Octagon HD SF918 EMU AU CCAM USB PVR V10534
Octagon HD SF918 EMU AU CCAM USB PVR V10534 18/06/09 HDTV !
ENGLISH :
Readme_Version_18-06-09_EMU_AU_V10534
for Octagon HD SF 918 HDTV :
Changes :
- CCcam function improved (Beta4)
- CleanUp Main SW
--> Improvements for Stability, Database and Reboot bug.
--> Pls. Test long-time
- MCAS update
- WLAN Zigbee preparation Menu :
--> Menu - Module - CAS - ComPort - Homeshare : Zigbee extern, Zigbee intern, RS232
--> Channel 1~16
Advice :
- Display bright Status : Menu - Module - CAS Menu - RS232 Com Port - NONE
- Display dark Status : Menu - Module - CAS Menu - RS232 Com Port - Gbox, Homeshare, HSIC, Xcrypt
- AU update still works ;-)
Please make factory settings after SW update.
EMU and other CAS Setup`s :
Pls. press Menu --> Modules --> RED Button --> Enter 9999
--> CAS menu for EMU and other CAS Setup`s
--> EMU Key for Enter Key and Keyreset (Reset) with Yellow Button
Memory Setup`s :
Menu --> STB Status --> Memory Setup --> Options : Memory Backup and Memory Restore
Update : File --> OCTAGON_HD_SF918_EMU_AU_PVR_USB_e SATA_V10534__18_0 6_09_HDTV.bin --> Pls. copy of USB Stick and update STB !
Programm list & Setups save direct to USB Stick :
--> USB Stick connect to STB,Go Menu - USB Menu --> press INFO Button, Program list + setups save direct to USB Stick
Premiere Portal (Multifeed) - Button --> OPT+ or also AV+
Master Password : 0918
Teletext Parental Lock, Password : 0918
- Advise : For new generation remote Control 2 Buttons changed
--> old Remote control : Fine-Tune and X+ Button
--> new Remote control : Fine Tune with Red Button, X+ with Green Button
- Channel hide/skip (HIDE) aktivate/deaktivate Button change
--> Pls. press OK button to Ch.List - now with REC Button can aktivate/deaktivate HIDE channels
--> Password : 9999
Ethernet LAN / RS232 : CCcam, NewCamd, Gbox, Homeshare, HSIC, Xcrypt etc. ;-)
Re: Octagon SF918 HDTV - Linux Kernel - LAN
un pret informativ , cel putin asa cred fiindca nu cred ca-l au in stoc pt. noul :
- Octagon SF 1018 HD : [Only registered and activated users can see links. Click Here To Register...]
Salut , pt. cei interesati de noul model OCTAGON 1018 HD, aveti mai jos manualul acestui receiver in germana/engleze :
