myepg 0.1.5
myepg 0.1.5
micron-0.0.4-r8
transmission 1.51
[Only registered and activated users can see links. Click Here To Register...]&
0.0.6:
- Buttons UP/DOWN moves OSD window vertically on the screen
(thnaks to coooloser)
- Start windows positon moved a bit upper to show good on TV
with zoom enabled
- Plugin recognize font used, and adapt font size so it always looks
good (thanks to cooloser)
- if you press the "i" button you get a additional window with more
stream infos (pid,program...)
myepg 0.2.3
IN ENGLISH (from changelog)
- Fixed crash in grid view if there are an empty group
- Added i18n support (with italian translation)
- Fixed config window look
- Fixed different √ button for 91HD series
- Added menu (start sync, start downloader, configuration)
- Added live preview box (thanks to Pippo9000)
- Added support for sky uk (untested)
- Added text justifying
- Other small fix and ui enhancements
- Added standby management in downloader
for installation instruction please read the file README.TXT
(uninstall myepg 0.2.1 before install myepg 0.2.2 is suggested)
Salut, am nevoie neaparata de ceva de genul asta, ca sa pot vedea si eu in ce hop e cardul, ecm time, cu ce linie deschide, etc.... am creat acel folder scripts in /var pt ca nu era, am copiat fisierele, le-am pus chmod 755, dar nu stiu cum sa vad informatiile.. am luat la rand butoanele de la telecomanda... ai idee? merci!!Quote:
le-am luat si pe rand in telnet si le-am rulat, dar numai *_ecm.sh merge, celelalte spun ca nu pot gasi /tmp/*.info
Iar asta imi da doar atat... nu stiu ce linie folosesc... nici ecm time... nici in ce hop e cardul.
cuberevo mini:/var/script# ./scrplg-crash_ecm.sh
===== Seca ECM on CaID 0x0100, pid 0x070b ======
prov: 00006A
cw0 : FD A1 A7 45 D4 1F 19 0C
cw1 : 67 B7 D2 F0 06 4A 5E AE
12.05.2009
For download your prefered .torrent
Install package
Open Browser
go in [Only registered and activated users can see links. Click Here To Register...]
..192.168.1.8 is my IP_DECODER ..change with your
P.S.
Change any options in file:
/var/bin/transmission.sh
myGreenButton 0.1.0 BETA
Facem unrar pe file green.rar,dupa copiam pe files cu ftp in plic plugin (in ipbox).Dam atributes 777.Si mergem la canal sky TG24 si prin panel pornim pe plugin.Cu sageata stinga-dreapta alegem ce canal dorim sa vedem.Asta versiuna ruleze sub firmware oficial si asemenea cu versiuna pt E2.
Facem unrar pe file si dupa il facem copy paste cu flashxp in /var/plugin
myPanel 0.2.0 by Ataru80
myPanel is a plugin that allows you to quickly launch your favourite plugins. Just edit the file myPanel.config according your preferences.
Then you can launch myPanel: an OSD banner will display the colored buttons/plugins associated.
PREVIEW:
CHANGELOG 0.2.0 :
- added managment of skins
- added managment of multiple menus
- coordinate TOP of OSD in file myPanel.config
INSTALLATION
copy the files:
- myPanel.plugin
- myPanel.config
copy the folder:
- /myPanel_skin
into the path /var/plug-in of your SAT receiver.
CONFIGURATION:
edit file myPanel.config according to your preferences.
GET STARTED:
Launch the plugin myPanel:
- keys RED/GREEN/YELLOW/BLU : to launch the associated plugins contained in myPanel.config
- keys UP/DOWN : to change skin
- kesy RIGHT/LEFT : to change menu
DOWNLOAD
DOWNLOAD
myGreenButton_0_2_0_by_Ataru80.tar.gz
ENGLISH:
This plugin emulates the behaviour of interactive GREEN button of SkyItaly.
INSTALLATION
copy the files:
- myGreenButton.plugin
- myGreenButton.dat
-Volevo uscire direttamente con la 0.3.0 definitiva... ma visto che la parte relativa ad enigma2 si stà tirando un po' per le lunghe (e la versione dgs è pronta già da un po') mi è sembrato giusto farvela provare per avere le prime impressioni.
Le novità sono svariate... le più importanti sono:
- temi con le immagini (già presente all'interno un tema chiamato bluewave)
- visuale a lista
- visuale light
- gestione delle registrazioni
- collegamento delle serie tv (tipo skybox)
Per l'installazione copiate il file myepg-0.3.0pre3-dgs-sh4.tar.gz in /tmp
poi via telnet fate
Code:
cd /tmp
tar zxf myepg-0.3.0pre3-dgs-sh4.tar.gz
./installer.sh
Few important fixes
camup control 0.3
Change options to /var/etc/inadyn.conf-sample, rename to inadyn.conf
change:
$USER = your user_name (or e-mail)
$PASSWORD = your password set to service
$NAME = your select name (xxx.dyndns.xxx)
$TIME_REFRESH = time refresh hostname (good is 3600 or more)
$SERVICE = [Only registered and activated users can see links. Click Here To Register...] (for no-ip service) [Only registered and activated users can see links. Click Here To Register...] (for dyndns service)
Start with script plugin (now at any reboot restart itself)
enjoy ..by ngc1927
Faq configuration plugin:[Only registered and activated users can see links. Click Here To Register...].
Plugin e2 VCL Player
I accept with information: This release from script-plugin uses the new jpg to bmp function, which allows us to store the background images as jpg instead of bmp, which saves us almost 1.2MB of space in the /var directory for each plugin.
I install it with no problem and I can even see my files and select a file to play.Quote:
Then I only see a picture of planets and "Dreambox" in big letters.
I see no other picture and hear no sound. I see the progress bar, but I have virtually no control.
I have IPBox 91HD, E2 PKT 5.6d and on the PC I run VLC 0.9.9a
Does anybody know what is wrong?
