stabila, menu interesant merge iftv in hd!!bravo baieti!:band:
tic2000 poti sa fii putin mai detaliat legat de , te citez : "mai multe linii....."
in prezent am numai 1 asa zisa linie (fiindca nu seamana cu linia C: data la schimb in cccam) , catre dm/server si unde am peste 30 linii
pot scrie mai multe linii cu "user" si "passw" + ip-ul , de la cei cu care fac schimb cccam in "incubus 0.82"
fiindca pt. o "linie" incubus iti trebuie :
- un "user" + o "passw" + ip-ul server-ului (a celui cu care ai facut schimb de linie) sau ma insel ?
merci de info. liniile din incubusCamd.conf trebuie configurate altfel decat in cazul 0.55?Quote:
Originally Posted by tic2000 [Only registered and activated users can see links. Click Here To Register...]
daca ai sa te utiti pe prima pagina al acestui topic ai sa vezi ca exista un exemplu de configurare. plus inca in vreo patru locuri pe forum
cu scuzele de rigoare, asa e. l-am facut sa mearga, ma uitasem pe exemplele de configurare, dar nu eram atent. acum merge. scuze once again, as sterge postul anterior, dar nu pot.
@mario si ionutz
cred ca raspunsurile sunt deja in incubuscamd.conf si chiar si in acest thread cateva raspunsuri mai sus.
da, sorry once again...
hi zildan
thank for new image
i am download and setup incubus 0.55 white kathe network in this image
but it not work
if i am start incubus 0.55 or 0.50 (E2 RSP 3.17b TDT 1142) showing this error (/usr/lib/enigma2/python/Plugins/Extensions/Fantastic/emustop.sh line 4 can't open /var/config/incubuscamd.v0.82.emu
i never launch download v0.82 i am download only v.055 and v0.50
no any incubus work for me
help please
sorry for bad English
This message appears only at first start of emu, and does not affect emu operation.Quote:
IncubusCamd.conf downloaded from server is for v 0.82.
If you want to use ver, 0.55 or 0.50, copy old version of conf to /var/keys/.
thank you very mach zildan
you are & RSP team very good
am reinstalat imaginea si FTV HD face la fel, adica se intrerupe sonorul, imaginea ...
sunetul pe 5.1 se intrerupe pe canalelel HD ...
este posibil sa fie din aparat, ca am vazut ca pe altele merge bine si FTV si sunetul 5.1.
oricum, cea mai buna imagine din toate timpurile, felicitari Zildan:dance:
Problema cu FTV HD poate fi din noile drivere video.
Am verificat, asa face si la mine.
Sonoru il lasi pe AC3 downmix ON daca vrei sa nu ai probleme.
nu stiu daca e o calitate a noii imagini sau a noului incubus, dar ce-am observat e ca dupa ce pornesc kathi, adica il scot din stand-by, nu mai e nevoie sa restartez incubusul, pleaca direct. inainte, trebuia sa restartez incubus (buton rosu/7/restart emu) ca altfel era blocat...
in rest, no green screens, nimic, dar il am doar de o zi, o sa mai postez impresii..
Wery nice Image I really love the RSP images.
But wonder about something i notised on the dvbsubtitle position on DreamTv HD skin. The sub is wery small and second line is wery low on my tv. Only halfe of the letters is showing
Is it possible to change the position on the dvbsub and maybe make the letters a bit bigger ?
If it is possible to do myself what , and which file to edit in ?
Thnx
Softkey
in fisierul "skin.xml" modificati:
screen name="SubtitleDisplay" position="275,150" (initial este 275,170)
o sa se vada mai sus subtitrarea
