AOC Introduces a Trio of New Gaming Monitors Ahead of CES 2025
Just ahead of CES 2025, prominent display maker AOC has introduced a trio of new gaming monitors. First up, we have the Q25G4S, a 24.5-inch IPS monitor with an impressive 300 Hz refresh rate, ideal for esports titles. The QHD resolution allows for a decent pixel density at its size, making it well-suited for content consumption as well. The monitor boasts dual HDMI 2.1 ports, a DisplayPort 1.4 port, and an audio jack. The monitor appears to be plenty ergonomic as well, with swivel, pivot, tilt and height adjustments courtesy of its included ergonomic stand.
Next up, we have the AOC 27G11ZE3, sporting a 27-inch IPS panel with a slower but impressive 260 Hz refresh rate. The 1080p monitor claims 99% of sRGB color gamut coverage, which is perfectly decent, but the overall content consumption experience will certainly be held back its poor pixel density. The monitor sports a DisplayPort 1.4 input, along with dual HDMI 2.0 inputs. When the latter is used, refresh rate will be limited to 240 Hz. An audio jack is also present.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Strix Halo Radeon 8050S and 8060S iGPU Performance Look Promising
AMD fans are undoubtedly on their toes to witness the performance improvements that Strix Halo is ready to bring forth. Unlike Strix Point, which utilizes a combination of Zen 5c and full-fat Zen 5 cores, Strix Halo will do away with the small cores for a Zen 5 "only" setup, allowing for substantially better multicore performance. Moreover, it is also widely expected that Strix Halo will boast chunky iGPUs that will bring the heat to entry-level and even some mid-range mobile GPUs, allowing Strix Halo systems to not require discrete graphics at all, with a prime example being the upcoming ROG Flow Z13 tablet.
As per recent reports, the upcoming Ryzen AI Max+ Pro 395 APU will sport an RDNA 3.5-based iGPU with a whopping 40 CUs, and will likely be branded as the Radeon 8060S. In a leaked Geekbench Vulkan benchmark, the Radeon 8060S managed to outpace the RTX 4060 Laptop dGPU in performance. However, according to yet another leaked benchmark, Passmark, the Radeon 8060S and the 32-CU 8050S scored 16,454 and 16,663 respectively - and no, that is not a typo. The 8060S with 40 CUs is marginally slower than the 8050S with 32 CUs, clearly indicating that the numbers are far from final. That said, performance in this range puts the Strix Halo APUs well below the RTX 4070 laptop GPU, and roughly the same as the RTX 3080 Laptop. Not bad for an iGPU, although it is almost certain that actual performance of the retail units will be higher, judging by the abnormally small delta between the 8050S and the 8060S.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GoDeal24 Unveils Yearend Deals on Discount Genuine Software
As 2024 draws to a close, and you scamper for gifts, GoDeal24 wants to step in—how about something really useful that doesn't move in a logistics van? Get amazing yearend deals on genuine, globally valid software, which you can use in your Winter 2024 builds, or give it away to friends and family. Get Windows 11 Pro at just $13.25. A multipack of 3 can be had at just $34.45 ($11.48 a piece). Don't forget to pair it with Office 2021 Professional Plus, now going at $35.11, with 5-PC multipacks going at $161.25 ($32.25/piece). Better yet, combine the two at just $47.59. Check out great deals on other editions of Windows at Office, and their combos.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
Please use the coupon code TCP62 on the following items to avail the prices you see here.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Intel Confirms CES 2025 Keynote, Teases "AI Inside" Era and Core Ultra
Intel has officially announced its presence at CES 2025, teasing what appears to be a significant focus on AI capabilities in its upcoming processor lineup. The tech giant shared a preview image featuring their tagline "AI Inside for a New Era." The announcement suggests that the company will be showcasing new developments in AI processing capabilities integrated directly into their consumer processors. Intel's upcoming lineup is expected to feature the mobile-focused "Arrow Lake" Core Ultra 200H/HX processors alongside the Arrow Lake-based Core Ultra 200S series designed for desktop systems with 35 W and 65 W power configurations. The company is also supposedly introducing new mid-range and workstation-class 800-series processors for desktop platforms.
The "AI Inside" messaging indicates that Intel is positioning itself to compete more aggressively in the AI computing space, particularly as PCs increasingly handle AI workloads locally. While specific details about the presentation remain under wraps, we can anticipate announcements regarding new Arrow Lake configurations, enhanced AI capabilities, and possibly new partnerships or software ecosystems designed to leverage these features. The keynote could also shed light on Intel's strategy for maintaining competitiveness in an increasingly AI-focused computing landscape. Michelle Johnston Holthaus, interim co-CEO, and Jack Weast, an Intel Fellow and VP of Intel Automotive, will deliver the live keynote. Intel's agenda also shows next-generation AI silicon so we can get information on accelerators like Falcon Shores.[Only registered and activated users can see links. Click Here To Register...]
AMD Radeon RX 9070 XT Alleged Benchmark Leaks, Underwhelming Performan
Recent benchmark leaks have revealed that AMD's upcoming Radeon RX 9070 XT graphics card may not deliver the groundbreaking performance initially hoped for by enthusiasts. According to leaked 3DMark Time Spy results shared by hardware leaker @All_The_Watts, the RDNA 4-based GPU achieved a graphics score of 22,894 points. The benchmark results indicate that the RX 9070 XT performs only marginally better than AMD's current RX 7900 GRE, showing a mere 2% improvement. It falls significantly behind the RX 7900 XT, which maintains almost a 17% performance advantage over the new card. These findings contradict earlier speculation that suggested the RX 9070 XT would compete directly with NVIDIA's RTX 4080.
However, synthetic benchmarks tell only part of the story. The GPU's real-world gaming performance remains to be seen, and rumors indicate that the RX 9070 XT may offer significantly improved ray tracing capabilities compared to its RX 7000 series predecessors. This could be crucial for market competitiveness, particularly given the strong ray tracing performance of NVIDIA's RTX 40 and the upcoming RTX 50 series cards. The success of the RX 9070 XT depends on how well it can differentiate itself through features like ray tracing while maintaining an attractive price-to-performance ratio in an increasingly competitive GPU market. We expect these scores not to be the final tale in the AMD RDNA 4 story, as we must wait and see what AMD delivers during CES. Third-party reviews and benchmarks will give the final verdict in the RDNA 4 market launch.[Only registered and activated users can see links. Click Here To Register...]
Alleged GALAX GeForce RTX 5080 "Blackwell" Box-art Drops Big Clue Abou
The box-art of upcoming GALAX GeForce RTX 5080 "Blackwell" graphics card has much to say about the graphics architecture, without dropping any explicit mentions. The front-face of the box features a hooded human face—nothing fancy, until you begin to pay attention to the details. Half the face is composed of triangles streaming toward the face, while the other half is composed in place by a blue stream of light, as if to denote that it's being drawn by a fundamentally different method than "triangles."
The triangles here represent classic raster 3D graphics, while the other spirit-like half denotes neural rendering. Here's where it gets interesting. Both kinds of rendering are being applied to the same frame, and so neural rendering is fundamentally different from DLSS 3 Frame Generation, a technology that draws alternate frames using optical flow, motion vectors, and AI. Neural rendering appears to be, at least from this GALAX box-art, a technology that runs in real-time, where some elements, portions, or details of a frame are rendered by a generative AI, and others by raster 3D graphics.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD to Launch Radeon RX 9070 Series and FSR 4 Alongside Ryzen 9 9000X3
AMD's client computing division is expected to have an action-packed 2025 International CES. On the CPU front, the company is expected to expand its Ryzen 9000X3D family with high-core count models, such as the Ryzen 9 9950X3D and Ryzen 9 9900X3D. It is also expected to introduce certain power-efficient 65 W models of its non-X3D Ryzen 9000 series "Zen 5" chips, which serve as value options within this processor generation, to try and lure buyers off the 65 W Intel Core Ultra "Arrow Lake-S" models. On the gaming graphics side, the company is expected to debut its Radeon RX 9000 series, led by the RX 9070 XT and RX 9070, both of which are based on the "Navi 48" silicon, and powered by the RDNA 4 graphics architecture.
That's not all, AMD is also expected to announce the new FSR 4 technology for gamers. Leaks describe FSR 4 as being a performance enhancement that's a generation ahead of FSR 3.x. While FSR 3.x combines super-resolution based performance enhancement, and algorithmic frame-generation that nearly doubles framerates; FSR 4 is expected to be AMD's first performance enhancement to incorporate AI to not just enhance the visual detail in super-resolution, but also to improve accuracy of frame-generation. At this point, it is not known if FSR 4 will be available as a feature at launch of the Radeon RX 9070 series. VideoCardz reports that the early-January announcements could be followed by late-January availability of the hardware.[Only registered and activated users can see links. Click Here To Register...]
NVIDIA App Gets v11.0.1 Update, Disables Game Filters by Default
NVIDIA has released the newest v11.0.1 update for its NVIDIA App, and according to the release notes, it comes with a single new update that disables Game Filter by default. Previously, [Only registered and activated users can see links. Click Here To Register...] looking into reported performance issues related to Game Filter options in the NVIDIA App.
The NVIDIA app comes as a replacement for GeForce Experience software, which went out of the beta phase and became the default NVIDIA software application since the GeForce 566.33 driver update. Before the update, users were left with an option to manually disable Game Filter options in Settings > Features > Overlay > Game Filters and Photo Mode. Now, users are left with an option to manually enable the option in the same settings menu.[Only registered and activated users can see links. Click Here To Register...]
Minisforum Launches Portable Monitor With Dual 1080p Displays
Portable monitors are undoubtedly a rather niche category of displays, but there sure are people who can greatly benefit from their existence. For such people, the recently announced Minisforum MDSA156 sure does sound like a great product, at least on paper. At a price of $231, the portable monitor is quite affordable too. In fact, the MDSA156 gives buyers not one, but two displays connected with a 315° hinge, with the bottom display having a kick stand built in which allows for multiple setups to fit varying use cases. The product sports dual Type-C ports, as well as an HDMI port for input.
Both the displays sport a 1080p 15.6 inch IPS panel, providing plenty of pixels for all kinds of workloads. Weighing in at just a hair below 1 kg (2.2 lbs), the MDSA156 is commendably portable as well. Minisforum's website has listed out a variety of setups for the product, which have been attached below. However, with a peak brightness of just 250 nits and a mere 45% coverage of the NTSC color gamut (72% of NTSC ≈ 100% sRGB), the MDSA156 is certainly not meant for any kind of professional usage on the go, at least the kinds that depend on color reproduction. For other workflows, however, the product does look enticing for those who can take advantage of the displays.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Apple M4 MacBook Air Enters Production, M5 MacBook Pro on Track for 20
The Apple M4 hardly needs any introduction - the latest desktop-class SoC from the Cupertino giant is remarkably fast, while being impressively efficient. Its recently unveiled Pro and Max variants are equally praiseworthy, although none of the 4th generation Apple Silicon goodness is available on the extremely popular MacBook Air as of right now. However, that is about to change soon according to a reliable recent report.
According to Bloomberg's Mark Gurman, the M4-powered MacBook Air has already entered production, and is scheduled to witness the light of day by the spring of next year, possibly even earlier. However, it is certainly worth noting that unlike the MacBook Pro, the MacBook Air does not feature active cooling, making its performance rather limited in demanding, sustained scenarios as compared to the MacBook Pro. Even then, the M4 is likely to be much snappier than its primary x86 rival, Intel's Lunar Lake, if the M4 iPad Pro's performance is anything to go by.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Minisforum V3 SE 3-in-1 Tablet Goes on Sale with Ryzen 7 APU
Minisforum is a consumer hardware brand that is well known for its impressive lineup of SFF/Mini PCs. However, what might not be as well-known, might be the fact that the brand also makes a plethora of other computing hardware and accessories. The company had recently announced the V3 and the more affordable V3 SE 3-in-1 tablet PCs with a design that is reminiscent of the Microsoft Surface. The V3 SE is now available to purchase, starting at $799.
At its heart, the Minisforum V3 SE is powered by the 28 W Ryzen 7735U "Rembrandt R" APU based on the Zen 3+ microarchitecture paired with 16 GB of LPDDR5-6400 memory. The APU is a decently powerful one, with multicore performance that is roughly in the same league as the Core Ultra 7 258V "Lunar Lake" processor. Unsurprisingly, any kind of discrete graphics is absent from the PC tablet, thereby making it rely solely on the 12-CU Radeon 680M iGPU for graphically demanding tasks. Storage is taken care of by its 1 TB M.2 SSD, which is housed in a 2280 slot.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Samsung Collaborates with SEGA on New Sonic the Hedgehog PRO Plus
Samsung Electronics America, a world leader in advanced memory technology, has expanded its microSD portfolio with a line of new cards inspired by iconic characters from the Sonic the Hedgehog franchise, giving players an exciting new way to celebrate their fandom, while expanding their storage and powering ultra-fast gameplay. Created in collaboration with SEGA, the Sonic the Hedgehog PRO Plus microSDs will feature special designs depicting Knuckles (128 GB), Tails (256 GB), Sonic (512 GB) and Shadow (1 TB).
"Samsung PRO Plus microSD cards provide gamers, content creators and more with an easy, reliable, and secure way to store large amounts of data - delivering Sonic-speed right to your fingertips," said Jim Kiczek, Vice President of Memory Marketing at Samsung Electronics America. "Since debuting more than three decades ago, Sonic has become an icon of pop culture, featured in dozens of games, TV series, and movies. Now, with the Sonic the Hedgehog PRO Plus microSD cards, we're combining the franchise's instantly recognizable characters with the speed and reliability of Samsung PRO Plus microSDs to give your gear the ultimate Sonic boost."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Rigetti Computing Launches 84-Qubit Ankaa-3 Quantum Computer
Rigetti Computing, Inc., a pioneer in full-stack quantum-classical computing, announced today the public launch of its 84-qubit Ankaa-3 system. Ankaa-3 is Rigetti's newest flagship quantum computer featuring an extensive hardware redesign that enables superior performance. Rigetti also celebrates major two-qubit gate fidelity milestones with Ankaa-3: successfully halving error rates in 2024 to achieve a median 99.0% iSWAP gate fidelity, as well as demonstrating 99.5% median fidelity fSim gates.
Ankaa-3 is now available to its partners via the Rigetti Quantum Cloud Services platform (QCS)and will be coming to Amazon Braket and Microsoft Azure in the first quarter of 2025. Users will be able to operate these higher fidelity and universal iSWAP gates for a wide range of algorithmic research, with a median gate time of 72 nanoseconds. The faster (median 56 nanoseconds), more specialized fSim gates are useful for specific algorithms such as random circuit sampling, as recently demonstrated on Google's Willow system.[Only registered and activated users can see links. Click Here To Register...]
NVIDIA Releases GeForce Hotfix Driver Version 566.45 WHQL
NVIDIA has released a new hotfix driver version 566.45 WHQL, built upon the recent Game Ready Driver 566.36. This targeted update addresses specific issues affecting gaming performance and stability. The hotfix primarily focuses on resolving micro-stuttering issues reported by players in Indiana Jones and the Great Circle, along with improving overall stability for Ubisoft titles running on the Snowdrop engine.
The previous driver release brought optimizations for S.T.A.L.K.E.R 2: Heart of Chornobyl and Microsoft Flight Simulator 2024, including DLSS 3 support. It also expanded GeForce Experience optimal settings for several titles including Call of Duty: Black Ops 6, Delta Force, Dragon Age: The Veilguard, Horizon Zero Dawn Remastered, and Red Dead Redemption. With this latest hotfix update, NVIDIA has managed to iron out stability issues. However, there are no words about the overlay feature that reportedly brought 15% performance reduction while using NVIDIA App. While we don't host hotfix drivers, you can grab it from NVIDIA [Only registered and activated users can see links. Click Here To Register...].[Only registered and activated users can see links. Click Here To Register...]
(PR) Alphawave Semi Scales UCIe to 64 Gbps for 3nm Die-to-Die Chiplet
Alphawave Semi (LSE: AWE), a global leader in high-speed connectivity and compute silicon for the world's technology infrastructure, proudly introduces the industry's first 64 Gbps Universal Chiplet Interconnect Express (UCIe) Die-to-Die (D2D) IP Subsystem to deliver unprecedented chiplet interconnect data rates, setting a new standard for ultra-high-performance D2D connectivity solutions in the industry. The third generation, 64 Gbps IP Subsystem builds on the successes of the most recent Gen 2 36 Gbps IP subsystem and silicon-proven Gen 1 24 Gbps and is available in TSMC's 3 nm Technology for both Standard and Advanced packaging. The silicon proven success and tapeout milestones pave the way for Alphawave Semi's Gen 3 UCIe IP subsystem offering.
Alphawave Semi is set to revolutionize connectivity with its Gen 3 64 Gbps UCIe IP, delivering a bandwidth density of over 20 Tbps/mm, with ultra-low power and latency. This solution is highly configurable supporting multiple protocols, including AXI-4, AXI-S, CXS, CHI and CHI-C2C to address the growing demands for high-performance connectivity across disaggregated systems in High-Performance Computing (HPC), Data Centers, and Artificial Intelligence (AI) applications.[Only registered and activated users can see links. Click Here To Register...]
AMD's Pain Point is ROCm Software, NVIDIA's CUDA Software is Still Sup
The battle of AI acceleration in the data center is, as most readers are aware, insanely competitive, with NVIDIA offering a top-tier software stack. However, AMD has tried in recent years to capture a part of the revenue that hyperscalers and OEMs are willing to spend with its Instinct MI300X accelerator lineup for AI and HPC. Despite having decent hardware, the company is not close to bridging the gap software-wise with its competitor, NVIDIA. According to the latest report from [Only registered and activated users can see links. Click Here To Register...], a research and consultancy firm, they have run a five-month experiment using Instinct MI300X for training and benchmark runs. And the findings were surprising: even with better hardware, AMD's software stack, including ROCm, has massively degraded AMD's performance.
"When comparing NVIDIA's GPUs to AMD's MI300X, we found that the potential on paper advantage of the MI300X was not realized due to a lack within AMD public release software stack and the lack of testing from AMD," noted SemiAnalysis, breaking down arguments in the report further, adding that "AMD's software experience is riddled with bugs rendering out of the box training with AMD is impossible. We were hopeful that AMD could emerge as a strong competitor to NVIDIA in training workloads, but, as of today, this is unfortunately not the case. The CUDA moat has yet to be crossed by AMD due to AMD's weaker-than-expected software Quality Assurance (QA) culture and its challenging out-of-the-box experience."[Only registered and activated users can see links. Click Here To Register...]
NVIDIA GB300 "Blackwell Ultra" Will Feature 288 GB HBM3E Memory, 1400
NVIDIA "Blackwell" series is barely out with B100, B200, and GB200 chips shipping to OEMs and hyperscalers, but the company is already setting in its upgraded "Blackwell Ultra" plans with its upcoming GB300 AI server. According to UDN, the next generation NVIDIA system will be powered by the B300 GPU chip, operating at 1400 W and delivering a remarkable 1.5x improvement in FP4 performance per card compared to its B200 predecessor. One of the most notable upgrades is the memory configuration, with each GPU now sporting 288 GB of HBM3e memory, a substantial increase from the previous 192 GB of GB200. The new design implements a 12-layer stack architecture, advancing from the GB200's 8-layer configuration. The system's cooling infrastructure has been completely reimagined, incorporating advanced water cooling plates and enhanced quick disconnects in the liquid cooling system.
Networking capabilities have also seen a substantial upgrade, with the implementation of ConnectX 8 network cards replacing the previous ConnectX 7 generation, while optical modules have been upgraded from 800G to 1.6T, ensuring faster data transmission. Regarding power management and reliability, the GB300 NVL72 cabinet will standardize capacitor tray implementation, with an optional Battery Backup Unit (BBU) system. Each BBU module costs approximately $300 to manufacture, with a complete GB300 system's BBU configuration totaling around $1,500. The system's supercapacitor requirements are equally substantial, with each NVL72 rack requiring over 300 units, priced between $20-25 per unit during production due to its high-power nature. The GB300, carrying Grace CPU and Blackwell Ultra GPU, also introduces the implementation of LPCAMM on its computing boards, indicating that the LPCAMM memory standard is about to take over servers, not just laptops and desktops. We have to wait for the official launch before seeing LPCAMM memory configurations.[Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 9 9950X3D and 9900X3D to Come with Clock Speeds Resembling n
The AMD Ryzen 7 9800X3D launched this November remains the fastest processor for PC gaming, but with just an 8-core/16-thread configuration, its performance in multithreaded productivity pales in comparison to the alternatives, including from AMD's own camp, such as the Ryzen 9 7950X3D. The company is planning to expand the Zen 5 X3D line of desktop processors in Q1-2025, with the introduction of its high core-count Ryzen 9 series SKUs, the Ryzen 9 9950X3D, and the Ryzen 9 9900X3D. HXL, a reliable source with hardware leaks, says that the Ryzen 9 X3D SKUs will lack the kind of "frequency debuff" we've seen with the older generation Ryzen 9 X3D chips such as the 7950X3D and 7900X3D.
On the 7950X3D, only one of the two 8-core CCDs comes with 3D V-Cache, the other is a regular CCD with 32 MB on-die L3 cache. The CCD with the 3D V-Cache has its frequency "debuffed" compared to the other CCD, mainly to deal with the thermal limitations of the way the 3D V-Cache is stacked on top of the CCD. With the Ryzen 9000 X3D generation, AMD has redesigned this CCD + L3D stacking such that the CCD is now above, directly interfacing with the STIM and IHS; with no conductive structural silicon along the way. This means that the CCD now thermally behaves like a regular Zen 5 CCD; and for this reason, not only will the CCD with 3D V-Cache on the 9950X3D/9900X3D have the same clock speeds and boosting behavior as the one without 3D V-Cache; but also the 9950X3D and 9900X3D are expected to ship with similar, if not identical clock speeds to the 9950X and 9900X.[Only registered and activated users can see links. Click Here To Register...]
Qualcomm Wins Partial Victory in Arm Licensing Dispute, Retrial Possib
A Delaware jury has delivered a mixed verdict in the high-stakes licensing dispute between Qualcomm and Arm, with Qualcomm securing a significant but incomplete victory. The jury unanimously found that Qualcomm's use of Oryon cores in its Snapdragon X processors for client PCs did not violate its [Only registered and activated users can see links. Click Here To Register...]. The case centered on Qualcomm's $1.4 billion acquisition of Nuvia in 2021 and subsequent use of Nuvia's processor designs. Arm had alleged that Nuvia's licensing terms couldn't transfer automatically to Qualcomm and demanded renegotiation of the agreements. When Qualcomm proceeded with development, Arm insisted the [Only registered and activated users can see links. Click Here To Register...]. During the trial, Gerard Williams III, the lead developer of Oryon cores and former Apple engineer, testified that the final design contained [Only registered and activated users can see links. Click Here To Register...].
This testimony supported Qualcomm's position that its existing architecture license covered products designed by its subsidiaries. While Qualcomm celebrated the verdict allowing continued development of its Snapdragon X processors, the jury deadlocked whether Nuvia violated its original agreement with Arm, specifically about permitting server processor development. This impasse has prompted Arm to announce its intention to seek a retrial on this unresolved count. "We are disappointed that the jury was unable to reach consensus across the claims," Arm stated, wanting to protect its intellectual property and ecosystem. Meanwhile, Qualcomm expressed satisfaction with the decision, stating the verdict "vindicated Qualcomm's right to innovate." The stakes remain high for both companies. Qualcomm relies on its Oryon cores to compete in the PC market, where it currently holds a [Only registered and activated users can see links. Click Here To Register...], while Arm derives approximately $300 million annually from Qualcomm, representing 10% of its revenue.[Only registered and activated users can see links. Click Here To Register...]
Ryzen AI 9 HX 370-powered GMKTec EVO X1 Mini PC Goes on Sale
AMD's recently announced Strix Point APU lineup has received favorable reviews from critics and consumers alike. Especially for SFF/Mini PC enthusiasts, Strix Point brings commendable efficiency and performance to the table - both of which are absolutely essential for a high-end mini PC. The GMK EVO-X1 is surely among those, and the system is now available for purchase from GMKTec's [Only registered and activated users can see links. Click Here To Register...].
The EVO X1 sports a 110.19 x 107.3 x 63.2 mm chassis, which is decently compact for its class. As mentioned previously, the system is powered by the 12-core (4x Zen 5 + 8x Zen 5c) [Only registered and activated users can see links. Click Here To Register...] APU with the shockingly potent RDNA 3.5-based Radeon 890M iGPU with 16 CUs. For most CPU-centric workloads, the EVO X1 should easily suffice. The iGPU, as mentioned, is potent enough to handle most graphically demanding tasks, including some lightweight gaming, but expecting anything more from it would be futile. Thankfully, an OCuLink port is present, which should allow for extremely fast eGPU connections courtesy of its 64 Gbps bandwidth.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
