r4741 | _network | 2011-02-20 17:51:29 +0100 (Sun, 20 Feb 2011) | 2 lines
fix emm reader selection, second try
r4740 | alno | 2011-02-20 17:47:33 +0100 (Sun, 20 Feb 2011) | 1 line
WebIf: add some debuglog in dyndns check. If you see a httpdyndns issue report with d1 log
r4739 | jerdvb | 2011-02-20 16:23:30 +0100 (Sun, 20 Feb 2011) | 1 line
Viaccess ECM : patch skip ECM for multi ECM, add fallback if all ECM are skiped
r4742 | _network | 2011-02-20 22:42:39 +0100 (Sun, 20 Feb 2011) | 2 lines
reader-nagra: fix possible crash if compiled with libcrypto
Oscam-1.00-svn4743
r4743 | _network | 2011-02-20 23:17:16 +0100 (Sun, 20 Feb 2011) | 2 lines
reader-nagra: correct changes in r4742
r4744 | schlocke | 2011-02-23 19:23:08 +0100 (Wed, 23 Feb 2011) | 2 lines
cccam: new mode "TRANSPARENT" for using less memory per client
r4746 | cogsi | 2011-02-24 10:11:14 +0100 (Thu, 24 Feb 2011) | 1 line
gbox: fixes (thanks to leloup, thatave and to everyone else)
r4745 | cogsi | 2011-02-24 09:41:09 +0100 (Thu, 24 Feb 2011) | 1 line
gbox: partial attempted ecm fix (will be superceded shortly - don't use this version)
Oscam-1.00-svn4748
r4748 | schlocke | 2011-02-24 22:35:57 +0100 (Thu, 24 Feb 2011) | 2 lines
Updated Maketype for compile #4747
r4747 | schlocke | 2011-02-24 22:19:46 +0100 (Thu, 24 Feb 2011) | 6 lines
cccam: removed transparent option, now it's default on every mode.
complete reimplementation of card management, now only one list is
generated and less memory and less cpu is used.
But the bad thing is, now we have to test everything again, because
everything is new implemented. See forum for details!
Oscam-1.00-svn4750
r4750 | schlocke | 2011-02-25 11:32:11 +0100 (Fri, 25 Feb 2011) | 2 lines
cccam: added missing file
r4749 | schlocke | 2011-02-25 11:26:16 +0100 (Fri, 25 Feb 2011) | 3 lines
cccam: added synchronisation for card reporting
cccam: possible fix for reader reconnect problem
r4751 | schlocke | 2011-02-25 17:44:12 +0100 (Fri, 25 Feb 2011) | 2 lines
cccam: card generating updated, segfault fixed
Oscam-1.00-svn4752
r4752 | schlocke | 2011-02-25 18:13:16 +0100 (Fri, 25 Feb 2011) | 2 lines
cccam: share/card handling id generation fixed
r4753 | schlocke | 2011-02-25 22:30:08 +0100 (Fri, 25 Feb 2011) | 3 lines
cccam: security fix: Shared Adress was transfered even when au is off
cccam: Card Id generation updated
r4754 | schlocke | 2011-02-26 10:19:21 +0100 (Sat, 26 Feb 2011) | 2 lines
cccam: preparing cccshare visualization for webif
Oscam-1.00-svn4755
r4755 | schlocke | 2011-02-26 16:13:43 +0100 (Sat, 26 Feb 2011) | 5 lines
cccam: updated forward_origin code to force also the card, not just the
reader
cccam: Better provider matching: Before, ecm requests also gone to
provider 0 also if ecm request has provider <>0
Oscam-1.00-svn4757
r4757 | schlocke | 2011-02-26 18:09:51 +0100 (Sat, 26 Feb 2011) | 3 lines
cccam: disabled cardlist generating if cccam server is disabled
cccam: if a card has no provider, now no 000000-provider is created
r4756 | _network | 2011-02-26 17:03:03 +0100 (Sat, 26 Feb 2011) | 2 lines
WebIf: fix crash on enabling a reader when all other reader are disabled
Oscam-1.00-svn4758
r4758 | schlocke | 2011-02-26 19:46:41 +0100 (Sat, 26 Feb 2011) | 3 lines
cccam: faster local card detection
webif prepared for sharelist viewing
Oscam-1.00-svn4759
r4759 | schlocke | 2011-02-27 11:16:14 +0100 (Sun, 27 Feb 2011) | 2 lines
cccam: fixed maxhop-problem
