r4688 | schlocke | 2011-02-07 21:00:00 +0100 (Mon, 07 Feb 2011) | 2 lines
loadbalancer: fixed reopening of blocked readers if no reader is found
r4687 | lattjo | 2011-02-07 19:30:45 +0100 (Mon, 07 Feb 2011) | 1 line
Use oscam DES functions!
Oscam-1.00-svn4689
r4689 | schlocke | 2011-02-07 21:02:34 +0100 (Mon, 07 Feb 2011) | 2 lines
cccam: disabled users now gets disconnected
r4690 | schlocke | 2011-02-07 21:36:29 +0100 (Mon, 07 Feb 2011) | 3 lines
cccam: reader: cccmaxhops changed! -1:disabled, 0=local, 1=hop1, 2=hop2
and so on...
Oscam-1.00-svn4691
r4691 | landlord | 2011-02-07 22:18:00 +0100 (Mon, 07 Feb 2011) | 1 line
Documentation update again for 'cccmaxhops' in 'oscam.server'.
Oscam-1.00-svn4693
r4693 | _network | 2011-02-08 10:39:14 +0100 (Tue, 08 Feb 2011) | 2 lines
card reset: fix deprecated mode not working
r4692 | _network | 2011-02-08 10:16:39 +0100 (Tue, 08 Feb 2011) | 2 lines
reader-dre: fix cw postprocessing
Oscam-1.00-svn4694
r4694 | schlocke | 2011-02-08 21:51:14 +0100 (Tue, 08 Feb 2011) | 2 lines
oscam-srvid reloadable: call init_srvid() again for re-reading file
Oscam-1.00-svn4698
r4698 | landlord | 2011-02-08 22:59:06 +0100 (Tue, 08 Feb 2011) | 1 line
Documentation update for oscam's SIGHUB.
r4697 | schlocke | 2011-02-08 22:45:40 +0100 (Tue, 08 Feb 2011) | 2 lines
SIGHUB now reloads oscam.user, oscam.srvid, oscam.tiers
r4696 | alno | 2011-02-08 22:12:59 +0100 (Tue, 08 Feb 2011) | 1 line
WebIf: reload oscam.srvid after saving in Files section
r4695 | landlord | 2011-02-08 22:11:24 +0100 (Tue, 08 Feb 2011) | 1 line
Documentation update for parameter 'minimizecards'.
Oscam-1.00-svn4699
r4699 | alno | 2011-02-09 08:13:16 +0100 (Wed, 09 Feb 2011) | 1 line
WebIf: set default value 'hideclient_to' to 15 if webinterface is present. Because users seems to be not able to read the forum this is maybe the best choice
Oscam-1.00-svn4700
r4700 | cogsi | 2011-02-10 09:57:03 +0100 (Thu, 10 Feb 2011) | 1 line
gbox: message codes added
Oscam-1.00-svn4702
r4702 | cogsi | 2011-02-10 10:23:40 +0100 (Thu, 10 Feb 2011) | 1 line
gbox: gsms config (landlord: please don't add to documentation yet, code is not complete)
r4701 | cogsi | 2011-02-10 10:16:47 +0100 (Thu, 10 Feb 2011) | 1 line
gbox: send boxinfo message
Oscam-1.00-svn4704
r4704 | landlord | 2011-02-10 14:14:29 +0100 (Thu, 10 Feb 2011) | 1 line
Added documentation for new parameter 'lb_retrylimits'.
r4703 | schlocke | 2011-02-10 13:39:33 +0100 (Thu, 10 Feb 2011) | 4 lines
loadbalancer: new parameter oscam.conf [global]
lb_retrylimits=caid1:time1,caid2:time2,...,caidn:timen
so you can spezify a retrylimit-time per caid!
Oscam-1.00-svn4705
r4705 | landlord | 2011-02-10 14:20:54 +0100 (Thu, 10 Feb 2011) | 1 line
Added VideoGuard totalTV Serbia (091F) SC. Thanks to jenova.
Oscam-1.00-svn4707
r4707 | schlocke | 2011-02-10 20:29:54 +0100 (Thu, 10 Feb 2011) | 2 lines
SIGHUP: reload config fix
r4706 | lattjo | 2011-02-10 20:17:13 +0100 (Thu, 10 Feb 2011) | 1 line
Cygwin pcsc support fixed.
Oscam-1.00-svn4709
r4709 | schlocke | 2011-02-11 10:17:09 +0100 (Fri, 11 Feb 2011) | 2 lines
fixed #1638 compile error
r4708 | schlocke | 2011-02-11 07:38:18 +0100 (Fri, 11 Feb 2011) | 3 lines
webif: applied patch oscam-http.c-patch-1593-v1 from Ticket 1593. Thanks
to coolacid !
Oscam-1.00-svn4711
r4711 | alno | 2011-02-11 22:17:53 +0100 (Fri, 11 Feb 2011) | 1 line
WebIf: add reload oscam.user after editing in files section
r4710 | alno | 2011-02-11 22:02:02 +0100 (Fri, 11 Feb 2011) | 1 line
WebIf: exclude scanusb functionality on Cygwin
