NU ! fonturile sint definite avand in vedere vizibilitatea pe un ecran de
dimensiuni medii ( 26"-32") ... pe ecrane mai mici se rezolva regland
distanta de vizionare. Printre altele am si un ecran de 22" si de la
cca 1.5 -2 m se vede perfect !
Te referi la "contrast"cu reglarea distantei sau nu am observat cv in meniu?
Hi,
I have a problem with Spark image. Sometime the video image becomes black for a few second. What can it be?
Nu se refera la contrast , se refera la distanta de vizionare ... adica sa stai mai departa sau mai aproape de tv dupa cum ai nevoie :cool2:Quote:
Originally Posted by scoo [Only registered and activated users can see links. Click Here To Register...]
@hoadeo --- is FTA ? is HDMI ? what EMU ? without any relevant information
is impossible to give an answer !
Will it work with the new version of monitor? I tried all images amiko to work with no monitor.
is HDMI. The EMU is mgcamd 1.35.Quote:
Thanks
@ Mihaip ..
Dacă este posibil, Spark are suport pentru CCcam, să lucreze ca un server.
@grle44 --- CCcam nu exista pentru procesoare SH4 asa cum este cel al lui Amiko Alien ( Spark ).
Poti realiza un server de tip CCcam folosind Oscam , toate functiile necesare sint perfect functionale
sub Spark inclusiv suportul de cardreader.
@hoadeo --- MgCamd is a poor client for CCcam server ! so use Oscam and you will not have black screens !
If you need help to implement ...contact me using PM ( personal message ).
@Geryl --- I dont understand your question ! what monitor are you reffering ?
I had same problem in HD channels. The black image was black for less then 1 sec. The problem at me was because alien worked in 1080P, but my tv knows only 1080I. After I put alien to 1080I, the problem resolved.Quote:
Originally Posted by hoadeo [Only registered and activated users can see links. Click Here To Register...]
Pana la urma ce scule trebuiesc pentru a folosi aceasta functie ... sa stim si noi ca ne-au lasat in ceata producatorii .Quote:
Release Notes for v1.1.42:
New Features:
- Wireless USB Keyboard & Mouse support
stargate ...poti folosi foarte bine un kit ce contine senzor pe USB pentru tastatura si mouse...
eU cel putin asa am folosit, bine ca nu mi-am aruncat la gunoi tastaura Genius care este de acest tip si merge foarte bine . just plug&play [Only registered and activated users can see links. Click Here To Register...]
cam asa ceva
Succes!!!
PS: Nu mai fi asa nervos pe Amiko...face si el destule lucruri bune :)
Am fost inteles gresit nu sunt nervos pe amiko , spark la ora actuala este unul dintre cele mai bune softuri non-enigma , doar ca sunt asa de multe lucruri care trebuiesc rezolvate si ei lanseaza floricele care sunt inutile in acest moment . In fine mai bine tac din gura si fiecare face ce doreste dar fara presiuni constante nu vom avem soft de calitate .
Sa inteleg ca ai folosit kitul din link si ti-a mers ok ?
New firmware will come out today for Amiko Alien?
On Golden Media 990 new firmware 1.2.06 is available since Wednesday 20.
da stargate cu kitul de tipul ala mi-a mers fara probleme mouse si tastatura prin Usb wirreless. Modelul nu este exact ala. Am tastatura din 2005 si nu gases model exact dar e acceasi firma probabil cel din link este ceva mai nou.
....si pentru ca sa scri din tastatura trebuie in Opera sa comuti la telecomanda cu F1 pe tastatura si merge foarte bine.
mersi , chestia cu F1 o stiam si apare si la accesare Opera . Daca vor continua sa lucreze la Opera si il vor aduce la un stadiu in care sa se poata folosi intr-un mod decent atunci voi face o achizitie de tastatura si mouse wireless dar daca ramane in stadiul actual nu se merita sa dai banii pe ele .
eu le aveam deja...au fost numa bune de test...ca in rest oricum nu folosesc metoda asta cu amiko pentru net :)
Deocamdata Opera este numai o floricica dar poate vor rezolva problemele si se va putea folosi intr-un mod decent . Sa vedem ce noutati va aduce noua versiune Spark si daca este ok o laudam daca nu este ok o criticam .
Si eu am facut tot felul de sugestii pentru Spark...sper ca unele sa fie luate in seama...nu de alta dar daca marea majoritate a ideilor bune ar fi aplicate, nu face altceva decat sa aduca noi utilizatori pentru acest receiver, in proportie de 80 % o reusita in materie. Cine are de castigat...toata lumea! Sper ca nu batem campiile cand propunem ceva...
Noua versiune Spark 1.2.06
nu incă
:tv: :tv:
