r4495 | _network | 2011-01-16 20:18:53 +0100 (Sun, 16 Jan 2011) | 2 lines
dvbapi: fix api detection
r4494 | _network | 2011-01-16 19:49:52 +0100 (Sun, 16 Jan 2011) | 2 lines
fixes for cardreader framework
Oscam-1.00-svn4498
r4498 | landlord | 2011-01-16 20:38:12 +0100 (Sun, 16 Jan 2011) | 1 line
Added new stbs to DVB API boxtype in documentation.
r4497 | landlord | 2011-01-16 20:33:59 +0100 (Sun, 16 Jan 2011) | 1 line
Added documentation for 'lb_savepath'.
r4496 | landlord | 2011-01-16 20:29:42 +0100 (Sun, 16 Jan 2011) | 1 line
Added new logging syntax for 'logfile'.
r4499 | _network | 2011-01-16 22:10:25 +0100 (Sun, 16 Jan 2011) | 2 lines
dvbapi: allow more seca emm filter
Oscam-1.00-svn4501
r4501 | pattex | 2011-01-16 23:00:59 +0100 (Sun, 16 Jan 2011) | 1 line
Fix wrong html tag
r4500 | alno | 2011-01-16 22:32:41 +0100 (Sun, 16 Jan 2011) | 1 line
WebIf: fix reader edit
r4503 | schlocke | 2011-01-16 23:47:13 +0100 (Sun, 16 Jan 2011) | 2 lines
reduced oscam-chk trace output
r4502 | schlocke | 2011-01-16 23:44:26 +0100 (Sun, 16 Jan 2011) | 2 lines
closed some memory-leaks.
Fix wrong html tag
r4509 | schlocke | 2011-01-17 14:34:35 +0100 (Mon, 17 Jan 2011) | 2 lines
cccam: fixed some segfaults
r4508 | schlocke | 2011-01-17 14:22:12 +0100 (Mon, 17 Jan 2011) | 2 lines
cccam: fixed some potention segfaults
Oscam-1.00-svn4510
r4510 | dingo35 | 2011-01-17 17:45:50 +0100 (Mon, 17 Jan 2011) | 1 line
oscam.c Suppress debug messages for now
r4513 | schlocke | 2011-01-17 19:12:28 +0100 (Mon, 17 Jan 2011) | 3 lines
completed matching_rdr change to list
updated loadbalancer
r4512 | _network | 2011-01-17 18:33:02 +0100 (Mon, 17 Jan 2011) | 2 lines
stapi: fix card reset with protocol=stapi
Oscam-1.00-svn4514
r4514 | dingo35 | 2011-01-17 19:43:19 +0100 (Mon, 17 Jan 2011) | 1 line
Small cleanup after matching_rdr migration
r4515 | Admin | 2011-01-18 00:55:07 +0100 (Tue, 18 Jan 2011) | 1 line
Revert [4463] as it makes problems with users/passwords with trailing slashes.
Oscam-1.00-svn4518
r4518 | dingo35 | 2011-01-18 15:28:19 +0100 (Tue, 18 Jan 2011) | 1 line
Doc update on sc8in1
r4517 | schlocke | 2011-01-18 14:14:35 +0100 (Tue, 18 Jan 2011) | 2 lines
matching_rdr: fix for corrupted/double free of mem
r4516 | cogsi | 2011-01-18 13:18:47 +0100 (Tue, 18 Jan 2011) | 1 line
ll_iter_release() guarding against NULL call
r4519 | dingo35 | 2011-01-18 17:39:17 +0100 (Tue, 18 Jan 2011) | 1 line
http, monitor: remove some code since get_ridx always returns >=0
---------- Post added at 20:19 ---------- Previous post was at 18:20 ----------
r4521 | schlocke | 2011-01-18 19:27:42 +0100 (Tue, 18 Jan 2011) | 2 lines
loadbalancer: fixed issue where last nonresponding reader is not blocked
r4520 | schlocke | 2011-01-18 19:19:05 +0100 (Tue, 18 Jan 2011) | 3 lines
loadbalancer: added debug output (d=1) showing primary readers and
[fallback readers]
r4522 | Admin | 2011-01-18 23:32:17 +0100 (Tue, 18 Jan 2011) | 1 line
Correction for [4464]. Thanks to -=Robby=-!
r4523 | schlocke | 2011-01-19 00:06:23 +0100 (Wed, 19 Jan 2011) | 4 lines
fixed fallback
internal: fixed reader-rc values (E_RDR_FOUND/E_RDR_NOTFOUND) different
from client-rc !
r4524 | Admin | 2011-01-19 00:14:06 +0100 (Wed, 19 Jan 2011) | 1 line
Fix #1518: If only stdout was set as logfile, a physical logfile was still written in /var/log/oscam.log on some plattforms.
fixed fallback
from client-rc !
