This Smartphone Tripod with Microphone is Designed for Audio/Video Rec
More and more use cases are being handled by smartphones, and we’ve recently seen smartphone stands helping with specific applications such as keyboard and mouse mobile gaming, or a flexible...[Only registered and activated users can see links. Click Here To Register...]
Primebook Laptop Runs Android based PrimeOS with Start Menu, Multi-Tasking Support, Key Mapping, etc…
After solutions such as Remix OS and Phoenix OS, PrimeOS is the latest attempt to bring Android OS to the desktop with support for a start menu, a status bar with pinned apps, multiple windows &...[Only registered and activated users can see links. Click Here To Register...]
Making a DIY Case Out of PVC Pipes & Fittings for Electronics Projects
If you’ve ever visited Thailand, you may have noticed blue PVC pipes that are for water supplies, and usually visible since most of the time they are not placed underground. The pipes and...[Only registered and activated users can see links. Click Here To Register...]
24 Orange Pi Zero Boards Cluster and ArmWizard’s Debian Image
ArmWizard forum member “-W.-” needed a cluster to test his firmware build and deployment solution for Orange Pi Zero boards which can deploy the firmware to multiple boards from one...[Only registered and activated users can see links. Click Here To Register...]
Run Linux Apps in (PixelBook) Chromebook with Crostini VM
Ever since the first Chromebooks were released, it has been possible to run Ubuntu or other Linux distributions using Crouton (Chromium OS Universal Chroot Environment) on Chrome OS devices, but that...[Only registered and activated users can see links. Click Here To Register...]
ESP8266 Loader App Allows you to Flash and Debug ESP8266 Boards from A
In case you’d like to flash ESP8266 boards using a phone, you can now do so with ESP8266 Loader app for Android, which also gives you access to the serial console. All you’ll need to an...[Only registered and activated users can see links. Click Here To Register...]
Acme Systems CM3-PANEL Panel PC based on Raspberry Pi Compute Module 3 Sells for 99 Euros and Up
After their first Raspberry Pi Compute Module 3 based board called CM3-Home designed for home automation, Acme Systems has designed a new RPi CM3 carrier board called CM3-PANEL for panel PCs /...[Only registered and activated users can see links. Click Here To Register...]
AAEON Releases an Intelligent Vending Machine Development Kit based on UP Board
UP board is a low cost development board powered by an Intel Atom x5-Z8350 Cherry Trail processor with 1GB to 4GB RAM, and 16 to 64GB eMMC flash that mostly follows Raspberry Pi 3 form factor. AAEON...[Only registered and activated users can see links. Click Here To Register...]
XH-M452 Board Helps Controlling a Cabinet or Room’s Temperature & Humidity
XH-M452 is a board designed to control the temperature and humidity in a room or cabinet. It comes with two relays to control appliances like fans, air conditioners, (de-)humidifiers, or heaters, and...[Only registered and activated users can see links. Click Here To Register...]
NXP QorIQ LayerScape LX2160A is a 16-core Arm Cortex A72 Communication Processor with 100 Gbit/s Ethernet
NXP Semiconductors has been working on a high-end communication processor with their QorIQ LayerScape LX2160A SoC equipped with 16 Arm Cortex A72 cores, 16 Ethernet ports supporting 1 to 100 Gbit/s,...[Only registered and activated users can see links. Click Here To Register...]
Microchip Offers Free PIC16F18446 8-bit MCU Development Boards
Microchip announced several PIC and AVR microcontrollers with “Core Independent Peripherals and Intelligent Analog” in February with respectively PIC16F18446 family of microcontrollers,...[Only registered and activated users can see links. Click Here To Register...]
Arm Cortex M35P Armv8-M MCU Core Gets Physical Security with Anti-tampering Features
Armv8 and Armv8-M processor already support Arm TrustZone security, which aims to prevent software attacks against the target device. However, if a hacker has physical access to the hardware, it may...[Only registered and activated users can see links. Click Here To Register...]
Ebyte Offers Low Cost Wireless Modules for LoRa, Zigbee, NB-IoT, Bluetooth, and More
Chengdu Ebyte Electronic Technology Ltd (or just Ebyte for short) is a company based in Western China that design and manufacturer low cost wireless modules for LoRa, WiFi, Bluetooth, Zigbee, NB-IoT...[Only registered and activated users can see links. Click Here To Register...]
Hardkernel & Libre Computer Release Ubuntu 18.04 Images for ODROID-XU4/3 & AML-S905X-CC Boards
Ubuntu 18.04 “Bionic Beaver” LTS operating system was released just last week, and at least two Arm board companies have independently released Ubuntu 18.04 images for their boards....[Only registered and activated users can see links. Click Here To Register...]
XTRX SDR Mini PCIe Card Supports 10 MHz to 3.8 GHz Tuning Range, up to 120 MSPS Sample Rate
Fairwaves is a startup that aims to make deploying and operating mobile networks in rural regions profitable, and their latest project is called XTRX, a high performance Software Defined Radio (SDR)...[Only registered and activated users can see links. Click Here To Register...]
Pepper Jobs W10 GYRO is an Air Mouse Designed for Windows 10
Air mice are remote controls including motion sensors allowing to wave the remote to emulate a mouse, as well as some buttons like in a standard remote control, and in some cases a keyboard. Some...[Only registered and activated users can see links. Click Here To Register...]
Ubuntu 18.04 Released – What’s New?
Canonical should release Ubuntu 18.04 “Bionic Beaver” long term support distribution later today. One of the most obvious change compared to Ubuntu 16.04 is the switch from Unity to GNOME...[Only registered and activated users can see links. Click Here To Register...]
QEMU 2.12 Released with Raspberry Pi 3, RISC-V Support
QEMU is open source machine emulator and virtualizer, which I used in the past at a time when Arm boards were more expensive or hard to get than today, and more recently I tested RISC-V Linux using...[Only registered and activated users can see links. Click Here To Register...]
How-to Make Your Own 3D Printing Goo
Karl here…just want to do a little post about bed adhesion and what I have been doing for the past month. What spurred this is I saw a ton of videos on Magigoo a while back. It is a product...[Only registered and activated users can see links. Click Here To Register...]
Working on High Quality Low Cost DIY 3D Scanning using Structured Light
Hello all, Karl here. I just wanted to send a note about what I have been working on. As the title says shows it is about 3d scanning. I have found it pretty fascinating so far. These are mainly...[Only registered and activated users can see links. Click Here To Register...]
Xiaomi Mi AI Speaker Mini Smart Speaker is Selling for $27 (in China)
Smart speakers are becoming cheaper and cheaper, and in the US and some other countries, Amazon Echo Dot can be purchased for under $50. But Xiaomi has come up with an even cheaper model – for...[Only registered and activated users can see links. Click Here To Register...]
MIPS I7200 Processor Core with nanoMIPS Architecture is Designed for L
MIPS has recently unveiled the I7200 multi-threaded multi-core processor for advanced LTE/5G communications and networking SoCs, which also happens to be the first MIPS core based on the new nanoMIPS...[Only registered and activated users can see links. Click Here To Register...]
HiFive Unleashed RISC-V Linux Development Board Gets a $2000 FPGA Expansion Board
If you’re a RISC-V architecture’s enthusiast or represent a company working on products with the new ISA, you may have spent $999 or more on Hifive Unleashed RISC-V Linux development...[Only registered and activated users can see links. Click Here To Register...]
Ubiquiti EdgeRouter X is a $60 Gigabit Ethernet PoE Router Supported by OpenWrt
Stanislav needed a Gigabit Ethernet router to run OpenVPN, and after some research he settled on Ubiquiti EdgeRouter X router with 5 Gigabit Ethernet ports, PoE in and pass-through, with a decent 256...[Only registered and activated users can see links. Click Here To Register...]
Review of Ubuntu 18.04 on ODROID-XU4Q Development Board
Hardkernel released their first Samsung Exynos 5422 octa-core board in July 2014 with ODROID-XU3, which at the time was really a powerful board, but also pricey at $179. Later that year, the company...[Only registered and activated users can see links. Click Here To Register...]
Allwinner Unveils A40i/A40pro and A60i/A60pro Industrial & Military Grade Processors
Allwinner A20 dual core Cortex A7 processor was/is one of the most popular Allwinner SoCs thanks to its low cost, the availability of interfaces such as SATA, Gigabit Ethernet, HDMI 1.4, and...[Only registered and activated users can see links. Click Here To Register...]
Lenovo Introduces Mirage Solo Daydream Standalone Virtual Reality Headset & Mirage Camera for VR180 Video Recording
Standalone / All-in-One Android virtual reality headsets have been around for a couple of years, mostly from Chinese vendors. But the number and quality of VR apps available were rather low at the...[Only registered and activated users can see links. Click Here To Register...]
Amlogic S905D2 Quad Core Cortex A53 Processor Coming Soon with Google Fuchsia Support
Earlier today, I wrote about the latest version of USB Burning Tool, and noticed added support for Amlogic “905D2” processor in the changelog. I had heard about Amlogic S905X2, but...[Only registered and activated users can see links. Click Here To Register...]
USB Burning Tool v2.16 for Amlogic Processors Released
Amlogic’s USB Burning Tool is a Windows based tool used to upgrade devices based on Amlogic processors over USB. Most devices now implement OTA firmware updates, so in most cases it is not...[Only registered and activated users can see links. Click Here To Register...]
Chrome 67 to Support the Generic Sensor API for Accelerometers, Gyroscopes, and Fusion Sensors
Once upon a time, web browsers were used to… well, browse the web, but overtime, features and API have been added to run apps with the ability to control hardware like webcams using the Media...[Only registered and activated users can see links. Click Here To Register...]
The World’s Smallest ESP8285 WiFi Module?
Taiwan based Blkbox may have designed the world’s smallest WiFi IoT module with their Espressif Systems ESP8285 based BB-E01P module pin-compatible with ESP-01 module, and measuring just...[Only registered and activated users can see links. Click Here To Register...]
Easily Make DIY Battery Packs with this Building Kit for 18650 Batteries (Crowdfunding)
If you have a project that requires some serious battery power, and can’t find a battery pack that matches your requirements, making your own is possible, but usually expensive as the commonly...[Only registered and activated users can see links. Click Here To Register...]
TTGO T5 is an ESP32 WiFi + Bluetooth Board with ePaper Display and Spe
Lilygo has made another ESP32 board part of their TTGO family with TTGO T5 board powered by Espressif System ESP32 WiFI & Bluetooth SoC, and offering a choice of ePaper displays from 1.54″...[Only registered and activated users can see links. Click Here To Register...]
Measy RCA220 is a $35 Wireless AV Transmitter / Receiver Kit with a 200m Range
There are several ways to send video & audio data over a distance without using long cables, from professional DVB-T transmitters with up to 10km range, to cheaper DIY SDR solutions with a...[Only registered and activated users can see links. Click Here To Register...]
Ugoos Releases Android 7.1.2 Nougat (Beta) for Rockchip RK3288 TV Boxes
Rockchip RK3288 quad core Arm Cortex A17 processor was first released in early 2014 with Android 4.4, and TV boxes that are still sold with the processor – e.g. Lenovo G66 – often still...[Only registered and activated users can see links. Click Here To Register...]
Jorjin WS2118/WS2119 is a Sigfox & Bluetooth LE Module Based on STMicro BlueNRG-1 & S2-LP Chips
Jorjin WS211X is a family of certified dual radio modules combining Sigfox wireless technology thanks to STMicro BlueNRG-1 BLE System-on-Chip (SoC) and Bluetooth Low Energy (BLE) using STMicro S2-LP...[Only registered and activated users can see links. Click Here To Register...]
CrowPi is a Portable Learning Kit for Raspberry Pi 3 B+ / Zero Boards
We have an embarrassment of choices for Raspberry Pi accessories from touchscreen displays, HAT add-ons boards, sensors, breadboard, and so on, as well as good software and support from Raspberry Pi... [Only registered and activated users can see links. Click Here To Register...]
Wear OS by Google Developer Preview 2 Adds Actions on Google (AoG) Support and Power-related Enhancements
Google has released the second developer preview of Wear OS by Google – previously known as Android Wear – that adds support for Actions on Google (AoG) and power-related enhancements... [Only registered and activated users can see links. Click Here To Register...]
Toradex Launches Apalis iMX8 Computer-on-Module based on NXP i.MX 8QuadMax SoC
Toradex Apalis iMX8 is another system-on-module powered by NXP i.MX 8QuadMax hexa core Arm Cortex A72 + 53 processor, which comes with 4GB LPDDR4 RAM, up to 16GB flash, and an on-board dual-band... [Only registered and activated users can see links. Click Here To Register...]
Two Interesting Projects on Github: Zigbee to MQTT bridge & “Deep Painterly Harmonization”
Hey Karl here. I thought I would try and showcase some GitHub projects that I run into that seem interesting or fun. This week I will start out with 2 projects. Zigbee to MQTT bridge The first one... [Only registered and activated users can see links. Click Here To Register...]
Vorke V5 Plus Kaby Lake Mini PC Review with Windows 10 and Ubuntu 18.04
The Vorke V5? Plus?? mini PC? just goes to show how initial impressions can be very misleading. Arriving in a plain manila-coloured box with the protection film on the top of the ?device starting to... [Only registered and activated users can see links. Click Here To Register...]
Microsoft Introduces Project Kinect for Azure
Kinect started as as motion sensing input device for Xbox 360 & One game consoles with an integrated webcam, infrared projector, and a microphone array, which enabled it to detect depth, motion,... [Only registered and activated users can see links. Click Here To Register...]
Google ADT-2 is an Android TV Dongle for Developers
You may remember we covered a “4K ATV Stick” last month, as a mostly unknown manufacturer (Shenzhen SEI Robotics) applied for FCC certification, with the device featuring a large G... [Only registered and activated users can see links. Click Here To Register...]
Google Assistant Adds 6 New Voices, Supports Smart Displays, Will Expand to 80 Countries
We’ve already seen announcements about Android P and Android Things 1.0 for Google I/O 2018, but the company also took the opportunity to provide an update to the new features coming to Google... [Only registered and activated users can see links. Click Here To Register...]
Android P Beta Released. What’s New?
Last March, Google released Android P developer preview with new features such as indoor positioning with WiFi RTT, support for display notch, HDR VP9, HEIF image compression, a new API to access two... [Only registered and activated users can see links. Click Here To Register...]
Mi Mini PC is a $150 Pocket-Sized Windows 10 Mobile PC with a 5? Touchscreen Display (Crowdfunding)
Around 2 years ago, I reviewed GOLE1 mini PC running Windows 10 and Android 5.1, powered by an Intel Atom x5-Z8300 Cherry Trail processor with 4GB RAM and 64GB SSD. It also came with a 5″... [Only registered and activated users can see links. Click Here To Register...]
A 6-Part BeagleBone Webinar for Users, Developers and Education Starts
The BeagleBone Black and derivatives like PocketBeagle or BeagleBone Green Wireless are still popular development boards, and if you are interested in the platform as a developer, user, or educator,... [Only registered and activated users can see links. Click Here To Register...]
Armbian History, Infrastructure, and Progress Report
Many of us rely on Armbian Debian and Ubuntu images for our cheap Arm development boards since they usually offer better support than vendor supplied firmware images. The community has just updated... [Only registered and activated users can see links. Click Here To Register...]
Android Things 1.0 Released with Support for NXP i.MX 8M, Qualcomm SDA212/SDA624 and Mediatek MT8516 SoMs
Brillo Project was renamed to Android Things with the release of a developer preview back in December 2014, and the operating system enabling developers and companies to build and maintain Internet... [Only registered and activated users can see links. Click Here To Register...]
If you’re a RISC-V architecture’s enthusiast or represent a company working on products with the new ISA, you may have spent $999 or more on Hifive Unleashed RISC-V Linux development... [Only registered and activated users can see links. Click Here To Register...]
Stanislav needed a Gigabit Ethernet router to run OpenVPN, and after some research he settled on Ubiquiti EdgeRouter X router with 5 Gigabit Ethernet ports, PoE in and pass-through, with a decent 256... [Only registered and activated users can see links. Click Here To Register...]
Hardkernel released their first Samsung Exynos 5422 octa-core board in July 2014 with ODROID-XU3, which at the time was really a powerful board, but also pricey at $179. Later that year, the company... [Only registered and activated users can see links. Click Here To Register...]
Allwinner A20 dual core Cortex A7 processor was/is one of the most popular Allwinner SoCs thanks to its low cost, the availability of interfaces such as SATA, Gigabit Ethernet, HDMI 1.4, and... [Only registered and activated users can see links. Click Here To Register...]
Standalone / All-in-One Android virtual reality headsets have been around for a couple of years, mostly from Chinese vendors. But the number and quality of VR apps available were rather low at the... [Only registered and activated users can see links. Click Here To Register...]
After their first Raspberry Pi Compute Module 3 based board called CM3-Home designed for home automation, Acme Systems has designed a new RPi CM3 carrier board called CM3-PANEL for panel PCs /... [Only registered and activated users can see links. Click Here To Register...]
UP board is a low cost development board powered by an Intel Atom x5-Z8350 Cherry Trail processor with 1GB to 4GB RAM, and 16 to 64GB eMMC flash that mostly follows Raspberry Pi 3 form factor. AAEON... [Only registered and activated users can see links. Click Here To Register...]
XH-M452 is a board designed to control the temperature and humidity in a room or cabinet. It comes with two relays to control appliances like fans, air conditioners, (de-)humidifiers, or heaters, and... [Only registered and activated users can see links. Click Here To Register...]
NXP Semiconductors has been working on a high-end communication processor with their QorIQ LayerScape LX2160A SoC equipped with 16 Arm Cortex A72 cores, 16 Ethernet ports supporting 1 to 100 Gbit/s,... [Only registered and activated users can see links. Click Here To Register...]
Armv8 and Armv8-M processor already support Arm TrustZone security, which aims to prevent software attacks against the target device. However, if a hacker has physical access to the hardware, it may... [Only registered and activated users can see links. Click Here To Register...]
Chengdu Ebyte Electronic Technology Ltd (or just Ebyte for short) is a company based in Western China that design and manufacturer low cost wireless modules for LoRa, WiFi, Bluetooth, Zigbee, NB-IoT... [Only registered and activated users can see links. Click Here To Register...]
Ubuntu 18.04 “Bionic Beaver” LTS operating system was released just last week, and at least two Arm board companies have independently released Ubuntu 18.04 images for their boards.... [Only registered and activated users can see links. Click Here To Register...]
Fairwaves is a startup that aims to make deploying and operating mobile networks in rural regions profitable, and their latest project is called XTRX, a high performance Software Defined Radio (SDR)... [Only registered and activated users can see links. Click Here To Register...]
Sens’it Discovery is a Sigfox IoT Solution with 6 Sensors
Sigfox has just launched Sens’it Discovery, which they describe as a “end-to-end IoT solution, which aims to accelerate the adoption of the IoT (Internet of things) among business and...[Only registered and activated users can see links. Click Here To Register...]
Intel NUC Kit NUC7PJYH Review – An Intel Gemini Lake Pentium Silver J5005 Barebone Mini PC
When Intel released their latest NUC Gemini Lake mini PCs they prioritized cost over performance. As a result the processor they chose for the ‘Intel NUC 7 Essential’ mini PC is somewhat...[Only registered and activated users can see links. Click Here To Register...]
AsteroidOS 1.0 Released – An Open Source Linux OS for Wear OS Smartwatches
We first discovered AsteroidOS, a Linux based open source operating system working on some Android Wear (now Wear OS by Google) smartwatches, in early 2016 while looking at FOSDEM 2016 schedule. The...[Only registered and activated users can see links. Click Here To Register...]
YC-CDA19Q is an 8-Port Quick Charge 3.0 Capable USB Charger with a Display Showing Power Consumption
USB charger doctor is a cheap and easy way to monitor the voltage and current from a USB 2.0 port or charger, but you may have more than one device to monitor, and USB 3.0 type C ports as well as...[Only registered and activated users can see links. Click Here To Register...]
Wi-Fi EasyMesh is a Standard for WiFi Mesh Networking
It’s been possible for add multiple WiFi routers and/or WiFi repeaters in order to provide good coverage in a house / building for years, so this required some manual configuration. So in...[Only registered and activated users can see links. Click Here To Register...]
Alfawise T1 Mini PC Powered by Intel Celeron N4100 Gemini Lake Processor is Going for $200
It’s been a long wait, but it appears it’s now possible to purchase Gemini Lake mini PCs and get them shipped within a few days. One example would be Alfawise T1 mini PC based on Intel...[Only registered and activated users can see links. Click Here To Register...]
MT3620 Development Board for Azure Sphere is Up for Pre-order for $84.90
Microsoft unveiled Azure Sphere solutions last month in order to provide a complete secure IoT solution from the hardware to the cloud with three main components: a secure MCU, Linux based Azure...[Only registered and activated users can see links. Click Here To Register...]
ULEWELL Z28 MINI is a $40 RK3328 TV Stick with 2GB RAM, 16GB Storage, and a USB 3.0 Port
While we’ve already covered many Rockchip RK3328 TV boxes and development boards, if you want a TV stick form factor the choice becomes much more limited. So far I was only aware of Rikomagic...[Only registered and activated users can see links. Click Here To Register...]
Arduino Introduces Two New IoT Boards – MKR WiFi 1010 (ESP32) and MKR NB 1500 (NB-IoT + eMTC)
Arduino introduced its MKR family of breadboard compatible maker boards with MKR1000 featuring an Atmel SAMD21 microcontroller combined with a Microchip WINC1500 WiFi module. The board was followed...[Only registered and activated users can see links. Click Here To Register...]
Running out of RAM in Ubuntu? Enable ZRAM
Whenever I ran out of RAM on a Linux system, I used to enable swap memory using the storage device to provide an extra bit of memory. The main advantage is that it’s does not require extra...[Only registered and activated users can see links. Click Here To Register...]
How to Run Chrome OS in Android Emulator
While it’s possible to run the open source Chromium OS in your computer or a virtual machine, AFAIK there was only was way to test Chrome OS: purchasing an actual Chromebook, or other device...[Only registered and activated users can see links. Click Here To Register...]
NeTV2 Open Video Development Board Works with Encrypted and Unencrypted Video Streams (Crowdfunding)
Chumby NeTV was an open source hardware Linux IPTV media player based on a Xilinx Spartan FPGA and a Marvell Armada 166 processor, and unveiled in 2011. Many years have passed since then, and now...[Only registered and activated users can see links. Click Here To Register...]
Astro Design HDMI Test Equipment Supports 8K @ 120 Hz
8K media players and 8K TVs are coming, but if you develop one of those products how do you test them since 8K players/TVs are not available just yet. Answer: Test equipment. Astro Design offers just...[Only registered and activated users can see links. Click Here To Register...]
Lenovo IdeaPad 330 Gemini Lake Laptops Sell for $250 and Up
We’ve previously seen companies unveil Gemini Lake laptops but at price points ($400 to $600) that did not seem right, considering Gemini Lake (GLK) processors should cost about the same as the...[Only registered and activated users can see links. Click Here To Register...]
Newport GW6400/GW6404 Arm SBC Comes with 5 Gigabit Ethernet Ports, 2 SFP Fiber Ports, and 4 mPCIe Sockets
Gateworks introduced their Newport SBC family based on Cavium Octeon TX Dual/Quad Core Arm processors at the end of last year, and the company has now announced the availability of the higher end...[Only registered and activated users can see links. Click Here To Register...]
Google has released the second developer preview of Wear OS by Google – previously known as Android Wear – that adds support for Actions on Google (AoG) and power-related enhancements...[Only registered and activated users can see links. Click Here To Register...]
Toradex Apalis iMX8 is another system-on-module powered by NXP i.MX 8QuadMax hexa core Arm Cortex A72 + 53 processor, which comes with 4GB LPDDR4 RAM, up to 16GB flash, and an on-board dual-band...[Only registered and activated users can see links. Click Here To Register...]
Hey Karl here. I thought I would try and showcase some GitHub projects that I run into that seem interesting or fun. This week I will start out with 2 projects. Zigbee to MQTT bridge The first one...[Only registered and activated users can see links. Click Here To Register...]
The Vorke V5? Plus?? mini PC? just goes to show how initial impressions can be very misleading. Arriving in a plain manila-coloured box with the protection film on the top of the ?device starting to...[Only registered and activated users can see links. Click Here To Register...]
Kinect started as as motion sensing input device for Xbox 360 & One game consoles with an integrated webcam, infrared projector, and a microphone array, which enabled it to detect depth, motion,...[Only registered and activated users can see links. Click Here To Register...]
We’ve already seen announcements about Android P and Android Things 1.0 for Google I/O 2018, but the company also took the opportunity to provide an update to the new features coming to Google...[Only registered and activated users can see links. Click Here To Register...]
Last March, Google released Android P developer preview with new features such as indoor positioning with WiFi RTT, support for display notch, HDR VP9, HEIF image compression, a new API to access two...[Only registered and activated users can see links. Click Here To Register...]
Around 2 years ago, I reviewed GOLE1 mini PC running Windows 10 and Android 5.1, powered by an Intel Atom x5-Z8300 Cherry Trail processor with 4GB RAM and 64GB SSD. It also came with a 5″...[Only registered and activated users can see links. Click Here To Register...]
Many of us rely on Armbian Debian and Ubuntu images for our cheap Arm development boards since they usually offer better support than vendor supplied firmware images. The community has just updated...[Only registered and activated users can see links. Click Here To Register...]
Brillo Project was renamed to Android Things with the release of a developer preview back in December 2014, and the operating system enabling developers and companies to build and maintain Internet...[Only registered and activated users can see links. Click Here To Register...]
Arduino Unveils its First FPGA Board with MKR Vidor 4000, Updates UNO
Arduino has been busy with new boards announcements in the last week, as after introducing MKR WiFi 1010 and MKR NB 1500 IoT boards with respectively WiFi + Bluetooth, and NB-IoT + eMTC connectivity,... [Only registered and activated users can see links. Click Here To Register...]
R-TV BOX S10+ is an Android 8.1 TV Box with a Built-in Qi Wireless Charger
A couple of years ago we wrote about ECS Live Station, an Intel Bay Trail mini PC with an integrated wireless charger that can be used to charge any compatible smartphone. But as I was checking out... [Only registered and activated users can see links. Click Here To Register...]
Spreadtrum SC9863 Octa-core Cortex A55 Processor is Made for LTE Smartphones
Arm unveiled Cortex A55 cores about a year ago, and while we have seen the new cores combined with Cortex 75-class cores in premium smartphone processors such as Exynos 9810 SoC, I had yet to see a... [Only registered and activated users can see links. Click Here To Register...]
UMIDIGI Z2 Pro is one of the first Smartphones based on MediaTek Helio P60 SoC
MediaTek unveiled Helio P60 Cortex A73/A53 processor with AI HW acceleration a few months ago, and we were promised smartphones would start selling in Q2 2018. Mediatek’s partners seem to be... [Only registered and activated users can see links. Click Here To Register...]
HP t430 Thin client Works with a Single USB Cable
Gemini Lake mini PCs are starting to sell and ship, and from the look of it, HP t430 appears to be yet another Gemini Lake mini PC based on an Intel Celeron N4000 processor. But the device is... [Only registered and activated users can see links. Click Here To Register...]
Hexabitz Modular Prototyping Platform Enables Wire-Free 3D Electronics Designs (Crowdfunding)
A few years ago, I made a Raspberry Pi case made of perfboard and created some sort of DIY modular 3D electronics design by using the top and sides of the case to also hold electronics components and... [Only registered and activated users can see links. Click Here To Register...]
Pi-Hole Kit is a Raspberry Pi based Ad Blocker
If you don’t like getting tracked or see ads, it’s normally easy enough to install an ad blocker plugin in your web browser. But if you want to save some resources on your computer(s)... [Only registered and activated users can see links. Click Here To Register...]
96Boards GPS Mezzanine is the First Add-on Board part of 96boards Community Mezzanine Initiative (Group Buy)
96Boards hardware development platforms support add-on boards called Mezzanines, and you’ll find a bunch of them on 96Boards website. Most are designed and manufactured by companies, but in... [Only registered and activated users can see links. Click Here To Register...]
XU4Q Retro Gaming System Runs ODROID GameStation Turbo, Sells for $150 and Up
One of the use case for little Arm Linux boards is retro gaming thanks to open source projects like RetroPie, RetrOrangePi, Lakka, and others. To get a complete & usable system, it’s... [Only registered and activated users can see links. Click Here To Register...]
When Intel released their latest NUC Gemini Lake mini PCs they prioritized cost over performance. As a result the processor they chose for the ‘Intel NUC 7 Essential’ mini PC is somewhat... [Only registered and activated users can see links. Click Here To Register...]
We first discovered AsteroidOS, a Linux based open source operating system working on some Android Wear (now Wear OS by Google) smartwatches, in early 2016 while looking at FOSDEM 2016 schedule. The... [Only registered and activated users can see links. Click Here To Register...]
USB charger doctor is a cheap and easy way to monitor the voltage and current from a USB 2.0 port or charger, but you may have more than one device to monitor, and USB 3.0 type C ports as well as... [Only registered and activated users can see links. Click Here To Register...]
It’s been possible for add multiple WiFi routers and/or WiFi repeaters in order to provide good coverage in a house / building for years, so this required some manual configuration. So in... [Only registered and activated users can see links. Click Here To Register...]
It’s been a long wait, but it appears it’s now possible to purchase Gemini Lake mini PCs and get them shipped within a few days. One example would be Alfawise T1 mini PC based on Intel... [Only registered and activated users can see links. Click Here To Register...]
Microsoft unveiled Azure Sphere solutions last month in order to provide a complete secure IoT solution from the hardware to the cloud with three main components: a secure MCU, Linux based Azure... [Only registered and activated users can see links. Click Here To Register...]
While we’ve already covered many Rockchip RK3328 TV boxes and development boards, if you want a TV stick form factor the choice becomes much more limited. So far I was only aware of Rikomagic... [Only registered and activated users can see links. Click Here To Register...]
Arduino introduced its MKR family of breadboard compatible maker boards with MKR1000 featuring an Atmel SAMD21 microcontroller combined with a Microchip WINC1500 WiFi module. The board was followed... [Only registered and activated users can see links. Click Here To Register...]
Whenever I ran out of RAM on a Linux system, I used to enable swap memory using the storage device to provide an extra bit of memory. The main advantage is that it’s does not require extra... [Only registered and activated users can see links. Click Here To Register...]
Chumby NeTV was an open source hardware Linux IPTV media player based on a Xilinx Spartan FPGA and a Marvell Armada 166 processor, and unveiled in 2011. Many years have passed since then, and now... [Only registered and activated users can see links. Click Here To Register...]
8K media players and 8K TVs are coming, but if you develop one of those products how do you test them since 8K players/TVs are not available just yet. Answer: Test equipment. Astro Design offers just... [Only registered and activated users can see links. Click Here To Register...]
RAK833 is an Industrial Grade mini PCIe LoRaWAN Gateway Card
The most obvious way to setup your own LoRAWAN network is to get an off-the-shelf Gateway such as MatchBox, which can be easily installed, and configured using the built-in web interface. But if you... [Only registered and activated users can see links. Click Here To Register...]
Dragino NB-IoT Bee is a $23 Xbee Compatible NB-IoT Add-on Board
Several companies are already offering XBee NB-IoT add-on board including Digi International themselves, and SODAQ with their NB-IoT Bee N211 module going for 69 Euros. Dragino NB-IoT Bee is another... [Only registered and activated users can see links. Click Here To Register...]
Circumference Datacentre-in-a-Box Features up to 32 Raspberry Pi 3 B+ Managed by a UDOO x86 Ultra Board (Crowdfunding)
We’ve previously seen several clusters made of Raspberry Pi boards with a 16 RPi Zero cluster prototype, or BitScope Blade with 40 Raspberry Pi boards. The latter now even offers solutions for... [Only registered and activated users can see links. Click Here To Register...]
Sonoff S26 WiFi Smart Plug Works in All/Most Countries, Sells for under $10
One recurring issue with smart plugs / sockets is that they are often designed with a specific prong type, so if you want to use them in our country you may have to add an adapter, which may not be... [Only registered and activated users can see links. Click Here To Register...]
ESP32-Sense Kit Lets You Experiment with ESP32 Touch Interface
Beside support for Bluetooth, one the other extra benefits of Espressif ESP32 over ESP8266 is the presence of a touch interface in the newer processor. If you are interested in that specific... [Only registered and activated users can see links. Click Here To Register...]
ZiP (zGlue Integration Platform) Enables the Design & Manufacturing of Low Cost Custom Chips
When I first started to read about zOrigin on Crowdsupply, I was not really impressed. Meh… Yet another Bluetooth LE fitness tracker with a few sensors, and an Android app. But as I read... [Only registered and activated users can see links. Click Here To Register...]
Khadas Tone High Resolution Audio Board is Designed for Khadas VIM/VIM
Khadas VIM and Khadas VIM2 are development boards powered respectively by Amlogic S905x and S912 processors that come with decent software support. The company also provides application specific...[Only registered and activated users can see links. Click Here To Register...]
Xiaomi Mi Router 4 is a $60 AC1200 Router with Three Gigabit Ethernet Ports
Xiaomi Mi Router 3 AC1200 router based on Mediatek MT7620A processor was launched in 2016 for just under $40 on online retailers. It had at least one caveat however, since it only supported Fast...[Only registered and activated users can see links. Click Here To Register...]
Android 8.1 Firmware and SDK Released for Orange Pi 4G-IoT Board
When Orange Pi 4G-IoT board launched a few months ago, it shipped with a not so recent Android 6.0 operating system. But the good news is that Shenzhen Xunlong Software has now released Android 8.1...[Only registered and activated users can see links. Click Here To Register...]
Beelink S2 Gemini Lake Mini PC Comes with an Intel Pentium N5000 Silver Processor, 8GB RAM, a 128GB SSD
I’ve written about Beelink S2 mini PC based on Intel Celeron N4100 Gemini Lake processor several times, simply because the motherboard appears to be used in other OEM models including Alfawise...[Only registered and activated users can see links. Click Here To Register...]
ESP8266 based ANAVI Light Controller can be Programmed with Home Assistant or the Arduino IDE (Crowdfunding)
ANAVI Technology previously launched a Light pHAT allowing for RGB Light strip connection to Raspberry Pi boards, and during my review of ANAVI Light pHAT with Raspberry Pi 2, it did the job, but if...[Only registered and activated users can see links. Click Here To Register...]
Qualcomm Snapdragon 710 Brings AI To Mid-Range Smartphones
Neural processing units (NPU) – also called Neural network accelerators (NNA) – can now be found in all premium smartphone SoCs in order to assist with artificial intelligence...[Only registered and activated users can see links. Click Here To Register...]
FriendlyELEC Launches a Rockchip RK3399 SBC for $129. Meet NanoPC-T4
Earlier this year, we have a number of SBCs based on Rockchip RK3399 hexa-core processor from Orange Pi RK3399 to ODROID-N1, or Pine64 RockPro64 boards. FriendlyELEC has joined the fray with their...[Only registered and activated users can see links. Click Here To Register...]
A Closer Look at Mediatek MT8516 Cortex A35 SoM / Devkit for Android Things
Earlier this month, Google released Android Things 1.0, the first stable release for the IoT operating system, and announced several certified SoMs (systems-on-module) based on NXP i.MX 8M, Qualcomm...[Only registered and activated users can see links. Click Here To Register...]
$240 CHUWI GBox Mini PC Offers HDMI and VGA Outputs, a Quad Core Gemini Lake Processor
Another day, another Gemini Lake mini PC, with CHUWI GBox which has just been listed on GearBest for pre-order for $239.99 plus shipping. The device features Intel Celeron N4100 quad core processor,...[Only registered and activated users can see links. Click Here To Register...]
MediaTek Helio P22 SoC for “Mid Range Premium” Smartphones Relies on 12nm Manufacturing Process
MediaTek already has plenty of Arm Cortex A53 processors in their portfolio, but with MediaTek Helio P22 they’ve now added another one. One of the selling point of the new processor is that it...[Only registered and activated users can see links. Click Here To Register...]
Several companies are already offering XBee NB-IoT add-on board including Digi International themselves, and SODAQ with their NB-IoT Bee N211 module going for 69 Euros. Dragino NB-IoT Bee is another...[Only registered and activated users can see links. Click Here To Register...]
We’ve previously seen several clusters made of Raspberry Pi boards with a 16 RPi Zero cluster prototype, or BitScope Blade with 40 Raspberry Pi boards. The latter now even offers solutions for...[Only registered and activated users can see links. Click Here To Register...]
One recurring issue with smart plugs / sockets is that they are often designed with a specific prong type, so if you want to use them in our country you may have to add an adapter, which may not be...[Only registered and activated users can see links. Click Here To Register...]
Beside support for Bluetooth, one the other extra benefits of Espressif ESP32 over ESP8266 is the presence of a touch interface in the newer processor. If you are interested in that specific...[Only registered and activated users can see links. Click Here To Register...]
When I first started to read about zOrigin on Crowdsupply, I was not really impressed. Meh… Yet another Bluetooth LE fitness tracker with a few sensors, and an Android app. But as I read...[Only registered and activated users can see links. Click Here To Register...]
A couple of years ago we wrote about ECS Live Station, an Intel Bay Trail mini PC with an integrated wireless charger that can be used to charge any compatible smartphone. But as I was checking out...[Only registered and activated users can see links. Click Here To Register...]
Arm unveiled Cortex A55 cores about a year ago, and while we have seen the new cores combined with Cortex 75-class cores in premium smartphone processors such as Exynos 9810 SoC, I had yet to see a...[Only registered and activated users can see links. Click Here To Register...]
MediaTek unveiled Helio P60 Cortex A73/A53 processor with AI HW acceleration a few months ago, and we were promised smartphones would start selling in Q2 2018. Mediatek’s partners seem to be...[Only registered and activated users can see links. Click Here To Register...]
Gemini Lake mini PCs are starting to sell and ship, and from the look of it, HP t430 appears to be yet another Gemini Lake mini PC based on an Intel Celeron N4000 processor. But the device is...[Only registered and activated users can see links. Click Here To Register...]
If you don’t like getting tracked or see ads, it’s normally easy enough to install an ad blocker plugin in your web browser. But if you want to save some resources on your computer(s)...[Only registered and activated users can see links. Click Here To Register...]
