Am incercat urmatorul MKV si nu merge:
Foloseste media info si vezi diferenta intre MKV care merg si cele care nu. Ar putea fi un bitrate, aplicatia folosita pentru codare sau orice alt motiv.Quote:
General
Unique ID : 244389078888695323520809602619520669828 (0xB7DB9FDFF8E5339F8C5442153FC15884)
Complete name :Cool It [2010].mkv
Format : Matroska
File size : 977 MiB
Duration : 1h 28mn
Overall bit rate : 1 550 Kbps
Encoded date : UTC 2011-05-28 15:29:12
Writing application : mkvmerge v4.5.0 ('Speed of Light') built on Feb 1 2011 02:10:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 28mn
Bit rate : 1 100 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.106
Stream size : 675 MiB (69%)
Writing library : x264 core 114
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x113 / me=esa / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=20 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1100 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 28mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 282 MiB (29%)
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Text #2
Format : UTF-8
Language : Spanish
Menu
00:00:00.000 : en:Chapter 01
00:10:15.815 : en:Chapter 02
00:19:10.149 : en:Chapter 03
00:30:50.882 : en:Chapter 04
00:40:31.262 : en:Chapter 05
00:50:22.919 : en:Chapter 06
00:58:29.205 : en:Chapter 07
01:04:54.257 : en:Chapter 08
01:12:24.073 : en:Chapter 09
01:16:08.030 : en:Chapter 10
01:21:02.157 : en:Chapter 11
01:24:41.076 : en:Chapter 12
