New SBox 0.0.4-e #2
____
| _ \
___| |_) | _____ __
/ __| _ < / _ \ \/ /
\__ \ |_) | (_) > <
|___/____/ \___/_/\_\ (emu/cardserver for PowerPC, MIPS, X86, SH4 & Freetz)
What's new? 0.0.4-e #2
-Fixed portlist bug
What's new? 0.0.4-e
-More changes related with nagra cards
+Added channelinfo support (see sbox.conf for details)
New SBox 0.0.4-f
____
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.4-f
-Fixed some bugs
+Added cccam cardserver support, emm support only for local cards (very very experimental) (see sbox.conf and users.sbox for details)
2 Attachment(s)
New SBox 0.0.5-0
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.5-0
-Fixes on cccam protocol (server/client)
+Added betatunnel support (see sbox.conf for details)
+More options for newcamd clients (see users.sbox)
What's new? 0.0.5-0 #2
-Como la lío
1 Attachment(s)
SBox 0.0.5-0 #3
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.5-0 #3
1 Attachment(s)
New SBox 0.0.5-0 #4
Code:
____
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.5-0 #4
+Added cache for virtual cccam cards
+Removed downhop limitation between SBox clients <-> servers (only work on local mode)
+Now, if you connect to a local newcamd server, card will appears as hop0
1 Attachment(s)
New SBox 0.0.5-1
Code:
____
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.5-1
-Some fixes
-Changes on dvbapi
+Now can send messages through webinterface between SBox clients <-> servers using cccam protocol
+Full emm support on cccam server
Daca ii merge cuiva ca si client cccam stabil sa ridice doua degete si sa spuna versiunea sbox,receptorul folosit,etc.Sunt binevenite si testele pe partea de server cccam,dar sa fie facute pe o perioada de minim cateva ore.
SBox 0.0.5-0 #3 + DM800 + card jiji
Din pacate ultimele 2 versiuni au un minus pe partea de stabilitate CCcam,in rest sunt ok
au rezolvat cu versiunea 5-1
se mai lucreaza la el.
mie imi merge stabil pe ipbox9000 sbox.sh4.
am renuntat la oscam client cccam!
incercai si eu sa-l pornesc pe Alien dar nu vrea ... apare la procese dar nu deschide nimic si nici nu se conecteaza la webinterface .
1 Attachment(s)
SBox 0.0.5-1 #2
Code:
____
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.5-1 #2
-Some fixes on webif and others
SBox 0.0.5-1 #3 Public
| _ \
___| |_) | _____ __
\__ \ |_) | (_) > <
What's new? 0.0.5-1 #3
-Contigo si contigo no
problema sbox
am un card digi care imi merge in dm500 cu cccam_sbox.pana acum ceva timp aveam o problema cu receptorul care se bloca si trebuia scos cablul de curent pentru a pleca.cu ajutorul lui zmeura am reusit sa scap de acest blocaj.acum mai nou am o alta problema si este si mai sacaitoare . de cateva ori pe zi se blocheaza imagine pe programul care merge din local.pleaca doar daca ii dau restart camd.cccamul functioneaza pentru ca programele din share imi merg.imaginea pe dm este gemini 4.6.orice sfat e binevenit.multumesc mult.
Si pana la urma ce card servar folosesti ? Sbox ??
Ai cumva setat asa:
pune 1 caci tu rulezi si cccam
apoi (daca) cand se blocheaza da din telnet
si vezi daca mai apare ca ruleaza sbox.
daca nu, pune scriptul ala si o sa-l restarteze
lao,e setat cu 1.am pus scriptul ala si nu se intampla nimic.pana nu ii dau restart camd nu pleaca.
Scriptul este numai ca sa restarteze sbox daca e oprit, daca e blocat si pare ca ruleaza scriptul nu-l reporneste.
Deci, din consola, ti-l mai arata ca exista ca proces?
habar nu am.cum imi dau seama?astept sa se mai blocheze si daca imi spui cum sa verific o sa o fac.
Incearca sa pui server_only=1 si sa opresti cccam,asa va merge doar sbox si vezi daca face aceleasi probleme.
Activeaza iar logul si vezi ce apare acolo in momentele in care se blocheaza,il gasesti in tmp (eventual postezi aici ce apare in acel moment).
