(PR) MSI Releases Socket AM5 Motherboard BIOS Updates to Support Upcom
MSI announcing today a new lineup of AMD Ryzen 7000 Series processors that will be compatible with all MSI's X670 and B650 motherboards. The new AMD Ryzen CPU will include the AMD Ryzen 9 7900, Ryzen 7 7700, and the Ryzen 5 7600 which will have a default TDP of 65 W. Even with a lower TDP, these CPUs will up to 12 cores and 24 threads as their respective CPUs and be able to hit their theoretical max boost clock of over 5 GHz. All X670 and B650 motherboards from MSI will be compatible and ready at launch with the newest BIOS version "AGESA COMBO PI-1.0.0.4" update.<br />
<br />
MSI has 3 unique features to help users to overclock their systems which are called Performance Switch, PBO Thermal Point, and Config TDP with the new launch of AMD Ryzen 7000 Series processors. Earlier this year, MSI introduced a brand-new function called Performance Switch within the MSI BIOS. Performance Switch provides 3 levels of preset and an advanced option for users to choose from. Then combines both AMD's default PBO "Precision Boost Overdrive" and MSI's OC settings to provide a much higher CPU performance in both single-core and multi-core.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/GnFtqvU9TP6f2A3O.jpg" target="_blank" data-width="960" data-height="410" ><img src="https://tpucdn.com/img/GnFtqvU9TP6f2A3O_thm.jpg" width="304" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303087/msi-releases-socket-am5-motherboard-bios-updates-to-support-upcoming-processors">Read full story</a></div>
AMD Confirms Ryzen 9 7950X3D and 7900X3D Feature 3DV Cache on Only One of the Two Chiplets
AMD today announced its new Ryzen 7000X3D high-end desktop processors to much fanfare, with availability slated for February 2023, you can read all about them in our <a href="https://www.techpowerup.com/303008/amd-ryzen-7000x3d-announced-claims-total-dominance-over-intel-raptor-lake-upcoming-i9-13900ks-deterred" target="_blank">older article</a>. In our coverage, we noticed something odd about the cache sizes of the 12-core 7900X3D and 16-core 7950X3D. Whereas the 8-core, single-CCD 7800X3D comes with 104 MB of total cache (L2+L3), which works out to 1 MB L2 cache per core and 96 MB of L3 cache (32 MB on-die + 64 MB stacked 3DV cache); the dual-CCD 7900X3D and 7950X3D was shown with total caches of 140 MB and 144 MB, while they should have been 204 MB or 208 MB, respectively. <br />
<br />
In our older article, we explored two possibilities—one that the 3DV cache is available on both CCDs but halved in size for whatever reason; and the second more outlandish possibility that only one of the two CCDs has stacked 3DV cache, while the other is a normal planar CCD with just the on-die 32 MB L3 cache. As it turns out, the latter theory is right! AMD put out high-resolution renders of the dual-CCD 7000X3D processors, where only one of the two CCDs is shown having the L3D (L3 cache die) stacked on top. Even real-world pictures of the older "Zen 3" 3DV cache CCDs from the 5800X3D or EPYC "Milan-X" processors show CCDs with 3DV caches having a distinct appearance with dividing lines between the L3D and the structural substrates over the regions of the CCD that have the CPU cores. In these renders, we see these lines drawn on only one of the two CCDs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YkztXJm1evhgHeS5.jpg" target="_blank" data-width="1406" data-height="1000" ><img src="https://tpucdn.com/img/YkztXJm1evhgHeS5_thm.jpg" width="183" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hgg4JGi5t4fpksdF.jpg" target="_blank" data-width="1133" data-height="1000" ><img src="https://tpucdn.com/img/hgg4JGi5t4fpksdF_thm.jpg" width="147" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dtd5xSnmnm7JpNeP.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/dtd5xSnmnm7JpNeP_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/auh6QzfnmzS2UINO.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/auh6QzfnmzS2UINO_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303084/amd-confirms-ryzen-9-7950x3d-and-7900x3d-feature-3dv-cache-on-only-one-of-the-two-chiplets">Read full story</a></div>
GIGABYTE Motherboards and Graphics Cards at the 2023 International CES
GIGABYTE displayed their latest motherboards and graphics cards at the 2023 International CES, covering their Socket LGA1700 Intel 700-series chipset; and Socket AM5 AMD 600-series chipset. The Z790 AORUS Tachyon is the company's top-grade LGA1700 motherboard targeting the professional overclocking crowd. The board is designed to chase down CPU and memory overclocking world records, featuring the company's most powerful CPU VRM solution, and a 1 DIMM-per-channel DDR5 memory setup that preferred by overclockers for supporting the highest memory overclocks with the tightest timings. There are several overclocker-friendly features besides the onboard buttons—dual-BIOS ROMs, angled connectors for bench cases, consolidated voltage measurement points, and a feature-packed BIOS setup program.<br />
<br />
Over in the AMD side, GIGABYTE's top Socket AM5 motherboard is the X670E AORUS Xtreme, which is a feature-packed motherboard with possibly the strongest CPU VRM solutions in the market for Ryzen 7000 processors, and with the best VRM cooling. In addition to the PCIe Gen 5 M.2 slot wired to the AM5 SoC, you get additional Gen 5 slots that subtract from the x16 PEG slot. The AORUS Xtreme also has the most feature-rich BIOS available among GIGABYTE's AM5 lineup. The B650I AORUS Ultra is a premium Mini-ITX Socket AM5 motherboard based on the AMD B650 chipset. Despite its compact size, it gives you a PCI-Express 4.0 x16 PEG slot, a Gen 5 M.2 slot, and two additional Gen 4 M.2 slots, besides the latest wired- and wireless connectivity. We also snapped the B650 AERO G motherboard targeting creators, and the mainstream B650 AORUS Elite AX.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/HCT2ewGdF1DqiTe7.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/HCT2ewGdF1DqiTe7_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BiduCjz5sQqqS40m.jpg" target="_blank" data-width="1220" data-height="924" ><img src="https://tpucdn.com/img/BiduCjz5sQqqS40m_thm.jpg" width="172" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JMJxdJ5cqxSQm5TW.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/JMJxdJ5cqxSQm5TW_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dTv8FomHSbaa3xu6.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/dTv8FomHSbaa3xu6_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nC6XIPb2SZ8vYdmk.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/nC6XIPb2SZ8vYdmk_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303232/gigabyte-motherboards-and-graphics-cards-at-the-2023-international-ces">Read full story</a></div>
GIGABYTE Stealth 500 PC Continues to Grab Eyeballs at CES
A showstopper from Computex 2022, the <a href="https://www.techpowerup.com/295070/gigabytes-project-stealth-computer-assembly-kit-leads-to-sleek-system-builds" target="_blank">Stealth 500 DIY gaming PC</a> kit from GIGABYTE continues to grab eyeballs at the 2023 International CES, where it's been awarded for innovation. Imagine you've assembled a gaming PC but forgot to install a single power cable from your modular PSU—that's what the Stealth 500 looks like. You won't find a single cable sticking out when you view the motherboard from the left side panel. Every connector and header of the motherboard has been discretely wired out either using 180° inflexible backplanes, or the motherboard itself has some of its headers located on the reverse side of the PCB. Even the RTX 3070 graphics card included with the build has a discretely located power connector that remains out of sight when installed. The challenge with this build will be to give it a highly capable air CPU cooler, as even cooling tubing from an AIO could spoil the look!<div class="imgcontainer"><a href="https://www.techpowerup.com/img/pk8kpEtyFReRMRPh.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/pk8kpEtyFReRMRPh_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/c6VItlE3JMSFCG8A.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/c6VItlE3JMSFCG8A_thm.jpg" width="173" height="130" alt="" /></a></div>
In Win Shows Off P-II Line of ATX 3.0 Power Supplies
In Win showed off the P-II line of power supplies offering ATX 3.0 + PCIe Gen 5 specs support, and 80 Plus Gold efficiency. The lineup includes four models based on Wattage—the P75II (750 W), P85II (850 W), P105II (1050 W), and the P130II (1300 W). The top-of-the-line 1300 W model comes with two 16-pin ATX 12VHPWR connectors that can deliver 600 W continuous power and excursion-tolerance within PCIe Gen 5 spec, whereas the other three models include one of these connectors. The 1050 W and 1300 W models also include six 6+2 pin PCIe power, whereas the lower models include four of these. Under the hood, these feature single +12 V rail design, and most common electrical protections. In Win didn't reveal pricing, but is backing these PSUs with a 5-year warranty.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Odq5B5ORlXEnMRj1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Odq5B5ORlXEnMRj1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/InSpNgsWeg45noL1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/InSpNgsWeg45noL1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/p7PXcTI7magOGzjD.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/p7PXcTI7magOGzjD_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hcicaAXLlXQ98GPL.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hcicaAXLlXQ98GPL_thm.jpg" width="173" height="130" alt="" /></a></div>
In Win Mod Free Takes Case Modularity to the Nth Level
Over the past decade, PC cases have grown increasingly compartmentalized, but rarely modular. A case could be partitioned horizontally, or vertically to accommodate the various purpose-built chambers, but why should you stick to a particular pre-set arrangement of the compartments? In Win has an answer to this question with Mod Free. This case can either be a tall full-tower, or a horizontal stack of compartments, depending on how you want it. You can reconfigure the case as many times are you like, to grow with your hardware upgrades. The detachable modules can even hold secondary ITX-based machines, entire DIY liquid-cooling setups, large arrays of storage devices, or dedicated to graphics cards. Reconfigure and reshape the case as you like.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/EBB7LEDFm7X5vcDs.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/EBB7LEDFm7X5vcDs_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CECaXHOLPU8OmK1i.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/CECaXHOLPU8OmK1i_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QynbLAa1BcBhVFa3.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/QynbLAa1BcBhVFa3_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tIkQvKO9yk1dDYv2.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/tIkQvKO9yk1dDYv2_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/YZYvz9bW2NyJ7ihV.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/YZYvz9bW2NyJ7ihV_thm.jpg" width="98" height="130" alt="" /></a> </div>A video presentation by In Win follows.<div class="readmore"><a href="https://www.techpowerup.com/303226/in-win-mod-free-takes-case-modularity-to-the-nth-level">Read full story</a></div>
In Win Envisions an Ikea-like Future for PC Cases for Sustainable Ship
In Win is always a stand-out attraction at PC trade-shows, and at the 2023 International CES, they presented a vision for what PC cases could ship like in the near-future. PC cases, particularly $20-50 ones, are incredibly uneconomical to ship, as they take up vast amount of spatial volume for the market-price. The new In Win POC isn't exactly an entry-level case, but adds a heavy DIY element to it, similar to what you'd find with Ikea furniture. <br />
<br />
The In Win POC case comes in completely knocked down kits, with nealy all its metal panels flattened. There are cutouts on the panel, along which you manually bend and fold the sheet-metal to construct 3D shapes, as shown in online instructional videos made by In Win. A few bends and tightening of joints later, your case is ready for the hardware to be installed. The knocked-down case comes in an incredibly compact box that's a fraction of the volume of what would've been for a factory-assembled case, and needs much less protective Styrofoam. The concept carries on to the Dubili, a rather upmarket-looking ATX mid-tower which, although doesn't come with "fold here" sheet-metal, remains in a completely knocked-down state out of the box, with mostly flat bits that you join using a series of thumb-screw joints to give the case its 3-dimensional form.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XbT2rU4J8g82XsVa.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XbT2rU4J8g82XsVa_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gBMiTaCtlmFlzBbw.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/gBMiTaCtlmFlzBbw_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JUYRIzVhoxEm2kFN.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/JUYRIzVhoxEm2kFN_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pGbIVfmizQgJlSXB.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/pGbIVfmizQgJlSXB_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vixUQ7HAKlhzuIXm.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/vixUQ7HAKlhzuIXm_thm.jpg" width="173" height="130" alt="" /></a> </div>A video presentation by In Win follows.<div class="readmore"><a href="https://www.techpowerup.com/303224/in-win-envisions-an-ikea-like-future-for-pc-cases-for-sustainable-shipping-with-poc-and-dubili">Read full story</a></div>
Twinkly Shows How Little Tiles of 64 ARGB Squares Can Make for Some Jaw-Dropping Wall Lighting
Most PC peripheral companies betting big on addressable RGB lighting have shown off some room lighting products, but one of them that stand out for us is a lesser-known brand called Twinkly. Their device is a tiny 15 cm x 15 cm tile that has 64 squares, each with an addressable RGB LED. You daisy-chain several of these tiles as shown in the example below, and create some amazing wall-art that you can show off as a backdrop in your game stream. These tiles are controlled by a PC software that lets you program them whichever way you want them—cycle presets, work as ambient lighting, or even mirror your main display.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NMmtTenPlwUWFFj1.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/NMmtTenPlwUWFFj1_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ohikzyEU5HFqKyUC.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/ohikzyEU5HFqKyUC_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5j8XoaUPzl4SYiVH.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/5j8XoaUPzl4SYiVH_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5qNTl9tnnFvCnGow.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/5qNTl9tnnFvCnGow_thm.jpg" width="98" height="130" alt="" /></a></div>
Toshiba Unveils Canvio Gaming Portable Hard Drives, Canvio Advance, and N300 Pro NAS HDDs
Toshiba may have spun off its flash memory business into Kioxia, but the company still makes mechanical hard-drives and derivative products such as portable HDDs. At the 2023 International CES, the company showed off its Canvio Gaming line of portable HDDs. These USB 3.1 portable hard drives come in capacities of up to 4 TB, and support both Xbox and PlayStation consoles, where they can be used to store entire libraries of games that can be made ready to play faster than fetching the game from the Internet.<br />
<br />
The Canvio Advance series targets professionals on the move providing storage of up to 4 TB, with auto-backup both to itself and the cloud (though your PC), and data-encryption. The Canvio Ready and Canvio Flex target consumer use-cases. The latter in particular has a broad device compatibility spanning PCs, Macs, tablets, and handhelds, with USB-C and type-A interfaces. Lastly there's the N300 line of enterprise hard drives targeting NAS applications, which come in capacities of up to 18 TB, with up to 7,200 RPM spindle speed, and CMR recording (no SMR). These drives are designed for 24x7 operation, come with up to 1.2 million hours MTTF at 300 TB/year workload, and are backed by 5-year warranties.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/X0RmTbHFaFDOMVAC.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/X0RmTbHFaFDOMVAC_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XcWWHhArQrcfE5MY.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/XcWWHhArQrcfE5MY_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qFy3cKQd0eAFdbMy.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/qFy3cKQd0eAFdbMy_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KqfYH7tbgpNlk954.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/KqfYH7tbgpNlk954_thm.jpg" width="173" height="130" alt="" /></a></div>
Battery Generators at CES: AllPowers, Jackery, and Ecoflow
Smart battery generators were a recurring theme this CES. These are devices with large batteries—usually lithium ion—connected to an integrated sine-wave AC inverter, and other goodies such as direct low-voltage DC charging points for all your devices. These come in pretty handy as a replacement for small gas-powered gensets you take along for camping, as the battery drains much slower than the genset burns fuel at its lowest-load state; and many of these batteries include a means to recharge with solar power, using portable, foldable PV panels.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hIGy2xUOWid1RkSM.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hIGy2xUOWid1RkSM_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/f9MW4OWuOjPLevhr.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/f9MW4OWuOjPLevhr_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kDxjj171tD1fbWXk.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/kDxjj171tD1fbWXk_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/otLOQXfKRMTQ83vh.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/otLOQXfKRMTQ83vh_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/t2IOxkvIn4WwuJqM.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/t2IOxkvIn4WwuJqM_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303218/battery-generators-at-ces-allpowers-jackery-and-ecoflow">Read full story</a></div>
Lexar Renews Enthusiast Interest in DDR4 with Latest ARES Memory, Also
Lexar extended its latest-generation ARES RGB memory enthusiast product design to the DDR4 segment, with its ARES RGB DDR4 memory series. Available in 16 GB (2x 8 GB) dual-channel kits, these modules come with an Intel XMP 2.0 profile for DDR4-4000, and come with software-controllable RGB LED illumination. Over in the DDR5 camp, we see Lexar show off its DDR5-6000 memory module that's been validated on the AMD Ryzen 7000 "Zen 4" platform, with an AMD EXPO profile that enables the advertised speeds, timings, and AMD-specific sub-timings. On Intel machines, the included XMP 3.0 profile enables the relevant timings and sub-timings besides the DDR5-6000 speed. There's a non-RGB version of the ARES DDR5 series at lower speed variants, at DDR5-5200 (JEDEC-standard SPD).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/98GjV7rUKr9eCVkl.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/98GjV7rUKr9eCVkl_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CMqAvI2Lgrct7IJN.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/CMqAvI2Lgrct7IJN_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/prvadT5slEa1IoLv.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/prvadT5slEa1IoLv_thm.jpg" width="173" height="130" alt="" /></a></div>
Lexar Fly microSDXC Cards for Camera Drones and 1900 MB/s CFexpress Cards Pictured
Lexar at the 2023 International CES showed off the Fly series of microSDXC cards optimized for small camera drone applications. These cards come with a wider temperature-range, are optimized for low power, and meet SD V30 class (at least 30 MB/s of stable write speeds), making them capable of 4K UHD @ 30 Hz video recording. The Play series of microSDXC cards are optimized for high read performance, and targets handheld game consoles, offering up to 150 MB/s reads, and capacities of up to 1 TB. The cards come in sizes of 64 GB, 128 GB, and 256 GB. Elsewhere in the Lexar booth, we come across their fastest CFexpress cards for DLSRs and high-performance video cameras.<br />
<br />
The new Lexar Professional series CFexpress type-A cards come in capacities of up to 320 GB, with transfer rates of up to 900 MB/s and 400 MB/s guaranteed write-speeds. The larger CFexpress type-B cards can be as large as 2 TB in size, with transfer-speeds of up to 1900 MB/s and 400 MB/s guaranteed writes (the 400 MB/s figure is an arbitrary industry standard to ensure a particular format of video recording doesn't run into media-write errors). The more premium Lexar Professional Gold series are being targeted at 8K RAW video recording rigs (the latest crop of ARRI and Red cameras), supporting XQD, 1900 MB/s max reads, and 1500 MB/s max writes. Both the type-A and type-B formats come in capacities of up to 2 TB.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3bMeFJrhE5ehjKWy.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/3bMeFJrhE5ehjKWy_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bCQE3hkxXE2hIRA2.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/bCQE3hkxXE2hIRA2_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3V3tCRqX7wpkqWao.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/3V3tCRqX7wpkqWao_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ceH7M6topWXnkceO.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/ceH7M6topWXnkceO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sM4hpmCEgXWBxHiY.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/sM4hpmCEgXWBxHiY_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303214/lexar-fly-microsdxc-cards-for-camera-drones-and-1900-mb-s-cfexpress-cards-pictured">Read full story</a></div>
BenQ Showcases OLED and Fast-IPS Gaming Monitors at CES
PC display and projection major BenQ showed off three of its latest Mobiuz gaming monitors at the 2023 International CES. The star-attraction was the Mobiuz EX480UZ, a large-format 48-inch gaming display with an OLED panel. This display provides 4K Ultra HD (3840 x 2160 pixels) resolution with blistering fast 0.1 ms (GTG) response-time, and covers 98% of DCI-P3 with delta ≤2. It uses HDMI 2.1 inputs, and includes a powerful internal speaker-set consisting of two 5 W front-channels, and 10 W woofer. The monitor supports AMD FreeSync Pro.<br />
<br />
The Mobiuz EX270QM is a 27-inch WQHD (2560 x 1440 pixels) monitor with a Fast-IPS panel that offers 240 Hz refresh rate, with 1 ms (GTG) response time, and 98% of DCI-P3 coverage, along with DisplayHDR 600 support. It uses a full-bandwidth HDMI 2.1 input and supports AMD FreeSync Pro. Lastly, there's the Mobiuz EX270M, which is the same 27-inch size, but with lower Full HD (1920 x 1080) resolution, the same 240 Hz refresh-rate and 1 ms response time, but with 99% sRGB coverage and AMD FreeSync Premium Pro support. This monitor packs a 2.1 speaker setup with 2.5 W front-channel speakers, and a 5 W subwoofer.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/MNGVXb2851hMyG2y.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/MNGVXb2851hMyG2y_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rqXragI8a9KQEH0e.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/rqXragI8a9KQEH0e_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yZ20dn6K5ZocefsX.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/yZ20dn6K5ZocefsX_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yVGohYD9JHTC49DZ.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/yVGohYD9JHTC49DZ_thm.jpg" width="173" height="130" alt="" /></a></div>
Kingston Exhibits its 5 Top Secure Storage Devices at CES
Kingston dominates the secure portable storage market with its IronKey brand of self-encrypting USB flash drives and portable SSDs. At the 2023 International CES, the company showed off its five top products from the IronKey brand. These include the IronKey Locker+ 50, the IronKey S1000, the IronKey Vault Privacy 50, the IronKey Keypad 200, and the IronKey Vault Privacy 80ES. The Locker+ 50 is an affordable secure encrypted flash drive with self-processing XTS-AES encryption and automatic cloud backup. It comes in capacities of up to 128 GB, and offers transfer rates of up to 145 MB/s reads with up to 115 MB/s writes, over 5 Gbps USB 3.1. The IronKey S1000 is a big step-up from the Locker+ 50, and features an on-device cryptochip for a self-contained root of trust, besides hardware-accelerated encryption without involving the host machine. It comes in capacities of up to 128 GB, and offers transfer rates of up to 230 MB/s reads, with up to 240 MB/s writes, leveraging 5 Gbps USB 3.1.<br />
<br />
The Vault Privacy 50 series is usually what enterprises buy in bulk, with hardware-accelerated XTS-AES, and 256-bit AES. It can be had with USB type-A or type-C (Vault Privacy 50C), and comes in capacities of up to 128 GB, pushing data at up to 250 MB/s reads, with up to 180 MB/s writes. The Keypad 200 is one of the most recognizable of Kingston's IronKey products. It meets FIPS 140-3 Level 3 data-security standards, and a physical keypad that unlocks the device without having to use any software running on the host. It transfers at speeds of up to 145 MB/s reads with up to 115 MB/s writes. Lastly, there's the Vault Privacy 80ES, a 5 Gbps USB 3.2 Gen 1 portable SSD that comes in capacities of up to 2 TB, a touchscreen-based on-device user-interface to lock/unlock without any software running on the host machine, and transfer rates of up to 250 MB/s.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/y4ufSaAzTmknZFn2.jpg" target="_blank" data-width="1220" data-height="920" ><img src="https://tpucdn.com/img/y4ufSaAzTmknZFn2_thm.jpg" width="172" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ezjqtXf8KojZSa77.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/ezjqtXf8KojZSa77_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AXWnOoIKBPuXYGmZ.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/AXWnOoIKBPuXYGmZ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ak8yPjWVe5bOxMYW.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/ak8yPjWVe5bOxMYW_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/GqMekY3ivNDIVBHJ.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/GqMekY3ivNDIVBHJ_thm.jpg" width="173" height="130" alt="" /></a></div>
Kingston FURY Renegade DDR5-7200, FURY Beast DDR5-6000, and FURY Impac
At the 2023 International CES, market leader Kingston expanded their FURY line of enthusiast-gaming PC memory with the introduction of several new DDR5 memory kits. The top-of-the-line FURY Renegade series comes in RGB and non-RGB trims, and with speeds of up to DDR5-7200 with Intel XMP 3.0 support. For the AMD crowd, the company showed off the FURY Beast RGB, which comes in speeds of up to DDR5-6000, and features AMD EXPO profiles along with extensive validation with Ryzen 7000 series processors. <br />
<br />
For those still making the transition between DDR4 and DDR5, Kingston introduced the FURY Beast DDR4 RGB, which looks visually similar to their DDR5 FURY Beast, but comes with speeds of up to DDR4-3600, with validation on AMD Ryzen 5000 series processors. It also supports an Intel XMP 2.0 profile. For high-end gaming notebooks and SFF platforms, including the Intel NUC 12 Extreme, Kingston introduced the FURY Impact line of DDR5 SO-DIMM memory, which comes in speeds of up to DDR5-5600.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3ZrACXTe7rZrUqbi.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/3ZrACXTe7rZrUqbi_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/YsEy0soodFyDZpyr.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/YsEy0soodFyDZpyr_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/g1RMyUpEnmY9waoB.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/g1RMyUpEnmY9waoB_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BtXU5UxK1mYj353K.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/BtXU5UxK1mYj353K_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BOORogFSzbFuo9Ad.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/BOORogFSzbFuo9Ad_thm.jpg" width="173" height="130" alt="" /></a></div>
HyperX HX3D Hardware Customization Program is Basically Hummels for Game Streamers
For the latest crop of game streamers, the set is as important as the gear and the gameplay itself, and so HyperX launched HX3D Hardware Customization Program. This is basically a new range of 3D-printed accessories for your HyperX gaming peripherals, which can liven up your streaming set to suit your personality/style. HyperX showed off several examples, such as a pretty slick Giger-inspired rib-cage enclosure for a Quadcast mic that doubles up as a Cloud headset stand; a giant mushroom holding a nest with a Quadcast sticking out, a bunny figurine headset stand, and countless new custom keycaps—basically Hummels for streamers.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oE5Zp9F4XiSy7Ldd.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/oE5Zp9F4XiSy7Ldd_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BUvuwgTo3QFYzjOV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/BUvuwgTo3QFYzjOV_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eKyqVYOGwfMlGkc0.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/eKyqVYOGwfMlGkc0_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1gZNG6naPCYSLqPF.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/1gZNG6naPCYSLqPF_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4quhKpfiqgOG9CX2.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4quhKpfiqgOG9CX2_thm.jpg" width="173" height="130" alt="" /></a></div>
HyperX Clutch Gladiate and Pulsefire Haste 2 Thumbs-on
At the 2023 International CES, HyperX launched its most powerful wired Xbox controller, the HyperX Clutch Gladiate. An official Xbox-licensed third-party controller, the Clutch Gladiate comes with locks for each of the two triggers, and re-mappable rear buttons. Haptics are care of a dual-motor rumble rigging, with fine-grained force feedback. The controller also comes with a 3.5 mm analog headset jack.<br />
<br />
The Pulsefire Haste 2 gaming mouse comes in wired- and wireless variants. It has a pseudo-ambidextrous shape (the side buttons are only accessible for righthanders). The wired version weights 53 g, while the wireless one surprisingly isn't much heavier, at just 62 g, yet with up to 100 hours of battery life on a single charge. These mice use in-house HyperX Switches rated for 100 million clicks; and HyperX 26K (26,000 dpi) sensor. Its electronics provide a staggering 8000 Hz polling rate. The mouse comes with PTFE skates that strike a balance between both speed and precision. The Clutch Gladiate is priced at $35, the wired Pulsefire Haste 2 at $60, and the wireless Pulsefire Haste 2 at $80.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/L1fICWXTBdjMNZrL.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/L1fICWXTBdjMNZrL_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hrHygUg1sFjnstH1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hrHygUg1sFjnstH1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ANaSeKRBIpoaUXzg.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/ANaSeKRBIpoaUXzg_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Sl99JPLzjCvdGFNC.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Sl99JPLzjCvdGFNC_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4LCgDT53lUlHqCBP.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4LCgDT53lUlHqCBP_thm.jpg" width="173" height="130" alt="" /></a></div>
HyperX Armada Gaming Monitor Pictured
HyperX, the former gaming peripherals brand of Kingston, was acquired by PC OEM giant HP in 2021. It was only natural for HP to use the HyperX brand to ship gaming monitors at some point, as the company has a vast lineup of not just PC and professional displays, but also some gaming displays under its HP OMEN brand. The company announced the HyperX Armada brand of gaming monitors in the 25-inch and 27-inch planar category in September 2022. We spotted it at the 2023 CES. It has prominent HyperX badging, some peel-off stickers on the front bezel detailing its key gamer-friendly features; and an NVIDIA G-SYNC logo. Key specs include WQHD (1440p) resolution, 165 Hz refresh-rate, DisplayHDR 400, and a fast IPS panel with 1 ms response time. HP will probably retain the OMEN brand for ultra-premium gaming monitors, with the HyperX Armada series in the mid-range.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dpXEnc1pjVDkBDpz.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/dpXEnc1pjVDkBDpz_thm.jpg" width="173" height="130" alt="" /></a></div>
AMD Ryzen 7000X3D Processors Have a Distinct Retail Packaging
Here's the first look at the retail PIB package of an AMD Ryzen 9 7950X3D processor with 3D Vertical Cache technology. These chips come in box design that's distinct from the rest of the Ryzen 7000 lineup. Bright orange and silver accents make up the front face of the box, with "3D Vertical Cache technology" being mentioned prominently. With the Ryzen 7 5800X3D, the PIB package design was probably found to look too similar to the rest of the lineup and practically indistinguishable from those of the 5000G "Cezanne" desktop APUs, which is probably why AMD took this route. <br />
<br />
It's very likely that we'll see Socket AM5 desktop APUs based on the "Phoenix Point" monolithic silicon later this year, with its 12 CU RDNA3 iGPU and 8-core/16-thread "Zen 4" CPU that has a 32 MB on-die L3 cache. These processors will have yet another distinguishable retail PIB packaging. AMD's then technical marketing director, Robert Hallock, assured us that the company will continue to invest in desktop APUs (processors with powerful iGPUs), despite Ryzen 7000 desktop processors coming with a low-power iGPU as standard.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/1X3kViU09VSG19F5.jpg" target="_blank" data-width="920" data-height="642" ><img src="https://tpucdn.com/img/1X3kViU09VSG19F5_thm.jpg" width="186" height="130" alt="" /></a></div>
(PR) BIOSTAR Launches the B760A-Silver Motherboard
BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today, is excited to announce the brand new B760A-SILVER motherboard. Constructed around the Intel LGA1700 Socket, which supports both 12th and 13th-generation Intel processors, the B760A-SILVER motherboard is a jack of all trades, highly suitable for gamers and content creators who look for the most advanced features with a tolerable price tag. <br />
<br />
Based on BIOSTAR's globally acclaimed RACING DNA, it offers efficient, reliable functionality typically found only on top-shelf motherboard offerings from market competitors. Signature RGB features, including the RGB ROCK ZONE, give any build a new level of depth and futuristic appeal that complements any color, style, or theme. The B760A-SILVER motherboard supports dual-channel DDR5 memory powered by advanced features like support for both AMD and Intel XMP RAM modules designed to facilitate unparalleled hardware acceleration and performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/O31GMqIJpqjq6gRo.jpg" target="_blank" data-width="1024" data-height="683" ><img src="https://tpucdn.com/img/O31GMqIJpqjq6gRo_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Qhw1DJ1BUUue7bBV.jpg" target="_blank" data-width="1024" data-height="683" ><img src="https://tpucdn.com/img/Qhw1DJ1BUUue7bBV_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iFd1nuFVRTHe12qk.jpg" target="_blank" data-width="1024" data-height="656" ><img src="https://tpucdn.com/img/iFd1nuFVRTHe12qk_thm.jpg" width="203" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303201/biostar-launches-the-b760a-silver-motherboard">Read full story</a></div>
(PR) ASUS Unveils Cutting-Edge Arsenal of Gaming and Business Routers
ASUS today announced the ROG Rapture GT-BE98, the world's first quad-band WiFi 7 gaming router, and the ASUS RT-BE96U, a tri-band WiFi 7 router for home and business, at CES 2023. Both routers feature the latest technologies exclusive to WiFi 7, including extended 320 MHz channels in the 6 GHz band, 4K QAM modulation, Multi-Link Operation and Multi-RU Puncturing.<br />
<br />
For businesses, ASUS is also unveiling three new ExpertWiFi devices: the EBM68 mesh system, EBR63 router and EBA63 access point, with more networking solutions to follow in the second half of 2023. These devices support the highest number of SSIDs in the industry, self-defined networks, up to 12 mesh nodes, and enterprise-grade network security. Each device can be easily managed using the free ASUS Router mobile app. For locations impacted by thick walls made of brick or concrete, ASUS offers the ZenWiFi Hybrid XC5, the world's first Multimedia over Coaxial (MoCA) mesh router, which provides four ways to connect to hybrid backhauls while supporting up to 2.5 Gbps connections through wired backhauls.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4tKwXYzL093l3hs8.jpg" target="_blank" data-width="1422" data-height="960" ><img src="https://tpucdn.com/img/4tKwXYzL093l3hs8_thm.jpg" width="193" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lnYGlpHMm8QJFqiT.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/lnYGlpHMm8QJFqiT_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9DqF1V6X1NHAEEVG.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/9DqF1V6X1NHAEEVG_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/f4D25T2sNLE2fnvz.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/f4D25T2sNLE2fnvz_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/o2GxLPbJykcCsaYD.jpg" target="_blank" data-width="1439" data-height="960" ><img src="https://tpucdn.com/img/o2GxLPbJykcCsaYD_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303188/asus-unveils-cutting-edge-arsenal-of-gaming-and-business-routers-at-ces-2023">Read full story</a></div>
(PR) AAEON Introduces AI Edge Solutions Powered by NVIDIA Jetson Orin SoM
Following the Consumer Electronics Show (CES), AAEON introduced a number of additions to its line of award-winning AI edge solutions, powered by the new NVIDIA Jetson Orin system-on-module platform.<br />
<br />
The first products are the BOXER-8641AI and BOXER-8640AI, which were first announced back in March, following the release of the NVIDIA Jetson AGX Orin developer kit, and are both powered by Jetson AGX Orin 32 GB modules. These are followed by the more recently planned BOXER-8646AI, which will also utilize the Jetson AGX Orin module.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/njTe3pXTU4Hz3RHe.jpg" target="_blank" data-width="1557" data-height="960" ><img src="https://tpucdn.com/img/njTe3pXTU4Hz3RHe_thm.jpg" width="211" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aycjSNwA8rfdvJhQ.jpg" target="_blank" data-width="1880" data-height="960" ><img src="https://tpucdn.com/img/aycjSNwA8rfdvJhQ_thm.jpg" width="255" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OS6AyPTX87RN3LpF.jpg" target="_blank" data-width="600" data-height="400" ><img src="https://tpucdn.com/img/OS6AyPTX87RN3LpF_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303184/aaeon-introduces-ai-edge-solutions-powered-by-nvidia-jetson-orin-som">Read full story</a></div>
Dell Announces 32-inch UltraSharp 6K Monitor With Thunderbolt 4 at CES
For those of you that find a 4K monitor to lack in resolution, but 8K being a bit too pricey, Dell announced a 6K option at CES in the shape of the 32-inch U3224KB monitor. The IPS Black panel features a 6144 x 3456 pixel resolution with 178 degree viewing angles, a contrast ratio of 2000:1 and it's also VESA DisplayHDR 600 certified. As this is a professional monitor, it offers a colour gamut that meets 99 percent of the DCI-P3 colour space, as well as 100 percent of the sRGB and Rec. 709 standards. <br />
<br />
On the connectivity side, it supports Thunderbolt 4, with one input and one throughput, which includes 140 W power delivery, the highest we've seen to date from a monitor. It also has a pair of additional pop-out front facing USB-C ports, which can deliver 15 W of power, as well as a USB-A port, all of which are able to deliver data speeds of up to 10 Gbps and four rear mounted USB-A ports. Display inputs consist of one HDMI 2.1, one mini DP 2.1, one USB-C with unknown DisplayPort standard support, as well as one of the Thunderbolt 4 ports. Finally the U3224KB also features an RJ45 jack for Ethernet connectivity.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fPbsPG8CkgVWcjPx.jpg" target="_blank" data-width="940" data-height="960" ><img src="https://tpucdn.com/img/fPbsPG8CkgVWcjPx_thm.jpg" width="127" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/27ESs36oeBYZnYJE.jpg" target="_blank" data-width="912" data-height="960" ><img src="https://tpucdn.com/img/27ESs36oeBYZnYJE_thm.jpg" width="124" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mQ0ORaadehOFV2G4.jpg" target="_blank" data-width="331" data-height="960" ><img src="https://tpucdn.com/img/mQ0ORaadehOFV2G4_thm.jpg" width="45" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/M7oyI5bIb7jomQmN.jpg" target="_blank" data-width="900" data-height="450" ><img src="https://tpucdn.com/img/M7oyI5bIb7jomQmN_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KVnJ76MUT0tc4xgf.jpg" target="_blank" data-width="1200" data-height="960" ><img src="https://tpucdn.com/img/KVnJ76MUT0tc4xgf_thm.jpg" width="163" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303329/dell-announces-32-inch-ultrasharp-6k-monitor-with-thunderbolt-4-at-ces">Read full story</a></div>
(PR) CHERRY Announcing Exciting New Keyboard and Mouse Options
Cherry Americas, part of the global leader in computer input devices, today announced the launch of two exciting new products for office and home users. The new products include the DW 9500 SLIM combo, bringing together the very popular KW 9100 wireless keyboard and the MW 8C ERGO mouse, and the addition of three new color variations to the popular GENTIX BT mouse. Both offerings are focused on delivering great value and performance while showcasing the style and sophistication users have come to expect from CHERRY.<br />
<br />
"Our focus is on delivering the innovative, stylish and easy to use products to our customers in both office and home settings while simultaneously providing unmatched value and quality," said Richard Simone, CEO of Cherry Americas.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jRlHEi3wvRDkxDOX.jpg" target="_blank" data-width="1280" data-height="585" ><img src="https://tpucdn.com/img/jRlHEi3wvRDkxDOX_thm.jpg" width="284" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mmynu5u7v8wzMssy.jpg" target="_blank" data-width="850" data-height="460" ><img src="https://tpucdn.com/img/mmynu5u7v8wzMssy_thm.jpg" width="240" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JGXyAuhKgcejEby3.jpg" target="_blank" data-width="652" data-height="352" ><img src="https://tpucdn.com/img/JGXyAuhKgcejEby3_thm.jpg" width="241" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KNVACLkQdWAEIoJD.jpg" target="_blank" data-width="1260" data-height="600" ><img src="https://tpucdn.com/img/KNVACLkQdWAEIoJD_thm.jpg" width="273" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303324/cherry-announcing-exciting-new-keyboard-and-mouse-options">Read full story</a></div>
(PR) Zyxel Launches High-Performance Multi-Gigabit Smart Managed Switches for SMBs
Zyxel Networks, a leader in delivering secure, AI- and cloud-powered business and home networking solutions, today announced the launch of the XMG1930 Series of Multi-Gigabit Lite-L3 Smart Managed Switches. XMG1930 series switches provide SMBs, system integrators, managed service providers, and small internet service providers with an ideal solution to support the increasing bandwidth requirements driven by advanced business applications.<br />
<br />
XMG1930-30 and XMG1930-30HP switches are layer 2 switches that are equipped with 24 2.5G multi-gigabit ports, delivering higher bandwidth capacity to support wireless access points, servers, and workstations. Both switches can be upgraded to Lite-L3 with the purchase of a license that also adds the capability to manage the switches via Command Line Interface (CLI). A first for SMBs, both XMG1930 models offer six 10G uplinks that support fiber or copper infrastructures, enabling service providers to upgrade customers' network speeds from 1G to 2.5G without re-cabling, and provide extensibility and resilience for network expansion.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dOhEYZ95t6ymV57t.jpg" target="_blank" data-width="928" data-height="390" ><img src="https://tpucdn.com/img/dOhEYZ95t6ymV57t_thm.jpg" width="309" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XJcigxFe6Akipq3q.jpg" target="_blank" data-width="922" data-height="410" ><img src="https://tpucdn.com/img/XJcigxFe6Akipq3q_thm.jpg" width="292" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303322/zyxel-launches-high-performance-multi-gigabit-smart-managed-switches-for-smbs">Read full story</a></div>
(PR) CES is Back and Thriving - CES by the Numbers
CES 2023 ended today after an incredible week of product launches, major company announcements and innovation that will help to solve global challenges. CES shattered expected attendance drawing over 115,000 industry professionals - marking the largest audited global tech event since early 2020. With over 3200 exhibitors, including 1000 startups, CES 2023 showcased the next era of innovation from transportation and mobility to digital health, sustainability, Web3, metaverse and beyond.<br />
<br />
For the first time, CES had a theme focused on Human Security for All. CES partnered with the United Nations Trust Fund for Human Security and the World Academy of Art and Science on the Human Security for All (HS4A) global campaign to foster food security, access to health care, personal income, environmental protection, personal safety, community security and political freedom. The products unveiled at CES 2023 tackle global issues such as access to clean water, food security, smart cities infrastructure, sustainable energy solutions, personal security and more. CES also featured the latest in accessibility tech, with innovation helping those in the disability community.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BShvt8y09wGkuchD.jpg" target="_blank" data-width="1482" data-height="991" ><img src="https://tpucdn.com/img/BShvt8y09wGkuchD_thm.jpg" width="194" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303321/ces-is-back-and-thriving-ces-by-the-numbers">Read full story</a></div>
(PR) Montage Technology PCIe 5.0/CXL 2.0 Retimer Chip Achieves Mass Production
Montage Technology, a leading data processing and interconnect IC design company, announced today that its PCIe 5.0/CXL 2.0 Retimer has successfully achieved mass production. This chip is a key upgrade based on Montage's PCIe 4.0 Retimer, providing a stable and reliable PCIe 5.0 and CXL 2.0 interconnect solution with high bandwidth and low latency for the cloud and high-performance computing market. <br />
<br />
Montage's PCIe 5.0/CXL 2.0 Retimer employs advanced signal conditioning technologies to improve signal integrity and increase the effective transmission distance of high-speed signals. Compliant with relevant PCI-SIG and CXL specifications, the chip meets mainstream package requirements, supports transfer rate up to 32 GT/s, and takes the lead in supporting ultra-low transmission latency of less than 5 ns. The chip supports various complex system topologies such as SRIS and Retimer cascading, offering an ideal solution to address the PCIe/CXL signal integrity challenges in next-generation servers, enterprise storage, and AI acceleration systems. The PCIe 5.0/CXL 2.0 Retimer has passed extensive interoperability testing with a variety of compute, storage and networking products, such as CPU, PCIe switches, SSDs, GPUs and NICs, thus laying a solid foundation for the large-scale deployment of cloud computing and data centers.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/uoKVlYwbSlWBlUbN.jpg" target="_blank" data-width="1112" data-height="680" ><img src="https://tpucdn.com/img/uoKVlYwbSlWBlUbN_thm.jpg" width="213" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303320/montage-technology-pcie-5-0-cxl-2-0-retimer-chip-achieves-mass-production">Read full story</a></div>
MSI Afterburner Developer Hasn't been Paid for a Year, Product Development in Limbo
MSI Afterburner is arguably the most popular graphics card overclocking utility that everyone from gamers to professional overclockers swear by. It is used across graphics card brands, and helps you tune up both NVIDIA and AMD GPUs. While you enjoy Afterburner with your new-generation GeForce RTX 40-series "Ada" and Radeon RX 7000 series RDNA3 GPUs that were released in 2022, do remember that Afterburner's developer hasn't been paid a penny for it.<br />
<br />
MSI Afterburner is developed by Russian national Alexey Nicolaychuk, who goes by the name Unwinder across tech forums. Following the Russian invasion of Ukraine in early-2022, MSI stopped payments to Unwinder citing "political reasons." Unwinder had been independently (read: without payment) supporting Afterburner out of personal interest throughout 2022 in hopes that MSI would figure out a way to pay him. Interestingly, MSI PC hardware continued to be sold in the Russian market throughout 2022. Despite continuing to develop Afterburner throughout 2022 without payment, MSI hasn't resolved its payments. In a community post, Unwinder announced that he is finally calling it quits, and is halting development of the app. This development ensures that the app works reliably with new GPUs as they're being launched, fixes bugs, and patches security issues.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fEND4FsHrx3iRKZf.jpg" target="_blank" data-width="1908" data-height="802" ><img src="https://tpucdn.com/img/fEND4FsHrx3iRKZf_thm.jpg" width="309" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303298/msi-afterburner-developer-hasnt-been-paid-for-a-year-product-development-in-limbo">Read full story</a></div>
(PR) Micron Technology Announces 9400 Series Enterprise NVMe SSDs
Micron Technology, today announced the Micron 9400 NVMe SSD is in volume production and immediately available from channel partners and to global OEM customers for use in servers requiring the highest levels of storage performance. The Micron 9400 is designed to manage the most demanding data center workloads, particularly in artificial intelligence (AI) training, machine learning (ML) and high-performance computing (HPC) applications. The drive delivers an industry-leading 30.72 terabytes (TB) of storage capacity, superior workload performance versus the competition, and 77% improved input/output operations per second (IOPS). The Micron 9400 is the world's fastest PCIe Gen4 data center U.3 drive shipping and delivers consistently low latency at all capacity points.<br />
<br />
"High performance, capacity and low latency are critical features for enterprises seeking to maximize their investments in AI/ML and supercomputing systems," said Alvaro Toledo, vice president and general manager of data center storage at Micron. "Thanks to its industry-leading 30 TB capacity and stunning performance with over 1 million IOPS in mixed workloads, the Micron 9400 SSD packs larger datasets into each server and accelerates machine learning training, which equips users to squeeze more out of their GPUs."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/1sJioUFKwvquaZVF.jpg" target="_blank" data-width="613" data-height="435" ><img src="https://tpucdn.com/img/1sJioUFKwvquaZVF_thm.jpg" width="183" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303315/micron-technology-announces-9400-series-enterprise-nvme-ssds">Read full story</a></div>
Mushkin Vortex Redline and Votex LX NVMe SSDs Detailed, Epsilon Gen 5 SSD Teased
Mushkin at the 2023 International CES showed off its Vortex Redline and Vortex LX M.2 NVMe SSDs. The Vortex Redline is the company's top PCIe Gen 4 drive, combining an Innogrit IG5236 NVMe 1.4 controller with 3D TLC NAND flash, to offer transfer speeds of up to 7415 MB/s. The Vortex Redline comes in capacities of 512 GB, 1 TB, and 2 TB. The Vortex LX is a more value-oriented product, based on an unnamed Innogrit-sourced DRAMless controller. This drive features a PCIe Gen 4 interface, but offers slightly lower performance that the company didn't disclose.<br />
<br />
The star attraction at the Mushkin booth was its Epsilon SSD that features a PCI-Express 5.0 x4 + NVMe 2.0 interface, a Phison E26-series controller, and next generation 3D NAND flash memory (possibly 232-layer). The drive features active cooling from a fan-heatsink, and while the company didn't talk about performance, drives based on this controller are known to offer up to 12 GB/s of sequential transfers. Lastly, the company showed off its lineup of 2.5-inch SATA 6 Gbps SSDs in capacities ranging all the way up to 16 TB, which are meant to be HDD replacements, and "warm" storage devices.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/28Msn7RCKWhAY3YZ.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/28Msn7RCKWhAY3YZ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8cEDa0lVxkdBuPVK.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/8cEDa0lVxkdBuPVK_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8dR66djGzu9e3uTX.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/8dR66djGzu9e3uTX_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XhxjCsKjwxjZ2nmT.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XhxjCsKjwxjZ2nmT_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lcIwEklIJJlkC3Hk.jpg" target="_blank" data-width="1200" data-height="1179" ><img src="https://tpucdn.com/img/lcIwEklIJJlkC3Hk_thm.jpg" width="132" height="130" alt="" /></a></div>
Battery Generators at CES: AllPowers, Jackery, Bluetti, and Ecoflow
Smart battery generators were a recurring theme this CES. These are devices with large batteries—usually lithium ion—connected to an integrated sine-wave AC inverter, and other goodies such as direct low-voltage DC charging points for all your devices. These come in pretty handy as a replacement for small gas-powered gensets you take along for camping, as the battery drains much slower than the genset burns fuel at its lowest-load state; and many of these batteries include a means to recharge with solar power, using portable, foldable PV panels.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hIGy2xUOWid1RkSM.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hIGy2xUOWid1RkSM_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/f9MW4OWuOjPLevhr.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/f9MW4OWuOjPLevhr_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kDxjj171tD1fbWXk.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/kDxjj171tD1fbWXk_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/otLOQXfKRMTQ83vh.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/otLOQXfKRMTQ83vh_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/t2IOxkvIn4WwuJqM.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/t2IOxkvIn4WwuJqM_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303218/battery-generators-at-ces-allpowers-jackery-bluetti-and-ecoflow">Read full story</a></div>
NVIDIA Could Release AI-Optimized Drivers, Improving Overall Performance
NVIDIA is using artificial intelligence to design and develop parts of its chip designs, as we have seen in the past, making optimization much more efficient. However, today we have a new rumor that NVIDIA will use AI to optimize its driver performance to reach grounds that the human workforce can not. According to CapFrameX, NVIDIA is allegedly preparing special drivers with optimizations done by AI algorithms. As the source claims, the average improvement will yield a 10% performance increase with up to 30% in best-case scenarios. Presumably, AI can do optimization on two fronts: shader compiles / game optimization side or for power management, which includes clocks, voltages, and boost frequency curves.<br />
<br />
It still needs to be made clear which aspect will company's AI optimize and work on; however, it can be a combination of two, given the expected drastic improvement in performance. Special tuning of code for more efficient execution and a better power/frequency curve will bring the efficiency level one notch above current releases. We have already seen AI solve these problems last year with the <a href="https://www.techpowerup.com/296699/nvidia-prefixrl-model-designs-25-smaller-circuits-making-gpus-more-efficient" target="_blank">PrefixML</a> model that compacted circuit design by 25%. We need to find out which cards NVIDIA plans to target, and we can only assume that the latest-generation GeForce RTX 40 series will be the goal if the project is made public in Q1 of this year.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/IpS1KT7aR011RqaG.jpg" target="_blank" data-width="1200" data-height="630" ><img src="https://tpucdn.com/img/IpS1KT7aR011RqaG_thm.jpg" width="248" height="130" alt="" /></a></div>
DeepCool Unveils PX-P and PX-G Series ATX 3.0 + PCIe Gen 5 PSUs at CES
At CES, DeepCool unveiled its latest PX-P and PX-G line of new-generation power supplies meeting the ATX 3.0 and PCI-Express Gen 5 specifications. The PX-P series offers 80 Plus Platinum switching efficiency and comes in two high-wattage variants of 1000 W and 1300 W. The PX-G, on the other hand, gives you 80 Plus Gold switching efficiency, and comes in 850 W, 1000 W, and 1200 W variants. What's common to both is that they offer one 16-pin ATX 12VHPWR connector that's capable of 600 W continuous power delivery, along with 200% excursions within the PCIe Gen 5 specs. The PX-P series PSUs offer five PCIe power connectors on the PSU's end besides the 12VHPWR, while the PX-G offers three. Each of these split out to two 6+2 pin connector's on the cable's end. The PX-P series uses a 120 mm fluid-dynamic bearing fan, while the PX-G uses 135 mm FDB fan.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UBbdDA0aMtHkfUc9.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/UBbdDA0aMtHkfUc9_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HIh94xIZolWWWAmT.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/HIh94xIZolWWWAmT_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vsewdyAi88neuCBb.jpg" target="_blank" data-width="1594" data-height="1200" ><img src="https://tpucdn.com/img/vsewdyAi88neuCBb_thm.jpg" width="173" height="130" alt="" /></a></div>
DeepCool AIO CLCs at CES and Unique FT14 Case Fan
DeepCool brought a pair of new all-in-one liquid CPU coolers to the 2023 International CES. These include the LT series, the LS520 series, and the new FT14 case fan. The LT series is characterized by the unique geometric shape of its pump-block, which looks like a metal cube has been peeled to reveal a more solid geometric shapes inside, thanks to an illusion created by an infinity-mirror setup. DeepCool already launched debuted the LT series in October 2022, but at CES it introduced new all-white variants.<br />
<br />
The LS520 series "smart" AIOs feature pump-blocks with LCD displays that provide real-time monitoring of the pump-speed, base-plate- and coolant temperature. These are otherwise identical to the LS series from mid-2022. Also making its debut is the FT14, a unique 140 mm case fan with a square fan-frame, which can be made to fit 120 mm fan vents, by pulling out the four corners of the frame, to reveal an inner frame with 120 mm mounts. This could prove useful where you have a 120 mm fan vent that has room for a larger impeller.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XaWvfLG8BblkQKcM.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XaWvfLG8BblkQKcM_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nsCxmZQuLMngOn6V.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/nsCxmZQuLMngOn6V_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iofNIRfSvrAFFr3a.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/iofNIRfSvrAFFr3a_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LVBapdMreUekIRIT.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/LVBapdMreUekIRIT_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2I6EwsoEEQH37hVv.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/2I6EwsoEEQH37hVv_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) QoQ Decline in DRAM ASP Will Moderate to Around 13~18% for 1Q23, but Slump Will Continue, Says TrendForce
TrendForce's latest analysis of the DRAM market finds that the inventory pressure on suppliers remain significant due to the persistently weak demand for consumer electronics. Among the top three DRAM suppliers, only Samsung has seen a slight drop in inventory level thanks to its highly competitive pricing strategy. To prevent DRAM prices as a whole from making another sharp dive, a few suppliers such as Micron have been cutting production. Therefore, the QoQ decline in DRAM prices are projected to shrink to around 13~18% for 1Q23. However, the slump will have yet to reach the bottom at that time. Regarding the QoQ changes in the prices of the major categories of DRAM products for 1Q23, PC DRAM and server DRAM are projected to again register a drop that is near 20%. Conversely, mobile DRAM will experience the smallest price decline because its profit margin is ready the thinnest.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BjLmxcRmgY6aWNud.jpg" target="_blank" data-width="546" data-height="440" ><img src="https://tpucdn.com/img/BjLmxcRmgY6aWNud_thm.jpg" width="161" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303296/qoq-decline-in-dram-asp-will-moderate-to-around-13-18-for-1q23-but-slump-will-continue-says-trendforce">Read full story</a></div>
DeepCool Gives Air CPU Coolers the Smarts with the Digital Series
With the latest crop of AIO liquid coolers getting some smarts such as displays on the pump-block that put out real-time monitoring information, DeepCool figured why not extend this to air coolers? The new Digital series air CPU coolers by DeepCool come with LCD displays that put out real-time monitoring information such as CPU temperature (as measured at the base-plate), and fan speed. <br />
<br />
These are essentially upgrades to the company's aluminium fin tower-type CPU coolers with top-plates that have the display and some electronics, instead of what should normally be a die-cast aluminium plate with some optional lighting. Shown at CES were at least four models with a single fin-stack (type-U) design of various sizes, and one dual fin-stack (type-D) design. All of these have a glossy piano-black acrylic top-plate that's framed by an ARGB diffuser. The LCD segment display is somewhere toward the center. The electronics work independently, but you'll need a 4-pin PWM connection for the fan(s), which also power the electronics; and 3-pin ARGB for the lighting.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/rPkjyEonQM2v4RYz.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/rPkjyEonQM2v4RYz_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hKq29GvOcYv91Fp7.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hKq29GvOcYv91Fp7_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SziawmuWo4rpPS25.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/SziawmuWo4rpPS25_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/w0nCk1VctKP1jA8t.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/w0nCk1VctKP1jA8t_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SBWKu1oOrvn4tnpL.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/SBWKu1oOrvn4tnpL_thm.jpg" width="173" height="130" alt="" /></a></div>
DeepCool Assassin IV is the "Air Apparent" to the Company's CPU Cooler
DeepCool brought a wealth of new PC cooling and casing solutions to the 2023 International CES, and one of the new stuff that caught our eye is their new Assassin IV CPU cooler. When installed, this looks like big dark cube inside your case, with a shroud covering all its sheet-metal. A large aluminium fin-stack heatsink is concealed inside the shroud, to which heat is fed by seven 6 mm-thick heatpipes. A combination of 140 mm and 120 mm fluid-dynamic bearing fans ventilate the heatsink. The cooler is capable of handling thermal loads of up to 280 W, and can match up to 240 mm AIO coolers, so you can even run the top Zen 4 or Rocket Lake processors. In more ways than one, the Assassin IV tries to match the aesthetic of NVIDIA's Founders Edition cards as shown in the example build below.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/f4c3c3wcNC85nQvK.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/f4c3c3wcNC85nQvK_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/svFhLQHHfp1ZuwNe.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/svFhLQHHfp1ZuwNe_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/h8RbLV7FzK0yDd9d.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/h8RbLV7FzK0yDd9d_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3aitX4XbWbRgo0cq.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/3aitX4XbWbRgo0cq_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KysTxOKfyMyzLjMj.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/KysTxOKfyMyzLjMj_thm.jpg" width="173" height="130" alt="" /></a></div>
Altec Lansing at CES: Hydra Series "Everything Proof" Party Speakers, Kids-safe Headphones
Altec Lansing introduced a lineup of party speakers, portable speakers, and kids-safe headphones at the 2023 International CES. The stall had a small selection of these in the new "wildlife camo" pattern. It includes two of the company's "everything proof" Hydra series wireless party speakers that pack powerful stereo+woofer speakers with a high degree of tuning to match the Hi-Fi systems of the old; and an internal lithium battery designed to last almost all day long. These speakers double up as power-banks, so you can recharge your smartphones, tablets, or ultraportable notebooks. The lineup also included palm-sized portable speakers, and a pair of new kids-safe headphones models.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/WvAObgEMX32hCtHP.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/WvAObgEMX32hCtHP_thm.jpg" width="173" height="130" alt="" /></a></div>
This Week in Gaming (Week 2)
After a couple of weeks of very limited releases, new games are starting to trickle out again and we're back to give you a heads up on what's coming. From now on we'll also add a poll, so you can vote on the game you're most interested in each week. Please keep the feedback coming if there's something we can improve in this weekly section.<br />
<br />
<b><a rel="nofollow" href="https://www.bandainamcoent.com/games/one-piece-odyssey" target="_blank">One Piece Odyssey</a> / This Week's AAA Title / Thursday January 12</b><br />
One Piece Odyssey transports the Straw Hat Crew to a mysterious new island where they embark on quests and fight powerful enemies and massive bosses in exciting turn-based battles. The game is introducing a new chapter for these famed pirates, with an original story and new characters developed under the guiding hand of series creator Eiichiro Oda.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/V5tIpMNPlMscwPKx.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/V5tIpMNPlMscwPKx_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/D9fGecFXEYTitCbK.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/D9fGecFXEYTitCbK_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rZFaQNZURqR7SaKt.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/rZFaQNZURqR7SaKt_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iDV5Vc5XuQqYQIpF.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/iDV5Vc5XuQqYQIpF_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303261/this-week-in-gaming-week-2">Read full story</a></div>
LG UltraGear Unveils the World's First 240 Hz OLED Gaming Monitor
LG UltraGear at the 2023 International CES showed off the world's first gaming monitor with a blistering fast 240 Hz OLED panel. An in-house development by LG Display, the LG UltraGear OLED 45GR95QE is a 45-inch ultrawide gaming monitor with a 21:9 aspect-ratio, 3440 x 1440 pixels native resolution, an 800R curvature, and a surreal 240 Hz refresh rate with 0.03 ms response time. It supports both G-SYNC and FreeSync Premium to help it twiddle its thumbs while it awaits new frames from your GPU. The display takes input from HDMI 2.1, and features a high-performance DAC + headphones amplifier along with support for DTS Headphone X. For these and more, the monitor bagged a 2023 CES Innovation Award.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6B3DVNb4WTI86s5t.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/6B3DVNb4WTI86s5t_thm.jpg" width="173" height="130" alt="" /></a></div>
GIGABYTE Shows Off AORUS and AERO OLED Notebooks Powered by 13th Gen Core and RTX 40-series
The AORUS brand of GIGABYTE originated with gaming notebooks. At the 2023 International CES, AORUS presented a large number of gaming notebooks covering various market-segments, powered by the latest-generation 13th Gen Core "Raptor Lake" mobile processors, and GeForce RTX 40-series "Ada" Laptop GPUs. The AORUS 17X (17-inch) and AORUS 15X (15-inch) are the company's key performance gaming notebooks. Both come with 1440p Fast IPS 240 Hz displays, and rock an Intel Core i7-13700HX 8P+8E processor. The company didn't specify the GPU model in use, but we expect options to range from the RTX 4060 Laptop GPU, all the way up to the RTX 4090 Laptop GPU. 16 GB dual-channel DDR5-4800 memory, and 1 TB Gen 4 NVMe SSDs make for the rest of the specs.<br />
<br />
GIGABYTE has a special treat for creators on the move, with the AERO 16 OLED (16-inch) and AERO 14 OLED (14-inch). As their names suggest, they feature OLED displays. These come with 16:10 aspect-ratio displays. The 14-inch model rocks a 2560 x 1600 pixels resolution, and the 16-inch one does 3840 x 2400 pixels. Both displays are Samsung AMOLED sourced, and Pantone validated for a very wide color gamut. The 14-inch model is powered by a Core i7-13700HX 8P+8E processor and 16 GB of LPDDR5 memory; while the 16-inch model rocks a Core i9-13900H 6P+8E processor with 32 GB of DDR5-4800 memory. Both come with a variety of RTX 40-series Laptop GPU options, and 1 TB of Gen 4 NVMe storage.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/T9o3EsVjjL8o53Fa.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/T9o3EsVjjL8o53Fa_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/GYc1yrpsa95A6z1f.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/GYc1yrpsa95A6z1f_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Qn5Vclx7PHCaffG5.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Qn5Vclx7PHCaffG5_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ihvBx9KCl4Gd9IoD.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/ihvBx9KCl4Gd9IoD_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EUE6DLalVqzZFooz.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/EUE6DLalVqzZFooz_thm.jpg" width="173" height="130" alt="" /></a></div>
AMD Ryzen 7040 Series "Phoenix Point" Mobile Processor I/O Detailed: Lacks PCIe Gen 5
The online datasheets of some of the first AMD Ryzen 7040 series "Phoenix Point" mobile processors went live, detailing the processor's I/O feature-set. We learn that AMD has decided to give PCI-Express Gen 5 a skip with this silicon, at least in its mobile avatar. The Ryzen 7040 SoC puts out a total of 20 PCI-Express Gen 4 lanes, all of which are "usable" (i.e. don't count 4 lanes toward chipset-bus). This would mean that the silicon has a full PCI-Express 4.0 x16 interface for discrete graphics, and a PCI-Express 4.0 x4 link for a CPU-attached M.2 NVMe slot; unlike the "Raphael" desktop MCM and the "Dragon Range" mobile MCM, whose client I/O dies put out a total of 28 Gen 5 lanes (24 usable, with x16 PEG + two x4 toward CPU-attached M.2 slots).<br />
<br />
Another interesting aspect about "Phoenix Point" is its memory controllers. The SoC features a dual-channel (four sub-channel) DDR5 memory interface, besides support for LPDDR5 and LPDDR5x. DDR5-5600 and LPDDR5-7600 are the native speeds supported. What's really interesting is the maximum amount of memory supported, which stands at 256 GB—double that of "Raphael" and "Dragon Range," which top out at 128 GB. This bodes well for the eventual Socket AM5 APUs AMD will design based on the "Phoenix Point" silicon. Older Ryzen 5000G "Cezanne" desktop APUs are known for superior memory overclocking capabilities to 5000X "Vermeer," with the monolithic nature of the silicon favoring latencies. Something similar could be expected from "Phoenix Point."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BJfDuGzCj0G2dSkC.jpg" target="_blank" data-width="1339" data-height="1000" ><img src="https://tpucdn.com/img/BJfDuGzCj0G2dSkC_thm.jpg" width="174" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ktCzghc95ieHACv1.jpg" target="_blank" data-width="1337" data-height="1000" ><img src="https://tpucdn.com/img/ktCzghc95ieHACv1_thm.jpg" width="174" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PXVQHpXsaLqAcUtO.jpg" target="_blank" data-width="1594" data-height="1000" ><img src="https://tpucdn.com/img/PXVQHpXsaLqAcUtO_thm.jpg" width="207" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/I1dKaaKBU5nKeIUE.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/I1dKaaKBU5nKeIUE_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303245/amd-ryzen-7040-series-phoenix-point-mobile-processor-i-o-detailed-lacks-pcie-gen-5">Read full story</a></div>
(PR) NVIDIA Pairs 4th Gen Intel Xeon Scalable Processors with H100 GPU
AI is at the heart of humanity's most transformative innovations—from developing COVID vaccines at unprecedented speeds and diagnosing cancer to powering autonomous vehicles and understanding climate change. Virtually every industry will benefit from adopting AI, but the technology has become more resource intensive as neural networks have increased in complexity. To avoid placing unsustainable demands on electricity generation to run this computing infrastructure, the underlying technology must be as efficient as possible.<br />
<br />
Accelerated computing powered by NVIDIA GPUs and the NVIDIA AI platform offer the efficiency that enables data centers to sustainably drive the next generation of breakthroughs. And now, timed with the launch of 4th Gen Intel Xeon Scalable processors, NVIDIA and its partners have kicked off a new generation of accelerated computing systems that are built for energy-efficient AI. When combined with NVIDIA H100 Tensor Core GPUs, these systems can deliver dramatically higher performance, greater scale and higher efficiency than the prior generation, providing more computation and problem-solving per watt.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jNbNdhLRunGtUefj.jpg" target="_blank" data-width="1184" data-height="954" ><img src="https://tpucdn.com/img/jNbNdhLRunGtUefj_thm.jpg" width="161" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303427/nvidia-pairs-4th-gen-intel-xeon-scalable-processors-with-h100-gpus">Read full story</a></div>
Cooler Master ORB-X and DYN-X Detailed: Step Aside Tables and Chairs, Purpose-built Gaming Furniture is Here
Cooler Master thinks that the gaming furniture should just be tables, desks, or chairs with certain gamer-specific functions or comforts, but entirely purpose-built rigs that work to improve immersion. The company over 2022-23 has been on a mission to bridge the gap between the conventional desktop, and a pro-grade simulator, with the 2022 announcement of the ORB-X, and the 2023 unveiling of the DYN-X. The ORB-X is a specialty gaming furniture that combines a desk and seat. You're supposed to install a curved gaming monitor on its top armature that envelopes you when you're seated; while a tray slides out with your input devices. The whole setup barely takes more space in your room than a payphone booth would, but promises hours upon hours of uninterrupted gameplay as you feel like Giger's Space Jockey. The DYN-X is a set of rigging for a DIY race simulator. The first portion of it is a set of stands that can hold on to three curved gaming monitors that you can span a single display-head across, for an immersive motorsport or flight simulator experience. The second portion of it is a race-sim "rollcage" that features race sim input devices.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/bOhuf9P1x6goZpWG.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/bOhuf9P1x6goZpWG_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DyZ0XhgXik38n2AY.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/DyZ0XhgXik38n2AY_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cAJ6Opz1PDu4lQmJ.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/cAJ6Opz1PDu4lQmJ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5o2j6g38NKSHvSZM.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/5o2j6g38NKSHvSZM_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4LqpqN8iQ4bOg51u.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4LqpqN8iQ4bOg51u_thm.jpg" width="173" height="130" alt="" /></a></div>
Memory OEM Datotek Showcases Latest Products: Gen 5 NVMe SSDs and DDR5 Memory
Taiwan-based memory products OEM Datotek has been in business selling flash memory and DRAM products since 2004, with one of its most notable clients being HP. At the 2023 International CES, the company showcased its latest-generation memory products spanning not just HP-branded flash drives, but also flash drives under its own marquee, besides M.2 NVMe and 2.5-inch SATA SSDs; and PC memory spanning DDR5 and DDR4 generations. The company sells various vanilla (JEDEC spec) DDR5 and DDR4 memory modules in both standard U-DIMM and SO-DIMM form-factors. For gamers and enthusiasts, the company has the Ares line of premium DDR5 and DDR4 memory products, which come in overclocked speeds such as DDR5-6000 or DDR4-4000, including with RGB LED illumination. <br />
<br />
Among its SSD products are a new PCIe Gen 5 NVMe SSD under the Ares brand, Gen 4 NVMe drives under the Ares Dark Sword brand, and various Gen 3 NVMe SSDs under the main Datotek brand. We also spotted several USB 3.2 portable SSDs, as well as 2.5-inch SATA 6 Gbps ones under the main brand. The idea here is to attract more brands for OEM partnerships the way rival Biwin makes SSD and DRAM products for various top brands (such as HP and Acer).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DRqFwNu2xpafesvP.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/DRqFwNu2xpafesvP_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hMzlmiH1hgVoP2OC.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/hMzlmiH1hgVoP2OC_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XUus1HQnp54uFcDY.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/XUus1HQnp54uFcDY_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PTBENKsoVSCjDWMM.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/PTBENKsoVSCjDWMM_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WfA6eegOSVWUwrXO.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/WfA6eegOSVWUwrXO_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) TYAN Refines Server Performance with 4th Gen Intel Xeon Scalable Processors
TYAN, an industry-leading server platform design manufacturer and a MiTAC Computing Technology Corporation subsidiary, today introduced 4th Gen Intel Xeon Scalable processor-based server platforms highlighting built-in accelerators to improve performance across the fastest-growing workloads in AI, analytics, cloud, storage, and HPC.<br />
<br />
"Greater availability of new technology like 4th Gen Intel Xeon Scalable processors continue to drive the changes in the business landscape", said Danny Hsu, Vice President of MiTAC Computing Technology Corporation's Server Infrastructure Business Unit. "The advances in TYAN's new portfolio of server platforms with features such as DDR5, PCIe 5.0 and Compute Express Link 1.1 are bringing high levels of compute power within reach from smaller organizations to data centers."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jWaRLZZcGnLw7UJY.jpg" target="_blank" data-width="900" data-height="457" ><img src="https://tpucdn.com/img/jWaRLZZcGnLw7UJY_thm.jpg" width="256" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303422/tyan-refines-server-performance-with-4th-gen-intel-xeon-scalable-processors">Read full story</a></div>
Formovie Exhibits S5 and V10 Portable Home Projectors at CES
Formovie brough its two latest portable laser home projectors to CES. These include the cuboidal S5 laser projector; and the cylindrical V10 4K UHD projector. The V10 has an Apple HomePod-inspired shape, which actually serves a function. Besides being a portable projector, the V10 packs an omnidirectional 2.1 speaker system not unlike the HomePod. It measures 200 mm x 200 mm x 210 mm (WxDxH), weighing about 3.8 kg. <br />
<br />
The V10 offers a 4K Ultra HD native resolution, and uses an LED light-source with up to 2,500 ANSI lumens maximum brightness, and a 1.27:1 throw-ratio. The V10 is suitable for screen-sizes ranging between 60-inch to 150-inch, and has automatic keystone adjustments. The projector supports dual-band WiFi and a smart TV OS. Besides it, inputs include HDMI 2.1 with analog output, and you get two USB 3.1 ports for mass-storage devices.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/l4gJn3ZXOh3Lhg08.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/l4gJn3ZXOh3Lhg08_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/494M2BTt4c6n7sdk.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/494M2BTt4c6n7sdk_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sZhhyBRy47IPnnhf.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/sZhhyBRy47IPnnhf_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cLO3hE7jpLKPM8er.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/cLO3hE7jpLKPM8er_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rZT6sSIogoBIlOk7.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/rZT6sSIogoBIlOk7_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303421/formovie-exhibits-s5-and-v10-portable-home-projectors-at-ces">Read full story</a></div>
(PR) Sheetak Announces Product Line Expansion with CENTUM C3 Multi-Stage Cooler Based on Novel Patented Thermoelectric Device Structures
Sheetak is expanding their flagship CENTUM product line, based on newly patented thermoelectric device structures, that offer the highest temperature difference with significant increases to cooling power and COP. These new trailblazing CENTUM C3 chips are now available for sample orders. High-volume manufacturing will start in Q2 2023 at Sheetak's Austin facility.<br />
<br />
CENTUM C3 chips have been characterized, using standard thermoelectric testing methods, and demonstrate significant increases in maximum temperature differentials, cooling power, and efficiency (COP). The new chips attain temperature differentials more than 115°C for 2-stage coolers with hot-side at 50°C, and more than 160°C for 4-stage devices. The performance and cost metrics are unchallenged by other commercially available products.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/f9PLlm0MQX1zb97J.jpg" target="_blank" data-width="700" data-height="350" ><img src="https://tpucdn.com/img/f9PLlm0MQX1zb97J_thm.jpg" width="260" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303419/sheetak-announces-product-line-expansion-with-centum-c3-multi-stage-cooler-based-on-novel-patented-thermoelectric-device-structures">Read full story</a></div>
(PR) AIC Introduces Server Systems Powered By 4th Gen Intel Xeon Scalable Processors
AIC Inc., (from now on referred to as"AIC"), a leading provider in enterprise storage and server solutions, today unveiled its new server systems powered by 4th Gen Intel Xeon Scalable processors (formerly codenamed Sapphire Rapids). The new server platforms are designed to accelerate performance across the most in-demand workloads that businesses rely on including enterprise, storage, AI and HPC.<br />
<br />
The newly launched AIC servers, SB102-HK, SB201-HK and HP202-KT, are designed to offer superior processing performance and energy efficiency by leveraging the innovative features of 4th Gen Intel Xeon Scalable processors. With built-in accelerators, the 4th Gen Intel Xeon Scalable processors optimize the utilization of CPU core resources and feature enhanced memory bandwidth with DDR5, advanced I/O with PCIe Gen 5 and Compute Express Link (CXL) 2.0/1.1, and the ability to accelerate PyTorch real-time inference performance by up to 10x using Intel Advanced Matrix Extensions (Intel AMX) compared to the previous generation. The new AIC servers are empowered by advanced security technologies from 4th Gen Intel Xeon Scalable processors, allowing them to protect data and unlock new opportunities for business collaborations.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XaWcSKaAaTu6aVGh.jpg" target="_blank" data-width="800" data-height="428" ><img src="https://tpucdn.com/img/XaWcSKaAaTu6aVGh_thm.jpg" width="243" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303417/aic-introduces-server-systems-powered-by-4th-gen-intel-xeon-scalable-processors">Read full story</a></div>
(PR) Inspur Announces G7 Server Platform Supports the Latest 4th Gen Intel Xeon Scalable Processors
Inspur Information, a leading IT infrastructure solutions provider, announced that its G7 server platform fully supports 4th Gen Intel Xeon Scalable Processors. The 16 servers making up the brand-new lineup are industry-leading in terms of performance, openness, intelligent operation & maintenance, and sustainability. Compared with the previous generation of Intel-based products, these servers have 61% higher performance and up to 30% higher computing performance per unit of power consumption. The server platform is designed to be deployed in general-purpose computing, critical computing, AI, and other application scenarios.<br />
<br />
Inspur Information's brand-new G7 platform was designed with green technology, open-source solutions, security, and intelligence as priorities. It is an industry-leading example of system design, energy efficiency, and operation & maintenance management. G7 servers support diversified computing, with the most comprehensive product lineup in the industry. With a focus on green energy, this product line supports cold plate and immersion cooling schemes, and has unique cooling designs such as T-shaped radiator and advance heat detection with intelligent regulation, which all work together to reduce energy consumption by up to 30%. The new series also supports cloud operation and maintenance for intelligent fault diagnosis with an accuracy rate up to 95%.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NAmMezDsk36gEiAw.jpg" target="_blank" data-width="1200" data-height="628" ><img src="https://tpucdn.com/img/NAmMezDsk36gEiAw_thm.jpg" width="248" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303416/inspur-announces-g7-server-platform-supports-the-latest-4th-gen-intel-xeon-scalable-processors">Read full story</a></div>
MSI Shows off its QD-OLED Displays at CES
Back at Computex 2022, MSI first announced the <a href="https://www.techpowerup.com/295274/msi-reveals-the-meg-342c-qd-oled-display-at-computex-2022" target="_blank">MEG 342C QD-OLED</a> display, which finally appears to be ready to hit retail, as the company was showing off it, alongside its upcoming <a href="https://www.techpowerup.com/301435/msi-teases-49-inch-super-ultra-wide-qd-oled-monitor" target="_blank">MEG 491C QD-OLED</a> display, which was teased back in November. MSI revealed some additional details of the 34-inch MEG 342C QD-OLED, beyond the fact that it's using a curved 1800R, 3440 x 1440 resolution panel with a 175 Hz refresh rate. As such, we now know the monitor has an unspecified DisplayPort input, a pair of HDMI 2.1 inputs, a USB Type-C input with DP Alt mode support and 65 W USB Power Delivery support, as well as a USB-B upstreams port and four USB-A downstreams ports. MSI has also kitted out the monitor with OLED Care, which the company claims reduces image sticking and burn-in. Other features include a built in KVM, PBP and PIP support as well as a VESA DisplayHDR True Black 400 certification, although the monitor has a peak brightness of 1000 nits. The MEG 342C QD-OLED is said to have an MSRP of around US$800.<br />
<br />
The MEG 491C QD-OLED appears to be based on the same QD-OLED panel as Samsung's OLED G9. The model on display at CES was apparently non functional, which suggests that we might have to wait another six months before it becomes available, if the MEG 342C QD-OLED is anything to go by. The monitor sports the same 1800R curvature as the Samsung OLED G9 and obviously has the same 5120 x 1440 resolution and 240 Hz refresh rate. MSI didn't share much else in terms of specifications, so we're going to have to wait for the actual launch to find out more, including what will probably be a prohibitively high price tag.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OhpYJ5TJBc3TxPB9.jpg" target="_blank" data-width="1280" data-height="658" ><img src="https://tpucdn.com/img/OhpYJ5TJBc3TxPB9_thm.jpg" width="253" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Fhnr9zUdq1SbOKXK.jpg" target="_blank" data-width="1280" data-height="943" ><img src="https://tpucdn.com/img/Fhnr9zUdq1SbOKXK_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/okYlGhr5AYA3BjAx.jpg" target="_blank" data-width="1126" data-height="681" ><img src="https://tpucdn.com/img/okYlGhr5AYA3BjAx_thm.jpg" width="215" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303415/msi-shows-off-its-qd-oled-displays-at-ces">Read full story</a></div>
iBuyPower Trace Gaming Case and Peripherals at CES Hands On
At the 2023 International CES, the lifestyle PC case brand HYTE shared its booth with its parent brand iBuyPower, a leading prebuilt gaming PC vendor, which showed off a premium mid-tower case under its own marquee rather than under HYTE. The new iBuyPower Trace 7 Mesh can be purchased as a standalone case, or you can buy prebuilt gaming desktops featuring it. The ATX mid-tower features a conventional horizontally-partitioned layout with an airy mesh front-panel. The case is tested to support many of the newer-generation graphics cards with 3+ slot thickness and 16-18 cm height. Among the fan-vents included with the case are three 120 mm along the front, with room for a 360 mm radiator, two 120 mm top exhausts that can hold onto a 240 mm radiator, and a 120 mm rear exhaust. <br />
<br />
Among the two new gaming peripherals released by iBuyPower are the Chimera K7 gaming keyboard, and the Chimera M7 gaming mouse. The two will be part of the Chimera KM7 combo, which can be added to your iBuyPower build, or sold piecemeal. The Chimera K7 is a membrane-type gaming keyboard with 24 RGB lighting zones that can be controlled via the HYTE Nexus software; while the Chimera M7 is a palm grip-optimized pseudo-ambidextrous wired mouse with an RGB diffuser that makes up the top grip. The HYTE Nexus software is used for fine-tuning the performance and lighting of this mouse.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vmhDAghZ8JSwCn9V.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/vmhDAghZ8JSwCn9V_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Dx9JhmAO38LSwaX1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Dx9JhmAO38LSwaX1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XWsBD6ffuyqfZJri.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XWsBD6ffuyqfZJri_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FAanjd2kvQkXiJMg.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/FAanjd2kvQkXiJMg_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Level Up Ethernet Connectivity with NEXCOM's New High-Performance Network Appliance
NEXCOM, a leading supplier of network appliances, launched a new platform based on the 4th Gen Intel Xeon Scalable processor - the NSA 7160. This high-performance 2U rackmount is a long-awaited enhancement of NEXCOM's well-established cyber security product line. NSA 7160 is equipped with the latest Intel technologies, featuring eight PCIe Gen5 extension slots for LAN modules, built-in accelerators, CXL1.1 and supports installation of RunBMC module & full-height full-length (FHFL) card.<br />
<br />
NEXCOM's NSA 7160 is intended for network security and 5G network applications, with cutting-edge features like multi-core computing performance, high memory capacity, high-speed I/O interface, and improved Intel QuickAssist Technology (Intel QAT) hardware acceleration for both enterprise and telecommunication applications. By leveraging 4th Gen Intel Xeon Scalable processors, NSA 7160 accelerates performance across the fastest-growing workloads and delivers value across multiple applications.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/9AXuGI4PsuRfTTjL.jpg" target="_blank" data-width="1000" data-height="854" ><img src="https://tpucdn.com/img/9AXuGI4PsuRfTTjL_thm.jpg" width="152" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303410/level-up-ethernet-connectivity-with-nexcoms-new-high-performance-network-appliance">Read full story</a></div>
(PR) Lenovo Unveils Next Generation of Intel-Based Smart Infrastructure Solutions to Accelerate IT Modernization
Today, Lenovo unveiled 25 new ThinkSystem and ThinkAgile server and hyperconverged solutions powered by Intel's 4th Generation Xeon Scalable Processors as part of its recently announced Infrastructure Solutions V3 portfolio. Designed to help accelerate global IT modernization for organizations of all sizes, the integrated solutions deliver advanced performance, efficiency and management capabilities specifically optimized for complex workloads, including mission-critical, AI, HPC and containerized applications.<br />
<br />
"In today's competitive business climate, modern infrastructure solutions that generate faster insights and more efficiently enable complex workloads from the edge to the cloud are critical across every major industry," said Kamran Amini, Vice President and General Manager of Server & Storage, Lenovo Infrastructure Solutions Group. "With the performance and management improvements of the Intel-based ThinkSystem V3 portfolio, customers can reduce their IT footprint by up to three times to achieve greater ROI and more easily transform their infrastructure with one seamless platform designed for today's AI, virtualization, multi-cloud and sustainable computing demands."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CWWS7cn0D7v1a8UX.jpg" target="_blank" data-width="2000" data-height="960" ><img src="https://tpucdn.com/img/CWWS7cn0D7v1a8UX_thm.jpg" width="271" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303409/lenovo-unveils-next-generation-of-intel-based-smart-infrastructure-solutions-to-accelerate-it-modernization">Read full story</a></div>
HYTE Y40 Up Close: Truly a Next-Gen Case for Next-Gen Hardware
At first glance, the HYTE Y40 may seem like a short and stout Micro-ATX tower, but up close, it's actually an ATX mid-tower that just so happens to look stout, and ready for the latest generation of CPU cooling solutions and 4-odd slot graphics cards. The Y40 retains HYTE's essential design language of making sure the front-left panel seems like a contiguous glasshouse. The case is horizontally partitioned, with the bottom compartment having the PSU- and drive bays, while the upper compartment has a spacious motherboard tray. This is where things get very interesting.<br />
<br />
The HYTE Y40 is unconventional in that all the 7 expansion slots of its motherboard tray are half-height (low-profile), while there are four full-height vertical slots, which is where you're supposed to install your graphics card. HYTE includes a PCI-Express 4.0 x16 riser with the case. All other expansion cards need to be half-height. Most aftermarket non-graphics add-on cards these days, such as WLAN cards, 10 GbE cards, USB/Thunderbolt cards, or even some sound cards, are half-height and include low-profile brackets anyway. The case is much longer than the motherboard tray itself, which opens up room for a 280 mm radiator mount along the plane of the motherboard tray. The Y40 offers clearance for graphics cards up to 4 slots thick, up to 94 mm tall, and up to 42.2 cm in length (the ASUS ROG Strix RTX 4090 should fit). There's also room for CPU coolers up to 18.3 cm in height.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/l8fjPaDuQ7d6cLml.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/l8fjPaDuQ7d6cLml_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6xpT6ESrZaiAUbbL.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/6xpT6ESrZaiAUbbL_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vFBdsZlfB4agWlRz.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/vFBdsZlfB4agWlRz_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UQwM729loYfmj6nA.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/UQwM729loYfmj6nA_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XXavERcL7zu9u4td.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XXavERcL7zu9u4td_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303408/hyte-y40-up-close-truly-a-next-gen-case-for-next-gen-hardware">Read full story</a></div>
innocn Shows Off Mini-LED, Fast IPS, and Curved OLED Gaming Monitors at CES
New entrant innocn showed off five new gaming monitors at the 2023 International CES, of various shapes and sizes, and with various display panel technologies. The 27B8U is a stunning, no-nonsense, 27-inch planar monitor with 4K Ultra HD (3840 x 2160 pixels) resolution, standard 60 Hz refresh rate, and 0.03 ms response time from its OLED panel. The 32A6U is another planar beauty, albeit larger at 31.5-inch panel size. It features an IPS panel with mini-LED backlighting, and 2,304 local dimming zones. This one, too, has a 60 Hz refresh-rate. The S48A8V-S is a 48-inch "large-format" gaming monitor with an OLED planar panel that has 4K Ultra HD resolution, 138 Hz refresh-rate, and 0.03 ms response time.<br />
<br />
Things get interesting with the company's curved gaming monitors, starting with the 45E3R, a 44.5-inch curved super-ultrawide monitor with 32:9 aspect ratio for the VA panel that has a native resolution of 5120 x 1440 pixels, 1500R curvature, and 120 Hz refresh-rate. The 34E7R has a more conservative 21:9 aspect ratio on its 34-inch, 1500R curved panel, but a much faster VA panel with mini-LED illumination that offers 2,304 LDZs, and 165 Hz refresh-rate. The 34E9R is the most advanced curved gaming monitor from the lot, with a 34-inch 1800R-curved OLED panel, 3440 x 1440 pixels resolution, 175 Hz refresh-rate, and 0.03 ms response time.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Z5z5Qu6SuA8CLXdO.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Z5z5Qu6SuA8CLXdO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fRcwtlh7PazjjigW.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/fRcwtlh7PazjjigW_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2JPf19yF6IF9N6cb.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/2JPf19yF6IF9N6cb_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BxsbHFST259I9Zk0.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/BxsbHFST259I9Zk0_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XmfantxlHFwLJY9Z.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/XmfantxlHFwLJY9Z_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8oiaJyLJxx3JACoa.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/8oiaJyLJxx3JACoa_thm.jpg" width="173" height="130" alt="" /></a></div>
HYTE Unleashes the Potential of its Unique Y60 Case Design with Touchs
HYTE started out as a DIY retail channel brand for the unique case and peripheral designs of gaming PC builder iBuyPower, but has grown into a unique brand on its own. Their most iconic product, the Y60 case, stands out for its "corner plot" design, where the front-left corner of the case has been carved out into a corner-facing side. In most trims of the Y60, this would be a tempered glass panel; and some of the newer themed variants, this is an additional surface for air—either decals or stained-glass/prints. At the 2023 International CES, the company unlocked two unique uses for this corner panel.<br />
<br />
The first of these is a touchscreen that spans the entire height of the panel, and connects to your graphics card like any other display, and takes up a USB header for the touch input. The possibilities for this screen are endless—scroll through Windows 11 Start widgets, use a hardware monitoring app, as a game HUD, or what have you. The second of these is a really groovy distro-plate + pump device designed by iBuyPower. You no longer need to cover the entire front-panel with one of these, can they can take up the corner panel. The coolant ports of the plate are optimally located for builds using this case. The company even designed HYTE branded fittings to go with these.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UJMKLAibv8dKBPQB.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/UJMKLAibv8dKBPQB_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SqWj2CoB3uRBwgV8.jpg" target="_blank" data-width="753" data-height="1000" ><img src="https://tpucdn.com/img/SqWj2CoB3uRBwgV8_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WDjcAKHPD3qTvjq6.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/WDjcAKHPD3qTvjq6_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sq0DL5e93p7bw2dA.jpg" target="_blank" data-width="907" data-height="904" ><img src="https://tpucdn.com/img/sq0DL5e93p7bw2dA_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jynYYdy5Er0nIp1f.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/jynYYdy5Er0nIp1f_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yDp2yeWXrTFaVRrV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/yDp2yeWXrTFaVRrV_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Team Group Announces JEDEC-standard DDR5-6400 Memory with Client Clock Drivers
World-leading memory brand, Team Group, has announced new breakthroughs in the Team Group ELITE U-DIMM DDR5 Standard Memory. To ensure compatibility with next-generation platforms, Team Group has pioneered the first high-performance 6400 MHz spec per JEDEC definitions for consumers to enjoy upgraded performances with ease in the DDR5 generation. <br />
<br />
To ensure a stable performance of 6400 MHz and above of the DDR5, Team Group has adopted the new CKD (client clock driver) components designed to strengthen, buffer, and steadily output high-frequency signals from the CPU to DDR5 memory kits, effectively ensuring high frequencies while supporting reliable high-speed transmissions. Team Group is dedicated to R&D and working simultaneously with motherboard manufacturers for rigorous compatibility testing, offering high-quality and highly compatible memory products for desktops and laptops to consumers around the world, fulfilling user demands for PC, laptops, or other small systems.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DpHKmekAt7eLhn24.jpg" target="_blank" data-width="919" data-height="568" ><img src="https://tpucdn.com/img/DpHKmekAt7eLhn24_thm.jpg" width="210" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/M92q6etjfqUy7tu2.jpg" target="_blank" data-width="800" data-height="435" ><img src="https://tpucdn.com/img/M92q6etjfqUy7tu2_thm.jpg" width="239" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303401/team-group-announces-jedec-standard-ddr5-6400-memory-with-client-clock-drivers">Read full story</a></div>
Wizmax Micronics PC Cooling at CES: MA Frigate and MA Falcon CPU Coolers, Warp Shield Heatsinks
Wizmax by Micronics introduced a handful new CPU coolers and purpose-build heatsinks at the 2023 International CES. The CPU cooler lineup is led by the MA Frigate series. The MA4 Frigate, a thick single aluminium fin-stack tower-type cooler. Five 6 mm-thick copper heatpipes make direct contact with the CPU at the base, conveying heat through a thick aluminium fin-stack, which is ventilated by a custom-design 130 mm fan. With this fan in place, the cooler measures 132 mm x 95 mm x 156.4 mm (WxDxH), weighing 990 g. The fan turns at speeds of up to 1,500 RPM, pushing up to 71.7 CFM of airflow at 1.9 mm H₂O static-pressure. The MA4 Frigate is rated for handling thermal loads of up to 210 W.<br />
<br />
The Wizmax MA6 Frigate is the larger sibling, with a type-D dual fin-stack design. Six 6 mm-thick nickel-plated copper heatpipes make indirect contact with the CPU through a copper base, conveying heat to two fin-stacks, which are ventilated by a pair of 140 mm fans in push-pull arrangement. One-third of the fins in the two fin-stacks are made of copper, and the rest aluminium. Each of the two 140 mm fans turns at speeds of up to 1,500 RPM, pushing up to 83 CFM of airflow at 2.2 mm H₂O. With the fans in place, the cooler measures 146 mm x 165 mm x 165 mm (WxDxH), weighing 1.6 kg. The MA6 Frigate is rated for 250 W thermal loads. Both coolers support the latest CPU socket types, including AM5 and LGA1700.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/m2M6GywsapvOAZA8.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/m2M6GywsapvOAZA8_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/24KdeaIKJR8Bc2ek.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/24KdeaIKJR8Bc2ek_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Sfa3mCARBzKRPFPr.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Sfa3mCARBzKRPFPr_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/exozmxYWEl4DVcar.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/exozmxYWEl4DVcar_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4oWqE9nRQsFXuUOA.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4oWqE9nRQsFXuUOA_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303400/wizmax-micronics-pc-cooling-at-ces-ma-frigate-and-ma-falcon-cpu-coolers-warp-shield-heatsinks">Read full story</a></div>
Wizmax Micronics New 2023 Power Supplies at CES: Amped Up for ATX 3.0 and PCIe Gen 5
Wizmax by Micronics showed off four new PSU lines at the 2023 International CES. At the top of the stack is the Astro II Gold, a monstrous high-end PSU with 1650 W continuous output, 80 Plus Gold switching efficiency, ATX 3.0 and PCIe Gen 5 standards compliance, and a patented digital-VRM voltage controller by Micronics. Other internal features include DC-to-DC switching a 135 mm fluid-dynamic bearing fan Zero RPM mode up to a certain electrical load, and fully-modular connectivity that includes two 16-pin ATX 12VHPWR connectors with 600 W continuous output each, twelve 6+2 pin PCIe power, two 4+4 pin EPS, and fourteen SATA power connectors.<br />
<br />
The Astro II Platinum is technically positioned a notch below the Astro II Gold 1650 W, but is more efficient. The Astro II Platinum comes in 1300 W, 1000 W, and 850 W variants. The 1300 W variant offers two 16-pin 12VHPWR connectors (each 600 W), while the 1000 W and 850 W ones offer one such 16-pin connector. The three get their names from the 80 Plus Platinum switching efficiency on offer, besides a feature-packed AC receptacle with Surge 4K and ESD 15K tolerance, and fluid-dynamic bearing fans with zero RPM up to a certain load.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JrBPugFpwAUFQtSy.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/JrBPugFpwAUFQtSy_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Heb8t32kDJzOR9lb.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Heb8t32kDJzOR9lb_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eK7r5f19EwtgWPal.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/eK7r5f19EwtgWPal_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fQMc1N7SVs2swGnO.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/fQMc1N7SVs2swGnO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lWbgMnOtWevvumhf.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/lWbgMnOtWevvumhf_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303399/wizmax-micronics-new-2023-power-supplies-at-ces-amped-up-for-atx-3-0-and-pcie-gen-5">Read full story</a></div>
An Introduction to Wizmax, a New Gaming PC Hardware Brand Storming the
Wizmax is a brand that came out of nowhere, with a strong presence at the 2023 International CES, debuting several new DIY gaming PC products, spanning cases, CPU coolers, case fans, peripherals, and power supplies. Wizmax is making inroads to western markets, and has its origins in South Korea, where it was started as a DIY channel brand by electronics OEM giant Micronics, which has been in business since 1996. While it works to set up a more organized distribution network, Wizmax is selling through a brand store on Amazon, with their lineup currently focused on gaming peripherals.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FseBT03m5Jv7IPvJ.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/FseBT03m5Jv7IPvJ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8isjccLBKgWMn9xV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/8isjccLBKgWMn9xV_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/88s32WEDMJZ1fDNB.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/88s32WEDMJZ1fDNB_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MOZhEM1zfHHl3tOs.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/MOZhEM1zfHHl3tOs_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) EK Pro Releases 4th Gen Intel Xeon Scalable CPU Water Blocks
EK, the leading liquid cooling gear manufacturer, is announcing the availability of two high-performance liquid cooling solutions for the Intel "Sapphire Rapids" processor family. These single-socket LGA4677 water blocks are specifically designed to cool the 4th Gen Intel Xeon Scalable CPUs that are optimized for advanced workstation professionals and go up to 60 cores. <br />
<br />
EK is quite experienced with demanding needs of heavily threaded, I/O intensive workloads across the industries like Architecture, Engineering and Construction, Media and Entertainment, and Artificial Intelligence and Machine Learning. This enabled them to create the EK-Pro CPU WB 4677, a water block designed to provide sufficient thermal headroom to maximize the performance benefits of Intel Turbo Boost Technology while maintaining healthy processor operating temperatures. EK aimed to create a liquid cooling solution that enables customers to operate at peak performance unrestricted by any thermals.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Sb6QtVwCIP5fZXKv.jpg" target="_blank" data-width="1303" data-height="588" ><img src="https://tpucdn.com/img/Sb6QtVwCIP5fZXKv_thm.jpg" width="288" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3x38TBXPsCgoEn41.jpg" target="_blank" data-width="1311" data-height="632" ><img src="https://tpucdn.com/img/3x38TBXPsCgoEn41_thm.jpg" width="270" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ISXXnoR2Csv478JH.jpg" target="_blank" data-width="1201" data-height="675" ><img src="https://tpucdn.com/img/ISXXnoR2Csv478JH_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/px0aJwELL0g4T7AP.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/px0aJwELL0g4T7AP_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303396/ek-pro-releases-4th-gen-intel-xeon-scalable-cpu-water-blocks">Read full story</a></div>
KeysOff Winter Sale: Get Jaw Dropping Prices on Genuine Software
KeysOff Winter Sale is live! Get some of the hottest discounts on the coolest software to help you maximize your PC building budget. Get Genuine Windows 10 Pro at just $6.22 when you buy a 2-PC pack, or $7.35 on its own. The latest and greatest Windows 11 Pro can be had for $10.45. Save big on annual 365 subscriptions by picking up Office 2021 Professional for just $26.25. Better yet, combine it with your preferred edition of Windows to save even more.<br />
<br />
<a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-32-64-bit-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro at $7.35</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-32-64-bit-2-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro 2-PC at $12.45</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-3-keys.html?kso=sks11" target="_blank">Buy Windows 10 Pro 3-PC at $21.67</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-5-keys.html?kso=sks11" target="_blank">Buy Windows 10 Pro 5-PC at $34.18</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-home-cd-key-32-64-bit-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Home at $7.25</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-cd-key-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro at $10.45</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-home-key.html?kso=sks11" target="_blank">Buy Windows 11 Home at $10.25</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2021-pro-plus-1-pc.html?kso=sks11" target="_blank">Buy Office 2021 Professional at $26.25</a> | <a rel="nofollow" href="https://www.keysoff.com/2-office-2021-pro-plus-keys-pack.html?kso=sks11" target="_blank">Buy Office 2021 Professional 2-PC at $41.25</a> | <a rel="nofollow" href="https://www.keysoff.com/3-office-2021-pro-plus-keys-pack.html?kso=sks11" target="_blank">Buy Office 2021 Professional 3-PC at $58.25</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2021-pro-plus-key-5-pcs.html?kso=sks11" target="_blank">Buy Office 2021 Professional 5-PC at $69.25</a> | <a rel="nofollow" href="https://www.keysoff.com/office-2019-professional-plus-1-pc.html?kso=sks11" target="_blank">Buy Office 2019 Professional at $24.25</a> | <a rel="nofollow" href="https://www.keysoff.com/ms-office-2016-prol-plus.html?kso=sks11" target="_blank">Buy Office 2016 Professional Plus at $18.99</a><br />
<br />
Please use the coupon code <b>SKK62</b> on the following items to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-office-2021-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $34.99</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-office-2019-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $31.99</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-pro-office-2021-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $31.76</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-pro-office-2019-pro-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $28.69</a> | <a rel="nofollow" href="https://www.keysoff.com/office-2021-home-and-business-for-mac.html?kso=sks11" target="_blank">Buy Office 2021 Home and Business for Mac at $68.66</a> | <a rel="nofollow" href="https://www.keysoff.com/office-home-and-business-2019-for-mac-cd-key-global.html?kso=sks11" target="_blank">Buy Office 2019 Home and Business for Mac at $66.22</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/QVPuKAUOhVqpHwpM.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/QVPuKAUOhVqpHwpM_thm.jpg" width="231" height="130" alt="" /></a> </div>Please check out great deals on system utilities.<div class="readmore"><a href="https://www.techpowerup.com/303544/keysoff-winter-sale-get-jaw-dropping-prices-on-genuine-software">Read full story</a></div>
ASUS Announces its Latest Vivobook Classic Series
ASUS today announced six of the latest models in its popular Vivobook Classic series of everyday laptops, led by the updated Vivobook 14 OLED (X1405), Vivobook 15 OLED (X1505) and Vivobook 16 (X1605). These are accompanied by new versions of the affordable Vivobook 14 (X1404), Vivobook 15 (X1504) and Vivobook 17 (X1704).<br />
<br />
Smooth performance is delivered by up to 13th Gen Intel Core H-series processors with 16 GB RAM and up to a 1 TB SSD. Quiet and efficient cooling is provided by the dual-vented cooling system with an IceBlade fan and up to two heat pipes. The long-lasting up to 50 Wh battery gives users more freedom, and there's up to WiFi 6E for ultrafast connectivity. Other helpful design features include the latest ASUS AI noise-canceling audio technology for crystal-clear communications, and there are bundled productivity-enhancing ASUS apps including GlideX, MyASUS and ScreenXpert.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YM2oyCPqWb5SK9ch.jpg" target="_blank" data-width="1280" data-height="860" ><img src="https://tpucdn.com/img/YM2oyCPqWb5SK9ch_thm.jpg" width="193" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3n6iMT7Z9oFRaF2K.jpg" target="_blank" data-width="1280" data-height="847" ><img src="https://tpucdn.com/img/3n6iMT7Z9oFRaF2K_thm.jpg" width="196" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BApFo5U8qTasy7J2.jpg" target="_blank" data-width="1280" data-height="656" ><img src="https://tpucdn.com/img/BApFo5U8qTasy7J2_thm.jpg" width="254" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7l0aJOengahEIA5W.jpg" target="_blank" data-width="1280" data-height="893" ><img src="https://tpucdn.com/img/7l0aJOengahEIA5W_thm.jpg" width="186" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VtAstvBvihif4Hy4.jpg" target="_blank" data-width="1280" data-height="744" ><img src="https://tpucdn.com/img/VtAstvBvihif4Hy4_thm.jpg" width="224" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303540/asus-announces-its-latest-vivobook-classic-series">Read full story</a></div>
XGIMI at the 2023 International CES: RS Pro 2 and MoGo 2 Pro
Home- and portable projectors specialist XGIMI showed off its two bestselling compact short-throw projectors at the 2023 International CES, the RS Pro 2, and the MoGo 2 Pro. The RS Pro 2 is designed for premium home-projection needs, with 2,200 ANSI lumens brightness, a lossless optical zooming mechanism, 4K Ultra HD native resolution, automated keystone adjustments, and smart TV features. The projector is designed for screen-sizes ranging between 30-inch to 300-inch (100-inch recommended by the manufacturer). The projector also integrates a 2.1-channel speaker set designed by Harman-Kardon. On sale now, the RS Pro 2 can be had around the $1,449-mark but it currently just planned for the Asian market. The MoGo 2 Pro is the latest version of XGIMI's award-winning ultraportable projectors. It packs a 350 ANSI Lumens LED light source, and can project Full HD (1920 x 1080) video with autofocus and keystone adjustments, onto a small-medium size screen.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8guUP4ONxGyKC21G.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/8guUP4ONxGyKC21G_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vPmR68Ze5ZOtn0Ta.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/vPmR68Ze5ZOtn0Ta_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/L9Jof8BsyrZ2kzEF.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/L9Jof8BsyrZ2kzEF_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IdztZYR1e5fMd3xn.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/IdztZYR1e5fMd3xn_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2mKA2K7o9tQXyrd5.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/2mKA2K7o9tQXyrd5_thm.jpg" width="98" height="130" alt="" /></a></div>
Cooler Master Shows Off Cooling X, a Unique Prebuilt with Whole-body Liquid Cooling
Cooler Master at the 2023 International CES showed off the Cooling X, a patent-pending unique desktop PC architecture by the company where the liquid cooling of the CPU and GPU isn't confined to a couple of closed loop AIOs, but rather a giant liquid-cooling loop that even involves the side-panels of the case itself, that double up as additional heat-dissipation surfaces. Notice how some compact fanless cases use extruded-aluminium body panels that double up as heatsinks, to cool the hot components? The Cooling X re-imagines this, where instead of dissipating heat from a heatpipe, the extruded-aluminium body panels have coolant channels, so some of the heat from the liquid-cooling loop is dissipated. These panels supplement a conventional liquid-cooling radiator that's located along the rear panel, which has active ventilation. The liquid-cooling loop cools the processor and GPU.<br />
<br />
For its compact dimensions of just 266 mm x 149 mm x 371 mm (LxWxH), the Cooling X prebuilt packs some mighty high-end hardware—an AMD Ryzen 9 5950X 16-core processor, and a Radeon RX 6800 XT GPU up to 64 GB of dual-channel DDR4-3200 memory, two 2 TB M.2 NVMe SSDs, and a homebrew 850 W 80 Plus Gold SFX power supply. For now Cooling X is just a codename, and Cooler Master intends to take this concept forward with high-performance gaming/creator prebuilt desktops sold under its own marquee.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/PlfXZazAzTMMn8q8.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/PlfXZazAzTMMn8q8_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yPRk02ZpyhpKft8S.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/yPRk02ZpyhpKft8S_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NaUPxFck9LcL1PHR.jpg" target="_blank" data-width="785" data-height="586" ><img src="https://tpucdn.com/img/NaUPxFck9LcL1PHR_thm.jpg" width="174" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hQg6gDJaP6NvCfbB.jpg" target="_blank" data-width="765" data-height="677" ><img src="https://tpucdn.com/img/hQg6gDJaP6NvCfbB_thm.jpg" width="147" height="130" alt="" /></a></div>
Cooler Master Keyboards at 2023 CES: MasterKeys MK770 and CK721 in New Colors
Cooler Master introduced several new color schemes of its MasterKeys MK770 and CK721 mechanical gaming keyboards at the 2023 International CES. The MK770 has a unique 99-key layout that retains the Numpad, squeezes the arrow keys between the main QWERTY key-cluster and the Numpad, and relocates the insert/delete/home/end/page-up/page-down cluster. This is essentially a full-size keyboard, but only 38 cm in length (comparable to some TKL keyboards). The MK770 supports three kinds of connectivity—USB (including type-C), wireless over Bluetooth 5.1, or wireless over a low-latency proprietary 2.4 GHz RF.<br />
<br />
The MK770 comes with hot-swappable Kailh Box V2 mechanical switches, a gasket mounted construction, PBT doubleshot keycaps with four distinct colors per color-set; and pre-lubed stabilizers for the keycaps. You get individual-key RGB lighting, a multi-function customizable wheel, and a 4000 mAh battery (the company didn't mention battery life on a full charge). In the USB and 2.4 GHz RF mode, the keyboard offers a 1000 Hz interface polling-rate, which drops down to 125 Hz in Bluetooth mode. A 512 KB onboard memory stores lighting and macro data. The four color sets the MK770 are offered in are: cyan+magenta+gray; mint-green+forest green+off-white; an Attack on Titan theme; and Fruity Pebbles theme. The CK721 Sakura Limited Edition is a 65% format mechanical gaming keyboard that uses TTC mechanical switches, PBT doubleshot keycaps, a 3-way digital dial, RGB lighting for each key, and triple interface just like MK770 (USB, Bluetooth, and 2.4 GHz RF). A 2,000 mAh battery provides up to 73 hours of use without lighting.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Jc8pVnInpY95sxvn.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/Jc8pVnInpY95sxvn_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MwSa8r5ZpqzLEcoB.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/MwSa8r5ZpqzLEcoB_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gofPc2OI6jZgUS3E.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/gofPc2OI6jZgUS3E_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tZ8SyQizwJ3C1dmG.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/tZ8SyQizwJ3C1dmG_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZdNL9CGkuIxXv0nu.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/ZdNL9CGkuIxXv0nu_thm.jpg" width="173" height="130" alt="" /></a></div>
Cooler Master New Case Fans at 2023 CES: MasterFan Halo2 and Mobius Se
Cooler Master at the 2023 International CES introduced several new case fans for various use-cases—case ventilation, air-heatsinks, and liquid-cooling radiators. The MasterFan Halo2 is the brightest and most striking of these, and the company is including them with some of their latest Hyper-series CPU coolers. They will be sold in standalone kits, too. The Halo2 gets its name from its two ARGB LED lighting zones—one along the bore of the frame, and the other inside the impeller hub. There are a couple of upgrades of the original MasterFan Halo series from 2020, including enlarged fan blades, a redesigned hybrid frame structure that minimizes frame footprint without sacrificing the fan's axial airflow; and updated motor driver IC. The MF Halo2 comes in 120 mm and 140 mm sizes; and in black- and white color trims. Both sizes feature rifle bearings that are rated for over 160,000 hours of operation.<br />
<br />
The MasterFan MF140 Halo2 features up to 1,600 RPM of speed, up to 58.5 CFM airflow, at up to 2.53 mm H₂O static pressure, and up to 27 dBA noise output. The MF120 Halo2 turns at speeds of up to 2,050 RPM, pushing up to 51.88 CFM of airflow, at up to 2.89 mm H₂O static pressure, and up to 27 dBA noise output. The fans take 4-pin PWM for their main function, and 3-pin Gen 2 ARGB for both their lighting zones.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hQsdTjw23dVlh9Hv.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hQsdTjw23dVlh9Hv_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4aLtREvkSyQQUCyE.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/4aLtREvkSyQQUCyE_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8hKRWJrdLSO0bpFx.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/8hKRWJrdLSO0bpFx_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9C7mPSjk9wJUEK0m.jpg" target="_blank" data-width="1200" data-height="1594" ><img src="https://tpucdn.com/img/9C7mPSjk9wJUEK0m_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TSrSXg3bbCz4vg8o.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/TSrSXg3bbCz4vg8o_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303529/cooler-master-new-case-fans-at-2023-ces-masterfan-halo2-and-mobius-series">Read full story</a></div>
Cooler Master MasterLiquid Atmos AIO Liquid CPU Cooler Features User-replaceable Block Covers
At the 2023 International CES, Cooler Master showed off a unique all-in-one liquid closed-loop CPU cooler that features user-replaceable pump-block covers, the MasterLiquid Atmos. The top cover of the pump-block comes off, so you can replace it with something with a different shape or color. Examples of these covers include a frosty-white cover made of recycled plastic resin, or a tinted acrylic diffuser. Underneath is a white silicone diffuser for an ARGB lighting element. The lighting extends to the included Cooler Master Sickleflow ARGB fans.<br />
<br />
The MasterLiquid Atmos model shown at CES was the ML360 Atmos, featuring a 360 mm x 120 mm radiator with a trio of Sickleflow ARGB fans. These fans come pre-installed on the radiator, to minimize packaging waste. The ML360 Atmos uses a dual-chamber pump-block, which features CM's Gen 2 ARGB lighting. The company didn't go into the technical details of the fan, but mentioned its top speed to be 2,400 RPM. The MasterLiquid Atmos series comes in two variants, 240 mm and 360 mm. Among the CPU socket types supported are LGA1700, LGA1200, AM5, and AM4.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NdbgyuTB4dEymn7Q.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/NdbgyuTB4dEymn7Q_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nQhsKDgCFkNVdSAF.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/nQhsKDgCFkNVdSAF_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hDRnwgdfln0dFmjT.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hDRnwgdfln0dFmjT_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) MINISFORUM HX99G 6900HX + RX 6600M Mini PC Goes on Sale
Minisforum introduced a new variant called HX99G in its Neptune portfolio today. It is an upgraded version of the first member, the HX90G (5900HX processor + RX6600M GPU), which was announced in May 2022 before going up for sale in September 2022. The Neptune HX99G looks practically identical to the HX90G. Measuring 205 x 203 x 69 mm (8.1" x 8" x 2.7"), both models feature 45 watts, 8-cores/16-threads graphics and the same laptop-class discrete GPU. However, it updates the Ryzen 9 5900HX with a faster Ryzen 9 6900HX and replaces the two DP ports with two speedier USB4 ports. <br />
<br />
R9 6900HX integrates all eight cores based on the Zen 3+ microarchitecture. It's clocked at 3.3 (guaranteed base clock) to 4.9 GHz (max boost). Ryzen 6000 brings a slew of technological advancements, like support for USB 4, PCI-E Gen 4, DDR5-4800MT/s, WIFI 6 and Bluetooth 5.2. The other AMD performance component is the RDNA 2 graphics architecture Radeon RX 6600M (GDDR6 8 GB) with a TDP of up to 100 watts. Users can expect to utilize the full performance of this dedicated GPU to handle professional-class photo and video editing as well as content creation. Also, this GPU packs enough firepower to hit 60 frames per second at 1080p (depending on the specific game and settings).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JH5K3stGb62xtXs7.jpg" target="_blank" data-width="1515" data-height="1000" ><img src="https://tpucdn.com/img/JH5K3stGb62xtXs7_thm.jpg" width="197" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/h7lYIQWXavdEBoQe.jpg" target="_blank" data-width="1218" data-height="1000" ><img src="https://tpucdn.com/img/h7lYIQWXavdEBoQe_thm.jpg" width="158" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9idd1aqdItau1jWo.jpg" target="_blank" data-width="1276" data-height="1000" ><img src="https://tpucdn.com/img/9idd1aqdItau1jWo_thm.jpg" width="166" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vYCIGwYTG1JCs5RQ.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/vYCIGwYTG1JCs5RQ_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303517/minisforum-hx99g-6900hx-rx-6600m-mini-pc-goes-on-sale">Read full story</a></div>
(PR) NZXT Announces H9 Series ATX Cases, C1200 PSU, and Duo RGB Fan
NZXT, a leader in PC gaming hardware and services, today announces mid-tower ATX cases, the H9 Flow and H9 Elite, the C1200 power supply, and the RGB Duo fans. The H9 Series features two new ATX compatible cases that will be the latest and largest options featured in NZXT's mid-tower lineup; they feature enough room for up to ten fans and direct airflow to cool off the most powerful video cards. The H9 Flow and H9 Elite are flexible to suit any type of build due to their large size, radiator support, and color schemes. For people who want to focus on thermal performance, the H9 Flow is designed to give you optimized cooling thanks to a mesh top panel. The H9 Elite is designed for people who want to build an RGB focused PC with some additional benefits, such as NZXT CAM support and a glass top panel to show off RGB lighting components.<br />
<br />
A perforated mesh top panel gives the H9 a greater focus on cooling performance. In addition, the case comes equipped with four 120 mm F Series Quiet Airflow fans to supplement airflow further. With superior airflow, the H9 Flow is the perfect case for people who want to build a system with the latest components with greater cooling requirements. The H9 Elite is an elegant way to accommodate builders who want a large tempered glass enclosure to show off their RGB builds, whether they want to share their setup on social media or their stream. With tempered glass on three sides for an uninterrupted look, a top radiator/fan, and with three included RGB Duo fans with an NZXT RGB and Fan controller V2, it is a perfect case to show off premium components.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vymNHTlzrKo0TtTs.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/vymNHTlzrKo0TtTs_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303516/nzxt-announces-h9-series-atx-cases-c1200-psu-and-duo-rgb-fan">Read full story</a></div>
Cooler Master Power Supplies at 2023 International CES: GX III, V Gold, V SFX Gold, and V SFX Platinum
Cooler Master brought a wealth of new power supplies at the 2023 International CES, to match the anticipated growth in PSU upgrades with the advent of the ATX 3.0 and PCIe Gen 5 standards. The GX III series will be the main workhorse for Cooler Master in its gaming-grade modular PSU lineup. Boasting 80 Plus Gold efficiency, the GX III comes in capacities ranging between 550 W and 1250 W, and cram in a half-bridge APFC, DC-to-DC switching, LLC, and a fan which offers zero-RPM mode up to a certain load. The 650 W, 750 W, 850 W, 1050 W, and 1250 W models include a 600 W-rated 12VHPWR connector, while the 550 W model includes a 450 W-rated 12VHPWR. Two EPS (CPU power) connectors are standard across all models. Depending on the model, you get two to six 6+2 pin PCIe power connectors. Cooler Master is backing the GX III series PSUs (along with most other PSU models it's launching at CES), with a 10-year warranty.<br />
<br />
The V Gold i series features an interesting brushed-gold design element on the body. These 80 Plus Gold-rated modular PSUs come in 750 W and 850 W models. What sets these apart from the GX III series is their semi-digital control, with the PSUs interfacing with the MasterPlus software over USB, for real-time monitoring and basic control. Both models include one 16-pin 12VHPWR connector capable of 600 W continuous power, two 8-pin EPS, three 6+2 pin PCIe power, twelve SATA power, and a couple of legacy power connectors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hTh0eZzF7WaECNHe.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/hTh0eZzF7WaECNHe_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/k2Cug2bhXB5EOkH1.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/k2Cug2bhXB5EOkH1_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a1NRQ0h9pfb25USV.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/a1NRQ0h9pfb25USV_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/53bXQzaK3RiQJOUD.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/53bXQzaK3RiQJOUD_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xtyWT8YuBdUy2Nuy.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/xtyWT8YuBdUy2Nuy_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303512/cooler-master-power-supplies-at-2023-international-ces-gx-iii-v-gold-v-sfx-gold-and-v-sfx-platinum">Read full story</a></div>
Cooler Master Hyper 212 Halo Series Brings the Iconic 212 up to 2023 Standards
The Cooler Master Hyper 212 series over the years has become synonymous with aftermarket CPU cooling, as possibly the most popular custom CPU cooler. The company modernized it over the years with new heatsink and fan technologies, and it's has undergone a major design- and tech overhaul with the new Hyper 212 Halo. It retains the conventional aluminium fin-stack (type-U) design, with four 6 mm-thick copper heatpipes making direct contact with the CPU at the base, conveying heat to an aluminium fin-stack heatsink that's been capped off with a die-cast aluminium top-plate. The included 120 mm Halo fan features rifle-bearings rated for over 160,000 hours, and features two sets of addressable-RGB LEDs—along the bore of the fan-frame, and the impeller hub. The fan turns at speeds ranging between 650 to 2,050 RPM, pushing up to 51.88 CFM of airflow at 2.89 mm H₂O static-pressure, and 27 dBA maximum noise output. As part of its design modernization, the Hyper 212 Halo gets support for the latest Sockets LGA1700 and AM5.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/HuiqjsU1nkEJodEw.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/HuiqjsU1nkEJodEw_thm.jpg" width="173" height="130" alt="" /></a></div>
NexiGo Aurora PJ90 is a Unique Ultra Short-Throw Projector for Space-C
NexiGo Aurora PJ90 is one of the few jaw-dropping UST (ultra short-throw) projectors we've come across at the 2023 International CES. This device can project onto a screen as large as 150-inch, from a very short throw distance (think a TV console right underneath the screen), with a very sophisticated automated keystone adjustment mechanism. What you get is a pristine 4K Ultra HD with HDR10 projection at up to 120 Hz refresh-rate, up to 2,500 ANSI lumens brightness, and in-built 60 W (RMS) Dolby Audio 2.1 speakers; along with a fully-fledged Android TV package, and HDMI 2.0 input. If you're in a space-constrained environment like a studio apartment, this is the one to get; however, get ready to fork out USD $2,100.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BL8QW65nc4XKP54w.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/BL8QW65nc4XKP54w_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2nvA7RTInT2Ob6Af.jpg" target="_blank" data-width="1200" data-height="904" ><img src="https://tpucdn.com/img/2nvA7RTInT2Ob6Af_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uM6VwTSLcNdi44pI.jpg" target="_blank" data-width="774" data-height="539" ><img src="https://tpucdn.com/img/uM6VwTSLcNdi44pI_thm.jpg" width="187" height="130" alt="" /></a></div>
Audio-Technica Makes a Big Push into the Game Streaming and Competitive Gaming Audio Segments
Known more for its audiophile-grade headphones, Audio-Technica this CES announced a big push into two distinct markets—the creator market led by game streamers; and the competitive gaming market. For creators and game streamers, the company announced variants of its popular headphones such as the ATH-M50x, with attached 10 mm condenser microphones, turning them into streaming-grade headsets, such as the ATH-M50xSTS (analog) and the ATH-M50xSTS-USB (USB). The company also revealed standalone microphones for streaming sets, in the form of the ATR-2100x-USB, the AT2020USB-X. For the podcasting and radio-show communities, the company launched the AT2040 and AT02020, a set of boom armature-suspended high-grade mics.<br />
<br />
Gamers are in for a treat, as Audio-Technica is now firmly into the gaming headset territory, with the ATH-G1 (wired analog) and ATH-G1WL (wireless). Both feature 45 mm high-end drivers from the ATH-M40x, a sound-stage that's tuned for a variety of gaming use-cases, weight reductions wherever possible, to improve extended use, and an in-line volume stock. The wireless version comes with buttons on the earcup, uses a proprietary 2.4 GHz RF wireless tech, and its battery offers 15 hours of use on a full charge. The ATH-G1 is priced at $169, and the ATH-G1WL at $249. The ATH-GDL3 is a wired analog headset for console gaming, with similar 45 mm drivers and a gaming soundstage, but is considerably lighter, and priced at $129.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Xv9gDxMK2ttg2a2T.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/Xv9gDxMK2ttg2a2T_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aVmzmHNUqI79zXAH.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/aVmzmHNUqI79zXAH_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/73qop0kwTjtBEean.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/73qop0kwTjtBEean_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NlxL17cmsuUdKEtT.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/NlxL17cmsuUdKEtT_thm.jpg" width="173" height="130" alt="" /></a></div>
Audio-Technica Unveils ATH-WB2022 Flagship Wireless Headphones with Wooden Chambers
Premium personal audio solutions maker Audio-Technica at the 2022 International CES showed off its flagship wireless headphones, the ATH-WB2022. This $2,700 pair of ultra-luxury headphones features wired + wireless dual-use mode, a 9-hour wireless playback ability on a full-charge, and the company's most premium 45 mm drivers. A high-end integrated DAC + OPAMP circuit power the headphones in wireless mode. The ATH-WB2022 is technically a headset, and packs a 10 mm condenser microphone. It's most striking aspect has to be its true-wood chamber design that helps produce more natural sounding notes. Positioned as a 60th Anniversary limited-edition product, the ATH-WB2022 could make it to lifestyle catalogs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FaVxncrPhEcEqkE2.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/FaVxncrPhEcEqkE2_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) EK Announces Direct Die Cooling for Intel 12th and 13th Gen Core Processors
EK, the premium liquid cooling hardware manufacturer, is launching the Direct Die product series aimed at delidding and achieving the ultimate cooling of the LGA 1700 socket-based Intel CPUs from the 12th generation Alder Lake and 13th gen Raptor Lake families. Kitguru teamed up with EK to investigate the potential benefits of direct die cooling for Intel's Alder Lake CPUs to achieve the best possible thermal performance on a daily basis. After publishing the first video announcing this collaboration, EK was overwhelmed by the response from Kitguru's audience. In order to bring these products to market, EK reached out to Der8auer, a renowned expert in delidding and direct die applications.<br />
<br />
EK has prepared a total of four products to start this Direct Die series: two CPU water blocks (one Limited Edition), a delidding tool, and an upgrade kit for existing EK-Quantum Vector² LGA1700 water blocks. So far, these products are aimed at Intel's LGA1700 socket and 12th and 13th-generation Intel Core CPUs. Delidding is the process of removing the integrated heatspreader (IHS) to reduce the distance between the CPU core die and the coldplate of the CPU cooler. Another benefit involves the removal of an entire layer of thermal transfer from the CPU die to the IHS. The delidding process enables a direct heat transfer from the CPU core to the water block. All this results in a significant reduction in overall thermals and less thermal difference between CPU cores. The procedure is typically performed by experienced enthusiasts because it involves a physical modification of the product that voids the CPU warranty. For a more in-depth explanation, please refer to this EK's blog post on delidding.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OSBL2iEmXqDNYsud.jpg" target="_blank" data-width="1200" data-height="676" ><img src="https://tpucdn.com/img/OSBL2iEmXqDNYsud_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5wIuKMrVTdsnKYwq.jpg" target="_blank" data-width="651" data-height="675" ><img src="https://tpucdn.com/img/5wIuKMrVTdsnKYwq_thm.jpg" width="125" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2IN2zHhAMdzW21g5.jpg" target="_blank" data-width="776" data-height="675" ><img src="https://tpucdn.com/img/2IN2zHhAMdzW21g5_thm.jpg" width="149" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/poGkSbk9lfagKmt9.jpg" target="_blank" data-width="871" data-height="675" ><img src="https://tpucdn.com/img/poGkSbk9lfagKmt9_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/x25972u5zfxKJZJU.jpg" target="_blank" data-width="1023" data-height="675" ><img src="https://tpucdn.com/img/x25972u5zfxKJZJU_thm.jpg" width="197" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303489/ek-announces-direct-die-cooling-for-intel-12th-and-13th-gen-core-processors">Read full story</a></div>
(PR) MSI Launches the Clutch GM31 Lightweight Wireless Gaming Mouse
MSI, a leading global computer brand for gamers, has announced 2 new additions in the lightweight gaming mouse series—Clutch GM31 Lightweight Wireless and Clutch GM31 Lightweight (wired version). As the successor of the award-winning Clutch GM41 Lightweight Wireless, the Clutch GM31 Lightweight Wireless is a better fit for gamers with small to medium-sized hands. The Clutch GM31 Lightweight Wireless is packed with a ton of features including state-of-the-art low latency wireless technology, up to 110 hours of battery life, a charging dock, and other various features that provide performance boosts to your gameplay.<br />
<br />
<b>Lightweight, Small, yet Ergonomic</b><br />
Utilizing the same lightweight plastic material as its predecessor, the Clutch GM31 Lightweight Wireless weighs in at an ultra-light 73 g. This results in rapid yet effortless movement, delivering outstanding gameplay with each move. The small ergonomic chassis makes the mouse a better choice for gamers with small to medium-sized hands and provides excellent comfort in most grip styles. It also features gaming grade 100% pure PTFE mouse skates which have a single-directional surface texture and double-cut edges that make each move faster and more precise.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qxCgDpHKk1RNxnuC.jpg" target="_blank" data-width="960" data-height="365" ><img src="https://tpucdn.com/img/qxCgDpHKk1RNxnuC_thm.jpg" width="342" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1ZPeBTETQmojTsOn.jpg" target="_blank" data-width="1029" data-height="960" ><img src="https://tpucdn.com/img/1ZPeBTETQmojTsOn_thm.jpg" width="139" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303487/msi-launches-the-clutch-gm31-lightweight-wireless-gaming-mouse">Read full story</a></div>
(PR) Synology Unveils DiskStation DS723+, a Capable Storage Device with a Small Footprint
Synology today announced the new 2-bay Synology DiskStation DS723+, the smallest expandable option in its lineup of all-in-one solutions for home offices and small businesses. Powered by the versatile Synology DiskStation Manager (DSM) operating system, the DS723+ offers comprehensive solutions to protect and manage business data, easily collaborate on documents, access files remotely, and monitor physical assets, all within a compact desktop format. <br />
<br />
"This new unit delivers impressive performance and capability for its size," said Michael Wang, Product Manager at Synology. "With its extremely compact form factor, it will certainly appeal to those that have smaller storage requirements but don't want to give up on the convenience of centralized storage and the possibility to scale in the future."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YB9p72JCjImudA9p.jpg" target="_blank" data-width="816" data-height="740" ><img src="https://tpucdn.com/img/YB9p72JCjImudA9p_thm.jpg" width="143" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KKsa24oXlmzioSNA.jpg" target="_blank" data-width="486" data-height="764" ><img src="https://tpucdn.com/img/KKsa24oXlmzioSNA_thm.jpg" width="83" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UwqextAIGaiYcIHJ.jpg" target="_blank" data-width="928" data-height="703" ><img src="https://tpucdn.com/img/UwqextAIGaiYcIHJ_thm.jpg" width="172" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yhIfqQ5Wua2eIGk0.jpg" target="_blank" data-width="908" data-height="718" ><img src="https://tpucdn.com/img/yhIfqQ5Wua2eIGk0_thm.jpg" width="164" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303481/synology-unveils-diskstation-ds723-a-capable-storage-device-with-a-small-footprint">Read full story</a></div>
(PR) QNAP Introduces TVS-h874 NAS with 12th Gen Intel Core i9 Sixteen-
QNAP Systems, Inc., a leading computing, networking, and storage solution innovator, today launched new high-performance TVS-h874 QuTS hero NAS models that incorporate 12th Gen Intel Core i9 sixteen-core, i7 twelve-core multi-thread processors with Intel Core Hybrid Technology for optimal computing performance and smooth multiple virtual machine (VM) operation. Integrating the reliable ZFS-based operating system, PCIe Gen 4 expandability, M.2 NVMe SSD caching, and 2.5GbE/10GbE connectivity, the TVS-h874 assists businesses in building high-performance storage environments for hosting multiple VM, application servers, and running business data backup/restore applications.<br />
<br />
"The new TVS-h874 models adopt Intel Core Hybrid Technology, combining Performance-cores and Efficient-cores," said Andy Chuang, Product Manager of QNAP, adding "The Performance Hybrid Architecture intelligently allocates CPU cores to different tasks, thus increasing the performance of the new TVS-h874 models by 3.55 times compared with previous models."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ZK3aulSgXolqcMcl.jpg" target="_blank" data-width="800" data-height="420" ><img src="https://tpucdn.com/img/ZK3aulSgXolqcMcl_thm.jpg" width="248" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Zg4gfr4i7GbYC7t9.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/Zg4gfr4i7GbYC7t9_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MHcD7ybIg0gYfhFn.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/MHcD7ybIg0gYfhFn_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/RzCjNHTauiOium2I.jpg" target="_blank" data-width="1000" data-height="625" ><img src="https://tpucdn.com/img/RzCjNHTauiOium2I_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303480/qnap-introduces-tvs-h874-nas-with-12th-gen-intel-core-i9-sixteen-core-i7-twelve-core-processor-and-intel-core-hybrid-technology">Read full story</a></div>
Intel Launches Core i9-13900KS 8P+16E Flagship Processor at $700
Intel today formally launched the Core i9-13900KS "Raptor Lake" flagship desktop processor. At an MSRP of USD $700, the i9-13900KS is positioned a notch above the $590 i9-13900K, which it replaces as the top 13th Gen Core desktop part you can buy. The i9-13900KS features the same 8P+16E core-configuration as the i9-13900K, but at increased clock speeds and power limits. It is the world's first 6 GHz processor, with its maximum boost frequency set at exactly 6.00 GHz, up from 5.80 GHz of the i9-13900K. This is not just a minor +200 MHz speed bump, but backed by increased power-limits, which enable improved multi-threaded boost-frequency spread thanks to the Adaptive Boost Technology carried over from the previous-generation i9-12900KS.<br />
<br />
The 8 "Raptor Cove" P-cores of the i9-13900KS are clocked at 3.00 GHz base with up to 6.00 GHz boost, compared to 3.00/5.80 GHz of the i9-13900K, while the E-core frequencies are left untouched at 2.20 GHz base and up to 4.30 GHz boost. The big change here is the processor base power value, which is now set at 150 W, compared to 125 W of the i9-13900K, and while the maximum turbo power value is the same 253 W, Intel has changed the way its power headroom is utilized to support improved boost frequency spread across the P-cores. It seems like Intel hasn't sampled tech publications this processor, and the handful publications that have posted their reviews today using processors sourced from friendly retailers, report increased power-draw, and the need for large aftermarket cooling solutions even at stock frequencies. The i9-13900KS is being offered as an overclocking-friendly chip to those who know what they're doing and can handle extreme cooling solutions.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lHP52KkC4Cyy45yr.jpg" target="_blank" data-width="1086" data-height="583" ><img src="https://tpucdn.com/img/lHP52KkC4Cyy45yr_thm.jpg" width="242" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Uv3hu5VkdhlKWlcE.jpg" target="_blank" data-width="735" data-height="607" ><img src="https://tpucdn.com/img/Uv3hu5VkdhlKWlcE_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gAGEips2xZq7WYdf.jpg" target="_blank" data-width="833" data-height="565" ><img src="https://tpucdn.com/img/gAGEips2xZq7WYdf_thm.jpg" width="192" height="130" alt="" /></a></div>
Corsair RMx Shift Series PSU Reimagines the Modular PSU
It's scary how nobody else thought of this. Imagine a modular PSU whose connectors are not at its tail end, but one of the sides that usually face right side-panel of your case, vastly minimizing cable clutter. That's the new Corsair RMx Shift series. All of the PSU's modular connections, including a 24-pin ATX, a couple of 4+4 pin EPS, a 16-pin 12VHPWR, six-odd 6+2 pin PCIe power, and a dozen SATA power connections, all wire out from the longer right side panel of the PSU (when oriented with its intake fan facing down). In most "cases," this would open up the connectors right below the motherboard tray, from where you can easily access them, without having to wrestle with them as you would on conventional modular PSUs. The RMx Shift includes new Corsair type-5 modular cables, and we expect these to be right angled, so further minimize cable clutter from having to bend these cables against the side-panel of your case. Pictured below are the RM1200x Shift, a 1200 W model with 80 Plus Gold efficiency, and the shorter RM850x Shift, its 850-Watt sibling.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CBCYzSwo0Y2X2oJJ.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/CBCYzSwo0Y2X2oJJ_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6iPJvZ03gOiW3zak.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/6iPJvZ03gOiW3zak_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dUAducI39dheZt8X.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/dUAducI39dheZt8X_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/joTWjl2m9rFPdOXO.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/joTWjl2m9rFPdOXO_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/WaLAEvPWekwnDc9o.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/WaLAEvPWekwnDc9o_thm.jpg" width="173" height="130" alt="" /></a></div>
This Week in Gaming (Week 3)
Three weeks into the new year and another week without any big game releases, although SEGA/Atlus is about to release updated versions of Personal 3 and 4, which ends up being the most well known game releases this coming week. That said, there are a couple of other potentially interesting games coming out, so check out the full list for more details on those.<br />
<br />
<b><a rel="nofollow" href="https://www.madnetic-games.com/ww2-rebuilder.html" target="_blank">WW2 Rebuilder</a> / Monday January 16</b><br />
It's 1945. It's the end of World War II, the war that left a mark. Now people like you have to leave their hometowns to rebuild their countries. Motivated by different reasons, they get set on the same quest - to repair and renovate places completely destroyed during the war.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ihd7FrLVseXqRaJT.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/ihd7FrLVseXqRaJT_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AwRH7FgnvbExEuhQ.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/AwRH7FgnvbExEuhQ_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gmR5F6PkQXdzT1h7.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/gmR5F6PkQXdzT1h7_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TK61EkJ6I6PQgTfP.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/TK61EkJ6I6PQgTfP_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/303591/this-week-in-gaming-week-3">Read full story</a></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
