Cum punem subtitrare la filmele de pe hdd in spark?
Filmele de pe disc pot avea fisiere de subtitrare cu acelasi nume ca filmul dar de tip .srt !!!
Deocamdata , fiind o etapa intermediara , fisierle XML exportate de versiunea 1.1.38 nu
sint exploatabile in DreamboxEdit. In curand vom avea subtitrari on-line bazate pe EPG si
un browser internet.
Mor de nerabdare...browser internet! Cand se lanseaza 'update-ul' pentru alien ? Doamne ce fericit sunt...
multi nu or sa inteleaga ce zic pe aici...dar mi-am dorit foarte mult chestia asta, e revolutie fratilor...in direct!
:cool:
P.S: Domnule Mihai, sunteti 'mesagerul meu preferat'... :clap:
"New firmware but still have problem to decode programs at HotBird 13E from Cyfra+ provider
(Canal+ HD, HBO 2 HD, HBO Comedy SD and HD, TVP Sport, AXN) with card in slot and through
CCcam, mcas and all others."
I agree with that from sparkfans page. I have the same problem. Any suggestions?
What type of card you have ? is it N3 ? if YES ...you need BoxKey and RSA Key
and oscam will decode ... Your problem is not due to the Spark firmware !
all can be solved in oscam ..but you need : information and competence ...
It's Seca Mediaguard, CAID 0100, Provider 000068.
A lot of people have the same problem on Spark firmware. Only few channels don't work from
Cyfra+ provider, on E2 everything is ok with the same oscam settings as on Spark.
I'm sure that it's Spark FW guilt because the problem occurs on Amiko Alien and his clone Golden Media S990 as well.
To understand I need some information ... the Cyfra+ card is working fine on Alien E2 ?
or under other implementations of E2 such as Dreambox, VU+ ...
Cyfra+ card is on OSCAM server. When I'm using E2 RSP on Amiko Alien everything working great but when I change software for Spark 1.1.38 a lot of channels don't work. For example:
HotBird 13E
11278/V/27500 Canal+ HD
11278/V/27500 Canal+ FILM HD
11278/V/27500 Canal+ SPORT HD
10719/V/27500 Canal+ GOL
10719/V/27500 HBO COMEDY
10796/V/27500 HBO COMEDY HD
12188/V/27500 AXN
12188/V/27500 AXN Crime
...and many more....
On webinterface of OSCAM in CAID:SRVID section I see 0000:0000 when one of above channels is turned on at Amiko Alien.
It's Spark guilt, I'm sure that because I have tested it on other receivers and everything working great on E2 under Dreambox and AB IPbox.
In a late test ... I find out ..you have right ! in Spark I cannot open the named
channels even in sharing ! in E2 all works fine ! hmmm ...will see !!
Great, so I will wait for some good information from you :)
For now I have to use E2 from RSP team.
Acest receiver stie blindscan si are Functia PIP ?
What about new Spark software for Amiko Alien? Amiko newest sw is 1.1.38 but Golden Media has 1.1.40
Am probleme majore cu Alien-ul meu. Pur si simplu a innebunit. Nu stiu daca e ceva cu FW-ul 1.38 sau am ceva probleme cu receptorul: orice apas pe telecomanda, se repeta:
- apas OK merge info - channel list - channel si repeta, apas meniu repeta orice apas repeta de cel putin 10 ori. Credeam ca vine de la telecomanda, am bagat baterii noi, insa nimic, si daca de pilda initializez lista de canale, asta apare si dispare chiar si atunci dupa ce am scos bateriile din telecomanda. Nici enigma nu merge bine nu recunoaste comenzile de pe telecomanda, nu pot intra in meniu. Cred ca s-a intamplat ceva cu receptorul din senin ... am dreptate sau e o problema cunoscuta?
Nu este vreo problema a versiunii 1.1.38 ! mai degraba s-a intamplat ceva cu telecomanda ta !
pentru clarificare fa asa ...descarca de pe sat-support "rescue image" ...instaleaz-o in mod "boot"
... asa vei avea o imagine perfect curata ! desi intrucat fenomenul se produce si in E2 ....
!!! new FW soon ... one of this days ...
a revenit dupa ce am scos din priza o ora.
NEW release --- Spark 1.1.40
Noua imagine este disponibila pe serverul de download si [Only registered and activated users can see links. Click Here To Register...]
-Add function:add backup plugin function.(in menu/system/upgrade/backup system to HDD)
-Fixed the bug:when menu language is Hebrew,display characters from right to left
-improve media play
-change scan 'file list' mode,make scan more quick
-improve usb wifi function more stable
Mai multe detalii dupa teste !
Great but still problems whit cyfra+hd
Avand in vedere ca ma uit des la filme in format mkv , poti face o comparatie intre playerul actual si cel din E2 RSP ?Quote:
Originally Posted by mihaip
De asemenea se poate descarca direct prin intermediul receiverului conectat la internet:
Captura 1
Captura 2
Captura 3
Pentru a descarca noua versiune se apasa tasta rosie 'upgrade'
:band:
daca doriti sa va schimbati logo de boot trebuie inlocuit la adresa
/root/spark/Logo/
fisierul boot cu un altul care doriti voi ( dar care sa se numeasca tot boot ) care sa contina o imagine care va place , imaginea trebuie sa fie in format .png si la o rezolutie 1920 х 1080
