Re: Enigma 2 pe Kathrein UFS-910
salut am observat ca dupa instalarea lui e2 , lucreaza mai bine cu porturile usb din spate decat cel din fata
ieri am facut instalarea lui e2 pe 1-mul port usb spate (cel de sus) si vad ca booteaza si dupa el , iar azi i-am dat drumul din on/off sa blocat pe "loading modules" si dupa scoaterea stick-ului l-am conectat pe cel de jos (al 2-lea) si a bootat
ecranele verzi am observat ca apar mai repede atunci cand nu-i dai o comanda ferma din telec. (sau nu o receptioneaza ca lumea) sau cand incerci sa te misti mai repede prin meniuri , dupa care isi revine automat
Eroarea "loading modules" apare cand nu se face reset bine la usb sau receptor.
Oprirea de la buton cu o pauza de cateva zeci de secunde rezolva problema asta.
Hi,
I have check your procedure but I cannot have a good result... !
When I try to boot I received the message like that :
U-Boot 1.1.2 (STLINUX_2_0p1) (May 30 2007 - 16:03:49)
DRAM: 32 MB
write time out = 1, clock = 40
Flash: 16 MB
In: serial
Out: serial
Err: serial
pll0 freq 531
pll1 freq 399
Net: VFD_Driver Init
VFD_Controller Type : NEW Kathrein VFD
board_version = 0
Button_value = 6
Boot From Emergency Root File System Upate Appliction
Hit any key to stop autoboot: 0
Using MAC Address 00:1D:EC:00:4B:60
File transfer via NFS from server 0.192.168.1; our IP address is 192.168.1.100
Filename '/nfs/boot/uImage'.
Load address: 0xa5000000
Loading: *
There is no link to the NFS server because the address of the server stay at 0.192.168.1 instead of 192.168.1.200
Of course I have set the correct address to the set serverip
I try to remove the change but every time the Kathrein boot and try to contact the NFS server.
Can you send me the normal environement setting to comeback in a normal boot ?
Thanks in advance (need help very much !)
Origon
Use this tool :[Only registered and activated users can see links. Click Here To Register...]
In Environment there is simple preparation added for booting from NFS and then return booting from FLASH
- Added in menu : Backup , now it is easy to make backup from your image
- some bug fixed
How to - BackUp :
1.Receiver is on ;
2.Launch KathiUp ;
3.Click BackUp ;
4.In the new window , fill up with the receiver's IP , username , password
5.Click Browse -> choose the folder where the files will be saved ;
6.Click BackUp ;
7.wait...about 20sec.;
8.Go to selected folder , U'll find 6 saved files .
Good luck !
How to - prepare for booting from NFS :
1.Connect both serial(null modem) and network cable to receiver ;
2.Launch KathiUp ;
3.Fill up corectly all 4 left sided windows ;
4.Click Connect ;
5.Power On Receiver ;
6.Click NFS ;
How to - prepare for booting from FLASH :
2.Launch KathiUp ;
4.Click Connect ;
6.Click FLASH ;
Hi,
Thank you for your reply
You give another live to the Kathrein :dance:
I have try the procedure to set parameters for a NFS link but there is a transfert and after few minutes it stop, I don't know yet why (since few weeks to try to put the enigma2...)
I would like simply change the flash of the receiver to use the incubus cam with the CCcam protocol.
Why I cannot found enigma2 in the same format like AAF-2.x (with 5 or 6 files to put on the USB key)
Does somebody has enigma2 already on the Kathrein can make a backup with Kathiup and give me the files ??
Thanks in advance
Origon
foloseste cineva lini CCcam pe katy ?,merci
Salut,
Am si eu 2 intrebari de incepator:
1. Merge sa vad un card local max (cu cam Viaccess red) in E2 ? (pentru vizionare locala)
2. Merge sa dau mai departe cardul asta ? Cu ce server/emu ? Trebuie neaparat sa-mi cumpar cardreader, pt. asta ?
Multumesc.
USb2Serial + Phoenix, DA la ambele.
Mersi pentru raspunsul rapid.
O lamurire totusi, as mai vrea. Sa inteleg ca merge cardul de max fara cardreader, adica sa fie citit direct din cam-ul viaccess ? Si daca da, cu ce emu ?
fara emu.... il citeste direct
Mă poate ajuta cineva am instalat in flash AAF2.0e iar pe stik E2 ultima versiune problema e că deși am pus emu și key nu imi merg programele codate.Unde am greșit??
verifica keya si foloseste camd3
zildan edit:
te rog sa nu mai folosesti QUOTE la posturi succesive
ai in stanga jos sub ultimul post butonul NEW REPLY
@tedugoroma
Mbox e numai client-server de sh@ring, deci nu merge cu key.
Daca vrei key foloseste camd3, si vezi in /var/keys/camd3.keys.
Merge unde se mai poate ..... 1 _w si 23,5_E
Mersi de raspunsuri - o sa mai sap sa vad de ce nu-mi vede E2 cam-ul Viaaccess. Stie cineva daca mai merge TPS-ul cu key ?
Enigma2 nu vede cam-urile dacat cu UFS910Camd pus ca emu, dar nu pe toate.
Diablo merge sigur.
salut , avand in vedere ca au inceput sa apara variante de e2 "ca ciupercile dupa ploaie" , poate nu ar fii rau de facut un sondaj la fel ca la dm 500 legat de "cea mai buna/complexa imagine" si "cea mai stabila imagine"
aici fiind vorba de enigma 2 de la : aaf , pkt , rsp s.a si eventual specificat sau impartite "flash" sau/si "ba"
Am mici probleme cu motorasul diseq 1.2 - mai "scapa" cateodata cativa "pasi"
Am incercat cu 2 ehigma (si rsp si pkt) si la ambele in meniul de reglaj al antenei primesc "verdeata".
Stie cineva o varianta (oricat de veche) la care sa mearga reglajul antenei si memorare pozitii ????
Sau scot iara de la naftalina vechiul FTA sa rememorez toti satelitii ???
THKS in advance
RSP 2.01 merge binisor cu antena.
Daca ai pus bine HH-ul foloseste USALS , probat de mine pe toate versiunile, merge excelent.
Salut din North America,
Urmaresc de cateva zile posturile voastre legate de e2 si receptorul ufs-910.
In NA suportul linux este destul de subtire si cu precadere dedicat dreambox e2, dar m-ar interesa pasii necesari implementarii unor patchuri pentru NA in codul e2 pentru kathrein si generarea unei imagini pentru acest box. cine ar putea sa ajute ? exista un server care detine sursele celei mai stabile imagini la care sa putem adauga cate ceva specific ? ma refer la satelitii pentru NA pentru bell si dish. O alta intrebare legata de stabilitatea e2 si ufs910. Daca se instaleaza in flash si se adauga un emulator pentru cardsharing face fata streamurilor HD 720p ? Sau se blocheaza ? Care este parerea voastra ? Multumesc
:gathering:
