YouTube HD videos in 1280x720 still doesn't work :( :( :(
- Browser Opera :
- Se poate face zoom pe pagina! O poti face cat casa poporului! Se vede ca pe pc!
- Se apasa F4...si se deschide pagina de start! Punem o pagina si dam enter! Apoi dupa ce am ales o pagina apasam pe 'zoom' cat dorim si devine la fel de vizibila ca pe pc!
:clap:
Ok, I figured out that it's possible to download in HD quality (720p) to external HDD or Pendrive when we set in options 1280x720 but receiver can't play it (.mov format). When I tried to open that file then receiver freezed and I have to reboot...Quote:
Originally Posted by aszymbeher [Only registered and activated users can see links. Click Here To Register...]
YouTube only work in SD format, HD 1280x720 doesn't work.
Iata cum e setat browserul pe telecomanda!
Tasta 0 = Zoom in, 20
Tasta 1 = Back
Tasta 2 = Forward
Tasta 3 = Reload
Tasta 4 = Stop
Tasta 8 = Zoom out, 20
Navigare placuta!
are si functia ddsubtitle?
@azym ... the .mov format is displayed only by ... youtoube player ! or you
can move it to PC and there ...
@samuell ...functia este in curs de implementare ..la unele filme ...chiar merge !
Yes by YT player but only in SD. HD doesn't work.
O singura lucru nu inteleg: de ce nu-mi merge cu noul plugin? Aveti si voi probleme cu el?
despre ce plugin este vorba ? concret ... ce ai incercat sa faci si nu merge ?
I am not satisfied with the Spark.
Lots of dust rising about anything.
It was announced a lot more, and where is it?
List of channels remains the same?
It was necessary to change the skin?
Teletext remained the same size, but should have been increased.
Ttlovi stay too long after the pronunciation.
And much more.
Absolutely, I do not see anything new in it.
Back to Enigmu2 of AR PEOJEKT
Am instalat noul soft, apoi am incercat sa-l configurez noul plugin ([Only registered and activated users can see links. Click Here To Register...]) pentru o linie C. Dar nimic, nu porneste...Quote:
Cu pluginul anterior functioneaza ( [Only registered and activated users can see links. Click Here To Register...]).
Este o si o setare pe care nu l-am observat in noul plugin?
Am facut si o incercare asa ca numai oscam.sh4 am schimbat in vechiul plugin cu cel nou, si nu functiona. Cand l-am copiat inapoi pe cel vechi, functiona iar.
Daca ar fi schimbat macar skinul...!Nu este o prioritate? Sau necesita un efort prea mare? In rest...e ok! Cel putin pt mine.Nu mi-am scris niciodata parerea despre acest receptor,dar scopul pentru care l-am achizitionat a fost atins,mai mult decat atat!Doar skinul,bata-l focul.....Ma imbat cand il vor schimba:drinks:
Ma eu nu v-a inteleg... Voi va uitati la televizor sau la skin? Pe mine singurul ce ma intereseaza este sa fie Spark o imagine stabila, bine functionala si usor de folosit - restul sunt niste lucruri mai putin folositoare. Pai Alien nu-i un smartphone sa-l iei cu tine si sa ai internet browser si de toate in mana... Bineinteles asta-i PAREREA MEA si spun fara a supara pe oricine.
De gustibus et coloribus non disputandum! Zicea unul...care nu avea Alien!A fost candva vorba de ,,doleante" new spark.....!Atat și nimic mai mult.
ce fel de filme@mihai? pe mine ma intereseaza de pe satelit gen rtl,rtl2 vox,de pe 28e etc sau de pe stik? mersi
Too much noise and waitings for nothing special....Quote:
Originally Posted by grle44 [Only registered and activated users can see links. Click Here To Register...]
O problema care nu a fost rezolvata. Dupa umila mea parere 'ar trebui rezolvata' si nu e imposibil de atins acest lucru. Si detaliez: faci o scanare la un satelit. Sa admitem ca sunt 5 canale tv. Le ai in lista dupa scanare. Ele vin cu un nume, sa dam un exemplu, TV 123 Bremen. Mie nu-mi convine numele si schimb in : Bremen 123. La rescanare revine la denumirea initiala si se transforma in TV 123 Bremen. Tu redenumesti...la scanare tot ce ai facut a fost inutil! Sper sa se tina cont. Multumesc frumos.
Deci pt YouTube nu se oate face nimic?
Hello
I have a request for you. Please check if videos in 1280x720 (change in options - green button) are working for you on newest Spark?
For example this hd videos:
or
Both in HD version.
Thanks!
I don't care about youtube. I don't care about Opera. I use a decent computer for that.
What I really really want is a decent mediaplayer.
Amiko advertises with the Alien as being a full HD mediaplayer. Well it is NOT.
It cannot play Full HD mkv. I only manage to play mkv with 1 AC3 track. Multiple audiotrtacks are not supported. DTS makes the player crash, or playback is crap.
With the last update there is subtitle support. But the font used is really terrible.
So what I need is:
Decent fonts in subtitles.
DTS support.
Multiple audio track support for mkv's.
Smooth playback of full HD mkv.
Uptill now the Alien is not a serious mediaplayer. It is better to remove the sentence ' HD mediaplayer' from the advertisements for the Amiko Alien. Because it is NOT.
