@abadon
Hopa...ti-ai luat Dreambox? Ce model?
@abadon
\Quote:
Originally Posted by wambertos [Only registered and activated users can see links. Click Here To Register...]
dm500 man ..neoriginal binenteles:) .....in sfarsit:clap: ...incepusem sa ma simt nashpa si cautam o solutie sa-ti spun..offfffff:sorry:
Ce e asa de greu sa spui ca ti-ai luat?
Oricum e mai bun decit ala de la mine de 10x, chiar daca e clona.
Felicitari man!,acuma cum e,e diferenta intre sharingul ce il incercasem noi anul trecut pe echolite 790 si....o clona dream nu? relax man,ai facut o achizitie excelenta ai sa-ti dai seama in timp de nenumeroasele facilitati pe care ti le ofera un receiver cu linux.:) :cheers:Quote:
Originally Posted by abadon [Only registered and activated users can see links. Click Here To Register...]
Aici vom posta tot ce apare nou ca imagine.!
DS TEAM 3.6 for DM7000,DM500, ITGATE TGS100,110, 200, 220, TECHNOMATE 9100, 9101
Image per FLASH / USB / HDD / CF / NFS
+ CVS 04.04.2008
+ kernel v. 2.6.9 (1.10)
+ enigma v. 1.10 Mod (04.04.2008 mod DS Team)
+ BusyBox v1.01
+ Web Interface: 6.04-Expert mod DS
+ Gcc 3.4.4
+ FP Firmware 1.06
+ LZMA Patch
+ ScriptService 2.05 mod DS
New mapping of Buttons:
+ BLUE Button - EmuManager
+ YELLOW Button - DS Extras
+ HELP Button - QuickButton
+ GREEN Button - Subservices (NVOD)
+ AUDIO Button - Audio Selection
+ TEXT Button - Videotext
+ RED Button - EPG List for the current channel
+ 2x RED Button - Double Click for EPG Style Menu
+ AUDIO -> Timeshift ( DREAMBOX )
!!! THIS FIRMWARE DOES NOT INCLUDE ****, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT!!
!!! DS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
NEWS & FIXES in DS 3.6
- Inadyn Manager
- Bacground Daemons
- DropBear Manager
- Swap Manager
- Hdd Manager
- Now you can choose picons place ( usb/cf/hdd/mmc)
- Decoding Setup moved to DS Extras
- EPG Store Setup moved to DS Extras
- Infobar Setup moved to DS Extras
- Automatic Scripts fix
- Main menu shortcut added
- Audio Language Priority Menu
- Added config files download
- New default skin: DS MultLine 9 Turkoise
--- TM & IT
- 16:9 Letter box & Panscan mode updated
- Audio subtittle improve
- Better OSD performance
- Card reader driver improved
- WSS bug fixed
- Sat config bug fixed
- Diseqc manual motor moving function bug fixed
- System memory increase(59Mbyte -> 61Mbyte)
- SUB Service bug fixed
- Audio Track selection menu bug fixed
- EPG memory leak bug fixed
- EPG list/info bar speed improved
- DHCP improved
- Net driver register API bug fixed and added(Multicast API)
- USALS button on motor screen FIX
- Voltage-> DISEqC cmd time gap (20 msec -> 120msec) some LNB have problem
- No more hang-up during PVR playing or channel zapping
- No more random reboot during channel zapping
- Improved DiSEqC Motor functioning
- Fixed PVR(or live) lip-sync, lock up problem
- SNR & AGC & BER fixed
- Radio channel overflow fixed
- Fixed memory leak
- Fixed volume
- Fixed Rotor
Known Bugs:
Timer don't work when you press INFO -> YELLOW
Timer WORKS only in Menu -> Timers and there you can manage it.
Many thanks go to: fdlsys, Nixus, Guardian, AllSats beta testers, bytes and our Best Skin Makers ever: mimi74 and Matrix10!!
Downloand;
Un back-up GP 4.3.1 ( DM 500) cu gbox 2.1b , mgcamd , gbox/mgcamd
sau alt link
@spaniolul....Imaginea noua DS TEAM 3.6 mi s-a parut mai slaba ca precedenta. Sincer. Subtitrarea nu mai merge deloc.
La mine a mers prima data dupa aceea nu a mai vrut deloc,probabil e singurul bug pe care il are.Quote:
a rezistat subtitrarea la zapp si restart ; mewcs+mgcam au mincat singure cam 33% din /var .
( si daca nu ma insel are default cel mai oribil OSD intilnit pina acum )
Cred ca din cauza OSD-ului nu am stat sa ma joc mai mult cu imaginea. Cert e ca la mine nu a vrut deloc sa mearga subtitrarea. Butonul audio era inexistent. Oricum cred ca baietii au facut un pas inapoi cu aceasta imagine.
Imaginile GP 4.3.0 si 4.3.1 nu le mai puneti!
Riscati sa va distrugeti boxurile!
Bine ca am pus la backup ca e 431 sa nu injure lumea ...imi pare rau dar si eu sant cu virusul in optibox.
Poate scoate cineva din imaginea aia cu au pe mct fisierele exacte ce fac au cu orice emu ? Poate se pot introduce in alt gemini mai vechi sau in Nabilo.
Astea sa fie
/var/lib/modules/269/fisier.ko
/var/etc /ini ?????
Am uitat sa specific , imaginea ce face au la MCT se numeste
'' No_public_Image" este un gp 431 compilat sa faca AU .E bine de stiut unde se afla fisierele alea si daca se pot baga in Nabilo de exemplu.
