PKT mod 8.9 Tideglo rev 0.8.0
Changes in Points
- Bringing fashion to rev 0.8.0 Tideglo
- Patch for HD and similar phat
- The new driver 1.4 from Pacco for internal readers - does the card CP
- New F1 design fashion
- Two new skins:
PKT_F1-lite - displays less information thanks tuner works faster (default)
PKT_F1 HD - displays all the information
- Charging drivers to change the way readers (faster startup newcsa)
Ustawienia - > Auto TV Out" onmouseout="this.style.backgroundColor='#fff'">- The ability to change TV output when starting the tuner (similar to a firmware DGSA - click on the 'menu' on the front panel when starting the tuner) - BP -> Settings -> Auto TV Out
- Added Romanian language
- Fixed Finnish language
- Volume control right-left
- "Yellow" call to plugins
- Added support for Aspect Ratio of "green" for Media Player
- Update Picon
- Update the channel list
- Added a separate menu for Points Infocenter
- WebcamViewer - Update Camera
- Amendments of speed and code optimization
- Amendment to the GS in the absence of HDD
Regards Polish Team Kathi
WARNING! NOT LIABLE FOR THE USE OF THIS SOFTWARE, unlawfully, REMEMBER THAT LOOK PAY TELEVISION SUBSCRIPTION unpaid is a crime and be subject to imprisonment up to 3 years!
PS
Points Mod version 0.9.x will improve when Tideglo action polsatu HD channels
Ipbox 91:
Ipbox 900:
Ipbox 910:
Ipbox 9000:
A aparut PKT mod 9.2 Tideglo rev 0.9.2usb
ipbox 91:
ipbox 900:
ipbox 910:
ipbox 9000:
[Only registered and activated users can see links. Click Here To Register...] :clap:
PKT mod 9.5 Tideglo rev 0.9.5 USB STICK
- New skin Silver
- Added new font to the Silver Skin - inspired by Ariel
- New InfoCenter
- Added support for the STOP button to stop recording - previously stopped the REC button.
- Update Picon
- Added support for the green button in the Video Player in Windows Media Center to change the image format
- Amendments, inter alia, resulting in scripts moving faster through the list of channels
- Added update time from the server
- Enabled readers and loading modules ntfs
- Change the reader module from 1.3 to 1.4
- Default mount sda2 to / hdd
- Added Russian translation
- HDTV Romania
- Other minor cosmetic holder
ipbox 91:
ipbox 900:
ipbox 910:
ipbox 9000:
FOARTE BUNA BAFTA
Istalati cu incredere no sa regretati
A aparut PKT mod 9.6 Based rev 0.9.6 USB STICK
- Current list of channels
- A new spinner
- Added information about the active tuner in the InfoCenter
- Fix playback
- Amendment epg.dat (do not die after deep standby and reboot)
- Other minor cosmetic fixes
Greetings to Polish Team Kathi
WARNING! We assume no responsibility for the use THIS SOFTWARE unlawfully, REMEMBER THAT LOOK unpaid pay television subscription is a crime and are punishable by imprisonment up to 3 years!
Ipbox 91HD:
Ipbox 900HD:
Ipbox 910HD:
Ipbox 9000HD:
PKT mod 9.7.1 Based rev 0.9.7 USB STICK
Changes compared to version 9.7:
- New skin Basic HD (default)
- InfoCenter now works as a plugin
- Added plugin BootPlus 2.1
- Added plugin PermanentClock
- Added plugin AutoResolution
- Thrown plugin MyTube
- New Graphical Multi EPG
- New Blue Panel POINT
- New Emu Manager 0.9.9
- New Mount Man 0.7.4
- New Skin options in the Setup
- Adjust the skins to the new changes POINT
- Slimming skins
- Optimization of libraries
- Update Picon
- Reorganization MENU
- Many other small fixes
Ipbox 91HD:
Ipbox 900HD:
Ipbox 910HD:
Ipbox 9000HD:
PKT mod 9.8 Based rev 0.9.8 USB STICK
Tideglo Changes:
release 0.9.8
- fixed Scart/NTSC, HDMI/480i60, HDMI/480p60 resolutions (let me know if they are working ok or not,
here i can't test perfectly NTSC standard, but seems working good)
- fixed grey screen of death
- fixed some compatibility of HDMI video output
- fixed the switching between certain 1080p modes unreliable
- fixed YCbCr to full range RGB conversion
- sometimes happened that screen can get hidden when switching between modes that do not change the resolution
- some rescale improvements
- fixed some downscale bugs
- fixed some artifacts cases when stopping playback (need to test more about it)
- first try for audio clock initial setup for HDMI compatibility (people who are using Samsung's TVs and
have had problems with audio throught HDMI should let me know if there are improvements)
- fixed the bug where non-linear video zoom fail all over on (now it works good let me know how do you feel it)
- fixed a wmv bug
- fixed an alignment problem on DVD-player
- updated cross epg changes (now you should be able to use latest cross-epg version)
- minor bug fixes
PKT changes:
- Change to use the EPG button on the remote control
- Short press - Graphical Multi EPG causes
- Long hold - cause Simple EPG
- New Blue Panel PKT
- Adjust the skins to the new changes PKT
- Slimming skins
- Update Picon
Download usb-version
PKT mod 1.0.233 Tideglo rev 1.0.0
release 1.0.0
- enabled movie-list menu also on 100hd, 200hd, 250hd (press PLAY button instead of FILE on other receivers)
- fixed some playback bugs
- updated crossepg patches (compatible with last crossepg version)
- fixed some CI-CAM compatibility
- first try to fix TimeZone bug (time should be always ok now, standby and running mode)
- unicable is now more customizable (check enigma2 configuration)
- synced enigma2 with 29/10/2010 cvs
PKT changes :
New version InfoCenter
Change the shortcut for the InfoCenter to align with ipbox 9900HD
New Graphics Multi EPG for BasicHD and SilverHD
BasicHD skin in blue + change image
Added Install Manager
Update SkinSetup
Change the TV mode <-> RADIO now instructs one key TV / RADIO
MyTube call by pressing the WWW
Screensaver added in TV mode - MOSAIC call button (which previously elicited InfoCenter)
Picon update
Modified WebCamViewer
Change bootlogo
Patch libraries
Fixes performance and stability
Download :
