(PR) EK Launches NVIDIA RTX A5000 Graphics Card Water Blocks
EK, the leading computer cooling solutions provider, is now offering an enterprise-grade GPU water block for NVIDIA GeForce RTX A5000 graphics cards. This new water block incorporates a CNC-machined nickel-plated copper base with a laser-cut stainless-steel top for a robust metal cooling solution, effectively making it a single-slot assembly. The EK-Pro Rack GPU water blocks fit the standard Full Height Full Width (FHFW) server chassis form factor, making them a drop-in replacement for dual-slot active and passive air coolers. EK-Pro GPU WB RTX A5000 - Nickel + Inox Rack water block is purpose-designed for the RTX A5000 graphics cards. This water block directly cools the GPU, VRAM, and VRM (voltage regulation module) as the cooling liquid is channeled right over these critical areas.<br />
<br />
The solution uses an Open Split-Flow cooling engine design that proved to be a superior solution for GPU water blocks. It is characterized by low hydraulic flow restriction, which means it can be used with weaker water pumps or pumps running on low-speed settings and still achieve top performance. The lowered coolant flow requirement makes it an ideal solution for multi-GPU workstations. The jet plate and fin structure geometry have been optimized to provide consistent flow distribution with minimal losses and optimal performances, even when used in reversed water flow scenarios.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/HJYl6K1gZEyS4oRC.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/HJYl6K1gZEyS4oRC_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vPstDNdTzetkxdKU.jpg" target="_blank" data-width="1200" data-height="676" ><img src="https://tpucdn.com/img/vPstDNdTzetkxdKU_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TTus3ezgDUHBcuYR.jpg" target="_blank" data-width="1200" data-height="676" ><img src="https://tpucdn.com/img/TTus3ezgDUHBcuYR_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DYyaIryQqxQOd5H0.jpg" target="_blank" data-width="1600" data-height="1067" ><img src="https://tpucdn.com/img/DYyaIryQqxQOd5H0_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301606/ek-launches-nvidia-rtx-a5000-graphics-card-water-blocks">Read full story</a></div>
AMD RDNA3 Second-largest Navi 32 and Third-largest Navi 33 Shader Counts Leaked
The unified shader (stream processor) counts of AMD's upcoming second- and third-largest GPUs based on the RDNA3 graphics architecture, have been leaked in some ROCm code, discovered by Kepler_L2 on Twitter. The "performance.hpp" file references "Navi 32" with a compute unit count of 60, and the "Navi 33" with 32 compute units. We know from the "Navi 31" specifications that an RDNA3 compute unit still amounts to 64 stream processors (although with significant IPC uplifts over the RDNA2 stream processor due to dual-instruction issue-rate).<br />
<br />
60 compute units would give the "Navi 32" silicon a stream processor count of 3,840, a 50% numerical increase over the 2,560 of its predecessor, the "Navi 22," powering graphics cards such as the Radeon RX 6750 XT. Meanwhile, the 32 CU count of the "Navi 33" amounts to 2,048 stream processors, which is numerically unchanged from that of the "Navi 23" powering the RX 6650 XT. The new RDNA3 compute unit has significant changes over RDNA2, besides the dual-issue stream processors—it gets second-generation Ray Accelerators, and two AI accelerators for matrix-multiplication.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vF3gQkIZeGNWMbtv.jpg" target="_blank" data-width="708" data-height="344" ><img src="https://tpucdn.com/img/vF3gQkIZeGNWMbtv_thm.jpg" width="268" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8QLK1QcCEYKX4m0L.jpg" target="_blank" data-width="1634" data-height="921" ><img src="https://tpucdn.com/img/8QLK1QcCEYKX4m0L_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HMWTzySjyNym2kye.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/HMWTzySjyNym2kye_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BktVJXjIoDtkRM4J.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/BktVJXjIoDtkRM4J_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301604/amd-rdna3-second-largest-navi-32-and-third-largest-navi-33-shader-counts-leaked">Read full story</a></div>
(PR) Phison Enterprise PCIe 4.0 X1 SSD Solution Received 2023 Taiwan Excellence Award
Phison Electronics Corp., a global leader in NAND flash controller and storage solutions, announced that its latest flagship enterprise PCIe 4.0 X1 SSD solution, which was developed in partnership with Seagate was awarded the 2023 Taiwan Excellence Award. "We are very pleased that Phison's enterprise PCIe 4.0 X1 SSD solution has received this honor," said K.S. Pua, CEO or Phison. "For Taiwanese products, the mark of Taiwan Excellence is associated with innovative values that are renowned in the international market for excellence and quality."<br />
<br />
The Taiwan Excellence Awards were established by the Ministry of Economic Affairs of Taiwan in 1993. Every year, eligible candidates are subjected to a rigorous and stringent selection system that covers four major aspects of R&D, Design, Quality, and Marketing to identify outstanding products that offer "Innovative Value" while satisfying the key criterion of being "made in Taiwan." Products that have been selected for the Taiwan Excellence Awards will serve as domestic industry examples while being promoted by the government in the international market to shape the creative image for Taiwanese businesses.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YsGwMZG3DaEVjFLl.jpg" target="_blank" data-width="1536" data-height="960" ><img src="https://tpucdn.com/img/YsGwMZG3DaEVjFLl_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301594/phison-enterprise-pcie-4-0-x1-ssd-solution-received-2023-taiwan-excellence-award">Read full story</a></div>
(PR) SMART Modular Technologies Launches New Family of Data Center Solid State Drives
SMART Modular Technologies, Inc. ("SMART"), a division of SGH and a global leader in memory solutions, solid-state drives and hybrid storage products announces that it is now offering a new class of high performance, power efficient, data center solid state disk drives (SSDs) beginning with the DC4800 PCIe Gen 4 family. <br />
<br />
SMART's DC4800 devices are designed with a specialized hardware-accelerated SSD controller that draws less power without compromising storage input/output (I/O) performance. Zero-induced throttling allows these SSDs to perform better under continued duress, even when they are pushed to their performance limit. This translates to significant power consumption improvement per server, as well as consistent latency performance of up to 7-nines or 99.99999% of the time.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/omSAD5h4UCtSNG2e.jpg" target="_blank" data-width="1042" data-height="626" ><img src="https://tpucdn.com/img/omSAD5h4UCtSNG2e_thm.jpg" width="216" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301593/smart-modular-technologies-launches-new-family-of-data-center-solid-state-drives">Read full story</a></div>
(PR) BBT.live Software-defined Connectivity to Accelerate Secure Access Service Edge Transformation with NVIDIA BlueField DPU Platforms
BBT.live, the Tel Aviv-based startup that has developed an all-in-one, tech-agnostic, software-defined connectivity solution, has announced a new technology innovation powered by NVIDIA. As a result, BBT.live, the software-defined connectivity platform, will run on NVIDIA BlueField data processing units (DPUs) to unlock the benefits of cloud-based connectivity solutions to businesses at every scale.<br />
<br />
Modern workloads are experiencing an ever-growing need for network efficiency, privacy, and security. Businesses and enterprises that depend on solutions require additional hardware and integration, which introduces additional complexity and points of failure. BBT.live's proprietary technology, recognized by the Israel Innovation Authority, is device agnostic. It integrates with a variety of different hardware platforms (uCPE) without the need for time-consuming customization.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/iCsW5XfcIFp3kpbF.jpg" target="_blank" data-width="1140" data-height="673" ><img src="https://tpucdn.com/img/iCsW5XfcIFp3kpbF_thm.jpg" width="220" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301592/bbt-live-software-defined-connectivity-to-accelerate-secure-access-service-edge-transformation-with-nvidia-bluefield-dpu-platforms">Read full story</a></div>
AWS Updates Custom CPU Offerings with Graviton3E for HPC Workloads
Amazon Web Services (AWS) cloud division is extensively developing custom Arm-based CPU solutions to suit its enterprise clients and is releasing new iterations of the Graviton series. Today, during the company re:Invent week, we are getting a new CPU custom-tailored to high-performance computing (HPC) workloads called Graviton3E. Given that HPC workloads require higher bandwidth, wider datapaths, and data types span in multiple dimensions, AWS redesigned the Graviton3 processor and enhanced it with new vector processing capabilities with a new name—Graviton3E. This CPU is promised to offer up to 35% higher performance in workloads that depend on heavy vector processing.<br />
<br />
With the rising popularity of HPC in the cloud, AWS sees a significant market opportunity and is trying to capture it. Available in the AWS EC2 instance types, this chip will be available with up to 64 vCPU cores and 128 GiB of memory. The supported EC2 tiers that will offer this enhanced chip are C7gn and Hpc7g instances that provide 200 Gbps of dedicated network bandwidth that is optimized for traffic between instances in the same VPC. In addition, Intel-based R7iz instances are available for HPC users in the cloud, now powered by 4th generation Xeon Scalable processors codenamed Sapphire Rapids.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6sC1FoMWkL9b2lxc.jpg" target="_blank" data-width="1276" data-height="960" ><img src="https://tpucdn.com/img/6sC1FoMWkL9b2lxc_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) The Dragon Isles Have Awakened—World of Warcraft: Dragonflight is Now Live
World of Warcraft : Dragonflight, the ninth expansion to Blizzard Entertainment's critically acclaimed massively multiplayer online role-playing game, is now live! Heroes of the Horde and Alliance are called back to Azeroth to explore the mystical Dragon Isles and its ancient secrets, where the dragon aspects have returned to reclaim their kingdom and ancestral home.<br />
<br />
"Dragonflight goes to the heart of what players have always loved about World of Warcraft—exploration, customization, and the feeling of wonder as the world and its stories unfold," said Mike Ybarra, president of Blizzard Entertainment. "The updates to core systems, such as the new talent trees, build on the legacy of WoW for players of all types, allowing old friends and new to enjoy everything Azeroth has to offer for years to come."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/1QApAZk4yRST5NJF.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/1QApAZk4yRST5NJF_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FueJUjTRm1MkPv4t.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/FueJUjTRm1MkPv4t_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rjDPIcTxJLZSDiii.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/rjDPIcTxJLZSDiii_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/q3ccGMB0ftXOsTdc.jpg" target="_blank" data-width="1555" data-height="960" ><img src="https://tpucdn.com/img/q3ccGMB0ftXOsTdc_thm.jpg" width="211" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301582/the-dragon-isles-have-awakened-world-of-warcraft-dragonflight-is-now-live">Read full story</a></div>
$700-800 Ideal Price for GeForce RTX 4080: TechPowerUp Poll Surveying 11,000 Respondents
The ideal price for the NVIDIA GeForce RTX 4080 "Ada" graphics card is around USD $700 to $800, according to results from a recent TechPowerUp Front-page poll surveying our readers. Our poll "How much would you pay for RTX 4080 at most?" received over 11,000 responses. At the number 1 spot with 22% of the vote is $800, closely followed by $700. Together, this range represents 44% of the voters. 14% of our readers think $600 is an ideal price, followed by "less than $400" at 13%. 9% think $500 seems fair, followed by 7% willing to spend as much as $900. 5% is happy to spend $1,100. 2% or less feel that the current $1,200 MSRP is justified or are willing to spend more than MSRP. There's more to a majority finding sanity with the $700 to $800 price-range.<br />
<br />
With NVIDIA cancelling the RTX 4080 12 GB, the RTX 4080 16 GB became the only SKU to bear the name "RTX 4080." This $1,200 MSRP GeForce RTX 4080 is the successor to the RTX 3080, which debuted at $700, marking a $500 MSRP increase generation-over-generation (or +71%). You begin to see why most readers prefer the $700-800 range to be the ideal MSRP, and are willing to tolerate a $100 increase. For even more context, the RTX 3080 "Ampere" launched at the same $700 MSRP that its successor, the RTX 2080 "Turing" launched at. The GTX 1080 "Pascal" came out at $600 ($700 for the Founders Edition), which explains the interest for $600 in our poll.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wTADs69H79wOezA0.jpg" target="_blank" data-width="916" data-height="449" ><img src="https://tpucdn.com/img/wTADs69H79wOezA0_thm.jpg" width="265" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301539/usd-700-800-ideal-price-for-geforce-rtx-4080-techpowerup-poll-surveying-11-000-respondents">Read full story</a></div>
(PR) Sharkoon Unveils RGB Wave Case
Sharkoon Technologies, an international supplier of high-performance, high-quality PC components and peripherals, is expanding its range of cases with the launch of the RGB Wave. This midi-ATX case gives current hardware components a framework that is both efficient and extraordinary thanks to four pre-installed fans and an air-permeable front panel with a 3D wave design. <br />
<br />
At the heart of the design concept of the RGB Wave is the front panel. This has a series of undulating wave-like strips in front of an air-permeable mesh and set within a carbon-fiber textured frame. It is complemented by a side panel made of tempered glass, through which the built-in hardware can be admired. To visually round things off, three 120-millimeter fans with addressable RGB illumination are installed behind the front panel to accentuate the wave design and the installed hardware with up to 16.3 million colors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ROzrcHyCkU7NM2jk.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/ROzrcHyCkU7NM2jk_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VLvyCnHJ380s9PoM.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/VLvyCnHJ380s9PoM_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7M6dah2VfGHBkXm8.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/7M6dah2VfGHBkXm8_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FGzXcLqP07O6wYen.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/FGzXcLqP07O6wYen_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/s7TbgnHsF7UCs5E1.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/s7TbgnHsF7UCs5E1_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301576/sharkoon-unveils-rgb-wave-case">Read full story</a></div>
(PR) Samsung Develops GDDR6W Memory Standard: Double the Bandwidth and Density of GDDR6 Through Packaging Innovations
As advanced graphics and display technologies develop, they are blurring the lines between metaverse and our everyday experience. Much of this important shift is being made possible by the advancement of memory solutions designed for graphics products. One of the biggest challenges for improving virtual reality is taking the complexities of real-world objects and environments and recreating them in a virtual space. Doing so requires massive memory and increased computing power. At the same time, the benefits of creating more true-to-life metaverse will be far reaching, including real-life simulations of complicated scenarios and more, sparking innovation across a number of industries. <br />
<br />
This is the central idea behind one of the most popular concepts in virtual reality: digital twin. A digital twin is a virtual representation of an object or space. Updated in real-time in accordance with the actual environment, a digital twin spans the lifecycle of its source and uses simulation, machine learning and reasoning to help decision-making. While until recently this was not feasible proposition due to limitations on data processing and transference, digital twins are now gaining traction thanks to availability of high bandwidth technologies.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/rRESd8rLILqMZ9yp.jpg" target="_blank" data-width="801" data-height="457" ><img src="https://tpucdn.com/img/rRESd8rLILqMZ9yp_thm.jpg" width="228" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cjEF80Ix2IB3F6xW.jpg" target="_blank" data-width="2059" data-height="1153" ><img src="https://tpucdn.com/img/cjEF80Ix2IB3F6xW_thm.jpg" width="232" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wbViJCsDrEfZE48O.jpg" target="_blank" data-width="3260" data-height="1153" ><img src="https://tpucdn.com/img/wbViJCsDrEfZE48O_thm.jpg" width="368" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301573/samsung-develops-gddr6w-memory-standard-double-the-bandwidth-and-density-of-gddr6-through-packaging-innovations">Read full story</a></div>
(PR) GIGABYTE Brings Raptor Lake "Instant 6 GHz" Auto-OC Feature to its Intel Z690 Motherboards
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of motherboards, graphics cards, and hardware solutions, today announced to extend the instant 6 GHz technology designed for Intel Core i9-13900K and Core i7-13700K processors to the Z690 platform. By simply upgrading the latest BIOS of Z690 motherboards and activating the relevant settings, users can optimize their Intel Core i9-13900K and Core i7-13700K processors to 6 GHz for the performance boost on single-core up to 3%. This enables users who stay with the existing Z690 platform can enjoy the performance enhancement of the new CPU as well.<br />
<br />
The latest Intel 13th gen processor has impressed users with its class-leading performance. GIGABYTE's Instant 6 GHz on the Z790 platform was renowned for unleashing the performance of Intel Core i9-13900K and Core i7-13700K processors for users in an easier way and is now employed on the Z690 platform. By simply upgrading the latest BIOS with Instant 6 GHz activated, the system can automatically tweak CPU voltage and Vcore Load Line Calibration of Intel Core i9-13900K and Core i7-13700K processors to detect the most two optimized cores running at 6 GHz frequency. This further delivers a 3% performance boost on one single core like the Z790 platform.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wBl2cRWTLMv36CTW.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/wBl2cRWTLMv36CTW_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301571/gigabyte-brings-raptor-lake-instant-6-ghz-auto-oc-feature-to-its-intel-z690-motherboards">Read full story</a></div>
(PR) OddBallers Launches on the 26th of January 2023
OddBallers, the new multiplayer party game, releases on January 26 for Switch, Xbox One, PS4, and PC, as well as Xbox Series X|S and PS5 via backwards compatibility. A new type of dodgeball game, players in Oddballers can throw anything and everything at their opponents to win - the more absurd, the better. With many different arenas, a variety of mini-games, and perilous environments that include electric fences, explosive gas tanks, and tennis ball launchers, OddBallers provides a fresh experience with every match.<br />
<br />
Up to six players can compete locally on the Switch, and up to four players on other platforms. For long-distance competitions, dodgeballers can also play OddBallers online, taking on opponents around the world. Each match also comes with customizable accessibility features, allowing players to adjust match length and difficulty. Players can also customize their avatar, celebratory dance moves, and choose which mini-game to play thanks to OddBaller's custom mode. You can pre-order OddBallers today, and be sure to challenge your friends and family to some goofy dodgeball when the game releases on January 26, and stay tuned to Ubisoft News for more updates.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/a22QNjZFcPLm0Xtg.jpg" target="_blank" data-width="960" data-height="540" ><img src="https://tpucdn.com/img/a22QNjZFcPLm0Xtg_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CwY8iLgBKtQu3vlK.jpg" target="_blank" data-width="960" data-height="540" ><img src="https://tpucdn.com/img/CwY8iLgBKtQu3vlK_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/apvHhqqe9J4WmJXx.jpg" target="_blank" data-width="960" data-height="540" ><img src="https://tpucdn.com/img/apvHhqqe9J4WmJXx_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EbEikq8o6WyokCsc.jpg" target="_blank" data-width="960" data-height="540" ><img src="https://tpucdn.com/img/EbEikq8o6WyokCsc_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301553/oddballers-launches-on-the-26th-of-january-2023">Read full story</a></div>
PowerColor Announces its Hellhound 7900-series Graphics Cards
With 11 days to go until the official launch of AMD's Radeon 7900-series graphics cards, PowerColor decided to share some more details about its upcoming cards. The two models appear to be the Hellhound Radeon RX 7900 XTX and the Hellhound Radeon RX 7900 XT, with both cards apparently sharing the same design and cooler. The cards appear to be at least triple-slot, but it's not entirely clear from the provided pictures. PowerColor is using a nine-blade fan design and the fans are of course kitted out with LEDs, where PowerColor is pushing what it calls an "amethyst purple" colour for this generation of Hellhound cards. The new fans are said to improve the GPU temperatures by as much as three degrees Celsius compared to the previous generation of fans.<br />
<br />
More importantly, the cards have been given an improved backplate, as well as a larger copper plate for the heatsink, for improved cooling. The new copper plate doesn't just cover the GPU now, but also the VRAM chips. The copper plate is connected to eight 6 mm heatpipes. PowerColor also shared that it's using a 14-layer high TG PCB, which uses a two ounce copper power layer. The RX 7900 XTX is kitted out with 20 VRMs, although this appears to be straight from the AMD reference design. PowerColor appears to have implemented a dual BIOS on the card, as there's a switch for OC/Silent operation and the card also appears to have a hardware LED switch, which is nice for those that don't care about lighting up their computer like a Christmas tree. Keep in mind that this is not PowerColor's top-of-the-range card, which is the Red Devil, so we should expect more details on those cards in the future too.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/U6Yaziuu8NKv9fta.jpg" target="_blank" data-width="1598" data-height="1920" ><img src="https://tpucdn.com/img/U6Yaziuu8NKv9fta_thm.jpg" width="108" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UwJ9Up42qDbDZhi3.jpg" target="_blank" data-width="1920" data-height="1160" ><img src="https://tpucdn.com/img/UwJ9Up42qDbDZhi3_thm.jpg" width="215" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dC2HN4kbdkSEkDlM.jpg" target="_blank" data-width="1804" data-height="1273" ><img src="https://tpucdn.com/img/dC2HN4kbdkSEkDlM_thm.jpg" width="184" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IOzdLev06RjcvDkb.jpg" target="_blank" data-width="1643" data-height="868" ><img src="https://tpucdn.com/img/IOzdLev06RjcvDkb_thm.jpg" width="246" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aCmDPS4Ibnhs7aGO.jpg" target="_blank" data-width="1920" data-height="1086" ><img src="https://tpucdn.com/img/aCmDPS4Ibnhs7aGO_thm.jpg" width="230" height="130" alt="" /></a></div>
(PR) Marvel's Midnight Suns Now Available Worldwide Today for Windows PC, Xbox Series X|S and PlayStation 5
2K and Marvel Entertainment announced that Marvel's Midnight Suns is now available worldwide on Windows PC via Steam and Epic Games Store, PlayStation 5 (PS5) and Xbox Series X|S. The PlayStation 4 (PS4), Xbox One and Nintendo Switch versions of the game will be available at a later date. Created by Firaxis Games, the legendary studio behind the critically-acclaimed, world-renowned XCOM and Civilization franchises, Marvel's Midnight Suns combines the rich story, character relationships, customization, and progression of an RPG with the tactical strategy and combat mechanics of a revolutionary new card-based tactics game.<br />
<br />
Marvel's Midnight Suns launched to critical acclaim, with VGC awarding it at 5 out of 5, calling it a "modern strategy classic;" PC Gamer said it was "completely brilliant" and scored it an 88 out of 100, and Rock Paper Shotgun called it "one of the best super hero games full stop." "The Firaxis team has created a remarkable game in Marvel's Midnight Suns," said Jay Ong, Executive Vice President at Marvel Games. "Marvel authenticity and love for our characters permeates every battle, decision, and interaction. It's a dream come true for any Marvel fan who ever fantasized of being able to not just fight alongside legendary Marvel heroes, but to live among them as well."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oW0w9yT6LKsgAsmk.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/oW0w9yT6LKsgAsmk_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EwBU8fdbnbvqQHUz.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/EwBU8fdbnbvqQHUz_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9ORBtjmkXx100zuJ.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/9ORBtjmkXx100zuJ_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Tde5cpDJIdk9rjLb.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/Tde5cpDJIdk9rjLb_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301706/marvels-midnight-suns-now-available-worldwide-today-for-windows-pc-xbox-series-x-s-and-playstation-5">Read full story</a></div>
(PR) 70mai Launches the 2-Hour Full Recharged Power Station
70mai, an industry leading consumer electronics brand, announced today its official launch of 70mai Power Station Tera 1000. This durable & easy-to-use power station first debuted for pre-order last year, and it had achieved over $1.5 million in sales globally. Tera 1000 is now officially available in the US on 70mai Official Store. Packed with clean electricity and solar charging, Tera 1000 is made for everyday power needs at home, off the grid, or on the way.<br />
<br />
With 1200 W rated power & 2400 W surge power and 10 outlets, Tera 1000 is designed to provide stable power to any mobile devices, majority of outdoor equipment and home appliances, even for car batteries. Tera 1000 can be charged in 4 flexible ways: via AC outlet, gas generator, car cigarette lighter and solar panel. With advanced inverter technology, Tera 1000 fully recharges in as fast as 2 hours, or recharge to 80% in 1 hour.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wjuUBT6MHdqVLryU.jpg" target="_blank" data-width="1679" data-height="960" ><img src="https://tpucdn.com/img/wjuUBT6MHdqVLryU_thm.jpg" width="227" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QLujWgEBHBMm3rah.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/QLujWgEBHBMm3rah_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301704/70mai-launches-the-2-hour-full-recharged-power-station">Read full story</a></div>
(PR) ZHIYUN's FIVERAY F100 and M40 Go-anywhere Pro Lights Let Creativity Fly
ZHIYUN, a pioneer and world leader in innovative gimbals and stabilizers for cameras and smartphones, has launched the FIVERAY M40 pocket fill light and the FIVERAY F100 stick light. With their launch, ZHIYUN pushes the boundaries of lighting technology and performance to put studio-quality, ultra-portable lighting products in the hands of content creators. Used with ZHIYUN handheld gimbals, content creators can create silky-smooth footage with stable and soft lighting, even in dark outdoor settings, thanks to its stay-cool technology.<br />
<br />
During December 7th and 8th 2022, ZHIYUN is marking the launch by giving readers a 'buy one get one free' offer on all purchases of the FIVERAY F100 and the M40. Both photography and filmmaking tools adopt ZHIYUN's patented and disruptive DynaVort Cooling System. Inspired by a panel of expert physicists, its intelligent stay-cool technology applies fluid dynamics and consists of advanced algorithms, controlling fans and a gyroscopic modeling heat sink. By raising the cooling efficiency through intelligent control, its two-way cooling system prevents overheating.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/j1dCS30gvdpO3nJl.jpg" target="_blank" data-width="662" data-height="1000" ><img src="https://tpucdn.com/img/j1dCS30gvdpO3nJl_thm.jpg" width="86" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wnzdio0gZ6HJJsqG.jpg" target="_blank" data-width="795" data-height="1000" ><img src="https://tpucdn.com/img/wnzdio0gZ6HJJsqG_thm.jpg" width="103" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Y02jw2BDYSPdnKR6.jpg" target="_blank" data-width="696" data-height="1000" ><img src="https://tpucdn.com/img/Y02jw2BDYSPdnKR6_thm.jpg" width="90" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NZkpTEiRKtcE2Kpy.jpg" target="_blank" data-width="812" data-height="1000" ><img src="https://tpucdn.com/img/NZkpTEiRKtcE2Kpy_thm.jpg" width="106" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NvnL2nhhryw0F2DS.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/NvnL2nhhryw0F2DS_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1nbOXRtbVVkcaY3W.jpg" target="_blank" data-width="1500" data-height="1001" ><img src="https://tpucdn.com/img/1nbOXRtbVVkcaY3W_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301698/zhiyuns-fiveray-f100-and-m40-go-anywhere-pro-lights-let-creativity-fly">Read full story</a></div>
(PR) Unigen Announces the Oncilla M.2 NVMe Gen4 SSD
Unigen Corporation has introduced the Oncilla PCIe Gen 4.0 M.2 2280 SSD. The high-performance solution pairs the latest advanced PCIe Gen 4.0 SSD controller with high endurance eTLC NAND Flash to deliver the fastest M.2 2280 to the performance market. Capable of 7400 MB/s Sequential Read performance, the Oncilla is perfect for workstation media applications where transferring large video files must be as fast as possible to process large datasets during VFX (Visual Effects) and post processing operations for Hollywood. The ability to perform at the highest level is also required for high performance OS boot and application drives in data centers and mission critical network appliances. For these applications optional features such as industrial temperatures and higher endurance NAND are available upon request.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Gre9slbPvG80kEuI.jpg" target="_blank" data-width="903" data-height="682" ><img src="https://tpucdn.com/img/Gre9slbPvG80kEuI_thm.jpg" width="172" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301696/unigen-announces-the-oncilla-m-2-nvme-gen4-ssd">Read full story</a></div>
GoDeal24 Signs Off Cyberweek with a Flash Sale
GoDeal24 signed off the blockbuster Cyberweek with its flash-sale. Get some of the lowest prices on the web for software to power your next-generation desktop build with—Windows 11 Pro, Windows 10 Pro, among other editions. Supercharge your domestic productivity with Office 2021 Professional Plus, the most powerful productivity suite. GoDeal24 offers the widest selection of Windows and Office editions, at some of the lowest prices, and you save more when you combine them.<br />
<br />
<a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2021-pro-plus-key-1pc.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus at $24.25</a> | <a rel="nofollow" href="https://www.godeal24.com/2-office-2021-pro-plus-keys-pack.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 2-PC at $39.25</a> | <a rel="nofollow" href="https://www.godeal24.com/3-office-2021-pro-plus-keys-pack.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 3-PC at $56.25</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2021-pro-plus-5pcs.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 5-PC at $65.25</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2019-professional-plus-key-1pc.html?g24=sgo23" target="_blank">Buy Office 2019 Professional Plus at $22.25</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2016-pro-plus-1-pc.html?g24=sgo23" target="_blank">Buy Office 2016 Professional Plus at $19.25</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-professiona-key.html?g24=sgo23" target="_blank">Buy Windows 10 Pro at $7.25</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-professional-32-64-bit-couple-2-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 2-PC at $12.12</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-10-professional-3-keys.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 3-PC at $21.57</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-professional-5-keys.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 5-PC at $33.99</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-windows-10-home-cd-key-32-64-bit.html?g24=sgo23" target="_blank">Buy Windows 10 Home at $7.15</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-windows-11-pro-cd-key.html?g24=sgo23" target="_blank">Buy Windows 11 Pro at $10.25</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-11-professional-2-keys.html?g24=sgo23" target="_blank">Buy Windows 11 Pro 2-PC at $20.25</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-professional-5-pcs.html?g24=sgo23" target="_blank">Buy Windows 11 Pro 5-PC at $48.99</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-home-key-1-pc.html?g24=sgo23" target="_blank">Buy Windows 11 Home at $9.98</a><br />
<br />
<a rel="nofollow" href="https://www.godeal24.com/ms-office-2021-home-and-business-for-mac.html?g24=sgo23" target="_blank">Buy Office 2021 Home and Business for Mac at $59.96</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2019-home-and-business-for-mac.html?g24=sgo23" target="_blank">Buy Office 2019 Home and Business for Mac at $54.96</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2016-home-and-business-for-mac.html?g24=sgo23" target="_blank">Buy Office 2016 Home and Business for Mac at $52.96</a><br />
<br />
Please use the coupon code <b>SGO62</b> at checkout on the following items to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2021-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2021 Professional Plus at $32.99</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2019 Professional Plus at $30.99</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-pro-office-2021-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $29.70</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-pro-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $27.66</a> <br />
<br />
Please use the coupon code <b>SGO50</b> on the following items.<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-10-enterprise-ltsc-2021-1-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Enterprise 2021 LTSC at $12.81</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-server-2022-standard.html?g24=sgo23" target="_blank">Buy Windows Server 2022 Standard at $26.13</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-server-2022-datacenter.html?g24=sgo23" target="_blank">Buy Windows Server 2022 Datacenter at $30.75</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/sSrhCedQJsNSaQLE.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/sSrhCedQJsNSaQLE_thm.jpg" width="231" height="130" alt="" /></a> </div>Check out great deals on system software you may want.<div class="readmore"><a href="https://www.techpowerup.com/301695/godeal24-signs-off-cyberweek-with-a-flash-sale">Read full story</a></div>
RTX 4090 has Issues with Need for Speed Unbound that can Only be Fixed with a VBIOS Update
Need for Speed Unbound (NFS Unbound), the latest entry to the popular genre-defining race sim by EA that launched today, unearthed a problem with the NVIDIA GeForce RTX 4090 "Ada" graphics card that cannot be fixed by simply updating the drivers or the game. This is a world-first—never before has a game required a VBIOS update to work around problems. <br />
<br />
According to EA, the title exhibits a display flashing/blinking issue on machines powered by the RTX 4090, <a rel="nofollow" href="https://answers.ea.com/t5/Technical-Issues/Need-for-Speed-Unbound-Known-Issues/td-p/12093748" target="_blank">which requires a firmware update</a> (i.e. video BIOS update). Luckily, this doesn't involve putting your RTX 4090 through a nerve-racking NVFlash manual BIOS update process (not that there's any risk with most RTX 4090 cards shipping with dual-BIOS). NVIDIA has released a <a rel="nofollow" href="https://nvidia.custhelp.com/app/answers/detail/a_id/5411/?=&linkId=100000163736896" target="_blank">fully-automated Firmware Update Tool</a> that can be run from within Windows, which easily updates the video BIOS of the RTX 4090. We confirmed that it is in fact the video BIOS that is being updated (by comparing the VBIOS dumps <a href="https://www.techpowerup.com/vgabios/251790/nvidia-rtx4090-24576-220830-1" target="_blank">before</a> and <a href="https://www.techpowerup.com/vgabios/251791/nvidia-rtx4090-24576-220830-3" target="_blank">after</a> using the tool).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/of47vThd3YybNJVZ.jpg" target="_blank" data-width="760" data-height="453" ><img src="https://tpucdn.com/img/of47vThd3YybNJVZ_thm.jpg" width="218" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301693/rtx-4090-has-issues-with-need-for-speed-unbound-that-can-only-be-fixed-with-a-vbios-update">Read full story</a></div>
AMD Software Adrenalin 22.11.2 Released
AMD released the latest version of the AMD Software Adrenalin drivers. Although released in December, the drivers bear the version number 22.11.2 (as opposed to something like 22.12.1); as they were probably finalized late last month. Version 22.11.2 beta adds optimization for "The Callisto Protocol," "Need for Speed Unbound," and "The Witcher 3: Wild Hunt" Next-Gen Update. Among the issues fixed with this release are intermittent driver timeout or black-screen occurring with Radeon RX 6000-series during video playback and window switching on machines powered by RX 6000-series graphics and 240 Hz monitors. <br />
<br />
Online video stuttering noticed in Firefox with hardware-acceleration on machines with RX 6000 series graphics, has been fixed. GPU utilization remaining at 100% after closing games on machines powered by RX 570 "Polaris" graphics cards caused due to buggy AMDRSServ.exe, has been fixed. A driver timeout or black-screen while videos are playing with VRChat on RX 6000-series GPU powered machines, has been fixed. Grapb the driver from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/" target="_blank">AMD Software Adrenalin 22.11.2 beta</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/RCwz7zQmCmfqRHfV.jpg" target="_blank" data-width="1200" data-height="545" ><img src="https://tpucdn.com/img/RCwz7zQmCmfqRHfV_thm.jpg" width="286" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LxnGnjBZGpOIHghM.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/LxnGnjBZGpOIHghM_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/U6Ki976OhDDYoKif.jpg" target="_blank" data-width="1428" data-height="744" ><img src="https://tpucdn.com/img/U6Ki976OhDDYoKif_thm.jpg" width="250" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301680/amd-software-adrenalin-22-11-2-released">Read full story</a></div>
US Might Reimpose GPU Import Tariffs in the New Year
Currently, the US has an exclusion in place when it comes to import tariffs relating to graphics cards and GPUs imported from China, but the exclusion is set to expire on the 31st of December this year. So far, the US government has been quiet on whether or not the import tariff will be reinstated or not. If the tariff was to be reinstated, US consumers are looking at a 25 percent import duty on graphics cards, starting on the 1st of January, 2023.<br />
<br />
There's no easy way to circumvent the tariff either, as it includes items like "printed circuit assemblies, constituting unfinished logic boards," according to Tom's Hardware. Not all graphics cards are made in China though, but the majority of graphics cards are today. It's possible that NVIDIA's move of its <a href="https://www.techpowerup.com/301434/nvidia-to-relocate-logistics-center-from-hong-kong-to-taiwan" target="_blank">logistics center</a> from Hong Kong to Taiwan could have some relation to this as well, as NVIDIA would then be shipping products out of Taiwan, rather than China, depending on how the US Customs classifies Hong Kong these days. We should know what happens in a month's time, but a 25 percent import duty on graphics cards will likely kill most sales, as most people already find them overpriced. This would of course affect AMD and NVIDIA, as well as their partners in the same way, unless they make their graphics cards outside of China.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vR1aWdGKYFsju6BU.jpg" target="_blank" data-width="959" data-height="720" ><img src="https://tpucdn.com/img/vR1aWdGKYFsju6BU_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Tropico 6 - New Frontiers Touches Down on PC
Publisher Kalypso Media and in-house developer Realmforge Studios are over the moon to announce that Tropico 6 - New Frontiers is out now for PC. Whilst a certain billionaire is distracted by the chaos at Twitter, El Presidente has decided that now is the perfect time for a little space exploration of his own if he truly wants to become the richest man in the universe. SpaceX who? <br />
<br />
In Tropico 6 - New Frontiers, players are tasked with ensuring Tropico stays ahead of the international competition. It's a wide world out there and El Prez is taking his persuasion tactics to galactic heights. With the new Space Port Complex, players will embark on launching Tropico into a glorious new future as they construct rockets and delve into research. Take on the Space Race, walk on the Moon and establish the first Mars colony of humankind with the all-new Mission Mars campaign. New characters, buildings and edicts open countless possibilities to make more money, keep your citizens happy and improve upon that Tropican perfection. You can even customise a fresh look for El Prez and his palace that is out of this world. But be warned, even with a stellar plan there is no greater risk than space exploration and who knows what unforeseen circumstances await. You'll need to be creative if you want to claim glory for Tropico.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/x1VsmZQZkPOu0tMc.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/x1VsmZQZkPOu0tMc_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4VHQEWsAZyIqHwmE.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/4VHQEWsAZyIqHwmE_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WWr3jWFHAJaoGTBQ.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/WWr3jWFHAJaoGTBQ_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rbQh2PjEGysFNXqd.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/rbQh2PjEGysFNXqd_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301676/tropico-6-new-frontiers-touches-down-on-pc">Read full story</a></div>
(PR) IDC Tracker Forecast Sees Further Contraction for the Global PC and Tablet Markets with Commercial PC Demand Remaining the One Clear Opportunity
In a new International Data Corporation (IDC) forecast, the outlook for PCs and tablets continues to get worse. Worldwide PC and tablet shipments are forecast to decline 11.9% in 2022 with volumes shrinking to 456.8 million units, followed by a further decline in 2023. According to the IDC Worldwide Quarterly Personal Computing Device Tracker, traditional PCs will see shipments drop 5.6% to 281 million units in 2023 while tablets will decline 6.7% to 148 million units.<br />
<br />
Despite the sharp decline, shipment volumes will remain above pre-pandemic levels although the market will continue to be challenged by macroeconomic headwinds, excess channel inventory, and high levels of saturation. While the PC market is expected to fare better than tablets with a compound annual growth rate (CAGR) of just over 1% expected over the five-year forecast, tablets are expected to have a CAGR of -1.7% over the same period.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FU5HX4Y9yrdrqOlz.jpg" target="_blank" data-width="556" data-height="403" ><img src="https://tpucdn.com/img/FU5HX4Y9yrdrqOlz_thm.jpg" width="179" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bMjPZKtZeIuk3IhY.jpg" target="_blank" data-width="1303" data-height="442" ><img src="https://tpucdn.com/img/bMjPZKtZeIuk3IhY_thm.jpg" width="383" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301671/idc-tracker-forecast-sees-further-contraction-for-the-global-pc-and-tablet-markets-with-commercial-pc-demand-remaining-the-one-clear-opportunity">Read full story</a></div>
NVIDIA GeForce 527.37 WHQL Game Ready Drivers Released
NVIDIA today released the latest version of its GeForce Game Ready software. Version 527.37 WHQL comes with day-zero optimization for "Marvel's Midnight Sons," and "Need for Speed Unbound." Among the handful issues fixed with this release is the previous 526.98 driver failing to install on "certain" RTX 3060 Ti graphics cards, meaning that this card introduces official support for the RTX 3060 Ti with GDDR6X memory. MSI Afterburner not prioritizing GPU temperature over power when selected in the app, has been fixed. Screen flickering observed with the TikTok Broadcasting tool has been fixed. Metro Exodus Enhanced Edition showing some random screen-flashing with RTX 40-series graphics cards has been fixed. Background apps randomly displaying a shift in color saturation has been fixed.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/" target="_blank">NVIDIA GeForce 527.37 WHQL</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/rpP4lhexzHLfBgXX.jpg" target="_blank" data-width="616" data-height="353" ><img src="https://tpucdn.com/img/rpP4lhexzHLfBgXX_thm.jpg" width="227" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/YM5puoNwmgBZcXyS.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/YM5puoNwmgBZcXyS_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301667/nvidia-geforce-527-37-whql-game-ready-drivers-released">Read full story</a></div>
(PR) DFI Empowers Edge AI Deployment with EC70A-TGU Compact Fanless System
DFI, the leading global provider of embedded solutions and Edge AI computing technology across multiple industries, is releasing the new Edge AI inference computer EC70A-TGU. EC70A-TGU is powered by Intel 11th Gen Tiger Lake Core processors, with 8 GB onboard memory in a compact platform. Equipped with an all-new GPU in Iris Xe embedded graphics, EC70A-TGU delivers disruptive GPU graphics performance and enables faster processing of images and video streams. Users can leverage the GPU to power cutting-edge AI solutions for various applications, including Industrial Automation, AMR/AGV, Smart Transportation, Medical Imaging, etc.<br />
<br />
Maintaining the small size of the previous generation fanless embedded system, the EC70A-TGU is equipped with a compact fanless design, measuring only 181.6 mm x 57 mm x 118.4 mm, while providing significantly upgraded performance. In addition, EC70A-TGU supports multiple I/Os, outperforming its counterparts with up to 6 USB 3.1 ports, and can be connected to more sensors and devices.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KaLF8eb06BfVRAbM.jpg" target="_blank" data-width="800" data-height="600" ><img src="https://tpucdn.com/img/KaLF8eb06BfVRAbM_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301664/dfi-empowers-edge-ai-deployment-with-ec70a-tgu-compact-fanless-system">Read full story</a></div>
BOE Debuts the World's First 600 Hz Gaming Notebook Display
At the World Display Industry Conference in China, BOE showed off a range of upcoming products, ranging from various new TV displays, to a foldable OLED display for notebooks and a 600 Hz display for gaming notebooks. Not much is known about the 600 Hz display, but it's a 16-inch panel and it was shown off inside a notebook from an unknown vendor. BOE showed off a <a href="https://www.techpowerup.com/291482/boe-creates-27-inch-full-hd-display-with-500-hz-refresh-rate" target="_blank">500 Hz desktop display</a> earlier this, but this is a step up from that. The foldable OLED laptop display measures 17.3-inches and is as such similar to products we've seen from Samsung.<br />
<br />
Also on display at the event was a 34-inch Mini-LED gaming display with a 165 Hz refresh rate, a 1 ms response time and it's said to meet the DisplayHDR 1000 standard and should have a contrast ratio of 100,000:1. BOE calls its Mini-LED displays for α-MLED and the company also had an 86-inch TV display based on the same technology at the event. It's unknown if any of these displays will appear in consumer products outside of the Chinese market, although BOE laptop panels have been used in products sold globally.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/S9LgG2lGOZDHmidk.jpg" target="_blank" data-width="1080" data-height="721" ><img src="https://tpucdn.com/img/S9LgG2lGOZDHmidk_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/P058cdPrHKYTzjYH.jpg" target="_blank" data-width="1080" data-height="720" ><img src="https://tpucdn.com/img/P058cdPrHKYTzjYH_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QUkdhDmsILUs2RNz.jpg" target="_blank" data-width="843" data-height="560" ><img src="https://tpucdn.com/img/QUkdhDmsILUs2RNz_thm.jpg" width="196" height="130" alt="" /></a></div>
(PR) be quiet! Launches Pure Rock LP 45mm Low-profile CPU Cooler
be quiet!, the German manufacturer for premium PC components, is today announcing an addition to its portfolio of air coolers: Pure Rock LP is a low-profile cooler with a height of mere 45 mm, making it the CPU cooler of choice for ultra-compact Mini-ITX builds that require reliable cooling, while featuring a brushed aluminium design.<br />
<br />
Due to its remarkably low height of 45 mm, Pure Rock LP will fit into the tightest of systems, such as Mini-ITX HTPCs and small multimedia or gaming systems. Its compact design enables full configurations of RAM banks even in PC cases with limited space. Despite its small size, Pure Rock LP delivers high enough cooling power of 100 W TDP thanks to three high-performance 6 mm heat pipes and a 92 mm quality fan. The fan has an ultra-low height of 15 mm and supports a silent operation of 30,6 dB(A) with a maximum speed of 2500 rpm. With its brushed aluminium finish and mounting options for AMD and Intel, the black Pure Rock LP will look good in any compact build. The cooler comes with a full 3-year manufacturer's warranty.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/exqZ2V7EqSactjWI.jpg" target="_blank" data-width="1041" data-height="1000" ><img src="https://tpucdn.com/img/exqZ2V7EqSactjWI_thm.jpg" width="135" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/72VoRe4kvvyNJKEG.jpg" target="_blank" data-width="1152" data-height="1000" ><img src="https://tpucdn.com/img/72VoRe4kvvyNJKEG_thm.jpg" width="150" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jNxhi4Urc46vrrui.jpg" target="_blank" data-width="1092" data-height="1000" ><img src="https://tpucdn.com/img/jNxhi4Urc46vrrui_thm.jpg" width="142" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Am5HbQsn7BAVVaGi.jpg" target="_blank" data-width="1178" data-height="1000" ><img src="https://tpucdn.com/img/Am5HbQsn7BAVVaGi_thm.jpg" width="153" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vpNZggOWpVQOxgq0.jpg" target="_blank" data-width="1316" data-height="1000" ><img src="https://tpucdn.com/img/vpNZggOWpVQOxgq0_thm.jpg" width="171" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301660/be-quiet-launches-pure-rock-lp-45mm-low-profile-cpu-cooler">Read full story</a></div>
(PR) Alphacool Unveils Core 100 and Core 200 Reservoir+Pump Assemblies, with Upgraded VPP Apex Pumps
With the new Core Aurora reservoir with pump, Alphacool presents a sleek and stylish team. The combination of the revised successor to the Eisbecher, the Core reservoir and the elegant VPP Apex pump allows for performance-oriented water cooling.<br />
<br />
The Core reservoir is equipped with an external thread on the acrylic tube, which ensures its stability and safety. 12 ARGB LEDs are installed in the pump top, which provide an extensive display of colors in the expansion tank. The included mounting kit allows the Core 100/200 Aurora Reservoir with VPP Apex pump to be placed freestanding in the case or to be mounted on a radiator or free fan spots. The 200ml or 400ml capacity is more than enough for any water loop.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ikTFIdekCyagGj3S.jpg" target="_blank" data-width="837" data-height="1000" ><img src="https://tpucdn.com/img/ikTFIdekCyagGj3S_thm.jpg" width="109" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Ft4GTE1HxziRzbrT.jpg" target="_blank" data-width="789" data-height="1000" ><img src="https://tpucdn.com/img/Ft4GTE1HxziRzbrT_thm.jpg" width="103" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/P3g1gdRSq1y12ejU.jpg" target="_blank" data-width="1212" data-height="1000" ><img src="https://tpucdn.com/img/P3g1gdRSq1y12ejU_thm.jpg" width="158" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DlvoaGPSuUkDwtEC.jpg" target="_blank" data-width="1074" data-height="1000" ><img src="https://tpucdn.com/img/DlvoaGPSuUkDwtEC_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/meZh8HMy4eBAj3MD.jpg" target="_blank" data-width="1200" data-height="630" ><img src="https://tpucdn.com/img/meZh8HMy4eBAj3MD_thm.jpg" width="248" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301657/alphacool-unveils-core-100-and-core-200-reservoir-pump-assemblies-with-upgraded-vpp-apex-pumps">Read full story</a></div>
(PR) G.SKILL DDR5-8000 Extreme Speed Memory Kit Now Available
G.SKILL International Enterprise Co., Ltd., the world's leading brand of performance overclock memory and PC components, is thrilled to announce the retail release of the ultra-high frequency DDR5-8000 CL38 32 GB (2x16GB) overclocked performance DRAM memory kit under the flagship Trident Z5 RGB series. Designed for use with the latest 13th Gen Intel Core desktop processors and compatible high-end Z790 chipset motherboards, this new DDR5-8000 memory kit specification is raising the bar for overclocked DDR5 memory speed to the next level.<br />
<br />
On the forefront of fast DDR5 memory speeds, G.SKILL is announcing the retail availability of the ultra-high frequency DDR5-8000 CL38-48-48-128 32 GB (2x16GB) memory kit. Designed as the pinnacle of DDR5 performance on current generation platforms, see the screenshot below for the validation of this overclocked DDR5-8000 memory specification on the ASUS ROG MAXIMUS Z790 APEX motherboard with the Intel Core i9-13900K processor:<div class="imgcontainer"><a href="https://www.techpowerup.com/img/82NtI7zcaFLnyw2V.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/82NtI7zcaFLnyw2V_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cZrtszAZxV9juhxG.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/cZrtszAZxV9juhxG_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301655/g-skill-ddr5-8000-extreme-speed-memory-kit-now-available">Read full story</a></div>
Team Group T-Force x TechPowerUp Giveaway: The Winners!
TechPowerUp and Team Group brought you the T-Force Giveaway earlier this month, with a chance to win a T-Force Delta RGB DDR5-6400 CL40 32 GB (2x 16 GB) memory kit, or one of five Vulcan Z 1 TB SSDs! The Delta RGB DDR5-6400 CL40 32 GB is an incredible start to your next-generation desktop build, with its incredible speeds that can supercharge an AMD "Zen 4" or Intel "Raptor Lake" desktop build; while the Vulcan Z 1 TB SSD is a great game storage drive. Without further ado, the winners:<ul><li>Jack from Australia, wins the Delta RGB DDR5-6400 32 GB memory kit</li><li>The Vulcan Z 1 TB SSD is won by:<ul><li>Anthony from Belgium</li><li>Elea from Romania</li><li>Andrei from the United States</li><li>Jari from Finland</li><li>Andres from Chile</li></ul></li></ul>A huge congratulations, TechPowerUp and Team Group will return with more such interesting giveaways.
AMD Ryzen 9 7900 and Ryzen 7 7700 (non-X) Listed as Prebuilt Options on Lenovo
Lenovo started offering the Ryzen 9 7900 and Ryzen 7 7700 processors as options for its prebuilt desktops, confirming that the 7900 and 7700 will be OEM-exclusives, at least initially. That doesn't mean these chips won't make it to the retail channel, as OEM-only parts from AMD in the past have somehow found their way to retailers, who bought them in trays, and sold them piecemeal as combos with motherboards and CPU coolers. The 7900 is a 12-core/24-thread part, just like its retail-channel sibling, the 7900X. The 7700 is an 8-core/16-thread part, again, similar to the 7700X. Not much else is known about these chips, except for their base frequency of just 3.60 GHz (compared to 4.70 GHz for the 7900X, and 4.50 GHz for the 7700X). Both chips are expected to feature a lowered TDP, with just 65 W for the 7700 (down from 105 W for the 7700X), and possibly 65 W or 105 W for the 7900 (down from 170 W for the 7900X).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BhuqyW5blldyzfB5.jpg" target="_blank" data-width="609" data-height="367" ><img src="https://tpucdn.com/img/BhuqyW5blldyzfB5_thm.jpg" width="216" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DqSZTGcFBwDFvq8a.jpg" target="_blank" data-width="1579" data-height="557" ><img src="https://tpucdn.com/img/DqSZTGcFBwDFvq8a_thm.jpg" width="369" height="130" alt="" /></a></div>
NVIDIA GeForce RTX 4090 with Nearly Half its Power-limit and Undervolting Loses Just 8% Performance
The monstrous NVIDIA GeForce RTX 4090 "Ada" graphics card has the potential to be a very efficient high-end graphics card with a daily-use undervolt, and with its power-limit halved, finds an undervolting adventure review by Korean tech publication Quasar Zone. The reviewer tested the RTX 4090 with a number of GPU core voltage settings, and lowered software-level power-limits (down from its 450 W default). <br />
<br />
It's important to note that 450 W is a very arbitrary number for the RTX 4090's power limit, the GPU rarely draws that much power in typical gaming workloads. Our own testing at stock settings sees its gaming power draw around the 340 W-mark. Quasar Zone tested the RTX 4090 with a power limit as low as 60% (270 W). With its most aggressive power management they could muster (i.e. 270 W PL), the card was found to lose just around 8% of performance at 4K UHD, averaged across five AAA games at maxed out settings. The story is similar with undervolting the GPU down to 850 mV, down from its 1 V stock. In both cases, the performance loss appear well contained, while providing a reduction in power-draw (in turn heat and noise).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/gA41aJWRC0HYTkNV.jpg" target="_blank" data-width="800" data-height="1220" ><img src="https://tpucdn.com/img/gA41aJWRC0HYTkNV_thm.jpg" width="85" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WrpzhhhzrFLj9I9q.jpg" target="_blank" data-width="800" data-height="1220" ><img src="https://tpucdn.com/img/WrpzhhhzrFLj9I9q_thm.jpg" width="85" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LbV8WYyI89GyChXM.jpg" target="_blank" data-width="1100" data-height="605" ><img src="https://tpucdn.com/img/LbV8WYyI89GyChXM_thm.jpg" width="236" height="130" alt="" /></a></div>
(PR) Intel Research Fuels Moore's Law and Paves the Way to a Trillion
Today, Intel unveiled research breakthroughs fueling its innovation pipeline for keeping Moore's Law on track to a trillion transistors on a package in the next decade. At IEEE International Electron Devices Meeting (IEDM) 2022, Intel researchers showcased advancements in 3D packaging technology with a new 10x improvement in density; novel materials for 2D transistor scaling beyond RibbonFET, including super-thin material just 3 atoms thick; new possibilities in energy efficiency and memory for higher-performing computing; and advancements for quantum computing.<br />
<br />
"Seventy-five years since the invention of the transistor, innovation driving Moore's Law continues to address the world's exponentially increasing demand for computing. At IEDM 2022, Intel is showcasing both the forward-thinking and concrete research advancements needed to break through current and future barriers, deliver to this insatiable demand, and keep Moore's Law alive and well for years to come." -Gary Patton, Intel vice president and general manager of Components Research and Design Enablement<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6i8zb3mtfXXOyNL8.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/6i8zb3mtfXXOyNL8_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9RfHwE01WePU09OJ.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/9RfHwE01WePU09OJ_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qMRpQQmymU81KaJk.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/qMRpQQmymU81KaJk_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/McL0spFBda5BDbMA.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/McL0spFBda5BDbMA_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301748/intel-research-fuels-moores-law-and-paves-the-way-to-a-trillion-transistors-by-2030">Read full story</a></div>
<br />
According to EA, the title exhibits a display flashing/blinking issue on machines powered by the RTX 4090, <a rel="nofollow" href="https://answers.ea.com/t5/Technical-Issues/Need-for-Speed-Unbound-Known-Issues/td-p/12093748" target="_blank">which requires a firmware update</a> (i.e. video BIOS update). Luckily, this doesn't involve putting your RTX 4090 through a nerve-racking NVFlash manual BIOS update process (not that there's any risk with most RTX 4090 cards shipping with dual-BIOS). NVIDIA has released a <a rel="nofollow" href="https://nvidia.custhelp.com/app/answers/detail/a_id/5411/?=&linkId=100000163736896" target="_blank">fully-automated Firmware Update Tool</a> that can be run from within Windows, which easily updates the video BIOS of the RTX 4090. We confirmed that it is in fact the video BIOS that is being updated (by comparing the VBIOS dumps <a href="https://www.techpowerup.com/vgabios/251790/nvidia-rtx4090-24576-220830-1" target="_blank">before</a> and <a href="https://www.techpowerup.com/vgabios/251791/nvidia-rtx4090-24576-220830-3" target="_blank">after</a> using the tool).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/of47vThd3YybNJVZ.jpg" target="_blank" data-width="760" data-height="453" ><img src="https://tpucdn.com/img/of47vThd3YybNJVZ_thm.jpg" width="218" height="130" alt="" /></a> </div><b>Update Dec 3rd</b>: EA Support has just updated their support recommendation from graphics card VBIOS update to a motherboard BIOS update. "After testing, we've found a solution is to upgrade the motherboard BIOS. Please refer to your motherboard manufacturer's support page to obtain the latest system BIOS," the updated recommendation reads.<div class="readmore"><a href="https://www.techpowerup.com/301693/rtx-4090-has-issues-with-need-for-speed-unbound-that-can-only-be-fixed-with-a-vbios-update">Read full story</a></div>
AMD Readies 16-core, 12-core, and 8-core Ryzen 7000X3D "Zen 4" Processors
AMD is firing full cylinders to release a new line of Ryzen 7000-series "Zen 4" Socket AM5 desktop processors featuring 3D Vertical Cache, at the earliest. Faced with a significant drop in demand due to the slump in the PC industry, and renewed competition from Intel in the form of its 13th Gen Core "Raptor Lake" processors, the company is looking to launch the Ryzen 7000X3D desktop processors within January 2023, with product unveiling expected at AMD's 2023 International CES event. The 3D Vertical Cache technology had a profound impact on the gaming performance of the older "Zen 3" architecture, bringing it up to levels competitive with those of the 12th Gen Core "Alder Lake" processors, and while gaming performance of the Ryzen 7000 "Zen 4" processors launched till take match or beat "Alder Lake," they fall behind those of the 13th Gen "Raptor Lake," which is exactly what AMD hopes to remedy with the Ryzen 7000X3D series.<br />
<br />
In a report, Korean tech publication Quasar Zone states that AMD is planning to release 16-core/32-thread, 12-core/24-thread, and 8-core/16-thread SKUs in the Ryzen 7000X3D series. These would use one or two "Zen 4" chiplets with stacked 3D Vertical Cache memory. A large amount of cache memory operating at the same speed as the on-die L3 cache, is made contiguous with it and stacked on top of the region of the CCD (chiplet) that has the L3 cache, while the region with the CPU cores has structural silicon that conveys heat to the surface. On "Zen 3," the 32 MB on-die cache is appended with 64 MB of stacked cache memory operating at the same speed, giving the processor 96 MB of L3 cache that's uniformly accessible by all CPU cores on the CCD. This large cache memory positively impacts gaming performance on the Ryzen 7 5800X3D in comparison to the 5800X; and a similar uplift is expected for the 7000X3D series over their regular 7000-series counterparts.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/SLW1vDmcuV7vhkkV.jpg" target="_blank" data-width="794" data-height="961" ><img src="https://tpucdn.com/img/SLW1vDmcuV7vhkkV_thm.jpg" width="107" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1kaQ6yh9me8Fa482.jpg" target="_blank" data-width="799" data-height="950" ><img src="https://tpucdn.com/img/1kaQ6yh9me8Fa482_thm.jpg" width="109" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Y9sO4TK9ZyXI5Ug7.jpg" target="_blank" data-width="798" data-height="948" ><img src="https://tpucdn.com/img/Y9sO4TK9ZyXI5Ug7_thm.jpg" width="109" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301721/amd-readies-16-core-12-core-and-8-core-ryzen-7000x3d-zen-4-processors">Read full story</a></div>
Sapphire's Radeon RX 7900 Cards Make an Early Appearance on Amazon
Although we're almost two weeks away from the official launch of AMD's Radeon RX 7900-series, Sapphire's reference design cards have already made an early appearance on Amazon. Both of its cards are listed on the e-tailers website, but sadly without pricing. No new specs were provided either, but at least we did get some more detailed pictures of the two cards. The cards are simply named the Radeon RX 7900 XT Gaming (21323-01-20G) and the Radeon RX 7900 XTX Gaming (21322-01-20G).<br />
<br />
It's very clear from the pictures that the Radeon RX 7900 XTX is a much chunkier card than the RX 7900 XT. This also confirms Sapphire as one of the partners that will sell reference cards, but it's unclear if Sapphire will have custom cards ready in time for the launch, or if the company will add those to its line-up at a later date. Note that the model number for the Radeon RX 7900 XTX lists it as having 20 GB of VRAM, although the packaging clearly lists it as having 24 GB. Searching for the model numbers provided by Amazon, it appears that the cards will be in stock in Sweden as well, as one of the local distributors is listing the cards. More pictures after the break.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/t2qTymOGT7feWX5Z.jpg" target="_blank" data-width="1062" data-height="960" ><img src="https://tpucdn.com/img/t2qTymOGT7feWX5Z_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/soEqoHBrs26n33W8.jpg" target="_blank" data-width="1089" data-height="960" ><img src="https://tpucdn.com/img/soEqoHBrs26n33W8_thm.jpg" width="147" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/o1RBLLvbxBWWUt7V.jpg" target="_blank" data-width="1500" data-height="1168" ><img src="https://tpucdn.com/img/o1RBLLvbxBWWUt7V_thm.jpg" width="167" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xNC0DnhsTaQ6D4XR.jpg" target="_blank" data-width="1500" data-height="1100" ><img src="https://tpucdn.com/img/xNC0DnhsTaQ6D4XR_thm.jpg" width="177" height="130" alt="" /></a><br />
</div><div class="readmore"><a href="https://www.techpowerup.com/301715/sapphires-radeon-rx-7900-cards-make-an-early-appearance-on-amazon">Read full story</a></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
(PR) Lattice Extends Low Power Leadership with New Lattice Avant FPGA
Lattice Semiconductor, the low power programmable leader, today unveiled Lattice Avant, a new FPGA platform purpose-built to bring the company's power efficient architecture, small size, and performance leadership to mid-range FPGAs. Lattice Avant offers best-in-class power efficiency, advanced connectivity, and optimized compute that enable Lattice to address an expanded set of customer applications across the Communications, Computing, Industrial, and Automotive markets.<br />
<br />
"With Lattice Avant, we extend our low power leadership position in the FPGA industry and are poised to continue our rapid pace of innovation, while also doubling the addressable market for our product portfolio," said Jim Anderson, President and CEO, Lattice Semiconductor. "We created Avant to address our customers' need for compelling mid-range FPGA solutions, and we're excited to help them accelerate their designs with new levels of power efficiency and performance."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/yYkapfcJbi2waVtd.jpg" target="_blank" data-width="480" data-height="480" ><img src="https://tpucdn.com/img/yYkapfcJbi2waVtd_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301834/lattice-extends-low-power-leadership-with-new-lattice-avant-fpga-platform">Read full story</a></div>
(PR) Canon Expands Business Inkjet and Laser Printer Portfolio with Four New Printers to Help Provide Harmony at Work
In today's working world it's vital that households and offices have the tools they need to get their work done, and that are simultaneously efficient and affordable. To help create Harmony at Work, Canon U.S.A., Inc., a leader in digital imaging solutions, is pleased to announce two new inkjet printer models and two new laser printers, expanding the MAXIFY GX and imageCLASS printer lines. The 4-in-1 MAXIFY GX4020 printer (print, copy, scan, and fax) and the 3-in-1 MAXIFY GX3020 printer (print, copy, and scan) expand the Canon MegaTank Printer lineup at an increasingly affordable cost. These models utilize a continuous ink supply system, which can significantly reduce ink costs by utilizing high-volume inkbottles. The imageCLASS MF264dw II and MF262dw II printers are 3-in-1 multifunction machines (print, copy, and scan) adding to the Canon black-and-white laser portfolio. <br />
<br />
The new MAXIFY printers can help hybrid and remote workers looking to upgrade their home office, as well as small business owners looking to manage daily work at a fast-moving pace. The MAXIFY GX4020 and GX3020 printers boast a print speed of 18 images per minute (IPM) in black-and-white, and 13 (IPM) in color. They both boast multiple paper paths, with a 250-sheet front-loading cassette, a 100-sheet rear tray, and a separate rear flat tray which is ideal for thicker paper, such as used for poster creation. The MAXIFY GX4020 and GX3020 printers can produce approximately 14,000 sheets in color and approximately 6,000 sheets in black ink. A three-year limited warranty comes standard, and users can easily replace the maintenance cartridge and the print head (replacements sold separately) to assist with printer longevity. These inkjet printers are environmentally conscious, meeting EPEAT Gold standard, and offer a small footprint, making it easy and convenient to place them in a compact space.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/infZ98xkdnixNiKa.jpg" target="_blank" data-width="1280" data-height="1092" ><img src="https://tpucdn.com/img/infZ98xkdnixNiKa_thm.jpg" width="152" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lhj571Ox3e0Q1ifl.jpg" target="_blank" data-width="1280" data-height="1154" ><img src="https://tpucdn.com/img/lhj571Ox3e0Q1ifl_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xG4kPiAgNEpwA2QB.jpg" target="_blank" data-width="1280" data-height="1133" ><img src="https://tpucdn.com/img/xG4kPiAgNEpwA2QB_thm.jpg" width="147" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CWiWcEdfBJlG3RWw.jpg" target="_blank" data-width="1280" data-height="1234" ><img src="https://tpucdn.com/img/CWiWcEdfBJlG3RWw_thm.jpg" width="135" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301831/canon-expands-business-inkjet-and-laser-printer-portfolio-with-four-new-printers-to-help-provide-harmony-at-work">Read full story</a></div>
(PR) Montech Announces the SKY TWO High-airflow Chassis
MONTECH, an innovative PC components and peripherals brand, announces the SKY TWO, a mainstream mid-tower case that showcases your PC components with the front and side tempered glass panels. The latest addition to the SKY series offers top cooling performance with a unique airflow configuration featuring fine mesh bottom front panel and side panel, 3 pre-installed RX120 reversed 120 mm ARGB/PWM fans at the side and bottom and pre-installed AX120 ARGB/PWM fan at the rear. The SKY TWO is compatible with motherboards from Mini-ITX to E-ATX, supports top mounting of up to a 360 mm radiator and fans, and features a top I/O including a USB Gen 2 Type C port. The SKY TWO is available in Black US $99.99, Pristine Frost White US$105.99, and Morocco Blue US $119.99.<br />
<br />
The SKY TWO offers a unique airflow approach with the lower portion of the front and left side panel designed with a fine mesh optimized for airflow and dust filtration. This concept ensures plenty of air is pushed through the PSU shroud and fed into the fans above it, providing a direct supply of fresh air to the GPU. In addition, the 3 pre-installed RX120 120 mm ARGB/PWM fans (2 at the side and 1 at the bottom) feature a reverse blade design which allows them to be installed as intake with their best side visible. An additional 120 mm ARGB/PWM fan is pre-installed at the rear of the SKY TWO to create a balanced out-of-the-box thermal solution.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cMQu1mXz2mChyRGT.jpg" target="_blank" data-width="800" data-height="450" ><img src="https://tpucdn.com/img/cMQu1mXz2mChyRGT_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1RtEX7qxJvpqCNl1.jpg" target="_blank" data-width="800" data-height="450" ><img src="https://tpucdn.com/img/1RtEX7qxJvpqCNl1_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qGZPZLzDA4dySgIX.jpg" target="_blank" data-width="800" data-height="533" ><img src="https://tpucdn.com/img/qGZPZLzDA4dySgIX_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301830/montech-announces-the-sky-two-high-airflow-chassis">Read full story</a></div>
AMD Radeon RX 7900 RDNA3 GPU Launch Could Face Scarcity, China Loses Reference Card Privilege
AMD's next-generation Radeon RX 7900 high-end graphics cards are set to arrive next week and bring the new RDNA3 GPU architecture to the masses. However, it seems like the customers will have to fight for their purchase as the availability could be scarce at launch, leading to potentially increased prices with low stocks. According to Igor's Lab report, Germany will receive only 3,000 reference MBA (Made By AMD) units of Radeon RX 7900 series cards. In contrast, the rest of the EMEA region will receive only 7,000 MBA units. These numbers are lower than expected, so AIB partners may improve the supply once their designs hit shelves.<br />
<br />
On the other hand, mainland China will not receive any MBA units of the new cards as a sign of increasing tension with Taiwan. Of course, AMD's board partners will supply their designs to China, and they are allowed to; however, it seems that only AMD is making a statement here. In addition to supply issues, the launch is rumored to be covered in BIOS issues such as memory leaks and the COVID-19 outbreak affecting production in closed factories. Of course, all of this information should be taken with a grain of salt, and we must wait for the official launch before making any further assumptions.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6FXUR3lwoIyjX9JB.jpg" target="_blank" data-width="1133" data-height="819" ><img src="https://tpucdn.com/img/6FXUR3lwoIyjX9JB_thm.jpg" width="180" height="130" alt="" /></a></div>
(PR) Alphacool Releases Eisblock Aurora Water Blocks for Various Custom RTX 4090 Cards
More performance for GeForce RTX 4090! With the Eisblock Aurora, Alphacool presents new, innovative coolers for active water cooling of Gigabyte, ASUS, Palit as well as Gainward graphics cards. In order to dissipate the enormous waste heat of this graphics card generation as effectively as possible, numerous optimizations have been made to the water cooler compared to the previous models. The fin structure has been adapted and allows a very effective water flow while simultaneously increasing the cooling surface. The modified jet plate with improved inflow engine ensures optimum distribution of the water on the cooling fins.<br />
<br />
The fully chrome-plated copper base is resistant to acids, scratches and damage. Additionally, the chrome plating provides homogeneity and shine that cannot be achieved by nickel plating. The illumination from the digitally addressable RGB LEDs is even better distributed throughout the cooler thanks to the chrome plating. The Aurora design of the GeForce RTX 40XX Eisblock Generation is visually quiet and sleek because only one O-ring runs around the entire cooler. Also, the design around the cooling fins and jetplate makes for a cleaner look.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DouyGdV0kJEedlUC.jpg" target="_blank" data-width="1238" data-height="1000" ><img src="https://tpucdn.com/img/DouyGdV0kJEedlUC_thm.jpg" width="161" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1zcnjHLaJaOnpzug.jpg" target="_blank" data-width="1299" data-height="1000" ><img src="https://tpucdn.com/img/1zcnjHLaJaOnpzug_thm.jpg" width="169" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ckeN35pn0GlfPKRI.jpg" target="_blank" data-width="1276" data-height="1000" ><img src="https://tpucdn.com/img/ckeN35pn0GlfPKRI_thm.jpg" width="166" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uzeovniVHpkPAYNS.jpg" target="_blank" data-width="950" data-height="800" ><img src="https://tpucdn.com/img/uzeovniVHpkPAYNS_thm.jpg" width="154" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/U2EGgHo9VXlUY8gD.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/U2EGgHo9VXlUY8gD_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301820/alphacool-releases-eisblock-aurora-water-blocks-for-various-custom-rtx-4090-cards">Read full story</a></div>
Intel Arc GPU Graphics Drivers 31.0.101.3959 Released
Intel Graphics today released the Intel Arc GPU Graphics Drivers, version 31.0.101.3959 beta. These bring game optimization for "World of Warcraft: Dragonflight," "Warhammer 40,000: Darktide," "The Callisto Protocol," "Marvel's Midnight Suns," and "Fortnite Chapter 4." The drivers also improve DirectX 9 game experience for a number of games (Arc GPUs lack native support for D3D9 and rely on API translation). These games include the likes of "Starcraft 2," "Payday 2," and CS:GO. Among the issues fixed with this release include ghosting and corruption noticed in "Victoria 3" in DirectX 11 mode; texture corruption with "Hearts of Iron IV," flickering noticed with "Stellaris" and "Sonic Frontiers." Grab the drivers from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/intel-arc-graphics-drivers/" target="_blank">Intel Arc GPU Graphics Drivers 31.0.101.3959 beta</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/MqOu9E0ufefggAb1.jpg" target="_blank" data-width="853" data-height="545" ><img src="https://tpucdn.com/img/MqOu9E0ufefggAb1_thm.jpg" width="203" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yVFxLwqYCOc8uZlf.jpg" target="_blank" data-width="616" data-height="353" ><img src="https://tpucdn.com/img/yVFxLwqYCOc8uZlf_thm.jpg" width="227" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qkSBRZb0pDwJf12T.jpg" target="_blank" data-width="1440" data-height="810" ><img src="https://tpucdn.com/img/qkSBRZb0pDwJf12T_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OkAVLfM7a4YG6zvP.jpg" target="_blank" data-width="616" data-height="353" ><img src="https://tpucdn.com/img/OkAVLfM7a4YG6zvP_thm.jpg" width="227" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Q7ENwEewaXAQJUaW.jpg" target="_blank" data-width="1538" data-height="1080" ><img src="https://tpucdn.com/img/Q7ENwEewaXAQJUaW_thm.jpg" width="185" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301819/intel-arc-gpu-graphics-drivers-31-0-101-3959-released">Read full story</a></div>
(PR) Team Group Launches P845-M80 Industrial M.2 NVMe Gen 4 SSD
Team Group, the global leader in industrial memory modules, launches the brand's first industrial grade PCIe Gen4x4 M.2 2280 SSD, P845-M80. With the adoption of the ultra-fast Gen 4 x4 interface, it delivers an exceptional reading/writing performance for a large data amount. Equipped with BiCS 5 112-layer 3D NAND flash memory, it is a highly cost-competitive solution that accelerates the development of biomedical innovation and digital medicine applications. P845-M80 comes in a maximum capacity of 2 TB and meets the NVMe 2.0 standards. Its bandwidth and data transmission speed are twice that of its predecessor PCIe Gen3, making it even more ideal for the transmission of large amounts of data. Meanwhile, its 3K P/E cycles make it the best memory solution in both performance and durability.<br />
<br />
In the wake of the global pandemic, science and digital medicine is rapidly on the rise in innovative biomedical fields. In response to the significant increase in the demand for high-performance image processing and stable storage, Team Group introduces the PCIe Gen 4 x4 industrial grade SSD with the adoption of an 8-channel controller and optional patented graphene and aluminium fin heat dissipation technologies. It effectively reduces the thermal energy generated from high-speed reading and writing and maintains system stability. The patented graphene heat dissipation technology (US invention patent number: US 110,513,92 B2 / Taiwan invention patent number: I703921) features a small volume and agility in application, suitable for machines of smaller sizes. Whereas, the patented aluminium fin heat dissipation technology (Taiwan utility model patent number: M541645) enables maximum heat dissipation and prolongs product service life. Both technologies are novel options for biomedical innovators, offering stability, high speed, and low latency.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YJaRWyZko7ex7mpl.jpg" target="_blank" data-width="1000" data-height="774" ><img src="https://tpucdn.com/img/YJaRWyZko7ex7mpl_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cs3EwbOMLGxWk39F.jpg" target="_blank" data-width="800" data-height="435" ><img src="https://tpucdn.com/img/cs3EwbOMLGxWk39F_thm.jpg" width="239" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301817/team-group-launches-p845-m80-industrial-m-2-nvme-gen-4-ssd">Read full story</a></div>
Intel Readies "Sapphire Rapids" Based Xeon W HEDT/Wosktation Processors for Q1-2023
Intel is planning a January 2023 market debut of its 4th Gen Xeon Scalable "Sapphire Rapids" server processors, which will be followed rather quickly by the launch of Xeon W-3400 and W-2400 processors targeting a segment of the market that spans HEDTs and workstations. According to information scored by leaf_hobby, a reliable source with Intel roadmap leaks; the company is planning a February 2023 announcement of these processors, followed by availability of the W-2400 in March, and W-3400 in April.<br />
<br />
Intel could extensively market the <a href="https://www.techpowerup.com/299390/intel-outs-first-xeon-scalable-sapphire-rapids-benchmarks-on-package-accelerators-help-catch-up-with-amd-epyc" target="_blank">various hardware-accelerators</a> on the "Sapphire Rapids" MCM to the workstation crowd, where they might help users overcome the rather low CPU core-count of these processors compared their upcoming <a href="https://www.techpowerup.com/301220/amd-zen-4-based-ryzen-threadripper-storm-peak-surfaces-with-96-core-192-thread-config" target="_blank">AMD Threadripper 7000 series</a> counterparts. "Sapphire Rapids" tops out at 60-core/120-thread per socket, whereas the SP5-based Threadripper 7000 is expected to offer 96-core/192-thread. Both platforms offer the latest I/O, including PCIe Gen 5, CXL, and ECC DDR5 memory.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/xThmHjnjaDtkqfgf.jpg" target="_blank" data-width="1100" data-height="732" ><img src="https://tpucdn.com/img/xThmHjnjaDtkqfgf_thm.jpg" width="195" height="130" alt="" /></a></div>
January 5 Release Date Predicted for NVIDIA GeForce RTX 4070 Ti
A January 5, 2023 release date is being mooted by retailers for NVIDIA's upcoming GeForce RTX 4070 Ti graphics card, which is widely expected to be a re-branding of what would have been the RTX 4080 12 GB. Italian retailer Drako started a countdown for an ASUS TUF Gaming RTX 4070 Ti O12G custom-design graphics card, which winds down to January 5, and aligns with the rumored January 3 announcement of the card. It is also expected that reviews of the RTX 4070 Ti will be allowed to go live on January 4.<br />
<br />
The GeForce RTX 4080 12 GB was supposed to max out the 4 nm AD104 silicon, featuring 7,680 CUDA cores across 60 SM (streaming multiprocessors), 60 RT cores, 240 Tensor cores, 240 TMUs, and 80 ROPs. The GPU features a 192-bit wide GDDR6X memory interface, to which NVIDIA is giving 21 Gbps-rated memory, yielding 504 GB/s of memory bandwidth. Its most interesting aspect is its power configuration, with a typical board power of 285 W, which makes it technically possible for board partners to use two 8-pin PCIe power connectors, unless they've been asked nicely to implement the 16-pin 12VHPWR connector.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lPGVqADlczFehhpZ.jpg" target="_blank" data-width="1446" data-height="849" ><img src="https://tpucdn.com/img/lPGVqADlczFehhpZ_thm.jpg" width="221" height="130" alt="" /></a></div>
(PR) Aqua Computer Offers Practical Sealing Frame for Socket AM5 CPUs
German watercooling specialist Aqua Computer offers a practical sealing frame for Socket AM5 CPUs. The flexible frame made of silicone fits perfectly to the bulky outer contour of the heatspreader and effectively prevents thermal paste or liquid metal from getting into these gaps. The sealing frame can withstand very high as well as low temperatures and can also be cleaned easily if necessary, which means it can be used again and again.<br />
<br />
The installation is very simple: The sealing frame is inserted into the processor's lock. Once the locking mechanism is closed, the corners of the sealing frame are carefully pressed into the recesses of the heatspreader with a finger and then the mechanism is being locked.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/TjAp8usYuhb3Pq7b.jpg" target="_blank" data-width="638" data-height="600" ><img src="https://tpucdn.com/img/TjAp8usYuhb3Pq7b_thm.jpg" width="138" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/T5RLIo5scz7GBWrZ.jpg" target="_blank" data-width="665" data-height="600" ><img src="https://tpucdn.com/img/T5RLIo5scz7GBWrZ_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bS7AbaFCQsS6C87Z.jpg" target="_blank" data-width="559" data-height="600" ><img src="https://tpucdn.com/img/bS7AbaFCQsS6C87Z_thm.jpg" width="121" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TO9luZCDAC7pvNRq.jpg" target="_blank" data-width="600" data-height="600" ><img src="https://tpucdn.com/img/TO9luZCDAC7pvNRq_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Jx65qeNEYkadae6G.jpg" target="_blank" data-width="600" data-height="600" ><img src="https://tpucdn.com/img/Jx65qeNEYkadae6G_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301813/aqua-computer-offers-practical-sealing-frame-for-socket-am5-cpus">Read full story</a></div>
Apple and NVIDIA First Customers of TSMC's Arizona Fab
Apple and NVIDIA will be among the first customers of TSMC's swanky new $12 billion semiconductor fab in Arizona, USA. Apple will be the first major player to kick off mass-production in the fab, and will be closely followed by NVIDIA. Both companies plan to produce some of their inventory in Arizona, and ramp proportionately up as the fab grows in capacity. <br />
<br />
The plan with TSMC's Arizona fab was to originally make 5 nm and 4 nm EUV chips, with an output of 20,000 wafers a month, but the company now expects to deploy a more advanced node to keep up with what will be considered cutting-edge when the fab goes live (think 2 nm-class); and also double the output to 40,000 wafers a month. The capacity should ensure Apple and NVIDIA make their most cutting-edge chips on the node (away from Asia), so there could be tighter export controls, and build supply-chain resilience in the face of security problems arising in the Taiwan straits.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/gNbyOJpV13EIUAKg.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/gNbyOJpV13EIUAKg_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) Enterprise SSD Revenue Slid to US$5.22 Billion for 3Q22 and Will Fall by Another 20% for 4Q22
TrendForce reports that the recent easing of tight supply for components has led to rising shipments for enterprise servers. Furthermore, ODMs for the most part have been able to sustain the momentum of data center build-out with the demand from ByteDance and the tenders issued by Chinese telecom companies. Nevertheless, the performance of the enterprise SSD market on the whole has been impacted by falling NAND Flash prices. For 3Q22, the NAND Flash industry's enterprise SSD revenue dropped by 28.7% QoQ to US$5.22 billion. Furthermore, all enterprise SSD suppliers recorded a negative performance for the period as well.<br />
<br />
Regarding individual enterprise SSD suppliers' revenue figures for 3Q22, Samsung posted around US$2.12 billion. Its market share also shrank to 40.6% from 44.5% in 2Q22. Samsung's performance was mainly dragged down by the decline in its NAND Flash ASP. In the aspect of product development, SSDs featuring 128L NAND Flash and PCIe 4.0 will remain Samsung's main offerings for enterprise storage during 2023.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/RJ60d63SbwR59XOE.jpg" target="_blank" data-width="647" data-height="302" ><img src="https://tpucdn.com/img/RJ60d63SbwR59XOE_thm.jpg" width="279" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301802/enterprise-ssd-revenue-slid-to-ususd-5-22-billion-for-3q22-and-will-fall-by-another-20-for-4q22">Read full story</a></div>
(PR) Cooler Master Announces ORB X, a Fully Immersive Multi-Purpose Station, Available for Waitlist Registration
Delicately designed and crafted, the Cooler Master ORB X introduces a whole new level of immersion, comfort, and luxury. With seamless hardware and software integration, ORB X aims to create a premium and private environment for users to immerse in by elevating their visual, audio, and comfort experiences as well as giving a sleek and futuristic appearance that can fit in any occasion such as business, entertainment, or gaming setup.<br />
<br />
ORB X creates an atmosphere of immersion by the semi-enclosed design provided with a fully automated motorized shuttle dome, keeping users away from distractions and enabling an uninterrupted privacy mode for them to focus on what truly matters. Users will have the privilege of selecting either one 34-inch monitor or three 27-inch monitors based on their needs. The surround sound speakers directly housed in the station will give users a realistic, accurate, and dynamic audio experience even without the hassles of wearing headphones for long hours.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/eU3tiemzDh9gnTjJ.jpg" target="_blank" data-width="914" data-height="793" ><img src="https://tpucdn.com/img/eU3tiemzDh9gnTjJ_thm.jpg" width="150" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PCEQA2dJ4bekbC74.jpg" target="_blank" data-width="1073" data-height="960" ><img src="https://tpucdn.com/img/PCEQA2dJ4bekbC74_thm.jpg" width="145" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nRrjo8VeeWYmVUqZ.jpg" target="_blank" data-width="1073" data-height="960" ><img src="https://tpucdn.com/img/nRrjo8VeeWYmVUqZ_thm.jpg" width="145" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yOF7pgMuS2q4NhV7.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/yOF7pgMuS2q4NhV7_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301795/cooler-master-announces-orb-x-a-fully-immersive-multi-purpose-station-available-for-waitlist-registration">Read full story</a></div>
AMD Still Believes in Moore's Law, Unlike NVIDIA
Back in September, NVIDIA's Jensen Huang said that <a href="https://www.techpowerup.com/299159/jensen-huang-tells-the-media-that-moores-law-is-dead" target="_blank">Moore's Law is dead</a>, but it seems like AMD disagrees with NVIDIA, at least for now. According to an interview with AMD's CTO, Mark Papermaster, AMD still believes that Moore's Law will be alive for another six to eight years. However, AMD no longer believes that transistor density can be doubled every 18 to 24 months, while remaining in the same cost envelope. "I can see exciting new transistor technology for the next - as far as you can really plot these things out - about six to eight years, and it's very, very clear to me the advances that we're going to make to keep improving the transistor technology, but they're more expensive," Papermaster said.<br />
<br />
AMD believes we'll see a change in how chips are being designed and put together, with chiplets being the future of semiconductors. Papermaster calls this "a Moore's Law equivalent, meaning that you continue to really double that capability every 18 to 24 months" although it's not exactly Moore's Law in the traditional sense. AMD also appears to be betting heavily on FPGA technology in some of its market segments, for something the company calls adaptive computing. As to how things will play out, time will tell, but with both AMD and Intel going down the chiplet route, albeit in slightly different ways, we should continue to see new innovations from both companies, with or without Moore's Law.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XpDYPkKBxOvrsX4A.jpg" target="_blank" data-width="1024" data-height="576" ><img src="https://tpucdn.com/img/XpDYPkKBxOvrsX4A_thm.jpg" width="231" height="130" alt="" /></a></div>
Intel Plans Slew of "Raptor Lake" Product Announcements on January 3
January 3, 2023, on the sidelines of the International CES, Intel could launch dozens upon dozens of 13th Gen Core processor SKUs spanning every conceivable client PC platform. The event is expected to bring "Raptor Lake" to the mobile platform, with announcements spanning the ultra-portable "Raptor Lake-U," the thin-and-light performance "Raptor Lake-P," the mainstream mobile "Raptor Lake-H," and the enthusiast mobile "Raptor Lake-HX." This would cover almost every mobile device segment, including 7-9 W U-segment, to the 15-28 W P-segment, the 35-45 W H-segment, and the >55 W HX-segment, with several SKUs per segment across the four brand extensions (Core i3 thru Core i9).<br />
<br />
For the desktop platform, Intel is expected to announce its new Core i9-13900KS "Raptor Lake-S" flagship, the world's first 6 GHz processor, besides a large number of 13th Gen Core "Raptor Lake-S" non-K SKUs in the 65 W TDP class, forming the bulk of the company's desktop processor lineup. Besides these, the company will also announce the more affordable Intel H770 and B760 desktop motherboard chipsets, bringing down platform costs (the 13th Gen Core processors are already supported on inexpensive motherboards based on the B660 and H670 chipsets via a BIOS update). Lastly, the company could announce "Raptor Lake" processors for the workstation segment, possibly compatible with the W780 chipset, and supporting ECC DDR5 memory, among other features relevant to the commercial desktop and workstation segments.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CEO3FF3iEtQnzBxQ.jpg" target="_blank" data-width="1500" data-height="930" ><img src="https://tpucdn.com/img/CEO3FF3iEtQnzBxQ_thm.jpg" width="210" height="130" alt="" /></a></div>
NVIDIA GeForce RTX 4080 Could Get a Price Cut to Better Compete with RDNA3
NVIDIA GeForce RTX 4080 graphics card has been out since mid-November and is a great performer in many resolutions and titles. However, with NVIDIA setting its price tag at $1200, it is an expensive product to afford and represents a considerable price jump compared to older xx80 GPU generations. According to MyDrivers, NVIDIA could lower the price starting in mid-December, to better suit the needs of consumers and have a competitive product. With AMD's RDNA3-based graphics cards releasing in the following days, the Radeon RX 7900 XTX costing $999 is a direct competitor to GeForce RTX 4080. If NVIDIA plans to cut the massive MSRP of the RTX 4080, then we expect it to be in the range of Radeon RX 7900 XTX to create better market competition.<br />
<br />
Of course, this is only wishful thinking and a rumor that MyDrivers has reported, so we have to wait until the middle of this month to find out if NVIDIA announces the alleged price cut.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/AiXaqsC0zG0wfaiC.jpg" target="_blank" data-width="1144" data-height="720" ><img src="https://tpucdn.com/img/AiXaqsC0zG0wfaiC_thm.jpg" width="207" height="130" alt="" /></a></div>
(PR) Knights of Honor II: Sovereign Shows Detailed Gameplay Ahead of L
Tomorrow is your coronation day, Sovereigns! Knights of Honor II: Sovereign is launching, and today's video presents all aspects of the game in a play session from developers Black Sea Games. As rulers of the small Spanish kingdom of Aragon, they attempt to gain control over the whole of Spain - but must overcome many obstacles, including a tragic death. Check out how - and if - they can manage to regain their strength.<br />
<br />
Choose your kingdom and be the king as you wrestle over control of Europe in this fresh take on medieval real-time grand strategy. Knights of Honor II: Sovereign includes all the depth players desire while being the gate-way game to the grand strategy genre, presenting the world as a living, breathing miniature, alive and ripe for the taking. Choose your royal court carefully and determine the destiny of your people, be it riches, conquest, intrigue, trade, or defeat! Raise armies to defend your lands or take war to the enemy - even jump into battle directly in action-packed RTS combat. The path is open: become the true Sovereign of your people.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fPkV4h5E2cvjE3ft.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/fPkV4h5E2cvjE3ft_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ydrl2abXfYYI60sL.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/ydrl2abXfYYI60sL_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yUr9v14dC7ojtf5n.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/yUr9v14dC7ojtf5n_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TtfiIX8K8jsahfut.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/TtfiIX8K8jsahfut_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301786/knights-of-honor-ii-sovereign-shows-detailed-gameplay-ahead-of-launch">Read full story</a></div>
(PR) Nfina Technologies Releases 3rd Gen Intel Xeon Scalable Processor-based Systems
Nfina announces the addition of three new server systems to its lineup, customized for hybrid/multi-cloud, hyperconverged HA infrastructure, HPC, backup/disaster recovery, and business storage solutions. Featuring 3rd Gen Intel Xeon Scalable Processors, Nfina-Store, and Nfina-View software, these scalable server systems fill a void in the marketplace, bringing exceptional multi-socket processing performance, easy-to-use management tools, built-in backup, and rapid disaster recovery. <br />
<br />
"We know we must build systems for the business IT needs of today while planning for unknown future demands. Flexible infrastructure is key, optimized for hybrid/multi-cloud, backup/disaster recovery, HPC, and growing storage needs," says Warren Nicholson, President, and CEO of Nfina. He continues by saying, "Flexible infrastructure also means offering managed services like IaaS, DRaaS, etc., that provide customers with choices that fit the size of their application and budget - not a one size fits all approach like many of our competitors. Our goal is to serve many different business IT applications, any size, anywhere, at any time."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JqAXbIxEF1koygzh.jpg" target="_blank" data-width="2700" data-height="834" ><img src="https://tpucdn.com/img/JqAXbIxEF1koygzh_thm.jpg" width="421" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7wNGgvKKLBjGHXIj.jpg" target="_blank" data-width="2700" data-height="1265" ><img src="https://tpucdn.com/img/7wNGgvKKLBjGHXIj_thm.jpg" width="277" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301784/nfina-technologies-releases-3rd-gen-intel-xeon-scalable-processor-based-systems">Read full story</a></div>
Thermalright Outs Assassin X 90 SE Compact Tower-type CPU Cooler
Thermalright today introduced the Assassin X 90 SE, a compact tower-type CPU cooler designed to replace the stock CPU cooling solution with something that's quieter at stock frequencies. The aluminium fin tower-type cooler features a typical design for its kind—four 6 mm-thick nickel-plated copper heat pipes make direct contact with the CPU at an aluminium base; with their ends passing through an aluminium fin-stack that's capped off by a die-case top-plate. This is then ventilated by an included Thermalright TL-G9B 92 mm PWM fan.<br />
<br />
The defining feature is the cooler's height of just 118 mm. With its fan in place, the cooler measures 94 mm x 77 mm x 118 mm, weighing 445 g. The included 92 mm fan features fluid dynamic bearing, takes in 4-pin PWM input, turns at speeds of up to 2,400 RPM, pushing up to 43 CFM of airflow at 1.51 mm H₂O pressure, and has a noise output of 27.3 dBA. Among the CPU socket types supported are LGA1700, AM5, AM4, and LGA1200. The company didn't reveal pricing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qMqcXYUYPLTvETI3.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/qMqcXYUYPLTvETI3_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mmZNvEPfTtKg2COb.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/mmZNvEPfTtKg2COb_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/n9X13CyV8ZOZufnd.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/n9X13CyV8ZOZufnd_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hcuCBwt7E4qU7qDt.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/hcuCBwt7E4qU7qDt_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xNhDXirYst6sLqji.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/xNhDXirYst6sLqji_thm.jpg" width="130" height="130" alt="" /></a></div>
Samsung Launches the ViewFinity S8UT 4K Monitor with Thunderbolt Support
This year has seen the arrival of a lot of Thunderbolt connected monitors and Samsung is joining the fray with a new model, the ViewFinity S8UT. The 27-inch 4K IPS monitor is very much an office model, as it only has a 60 Hz refresh rate with a 5 ms response time (GtG). The panel is edge lit and has a typical brightness of 350 cd/m² and a contrast ratio of 1000:1. The monitor supports Picture-by-Picture and Picture-in-Picture, courtesy of multiple inputs.<br />
<br />
The interesting part of this monitor is the Thunderbolt 3 connectivity, as the main port can output 90 W for charging a connected laptop, while the secondary port can deliver 15 W. The monitor supports Thunderbolt daisy chaining, which isn't a common feature on monitors. The S8UT also sports an HDMI 2.0 port, a three port USB 3.0 hub, a Gigabit Ethernet port and a 3.5 mm headphone socket, as well as a pair of integrated stereo speakers. The stand supports pivot, swivel, tilt and height adjustment. The S8UT comes with a three year warranty, but there's currently no word on pricing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/eApKnj7tCEvGX5zW.jpg" target="_blank" data-width="1440" data-height="822" ><img src="https://tpucdn.com/img/eApKnj7tCEvGX5zW_thm.jpg" width="228" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ErDeRPxCnHXyOvA7.jpg" target="_blank" data-width="730" data-height="567" ><img src="https://tpucdn.com/img/ErDeRPxCnHXyOvA7_thm.jpg" width="167" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/r6xa5zGmB69GuR3z.jpg" target="_blank" data-width="684" data-height="347" ><img src="https://tpucdn.com/img/r6xa5zGmB69GuR3z_thm.jpg" width="256" height="130" alt="" /></a></div>
(PR) Global Top 10 Foundries' Total Revenue Grew by 6% QoQ for 3Q22, b
According to TrendForce's research, the total revenue of the global top 10 foundries rose by 6% QoQ to US$35.21 billion for 3Q22 as the release of the new iPhone series during the second half of the year generated significant stock-up activities across Apple's supply chain. However, the global economy shows weak performances, and factors such as China's policy on containing COVID-19 outbreaks and high inflation continue to impact consumer confidence. As a result, peak-season demand in the second half of the year has been underwhelming, and inventory consumption is proceeding slower than anticipated. This situation has led to substantial downward corrections to foundry orders as well. For 4Q22, TrendForce forecasts that the total revenue of the global top 10 foundries will register a QoQ decline, thereby terminating the boom of the past two years—when there was an uninterrupted trend of QoQ revenue growth.<br />
<br />
Regarding individual foundries' performances in 3Q22, the group of the top five was led by TSMC, followed by Samsung, UMC, GlobalFoundries, and SMIC. Their collective global market share (in revenue terms) came to 89.6%. Most foundries were directly impacted by clients slowing down their stock-up activities or significantly correcting down their orders. Only TSMC was able to make a notable gain due to Apple's strong stock-up demand for the SoCs deployed in this year's new iPhone models. TSMC saw its revenue rise by 11.1% QoQ to US$20.16 billion, and the corresponding market share expanded to 56.1%. The growth was mainly attributed to the ≤7 nm nodes, whose share in the foundry's revenue had kept climbing and reached 54% in the third quarter. Conversely, Samsung actually experienced a slight QoQ drop of 0.1% in foundry revenue even though it had also benefited from the component demand related to the new iPhone series. Partially impacted by the weakening of the Korean won, Samsung's market share fell to 15.5%.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fkfJgOAfcxLhYzah.jpg" target="_blank" data-width="528" data-height="483" ><img src="https://tpucdn.com/img/fkfJgOAfcxLhYzah_thm.jpg" width="142" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301920/global-top-10-foundries-total-revenue-grew-by-6-qoq-for-3q22-but-foundry-industrys-revenue-performance-will-enter-correction-period-in-4q22">Read full story</a></div>
(PR) Listan Group Acquires MOUNTAIN
The global Listan group of companies continues its impressive success story and announces today, with great pleasure, the acquisition of the innovative premium peripheral brand MOUNTAIN. The full acquisition makes MOUNTAIN the third wholly owned subsidiary alongside the popular products of be quiet! and Xilence brands. With MOUNTAIN as a brand for peripherals, the Listan Group expands into the category of high-quality input devices. <br />
<br />
MOUNTAIN was founded in 2018 and was able to raise the bar in 2020 with its trend-setting Everest Max keyboard. Since then, MOUNTAIN has received hundreds of endorsements and awards from leading tech and gaming media around the world. Not to mention increased attention from influencers on YouTube, TikTok, Instagram and Twitch. The Makalu 67 lightweight gaming mouse was praised for its innovative exceptional design and, like the Everest Max, won the iF Design Award 2021. In October 2022, MOUNTAIN launched the DisplayPad and MacroPad. These are software-enabled controllers for streaming and content creation that further expand MOUNTAIN's ecosystem and customer reach.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/POhohhqkBF2O1TT1.jpg" target="_blank" data-width="1300" data-height="667" ><img src="https://tpucdn.com/img/POhohhqkBF2O1TT1_thm.jpg" width="253" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301919/listan-group-acquires-mountain">Read full story</a></div>
NVIDIA Releases GeForce 527.56 WHQL Game Ready Drivers
NVIDIA today released the latest version of its GeForce Game Ready drivers. Version 527.56 WHQL comes with optimization for Portal with RTX, a remaster of the cult classic with enhanced with NVIDIA RTX, which <a href="https://www.techpowerup.com/review/portal-with-rtx/" target="_blank">we took for a spin</a>. Besides, the new drivers also add optimization for The Witcher 3 Wildhunt Enhanced Edition, which will debut later this month, and Jurassic World Evolution 2. Among the issues fixed with this release include flickering noticed when looking at the sky in Watch_Dogs 2, on machines powered by RTX 4090; games with DLSS 3 crashing when ending a recording using Shadowplay or OBS with NVENC; display corruption noticed in Minecraft Java Edition, hotplugging between HDMI and DP not working correctly on RTX 4090; and certain issues with Adobe Premiere with H.265 and HEVC content.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/" target="_blank">NVIDIA GeForce 527.56 WHQL</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/x3Sfqv3Gxytvd1Jd.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/x3Sfqv3Gxytvd1Jd_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fV2jAdQyF0iYLiBX.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/fV2jAdQyF0iYLiBX_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8HKpNuJ2eHYaAFZ4.jpg" target="_blank" data-width="616" data-height="353" ><img src="https://tpucdn.com/img/8HKpNuJ2eHYaAFZ4_thm.jpg" width="227" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301916/nvidia-releases-geforce-527-56-whql-game-ready-drivers">Read full story</a></div>
(PR) Audeze Releases New Maxwell Wireless Gaming Headset for PCs and Consoles
Audeze, the leading audio technology brand and pioneer of high-end gaming audio products, today announces Maxwell, a new ultra-low-latency wireless PC & console gaming headset with class-leading 80+ hours of battery life. Two versions of Maxwell will be available: Maxwell for Xbox & PC is officially licensed by Microsoft and includes the first auto-activating Dolby Atmos license, while Maxwell for Playstation & PC supports Tempest 3D Audio. Maxwell is the latest release from Audeze in a line of purpose-built gaming headsets like the LCD-GX and Mobius which have garnered rave reviews for their innovations in audio performance and headtracking.<br />
<br />
Connect and game anywhere, without limitations. Maxwell provides ultra-low-latency, high-resolution audio up to 24-bit 96 kHz when connected to the included USB dongle. Low-latency wireless range and stability are improved up to 3X from the award-winning Audeze Penrose headset. Maxwell features many wired and wireless connection options including the latest Bluetooth 5.3 LE Audio technology, supporting the LC3 and LC3plus codecs. In addition, Maxwell supports classic Bluetooth codecs like SBC, AAC and LDAC for high-quality portable audio. Maxwell also supports lossless high-resolution audio up to 24-bit 96 kHz over wired USB.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6gHsuL3yEoD7Cagj.jpg" target="_blank" data-width="820" data-height="960" ><img src="https://tpucdn.com/img/6gHsuL3yEoD7Cagj_thm.jpg" width="111" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tl9WQv3eANlLff68.jpg" target="_blank" data-width="1444" data-height="960" ><img src="https://tpucdn.com/img/tl9WQv3eANlLff68_thm.jpg" width="196" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TxYEV2ZaPlcgUtfH.jpg" target="_blank" data-width="1041" data-height="960" ><img src="https://tpucdn.com/img/TxYEV2ZaPlcgUtfH_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rOmiyn8jtmDPqt5Z.jpg" target="_blank" data-width="919" data-height="960" ><img src="https://tpucdn.com/img/rOmiyn8jtmDPqt5Z_thm.jpg" width="124" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cB7JGMppN4QEiBo0.jpg" target="_blank" data-width="1488" data-height="960" ><img src="https://tpucdn.com/img/cB7JGMppN4QEiBo0_thm.jpg" width="202" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Rn4cJ2Q4qqzEfM5G.jpg" target="_blank" data-width="1374" data-height="960" ><img src="https://tpucdn.com/img/Rn4cJ2Q4qqzEfM5G_thm.jpg" width="186" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301891/audeze-releases-new-maxwell-wireless-gaming-headset-for-pcs-and-consoles">Read full story</a></div>
(PR) ASRock Launches AMD Radeon RX 7900 Series Graphics Cards Unlock Your Gaming Power and Creativity
ASRock, the leading global motherboard, graphics card and mini PC manufacturer, today launched the new AQUA, Taichi and Phantom Gaming series graphics cards based on AMD Radeon RX 7900 Series GPUs.<br />
<br />
The new graphics cards are built on the groundbreaking AMD RDNA 3 architecture with chiplet technology. AMD RDNA 3 architecture delivers up to 54% more performance per watt than AMD RDNA 2, features the world's fastest interconnect linking the graphics and memory system chiplets at up to 5.3 TB/s, and offers up to 96 new unified compute units and second-generation AMD Infinity Cache technology. It also delivers increased AI throughput that provides up to 2.7X higher AI performance, and rearchitected compute units with second-generation ray tracing technology that provides up to 1.8X higher ray tracing architectural performance in select titles versus AMD RDNA 2 architecture.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/QF8jbfSARwWx7F8n.jpg" target="_blank" data-width="1200" data-height="600" ><img src="https://tpucdn.com/img/QF8jbfSARwWx7F8n_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MdavddBZTWCikIM0.jpg" target="_blank" data-width="1152" data-height="960" ><img src="https://tpucdn.com/img/MdavddBZTWCikIM0_thm.jpg" width="156" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CZp08luMR0oEpvtb.jpg" target="_blank" data-width="1152" data-height="960" ><img src="https://tpucdn.com/img/CZp08luMR0oEpvtb_thm.jpg" width="156" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iZTGiHnPlVrRDBys.jpg" target="_blank" data-width="1152" data-height="960" ><img src="https://tpucdn.com/img/iZTGiHnPlVrRDBys_thm.jpg" width="156" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301911/asrock-launches-amd-radeon-rx-7900-series-graphics-cards-unlock-your-gaming-power-and-creativity">Read full story</a></div>
(PR) Alphacool Announces Eisbaer Pro HPE Aurora AIO CPU Cooler
The multi-talent from Alphacool, the Eisbaer Pro Aurora CPU AIO has received an upgrade! It is now available with the extremely powerful NexXxos HPE radiator. This improvement enables even processors with particularly large CPU cores to be cooled even more effectively. The included mounting kit allows high compatibility with all common sockets, including the new AMD AM5.<br />
<br />
The NexXxos HPE radiator uses the same materials as the previous NexXxos models, but goes a step further technically. Due to the condensed internal structure, the number of water channels and copper fins has been increased. Thus, a larger volume of water is in direct contact with the cooling fins and the heat transfer is improved enormously. Alphacool continues to use the Rise Aurora 120 mm fan. The fan, which can be controlled via PWM, is almost silent at 800 rpm, but still offers a good air throughput together with a high static pressure. The cooler as well as the fans feature digitally addressable RGB LEDs, allowing for a brilliant illumination.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qiI7xyd91nKjsav2.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/qiI7xyd91nKjsav2_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8ppNecrwgH2CgCOU.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/8ppNecrwgH2CgCOU_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3hyGRbWtHgkUDw3D.jpg" target="_blank" data-width="1301" data-height="1000" ><img src="https://tpucdn.com/img/3hyGRbWtHgkUDw3D_thm.jpg" width="169" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/807PdQS3AXHKdFxc.jpg" target="_blank" data-width="1363" data-height="1000" ><img src="https://tpucdn.com/img/807PdQS3AXHKdFxc_thm.jpg" width="177" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VhzqKWYWPpNEr0Bu.jpg" target="_blank" data-width="1592" data-height="1000" ><img src="https://tpucdn.com/img/VhzqKWYWPpNEr0Bu_thm.jpg" width="207" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301910/alphacool-announces-eisbaer-pro-hpe-aurora-aio-cpu-cooler">Read full story</a></div>
(PR) SK hynix Develops MCR DIMM, World's Fastest Server Memory Module
SK hynix Inc. announced today that it has developed working samples of DDR5 Multiplexer Combined Ranks (MCR) Dual In-line Memory Module, the world's fastest server DRAM product. The new product has been confirmed to operate at the data rate of minimum 8 Gbps, and at least 80% faster than 4.8 Gbps of the existing DDR5 products. MCR DIMM is an achievement coming from out-of-the-box thinking with an aim to improve the operation speed of DDR5. Challenging the prevailing concept that the operation speed of DDR5 relies on that of DRAM chip itself, engineers sought to find a way to improve the speed of modules instead of chips for development of the latest product.<br />
<br />
SK hynix designed the product in a way that enables simultaneous operation of two ranks by utilizing the data buffer installed onto the MCR DIMM based on Intel's MCR technology. By enabling simultaneous operation of two ranks, MCR DIMM allows transmission of 128 bytes of data to CPU at once, compared with 64 bytes fetched generally in conventional DRAM module. An increase in the amount of data sent to the CPU each time supports the data transfer rate of minimum 8 Gbps, twice as fast as a single DRAM.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Xl9W46nE8FJEENbA.jpg" target="_blank" data-width="1421" data-height="900" ><img src="https://tpucdn.com/img/Xl9W46nE8FJEENbA_thm.jpg" width="205" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SlFSMO8Yapa9rIzd.jpg" target="_blank" data-width="1458" data-height="900" ><img src="https://tpucdn.com/img/SlFSMO8Yapa9rIzd_thm.jpg" width="211" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mKBwfPFnmyvmypes.jpg" target="_blank" data-width="1379" data-height="776" ><img src="https://tpucdn.com/img/mKBwfPFnmyvmypes_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301909/sk-hynix-develops-mcr-dimm-worlds-fastest-server-memory-module">Read full story</a></div>
(PR) Micron Delivers the World's Most Advanced Client SSD Featuring 232-Layer NAND Technology
Micron Technology, Inc.,, today announced it is shipping the Micron 2550 NVMe SSD to global PC OEM customers for use in mainstream laptops and desktops. The 2550 is the world's first client SSD to ship using NAND over 200 layers. Delivering performance that eclipses the competition through its density and power advantages, the 2550 provides users with responsiveness and the low power consumption needed to extend battery life for work and home PCs.<br />
<br />
"We focused on delivering a superior user experience for PC users with this SSD," said Praveen Vaidyanathan, vice president and general manager of the Client Storage Group at Micron. "The new 2550 SSD builds on our established and broadly adopted PCIe Gen4 architecture. It also incorporates Micron's industry-leading 232-layer NAND and focuses on thermal architecture and power design. These capabilities deliver impressive application performance and phenomenal power savings."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Duby9HeXH9Gwxfb5.jpg" target="_blank" data-width="1116" data-height="689" ><img src="https://tpucdn.com/img/Duby9HeXH9Gwxfb5_thm.jpg" width="211" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301881/micron-delivers-the-worlds-most-advanced-client-ssd-featuring-232-layer-nand-technology">Read full story</a></div>
(PR) Campfire Audio Launches Orbit: Their First True Wireless Earphones
Hot on the heels of releasing Trifecta - Campfire Audio's most ambitious wired IEM to date - the team has now decided to turn their attention to the world of wireless. Introducing Orbit, Campfire Audio's first ever true wireless earphone. Orbit is the culmination of years of meticulous design and engineering, resulting in a true wireless like no other. Every part of the process has been approached with passion and creativity to produce something unique - in typical Campfire Audio fashion. From December 7th, Orbit will be available to buy for $249/£249 from <a rel="nofollow" href="https://campfireaudio.com/" target="_blank">campfireaudio.com</a>, Amazon and selected retailers worldwide.<br />
<br />
Campfire Audio are masters of their craft, known in the high-end audio space for their bombastic designs, eye-catching artwork and most importantly - sound quality that transports you to another dimension. Orbit brings Campfire Audio's experience and love for what they do to the true wireless market - a fresh and well needed arrival. This is a completely new design for Campfire Audio, with Orbit's two-tone housings shaped in a way that makes them extremely comfortable. The design is also robust, with a stainless-steel sound nozzle and grille. This not only looks impressive; this adds to the solid feel of these earbuds. The touch controls are easy to use, and taking calls is equally impressive due to the built-in high-quality microphone.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/EGVDYbMEmsetd8EF.jpg" target="_blank" data-width="972" data-height="960" ><img src="https://tpucdn.com/img/EGVDYbMEmsetd8EF_thm.jpg" width="132" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/u4xcQHR5YqPUnRNf.jpg" target="_blank" data-width="1301" data-height="960" ><img src="https://tpucdn.com/img/u4xcQHR5YqPUnRNf_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sirLfbx59Tbrlp2E.jpg" target="_blank" data-width="1042" data-height="960" ><img src="https://tpucdn.com/img/sirLfbx59Tbrlp2E_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TAJpafVdZVvXKmZ0.jpg" target="_blank" data-width="1143" data-height="960" ><img src="https://tpucdn.com/img/TAJpafVdZVvXKmZ0_thm.jpg" width="155" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2WFrKWTYTKKHSKfe.jpg" target="_blank" data-width="1194" data-height="960" ><img src="https://tpucdn.com/img/2WFrKWTYTKKHSKfe_thm.jpg" width="162" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QpH8I5JnnLUJjbRO.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/QpH8I5JnnLUJjbRO_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301869/campfire-audio-launches-orbit-their-first-true-wireless-earphones">Read full story</a></div>
(PR) Smartphone Production Fell to About 289 Million Units for 3Q22 as Demand Was Not Sufficient to Offset Inventory Pressure and Economic Headwinds
According to TrendForce's latest research, global smartphone production totaled around 289 million units for 3Q22, showing a slight QoQ drop of 0.9% and a YoY drop of 11%. The smartphone market thus exhibited an extremely weak demand situation as the "iron law" of positive growth in the third quarter was broken after being in effect for years. The contraction of smartphone production during this year's peak season was mainly attributed to smartphone brands giving priority to consumption of channel inventory for whole devices and maintaining a fairly conservative production plan for 3Q22. Moreover, they had kept lowering their production targets due to strong global economic headwinds.<br />
<br />
Regarding the performances of the major smartphone brands in 3Q22, Samsung posted around 64.2 million units in device production, showing a QoQ increase of just 3.9%. This was the result of the brand scaling back production since 2Q22 and maintaining a conservative outlook on the future market situation. Due to persistent inventory pressure, Samsung is expected to again post a QoQ decline for 4Q22. In the aspect of product development, Samsung has been the leader in foldable smartphones. This year, the global market share of foldable smartphones is estimated to reach 1.1%; and within this segment, Samsung is expected to hold a market share of almost 90%. As for 2023, the global market share of foldable smartphones is forecasted to climb to 1.5%, and Samsung is forecasted to retain a market share of almost 80% in the segment.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/yK1Mq1E0ZeCD63Eb.jpg" target="_blank" data-width="545" data-height="240" ><img src="https://tpucdn.com/img/yK1Mq1E0ZeCD63Eb_thm.jpg" width="295" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301880/smartphone-production-fell-to-about-289-million-units-for-3q22-as-demand-was-not-sufficient-to-offset-inventory-pressure-and-economic-headwinds">Read full story</a></div>
(PR) Fractal Design Introduces the North Mid-tower Case with Wooden Elements
North helps to reimagine the gaming station, introducing natural materials and bespoke details for a case which integrates stylishly into the living space. Merging design and airflow engineering, the case features fine-patterned mesh ventilation and an open front with real walnut or oak panels. The design is complemented by sleek brass or steel details and an integrated tab for easy access to the top of the case.<br />
<br />
Developed for an enjoyable building and gaming experience, North offers an intuitive interior layout and generous compatibility. It supports GPUs up to a length of 355 mm, or up to 300 mm with a 360 mm front radiator. For a smooth start, it includes two 140 mm Aspect PWM fans, a USB-C port and drive mounts for up to four 2.5" drives and two 3.5" drives out of the box.<br />
<br />
[Editor's note: Our <a href="https://www.techpowerup.com/review/fractal-design-north/" target="_blank">in-depth review of the Fractal Design North</a> is now live]<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ESszB3GzdNjgLyuH.jpg" target="_blank" data-width="1358" data-height="960" ><img src="https://tpucdn.com/img/ESszB3GzdNjgLyuH_thm.jpg" width="184" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eFk1cJKncg2Tx9zN.jpg" target="_blank" data-width="1358" data-height="960" ><img src="https://tpucdn.com/img/eFk1cJKncg2Tx9zN_thm.jpg" width="184" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pE0r1GDnmKXwdxcr.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/pE0r1GDnmKXwdxcr_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xvwAUdbj3ZDXt0tG.jpg" target="_blank" data-width="1358" data-height="960" ><img src="https://tpucdn.com/img/xvwAUdbj3ZDXt0tG_thm.jpg" width="184" height="130" alt="" /></a></div>
ASRock and XFX Radeon RX 7900-series Custom Design Cards Leak
As we're getting closer to the official launch date, pictures of AMD Radeon RX 7900-series cards from both ASRock and XFX have tipped up online. The ASRock cards are part of its Phantom Gaming and Taichi series of cards, whereas the XFX card is part of the MERC line. Sadly none of the cards appear to sport a USB-C port, suggesting that it's not a feature that any of the OEM's have thought worthwhile to include in their custom board designs. <br />
<br />
The ASRock Phantom Gaming cards appear to be 2.5-slot cards, whereas the Taichi cards are triple slot. The Phantom Gaming cards seem to be equipped with a short backplate that only covers the rear of the PCB, rather than the full length of the card, with the Taichi cards seemingly having a full-length backplate. The XFX MERC 310 also appears to be a 2.5-slot design, but it has a very different backplate design which appears to act much more as a heatsink than most backplate designs we've seen to date. The fact that it appears to be made of a large chunk of aluminium that wraps around the back edge of the card is also rather unusual. XFX also appears to have gone with the same size for its RX 7900 XT and RX 7900 XTX cards. We can also see that XFX has gone for three 8-pin power connectors for their cards.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/E5oZc2Ii9c11mEtf.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/E5oZc2Ii9c11mEtf_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NJ7rkTL5XVDDsdOU.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/NJ7rkTL5XVDDsdOU_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uFJO1pS4A8XV0WyC.jpg" target="_blank" data-width="1109" data-height="1136" ><img src="https://tpucdn.com/img/uFJO1pS4A8XV0WyC_thm.jpg" width="127" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZUwf86YNGsUN2q2g.jpg" target="_blank" data-width="1110" data-height="1136" ><img src="https://tpucdn.com/img/ZUwf86YNGsUN2q2g_thm.jpg" width="127" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PqZm4KGAQOsfm2Rb.jpg" target="_blank" data-width="1280" data-height="732" ><img src="https://tpucdn.com/img/PqZm4KGAQOsfm2Rb_thm.jpg" width="227" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301872/asrock-and-xfx-radeon-rx-7900-series-custom-design-cards-leak">Read full story</a></div>
ASRock Radeon RX 7900 XTX AQUA Liquid Cooled Graphics Card Pictured
Here's the first picture of the ASRock Radeon RX 7900 XTX AQUA, marking the debut of the company's top-of-the-line AQUA brand to its graphics card lineup. The ASRock AQUA line of motherboards come with liquid monoblocks that let you cool the processor, chipset, and CPU VRM using your own DIY liquid-cooling loop. The Radeon RX 7900 XTX comes with a factory-fitted full-coverage water block. The OEM of this block is unknown (could be either CoolIT or Bitspower). The block features a nickel-plated copper primary material, with an acrylic top and vinyl film for the brushed-aluminium look. The top is studded with addressable RGB LEDs. The block sits on top of ASRock's most premium custom-design PCB for the RX 7900 XTX, which pulls power from three 8-pin PCIe power connectors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/voZbPXXDsZpSqEax.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/voZbPXXDsZpSqEax_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hGE1P81OfzWXm4xt.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/hGE1P81OfzWXm4xt_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2azP1HsfX11VVlD0.jpg" target="_blank" data-width="1200" data-height="463" ><img src="https://tpucdn.com/img/2azP1HsfX11VVlD0_thm.jpg" width="337" height="130" alt="" /></a></div>
Alphacool Wants to Award Your Ugliest Christmas Outfits With Another Ugly Sweater!
We don't typically cover holiday promotions but this one tickled my schadenfreude bone too much to be ignored. Alphacool decided to cause havoc today by inviting photos of you wearing your ugliest Christmas outfits/accessories in return for a chance to win one of three €1000 vouchers for Alphacool products or five hideously ugly Christmas jumpers/sweaters/hoodies/whatever you want to call them. If interested, you can enter the competition via the company's social media channels on Facebook, Instagram and Twitter as well as by sending an email to [Only registered and activated users can see links. Click Here To Register...]. While it's not part of the competition, I would certainly like to see you share those photos in the comments section too!<div class="imgcontainer"><a href="https://www.techpowerup.com/img/h61TP2DGFpNbFYZW.jpg" target="_blank" data-width="1827" data-height="960" ><img src="https://tpucdn.com/img/h61TP2DGFpNbFYZW_thm.jpg" width="247" height="130" alt="" /></a></div>
Seagate Mechanical HDD with U.2 NVMe Interface Pictured, Signals the Decline of SAS 12G
Here's one of the first pictures of a mechanical HDD with NVMe interface. Seagate is apparently in production of an Exos-series Enterprise HDD featuring U.2 NVMe interface where one would expect SAS 12 Gbps. We seriously doubt if the HDD is fast enough to take advantage of U.2 NVMe (at least 32 Gbps per direction), but the move to NVMe probably has to do with the decline of older interface standards such as SAS 12 Gbps and SATA 6 Gbps in the enterprise space for cold-storage, and that future generations of rackmount DAS and NAS enclosures could increasingly feature U.2 backplanes, phasing out SAS and SATA. This is like when optical drives switched over to SATA despite not needing the bandwidth SATA had to offer (optical discs barely move a few dozen MB/s, for which even ATA33 IDE was sufficient). We don't know how the Seagate Exos drive handles NVMe internally—whether there is a new native NVMe controller, or whether this is really just a SAS 12 Gbps drive with a PCIe-to-SAS bridge chip.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/VBMyvvXfnw6ZLj7C.jpg" target="_blank" data-width="540" data-height="720" ><img src="https://tpucdn.com/img/VBMyvvXfnw6ZLj7C_thm.jpg" width="98" height="130" alt="" /></a></div>
ICYMI, Intel Improved DirectX 9 API Performance for Arc "Alchemist" GPUs Spanning Several Popular Game Titles
Intel Arc "Alchemist" graphics architecture was originally developed as a forward-facing PC GPU architecture with many of the contemporary graphics technologies, including full DirectX 12 Ultimate support, however, the GPU curiously <a href="https://www.techpowerup.com/297806/intel-xe-igpus-and-arc-graphics-lack-directx-9-support-rely-on-api-translation-to-play-older-games" target="_blank">lacks hardware support</a> for DirectX 9. Released 20 years ago, DirectX 9 continued to power AAA PC titles well into the 2010s as game console development lagged (the era of Xbox 360 and PlayStation 3), and most e-sports titles of the time included either native or fallback DirectX 9 support for those on older GPUs. This is a problem for Intel, as many of the currently-popular e-Sports titles may still use DirectX 9, and so the Intel Graphics team set out to individually optimize DirectX 9 titles with each new Arc GPU driver release.<br />
<br />
While Arc GPUs lack DirectX 9 support, foolproof API translation technologies exist, which convert DirectX 9 API instructions into DirectX 12. This is not fundamentally unlike how 32-bit applications work on 64-bit Windows (using WOW64 machine-architecture translation). This, however, requires per-game optimization to ensure any engine-level special features are correctly translated. With the latest 101.3959 Beta drivers, Intel optimized popular DirectX 9 titles "League of Legends," "Counter Strike: Global Offensive," "Starcraft 2," "Payday 2," "Guild Wars 2," "Stellaris," "NiZhan," and "Moonlight Blade." The company seems to be going about this the smart way, by relying on market analysis for selecting the games in need of optimization (understanding what DirectX 9 games are still being played).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KA7lE3p9ETvkN8kl.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/KA7lE3p9ETvkN8kl_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rDSmQc3aaz2ajKFC.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/rDSmQc3aaz2ajKFC_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9C9A26Oz6cfc66EE.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/9C9A26Oz6cfc66EE_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4knmdbs4kNKpqThs.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/4knmdbs4kNKpqThs_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301865/icymi-intel-improved-directx-9-api-performance-for-arc-alchemist-gpus-spanning-several-popular-game-titles">Read full story</a></div>
(PR) Phison 8 TB SSD Ready for Historic Liftoff After Earning NASA Certification
Phison Electronics Corp., a global leader in NAND flash and storage solutions, announced today that its 8 TB M.2 2280 SSD solution has completed flight qualification tests required for Lonestar Data Holdings' historic first lunar data center mission. This SSD has been selected by Lonestar's contractor and Phison's partner, space logistics company Skycorp. Skycorp is also Lonestar's engineering design and manufacturing partner for the lunar data center mission scheduled for the second half of 2023.<br />
<br />
"After comprehensive testing and certification process, Phison is thrilled that our SSD technology has passed all the rigorous requirements for Lonestar's upcoming Moon mission," said K.S. Pua, Phison CEO. "We are excited about playing a vital role on this important mission, and other future ones as we continue our foray into the new frontier. We also want to thank our outstanding customer, Lonestar, and partner, Skycorp, for helping to make this happen."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2eNT7XMZYFkh8ywf.jpg" target="_blank" data-width="1920" data-height="1200" ><img src="https://tpucdn.com/img/2eNT7XMZYFkh8ywf_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301864/phison-8-tb-ssd-ready-for-historic-liftoff-after-earning-nasa-certification">Read full story</a></div>
(PR) ViewSonic Introduces Its First Portable Monitor with OLED Technology for Creators
ViewSonic, a leading global provider of visual solutions, presents the advanced 15.6" ColorPro VP16-OLED portable display with native 1080p Full HD resolution and advanced OLED technology for remarkable color performance and immersive visuals. It is Pantone-Validated, and factory calibrated to deliver richer color uniformity, accuracy, and enhanced details, ensuring that it meets the demands of professional content creators. The VP16-OLED won the distinguished GOOD DESIGN AWARD 2022 in the "Special Award" category for its remarkable color performance and immersive visuals while being ultra-thin, light-weighted, and versatile for professional creators to deliver their best work anytime, anywhere.<br />
<br />
In today's increasingly mobile world, ViewSonic recognizes that creative professionals are seeking tools that are portable yet still maintaining the performance required for color-critical work," said Oscar Lin, General Manager of the Monitor Business Unit at ViewSonic. "ViewSonic already has a series of portable monitors. The VP16-OLED is the first portable display in the ColorPro product line, and it is specially designed for creators who seek flexibility and productivity. It's light and simple and has a unique folding stand for users to take it anywhere. The two-way screen cover can be used as a shading hood for easy editing anywhere without lighting interference. We'll continue to push the boundary for high-quality professional monitors to deliver incredible user experiences anytime, anywhere."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/TPBig9sXKCrOGy5C.jpg" target="_blank" data-width="1333" data-height="1000" ><img src="https://tpucdn.com/img/TPBig9sXKCrOGy5C_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301863/viewsonic-introduces-its-first-portable-monitor-with-oled-technology-for-creators">Read full story</a></div>
(PR) SMART Modular Launches DC4800 Line of NVMe Gen 4 Data-center SSDs
SMART Modular Technologies, Inc. ("SMART"), a division of SGH and a global leader in memory solutions, solid-state drives and hybrid storage products, announces that it is now offering a new class of high performance, power efficient, data center solid state disk drives (SSDs) beginning with the DC4800 PCIe Gen 4 family. SMART's DC4800 devices are designed with a specialized hardware-accelerated SSD controller that draws less power without compromising storage input/output (I/O) performance. Zero-induced throttling allows these SSDs to perform better under continued duress, even when they are pushed to their performance limit. This translates to significant power consumption improvement per server, as well as consistent latency performance of up to 7-nines or 99.99999% of the time.<br />
<br />
"Today's leading-edge servers are not only expected to manage a significant mass of transactions to enable processes like machine learning, artificial intelligence, and the internet of things, but they are also expected to be more power efficient," said Andy Mills, data center architect for SMART. "Data centers are increasingly challenged by performance and energy demands as they expand to address these new workloads that process data from an ever-growing array of intelligent devices at the edge."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3nzfY59j7gbXpVIs.jpg" target="_blank" data-width="1500" data-height="1163" ><img src="https://tpucdn.com/img/3nzfY59j7gbXpVIs_thm.jpg" width="168" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301860/smart-modular-launches-dc4800-line-of-nvme-gen-4-data-center-ssds">Read full story</a></div>
(PR) AAEON Unveils UP Xtreme i12 Single-board Computer
Adding to its incredibly popular UP Xtreme product line, industry leader AAEON has announced the release of the UP Xtreme i12, the next generation developer board with 12th Generation Intel Core Processors (formerly Alder Lake-P). Improving upon the 11th Generation Intel Core Processor SoC of its predecessor, the UP Xtreme i11, AAEON's next-generation UP Xtreme i12 utilizes the 12 core, 16 thread hybrid architecture of 12th Generation Intel Core Processors, making it more energy-efficient despite possessing double the previous generation's thread count. With these improvements, the UP Xtreme i12 offers up to 20% greater CPU performance, while also hosting 32 GB onboard LPDDR5 system memory, which provides double the bandwidth and memory capacity of the previous generation.<br />
<br />
The UP Xtreme i12's configuration of HDMI 2.0b, eDP 1.4, and two DP 1.4 slots give it the necessary tools to host four simultaneous 4K displays, alongside USB 4.0 and 2.5 GbE ports ensuring high-speed connectivity to peripheral cameras. Compounding this powerful, efficient function is the 2.47 x increase in graphics speed provided by Intel Iris Xe graphics, which makes the board an excellent candidate for smart retail deployments.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DoiKNTUkeHZGVyt3.jpg" target="_blank" data-width="1169" data-height="1053" ><img src="https://tpucdn.com/img/DoiKNTUkeHZGVyt3_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mE7uVSlrxHf9j2CC.jpg" target="_blank" data-width="600" data-height="400" ><img src="https://tpucdn.com/img/mE7uVSlrxHf9j2CC_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hQfcEenxREhaMCd9.jpg" target="_blank" data-width="946" data-height="1053" ><img src="https://tpucdn.com/img/hQfcEenxREhaMCd9_thm.jpg" width="117" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qymmtFTzz5WFVqaJ.jpg" target="_blank" data-width="891" data-height="626" ><img src="https://tpucdn.com/img/qymmtFTzz5WFVqaJ_thm.jpg" width="185" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301857/aaeon-unveils-up-xtreme-i12-single-board-computer">Read full story</a></div>
(PR) GIGABYTE Launches AMD Radeon RX 7900 Series Graphics Cards
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of premium gaming hardware, today announced the new AMD Radeon RX 7900 Series graphics cards powered by the high-performance, energy-efficient AMD RDNA 3 architecture - the AORUS Radeon RX 7900 XTX ELITE 24G, Radeon RX 7900 XTX GAMING OC 24G, Radeon RX 7900 XTX 24G, Radeon RX 7900 XT GAMING OC 20G and Radeon RX 7900 XT 20G graphics cards. The new graphics cards will be available for purchase on December 13, 2022. <br />
<br />
The new graphics cards are the world's first gaming graphics cards to feature an advanced AMD chiplet design, delivering exceptional performance and superb energy efficiency to power high-framerate 4K and higher resolution gaming in the most demanding titles.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Zs0fAlTCXurVTfWE.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/Zs0fAlTCXurVTfWE_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HMldBhMOXrcjnkVl.jpg" target="_blank" data-width="2052" data-height="960" ><img src="https://tpucdn.com/img/HMldBhMOXrcjnkVl_thm.jpg" width="278" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MWEWp92Y6Gtf6Poo.jpg" target="_blank" data-width="2052" data-height="960" ><img src="https://tpucdn.com/img/MWEWp92Y6Gtf6Poo_thm.jpg" width="278" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301993/gigabyte-launches-amd-radeon-rx-7900-series-graphics-cards">Read full story</a></div>
First Alleged AMD Radeon RX 7900-series Benchmarks Leaked
With only a couple of days to go until the AMD RX 7900-series benchmarks go live, some alleged benchmarks from both the RX 7900 XTX and RX 7900 XT have leaked on Twitter. The two cards are being compared to a NVIDIA RTX 4080 card in no less than seven different game titles, all running at 4K resolution. The games are God of War, Cyberpunk 2077, Assassin's Creed Valhalla, Watchdogs Legion, Red Dead Redemption 2, Doom Eternal and Horizon Zero Dawn. The cards were tested on a system with a Core i9-12900K CPU which was paired with 32 GB of RAM of unknown type. <br />
<br />
It's too early to draw any real conclusions from this test, but in general, the RX 7900 XTX comes out on top, ahead of the RTX 4080, so no surprises here. The RX 7900 XT is either tied with the RTX 4080 or a fair bit slower, with the exception being Red Dead Redemption 2, where the RTX 4080 is the slowest card, although it also appears to have some issues, since the one percent lows are hitting 2 FPS. Soon, the reviews will be out and everything will become more clear, but it appears that AMD's RX 7900 XTX will give NVIDIA's RTX 4080 a run for its money, if these benchmarks are anything to go by.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Dh7Jon3G7iHxy4WP.jpg" target="_blank" data-width="2048" data-height="922" ><img src="https://tpucdn.com/img/Dh7Jon3G7iHxy4WP_thm.jpg" width="289" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/U30PPmwuAnwAWOVd.jpg" target="_blank" data-width="2048" data-height="922" ><img src="https://tpucdn.com/img/U30PPmwuAnwAWOVd_thm.jpg" width="289" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301992/first-alleged-amd-radeon-rx-7900-series-benchmarks-leaked">Read full story</a></div>
(PR) SilverStone Announces New Compact HTPC/Workstation Chassis - MILO 12
SilverStone Technology today announced the immediate availability of the latest installment from the MILO series line, MILO 12 - a 15.6L slim and compact Mini-ITX case suitable as a HTPC system that sits next to your TV or as a high-performance workstation.<br />
<br />
MILO 12 sports a dual-chamber internal body structure as the ML08 and RVZ03, but with few adjustments and enhancements to adhere to today's high-end hardware standards. A modular design has also been implemented which allows for all 4 panels (top, bottom, left & right side) to be removed for a simple and convenient build process.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/WTP1t4tFYFRv3T15.jpg" target="_blank" data-width="876" data-height="1280" ><img src="https://tpucdn.com/img/WTP1t4tFYFRv3T15_thm.jpg" width="89" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2uDclPjvIKtWjdY5.jpg" target="_blank" data-width="378" data-height="1280" ><img src="https://tpucdn.com/img/2uDclPjvIKtWjdY5_thm.jpg" width="38" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gGOPlrdBvTNH9wI5.jpg" target="_blank" data-width="1275" data-height="1280" ><img src="https://tpucdn.com/img/gGOPlrdBvTNH9wI5_thm.jpg" width="129" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LvtCv79URJtOaBuI.jpg" target="_blank" data-width="1012" data-height="1280" ><img src="https://tpucdn.com/img/LvtCv79URJtOaBuI_thm.jpg" width="103" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dWsO8mUvz0groA4f.jpg" target="_blank" data-width="1248" data-height="1280" ><img src="https://tpucdn.com/img/dWsO8mUvz0groA4f_thm.jpg" width="127" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VGbrMNlnJHO7dPZg.jpg" target="_blank" data-width="1280" data-height="1280" ><img src="https://tpucdn.com/img/VGbrMNlnJHO7dPZg_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301989/silverstone-announces-new-compact-htpc-workstation-chassis-milo-12">Read full story</a></div>
(PR) Ghost Story Games Reveals Judas, an All-New Single-Player Narrative First-Person Shooter
Ghost Story Games, the development studio led by game creator Ken Levine, today announced that Judas, an all-new single-player, narrative first-person shooter is in development for the PlayStation 5 computer entertainment system, Xbox Series X|S console systems, and PC via Steam and Epic Games Store. The new project was revealed at The Game Awards 2022 as a world premiere unveiled by Geoff Keighley. In conjunction with the project reveal, Ghost Story Games has launched the official pages for Judas on Steam and the Epic Games Store where fans can now add the game to their Wishlist.<br />
<br />
"We founded Ghost Story Games to build upon the legacy of System Shock 2, BioShock, and BioShock Infinite," said Ken Levine, President & Creative Director. "With Judas, we've created an entirely new world and set of characters while exploring different approaches to single-player, narrative first-person shooters."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JQTgGjAnWcWRGdM8.jpg" target="_blank" data-width="720" data-height="960" ><img src="https://tpucdn.com/img/JQTgGjAnWcWRGdM8_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/K1eLtM4exA63Y5hA.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/K1eLtM4exA63Y5hA_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/oACc5SlBr3H1F2dG.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/oACc5SlBr3H1F2dG_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OBskS2m3xxhDcEuz.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/OBskS2m3xxhDcEuz_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301966/ghost-story-games-reveals-judas-an-all-new-single-player-narrative-first-person-shooter">Read full story</a></div>
(PR) Hellboy Web of Wyrd Announced by Good Shepherd Entertainment & Dark Horse Comics
Global video game publisher Good Shepherd Entertainment has revealed a new partnership to adapt series creator Mike Mignola's Hellboy franchise, published by Dark Horse Comics. Developed by Upstream Arcade, Hellboy Web of Wyrd is an upcoming roguelite action-adventure game in development for all major gaming consoles and PC. It features an original storyline crafted in collaboration with Mignola, as well as the renowned voice talents of Lance Reddick as Hellboy himself. Mignola has also designed the game's unique key art.<br />
<br />
"Adapting the Hellboy comics to a game is a dream project for all of us. The opportunity to create something authentic—that's something we take very seriously," said Amanda Kruse, Publishing Director at Good Shepherd Entertainment. "Our partnership with Mike Mignola and the creative team at Dark Horse has been inspiring. The support and trust they've given us has allowed Upstream Arcade to bring their vision to life. Hellboy Web of Wyrd is a bold new work we are excited to share with fans of the comics and action-adventure games alike."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/A2mE9BuOlQSM6L1O.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/A2mE9BuOlQSM6L1O_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aeTU6pCU3y4qMYLt.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/aeTU6pCU3y4qMYLt_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bcJEnrByOtKgSY6O.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/bcJEnrByOtKgSY6O_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/k0idH2zMDfSs9SkX.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/k0idH2zMDfSs9SkX_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301965/hellboy-web-of-wyrd-announced-by-good-shepherd-entertainment-dark-horse-comics">Read full story</a></div>
