Apexel “Telescopes” Add 8x to 20x Optical Zoom to Smartphones for $8 a
Smartphones are getting better at taking photos, and cameras in high-end phones are are getting almost as good as DSLR cameras in many cases. However, one advantage of DSLR cameras is that...[Only registered and activated users can see links. Click Here To Register...]
Samsung Unveils Exynos Modem 5100 with 5G, 4G, 3G, and 2G Connectivity
5G will start being deployed sometimes next year, and we’ve already seen announcement of several 5G modem chips including Qualcomm Snapdragon X50, Mediatek Helio M70 , and Huawei Balong 5G01....[Only registered and activated users can see links. Click Here To Register...]
USB Charging Actually Poses Security Risks – Hacking a Laptop via a USB-C Adapter
Smartphones have been charged over USB for many years, but with the advance of USB type-C now even laptops may be charged over USB, instead of the typical DC power barrel jack. Why am I writing about...[Only registered and activated users can see links. Click Here To Register...]
Linux 4.18 Release – Main Changes, Arm and MIPS Architecture
Linus Torvalds has just announced the release of Linux 4.18: One week late(r) and here we are – 4.18 is out there. It was a very calm week, and arguably I could just have released on schedule...[Only registered and activated users can see links. Click Here To Register...]
Amlogic Open Source Video Decoder Driver Coming Soon for S905, S905X and S912 Processors
Allwinner processors aren’t the only ones getting an open source hardware video decoding / encoding support in Linux, as Maxim Jourdan recently submitted a patchset to Amlogic Linux mailing...[Only registered and activated users can see links. Click Here To Register...]
Arduino Releases Command Line Interface (CLI) Alpha Preview
So far, AFAIK the only official ways to program Arduino boards were through the Arduino IDE program, or the cloud-based Arduino Create which works in your web browser and does not require any...[Only registered and activated users can see links. Click Here To Register...]
Axiomtek SDM300S is an Intel Apollo Lake Smart Display Module (SDM-S) for Digital Signage
Way back in 2010, Intel introduced the Open Pluggable Specification (OPS) defining mechanical and electrical parameters for players to be integrated into digital signage displays, with the goal of...[Only registered and activated users can see links. Click Here To Register...]
NanoPi M4 Raspberry Pi Inspired RK3399 Board Launched for $65 and Up
As expected, FriendlyELEC has now launched NanoPi M4 board, a lower cost version of NanoPC-T4 Rockchip RK3399 SBC, and mostly following Raspberry Pi form factor. How much you may ask? That would be...[Only registered and activated users can see links. Click Here To Register...]
CHOETECH 24W Foldable Solar Charger Review
A short while ago, I wrote about a tri-panel waterproof solar power bank that delivers up to 4 Watts and comes with 10,000 mAh capacity. I’ve now received a sample of a somewhat similar...[Only registered and activated users can see links. Click Here To Register...]
PiMecha Humanoid Robot Based on Raspberry Pi Sells for about $500
SB Components introduced PiMecha humanoid robot powered by a Raspberry Pi Zero (W)/ A+ / 2 / 3 (B+) board, and offering 17 degrees of freedom (DoF) on Kickstarter a few months ago. But with KS...[Only registered and activated users can see links. Click Here To Register...]
TableX Arm Linux Tablet Runs Armbian Ubuntu, To Launch for 89 Euros
If you want an Arm Linux laptop, you have already some choices with products such as Pine64 Pinebook, or Olimex TERES-I open source hardware laptop, but if instead you’d rather do without...[Only registered and activated users can see links. Click Here To Register...]
Kohler Novita “Therapy Bidet” Bluetooth LE Enabled Toilet Seat Works with Android & iOS Smartphones
If you’ve ever been to Japan, and to a lesser extend in Korea, you’ll probably have used one those toilet seat that sprays water, and ends with a gentle drying once you’re done with...[Only registered and activated users can see links. Click Here To Register...]
Samsung Introduces Exynos i S111 NB-IoT Modem + GNSS Chip
Samsung has just announced their first NB-IoT solution with Exynos i S111 chipset with a single chip integrating an NB-IoT capable LTE modem, RF IC, an on-chip security sub-system, and a PUF...[Only registered and activated users can see links. Click Here To Register...]
?Art is a Universal USB to UART-TTL Adapter with Safety Features (Crowdfunding)
I’ve never had specific issues with USB to TTL debug boards personally, but potentially you could damage the target if you select one with the wrong voltage, and for more advanced use cases...[Only registered and activated users can see links. Click Here To Register...]
n-fuse LoRaWAN Concentrator mini PCIe Card Comes with either SX1301 or SX1308 Chip
Most gateways are based on Semtech SX1301 chip, but the company unveiled a SX1308 chip for picocell gateways back in 2016 that’s supposed to be cheaper and used indoors. Designs have been slow...[Only registered and activated users can see links. Click Here To Register...]
Review of Firefly-RK3399 Board with Android 8.1 Firmware
Last week, I tested Android 7.1 on NanoPC-T4 Rockchip RK3399 SBC, and this week, I’ve given a try at Android 8.1 (Beta) on Firefly-RK3399 Board. Since it’s still a beta version, I’m...[Only registered and activated users can see links. Click Here To Register...]
Embedded Base Boot Requirements (EBBR) Project Aims to Standardize Booting on Embedded Systems
Desktop and server systems relies on standardized interfaces between the bootloader and the OS like UEFI and ACPI, but for embedded systems the way the bootloader, often U-boot, handles the boot flow...[Only registered and activated users can see links. Click Here To Register...]
How to Make a Cheap Single Channel Gateway with an ESP32 LoRa Board
Actual LoRaWAN gateways based on Semtech SX1301 concentrator can be pretty expensive, and even if you take a LoRa gateway design based on Raspberry Pi for indoor placement or experimentation, price...[Only registered and activated users can see links. Click Here To Register...]
Pocket Science Lab (PSLab) is an Open Source Hardware Electronics Lab
Last Saturday I created a virtual schedule for the Embedded Linux Conference Europe 2018 where I listed some of sessions relevant to myself and hopefully regular readers of CNX Software, but due to...[Only registered and activated users can see links. Click Here To Register...]
Forlinx OK5718-C Development Board is Powered by TI AM5718 Cortex-A15/M4 processor
Forlinx Embedded Technology (Forlinx) has just launched a new development board for indsutrial applications with audio and video processing requirements. OK5718-C development board features Texas...[Only registered and activated users can see links. Click Here To Register...]
Tranquil PC’s AMD Ryzen Embedded Mini PC Supports Up to 4 Displays
AMD Ryzen Embedded V1000 processor family was introduced last February, but if you’d wanted to buy a Ryzen Embedded mini PC today, you’ struggle to do so at least for a retail model. One...[Only registered and activated users can see links. Click Here To Register...]
Acer Aspire 3 A315-41G (AMD Ryzen 7 2700U) Laptop – Installing Ubuntu 18.04 and “Hidden” M.2 SSD Socket
Everyday I’m using a tower PC running Ubuntu 18.04 to take care of this blog, but when I travel it’s obviously not so convenient, so a few years ago I bought an Acer Aspire E5-421G...[Only registered and activated users can see links. Click Here To Register...]
Embedded Linux Conference Europe & OpenIoT Summit Europe 2018 Schedule
The Embedded Linux Conference & OpenIoT Summit 2018 took place in March of this year in the US, but the European version of the events are now planned to take place on October 21-24 in Edinburg,...[Only registered and activated users can see links. Click Here To Register...]
Check for Spectre, Meltdown, and L1 Terminal Fault Vulnerabilities with Spectre-meltdown-checker Script
Yesterday, we wrote a little bit about the new speculative execution vulnerability known as L1 Terminal Fault (L1TF) or Foreshadow, and a reader – MHSadri – pointed to an interesting...[Only registered and activated users can see links. Click Here To Register...]
Tachyon Arduino Zero Compatible Board Features Microchip SAMD51 Arm MCU @ 120 MHz (Crowdfunding)
Most Arm based Arduino compatible boards come with a Microchip SAMD21 Arm Cortex-M0+ MCU clocked at up to 48 MHz since this is the microcontroller found in the official Arduino Zero and MKRZero...[Only registered and activated users can see links. Click Here To Register...]
Arm Roadmap to 2020 Reveals Deimos and Hercules Processors for 5G Lapt
Arm has just published a roadmap for their Cortex-A processors until 2020, where we can see 7nm Deimos, and 7 to 5 nm Hercules succeeding Arm Cortex A76 core with “laptop class...[Only registered and activated users can see links. Click Here To Register...]
Zymkey is a Hardware Security Module for Raspberry Pi Board
Microchip ATECC508A CryptoAuthentication chip appears to be a popular way to add hardware encryption support to development boards, as we’ve seen previously with 96Boards’ Secure96...[Only registered and activated users can see links. Click Here To Register...]
$50 Fish32 Seed “Education” ESP32 Board Comes with Plenty of I/Os, Sensors, and Connectivity Options
Sometimes I feel the word “Education” is sometimes thrown around for marketing purpose, and AnalogLamb Fish32 Seed board for “ESP32 Community Education Board” feels that way...[Only registered and activated users can see links. Click Here To Register...]
More Speculative Execution Exploits – Meet Foreshadow / L1 Terminal Fault
Speculative execution is a feature to speed up performance of recent processors which works by predicting and loading likely future instructions ahead of time. The features became somewhat famous a...[Only registered and activated users can see links. Click Here To Register...]
BlitzWolf Inexpensive & Compact EU & US Smart Sockets Work with ESPurn
When I first started to look into WiFi smart sockets a few years, there were some fairly compact models such as the Linux based Kankun KK-SP3 or ESP8266 based Konke Mini K sockets. In recent years,...[Only registered and activated users can see links. Click Here To Register...]
Seeed Studio Introduces 1 to 8 Channels Grove I2C Solid State Relay Modules
I’ve been playing with products or boards with AC relays for a while, but I never really cared to check about different types of relay. So far, all platforms I tested came with largish blue or...[Only registered and activated users can see links. Click Here To Register...]
Intel Core Y-series and U-series 8th Gen Processors Target Laptops with Built-in Gigabit WiFi, Optional LTE Connectivity
We discovered three Intel Amber Lake processors with a 5W TDP through a leak last month namely Core m3-8100Y, Core i5-8200Y, Core i7-8500Y dual core/quad thread processors. Intel has now made an...[Only registered and activated users can see links. Click Here To Register...]
MCC 118 DAQ HAT Enables Up to 64-Channel Voltage Measurement on Raspberry Pi Boards
Measurement Computing Corp. (MCC) has recently introduced their MCC 118 DAQ HAT for Raspberry Pi which includes 8 analog inputs for voltage measurements between +/- 10V at a 100kS/s data rate. You...[Only registered and activated users can see links. Click Here To Register...]
Xiaomi PocoPhone F1 Snapdragon 845 Smartphone Launched for $300 and up in 65 Countries
Several manufacturer have launched Qualcomm Snapdragon 845 powered smartphones, including Samsung with Galaxy Note9 and Galaxy S9/S9+ models. Those premium smartphones are normally pretty expensive...[Only registered and activated users can see links. Click Here To Register...]
VMWare Showcases ESXi Bare Metal Hypervisor Support for ARM64 Edge Servers
As I checked my Twitter timeline in Thunderbird this morning, I started to see a lot of tweets about #VMworld2018 and “ESXi on 64-bit Arm”. What is that? VMWare has just announced and...[Only registered and activated users can see links. Click Here To Register...]
RockPro64 RK3399 Board Linux Review with Ubuntu 18.04 + LXDE
Let’s do one more RK3399 Linux review using Pine64 RockPro64 development board. After shortly checking out the hardware, I’ll test Ubuntu 18.04 “Bionic” LXDE on the board,...[Only registered and activated users can see links. Click Here To Register...]
MicroWebSrv Lightweight HTTP Web Server Supports HTML/Python Language Templating
There are many languages that can be used to create a web page: HTML, HTML5, JavaScript, PHP, etc… But Python? Apparently yes, as MicroWebSrv lightweight web server – mostly designed...[Only registered and activated users can see links. Click Here To Register...]
UltraZed-EV Starter Kit Support Simultaneous 4K Encoding and Decoding with Xilinx Zynq UltraScale+ EV MPSoC
Xilinx unveiled Zynq UltraScale+ MPSoC‘s combining Arm Cortex A53/R5 cores with FPGA fabric back in 2015. and we started to see development boards and products based on the solution starting in...[Only registered and activated users can see links. Click Here To Register...]
Tanix TX3 Mini L Amlogic S905W TV Box with 2GB RAM Sells for as low as $16.99 (Promo)
Last year, it was relatively easy to find promotions for ultra cheap TV boxes selling for under $20, but with the price increase of flash and RAM chips it has become harder to find. GearBest has now...[Only registered and activated users can see links. Click Here To Register...]
MINIX NEO J50C-4 Pentium J5005 Mini PC Review – Part 1: Unboxing, Wind
MINIX has just announced a new Windows 10 Pro mini PC with MINIX NEO J50C-4 mini PC that just looks like their previous models like MINIX NEO N42C-4, except it comes with a Pentium Silver J5005...[Only registered and activated users can see links. Click Here To Register...]
Lindenis V5 Allwinner V5 SBC is Designed for AI Video Processing, 4K Encoding
Allwinner V5 V100 is a new quad core Cortex A7 processor targeting 4K 30 fps (Linux) cameras, and integrating AIE intelligent analytic acceleration engine handling motion detection, perimeter...[Only registered and activated users can see links. Click Here To Register...]
BladeRF 2.0 USB 3.0 Software Defined Radio Launched for $480 and Up
Around 5 years ago, several affordable FPGA based open source software defined radio boards launched including HackRF, BladeRF x40 / x115, and USRP B200. The company behind BladeRF has now launched...[Only registered and activated users can see links. Click Here To Register...]
Lenovo Yoga C630 WOS Laptop Comes with Qualcomm Snapdragon 850 SoC, up to 8GB RAM & 256GB UFS Storage
The first Windows 10 based Arm laptops, also referred to as always-on always connected mobile PC’s, were launched last year with Qualcomm Snapdragon 835 processor, LTE connectivity and promises...[Only registered and activated users can see links. Click Here To Register...]
ARCO is a Real Robot that Lives in Virtual Worlds (Crowdfunding)
Hicat launched HICAT.Livera machine vision board for robotics projects on Kickstarter two year ago. The company second project is still related to robotics and machine vision, but geared towards a...[Only registered and activated users can see links. Click Here To Register...]
ASUS ZenBook Pro 14 UX480FD Laptop Replaces the Touchpad with a 5.5? “ScreenPad” Display
Touchpads is a feature found in most laptops, but AFAIK there’s not been much innovation recently apart from maybe support for multitouch and gestures. But I’ve just found out ASUS...[Only registered and activated users can see links. Click Here To Register...]
TopJoy Falcon Mini Laptop Features an Intel Pentium N5000 Processor, an 8? Display (Crowdfunding)
UMPC’s (Ultra Mobile PC) or mini laptops have made a sort of comeback in recent years with products such as GPD Pocket 2 mini laptop or One Mix Yoga pocket laptop. Those products come with a...[Only registered and activated users can see links. Click Here To Register...]
MINIX NEO U9-H TV Box Gets Android 7.1 Firmware
MINIX NEO U9-H is generally considered one of the best Android TV boxes if you are after an Android experience, as opposed to a pure Android TV experience. I found the firmware solid and performing... [Only registered and activated users can see links. Click Here To Register...]
LicheeTang Anlogic EG4S20 FPGA Board Targets RISC-V Development
LicheePi has already made some interested little development board in the past with products such as LicheePi Zero, and the recently-announced SD card sized LicheePi Nano board, but their latest... [Only registered and activated users can see links. Click Here To Register...]
Self-hosted GLES on ChromeOS, part two
This is a follow-up post from an earlier guest post by Blu about OpenGL ES development on Chrome OS. One can’t practice real-time rendering to disk files for long ? it’s just unnatural. So... [Only registered and activated users can see links. Click Here To Register...]
HiSilicon Unveils Kirin 980 Octa-core Cortex A76/A55 Processor with Mali-G76 GPU
Arm announced Cortex A76 CPU core and Mali-G76 GPU in June of this year, and in the past, we normally had to wait about a year between the announcement and the actual launch of SoC with the new IP... [Only registered and activated users can see links. Click Here To Register...]
Allwinner V5 V100 is a new quad core Cortex A7 processor targeting 4K 30 fps (Linux) cameras, and integrating AIE intelligent analytic acceleration engine handling motion detection, perimeter... [Only registered and activated users can see links. Click Here To Register...]
Around 5 years ago, several affordable FPGA based open source software defined radio boards launched including HackRF, BladeRF x40 / x115, and USRP B200. The company behind BladeRF has now launched... [Only registered and activated users can see links. Click Here To Register...]
The first Windows 10 based Arm laptops, also referred to as always-on always connected mobile PC’s, were launched last year with Qualcomm Snapdragon 835 processor, LTE connectivity and promises... [Only registered and activated users can see links. Click Here To Register...]
Hicat launched HICAT.Livera machine vision board for robotics projects on Kickstarter two year ago. The company second project is still related to robotics and machine vision, but geared towards a... [Only registered and activated users can see links. Click Here To Register...]
Touchpads is a feature found in most laptops, but AFAIK there’s not been much innovation recently apart from maybe support for multitouch and gestures. But I’ve just found out ASUS... [Only registered and activated users can see links. Click Here To Register...]
UMPC’s (Ultra Mobile PC) or mini laptops have made a sort of comeback in recent years with products such as GPD Pocket 2 mini laptop or One Mix Yoga pocket laptop. Those products come with a... [Only registered and activated users can see links. Click Here To Register...]
I’ve been playing with products or boards with AC relays for a while, but I never really cared to check about different types of relay. So far, all platforms I tested came with largish blue or... [Only registered and activated users can see links. Click Here To Register...]
We discovered three Intel Amber Lake processors with a 5W TDP through a leak last month namely Core m3-8100Y, Core i5-8200Y, Core i7-8500Y dual core/quad thread processors. Intel has now made an... [Only registered and activated users can see links. Click Here To Register...]
Measurement Computing Corp. (MCC) has recently introduced their MCC 118 DAQ HAT for Raspberry Pi which includes 8 analog inputs for voltage measurements between +/- 10V at a 100kS/s data rate. You... [Only registered and activated users can see links. Click Here To Register...]
As I checked my Twitter timeline in Thunderbird this morning, I started to see a lot of tweets about #VMworld2018 and “ESXi on 64-bit Arm”. What is that? VMWare has just announced and... [Only registered and activated users can see links. Click Here To Register...]
Let’s do one more RK3399 Linux review using Pine64 RockPro64 development board. After shortly checking out the hardware, I’ll test Ubuntu 18.04 “Bionic” LXDE on the board,... [Only registered and activated users can see links. Click Here To Register...]
There are many languages that can be used to create a web page: HTML, HTML5, JavaScript, PHP, etc… But Python? Apparently yes, as MicroWebSrv lightweight web server – mostly designed... [Only registered and activated users can see links. Click Here To Register...]
Xilinx unveiled Zynq UltraScale+ MPSoC‘s combining Arm Cortex A53/R5 cores with FPGA fabric back in 2015. and we started to see development boards and products based on the solution starting in... [Only registered and activated users can see links. Click Here To Register...]
Last year, it was relatively easy to find promotions for ultra cheap TV boxes selling for under $20, but with the price increase of flash and RAM chips it has become harder to find. GearBest has now... [Only registered and activated users can see links. Click Here To Register...]
As expected, FriendlyELEC has now launched NanoPi M4 board, a lower cost version of NanoPC-T4 Rockchip RK3399 SBC, and mostly following Raspberry Pi form factor. How much you may ask? That would be... [Only registered and activated users can see links. Click Here To Register...]
A short while ago, I wrote about a tri-panel waterproof solar power bank that delivers up to 4 Watts and comes with 10,000 mAh capacity. I’ve now received a sample of a somewhat similar... [Only registered and activated users can see links. Click Here To Register...]
SB Components introduced PiMecha humanoid robot powered by a Raspberry Pi Zero (W)/ A+ / 2 / 3 (B+) board, and offering 17 degrees of freedom (DoF) on Kickstarter a few months ago. But with KS... [Only registered and activated users can see links. Click Here To Register...]
If you want an Arm Linux laptop, you have already some choices with products such as Pine64 Pinebook, or Olimex TERES-I open source hardware laptop, but if instead you’d rather do without... [Only registered and activated users can see links. Click Here To Register...]
Samsung has just announced their first NB-IoT solution with Exynos i S111 chipset with a single chip integrating an NB-IoT capable LTE modem, RF IC, an on-chip security sub-system, and a PUF... [Only registered and activated users can see links. Click Here To Register...]
STMicro STM32F7x0 & H7x0 Value Line Microcontrollers Deliver Cortex-M7
STMicro introduces their first Arm Cortex-M7 microcontrollers in 2014 with STM32F7 series clocked up to 200 MHz. The next year, Atmel – now Microchip – announced SAM S70 & SAM E70...[Only registered and activated users can see links. Click Here To Register...]
MUSTOOL MT8206 Multimeter & Oscilloscope Goes for $42 (Promo)
MUSTOOL MT8206 looks like a standard digital multimeter, but the device is actually a 2-in-1 device that also serves as a oscilloscope. Banggood have the digital multimeter scope on sale now for...[Only registered and activated users can see links. Click Here To Register...]
Nubia–? Wearable Smartphone is a Smartwatch with a Long Curved Display
We have smartphones, we have smartwatches. and we have… Nubia-? that is something in between, and which the company (Nubia) promotes as a “wearable smartphone”. The device comes...[Only registered and activated users can see links. Click Here To Register...]
Creality Ender 3 3D Printer Sells for $169.99 (Promo)
From time to time I come across good deals for 3D printers, and a recent promotion for Creality Ender 3 3D printer appears to be one of them. Creality Ender 3 has gotten some pretty good reviews...[Only registered and activated users can see links. Click Here To Register...]
Compulab WILD WiFi Router Supports WiFi RTT (802.11mc) Location
When Google released the first Android P preview back in March, one interesting new feature was indoor positioning through 802.11mc WiFi aka. WiFi RTT (Round Trip-Time). That looks promising so I...[Only registered and activated users can see links. Click Here To Register...]
LicheePi has already made some interested little development board in the past with products such as LicheePi Zero, and the recently-announced SD card sized LicheePi Nano board, but their latest...[Only registered and activated users can see links. Click Here To Register...]
This is a follow-up post from an earlier guest post by Blu about OpenGL ES development on Chrome OS. One can’t practice real-time rendering to disk files for long ? it’s just unnatural. So...[Only registered and activated users can see links. Click Here To Register...]
Arm announced Cortex A76 CPU core and Mali-G76 GPU in June of this year, and in the past, we normally had to wait about a year between the announcement and the actual launch of SoC with the new IP...[Only registered and activated users can see links. Click Here To Register...]
Make Your Phone Readable under the Sun with Anti-glare Covers, Sunshad
So I rented a bicycle to have a small cycling trip, and since I like to take smaller roads, and did not know the way, decided to use my phone as GPS. This works normally well while walking, but I... [Only registered and activated users can see links. Click Here To Register...]
Khadas is Working on more RK3399 / RK3399Pro Boards, Projector Development Kit, AR Kit
Shenzhen Wesion had already unveiled their Khadas Edge board that works both as a system-on-module and a standalone SBC thanks to an MXM3 connector on one side, and traditional HDMI and USB ports on... [Only registered and activated users can see links. Click Here To Register...]
How to Make a Low Cost DIY SD Card Duplicator
If you have to duplicate many SD cards for example to boot Raspbian on multiple Raspberry Pi board, one option is buy one of those SD card duplicators, but the problem is that they are not really... [Only registered and activated users can see links. Click Here To Register...]
MUSTOOL MT8206 looks like a standard digital multimeter, but the device is actually a 2-in-1 device that also serves as a oscilloscope. Banggood have the digital multimeter scope on sale now for... [Only registered and activated users can see links. Click Here To Register...]
We have smartphones, we have smartwatches. and we have… Nubia-? that is something in between, and which the company (Nubia) promotes as a “wearable smartphone”. The device comes... [Only registered and activated users can see links. Click Here To Register...]
From time to time I come across good deals for 3D printers, and a recent promotion for Creality Ender 3 3D printer appears to be one of them. Creality Ender 3 has gotten some pretty good reviews... [Only registered and activated users can see links. Click Here To Register...]
When Google released the first Android P preview back in March, one interesting new feature was indoor positioning through 802.11mc WiFi aka. WiFi RTT (Round Trip-Time). That looks promising so I... [Only registered and activated users can see links. Click Here To Register...]
Howchip ExSOM-8895 Exynos 8895 Board is Designed for Android Developme
Howchip has just launched a new Samsung based Android development kit -ExSOM-8895 DVK – powered by an Exynos 8895 system-on-module with 4GB DDR4, and UFS 2.1 storage. as well as featuring a...[Only registered and activated users can see links. Click Here To Register...]
MINIX NEO J50C-4 Mini PC Review – Part 2: Windows 10 Pro
Intel Gemini Lake processors and associated have been products available for several months, and although I’ve published several Gemini Lake reviews, those were courtesy of Linuxium, which...[Only registered and activated users can see links. Click Here To Register...]
MINIX NEO W2 PC Remote Control Review in Windows 10 and Ubuntu 18.04
MINIX NEO W2 is sold as a Windows 10 remote control with one side acting as an actual remote with shortcuts to useful Windows functions and programs, another side as a keyboard, as well as a motion...[Only registered and activated users can see links. Click Here To Register...]
Sunvell H3 Allwinner H3 TV Box with 2GB RAM Sells for $27.99 (Promo)
There aren’t that many Allwinner H3 TV boxes with some models coming to mind being Zidoo X1 or Beelink X2, but of which appear to be phased out. If you are just looking for Android boxes,...[Only registered and activated users can see links. Click Here To Register...]
Snapdragon Wear 3100 Smartwatch Platform to Deliver Longer Battery Life
Qualcomm introduced Snapdragon Wear 2100 in 2016 for wearables, and the processor ended up in several products such as LG Watch Style / Sport smartwatch. Since then the company released other Wear...[Only registered and activated users can see links. Click Here To Register...]
Shenzhen Wesion had already unveiled their Khadas Edge board that works both as a system-on-module and a standalone SBC thanks to an MXM3 connector on one side, and traditional HDMI and USB ports on...[Only registered and activated users can see links. Click Here To Register...]
If you have to duplicate many SD cards for example to boot Raspbian on multiple Raspberry Pi board, one option is buy one of those SD card duplicators, but the problem is that they are not really...[Only registered and activated users can see links. Click Here To Register...]
