cleanup
r3670 | rorothetroll | 2010-10-21 16:35:01 -0700 (Thu, 21 Oct 2010) | 1 line
fix a bus error/segfault on newcamd disconnect when it tries to close the connection but the cl->reader is already null and it receives a network messages (message was probably in the queue and get processed after the connection is actually close).
r3669 | alno | 2010-10-21 13:51:42 -0700 (Thu, 21 Oct 2010) | 1 line
WebIf: some cleanup
r3672 | _network | 2010-10-22 05:47:35 -0700 (Fri, 22 Oct 2010) | 2 lines
try to fix seca shared emm filter
r3671 | schlocke | 2010-10-22 03:30:57 -0700 (Fri, 22 Oct 2010) | 3 lines
fix for "failban not closing sockets"
Oscam-1.00-svn3673
Changeset #3673
Message: detect type of camd3 cryptoworks emm
Oscam-1.00-svn3676
Changeset #3674
Message: WebIf: some completition of cccam parameters
Changeset #3675
Message: WebIf: fix last commit
Changeset #3676
Message: WebIf: remove reshare from reader (is a user setting)
