AMD Announces the $999 Radeon RX 7900 XTX and $899 RX 7900 XT, 5nm RDN
AMD today announced the Radeon RX 7900 XTX and Radeon RX 7900 XT gaming graphics cards debuting its next-generation RDNA3 graphics architecture. The two new cards come at $999 and $899—basically targeting the $1000 high-end premium price point.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3EFWSr9rU8EjNvN9.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/3EFWSr9rU8EjNvN9_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/N7seRAG9KrIlaNCY.jpg" target="_blank" data-width="1802" data-height="1029" ><img src="https://tpucdn.com/img/N7seRAG9KrIlaNCY_thm.jpg" width="228" height="130" alt="" /></a> </div>Both cards will be available on December 13th, not only the AMD reference design, which is sold through AMD.com, but also custom-design variants from the many board partners on the same day. AIBs are expected to announce their products in the coming weeks.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4dZf1DS0cksNlv4H.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/4dZf1DS0cksNlv4H_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JHEVl1yVmAYiNMbY.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/JHEVl1yVmAYiNMbY_thm.jpg" width="231" height="130" alt="" /></a><br />
</div>The RX 7900 XTX is priced at USD $999, and the RX 7900 XT is $899, which is a surprisingly small difference of only $100, for a performance difference that will certainly be larger, probably in the 20% range. Both Radeon RX 7900 XTX and RX 7900 XT are using the PCI-Express 4.0 interface, Gen 5 is not supported with this generation. The RX 7900 XTX has a typical board power of 355 W, or about 95 W less than that of the GeForce RTX 4090. The reference-design RX 7900 XTX uses conventional 8-pin PCIe power connectors, as would custom-design cards, when they come out. AMD's board partners will create units with three 8-pin power connectors, for higher out of the box performance and better OC potential. The decision to not use the 16-pin power connector that NVIDIA uses was made "well over a year ago", mostly because of cost, complexity and the fact that these Radeons don't require that much power anyway.<div class="readmore"><a href="https://www.techpowerup.com/300632/amd-announces-the-usd-999-radeon-rx-7900-xtx-and-usd-899-rx-7900-xt-5nm-rdna3-displayport-2-1-fsr-3-0-fluidmotion">Read full story</a></div>
AMD Radeon RDNA3 Graphics Launch Event Live-blog: RX 7000 Series, Next-Generation Performance
AMD today is expected to launch its next-generation RDNA3 graphics architecture and next-generation Radeon RX 7000-series graphics cards, along with new gaming technologies as part of the company's "together we advance_gaming" event, unfurled by CEO Dr Lisa Su. In this live-blog we track the various announcements made in the event.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/pSvB0oO9EVjBzgZ8.jpg" target="_blank" data-width="1306" data-height="770" ><img src="https://tpucdn.com/img/pSvB0oO9EVjBzgZ8_thm.jpg" width="220" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rFgCsTGjD2d6OnJ8.jpg" target="_blank" data-width="1851" data-height="848" ><img src="https://tpucdn.com/img/rFgCsTGjD2d6OnJ8_thm.jpg" width="284" height="130" alt="" /></a> </div><b>20:01 UTC</b>: AMD's roadmap is supremely busy:<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CISjjt82lxd6BLeV.jpg" target="_blank" data-width="1963" data-height="1006" ><img src="https://tpucdn.com/img/CISjjt82lxd6BLeV_thm.jpg" width="254" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/q3nzYEPPPCoRMGaf.jpg" target="_blank" data-width="2047" data-height="950" ><img src="https://tpucdn.com/img/q3nzYEPPPCoRMGaf_thm.jpg" width="280" height="130" alt="" /></a> </div><b>20:02 UTC</b>: "today it's all about gaming"<div class="readmore"><a href="https://www.techpowerup.com/300634/amd-radeon-rdna3-graphics-launch-event-live-blog-rx-7000-series-next-generation-performance">Read full story</a></div>
AMD Navi 31 RDNA3 GPU Pictured
Here's the first picture of the "Navi 31" GPU at the heart of AMD's fastest next-generation graphics cards. Based on the RDNA3 graphics architecture, this will mark an ambitious attempt by AMD to build the first multi-chip module (MCM) client GPU featuring more than one logic die. MCM GPUs aren't new in the enterprise space with Intel's "Ponte Vecchio," but this would be the first such GPU meant for hardcore gaming graphics products. AMD had made MCM GPUs in the past, but those have been packages with just one logic die, surrounded by memory stacks. "Navi 31" is an MCM of as many as eight logic dies, and no memory stacks (no, those aren't HBM stacks in the picture below).<br />
<br />
It's rumored that "Navi 31" features one or two SIMD chiplets dubbed GCDs, featuring the GPU's main number crunching machinery, the RDNA3 compute units. These chiplets are likely built on the most advanced silicon fabrication node, likely TSMC 5 nm EUV, but we'll see. The GDDR6 memory controllers handling the chip's 384-bit wide GDDR6 memory interface, will be located on separate chiplets built on a slightly older node, such as TSMC 6 nm. This is not multi-GPU-a-stick, because both SIMD chiplets have uniform access to the entire 384-bit wide memory bus (which is not 2x 192-bit but 1x 384-bit), besides the other ancillaries. The "Navi 31" MCM are expected to be surrounded by JEDEC-standard 20 Gbps GDDR6 memory chips.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/WEXnAVicShYwpjo7.jpg" target="_blank" data-width="551" data-height="476" ><img src="https://tpucdn.com/img/WEXnAVicShYwpjo7_thm.jpg" width="150" height="130" alt="" /></a></div>
(PR) Comino Launches a GPU Waterblock for Gigabyte's GeForce RTX 4090 SKUs
The innovative manufacturer of high-end multi-GPU workstations and professional liquid cooling solutions for individuals and workgroups requiring GPU computation, announces a slim waterblock of top-tier efficiency for GIGABYTE GeForce RTX 4090 GAMING OC 24 GB and AORUS RTX 4090 MASTER 24G GPUs.<br />
<br />
Given the fact that the latest 4090 GPUs by Nvidia are extremely power hungry, the Comino team did its best to deliver the highest performance 4090 waterblock design, specifically adding:<div class="imgcontainer"><a href="https://www.techpowerup.com/img/7WsMNtTEX18TQjKV.jpg" target="_blank" data-width="1536" data-height="960" ><img src="https://tpucdn.com/img/7WsMNtTEX18TQjKV_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8kWPoEvRE0B84Ao8.jpg" target="_blank" data-width="1536" data-height="960" ><img src="https://tpucdn.com/img/8kWPoEvRE0B84Ao8_thm.jpg" width="208" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5hzwIzfv4vdGOK8C.jpg" target="_blank" data-width="1536" data-height="960" ><img src="https://tpucdn.com/img/5hzwIzfv4vdGOK8C_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300624/comino-launches-a-gpu-waterblock-for-gigabytes-geforce-rtx-4090-skus">Read full story</a></div>
(PR) Alphacool Unveils New Liquid Cooling Sets
With Core Storm and Core Wind, Alphacool offers new complete water cooling kits that include all components for building a performance-oriented CPU cooling system. With the included mounting hardware, the CPU cooler is compatible with popular mainstream sockets from AMD and Intel. Even AMD's newest AM5 socket can be water-cooled with the Core Wind or Core Storm sets without any difficulties.<br />
<br />
The sets are not only aimed at beginners, but also at enthusiasts. The selected components are optimally matched and come from Alphacool's DIY program. Thanks to the included quick-connect coupling, the loop can be easily expanded with additional components such as radiators, GPU coolers or sensors without having to drain or rebuild the water loop.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ttp3i5G0Il487BIl.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/ttp3i5G0Il487BIl_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/weIDkAe2vsO46Fl7.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/weIDkAe2vsO46Fl7_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9rEhZs0R1d1ds4YE.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/9rEhZs0R1d1ds4YE_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3vzmt8DU79nfARzO.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/3vzmt8DU79nfARzO_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HlyxvV86xiWGJPod.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/HlyxvV86xiWGJPod_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300617/alphacool-unveils-new-liquid-cooling-sets">Read full story</a></div>
Arctic Unveils the MX-6 High Performance Thermal Compound
Arctic today unveiled the MX-6 thermal-compound. The incoming MX-6 replaces MX-5 from the shelves, which is now EOL, but retails alongside the MX-4, Arctic's best-selling TIM. The new MX-6 is a high-viscosity, non-conductive, non-capacitive thermal paste which doesn't corrode pure copper. It is suitable for processor IHS, exposed dies (such as GPUs), or even ceramic packages (such as DRAM chips). <br />
<br />
The Arctic MX-6 has a viscosity of 550 poise, density of 3.2 g/cm³, 1.9 X 1013 Ω-cm, and a breakdown voltage of 250 V/mil. Each application can stay in place for 8 years (maintain conductivity and viscosity). The company didn't mention chemical composition or conductivity figures, yet. It comes in syringe-type dispensers of 2 g, 4 g, and 8 g, as well as a bundle of a 4 g dispenser with six MX Cleaner wipes. The MX-6 is available from now, priced at USD $6.79 for the 2 g syringe, $8.49 for the 4 g syringe, $9.79 for the 4 g syringe and 6 pieces of MX Cleaner wipes; and $11.99 for the 8 g syringe. These are introductory prices.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/y6cyLSJ8DCQEx5si.jpg" target="_blank" data-width="1067" data-height="412" ><img src="https://tpucdn.com/img/y6cyLSJ8DCQEx5si_thm.jpg" width="337" height="130" alt="" /></a></div>
(PR) Andes Technology Unveils The AndesCore AX60 Series, An Out-Of-Order Superscalar Multicore RISC-V Processor Family
Today, at Linley Fall Processor Conference 2022, Andes Technology, a leading provider of high efficiency, low power 32/64-bit RISC-V processor cores and founding premier member of RISC-V International, reveals its top-of-the-line AndesCore AX60 series of power and area efficient out-of-order 64-bit processors. The family of processors are intended to run heavy-duty OS and applications with compute intensive requirements such as advanced driver-assistance systems (ADAS), artificial intelligence (AI), augmented/virtual reality (AR/VR), datacenter accelerators, 5G infrastructure, high-speed networking, and enterprise storage.<br />
<br />
The first member of the AX60 series, the AX65, supports the latest RISC-V architecture extensions such as the scalar cryptography extension and bit manipulation extension. It is a 4-way superscalar with Out-of-Order (OoO) execution in a 13-stage pipeline. It fetches 4 to 8 instructions per cycle guided by highly accurate TAGE branch predictor with loop prediction to ensure fetch efficiency. It then decodes, renames and dispatches up to 4 instructions into 8 execution units, including 4 integer units, 2 full load/store units, and 2 floating-point units. Besides the load/store units, the AX65's aggressive memory subsystem also includes split 2-level TLBs with multiple concurrent table walkers and up to 64 outstanding load/store instructions.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Yup6DlgjiBrpY3eT.jpg" target="_blank" data-width="768" data-height="432" ><img src="https://tpucdn.com/img/Yup6DlgjiBrpY3eT_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300615/andes-technology-unveils-the-andescore-ax60-series-an-out-of-order-superscalar-multicore-risc-v-processor-family">Read full story</a></div>
(PR) The Legendary Dwarf Fortress Gets a Whole New Look on December 6t
After years of hard work, developer Bay 12 Games and publisher Kitfox Games are thrilled to announce that the highly anticipated, and newly inviting Steam and Itch.io PC release of the fabled Dwarf Fortress will release on December 6 for $29.99 USD! Originally released by brothers Tarn and Zach Adams in 2006, this new version of Dwarf Fortress reimagines the deeply intricate, dwarven civilization management and construction game beyond its ASCII character presentation with a brand new pixel art tileset, a new helpful tutorial to onboard unfamiliar players, new soundtrack and sound effects, new user interface and navigable menus, and other quality of life additions. <br />
<br />
These new additions make this version of Dwarf Fortress the most approachable it has ever been, while still maintaining the beloved core experience and complex simulation that has made it popular for so many years. The classic version of Dwarf Fortress will remain available for download at no cost, and will continue to be supported, on Bay 12's website.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/MicUB1hNcIr4jrv1.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/MicUB1hNcIr4jrv1_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/K0rIdZNF4XgY5YZN.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/K0rIdZNF4XgY5YZN_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Bosqhp3vrBV1Lits.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/Bosqhp3vrBV1Lits_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/y2ylp9etQBh7NbRL.jpg" target="_blank" data-width="1920" data-height="996" ><img src="https://tpucdn.com/img/y2ylp9etQBh7NbRL_thm.jpg" width="251" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300614/the-legendary-dwarf-fortress-gets-a-whole-new-look-on-december-6th">Read full story</a></div>
AMD Discounts the Ryzen 5000-series on its Official US Web Store, Ryzen 7 5800X3D Goes for US$329
AMD has dropped the price on most of its Ryzen 5000-series CPUs on its official web store and some models have been discounted by as much as US$250 over the MSRP. However, the most interesting discount here might be the Ryzen 7 5800X3D, which has been discounted from US$449 to US$329, which makes it a pretty good deal for anyone considering getting what is one of the best CPUs out there for gaming. <br />
<br />
Unfortunately, AMD's discounted deal appears to have been very popular and as such the Ryzen 7 5800X3D is currently sold out. It's unclear if AMD will add more stock at the same price point, but what is clear is that the Ryzen 7 5800X3D is a popular CPU, especially at what now appears to be the right price point. As mentioned, AMD has discounted its entire lineup of Ryzen 5000-series CPUs, so if you've been on the fence whether to upgrade or not, now might be a good time to do so. That said, most online retailers appear to be offering the same CPUs at the same, or at least almost the same price, making the Ryzen 7 5800X3D the only real bargain to be had, if it comes back in stock. Unfortunately, AMD hasn't discounted its CPUs in other regions, so if you're outside of the US, you're not going to see any special deals if you visit the AMD web store.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/pElfeQUBgiOi5Wy1.jpg" target="_blank" data-width="1443" data-height="1473" ><img src="https://tpucdn.com/img/pElfeQUBgiOi5Wy1_thm.jpg" width="127" height="130" alt="" /></a></div>
(PR) BenQ Unveils 240Hz MOBIUZ Monitors for Dynamic and Immersive Gami
BenQ, a global leader in display technology, announced today its newest MOBIUZ gaming monitors, the EX270M and the EX270QM, which were unveiled at PAX West back in September. As the first 240 Hz monitors to join the MOBIUZ line of gaming monitors, the 27-inch monitors are packed with premium features for gamers including stunning colors and imagery, built-in 2.1 channel speakers from treVolo, HDRi intelligent optimization, and FreeSync Premium.<br />
<br />
For a fully immersive gaming experience, both monitors offer a wide color gamut, coupled with BenQ's exclusive HDRi technology which enhances color, contrast and detail display. The EX270M, an FHD monitor, covers 99% sRGB color space while the EX270QM, a QHD monitor, boasts 98% P3 and 1.07 billion color hues. Both monitors provide a smooth gaming experience unlike any other with beautiful visuals, 1 ms GtG, 240 Hz refresh rate, and FreeSync Premium.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/tgWB2z8eY3IkSLUq.jpg" target="_blank" data-width="1124" data-height="903" ><img src="https://tpucdn.com/img/tgWB2z8eY3IkSLUq_thm.jpg" width="162" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7zJkQDeVRtUZI9UI.jpg" target="_blank" data-width="1220" data-height="680" ><img src="https://tpucdn.com/img/7zJkQDeVRtUZI9UI_thm.jpg" width="233" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5NIIgiNVJn3z984t.jpg" target="_blank" data-width="1220" data-height="680" ><img src="https://tpucdn.com/img/5NIIgiNVJn3z984t_thm.jpg" width="233" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300861/benq-unveils-240hz-mobiuz-monitors-for-dynamic-and-immersive-gaming">Read full story</a></div>
GIGABYTE Launches GeForce RTX 4080 Series graphics cards
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of premium gaming hardware, the GIGABYTE GeForce RTX 4080 16 GB series graphics cards powered by NVIDIA Ada Lovelace architecture are going to be available for purchase on Nov 16. The new GeForce RTX 40 series GPUs have a quantum leap in performance, allowing gamers and content creators to enjoy ultra-high FPS gaming and improve the workflow efficiency. GIGABYTE provides both WATERFORCE and WINDFORCE thermal solutions for users, including AORUS XTREME water-cooled graphics cards, AORUS MASTER, GAMING OC, AERO OC, and EAGLE OC air-cooled graphics cards, which all meet the diverse requirements and needs.<br />
<br />
AORUS WATERFORCE WB is the top choice for those who wish to build open-loop liquid cooling systems. GIGABYTE specializes in thermal cooling solutions, providing optimal channel spacing between the micro fins for enhanced heat transfer from the GPU via stable water flows. The sunk-designed copper micro fins shorten the heat conduction path from the GPU, so that the heat can be transferred to the water channel area quickly. Moreover, with the patented "Leak detection" technology, the built-in leak detection circuit covers the entire fitting and water block and can promptly alert users by flashing lights at the first sign of a leak, so users can deal with the leakage early and prevent any further damage to the system. Both the front cover and the backplate of the graphics card support RGB lighting, allowing gamers to customize their own style through GIGABYTE CONTROL CENTER (GCC) software.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/shPME0uSdabe2URK.jpg" target="_blank" data-width="3185" data-height="1000" ><img src="https://tpucdn.com/img/shPME0uSdabe2URK_thm.jpg" width="414" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5CdRPnHyUYUIXkv8.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/5CdRPnHyUYUIXkv8_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/y0Irjp8OzA5cHTbV.jpg" target="_blank" data-width="2215" data-height="1000" ><img src="https://tpucdn.com/img/y0Irjp8OzA5cHTbV_thm.jpg" width="288" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300859/gigabyte-launches-geforce-rtx-4080-series-graphics-cards">Read full story</a></div>
(PR) Hewlett Packard Enterprise Brings HPE Cray EX and HPE Cray XD Supercomputers to Enterprise Customers
Hewlett Packard Enterprise (NYSE: HPE) today announced it is making supercomputing accessible for more enterprises to harness insights, solve problems and innovate faster by delivering its world-leading, energy-efficient supercomputers in a smaller form factor and at a lower price point.<br />
<br />
The expanded portfolio includes new HPE Cray EX and HPE Cray XD supercomputers, which are based on HPE's exascale innovation that delivers end-to-end, purpose-built technologies in compute, accelerated compute, interconnect, storage, software, and flexible power and cooling options. The supercomputers provide significant performance and AI-at-scale capabilities to tackle demanding, data-intensive workloads, speed up AI and machine learning initiatives, and accelerate innovation to deliver products and services to market faster.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3w9YquSg5WvgLdPR.jpg" target="_blank" data-width="1462" data-height="916" ><img src="https://tpucdn.com/img/3w9YquSg5WvgLdPR_thm.jpg" width="207" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300857/hewlett-packard-enterprise-brings-hpe-cray-ex-and-hpe-cray-xd-supercomputers-to-enterprise-customers">Read full story</a></div>
AMD Bundles Dead island 2 and The Callisto Protocol with Radeon RX 6000 Series
In a bid to clear inventory of its Radeon RX 6000 series RDNA2 graphics cards in the lead up to its next-generation, AMD is bundling two of the latest AAA game titles. Besides this, the company has significantly lowered prices of its RX 6000 series over several months now. The company is bundling "Dead island 2," and "The Callisto Protocol" with new purchases of Radeon RX 6000 graphics cards.<br />
<br />
New purchases of the Radeon RX 6600, RX 6600 XT, RX 6650 XT, RX 6700, RX 6700 XT, RX 6750 XT, RX 6800, RX 6800 XT, RX 6900 XT, and RX 6950 XT, will receive both games. New purchases of the RX 6500 XT and RX 6400 will receive just "Dead Island 2." The bundle is only available in select markets, and through participating retailers. Find where you can grab it, from the source link below.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XmPB2JIQMYNpIH6F.jpg" target="_blank" data-width="992" data-height="558" ><img src="https://tpucdn.com/img/XmPB2JIQMYNpIH6F_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) Eliyan Closes $40M Series A Funding Round and Unveils Industry's Highest Performance Chiplet Interconnect Technologies
Eliyan Corporation, credited for the invention of the semiconductor industry's highest-performance and most efficient chiplet interconnect, today announced two major milestones in the commercialization of its technology for multi-die chiplet integration: the close of its Series A $40M funding round, and the successful tapeout of its technology on an industry standard 5-nanometer (nm) process.<br />
<br />
Eliyan's NuLink PHY and NuGear technologies address the critical need for a commercially viable approach to enabling high performance and cost-effectiveness in the connection of homogeneous and heterogenous architectures on a standard, organic chip substrate. It has proven to achieve similar bandwidth, power efficiency, and latency as die-to-die implementations using advanced packaging technologies, but without the other drawbacks of specialized approaches.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FGcIUTV8iBBnlPU3.jpg" target="_blank" data-width="391" data-height="214" ><img src="https://tpucdn.com/img/FGcIUTV8iBBnlPU3_thm.jpg" width="238" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pll3nQQchQTGY8cP.jpg" target="_blank" data-width="600" data-height="341" ><img src="https://tpucdn.com/img/pll3nQQchQTGY8cP_thm.jpg" width="229" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300846/eliyan-closes-usd-40m-series-a-funding-round-and-unveils-industrys-highest-performance-chiplet-interconnect-technologies">Read full story</a></div>
(PR) Lexar Announces New 320GB Lexar Professional CFexpress Type A Card Gold Series
Lexar, a leading global brand of flash memory solutions, is proud to announce the new Lexar Professional CFexpress Type A Card GOLD Series in the 320 GB capacity. Ideal for professional creators, photographers, and videographers who want to capture high-quality images with superior read speed up to 900 MB/s. The 320 GB model will be bundled with the Lexar Professional CFexpress Type A / SD USB 3.2 Gen 2 Reader for a more seamless workflow from field to post-production.<br />
<br />
With read speed up to 900 MB/s and write speed up to 800 MB/s, Lexar Professional CFexpress Type A Card GOLD Series 320 GB is designed to seamlessly capture high-resolution images and cinema-quality 8K video. It is also ideal for professionals who need to handle demanding workflow on the go. Also, the Lexar Professional CFexpress Type A Card GOLD Series 320 GB allows professional creators to get back to business without having to constantly switch cards. And for added peace of mind, the card is also rated Video Performance Guarantee 400 (VPG 400) meeting a minimum write speed of 700 MB/s so your content is captured seamlessly without dropping a frame.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JyC7od0kYf5uLVId.jpg" target="_blank" data-width="1139" data-height="1000" ><img src="https://tpucdn.com/img/JyC7od0kYf5uLVId_thm.jpg" width="148" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EkHu0gCcXHQdPX5I.jpg" target="_blank" data-width="1066" data-height="1000" ><img src="https://tpucdn.com/img/EkHu0gCcXHQdPX5I_thm.jpg" width="139" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gSrKhXOonBFlpLyH.jpg" target="_blank" data-width="432" data-height="354" ><img src="https://tpucdn.com/img/gSrKhXOonBFlpLyH_thm.jpg" width="159" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yAfo9h1Uq754qzRy.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/yAfo9h1Uq754qzRy_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300844/lexar-announces-new-320gb-lexar-professional-cfexpress-type-a-card-gold-series">Read full story</a></div>
Diabolical New VR Headset is Designed to Kill its User IRL if Killed In-game
Oculus co-founder Palmer Luckey designed a new VR headset that adds the ultimate layer of realism to VR—mortality. Thought to be relegated to dystopian cyberpunk fiction, this new headset comes with the ability to literally kill its user if killed in-game. Its design involves an Oculus Quest Pro, with explosive charges strapped to the forehead, which activate when the headset receives a specific pattern of red color flashes from the game's display-head, to a photo receiver (typically the "Game Over" screen). There's already a game designed for this, "Sword Art Online." a medieval swordplay-based MMORPG, which can be played with the lethal setting enabled. <br />
<br />
Mortality replaces visual fidelity and photorealism (or other forms of sensory realism); as the most powerful stimulus. You play the game like your life depends on it—which it literally does. You're in an MMO playing against another human in an unpausable PvP game, where the consequence of losing the duel is losing your head in real life. But first, the good news—the cursed thing isn't in mass-production, and while the US-FDA has approved for certain kinds of pain-stimulating gaming peripherals, it didn't approve killing the user. The product will have to pass through a long line of political, legislative, legal, and philosophical hurdles before it's released to market as something you can buy. Please don't.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/doWODmyGhuYsrtvz.jpg" target="_blank" data-width="800" data-height="480" ><img src="https://tpucdn.com/img/doWODmyGhuYsrtvz_thm.jpg" width="217" height="130" alt="" /></a></div>
(PR) Intel NUC 13 Extreme Sets New Standard for Mini PC Gaming Performance
Today, Intel launched the new Intel NUC 13 Extreme Kit (code-named Raptor Canyon) and Intel NUC 13 Extreme Compute Element, which combine to make the most powerful Intel NUC ever built. The NUC 13 Extreme features unlocked 13th Gen Intel Core desktop processors and space for new triple-slot, 12-inch graphics cards to unleash even more performance for enthusiast gamers and content creators. <br />
<br />
"This year marks the 10-year anniversary for our impressive lineup of Intel NUC products, and the Intel NUC 13 Extreme (code named Raptor Canyon) is an excellent representation of how far we've come. Our first ever NUC demonstrated a breakthrough in the miniaturization of a small desktop PC into an ultra-small PC form factor. While much larger than our tiniest mini-PC, our latest Intel NUC 13 Extreme sets a new bar for how to pack stellar gaming performance in a form factor that is 70% smaller than a typical 50L gaming tower. Along with the epic performance you expect from an Intel NUC product, we also deliver exceptional product quality and feature density in a completely modular and customizable design," said Brian McCarson, Intel Vice President and General Manager of the Intel NUC Group.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/N736jSdPOsMZSoVt.jpg" target="_blank" data-width="1600" data-height="1200" ><img src="https://tpucdn.com/img/N736jSdPOsMZSoVt_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/7zlnGTtq4Ybz1rdq.jpg" target="_blank" data-width="1600" data-height="1200" ><img src="https://tpucdn.com/img/7zlnGTtq4Ybz1rdq_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CAQ1pdPBgOnD8sCZ.jpg" target="_blank" data-width="1600" data-height="1138" ><img src="https://tpucdn.com/img/CAQ1pdPBgOnD8sCZ_thm.jpg" width="183" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sj004FuP7GZvexJq.jpg" target="_blank" data-width="1600" data-height="1171" ><img src="https://tpucdn.com/img/sj004FuP7GZvexJq_thm.jpg" width="178" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300839/intel-nuc-13-extreme-sets-new-standard-for-mini-pc-gaming-performance">Read full story</a></div>
(PR) Arctic Announces Alpine 17 LP Low-profile Socket LGA1700 CPU Cool
Today, ARCTIC, a leading manufacturer of low-noise PC coolers and components, introduces the Alpine 17 LP, a new low-profile case cooler. The Alpine 17 LP relies on a slim and flat radial heat sink and a powerful fan. The installation height of the Alpine 17 LP is only 42.9 mm, making it ideal for small cases such as Mini-ITX cases and HTCPs.<br />
<br />
The fan has a wide speed range of 300 to 3000 rpm and remains very quiet, even at higher speeds. The Alpine 17 LP also has the typical ARCTIC 4-pin PWM fan connector and can be easily connected and conveniently regulated via pulse width modulation. The cooler is mounted via push pins and therefore requires no additional tools. Thanks to the pre-applied MX-4 Thermal Paste, the entire assembly is quick and uncomplicated. ARCTIC gives the Alpine 17 LP the 6-year warranty typical for the manufacturer.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YHilIFWQbk1OHlGv.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/YHilIFWQbk1OHlGv_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/669szFtDOoh2XhSm.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/669szFtDOoh2XhSm_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/82Huf8TFEjDOXdVE.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/82Huf8TFEjDOXdVE_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vHwuN2ACfxfwjAsA.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/vHwuN2ACfxfwjAsA_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yJA1tWbRfcv2YydP.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/yJA1tWbRfcv2YydP_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300838/arctic-announces-alpine-17-lp-low-profile-socket-lga1700-cpu-cooler">Read full story</a></div>
(PR) MPEG LA Takes Measures to Assist VVC Adoption
MPEG LA, LLC today announced measures to bring its pool license for Versatile Video Coding, or VVC (introduced to the market on January 27, 2022), into conformity with market realities that will free implementers to invest in VVC adoption. First, a waiver of royalties for standalone (not in or with hardware) VVC software products Sold (with or without compensation or consideration) to an End User is available to any VVC Licensee that commits to becoming a Licensor to MPEG LA's VVC License if they or their Affiliates presently or in the future have the right to license or sublicense VVC Essential Patents. Products to which the waiver applies will still benefit from coverage as licensed products under the VVC License.<br />
<br />
Second, a 25% VVC royalty discount is available to any VVC Licensee that enters into and is compliant with MPEG LA's AVC Patent Portfolio License, HEVC Patent Portfolio License and VVC Patent Portfolio License.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YolFLbuAjHXNhinL.jpg" target="_blank" data-width="600" data-height="200" ><img src="https://tpucdn.com/img/YolFLbuAjHXNhinL_thm.jpg" width="390" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300832/mpeg-la-takes-measures-to-assist-vvc-adoption">Read full story</a></div>
(PR) Supermicro Opens Remote Online Access Program, JumpStart for the H13 Portfolio of Systems Based on the All-New 4th Gen AMD EPYC Processors
Supermicro, a Total IT Solution Provider for Cloud, AI/ML, Storage, and 5G/Edge, announces its JumpStart remote access program - Supermicro H13 JumpStart -- for workload testing and application tuning on 4th Gen AMD EPYC processor-based systems. Developers and IT administrators in AI, Deep Learning, Manufacturing, Telco, Storage, and other industries will get immediate access to leading-edge technologies to accelerate their solution deployment on Supermicro's extensive portfolio of upcoming H13 systems. Customers will be able to test compatibility with previous generations of AMD EPYC processor-based systems and optimize their applications to take advantage of DDR5 memory, PCI-E 5.0 storage, networking, accelerators, and CXL 1.1+ peripherals of the 4th Gen AMD EPYC processors.<br />
<br />
"Supermicro's 4th Gen AMD EPYC processor JumpStart program is poised to give customers a market advantage over their competitors through quick validation of workload performance to accelerate data center deployments," said Charles Liang, president and CEO, Supermicro. "Supermicro's application-optimized servers incorporate the latest technologies to improve performance per watt, energy efficiency, and reduced TCO."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qNTTQjUrOhA2JAeT.jpg" target="_blank" data-width="1216" data-height="486" ><img src="https://tpucdn.com/img/qNTTQjUrOhA2JAeT_thm.jpg" width="325" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300831/supermicro-opens-remote-online-access-program-jumpstart-for-the-h13-portfolio-of-systems-based-on-the-all-new-4th-gen-amd-epyc-processors">Read full story</a></div>
(PR) Noctua Introduces NA-IS1 Inlet Spacers for Suction Applications and NA-SAVG2 Gasket Set
Noctua today introduced its new NA-IS1 intake side spacer frames for suction or "pull" type applications where fans draw air through obstacles such as grills, perforated plates, mesh panels, filters or radiators. By offsetting the fan from the obstacle, the NA-IS1 can significantly reduce influx turbulences and thereby help to improve both acoustics and performance. In addition, Noctua also introduced the NA-SAVG2 anti-vibration gasket set for using 140 mm fans on water cooling radiators or other applications that benefit from a tighter seal with the fan.<br />
<br />
"Intake applications where fans draw air through obstacles such as grills or perforated panels are notoriously challenging both from an aerodynamic and from an acoustic point of view due to the massive turbulences that are caused by these objects", explains Roland Mossig (Noctua CEO). "These influx turbulences can have a significant impact on fan acoustics and performance, so we have created the NA-IS1 spacer frames that give customers a simple yet highly effective solution to reduce these turbulences and thereby make fans more efficient in suction type applications."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/SONy0ywlHoRsjVyJ.jpg" target="_blank" data-width="650" data-height="433" ><img src="https://tpucdn.com/img/SONy0ywlHoRsjVyJ_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yJq0PSpnglr3ezWE.jpg" target="_blank" data-width="650" data-height="813" ><img src="https://tpucdn.com/img/yJq0PSpnglr3ezWE_thm.jpg" width="104" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300830/noctua-introduces-na-is1-inlet-spacers-for-suction-applications-and-na-savg2-gasket-set">Read full story</a></div>
(PR) MediaTek Launches Flagship Dimensity 9200 Chipset for Incredible Performance and Unmatched Power Saving
MediaTek today launched the Dimensity 9200, its latest 5G chipset powering the next era of flagship smartphones. Boasting extreme performance and intelligent power efficiency, the new SoC brings immersive all-day gaming experiences, ultra-sharp image capturing and support for both mmWave 5G and sub-6 GHz connectivity to consumers around the globe.<br />
<br />
"MediaTek's Dimensity 9200 combines ultimate performance with significant power savings, extending battery life and keeping smartphones cool," said JC Hsu, Corporate Vice President and General Manager of MediaTek's wireless communications business unit at MediaTek. "With notably brighter image capturing and improved gaming speeds, along with the latest display enhancements, the Dimensity 9200 will bring new possibilities for next-gen smartphones that come in a variety of stylish and foldable form factors."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/snUHuNKzZNq6dIL0.jpg" target="_blank" data-width="2700" data-height="1927" ><img src="https://tpucdn.com/img/snUHuNKzZNq6dIL0_thm.jpg" width="182" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300829/mediatek-launches-flagship-dimensity-9200-chipset-for-incredible-performance-and-unmatched-power-saving">Read full story</a></div>
(PR) Gigabyte and Team Group Goes DDR5-8000 XMP on Z790 Motherboards
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of motherboards, graphics cards, and hardware solutions, today revealed the supreme performance of XMP DDR5-8000 on Z790 AORUS XTREME and Z790 AORUS MASTER motherboards with Team Group gaming modules T-FORCE DELTA RGB DDR5 memory. Enhanced with the exclusive Low Latency and High Bandwidth technology, this achievement proves again that GIGABYTE motherboard is the ultimate choice to unleash memory performance, as well as the leading role of memory performance by the teamwork of GIGABYTE vs. Team Group. <br />
<br />
It's always been challenging to constantly exceed the high-frequency record of memory, and stable motherboards and high-performance memories make a perfect team to accomplish this difficult task. To provide superior performance and user experience, GIGABYTE has been working closely with Team Group on the record-breaking performance from DDR5-7600, DDR-7800, to XMP DDR5 8000. The detailed memory information is listed in the memory support list of the motherboard, users can check on the site for the best performance matrix on the Z790 platform.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ioKwIC8LPaBusjna.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/ioKwIC8LPaBusjna_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NbC2YvzJc3fQkV4y.jpg" target="_blank" data-width="539" data-height="518" ><img src="https://tpucdn.com/img/NbC2YvzJc3fQkV4y_thm.jpg" width="135" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6Kj9clwS3CsFP3Eh.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/6Kj9clwS3CsFP3Eh_thm.jpg" width="231" height="130" alt="" /></a><br />
</div><div class="readmore"><a href="https://www.techpowerup.com/300828/gigabyte-and-team-group-goes-ddr5-8000-xmp-on-z790-motherboards">Read full story</a></div>
(PR) KLEVV Launches New DDR5-5600 Standard Desktop and Laptop Memory
KLEVV, an emerging memory brand introduced by Essencore, unveils its latest DDR5 standard U-DIMM and SO-DIMM memory running at 5600MT/s. Designed to support both AMD's latest Ryzen 7000 series processors and AM5 platform as well as Intel's 13th Gen Raptor Lake processors and Z790 motherboards, featuring blisteringly fast speed with a highly efficient power to performance ratio.<br />
<br />
To cater the growing demand for high-speed computing with a highly versatile product selection, KLEVV introduces a brand-new 5600 MT/s version to its DDR5 standard desktop and laptop memory lineup. Fully compliant with JEDEC standards, the new 5600MT/s DDR5 memory is the latest addition to KLEVV's DDR5 U-DIMM and SO-DIMM lineup with the pre-existing 4800 MT/s memory.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/QOKCqxRl57JJpRol.jpg" target="_blank" data-width="1019" data-height="741" ><img src="https://tpucdn.com/img/QOKCqxRl57JJpRol_thm.jpg" width="179" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/qOjrWUvlQSG1z2JV.jpg" target="_blank" data-width="997" data-height="630" ><img src="https://tpucdn.com/img/qOjrWUvlQSG1z2JV_thm.jpg" width="206" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fKuLm6yQ3qlxeJ8i.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/fKuLm6yQ3qlxeJ8i_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300827/klevv-launches-new-ddr5-5600-standard-desktop-and-laptop-memory">Read full story</a></div>
Acer to be an 8.97% Shareholder of Apacer, Hints at Cooperation
Acer is bidding to buy 11 million equity shares of Apacer, a major DRAM and NAND flash products manufacturer. The shares, valued at NTD 363 million, will make the Taiwanese prebuilt PC and notebooks giant an 8.97% shareholder of Apacer's stock. The announcement put out by Apacer also speaks of an enhancement of "strategic collaborations" between the two companies. This could only mean one thing—that Apacer becomes a supplier of DRAM and NAND flash products to Acer.<br />
<br />
Acer sells a small but significant lineup of SSDs and PC memory products in the DIY retail channel. These products are sourced from BIWIN, an OEM of DRAM and NAND flash products. Will Apacer replace BIWIN as a supplier? We'll have to wait and see. Besides an OEM, Apacer sells its own-branded memory cards, USB flash drives, SSDs, and PC memory modules; besides holding the PC enthusiast brand ZADAK, which sells high-end SSDs and overclocking memory modules.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/a1TCx0zzCWg9O7Oa.jpg" target="_blank" data-width="1920" data-height="600" ><img src="https://tpucdn.com/img/a1TCx0zzCWg9O7Oa_thm.jpg" width="416" height="130" alt="" /></a></div>
(PR) Creative Announces Sensemore Air True Wireless Earbuds
Creative Technology today launched Creative Sensemore Air, its latest high-performance true wireless earbuds which allow users to hear more of their surroundings than ever before, without compromising on audio quality. The new Sensemore technology helps to address the oft-annoying inconvenience associated with earbuds - because they are in-ear and block out much of the aural environment, users tend to remove their earbuds in various everyday situations, for example when starting a conversation. This changes with the Creative Sensemore Air, as users are given full control on the level of environmental sounds they want to hear. With Sensemore Mode, which is 5 times more sensitive than Ambient Mode, users can hear much more of speech, and other environmental elements, which are amplified with higher clarity. As a bonus, when set to a higher intensity, it could even benefit folks with mild hearing deficiencies.<br />
<br />
The Ambient Mode can be used when users would like to hear their music well while still being aware of the environment, for example while jogging along a busy street. Conversely, to shut the world out so as to fully immerse in the music, users can rely on the Active Noise Cancellation (ANC) Mode. The intensity of all 3 modes is fully adjustable through the handy Creative app.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/orG7IzcbyMHVXjcN.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/orG7IzcbyMHVXjcN_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5p2PbTSQFn8Heo0u.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/5p2PbTSQFn8Heo0u_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pFg8sog54gcTn9aU.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/pFg8sog54gcTn9aU_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aRAxdV5Zcn9b8B1d.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/aRAxdV5Zcn9b8B1d_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VTEHbvd2kr8TQewe.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/VTEHbvd2kr8TQewe_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300822/creative-announces-sensemore-air-true-wireless-earbuds">Read full story</a></div>
(PR) Seagate Announces Black Panther Legacy Edition FireCuda HDDs
Seagate announces three all-new external hard disk drives (HDD) featuring designs inspired by the stories and characters of Marvel Studios' Black Panther. The officially licensed HHDs are available this month and join the company's line of special edition storage devices. Paying homage to T'Challa (aka Black Panther), Shuri, and Okoye, these special edition HDDs deliver one-of-a-kind pieces of Marvel artwork to fans and highlight traits of the characters with customizable RGB LED lighting: magenta to honor Black Panther, cyan for the innovative style of Princess Shuri, and yellow for the elite strength of the warrior, Okoye.<br />
<br />
With up to 2 TB of capacity, the FireCuda external HDDs are compatible with PC, Mac, PlayStation, and Xbox so tech enthusiasts can capture and access a wealth of media, files, and games, regardless of operating system. USB bus-powered and designed with USB 3.2 Gen 1 connection for universal compatibility and quick transfer speeds, the lightweight drives make it easy for Black Panther fans to take their whole library on the road.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/PFyw6IZpaus9uvMY.jpg" target="_blank" data-width="1384" data-height="1000" ><img src="https://tpucdn.com/img/PFyw6IZpaus9uvMY_thm.jpg" width="180" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Pe3SquHcFQEU24Iu.jpg" target="_blank" data-width="1352" data-height="1000" ><img src="https://tpucdn.com/img/Pe3SquHcFQEU24Iu_thm.jpg" width="176" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LvnIsNVlHjq5a1gq.jpg" target="_blank" data-width="1388" data-height="1000" ><img src="https://tpucdn.com/img/LvnIsNVlHjq5a1gq_thm.jpg" width="180" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BiCFmxgAmQ1wIx9C.jpg" target="_blank" data-width="1391" data-height="1000" ><img src="https://tpucdn.com/img/BiCFmxgAmQ1wIx9C_thm.jpg" width="181" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/57Bxa8CDhN7boHBk.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/57Bxa8CDhN7boHBk_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300821/seagate-announces-black-panther-legacy-edition-firecuda-hdds">Read full story</a></div>
(PR) QNAP Releases the ZFS-based QuTS hero h5.0.1
QNAP Systems, Inc. (QNAP) today released QuTS hero h5.0.1, the latest version of QNAP's ZFS-based NAS operating system, to level up QuTS hero NAS with stronger capabilities for big data storage and data security. "Digital transformation and AI rely on massive data analysis, requiring petabyte-scale storage capacity. As storage speed and capacity grows, preventing silent data corruption and ensuring data integrity becomes essential for business IT," said Sam Lin, Product Manager of QNAP, adding "The ZFS-based QuTS hero NAS prioritizes data security and integrity, making it the first choice for businesses to implement a reliable storage solution for a wide range of applications."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/S8VryIoNKyQZ0JHU.jpg" target="_blank" data-width="800" data-height="420" ><img src="https://tpucdn.com/img/S8VryIoNKyQZ0JHU_thm.jpg" width="248" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300820/qnap-releases-the-zfs-based-quts-hero-h5-0-1">Read full story</a></div>
Microsoft DirectStorage 1.1 with GPU-accelerated Game Asset Decompression Released
Microsoft formally released the DirectStorage 1.1 API to game developers on Monday, allowing them to take advantage of GPU-accelerated game asset decompression, to help minimize game loading times. DirectStorage establishes a path for GPUs to directly access storage devices on a system. With version 1.1, the API introduces a way by which the PC can use the GPU to decompress game assets. Microsoft is also promoting GDeflate, a new file compression format developed by NVIDIA, which is optimized for highly parallelized decompression techniques, making it suitable for GPUs. NVIDIA, Intel, and AMD, have each responded positively to this development, and rolled out early drivers with DirectStorage 1.1 support, which can be used by game developers or students. The three will add official DirectStorage 1.1 support to their regular driver update channels later. <br />
<br />
<b>DOWNLOAD:</b> DirectStorage 1.1 early-support (not official) drivers for <a rel="nofollow" href="https://developer.nvidia.com/blog/accelerating-load-times-for-directx-games-and-apps-with-gdeflate-for-directstorage/" target="_blank">NVIDIA GeForce</a> | <a rel="nofollow" href="https://gpuopen.com/amd-support-for-microsoft-directstorage-1-1" target="_blank">AMD Radeon</a> | <a rel="nofollow" href="https://www.intel.com/content/www/us/en/developer/articles/news/directstorage-on-intel-gpus.html" target="_blank">Intel Arc</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/BVzN7FQsIY8EO4VO.jpg" target="_blank" data-width="1366" data-height="804" ><img src="https://tpucdn.com/img/BVzN7FQsIY8EO4VO_thm.jpg" width="221" height="130" alt="" /></a></div>
(PR) Keep Law and Order! Police Simulator: Patrol Officers Available N
astragon Entertainment, in collaboration with developer studio Aesir Interactive, releases Police Simulator: Patrol Officers both digitally and at retail for PC and consoles today. Players start their career with the Brighton Police Department to enforce law and order in the streets of the fictive US coastal city of Brighton and get an insight into everyday police work. At the same time as the release, the Urban Terrain Vehicle DLC is also available at a price of 2.99 Euro/2.49 GBP/2.99 USD, which includes a fancy patrol car. Players who have already purchased Police Simulator: Patrol Officers in Early Access or pre-ordered the game will receive the DLC for free.<br />
<br />
Before they start their first shift, players can choose between eight different characters to start their police career with. A variety of challenging tasks await them, with the difficulty and complexity increasing as the police officers climb the career ladder. Initially, they distribute parking tickets on foot, but soon the players receive their first patrol car, are allowed to catch speeders, solve accidents and track down suspects. Particularly experienced officers can eventually even solve robberies and arrest drug dealers. As you play, new interactions, vehicles and precincts are continuously unlocked, making no shift feel like the previous one. In addition, a game mechanic has been implemented that tracks and rates the player's behavior, where bad behavior can quickly lead to dismissal. In addition, Police Simulator: Patrol Officers offers players the possibility to go on patrol in pairs in the online co-op mode and thus keep law and order in Brighton.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ON9fyz8ZGZ5Fbgof.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/ON9fyz8ZGZ5Fbgof_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tOkpMeD1wKb27KiG.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/tOkpMeD1wKb27KiG_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fw70u2oBtkLRLgzN.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/fw70u2oBtkLRLgzN_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HuqIvFZ76KmmzeG2.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/HuqIvFZ76KmmzeG2_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300958/keep-law-and-order-police-simulator-patrol-officers-available-now-on-pc-playstation-and-xbox">Read full story</a></div>
AMD Launches 4th Gen EPYC "Genoa" Zen 4 Server Processors: 100% Performance Uplift for 50% More Cores
AMD at a special media event titled "together we advance_data centers," formally launched its 4th generation EPYC "Genoa" server processors based on the "Zen 4" microarchitecture. These processors debut an all new platform, with modern I/O connectivity that includes PCI-Express Gen 5, CXL, and DDR5 memory. The processors come in CPU core-counts of up to 96-core/192-thread. There are as many as 18 processor SKUs, differentiated not just in CPU core-counts, but also the way the the cores are spread across the up to 12 "Zen 4" chiplets (CCDs). Each chiplet features up to 8 "Zen 4" CPU cores, depending on the model; up to 32 MB of L3 cache, and is built on the 5 nm EUV process at TSMC. The CCDs talk to a centralized server I/O die (sIOD), which is built on the 6 nm process.<br />
<br />
The processors AMD is launching today are the EPYC "Genoa" series, targeting general purpose servers, although they can be deployed in large cloud data-centers, too. To large-scale cloud providers such as AWS, Azure, and Google Cloud, AMD is readying a different class of processor, codenamed "Bergamo," which is plans to launch later. In 2023, the company will launch the "Genoa-X" line of processor for technical-compute and HPC applications, which benefit from large on-die caches, as they feature the 3D Vertical Cache technology. There will also be "Siena," a class of EPYC processors targeting the telecom and edge-computing markets, which could see an integration of more Xilinx IP.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KbI8z31e66HWkClw.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/KbI8z31e66HWkClw_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/B62uwAinzC5A7SZO.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/B62uwAinzC5A7SZO_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/El94yWorgLqPW5Ze.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/El94yWorgLqPW5Ze_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dVtxL5mYSM1eaVod.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/dVtxL5mYSM1eaVod_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300936/amd-launches-4th-gen-epyc-genoa-zen-4-server-processors-100-performance-uplift-for-50-more-cores">Read full story</a></div>
(PR) Razer Launches the new Razer Naga V2 Pro MMO Mouse
Razer, the leading global lifestyle brand for gamers, today announced the new Razer Naga V2 Pro and Naga V2 HyperSpeed, the latest in Razer's genre-busting MMO and battle-royale mice. Designed primarily for MMOs, with 3 interchangeable side plates on the Naga V2 Pro, and a wealth of new features in both mice, the new Naga V2 Pro and Naga HyperSpeed signal the return of Razer's most adaptable mouse, now better than ever.<br />
<br />
Launched in 2009, the original Naga created the MMO mouse category, setting new standards for functionality and control with its groundbreaking multi-button side panel, immediately becoming the world's bestselling MMO mouse. The new Naga V2 Pro continues this legacy of excellence, with a series of upgrades and improvements that retain the shape and feel of the Naga series that players love, while focusing on the features that matter most to MMO players.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qcJQG4mCBTzN0OH7.jpg" target="_blank" data-width="856" data-height="1280" ><img src="https://tpucdn.com/img/qcJQG4mCBTzN0OH7_thm.jpg" width="87" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2AJu9NOR2CJ7rBI8.jpg" target="_blank" data-width="1280" data-height="1072" ><img src="https://tpucdn.com/img/2AJu9NOR2CJ7rBI8_thm.jpg" width="155" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SF0NyVHM2IyBaKDX.jpg" target="_blank" data-width="1280" data-height="528" ><img src="https://tpucdn.com/img/SF0NyVHM2IyBaKDX_thm.jpg" width="315" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1YwffOdERgczhQqM.jpg" target="_blank" data-width="1280" data-height="763" ><img src="https://tpucdn.com/img/1YwffOdERgczhQqM_thm.jpg" width="218" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9kH4bnysAlWBszMA.jpg" target="_blank" data-width="1280" data-height="839" ><img src="https://tpucdn.com/img/9kH4bnysAlWBszMA_thm.jpg" width="198" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QaNKjHpggX7kYm0b.jpg" target="_blank" data-width="812" data-height="1280" ><img src="https://tpucdn.com/img/QaNKjHpggX7kYm0b_thm.jpg" width="82" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300955/razer-launches-the-new-razer-naga-v2-pro-mmo-mouse">Read full story</a></div>
(PR) Intel Delivers Leading AI Performance Results on MLPerf v2.1 Industry Benchmark for DL Training
Today, MLCommons published results of its industry AI performance benchmark in which both the 4th Generation Intel Xeon Scalable processor (code-named Sapphire Rapids) and Habana Gaudi 2 dedicated deep learning accelerator logged impressive training results.<br />
<br />
<br />
"I'm proud of our team's continued progress since we last submitted leadership results on MLPerf in June. Intel's 4th gen Xeon Scalable processor and Gaudi 2 AI accelerator support a wide array of AI functions and deliver leadership performance for customers who require deep learning training and large-scale workloads." Sandra Rivera, Intel executive vice president and general manager of the Datacenter and AI Group<div class="imgcontainer"><a href="https://www.techpowerup.com/img/sWCv2WVsYKgnv9kc.jpg" target="_blank" data-width="1300" data-height="757" ><img src="https://tpucdn.com/img/sWCv2WVsYKgnv9kc_thm.jpg" width="223" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bjOGFaOFuBSutQfu.jpg" target="_blank" data-width="1044" data-height="781" ><img src="https://tpucdn.com/img/bjOGFaOFuBSutQfu_thm.jpg" width="174" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300952/intel-delivers-leading-ai-performance-results-on-mlperf-v2-1-industry-benchmark-for-dl-training">Read full story</a></div>
Samsung is Considering 27-inch QD-OLED Display Production, to Supply Apple
It appears that the competition is heating up, well, at least when it comes to who is going to be first to launch a 27-inch OLED-type panel, as Samsung is now considering doing its own 27-inch OLED-type panels, following rumours about <a href="https://www.techpowerup.com/299524/lg-display-said-to-start-producing-27-inch-w-oled-panels-this-month" target="_blank">LG considering its own 27-inch OLED-type panels</a>. The details are from UBI Research via the Elec and based on what's being reported, Samsung was initially going to release an RGB OLED based 27-inch panel, but the company wasn't quite there research wise. However, Samsung allegedly went for QD-OLED instead and the article claims it's more profitable for Samsung.<br />
<br />
That said, it seems like Samsung will try to win over Apple as its first customer for the panels, rather than launching them under its own brand. The panels are said to be manufactured in a brand new plant using Gen 8 OLED substrates, which means that these panels will be produced in a cutting edge facility. 27-inches also appears to be the smallest size QD-OLED panels we can expect, at least for now, as smaller size panels will use what is referred to as two stack tandem RGB OLED panels. These will be used in notebooks and other smaller devices. Samsung is currently producing single stack RGB OLED panels that are used in phones.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fN9AQRhmcA30i5ln.jpg" target="_blank" data-width="1200" data-height="744" ><img src="https://tpucdn.com/img/fN9AQRhmcA30i5ln_thm.jpg" width="210" height="130" alt="" /></a></div>
(PR) Rescale Teams with NVIDIA to Unite HPC and AI for Optimized Engineering in the Cloud
Rescale, the leader in high performance computing built for the cloud to accelerate engineering innovation, today announced it is teaming with NVIDIA to integrate the NVIDIA AI platform into Rescale's HPC-as-a-Service offering. The integration is designed to advance computational engineering simulation with AI and machine learning, helping enterprises commercialize new product innovations faster, more efficiently and at less cost.<br />
<br />
Additionally, Rescale announced the world's first Compute Recommendation Engine (CRE) to power Intelligent Computing for HPC and AI workloads. Optimizing workload performance can be prohibitively complex as organizations seek to balance decisions among architectures, geographic regions, price points, scalability, service levels, compliance, and sustainability objectives. Developed using machine learning on NVIDIA architectures with infrastructure telemetry, industry benchmarks, and full-stack metadata spanning over 100 million production HPC workloads, Rescale CRE provides customers unprecedented insight to optimize overall performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/v3ueg4WIH08uDnio.jpg" target="_blank" data-width="1663" data-height="854" ><img src="https://tpucdn.com/img/v3ueg4WIH08uDnio_thm.jpg" width="253" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300945/rescale-teams-with-nvidia-to-unite-hpc-and-ai-for-optimized-engineering-in-the-cloud">Read full story</a></div>
(PR) ASUS Announces AMD EPYC 9004-Powered Rack Servers and Liquid-Cool
ASUS, a leading provider of server systems, server motherboards and workstations, today announced new best-in-class server solutions powered by the latest AMD EPYC 9004 Series processors. ASUS also launched superior liquid-cooling solutions that dramatically improve the data-center power-usage effectiveness (PUE).<br />
<br />
The breakthrough thermal design in this new generation delivers superior power and thermal capabilities to support class-leading features, including up to 400-watt CPUs, up to 350-watt GPUs, and 400 Gbps networking. All ASUS liquid-cooling solutions will be demonstrated in the ASUS booth (number 3816) at SC22 from November 14-17, 2022, at Kay Bailey Hutchison Convention Center in Dallas, Texas.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JYHv6a3SbxOd1ttX.jpg" target="_blank" data-width="754" data-height="820" ><img src="https://tpucdn.com/img/JYHv6a3SbxOd1ttX_thm.jpg" width="120" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/H1syMqU3fDqTHaxj.jpg" target="_blank" data-width="866" data-height="738" ><img src="https://tpucdn.com/img/H1syMqU3fDqTHaxj_thm.jpg" width="153" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Ud2L2XU3yot2rSGk.jpg" target="_blank" data-width="918" data-height="446" ><img src="https://tpucdn.com/img/Ud2L2XU3yot2rSGk_thm.jpg" width="268" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300943/asus-announces-amd-epyc-9004-powered-rack-servers-and-liquid-cooling-solutions">Read full story</a></div>
(PR) ASUS Announces ExpertBook B6 Flip Series
ASUS, a global technology leader renowned for continuously reimagining today's technologies for tomorrow, today announced ExpertBook B6 Flip (B6602F)—the first Expert-series flippable mobile workstation.<br />
<br />
This high-performance mobile workstation with its versatile 360° hinge is designed specifically to help architecture, engineering and construction (AEC) companies running industry-leading software solutions like 3ds Max, MicroStation, and Vectorworks. With immense power packed in a slim and flippable form, ExpertBook B6 Flip handles complex workloads seamlessly across AEC disciplines. It helps users bring design concepts to life through BIM software like ArchiCAD, effortlessly transition from 2D sketches to 3D modelling and printing via tools like Creo and Solidworks, and handle data-intensive applications for deeper insights and better decision-making—delivering the edge that AEC companies need in today's competitive market.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/clzjYzPBfbKHOLY9.jpg" target="_blank" data-width="929" data-height="960" ><img src="https://tpucdn.com/img/clzjYzPBfbKHOLY9_thm.jpg" width="126" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/p0RSExXG4Oa30tw1.jpg" target="_blank" data-width="1280" data-height="836" ><img src="https://tpucdn.com/img/p0RSExXG4Oa30tw1_thm.jpg" width="199" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/r1AVctqKNFQMR5Ia.jpg" target="_blank" data-width="1280" data-height="881" ><img src="https://tpucdn.com/img/r1AVctqKNFQMR5Ia_thm.jpg" width="189" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300942/asus-announces-expertbook-b6-flip-series">Read full story</a></div>
Most Expensive RTX 4080 Custom Just $50 Shy of the RTX 4090 MSRP: MicroCenter Pricing Leak
The most expensive custom-design NVIDIA GeForce RTX 4080 will be priced at $1,550, putting it just $50 short of the $1,600 baseline MSRP of the <a href="https://www.techpowerup.com/300934/nvidia-rtx-4080-20-30-slower-than-rtx-4090-still-smokes-the-rtx-3090-ti-leaked-benchmarks" target="_blank">much faster</a> RTX 4090, according to a pricing leak of custom-design cards on popular PC components retailer MicroCenter. The most interesting takeaway from this leak is that there will actually be RTX 4080 cards at the NVIDIA-set baseline MSRP of $1,200. These include the GIGABYTE Eagle, ZOTAC Trinity, ASUS TUF Gaming, and PNY XLR8 Verto. NVIDIA appears to be telling its partners to sell at least one custom-design RTX 4080 SKU at the baseline price.<br />
<br />
Most factory-overclocked custom-design RTX 4080 SKUs are within $125 of the $1,200 baseline, with the GIGABYTE Eagle OC priced at $1,240, GIGABYTE Gaming OC at $1,280, MSI Ventus 3X OC at $1,280, and the premium MSI Gaming X Trio at $1,325. The top-tier custom-design cards start here, with the GIGABYTE AORUS Master priced at $1,350, the MSI SUPRIM X (air-cooled) at $1,400, the ZOTAC AMP Extreme AIRO at $1,400, ASUS TUF Gaming OC at $1,500; and the ASUS ROG Strix OC at $1,550, which is just $50 short of the cheapest RTX 4090 (baseline-spec). Will anyone pick the ASUS ROG Strix RTX 4080 O16G over the cheapest RTX 4090 (assuming availability of both)? That's a social experiment to watch out for.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ibmIQiKuM9xvqZ1s.jpg" target="_blank" data-width="2846" data-height="1364" ><img src="https://tpucdn.com/img/ibmIQiKuM9xvqZ1s_thm.jpg" width="271" height="130" alt="" /></a></div>
NVIDIA GeForce 526.86 WHQL Game Ready Drivers Released
NVIDIA today released the GeForce 526.86 WHQL drivers. These provide a more stable gaming experience with "Call of Duty: Modern Warfare II" than the previous Game Ready drivers did, solving several image corruption issues and bugs with DLSS and Reflex. The drivers also fix random crashes with "Call of Duty: Vanguard," and a BSOD with VTube Studio. The GPU getting stuck in the P0 power-state after exiting certain games, has been fixed. A drop in 8K60 video decode performance in RTX 4090 has been fixed. Rainbow-like artifacts in "Forza Horizon 5" in some PC configurations after extended gameplay have been fixed. Grab the drivers from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/nvidia-geforce-graphics-drivers/" target="_blank">NVIDIA GeForce 526.86 WHQL</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/vJgP7VDaJhiP5ZJC.jpg" target="_blank" data-width="1920" data-height="1090" ><img src="https://tpucdn.com/img/vJgP7VDaJhiP5ZJC_thm.jpg" width="229" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300938/nvidia-geforce-526-86-whql-game-ready-drivers-released">Read full story</a></div>
NVIDIA RTX 4080 20-30% Slower than RTX 4090, Still Smokes the RTX 3090 Ti: Leaked Benchmarks
Benchmarks of NVIDIA's upcoming GeForce RTX 4080 (formerly known as the RTX 4080 16 GB) are already out as the leaky taps in the Asian tech forumscape know no bounds. Someone with access to an RTX 4080 sample and drivers on ChipHell forums, put it through a battery of synthetic and gaming tests. The $1,200 MSRP graphics card was tested on 3DMark Time Spy, Port Royal, and games that include Forza Horizon 5, Call of Duty Modern Warfare II, Cyberpunk 2077, Borderlands 3, and Shadow of the Tomb Raider.<br />
<br />
The big picture: the RTX 4080 is found to be halfway between the RTX 3090 Ti and the RTX 4090. At stock settings, and in 3DMark Time Spy Extreme (4K), it has 71% the performance of an RTX 4090, whereas the RTX 3090 Ti is 55% that of the RTX 4090. With its "power limit" slider maxed out, the RTX 4080 inches 2 percentage-points closer to the RTX 4090 (73% that of the RTX 4090), and with a bit of manual OC, it adds another 4 percentage-points. Things change slightly with 3DMark Port Royal, where the RTX 4080 is 69% the performance of the RTX 4090 in a test where the RTX 3090 Ti does 58% that of the RTX 4090.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/7stWk0JLw3Vyggs0.jpg" target="_blank" data-width="1654" data-height="618" ><img src="https://tpucdn.com/img/7stWk0JLw3Vyggs0_thm.jpg" width="348" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Up48RlPZDP5wydyH.jpg" target="_blank" data-width="2000" data-height="863" ><img src="https://tpucdn.com/img/Up48RlPZDP5wydyH_thm.jpg" width="301" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hNhRccD1TNBc9mKB.jpg" target="_blank" data-width="2000" data-height="863" ><img src="https://tpucdn.com/img/hNhRccD1TNBc9mKB_thm.jpg" width="301" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300934/nvidia-rtx-4080-20-30-slower-than-rtx-4090-still-smokes-the-rtx-3090-ti-leaked-benchmarks">Read full story</a></div>
(PR) noblechairs Announces the Legend Series Gaming Chairs
Today- noblechairs unveil their newest model in the noblechairs line-up, the LEGEND. The unparalleled design combines the automotive inspired style of the EPIC and its eye holes, the sleek shape of the ICON, and the ergonomics that come with the built-in lumbar support of the HERO, to create LEGEND, the spearhead of development, which takes these beloved features to create a unique and sophisticated chair to suit our customers' high demand for quality and comfort.<br />
<br />
Winning over 250 product awards, noblechairs is the proud bearer of a long and stellar line of positive feedback from its many wonderful customers. As a company dedicated to providing a premium range of comfortable gaming chairs, all with durability and ergonomics in mind, noblechairs is a German brand that takes pride in being seen as one of the best on the market.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dnPfuvUPmpkEUKOH.jpg" target="_blank" data-width="930" data-height="1000" ><img src="https://tpucdn.com/img/dnPfuvUPmpkEUKOH_thm.jpg" width="121" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KInbvRcYXdWwUA7B.jpg" target="_blank" data-width="930" data-height="1000" ><img src="https://tpucdn.com/img/KInbvRcYXdWwUA7B_thm.jpg" width="121" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LkU8KlrDp3AwP6pJ.jpg" target="_blank" data-width="930" data-height="1000" ><img src="https://tpucdn.com/img/LkU8KlrDp3AwP6pJ_thm.jpg" width="121" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JnR1inBHq9xUv8Z8.jpg" target="_blank" data-width="923" data-height="1000" ><img src="https://tpucdn.com/img/JnR1inBHq9xUv8Z8_thm.jpg" width="120" height="130" alt="" /></a> </div>[Editor's note: Our <a href="https://www.techpowerup.com/review/noblechairs-legend-series-chair/" target="_blank">in-depth review of the noblechairs Legend</a> is now live]<div class="readmore"><a href="https://www.techpowerup.com/300925/noblechairs-announces-the-legend-series-gaming-chairs">Read full story</a></div>
Intel Data Center Max GPU "Ponte Vecchio" Implements 16-pin 12VHPWR Connector
The swanky new Intel Data center Max GPU "Ponte Vecchio" is the company's first product to implement the 12+4 pin ATX 12VHPWR power connector, which the company helped design as part of the ATX 3.0 spec. The PCI-Express add-in card (AIC) form-factor variant of the GPU comes with a single 12VHPWR connector that can deliver up to 600 W of power with 100% excursions within small fractions of time (as prescribed in the ATX 3.0 spec). The card elegantly positions the connector at the tail end of the PCB, where while it might obstruct the air intake slightly, it would still ensure that the connectors aren't bent at odd angles. More importantly, the positioning of the connector ensures a bunch of these cards can be installed in 4U server enclosures (without adding 3.5 cm to the Z-height). <br />
<br />
The first GPU maker to implement the 12VHPWR is NVIDIA, with its "Ampere" GeForce RTX 3090 Ti, doubling down on it with the RTX 4090 and soon-to-launch RTX 4080. The connector's implementation heaped bad press over the past few weeks, particularly with the adapter that converts four 8-pin PCIe power connectors to an 12VHPWR; which is allegedly flimsy in the face of aggressive bending for cable-management; with RTX 4090 users on social-media reporting burnt adapters and power connectors on card due to improper mechanical contact from the cable bending/strain. The cable-management standards for servers are different from those of DIY gaming PCs, with many server PSUs still wiring unsleeved "mustard-and-ketchup" cables.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/caqAKMID8vq8HzMr.jpg" target="_blank" data-width="2000" data-height="995" ><img src="https://tpucdn.com/img/caqAKMID8vq8HzMr_thm.jpg" width="261" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/BNDWXPjbucTsc86A.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/BNDWXPjbucTsc86A_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mBOHctE6xhdA4yaV.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/mBOHctE6xhdA4yaV_thm.jpg" width="231" height="130" alt="" /></a></div>
NVIDIA GeForce RTX 4070 Ti Could See a Tight January 5 Launch Schedule
NVIDIA's upcoming GeForce RTX 4070 Ti performance-segment graphics card could see a January 5, 2023 launch (the day on which you can buy one), according to a Wccftech report. The card will be unveiled to the masses on January 3, and reviews of the card could go live on January 4, before product-availability the next day. This would mean that reviewers could get the card well in advance, and would probably be testing it over the Christmas break in order to meet the review date, before flying off to the 2023 International CES, which opens to the public on January 5, and to the press a couple of days earlier.<br />
<br />
The GeForce RTX 4070 Ti is reportedly a <a href="https://www.techpowerup.com/300872/cancelled-nvidia-geforce-rtx-4080-12gb-rebadged-as-rtx-4070-ti-bound-for-january" target="_blank">rebadged RTX 4080 12 GB</a>, which was supposed to launch alongside the RTX 4080 16 GB on November 16; before NVIDIA pulled the plug on the SKU in the face of backlash on social media and the press over its controversial naming that could confuse buyers, given its significantly different hardware specs to those of the RTX 4080 16 GB. With the first batch of RTX 4080 12 GB cards probably already boxed and ready to ship, if not shipped already, NVIDIA is issuing re-branding guidelines to its board partners, so they could do their best at pasting stickers, a template of which is below. It remains to be seen if NVIDIA sticks to the $900 MSRP for the SKU.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/H3pd3wlm7kaJrkFu.jpg" target="_blank" data-width="1200" data-height="613" ><img src="https://tpucdn.com/img/H3pd3wlm7kaJrkFu_thm.jpg" width="254" height="130" alt="" /></a></div>
65W Non-X AMD Ryzen 7 7700 and Ryzen 5 7600 Surface
The SiSoft SANDRA user database has just been pinged by two new unreleased AMD Ryzen 7000 series "Zen 4" processor models, the Ryzen 7 7700 and Ryzen 5 7600. These chips have the same 8-core/16-thread and 6-core/12-thread core-counts as the 7700X and 7600X, respectively; but with lower clock speeds, and more importantly, a lower TDP of just 65 W. This would put their package power tracking (PPT) limit around 90 W, down from the 105 W and 140 W of the their "X" siblings. <br />
<br />
The 7600 and 7700 come with a base frequency of 3.80 GHz, as detected by SANDRA. Every other specification, such as cache size, is the unchanged from the 7600X or 7700X. There's no word on the availability, but it's likely that AMD would debut these chips in the OEM channel first, especially given that the 7600 has the potential to undercut sales of the embattled 7600X. Things could get interesting as Intel debuts the lower end of its 13th Gen Core i5 series, which are rumored to be based on the "Alder Lake" microarchitecture, and 6P+4E SKUs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8rjlmk3oQAU8B5re.jpg" target="_blank" data-width="1355" data-height="479" ><img src="https://tpucdn.com/img/8rjlmk3oQAU8B5re_thm.jpg" width="368" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/v4AOXKcMQsNBxeQl.jpg" target="_blank" data-width="1348" data-height="480" ><img src="https://tpucdn.com/img/v4AOXKcMQsNBxeQl_thm.jpg" width="365" height="130" alt="" /></a></div>
(PR) Alphacool Apex Thermal Grease Now in 20g, 50g or 100g Containers
Alphacool expands the portfolio for thermal pastes and offers Apex Thermal Grease also in containers with 20 g, 50 g or 100 g content. The offer is intended for users who have to frequently resort to the use of thermal paste. The container has a large opening, is uncomplicated to handle and protects the thermal paste reliably and in the long term from drying out. The new containers are also very interesting in terms of price. When purchasing the 20 g can, one already achieves a saving of 25% compared to the quantity in the 4 g applicators required for this.<br />
<br />
With a thermal conductivity of 17 W/mK, Apex is one of the best-performing thermal pastes on the market. However, this is not only due to the high thermal conductivity. Aspects such as viscosity and durability play an equally important role. Alphacool was able to optimize the viscosity so that the thermal grease is particularly suitable for high contact pressures and is still easy to apply. The Apex Thermal Grease is electrically non-conductive and non-caustic. The contained nano particles have a very low thermal impedance and manage to close even microscopic gaps between cooler and heatspreader. Disruptive air pockets are a thing of the past, as are excessively high temperatures.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dnCrYoc8t1gCQOKL.jpg" target="_blank" data-width="1592" data-height="1000" ><img src="https://tpucdn.com/img/dnCrYoc8t1gCQOKL_thm.jpg" width="207" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300927/alphacool-apex-thermal-grease-now-in-20g-50g-or-100g-containers">Read full story</a></div>
(PR) SK hynix Announces the World's first 1anm 8.5 Gbps LPDDR5x DRAM with HKMG Process
SK hynix has developed LPDDR5X (Low Power Double Data Rate 5X), the world's first-ever mobile DRAM with an integrated HKMG (High-K Metal Gate) process, which was just recently introduced to the market. The LPDDR5X boasts the industry's highest energy-efficiency as SK hynix succeeded in reducing power consumption by 25% compared to the previous generation and operates in the ultra-low voltage range of 1.01 V to 1.12 V set by the JEDEC (Joint Electron Device Engineering Council).<br />
For the LPDDR, which is also called a mobile DRAM, having a low power consumption is its greatest asset, just as its standard name—LP (Low Power)—suggests. As power is limited in mobile devices, it's necessary to reduce power consumption as much as possible to extend the usage time.<br />
<br />
This is why lowering power consumption is just as important as increasing operating speed. LPDDR5X was the first among mobile DRAMs to integrate the HKMG process and see improved performance and a reduction in power consumption, essentially killing two birds with one stone. As the power consumption of DRAM gets lowered by LPDDR5X, mobile devices can be used for a longer time with a single charge. The reduction in power consumption of such products can subsequently lead to a reduction in the power used by consumers, which is in line with the value of SK hynix's ESG-centered business management.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BBAryG2wMgvRtwKL.jpg" target="_blank" data-width="1000" data-height="670" ><img src="https://tpucdn.com/img/BBAryG2wMgvRtwKL_thm.jpg" width="194" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/RaGv0Bw7gz2C6RAT.jpg" target="_blank" data-width="1000" data-height="670" ><img src="https://tpucdn.com/img/RaGv0Bw7gz2C6RAT_thm.jpg" width="194" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300926/sk-hynix-announces-the-worlds-first-1anm-8-5-gbps-lpddr5x-dram-with-hkmg-process">Read full story</a></div>
Seagate Boosts PlayStation Storage Capacity with God of War Ragnarök-Inspired HDD
Mythical landscapes and fearsome Norse gods and monsters lay in wait as Kratos and Atreus explore the Nine Realms in the highly anticipated God of War Ragnarök, coming this November. The follow up to PlayStation's critically acclaimed God of War title is certain to capture the imagination and excitement of gamers, and it has inspired Seagate to offer a new special edition external hard disk drive (HDD) Game Drive featuring one-of-a-kind artwork inspired by the game.<br />
<br />
Adding to Seagate's expanding line of PlayStation storage for gamers, the new officially licensed Seagate special edition God of War Ragnarök Game Drive for PlayStation 5 (PS5) and PlayStation 4 (PS4) consoles features a stunning design based on the title and customizable LED RGB light. The external 2 TB HDD expands storage capacity letting players spend less time managing console storage and more time gaming.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FXGOrhsTfg5AYOQY.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/FXGOrhsTfg5AYOQY_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CU4kfPoBVKjXVeEn.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/CU4kfPoBVKjXVeEn_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/E54c28oxT6wUSfFt.jpg" target="_blank" data-width="1280" data-height="732" ><img src="https://tpucdn.com/img/E54c28oxT6wUSfFt_thm.jpg" width="227" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300921/seagate-boosts-playstation-storage-capacity-with-god-of-war-ragnar-k-inspired-hdd">Read full story</a></div>
(PR) Icelandic Game Studio Arctic Theory Lays Foundation for Ambitious Co-Op MMO in 2023
Helmed by veterans from CCP Games and EA, Arctic Theory is proud to reveal they are working on a genre-defining co-op MMO set to release in 2023. Arctic Theory has already raised 2 million USD in funding from its initial seed round in early 2022 and is in talks with prospective publishing partners. Founded by industry veterans with decades of experience creating some of the most iconic, ambitious multiplayer games enjoyed by millions worldwide, Arctic Theory is setting the groundwork for its own boundary-pushing massively multiplayer online game.<br />
<br />
Codenamed Annex, the game takes place in a persistent, single-shared world where nature has taken over the remnants of a long-vanished civilization. By searching for resources, building infrastructure and solving logistical challenges, players will alter the landscape of Annex, creating everything from lone outposts, trade networks and humble settlements to large-scale, democratically run cities of industry.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/MFLiE1n2vZtICzPv.jpg" target="_blank" data-width="1000" data-height="562" ><img src="https://tpucdn.com/img/MFLiE1n2vZtICzPv_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DzPWSapsxPxqlGQU.jpg" target="_blank" data-width="2000" data-height="1125" ><img src="https://tpucdn.com/img/DzPWSapsxPxqlGQU_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300920/icelandic-game-studio-arctic-theory-lays-foundation-for-ambitious-co-op-mmo-in-2023">Read full story</a></div>
Solidigm is Working on 192-layer 3D QLC With Improved Endurance, 61.44 TB SSD
Solidigm—the company that Intel sold its SSD business to—held a tech day last week where the company shared some details about its future roadmaps. The company appears to be focusing on 3D QLC NAND and its 192-layer product promises both larger drives, but also enhanced endurance for QLC NAND. For example, Solidigm's 30.72 TB SSD is promising a PBW of around 32 PB (Petabyte) endurance. This is using what the company calls QLC Essential Endurance NAND. <br />
<br />
However, its QLC Value Endurance NAND is what will enable the 61.44 TB drive, which is said to offer around 65 PB write endurance, but it should be noted that this is at 16 KB aligned data or during other types of light data writes. Neither type of NAND is destined for consumer applications as of now, as Solidigm is only targeting E1, E3 and U.2 form factors. Regardless, this appears to be a huge step forward for 3D QLC NAND and Solidigm is hoping that its upcoming drives will be able to replace mechanical drives in the enterprise market space. On top of this, Solidigm also claims to offer better throughput and latency compared to its competitors, but we're still looking at SATA type level SSD performance for the IOPS. The first drives with the new 192-layer 3D QLC NAND are expected to be available sometime early next year.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/c504xD8MYd8oCf8P.jpg" target="_blank" data-width="950" data-height="537" ><img src="https://tpucdn.com/img/c504xD8MYd8oCf8P_thm.jpg" width="230" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/N0rlzldMEqjNrSZ1.jpg" target="_blank" data-width="950" data-height="534" ><img src="https://tpucdn.com/img/N0rlzldMEqjNrSZ1_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UuRh1KdHvkusJXeQ.jpg" target="_blank" data-width="950" data-height="537" ><img src="https://tpucdn.com/img/UuRh1KdHvkusJXeQ_thm.jpg" width="230" height="130" alt="" /></a></div>
(PR) Atari, Celebrates 50 Years of History with the Release of Atari 5
Atari—one of the world's most iconic consumer brands and interactive entertainment producers—today launches its new title, Atari 50: The Anniversary Celebration, commemorating 50 years of success, growth, and progress in the video game industry. Available now on Nintendo Switch, Xbox One and Series X|S, PlayStation 4|5, and Windows PC, Atari 50 functions as an interactive trek through Atari's historic past, featuring a selection of the publisher's most iconic games, and brands, as well as showcasing the creative individuals who launched the video game industry. <br />
<br />
A mix of video game collection-meets-anthology, Atari 50: The Anniversary Celebration showcases the history of Atari through a combination of retro and modern playable games, short videos, never-before-seen interviews, early development diaries, and more. Emulating seven separate console platforms, and containing titles spanning five decades, the library-styled interface presents over 100 video games sorted by era in an intuitive linear timeline. Other files and materials are also part of the package, including early development sketches, hardware schematics, internal memos, pictures, films, and other "artifacts," the majority of which have never been made public.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vfgfJbpgYjnOysL6.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/vfgfJbpgYjnOysL6_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Ojhenibs4MZoTAhw.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/Ojhenibs4MZoTAhw_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300995/atari-celebrates-50-years-of-history-with-the-release-of-atari-50-the-anniversary-celebration">Read full story</a></div>
(PR) AIC's New Edge Server Platform Powered by 4th Gen AMD EPYC Processors Will Make a Debut at SC22
AIC Inc., (from now on referred to as "AIC"), a leading provider in enterprise storage and server solutions, today revealed its new edge server appliance powered by 4th Gen AMD EPYC processors (codename Genoa). The new server, EB202-CP, is designed to deliver superior performance in a compact size while offering excellent cost efficiency. Combined with the 4th Gen AMD EPYC processors, EB202-CP is expected to drive the innovations in AI, training simulation, autonomous vehicles and edge applications. AIC will showcase EB202-CP at SC22 expo from November 14th to 17th, 2022.<br />
<br />
AIC EB202-CP is a 2U rackmount server with 22 inches in depth. It supports eight E1.S/ E3.S or U.2 SSDs which are front-serviceable and hot-swappable. The E1.S/ E3.S drives are Enterprise and Datacenter SSD Form Factor (EDSFF) that enables EB202-CP to provide high-density all-flash NVMe for half petabyte storage capabilities and enhance IOPS and space utilization. EB202-CP has great expansion functionality and supports up to two double-stack GPU or accelerator cards, two FHHL/HHHL PCIe 5.0 cards and an OCP 3.0 card. Based on AIC server board Capella, EB202-CP supports single 4th Gen AMD EPYC processor and eight DDR5 DIMMs. The 4th Gen AMD EPYC processors, built on "Zen 4" architecture, are optimized for general-purpose workloads across enterprise, cloud and edge. This new generation of AMD EPYC features the world's highest-performing x86 processor, PCIe 5.0 ready, and enables low TCO. It also delivers leadership energy efficiency as well as state-of-the-art security features.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hPlHZskGWsqESpOx.jpg" target="_blank" data-width="800" data-height="428" ><img src="https://tpucdn.com/img/hPlHZskGWsqESpOx_thm.jpg" width="243" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300991/aics-new-edge-server-platform-powered-by-4th-gen-amd-epyc-processors-will-make-a-debut-at-sc22">Read full story</a></div>
(PR) Remedy Entertainment Signs a Co-Development and Co-Publishing Agreement With 505 Games for Control 2
Remedy Entertainment ("Remedy") has signed an agreement with 505 Games, an international video game publisher and a subsidiary of Digital Bros Group, under which Remedy and 505 Games will co-develop and co-publish Control 2 (formerly known as Codename Heron), a sequel to Remedy's award-winning game Control.<br />
<br />
Control 2's initial development budget amounts to EUR 50 million, and Remedy will retain the ownership of the game's intellectual property. The development, marketing, and post-launch investments as well as the future net revenues generated by the game will be equally split between 505 Games and Remedy. The game will be available on PC, PlayStation 5, and Xbox Series X|S, and it will be built on Remedy's proprietary Northlight engine and tools. Remedy will publish the game on the PC platform and 505 Games will publish it on the console platforms. The project is currently in concept stage.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/PfOwFjk3VWaEWTJP.jpg" target="_blank" data-width="4000" data-height="1750" ><img src="https://tpucdn.com/img/PfOwFjk3VWaEWTJP_thm.jpg" width="297" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300983/remedy-entertainment-signs-a-co-development-and-co-publishing-agreement-with-505-games-for-control-2">Read full story</a></div>
(PR) Lian Li Launches Airflow Focused LANCOOL 216 Case
LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, announces the LANCOOL 216, an airflow focused case. Pre-installed with two 160 mm and one 140 mm PWM fan, the LANCOOL 216 offers great out-of-box performance and can be configured from air cooling to AIO cooling mode by lowering/raising the motherboard position. To help balance the case airflow and provide better GPU cooling, the Lancool 216 includes an external PCIe fan bracket that supports a 120 mm fan to be mounted on the rear panel, in front of the expansion slots. The LANCOOL 216 is available in black with non-RGB front fans, and in black or white with addressable RGB front fans. <br />
<br />
To ensure plenty of air is passed through, the LANCOOL 216 features a continuous front-to-top fine mesh panel and a PSU shroud side mesh panel. Paired with 2 x 160 mm and 1x 140 mm pre-installed PWM fans, the LANCOOL 216 ensures great out-of-box performance. For air cooling solutions, the LANCOOL 216's rear I/O can be flipped and the motherboard standoffs set higher in the main chamber to allow up to 2x 140 mm fans above the PSU shroud and at the top of the case. In water-cooling mode, with a motherboard in a lower position, the top of the case can be fitted with up to a 360 mm radiator for AIO or custom water-cooling loop design. <br />
<br />
[Editor's note: Our <a href="https://www.techpowerup.com/review/lian-li-lancool-216-rgb/" target="_blank">in-depth review of the Lian Li Lancool 216 RGB</a> is now live]<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4jLSDWOiD4gnk3cU.jpg" target="_blank" data-width="800" data-height="314" ><img src="https://tpucdn.com/img/4jLSDWOiD4gnk3cU_thm.jpg" width="331" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300982/lian-li-launches-airflow-focused-lancool-216-case">Read full story</a></div>
(PR) MediaTek Takes Entry Chromebook Performance to the Next Level with New Kompanio Chipsets
MediaTek today announced its new Kompanio chipsets for Chromebooks: the Kompanio 520 and Kompanio 528. With upgraded computing performance and battery life for entry level Chromebooks, the newest Kompanio chipsets provide a seamless experience so consumers can browse, cloud game, stream and use Google Play apps while enjoying all-day battery life.<br />
<br />
"Enhanced power efficiency, speedy performance and reliable connectivity are at the core of a great user experience, and that's exactly what MediaTek's new Kompanio chipsets deliver," said Adam King, Vice President and General Manager, Client Computing Business Unit at MediaTek. "As the No. 1 provider of Arm-based Chromebooks, MediaTek makes the latest AI, connectivity, display and imaging features accessible at every price point."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LP5NZnbBTe8bW3c2.jpg" target="_blank" data-width="2700" data-height="1519" ><img src="https://tpucdn.com/img/LP5NZnbBTe8bW3c2_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300981/mediatek-takes-entry-chromebook-performance-to-the-next-level-with-new-kompanio-chipsets">Read full story</a></div>
(PR) MediaTek Upgrades Flagship 4K 120Hz TV Experiences with New Pentonic 1000 Chipset
MediaTek today launched the Pentonic 1000, its latest flagship smart TV system-on-chip (SoC) designed for 4K 120 Hz displays. Pentonic 1000 integrates Wi-Fi 6/6E support, MEMC for smoother video, a powerful AI processor, Dolby Vision IQ with Precision Detail, and 8-screen Intelligent View so users can watch or preview multiple streams of content at once. The chipset also supports the most advanced video codecs and global TV broadcast standards in a single platform.<br />
<br />
The MediaTek Pentonic 1000 combines a powerful multi-core CPU, dual-core GPU, dedicated AI processing unit (APU) and video decoding engines into a single chip. The chipset provides resolution support up to 4K at 120 Hz and is capable of VRR up to 4K at 144 Hz for gaming applications. In addition to supporting super-fast frame rates for smoother gaming, it provides a lag-free experience with Auto Low Latency Mode (ALLM).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/J8l4sorQEwvgogJ6.jpg" target="_blank" data-width="2700" data-height="1780" ><img src="https://tpucdn.com/img/J8l4sorQEwvgogJ6_thm.jpg" width="197" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300980/mediatek-upgrades-flagship-4k-120hz-tv-experiences-with-new-pentonic-1000-chipset">Read full story</a></div>
GoDeal24 Celebrates Singles Day 11/11: Pick Up Genuine Software at Great Prices
GoDeal24 celebrates the joy of being single, with its 11.11 Singles Day Sale. Give yourself the latest and greatest software, to go with your swanky new next-generation hardware gaming PC build. Get Genuine Windows 11 Pro at just $11.11, and power-up your gaming PC with an operating system that understands your hardware the best. Supercharge your domestic productivity with Genuine Office 2021 Professional Plus, at $25.11. Combine the two for $32.99. Check out other great deals on various other editions of Windows and Office, so you can take what's best for you.<br />
<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-10-professiona-key.html?g24=sgo23" target="_blank">Buy Windows 10 Pro at $7.42</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-windows-11-pro-cd-key.html?g24=sgo23" target="_blank">Buy Windows 11 Pro at $11.11</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-professional-32-64-bit-couple-2-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 2-PC at $12.22</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-11-professional-2-keys.html?g24=sgo23" target="_blank">Buy Windows 11 Pro 2-PC at $21.11</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-10-professional-3-keys.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 3-PC at $21.57</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-professional-5-keys.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 5-PC at $33.99</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-professional-5-pcs.html?g24=sgo23" target="_blank">Buy Windows 11 Pro 5-PC at $49.11</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-windows-10-home-cd-key-32-64-bit.html?g24=sgo23" target="_blank">Buy Windows 10 Home at $7.32</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-home-cd-key-32-64-bit-couple-2-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Home 2-PC at $12.01</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-home-key-1-pc.html?g24=sgo23" target="_blank">Buy Windows 11 Home at $10.11</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-11-home-2-keys.html?g24=sgo23" target="_blank">Buy Windows 11 Home 2-PC at $20.11</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2021-pro-plus-key-1pc.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus at $25.11</a> | <a rel="nofollow" href="https://www.godeal24.com/2-office-2021-pro-plus-keys-pack.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 2-PC at $40.11</a> | <a rel="nofollow" href="https://www.godeal24.com/3-office-2021-pro-plus-keys-pack.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 3-PC at $57.11</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2021-pro-plus-5pcs.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 5-PC at $66.11</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2019-professional-plus-key-1pc.html?g24=sgo23" target="_blank">Buy Office 2019 Professional Plus at $23.11</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2016-pro-plus-1-pc.html?g24=sgo23" target="_blank">Buy Office 2016 Professional Plus at $20.11</a><br />
<br />
Please use the coupon <b>SGO62</b> on the following items to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2021-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2021 Professional Plus at $32.99</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2019 Professional Plus at $30.99</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-pro-office-2021-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $29.70</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-pro-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $27.66</a> | <a rel="nofollow" href="https://www.godeal24.com/office-2021-home-and-business-for-mac.html?g24=sgo23" target="_blank">Buy Office 2019 Home and Business for Mac at $68.66</a> | <a rel="nofollow" href="https://www.godeal24.com/office-home-and-business-2019-for-mac-cd-key-global.html?g24=sgo23" target="_blank">Buy Office 2019 Home and Business for Mac at $66.60</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2016-home-business-cd-key-for-mac.html?g24=sgo23" target="_blank">Buy Office 2016 Home and Business for Mac at $60.81</a><br />
<br />
Please use the coupon <b>SGO50</b> on the following items to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-10-enterprise-2019-ltsc-html.html?g24=sgo23" target="_blank">Buy Windows 10 Enterprise 2019 LTSC at $9.14</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-enterprise-ltsc-2021-1-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Enterprise 2021 LTSC at $12.81</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-server-2022-standard.html?g24=sgo23" target="_blank">Buy Windows Server 2022 Standard at $26.13</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-server-2022-datacenter.html?g24=sgo23" target="_blank">Buy Windows Server 2022 Datacenter at $30.75</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/UbJarN9bdJQ0A58J.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/UbJarN9bdJQ0A58J_thm.jpg" width="231" height="130" alt="" /></a> </div>Check out great deals on system utilities you may want.<div class="readmore"><a href="https://www.techpowerup.com/300978/godeal24-celebrates-singles-day-11-11-pick-up-genuine-software-at-great-prices">Read full story</a></div>
AMD 4th Generation EPYC "Genoa" Processors Benchmarked
Yesterday, AMD announced its latest addition to the data center family of processors called <a href="https://www.techpowerup.com/300936/amd-launches-4th-gen-epyc-genoa-zen-4-server-processors-100-performance-uplift-for-50-more-cores" target="_blank">EPYC Genoa</a>. Named the 4th generation EPYC processors, they feature a Zen 4 design and bring additional I/O connectivity like PCIe 5.0, DDR5, and CXL support. To disrupt the cloud, enterprise, and HPC offerings, AMD decided to manufacture SKUs with up to 96 cores and 192 threads, an increase from the previous generation's 64C/128T designs. Today, we are learning more about the performance and power aspects of the 4th generation AMD EPYC Genoa 9654, 9554, and 9374F SKUs from 3rd party sources, and not the official AMD presentation. Tom's Hardware published a heap of benchmarks consisting of rendering, compilation, encoding, parallel computing, molecular dynamics, and much more.<br />
<br />
In the comparison tests, we have AMD EPYC Milan 7763, 75F3, and Intel Xeon Platinum 8380, a current top-end Intel offering until Sapphire Rapids arrives. Comparing 3rd-gen EPYC 64C/128T SKUs with 4th-gen 64C/128T EPYC SKUs, the new generation brings about a 30% increase in compression and parallel compute benchmarks performance. When scaling to the 96C/192T SKU, the gap is widened, and AMD has a clear performance leader in the server marketplace. For more details about the benchmark results, go <a rel="nofollow" href="https://www.tomshardware.com/reviews/amd-4th-gen-epyc-genoa-9654-9554-and-9374f-review-96-cores-zen-4-and-5nm-disrupt-the-data-center/5" target="_blank">here to explore</a>. As far as comparison to Intel offerings, AMD leads the pack as it has a more performant single and multi-threaded design. Of course, beating the Sapphire Rapids to market is a significant win for team red, so we are still waiting to see how the 4th generation Xeon stacks up against Genoa.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qIru9EaTPZ4OKXsK.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/qIru9EaTPZ4OKXsK_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) TYAN Now Offering Systems Powered by 4th Gen AMD EPYC Processors
TYAN, an industry-leading server platform design manufacturer and a MiTAC Computing Technology Corporation subsidiary, today introduced AMD EPYC 9004 Series processor-based server platforms highlighting energy efficiency and performance breakthroughs designed for next generation server architecture for data centers. "Facing the post-COVID economy world, data centers are required to build on more environmentally friendly, secure and flexible features to respond to the growing of teleworking, video streaming, IoT and 5G," said Danny Hsu, Vice President of MiTAC Computing Technology Corporation's Server Infrastructure BU. "TYAN's new server platforms powered by 4th Gen AMD EPYC processors efficiently enable data centers by doing more tasks with the same number of servers."<br />
<br />
"We designed 4th Gen AMD EPYC processors to give our customers exactly what they said they needed, high performance, exceptional energy efficiency and low total cost of ownership," said Ram Peddibhotla, corporate vice president, EPYC product management, AMD. "With the latest "Zen 4" architecture that incorporates modern security by design, 4th Gen AMD EPYC processors are an outstanding choice for IT professionals looking to optimize their data centers for leadership performance while helping address environmental goals."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LInFXEVvrnJme9fx.jpg" target="_blank" data-width="2280" data-height="1000" ><img src="https://tpucdn.com/img/LInFXEVvrnJme9fx_thm.jpg" width="296" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wM8dsRQCMF9Ywhwt.jpg" target="_blank" data-width="612" data-height="1200" ><img src="https://tpucdn.com/img/wM8dsRQCMF9Ywhwt_thm.jpg" width="66" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Bs5PSdO5lcqvJFpZ.jpg" target="_blank" data-width="533" data-height="1200" ><img src="https://tpucdn.com/img/Bs5PSdO5lcqvJFpZ_thm.jpg" width="58" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QVQTItEu1XXBvC50.jpg" target="_blank" data-width="539" data-height="1200" ><img src="https://tpucdn.com/img/QVQTItEu1XXBvC50_thm.jpg" width="58" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LHkn0Y9TbwvnXc5m.jpg" target="_blank" data-width="1583" data-height="1000" ><img src="https://tpucdn.com/img/LHkn0Y9TbwvnXc5m_thm.jpg" width="206" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300970/tyan-now-offering-systems-powered-by-4th-gen-amd-epyc-processors">Read full story</a></div>
(PR) SK hynix DDR5 & CXL Solutions Validated with AMD EPYC 9004 Series Processors
SK hynix announced that its DRAM, and CXL solutions have been validated with the new AMD EPYC 9004 Series processors, which were unveiled during the company's "together we advance_data centers" event on November 10. SK hynix has worked closely with AMD to provide fully compatible memory solutions for the 4th Gen AMD EPYC processors.<br />
<br />
4th Gen AMD EPYC processors are built on an all-new SP5 socket and offer innovative technologies and features including support for advanced DDR5 and CXL 1.1+ memory expansion. SK hynix 1ynm, 1a nm 16 Gb DDR5 and 1a nm 24Gb DDR5 DRAM support 4800 Mbps on 4th Gen AMD EPYC processors, which deliver up to 50% more memory bandwidth than DDR4 product. SK hynix also provides CXL memory device that is a 96 GB product composed of 24 Gb DDR5 DRAMs based on 1a nm. The company expects high customer satisfaction of this product with flexible configuration of bandwidth and capacity expanded cost-efficiently.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FYNzFiMFiGLPbGwu.jpg" target="_blank" data-width="1200" data-height="800" ><img src="https://tpucdn.com/img/FYNzFiMFiGLPbGwu_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300969/sk-hynix-ddr5-cxl-solutions-validated-with-amd-epyc-9004-series-processors">Read full story</a></div>
(PR) GIGABYTE Delivers a Comprehensive Portfolio of Enterprise Solutio
GIGABYTE Technology, an industry leader in high-performance servers and workstations, today announced its portfolio of products ready to support the new AMD EPYC 9004 Series Processors in the first wave of GIGABYTE solutions that will target a wide range of demanding workloads that include GPU-centric, high-density, edge, and general computing. A new x86 platform, a new socket, and a wealth of highly performant technologies provided new opportunities for GIGABYTE to tailor products for leading data centers. So far, GIGABYTE has released twenty-two new servers and motherboards to support the new AMD "Zen 4" architecture. Both single-socket and dual-socket options are available to handle big data and digital transformation. The ongoing collaboration between GIGABYTE and AMD has allowed for a comprehensive portfolio of computing solutions that are ready for the market.<br />
<br />
The new 4th Gen AMD EPYC processors feature substantial compute performance and scalability by combing high core counts with impressive PCIe and memory throughput. In terms of out of the box performance, AMD estimates found that 4th Gen AMD EPYC CPUs are the highest performing server processors in the worldi. With the advancement to 5 nm technology and other performant innovations, the new AMD EPYC 9004 series processors move to a new SP5 socket. The new architecture leads the way to faster data insights with high performance and built-in security features, and this platform targets HPC, AI, cloud, big data, and general enterprise IT.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UOHVQCsqsd3QeS7B.jpg" target="_blank" data-width="1200" data-height="630" ><img src="https://tpucdn.com/img/UOHVQCsqsd3QeS7B_thm.jpg" width="248" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6qHgiQpeZ3dHMZCB.jpg" target="_blank" data-width="1200" data-height="630" ><img src="https://tpucdn.com/img/6qHgiQpeZ3dHMZCB_thm.jpg" width="248" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NqZWbrGSN0GfnoTD.jpg" target="_blank" data-width="1200" data-height="631" ><img src="https://tpucdn.com/img/NqZWbrGSN0GfnoTD_thm.jpg" width="247" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300967/gigabyte-delivers-a-comprehensive-portfolio-of-enterprise-solutions-with-amd-epyc-9004-series-processors">Read full story</a></div>
(PR) Turtle Beach Announces Fuel Dual Controller Charging Station & Headset Stand for Xbox
Best-selling gaming headset and accessories maker Turtle Beach Corporation today unveiled the new Turtle Beach Fuel Dual Controller Charging Station & Headset Stand for Xbox. The Designed for Xbox charging station is the second charging station product announced this week for Turtle Beach, following Monday's Fuel Compact VR Charging Station for Meta Quest 2 reveal as the Company continues expanding into new markets. The Designed for Xbox Fuel Dual Controller Charging Station delivers reliable, ready-for-action power for Xbox Wireless Controllers for gamers playing on Xbox Series X|S through two quick-charging 22+ hour battery packs. The charging station holds two Xbox Wireless Controllers, while the removable headset stand ensures your Stealth 600 Gen 2 MAX or other award-winning Turtle Beach headset is closely within reach. The Fuel Dual Controller Charging Station and Headset Stand for Xbox is available for pre-order now from the Turtle Beach website and participating retailers for a $34.99 (£29.99/€34.99) MSRP and launches December 12, 2022.<br />
<br />
"Earlier this week we entered a new product category with the reveal of our Fuel VR Charger and we're already adding another product to the Fuel family with our officially licensed for Xbox Fuel Dual Controller Charging Station," said Juergen Stark, Chairman and CEO, Turtle Beach Corporation. "With gamers flocking to the latest Call of Duty and other upcoming holiday game launches, it's as important as ever for gamers to keep their gear charged-up and ready to go. The Fuel Dual Charger powers-up Xbox gamers' controllers and helps keep their gaming area clean by becoming a home for two Xbox Wireless Controllers plus a headset when they're not being used."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/7mmoFpDxmmTtzYUl.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/7mmoFpDxmmTtzYUl_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QqMKkVvedmvxlJii.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/QqMKkVvedmvxlJii_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dLfUB1asWaEYpuUU.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/dLfUB1asWaEYpuUU_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QtXWAdijNNPQsvPx.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/QtXWAdijNNPQsvPx_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OdvRIxNC9SCHgAFg.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/OdvRIxNC9SCHgAFg_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300966/turtle-beach-announces-fuel-dual-controller-charging-station-headset-stand-for-xbox">Read full story</a></div>
AMD Launches 4th Gen EPYC "Genoa" Zen 4 Server Processors: 100% Performance Uplift for 50% More Cores
AMD at a special media event titled "together we advance_data centers," formally launched its 4th generation EPYC "Genoa" server processors based on the "Zen 4" microarchitecture. These processors debut an all new platform, with modern I/O connectivity that includes PCI-Express Gen 5, CXL, and DDR5 memory. The processors come in CPU core-counts of up to 96-core/192-thread. There are as many as 18 processor SKUs, differentiated not just in CPU core-counts, but also the way the the cores are spread across the up to 12 "Zen 4" chiplets (CCDs). Each chiplet features up to 8 "Zen 4" CPU cores, depending on the model; up to 32 MB of L3 cache, and is built on the 5 nm EUV process at TSMC. The CCDs talk to a centralized server I/O die (sIOD), which is built on the 6 nm process.<br />
<br />
The processors AMD is launching today are the EPYC "Genoa" series, targeting general purpose servers, although they can be deployed in large cloud data-centers, too. To large-scale cloud providers such as AWS, Azure, and Google Cloud, AMD is readying a different class of processor, codenamed "Bergamo," which is plans to launch later. In 2023, the company will launch the "Genoa-X" line of processor for technical-compute and HPC applications, which benefit from large on-die caches, as they feature the 3D Vertical Cache technology. There will also be "Siena," a class of EPYC processors targeting the telecom and edge-computing markets, which could see an integration of more Xilinx IP.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KbI8z31e66HWkClw.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/KbI8z31e66HWkClw_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/B62uwAinzC5A7SZO.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/B62uwAinzC5A7SZO_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/El94yWorgLqPW5Ze.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/El94yWorgLqPW5Ze_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dVtxL5mYSM1eaVod.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/dVtxL5mYSM1eaVod_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300936/amd-launches-4th-gen-epyc-genoa-zen-4-server-processors-100-performance-uplift-for-50-more-cores">Read full story</a></div>
(PR) Razer Launches the new Razer Naga V2 Pro MMO Mouse
Razer, the leading global lifestyle brand for gamers, today announced the new Razer Naga V2 Pro and Naga V2 HyperSpeed, the latest in Razer's genre-busting MMO and battle-royale mice. Designed primarily for MMOs, with 3 interchangeable side plates on the Naga V2 Pro, and a wealth of new features in both mice, the new Naga V2 Pro and Naga HyperSpeed signal the return of Razer's most adaptable mouse, now better than ever.<br />
<br />
Launched in 2009, the original Naga created the MMO mouse category, setting new standards for functionality and control with its groundbreaking multi-button side panel, immediately becoming the world's bestselling MMO mouse. The new Naga V2 Pro continues this legacy of excellence, with a series of upgrades and improvements that retain the shape and feel of the Naga series that players love, while focusing on the features that matter most to MMO players.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qcJQG4mCBTzN0OH7.jpg" target="_blank" data-width="856" data-height="1280" ><img src="https://tpucdn.com/img/qcJQG4mCBTzN0OH7_thm.jpg" width="87" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2AJu9NOR2CJ7rBI8.jpg" target="_blank" data-width="1280" data-height="1072" ><img src="https://tpucdn.com/img/2AJu9NOR2CJ7rBI8_thm.jpg" width="155" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SF0NyVHM2IyBaKDX.jpg" target="_blank" data-width="1280" data-height="528" ><img src="https://tpucdn.com/img/SF0NyVHM2IyBaKDX_thm.jpg" width="315" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1YwffOdERgczhQqM.jpg" target="_blank" data-width="1280" data-height="763" ><img src="https://tpucdn.com/img/1YwffOdERgczhQqM_thm.jpg" width="218" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9kH4bnysAlWBszMA.jpg" target="_blank" data-width="1280" data-height="839" ><img src="https://tpucdn.com/img/9kH4bnysAlWBszMA_thm.jpg" width="198" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QaNKjHpggX7kYm0b.jpg" target="_blank" data-width="812" data-height="1280" ><img src="https://tpucdn.com/img/QaNKjHpggX7kYm0b_thm.jpg" width="82" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300955/razer-launches-the-new-razer-naga-v2-pro-mmo-mouse">Read full story</a></div>
(PR) Intel Delivers Leading AI Performance Results on MLPerf v2.1 Industry Benchmark for DL Training
Today, MLCommons published results of its industry AI performance benchmark in which both the 4th Generation Intel Xeon Scalable processor (code-named Sapphire Rapids) and Habana Gaudi 2 dedicated deep learning accelerator logged impressive training results.<br />
<br />
<br />
"I'm proud of our team's continued progress since we last submitted leadership results on MLPerf in June. Intel's 4th gen Xeon Scalable processor and Gaudi 2 AI accelerator support a wide array of AI functions and deliver leadership performance for customers who require deep learning training and large-scale workloads." Sandra Rivera, Intel executive vice president and general manager of the Datacenter and AI Group<div class="imgcontainer"><a href="https://www.techpowerup.com/img/sWCv2WVsYKgnv9kc.jpg" target="_blank" data-width="1300" data-height="757" ><img src="https://tpucdn.com/img/sWCv2WVsYKgnv9kc_thm.jpg" width="223" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bjOGFaOFuBSutQfu.jpg" target="_blank" data-width="1044" data-height="781" ><img src="https://tpucdn.com/img/bjOGFaOFuBSutQfu_thm.jpg" width="174" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300952/intel-delivers-leading-ai-performance-results-on-mlperf-v2-1-industry-benchmark-for-dl-training">Read full story</a></div>
Samsung is Considering 27-inch QD-OLED Display Production, to Supply A
It appears that the competition is heating up, well, at least when it comes to who is going to be first to launch a 27-inch OLED-type panel, as Samsung is now considering doing its own 27-inch OLED-type panels, following rumours about <a href="https://www.techpowerup.com/299524/lg-display-said-to-start-producing-27-inch-w-oled-panels-this-month" target="_blank">LG considering its own 27-inch OLED-type panels</a>. The details are from UBI Research via the Elec and based on what's being reported, Samsung was initially going to release an RGB OLED based 27-inch panel, but the company wasn't quite there research wise. However, Samsung allegedly went for QD-OLED instead and the article claims it's more profitable for Samsung.<br />
<br />
That said, it seems like Samsung will try to win over Apple as its first customer for the panels, rather than launching them under its own brand. The panels are said to be manufactured in a brand new plant using Gen 8 OLED substrates, which means that these panels will be produced in a cutting edge facility. 27-inches also appears to be the smallest size QD-OLED panels we can expect, at least for now, as smaller size panels will use what is referred to as two stack tandem RGB OLED panels. These will be used in notebooks and other smaller devices. Samsung is currently producing single stack RGB OLED panels that are used in phones.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fN9AQRhmcA30i5ln.jpg" target="_blank" data-width="1200" data-height="744" ><img src="https://tpucdn.com/img/fN9AQRhmcA30i5ln_thm.jpg" width="210" height="130" alt="" /></a></div>
(PR) Rescale Teams with NVIDIA to Unite HPC and AI for Optimized Engineering in the Cloud
Rescale, the leader in high performance computing built for the cloud to accelerate engineering innovation, today announced it is teaming with NVIDIA to integrate the NVIDIA AI platform into Rescale's HPC-as-a-Service offering. The integration is designed to advance computational engineering simulation with AI and machine learning, helping enterprises commercialize new product innovations faster, more efficiently and at less cost.<br />
<br />
Additionally, Rescale announced the world's first Compute Recommendation Engine (CRE) to power Intelligent Computing for HPC and AI workloads. Optimizing workload performance can be prohibitively complex as organizations seek to balance decisions among architectures, geographic regions, price points, scalability, service levels, compliance, and sustainability objectives. Developed using machine learning on NVIDIA architectures with infrastructure telemetry, industry benchmarks, and full-stack metadata spanning over 100 million production HPC workloads, Rescale CRE provides customers unprecedented insight to optimize overall performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/v3ueg4WIH08uDnio.jpg" target="_blank" data-width="1663" data-height="854" ><img src="https://tpucdn.com/img/v3ueg4WIH08uDnio_thm.jpg" width="253" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300945/rescale-teams-with-nvidia-to-unite-hpc-and-ai-for-optimized-engineering-in-the-cloud">Read full story</a></div>
(PR) ASUS Announces ExpertBook B6 Flip Series
ASUS, a global technology leader renowned for continuously reimagining today's technologies for tomorrow, today announced ExpertBook B6 Flip (B6602F)—the first Expert-series flippable mobile workstation.<br />
<br />
This high-performance mobile workstation with its versatile 360° hinge is designed specifically to help architecture, engineering and construction (AEC) companies running industry-leading software solutions like 3ds Max, MicroStation, and Vectorworks. With immense power packed in a slim and flippable form, ExpertBook B6 Flip handles complex workloads seamlessly across AEC disciplines. It helps users bring design concepts to life through BIM software like ArchiCAD, effortlessly transition from 2D sketches to 3D modelling and printing via tools like Creo and Solidworks, and handle data-intensive applications for deeper insights and better decision-making—delivering the edge that AEC companies need in today's competitive market.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/clzjYzPBfbKHOLY9.jpg" target="_blank" data-width="929" data-height="960" ><img src="https://tpucdn.com/img/clzjYzPBfbKHOLY9_thm.jpg" width="126" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/p0RSExXG4Oa30tw1.jpg" target="_blank" data-width="1280" data-height="836" ><img src="https://tpucdn.com/img/p0RSExXG4Oa30tw1_thm.jpg" width="199" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/r1AVctqKNFQMR5Ia.jpg" target="_blank" data-width="1280" data-height="881" ><img src="https://tpucdn.com/img/r1AVctqKNFQMR5Ia_thm.jpg" width="189" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/300942/asus-announces-expertbook-b6-flip-series">Read full story</a></div>
TechPowerUp GPU-Z v2.51.0 Released
TechPowerUp today released the latest version of TechPowerUp GPU-Z, the popular graphics sub-system information, diagnostic, and monitoring utility. Version 2.51.0 adds full support for the new NVIDIA GeForce RTX 4080 graphics card, including support for BIOS extraction from RTX 4090 and RTX 4080. Besides these, it supports the new RTX 3060 Ti GDDR6X variant, and RTX 3060 based on GA104. We've added the ability to monitor real-time power draw from 16-pin ATX 12VHPWR connector on graphics cards with it. Memory temperature sensors for RTX 40-series has also been added. The transistor-count of the AD102 silicon has been fixed. The DLSS Scan in the Advanced tab no longer starts automatically, and waits for you to select the drives first. It now properly indicates that a search operation has been stopped, when you click on "stop." A crash with crash in Glenfly's Advanced panel has been fixed. The Vulkan and OpenGL tabs have visual improvements. Grab GPU-Z from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/techpowerup-gpu-z/" target="_blank">TechPowerUp GPU-Z v2.51.0</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/tUnWwl7KTE1NUDSw.jpg" target="_blank" data-width="388" data-height="539" ><img src="https://tpucdn.com/img/tUnWwl7KTE1NUDSw_thm.jpg" width="94" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301219/techpowerup-gpu-z-v2-51-0-released">Read full story</a></div>
KeysFan Brings Black Friday Early, Gives Away iSlide Trials with Genuine Software
KeysFan kicks off its year's greatest sale in the run up to Black Friday. Get genuine software at some of the lowest-ever prices, as you build your next-generation hardware battlestation. Get Windows 10 Pro for as low as $7.25 (or as low as $6.12 in a multi-PC pack). The latest and greatest Windows 11 Pro can be had for $10.25. Gear up for domestic productivity with Genuine Office 2021, Office 2019, and Office 2016 now packing 7 days of iSlide Premium. Save even more when you combine your preferred edition of Windows and Office. Also check out great deals on system software you may want.<br />
<br />
<a rel="nofollow" href="https://www.keysfan.com/ms-office-2021-pro-plus-key.html?ksf=skf23" target="_blank">Buy Office 2021 Professional Plus (with iSlide Premium 7 days) for $25.25</a> | <a rel="nofollow" href="https://www.keysfan.com/ms-office-2019-pro-plus-key-1pc.html?ksf=skf23" target="_blank">Buy Office 2019 Professional Plus (with iSlide Premium 7 days) for $23.25</a> | <a rel="nofollow" href="https://www.keysfan.com/ms-office-2016-professional-plus-key-1-pc.html?ksf=skf23" target="_blank">Buy Office 2016 Professional Plus (with iSlide Premium 7 days) for $19.85</a> | <a rel="nofollow" href="https://www.keysfan.com/2-office-2021-pro-plus-keys-pack.html?ksf=skf23" target="_blank">Buy Office 2021 Professional Plus 2-PC at $40.25</a> | <a rel="nofollow" href="https://www.keysfan.com/3-office-2021-pro-plus-keys-pack.html?ksf=skf23" target="_blank">Buy Office 2021 Professional Plus 3-PC at $57.25</a> | <a rel="nofollow" href="https://www.keysfan.com/office-2021-professional-plus-key-5pcs.html?ksf=skf23" target="_blank">Buy Office 2021 Professional Plus 5-PC at $68.25</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-windows-10-pro-key.html?ksf=skf23" target="_blank">Buy Windows 10 Pro at $7.25</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-windows-10-pro-key-2-pcs.html?ksf=skf23" target="_blank">Buy Windows 10 Pro 2-PC at $12.25</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-pro-3-keys-pack.html?ksf=skf23" target="_blank">Buy Windows 10 Pro 3-PC at $21.57</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-pro-5-keys.html?ksf=skf23" target="_blank">Buy Windows 10 Pro 5-PC at $33.99</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-windows-10-home-key.html?ksf=skf23" target="_blank">Buy Windows 10 Home at $7.18</a> | <a rel="nofollow" href="https://www.keysfan.com/ms-microsoft-windows-11-pro-key.html?ksf=skf23" target="_blank">Buy Windows 11 Pro at $10.25</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-pro-2-keys-pack.html?ksf=skf23" target="_blank">Buy Windows 11 Pro 2-PC at $20.25</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-pro-5-pcs.html?ksf=skf23" target="_blank">Buy Windows 11 Pro at $49.88</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-home-key-1-pc.html?ksf=skf23" target="_blank">Buy Windows 11 Home at $9.99</a> <br />
<br />
Please use the coupon code <b>SKF62</b> on the following items to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.keysfan.com/windows-11-pro-and-office-2021-pro-plus-key-bundle.html?ksf=skf23" target="_blank">Buy Windows 11 Pro + Office 2021 Professional Plus at $33.99</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-pro-and-office-2019-pro-plus-key-bundle.html?ksf=skf23" target="_blank">Buy Windows 11 Pro + Office 2019 Professional Plus at $31.99</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-pro-and-office-2021-pro-plus-key-bundle.html?ksf=skf23" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $31.76</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-office-2019-professional-plus.html?ksf=skf23" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $29.70</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-office-2019-home-and-student-1-user.html?ksf=skf23" target="_blank">Buy Office 2019 Home and Student at $31.15</a> | <a rel="nofollow" href="https://www.keysfan.com/office-2019-home-and-business-for-pc.html?ksf=skf23" target="_blank">Buy Office 2019 Home and Business at $47.77</a> | <a rel="nofollow" href="https://www.keysfan.com/office-2021-home-and-business-for-mac.html?ksf=skf23" target="_blank">Buy Office 2021 Home and Business for Mac at $68.67</a> | <a rel="nofollow" href="https://www.keysfan.com/office-2019-home-and-business-for-mac.html?ksf=skf23" target="_blank">Buy Office 2019 Home and Business for Mac at $66.22</a> | <a rel="nofollow" href="https://www.keysfan.com/office-2016-home-and-business-for-mac.html?ksf=skf23" target="_blank">Buy Office 2016 Home and Business for Mac at $60.81</a> <br />
<br />
Please use the coupon code <b>SKF50</b> on the following items.<br />
<a rel="nofollow" href="https://www.keysfan.com/windows-10-enterprise-ltsc-2019-1-pc.html?ksf=skf23" target="_blank">Buy Windows 10 Enterprise LTSC 2019 at $9.14</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-enterprise-ltsc-2021-1-pc.html?ksf=skf23" target="_blank">Buy Windows 10 Enterprise LTSC 2021 at $12.81</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-server-2019-standard.html?ksf=skf23" target="_blank">Buy Windows Server 2019 Standard at $16.06</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-server-2022-standard-key.html?ksf=skf23" target="_blank">Buy Windows Server 2022 Standard at $25.62</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/WZKDSaqyOLAhhFUb.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/WZKDSaqyOLAhhFUb_thm.jpg" width="231" height="130" alt="" /></a> </div>Check out great deals on system software you may want.<div class="readmore"><a href="https://www.techpowerup.com/301228/keysfan-brings-black-friday-early-gives-away-islide-trials-with-genuine-software">Read full story</a></div>
(PR) Lian Li Launches the V3000 PLUS Case Offering Endless Possibilities
LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, announces the V3000 PLUS, a modular full tower that can be configured to 3 different modes. Standard mode fits EEB motherboards with a total of 3x 480 mm radiators and 16x storage drives. Rotated mode, the motherboard tray is rotated 90 degrees, maintains the same radiator support, and upright GPU installation. Dual System mode fits the main system with support for up to EEB motherboards, and a secondary with Mini-ITX. The V3000 PLUS is available in black, and in January also in white, at an MSRP of $499.99.<br />
<br />
The V3000 PLUS is compatible with EEB motherboards, up to 16x 120 mm fans, 480 mm radiators at the top, front and on the side of the PSU shroud, and a 360 mm radiator above it. A removable top radiator bracket, removable side PSU shroud radiator bracket, and multi-position front radiator bracket ensure easy and safe installation of all the cooling hardware. Even the motherboard tray can be removed for the installation of the main components outside of the case.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/U5I74DxadqWKNH9b.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/U5I74DxadqWKNH9b_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a6dvSi2e9x0B4xJp.jpg" target="_blank" data-width="1001" data-height="1000" ><img src="https://tpucdn.com/img/a6dvSi2e9x0B4xJp_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XTTZkUq29rx81Ap2.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/XTTZkUq29rx81Ap2_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/o3tnOdlqqhzqvJEr.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/o3tnOdlqqhzqvJEr_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fpQdUllmyl7T6cdt.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/fpQdUllmyl7T6cdt_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301224/lian-li-launches-the-v3000-plus-case-offering-endless-possibilities">Read full story</a></div>
(PR) Samsung Electronics Announces Exciting New Ways To Experience Game Streaming
Samsung Electronics announced exciting new ways for gamers to experience game streaming with the addition of new partners and the introduction of game streaming to select 2021 Samsung TV models and 4K games, further delivering on its promise of bringing the future of gaming to consumers across the globe.<br />
<br />
Antstream Arcade is the world's largest cloud gaming service that provides players access to over 1,500 iconic games and weekly new multiplayer challenges and tournaments. Select Samsung TV owners will soon be able to battle their friends and the global community at the best games from the 80s, 90s and 00s, from Pac-Man to Mortal Kombat and Metal Slug.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Lk5tXqiVQasMaKL2.jpg" target="_blank" data-width="728" data-height="410" ><img src="https://tpucdn.com/img/Lk5tXqiVQasMaKL2_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301222/samsung-electronics-announces-exciting-new-ways-to-experience-game-streaming">Read full story</a></div>
(PR) ASUS Unveils TUF Gaming and Dual GeForce RTX 3060 Ti with GDDR6X Memory
ASUS today announced new versions of the TUF Gaming GeForce RTX 3060 Ti and the Dual GeForce RTX 3060 Ti graphics cards that now feature GDDR6X memory for greater performance. The NVIDIA GeForce RTX 3060 Ti has been an excellent sweet spot between price and performance for the past generation of graphics cards, and it has now been improved. The GDDR6X memory further boosts the capabilities of the 3060 Ti and expands the options available to the discerning PC DIY builder. ASUS is also updating the GeForce RTX 3060 with a new model featuring 8 GB of GDDR6 VRAM to add even more possibilities for upgrading and assembling.<br />
<br />
The ASUS TUF Gaming GeForce RTX 3060 Ti 8 GB GDDR6X features the same triple Axial Tech fan design, solid aluminium backplate, and 2.7-slot form factor as its predecessor, as well as support for NVIDIA G-SYNC and GPU Tweak III. Supplementing that rock-solid foundation is the introduction of GDDR6X ultra-high-speed and error-correcting VRAM, setting up the GPU to deliver more frames per second than the previous iteration. A factory-overclocked version is also available, tuned in-house to make sure users get the absolute best performance right out of the box.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/A205fV0xAgOOfs8N.jpg" target="_blank" data-width="1012" data-height="866" ><img src="https://tpucdn.com/img/A205fV0xAgOOfs8N_thm.jpg" width="152" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IrDB858w3o8DMcv4.jpg" target="_blank" data-width="794" data-height="738" ><img src="https://tpucdn.com/img/IrDB858w3o8DMcv4_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uIC8TsOSfXcW8R4j.jpg" target="_blank" data-width="982" data-height="882" ><img src="https://tpucdn.com/img/uIC8TsOSfXcW8R4j_thm.jpg" width="145" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301221/asus-unveils-tuf-gaming-and-dual-geforce-rtx-3060-ti-with-gddr6x-memory">Read full story</a></div>
AMD "Zen 4" Based Ryzen Threadripper "Storm Peak" Surfaces with 96-core/192-thread Config
AMD will build "Zen 4" based Ryzen Threadripper processors in an attempt to meet competition from Intel, which is rumored to launch HEDT processors of its own based on "Sapphire Rapids." While Intel's chip tops out at 60-core/120-thread and has a constellation of <a href="https://www.techpowerup.com/299390/intel-outs-first-xeon-scalable-sapphire-rapids-benchmarks-on-package-accelerators-help-catch-up-with-amd-epyc" target="_blank">task-specific hardware-accelerators</a>, AMD will arm its processors with raw CPU core-count, going as high up as 96-core/192-thread. The company has assigned the codename "Storm Peak" for these chips.<br />
<br />
The Ryzen Threadripper 7000-series "Storm Peak" processor engineering samples surfaced on the Einstein@Home user database. As many as three OPNs have surfaced, "AMD Eng Sample: 100-000000884-21_N" and "AMD Eng Sample: 100-000000884-20_Y," which are 96-core/192-thread; and the "AMD Eng Sample: 100-000000454-20_Y," which is 64-core/128-thread. "Storm Peak" is likely just a variation of EPYC "Genoa," geared for higher frequencies.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/evTLhksuLoWFtcFH.jpg" target="_blank" data-width="1417" data-height="885" ><img src="https://tpucdn.com/img/evTLhksuLoWFtcFH_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301220/amd-zen-4-based-ryzen-threadripper-storm-peak-surfaces-with-96-core-192-thread-config">Read full story</a></div>
Intel XeSS Plugin Released for Unreal Engine
Intel released the XeSS Unreal Engine plugin, letting game developers integrate the performance enhancement technology with their Unreal Engine 4 and Unreal Engine 5 powered games, simulators, and 3D visualization applications. The plugin lets Unreal Engine take advantage of XeSS not just on Intel Arc "Alchemist" GPUs, where they benefit from the accelerated XMX code-path; but also AMD and NVIDIA GPUs, where the technology takes advantage of the slower yet functional DP4a code-path. XeSS is technically a second-generation super-resolution technology that Intel claims is on-par with AMD FSR 2.x and NVIDIA DLSS 2. Integrating it is as straightforward as adding AMD FSR support. Those interested can grab the plugin from the GitHub source link, below.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DB7nXpgRrKFP2e9x.jpg" target="_blank" data-width="783" data-height="553" ><img src="https://tpucdn.com/img/DB7nXpgRrKFP2e9x_thm.jpg" width="184" height="130" alt="" /></a></div>
Intel Arc Graphics 31.0.101.3802 Game On Drivers Released
Intel Graphics today released the Arc Graphics Driver 31.0.101.3802 beta. The drivers introduce Game On (day-zero) optimization for "Sonic Frontiers," "Marvel's Spider-Man: Miles Morales," "Call of Duty: Warzone 2.0," and "Dysterra." The drivers also improve performance of a handful games such as "Chrorus," "DiRT 5," "Far Cry 6," "Ghostwire Tokyo," "Gotham Knights," "Marvel's Guardians of the Galaxy," and "Sniper Elite 5," by anywhere between 3% to 8%, at specific resolutions of 1080p or 1440p.<br />
<br />
Among the handful issues fixed with this release include flickering of certain textures in the "Cultist Base" level of "DOOM Eternal," lower than expected performance in Tom Clancy's "Rainbow Six Siege," lighting or flickering issues with "Death Stranding" Director's Cut," and display corruption lines noticed with 2x MSAA enabled in "Forza Horizon 5." Grab the drivers from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/intel-arc-graphics-drivers/" target="_blank">Intel Arc 31.0.101.3802 Game On Drivers</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/4ChtJexAW7Li01Db.jpg" target="_blank" data-width="640" data-height="363" ><img src="https://tpucdn.com/img/4ChtJexAW7Li01Db_thm.jpg" width="229" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3lR2aalWlWQ2ngp8.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/3lR2aalWlWQ2ngp8_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NMyHP9FZSig99BPX.jpg" target="_blank" data-width="620" data-height="311" ><img src="https://tpucdn.com/img/NMyHP9FZSig99BPX_thm.jpg" width="259" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SrzYBqupAXAqkdK5.jpg" target="_blank" data-width="616" data-height="353" ><img src="https://tpucdn.com/img/SrzYBqupAXAqkdK5_thm.jpg" width="227" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301210/intel-arc-graphics-31-0-101-3802-game-on-drivers-released">Read full story</a></div>
(PR) Fractal Announces the Ridge SFF Chassis
Meet Ridge—an uncluttered, small form factor case designed to integrate seamlessly into people's living spaces and daily rituals. Developed for gaming and entertainment, Ridge offers generous compatibility in a space-saving format. It can house GPUs up to a length of 335 mm and has space for up to four 2.5" drives. Uncompromising accessibility and a well-structured interior layout make building in Ridge an intuitive experience. And to make it even easier, Ridge includes a PCIe 4.0 riser card, two 140 mm PWM Aspect fans and a USB type-C port. <br />
<br />
For smooth operation, Ridge features ventilation on all six sides of the case, including a fabric front mesh and perforated top, bottom and side panels. It can also be placed horizontally or vertically, with two included feet, to flexibly integrate into gaming and entertainment spaces. An evolution of the slimline format, Ridge was developed in collaboration with gaming and entertainment enthusiasts to subtly improve their homes and enhance the small form factor PC experience.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2iLDwDOsUkdpctUW.jpg" target="_blank" data-width="1170" data-height="1000" ><img src="https://tpucdn.com/img/2iLDwDOsUkdpctUW_thm.jpg" width="152" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ERLMwNOVLjlXk2qA.jpg" target="_blank" data-width="1409" data-height="1000" ><img src="https://tpucdn.com/img/ERLMwNOVLjlXk2qA_thm.jpg" width="183" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8szF3vlMaQWeNhyu.jpg" target="_blank" data-width="1062" data-height="1000" ><img src="https://tpucdn.com/img/8szF3vlMaQWeNhyu_thm.jpg" width="138" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8p7jM0FeDOojgvxA.jpg" target="_blank" data-width="978" data-height="1000" ><img src="https://tpucdn.com/img/8p7jM0FeDOojgvxA_thm.jpg" width="127" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DgDl1iAjTcWV5PO1.jpg" target="_blank" data-width="1415" data-height="1000" ><img src="https://tpucdn.com/img/DgDl1iAjTcWV5PO1_thm.jpg" width="184" height="130" alt="" /></a> </div>[Editor's note: Our <a href="https://www.techpowerup.com/review/fractal-design-ridge/" target="_blank">in-depth review of the Fractal Ridge</a> is now live]<div class="readmore"><a href="https://www.techpowerup.com/301207/fractal-announces-the-ridge-sff-chassis">Read full story</a></div>
(PR) CORSAIR Launches TBT200 Thunderbolt 4 Dock
CORSAIR, a world leader in enthusiast components for gamers, creators, and PC builders, today announced the launch of the CORSAIR TBT200 Thunderbolt 4 dock, unlocking a huge array of connectivity options to user's compatible laptops, Macs, PCs and Chromebooks over a single cable. The TBT200 boasts no less than four Thunderbolt 4 ports (including one host connection), and a multitude of additional connections, including HDMI 2.0, DisplayPort 1.4, 2.5 Gbps Ethernet, 3.5 mm audio, USB Type- C as well as Type-A and more. All this is encased in a stylish, aluminium-clad package that looks at home alongside any setup. Whether it's maximizing a workstation's connectivity, or creating an ambitious power-user setup that connects with just a single cable, the TBT200 puts even the most demanding setup just a single cable away.<br />
<br />
With Thunderbolt 4, the TBT200 unlocks even more connection options for today's most advanced laptops and PCs over a single cable. While Thunderbolt 4 shares the same bandwidth as its predecessor at 40 Gbps, it unlocks an array of new connection options, including up to 3 simultaneously connected Thunderbolt devices. Users can choose to connect their displays via any combination HDMI 2.0, DisplayPort, or via the included USB Type-C to DisplayPort and USB Type-C to HDMI adapters, supporting a huge range of hardware from 4K TVs to professional production-level displays.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/hihJpYg1GnEJtJaX.jpg" target="_blank" data-width="1371" data-height="1000" ><img src="https://tpucdn.com/img/hihJpYg1GnEJtJaX_thm.jpg" width="178" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JUDxy9T8jdIVEfm7.jpg" target="_blank" data-width="1418" data-height="1000" ><img src="https://tpucdn.com/img/JUDxy9T8jdIVEfm7_thm.jpg" width="184" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/X035IWJYrraK6qZu.jpg" target="_blank" data-width="1476" data-height="1000" ><img src="https://tpucdn.com/img/X035IWJYrraK6qZu_thm.jpg" width="192" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SQOVePAYyROmAoWl.jpg" target="_blank" data-width="1333" data-height="1000" ><img src="https://tpucdn.com/img/SQOVePAYyROmAoWl_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vJDjNl8toKj5Q8jM.jpg" target="_blank" data-width="1333" data-height="1000" ><img src="https://tpucdn.com/img/vJDjNl8toKj5Q8jM_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301206/corsair-launches-tbt200-thunderbolt-4-dock">Read full story</a></div>
(PR) Warhammer 40,000: Rogue Trader Gamplay Trailer Debuts at PC Gaming Show
Award-winning studio Owlcat Games is thrilled to reveal the first gameplay trailer for Warhammer 40,000: Rogue Trader - the first cRPG set in the legendary grim darkness of the far future of Warhammer 40,000. Set to be released on PC and consoles, the game features turn-based combat and is being produced in close collaboration with Games Workshop.<br />
<br />
Owlcat unveiled a new gameplay trailer during the PC Gaming Show 2023 Preview, giving viewers a taste of what it truly means to be a Rogue Trader. The launch of the trailer is also heralding the opening of the Steam and GOG wishlists for the eagerly anticipated title. The fabulous Warhammer 40,000: Rogue Trader collector's box revealed on the show includes an 8-inch painted figure of Navigator Cassia Orsellio, hardcover art book, Warrant of Trade that you can personalize with your name, Rogue Trader banner, and sticker pack. Together with physical items you will receive a digital version of the game in a selected store with the pack of various in-game goodies and access to Alpha and Beta versions. The Collector's Edition is available for pre-order via owlcat.games' website.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6ZXQH4IwfoLSBfx4.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/6ZXQH4IwfoLSBfx4_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/osvG9KTwwsjEvwHb.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/osvG9KTwwsjEvwHb_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6fd44tVZwtULXnMG.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/6fd44tVZwtULXnMG_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rcIbmeROBTLQCNKS.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/rcIbmeROBTLQCNKS_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301196/warhammer-40-000-rogue-trader-gamplay-trailer-debuts-at-pc-gaming-show">Read full story</a></div>
(PR) HYTE in Collaboration With hololive English Unveils the New Limited Edition Ouro Kronii Y60 PC Case
HYTE, the PC components, peripherals, and lifestyle brand of iBUYPOWER, today, unveiled the new limited edition Ouro Kronii Y60 PC Case, in collaboration with hololive English team, represented by the COVER Corporation from Japan.<br />
<br />
In HYTE's second collaboration with hololive English and illustrator Rosuuri, the beloved Ouro Kronii of holoCouncil comes to life along the tempered glass side panels of the uniquely designed Y60 PC Case. The famous VTuber is depicted on the main side panel holding up one of her blades while clock cogs appear to float in the background. On the corner glass, Kronii's white snake, Boros, sits atop a cog floating above a golden clock while a chibi version of Kronii embracing her Kronies plushie is depicted on the front glass panel.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8STZeNu2FC4rbsVG.jpg" target="_blank" data-width="1245" data-height="1280" ><img src="https://tpucdn.com/img/8STZeNu2FC4rbsVG_thm.jpg" width="126" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5v6PG80KCZduQUqu.jpg" target="_blank" data-width="828" data-height="1280" ><img src="https://tpucdn.com/img/5v6PG80KCZduQUqu_thm.jpg" width="84" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QKDPQY5IjER4TRn8.jpg" target="_blank" data-width="1146" data-height="1280" ><img src="https://tpucdn.com/img/QKDPQY5IjER4TRn8_thm.jpg" width="116" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PAdIf3oUAlKRrCRy.jpg" target="_blank" data-width="1041" data-height="1280" ><img src="https://tpucdn.com/img/PAdIf3oUAlKRrCRy_thm.jpg" width="106" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301192/hyte-in-collaboration-with-hololive-english-unveils-the-new-limited-edition-ouro-kronii-y60-pc-case">Read full story</a></div>
(PR) Netgear Launches Two Unmanaged Multi-Gigabit Ethernet Switches
The number of devices, such as WiFi 6 access points and NAS, with multi-gig capabilities and speed is increasing. Also, the use of modern applications, increasing prevalence of BYOD and usage of more and more video requires companies to have more bandwidth to ensure smooth network traffic that just can't be handled by Gigabit connectivity anymore. Even the smallest firms are doing big business when it comes to the sheer volume of data that their networks are expected to handle, and this load will continue to grow as applications become more advanced.<br />
<br />
To help businesses cost-effectively expand their networks with multi-gigabit speeds, we've introduced a couple of new 5-port Multi-Gigabit Unmanaged Switches, MS105 and MS305. The MS105 and MS305 Multi-Gigabit Ethernet switches come with five 2.5G ports in a metal case that can be placed on a desk or mounted on a wall. These switches are energy efficient, built to last, and rigorously tested to provide the reliability businesses need.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kfaOpu8nGuXnTixH.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/kfaOpu8nGuXnTixH_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Zb8C25zrGOHNJwCV.jpg" target="_blank" data-width="1280" data-height="410" ><img src="https://tpucdn.com/img/Zb8C25zrGOHNJwCV_thm.jpg" width="406" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bkOxNbAVVMlZZJ6r.jpg" target="_blank" data-width="1280" data-height="408" ><img src="https://tpucdn.com/img/bkOxNbAVVMlZZJ6r_thm.jpg" width="408" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301191/netgear-launches-two-unmanaged-multi-gigabit-ethernet-switches">Read full story</a></div>
(PR) Hundreds of Renesas' Intersil-Brand Radiation-Hardened ICs Lift Off Onboard Artemis 1 Mission to the Moon
Renesas Electronics Corporation, a premier supplier of advanced semiconductor solutions, today announced that hundreds of its radiation-hardened (rad-hard) integrated circuits (ICs), including over 50 different part numbers, are onboard the Artemis 1 launch that blasted off on November 16. Intersil-brand rad-hard ICs are part of the battery management systems, RS-25 engine control electronics and the launch abort system on the Space Launch System that propelled the mission into space, the most powerful rocket ever built. On the Orion Capsule that will circle the moon, Renesas provided critical components for controller boards, the main flight computer, the docking camera system, the power distribution system and display and panel electronics. The Intersil-brand ICs perform multiple functions, including power management and precision signal processing.<br />
<br />
Artemis is the ambitious NASA program that will take humankind back to the moon for the first time in more than 50 years. Artemis 1 is sending the test-mannequin populated Orion capsule to orbit the moon and deploy cubesats and other space experiments on a 42-day mission to test all the critical systems. Artemis 2 (2024) will have a crew that will orbit the moon paving the way for Artemis 3 (2025), which will land the first woman and the first person of color on the moon. The plan is for Artemis to continue to build a space station in lunar orbit and a base on the lunar South Pole. This infrastructure will allow for the awe-inspiring goal of a crewed mission to Mars in the 2040s.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FsvsWWs364xwkovF.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/FsvsWWs364xwkovF_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301190/hundreds-of-renesas-intersil-brand-radiation-hardened-ics-lift-off-onboard-artemis-1-mission-to-the-moon">Read full story</a></div>
(PR) Phanteks Announces Eclipse G500A, M25 Fans, and All-White Neon Strips
Phanteks today announces four models of the new Eclipse G500A, a new range of cooling fans, the M25 Series, and new all-white Neon D-RGB LED strips. The Eclipse G500A pushes the limit with its high airflow design to unlock next-gen CPU and GPU performance. The G500A's front and top panels feature Phanteks' Ultra-fine Performance Mesh design that combines high airflow performance with excellent dust filtration, all-in-one. With its spacious interior, the G500A is ready for powerful gaming setups, offering a 420 radiator in the front, and a 360 radiator in the top, while having plenty of space for full-length GPUs, multiple HDD and SSD locations, and a vertical GPU mounting option.<br />
<br />
Like all Phanteks lighting products, the integrated D-RGB lighting is simple to control with pre-programmed lighting effects and requires no software. Optionally, the D-RGB controller can be synchronized with compatible motherboards and expanded with more D-RGB products. The G500A D-RGB comes with 2x D-RGB LED strips built into the front and side. Three M25-140 D-RGB fans are pre-installed on the front. The G500A D-RGB Fanless model includes 2x D-RGB LED strips built into the front and side. The G500A Performance model comes with 4x M25-140 black fans pre-installed and a white LED strip in the front.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lWMlqssYs1UfNus8.jpg" target="_blank" data-width="2000" data-height="1000" ><img src="https://tpucdn.com/img/lWMlqssYs1UfNus8_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ptNqGQlMNNk3cLmP.jpg" target="_blank" data-width="2000" data-height="1000" ><img src="https://tpucdn.com/img/ptNqGQlMNNk3cLmP_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6tumyZT012XbXtov.jpg" target="_blank" data-width="2000" data-height="1000" ><img src="https://tpucdn.com/img/6tumyZT012XbXtov_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xI4cZwB5ENrlp2TN.jpg" target="_blank" data-width="2000" data-height="1000" ><img src="https://tpucdn.com/img/xI4cZwB5ENrlp2TN_thm.jpg" width="260" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301171/phanteks-announces-eclipse-g500a-m25-fans-and-all-white-neon-strips">Read full story</a></div>
(PR) Qualcomm Launches Snapdragon AR2 Designed to Revolutionize AR Glasses
During Snapdragon Summit 2022, Qualcomm Technologies, Inc. revealed the Snapdragon AR2 Gen 1 Platform, which delivers groundbreaking AR technology that will unlock a new generation of sleek, highly capable glasses. The Company built Snapdragon AR2 from the ground up to revolutionize the headworn glass form factor and usher in a new era of spatial computing experiences for the real-world/metaverse mix.<br />
<br />
Purpose-built for AR: To help create the thinnest possible, high-performance AR glass, we have built a multi-chip distributed processing architecture combined with customized IP blocks. The main processor occupies a 40% smaller PCB area on glass and the overall platform delivers 2.5x better AI performance while consuming 50% less power to help achieve AR glasses that consume <1 W power. This enables rich AR experiences on glasses that can be comfortably worn for extended periods of time and meet the demands of both consumers and enterprise use cases.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/phaXwY15mWUsyWdA.jpg" target="_blank" data-width="1280" data-height="805" ><img src="https://tpucdn.com/img/phaXwY15mWUsyWdA_thm.jpg" width="207" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/RcU7GCeMDUo5bjvs.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/RcU7GCeMDUo5bjvs_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FjGwqbpfMFbnW1Ho.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/FjGwqbpfMFbnW1Ho_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301189/qualcomm-launches-snapdragon-ar2-designed-to-revolutionize-ar-glasses">Read full story</a></div>
Colorful Releases iGame GeForce RTX 4080 Neptune OC-V Graphics Card with 470W Power Limit and AIO Cooling
Colorful formally released its flagship custom-design graphics card based on the GeForce RTX 4080 "Ada" launched earlier this week, the iGame RTX 4080 Neptune OC-V. This card features a factory-fitted all-in-one (AIO) liquid cooling solution. Unlike some other similar cards, such as the MSI SUPRIM Liquid X, the Neptune OC-V relies on a 100% liquid-cooled configuration, wherein a the cold-plate is the only source of cooling for the GPU, memory, and VRM; there are no additional fans on the card. The cooling solution involves a waterblock that pulls heat from all key components on the PCB, which is connected to a 360 mm x 120 mm radiator that comes with three 120 mm RGB fans. <br />
<br />
The card is 25.3 cm in length, strictly 2 slots thick, and 17 cm in height. Silvery aluminium makes up the cooler shroud and backplate. The coolant tubing comes with white Nylon sleeving. The aluminium radiator has a white frame, as do the three fans. The fan impellers are frosted to act like RGB diffusers. The Neptune OC-V comes with factory-overclocked speeds of 2640 MHz GPU Boost (compared to 2505 MHz reference). The most interesting aspect is the power limit, which is now set at 470 W (compared to 320 W reference).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/9v4egI71q6tUoGeu.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/9v4egI71q6tUoGeu_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cI5kvTQHE0DlNaxd.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/cI5kvTQHE0DlNaxd_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eN6g5TyWk6a1KwDg.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/eN6g5TyWk6a1KwDg_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5nkqCswMsCOO92m3.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/5nkqCswMsCOO92m3_thm.jpg" width="130" height="130" alt="" /></a></div>
NVIDIA Plans GeForce RTX 4060 Launch for Summer 2023, Performance Rivaling RTX 3070
NVIDIA is reportedly planning to ramp its GeForce "Ada" generation into the high-volume performance segment by Summer 2023, with the introduction of the GeForce RTX 4060. The card is expected to launch somewhere around June, 2023. The card will be based on the 4 nm "AD106" silicon, the 4th chip based on the "Ada Lovelace" graphics architecture. Wolstame. a reliable source with NVIDIA leaks as Lenovo's Legion gaming desktop product manager, predicts that the RTX 4060 performance could end up matching that of the current RTX 3070 at a lower price-point. <br />
<br />
This should make it a reasonably fast graphics card for 1440p AAA gaming with high-ultra settings, and ray tracing thrown in. What's interesting is if NVIDIA is expected to extend the DLSS 3 frame-generation feature to even this segment of graphics cards, which means a near-100% frame rate uplift can be had. Other predictions include a board power expected to be in the range of 150-180 W, and a 10% generational price-increase, which would mean that the RTX 4060 would have a launch-price similar to that of the RTX 3060 Ti (USD $399).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fn8z2B6XeNuETbHZ.jpg" target="_blank" data-width="1500" data-height="1112" ><img src="https://tpucdn.com/img/fn8z2B6XeNuETbHZ_thm.jpg" width="175" height="130" alt="" /></a></div>
(PR) Cincoze Launches Industrial Panel PCs: The Ideal HMI for Smart Manufacturing
Rugged embedded computer brand, Cincoze, knows that HMI is the most common application of industrial panel PCs. In addition to visualizing equipment-related data, HMI can also monitor and control machinery equipment, which is helpful for the on-site manager to get an accurate picture of the process status.<br />
<br />
The newly launched open frame panel PC is the latest addition to the Cincoze Display Computing - CRYSTAL product line. Whether an industrial panel PC for factory use, a sunlight-readable panel PC for outdoor use, or an open frame panel PC for integration into advanced equipment, customers now have more options for selecting a suitable panel PC for their HMI application. The core technology behind Cincoze panel PCs is CDS (Convertible Display System, Pat. M482908), a modular panel PC system consisting of a computer module and display module that enables convenient on-site maintenance and flexibility for future upgrades.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oXkFWoNRTV35TJEo.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/oXkFWoNRTV35TJEo_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/VsPmAjZe5gYpXwdt.jpg" target="_blank" data-width="1000" data-height="350" ><img src="https://tpucdn.com/img/VsPmAjZe5gYpXwdt_thm.jpg" width="371" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dICodmaZme5wGiCR.jpg" target="_blank" data-width="1000" data-height="350" ><img src="https://tpucdn.com/img/dICodmaZme5wGiCR_thm.jpg" width="371" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301178/cincoze-launches-industrial-panel-pcs-the-ideal-hmi-for-smart-manufacturing">Read full story</a></div>
(PR) Alphacool Unveils Core Storm and Core Hurrican Liquid Cooling Set
With Core Storm and Core Hurrican, Alphacool provides further complete water cooling sets that contain all components for setting up a performance-oriented CPU cooling. The sets differ in that Core Storm comes with SoftTubes, while Core Hurrican comes with HardTubes. Due to the included mounting hardware, the bundled CPU coolers are compatible with all common mainstream sockets from AMD and Intel. Even AMD's newest AM5 socket can be water-cooled with the Core Storm or Core Hurrican sets with ease.<br />
<br />
The sets are not only aimed at beginners, but also at enthusiasts. The selected components are optimally matched and come from Alphacool's DIY program. By using the Alphacool quick-connect coupling included with the Core Set, the loop can be easily expanded with additional components such as radiators, GPU coolers or sensors without having to drain or rebuild the water loop.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oRmCnRMeHDzj7eH5.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/oRmCnRMeHDzj7eH5_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/u0b2QArQjYxA9L0H.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/u0b2QArQjYxA9L0H_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fpqILWWcSIHBLa3S.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/fpqILWWcSIHBLa3S_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/L5q8DyIMXfyBtXBG.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/L5q8DyIMXfyBtXBG_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wOfkUzz3lCgtHHEz.jpg" target="_blank" data-width="1592" data-height="1000" ><img src="https://tpucdn.com/img/wOfkUzz3lCgtHHEz_thm.jpg" width="207" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301177/alphacool-unveils-core-storm-and-core-hurrican-liquid-cooling-sets">Read full story</a></div>
CaseLabs is Back in Business Under New Management
For those of you familiar with CaseLabs, the demise of the company in 2018 was most likely a sad time when it comes to the history of PC component manufacturers. However, it appears that the company is back in business, under new management and in a new location. CaseLabs was originally from California in the US, but the new owners have moved the company to Sweden. In fact, the key person is said to be a CaseLabs enthusiast by the name of Emil Rytterstedt who bought the rights to the CaseLabs brand in 2021, as well as what appears to be the rights for all of the products that the original company made. For now, the CaseLabs website is back up and running, but the company isn't selling any products, yet.<br />
<br />
Based on the information available on the CaseLabs website, the company will initially offer spare parts for existing CaseLabs products, as well as offer support and customer service through it. This will be followed by at least some of the cases that CaseLabs used to offer, which will see some updates, especially when it comes to the I/O options and some other additions such as vertical GPU brackets. However, the longer term plan is to offer new products under the CaseLabs brand, which will apparently start with a smaller form factor case. All the new products will apparently be made in Sweden, so expect CaseLabs products to remain in the premium price segment. For those in the US, the company has already mentioned that the prices will be more expensive than in the past, due to shipping costs. Expect things to kick off sometime in early 2023 when it comes to actual product availability.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/MoKA2VETEgCAv68E.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/MoKA2VETEgCAv68E_thm.jpg" width="130" height="130" alt="" /></a></div>
PowerColor Shows Off the Radeon RX 7900 Red Devil on Social Media
Although we're only some three weeks away from the launch of AMD's Radeon RX 7000-series cards, it has been pretty quiet from its partners. That said, PowerColor has finally revealed more than just a tiny detail of its upcoming Radeon RX 7900 Red Devil via a post on Facebook. The company didn't reveal any specs and it's unclear if this will be an RX 7900 XT or an RX 7900 XTX based card.<br />
<br />
What we can see from the picture is that it's a triple-slot card with air being vented out the rear, something AMD's reference cards don't do. It's obviously a triple-fan card and PowerColor has equipped it with some LED lights as one would expect. Not much else is revealed by the single picture of the card, due to the angle the card sits at, so we don't know what kind of ports to expect, or what kind of power connectors the card will have. Hopefully PowerColor will reveal more details before the official launch on the 13th of December.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6N5MJKVmHufKYyb6.jpg" target="_blank" data-width="1200" data-height="1200" ><img src="https://tpucdn.com/img/6N5MJKVmHufKYyb6_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OqPw3n2NpiS5sX0p.jpg" target="_blank" data-width="860" data-height="1170" ><img src="https://tpucdn.com/img/OqPw3n2NpiS5sX0p_thm.jpg" width="96" height="130" alt="" /></a></div>
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
(PR) Intel Elects Barbara G. Novick to Board of Directors
Intel Corporation today announced that Barbara G. Novick, co-founder and senior advisor at BlackRock Inc., was elected to its board of directors, effective Dec. 1, 2022. Novick will serve as an independent director and join the board's Audit & Finance and Compensation committees. "As co-founder and leader of one of the world's most successful investment firms, Barbara brings a unique perspective to Intel's board," said Omar Ishrak, chairman of the Intel board. "With her deep experience in investment and finance as well as broad business acumen, Barbara will be a strong advocate for the interests of our stockholders as Intel continues its transformation."<br />
<br />
Novick, 62, co-founded BlackRock in 1988 and continued as its vice chairman until February 2021, when she transitioned to senior advisor. In 2009, she established BlackRock's Global Government Relations and Public Policy Group to provide a voice for investors, which she headed until 2021; and from 2018 to 2020, she additionally oversaw BlackRock's Global Investment Stewardship team.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/tNWmm54X1Eondgyf.jpg" target="_blank" data-width="690" data-height="960" ><img src="https://tpucdn.com/img/tNWmm54X1Eondgyf_thm.jpg" width="93" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301350/intel-elects-barbara-g-novick-to-board-of-directors">Read full story</a></div>
(PR) Projected YoY Growth Rate of Server Shipments for 2023 Has Been Revised Down to 2.8% as Inventory Adjustments Continue
Based on the latest data and research, TrendForce has further corrected down the projected YoY growth rate of whole server shipments for 2023 to 2.8%. Three factors are behind this revision. First, lead time has started to return to its usual length for most orders related to server components from 3Q23 onward. Seeing this, server OEMs and cloud service providers (CSPs) have also begun to correct the component mismatch issue by lowering demand for items that are in excess while maintaining a constant inventory level for items that are still in tight supply. This development, in turn, has reduced the flow of server orders going to ODMs. Second, the wave of demand that was generated earlier from the effects of the COVID-19 pandemic is dissipating. Hence, expansion activities have cooled off noticeably for services such as video streaming, e-commerce, etc. Among CSPs, Meta, Google, and ByteDance (TikTok) have lowered their server procurement quantities for next year. Lastly, the global economic outlook has remained fairly negative, so companies across most industry sectors have formulated a more conservative expenditure plan and scaled back IT-related spending for next year.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/eQYWkimJ6Gm0fGg1.jpg" target="_blank" data-width="640" data-height="360" ><img src="https://tpucdn.com/img/eQYWkimJ6Gm0fGg1_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301347/projected-yoy-growth-rate-of-server-shipments-for-2023-has-been-revised-down-to-2-8-as-inventory-adjustments-continue">Read full story</a></div>
(PR) GPU Sales See Biggest Quarterly Drop Since 2009 Recession: JPR
Jon Peddie Research reports the growth of the global PC-based graphics processor unit (GPU) market reached 75.5 million units in Q3'22 and PC CPU shipments decreased by -19% year over year. Overall, GPUs will have a compound annual growth rate of 2.8% during 2022-2026 and reach an installed base of 3,138 million units at the end of the forecast period. Over the next five years, the penetration of discrete GPUs (dGPUs) in the PC will grow to reach a level of 26%.<br />
<br />
Year-to-year total GPU shipments, which include all platforms and all types of GPUs, decreased by -25.1%, desktop graphics decreased by -15.43%, and notebooks decreased by -30%—the biggest drop since the 2009 recession. AMD's overall market share percentage from last quarter decreased by -8.5%, Intel's market share increased by 10.3%, and NVIDIA's market share decreased by -1.87%, as indicated in the following chart.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8RhecKU4cpeZ6BZE.jpg" target="_blank" data-width="465" data-height="481" ><img src="https://tpucdn.com/img/8RhecKU4cpeZ6BZE_thm.jpg" width="126" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TDJowXr7CUjs6Afj.jpg" target="_blank" data-width="495" data-height="323" ><img src="https://tpucdn.com/img/TDJowXr7CUjs6Afj_thm.jpg" width="199" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301346/gpu-sales-see-biggest-quarterly-drop-since-2009-recession-jpr">Read full story</a></div>
(PR) Akasa Announces the SOHO H6L and Alucia H6L Low-profile CPU Coolers
Akasa, a leading provider of active CPU cooling solutions has recently produced a new low-profile CPU cooler, capable of taming some of the most powerful CPUs on the market. The SOHO H6L and Alucia H6L are both rated at 130 W TDP, making them the perfect choice for high-performance, small form factor PC builds. 67.2 mm. Akasa's newest coolers are made up of premium heat sinks with six heat pipes to help disperse the heat from the processors. This allows for an efficient transfer of heat; the small and mighty coolers can handle up to 110 W TDP CPUs (such as Intel i9 12900T, and AMD's Ryzen 9 5900). Complete your Mini-ITX or thin Mini-ITX motherboard builds using these high-performance coolers.<br />
<br />
Compatibility is not an issue for the SOHO and Alucia H6L coolers, as mounting kits are included inside each package for LGA 1700, AM5, and almost all previous socket sizes (LGA 1200 and 15XX, and AM4). The mechanism is easy to install, simply follow the instructions in the manual to set up the cooler for each socket type. The SOHO AR fan included with SOHO H6L has an iconic, minimalist, neon-style aRGB ring, with over 16 million lighting combinations. The aRGB connects using a three-pin 5 V header, seamlessly controlled using all major RGB control software such as Gigabyte RGB Fusion, MSI Mystic Light, ASUS AURA, ASRock Polychrome and Razer Chroma RGB. Akasa also provides aRGB controllers if the motherboard does not include them, which are an excellent addition to any colorful build (for example, product code AK-RLD-04).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/YdHqFMRJjzTv7tQy.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/YdHqFMRJjzTv7tQy_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KUWkVXrAKiELGaUj.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/KUWkVXrAKiELGaUj_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NEH5vAb2LX5gB8gG.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/NEH5vAb2LX5gB8gG_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301344/akasa-announces-the-soho-h6l-and-alucia-h6l-low-profile-cpu-coolers">Read full story</a></div>
(PR) AxiomTek Unveils MANO561 Thin Mini-ITX LGA1700 Motherboard
Axiomtek—a world-renowned leader relentlessly devoted to the research, development, and manufacturing of innovative and reliable industrial computer products of high efficiency - is pleased to introduce the MANO561, a high-performance thin Mini-ITX motherboard built with LGA1700 socket for the 12th generation Intel Core processors (codename: Alder Lake-S). Aside from superior compute performance, this low-profile embedded motherboard delivers high-speed connectivity with flexible I/O, impressive graphics in support of triple displays, and high reliability by 12 V-24 V wide-range DC power to bridge the next-gen AIoT applications.<br />
<br />
Axiomtek's MANO561 is powered by the 12th generation Intel Core i9/i7/i5/i3, Intel Pentium Gold or Intel Celeron processors (up to 65 W) with the Intel H610 chipset. This embedded board has dual 260-pin DDR4-3200/2666/2400 SO-DIMM sockets with a total capacity of 64 GB. When it comes to display-related features, this motherboard along with Intel UHD graphics offers triple displays with two HDMI ports, one LVDS port, and one VGA port. Plus, it provides various wireless connectivity options which include 5G/4G/LTE connectivity with an M.2 Key B 2242/3042/3052 slot and seamless Wi-Fi connection with an M.2 Key E 2230 slot and a mini-PCIe slot. This motherboard also has a PCIe x16 slot for GPU, AI acceleration, and frame grabber card configurations.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/9srAZsGusJLaC8Jp.jpg" target="_blank" data-width="1150" data-height="610" ><img src="https://tpucdn.com/img/9srAZsGusJLaC8Jp_thm.jpg" width="245" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301337/axiomtek-unveils-mano561-thin-mini-itx-lga1700-motherboard">Read full story</a></div>
Thermalright Intros Phantom Spirit 120 SE CPU Cooler
Thermalright today introduced the Phantom Spirit 120 SE premium air-type CPU cooler. The cooler features a dual fin-stack (type-D) design. Seven 6 mm-thick nickel-plated copper heatpipes make indirect contact with the CPU through a nickel-plated C1100 mirror-finish copper base, passing through two aluminium fin-stacks. Two 120 mm fans are included, which can be installed that one of them pushes fresh air through the first fin-stack, while the second one acts as a conveyor, and is located between the two fin-stacks (typical type-D cooler arrangement).<br />
<br />
Each of the two included TL-C12B V2 fans takes in 4-pin PWM input, turn at speeds of up to 1,500 RPM, pushing up to 66.17 CFM of airflow, at 1.53 mm H₂O static pressure, and a maximum noise output of 25.6 dBA. The fans feature fluid dynamic bearings. With the fans installed, the Thermalright Phantom Spirit 120 SE measures 130 mm x 125 mm x 154 mm (LxWxH), weighing 1.03 kg. Among the CPU socket types supported are LGA1700, AM5, AM4, and LGA1200. The company didn't reveal pricing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/5Ig2DQNaQxiYnO8o.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/5Ig2DQNaQxiYnO8o_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bHvBScIhQzu0DVZH.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/bHvBScIhQzu0DVZH_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NDRy3P5aGmOMa0mp.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/NDRy3P5aGmOMa0mp_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/03md18SzthP3pqNa.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/03md18SzthP3pqNa_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/F2PoSGLrZdraxju8.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/F2PoSGLrZdraxju8_thm.jpg" width="130" height="130" alt="" /></a></div>
(PR) AMD and Analog Devices Resolve Patent Infringement Lawsuits
AMD and Analog Devices, Inc. today announced that they have resolved all their ongoing patent litigations, based on mutually agreed upon terms. As part of this resolution, the two companies have committed to pursue technology collaborations to bring next generation solutions to their communications and data center customers.<br />
<br />
For more than 50 years AMD has driven innovation in high-performance computing, graphics and visualization technologies. Billions of people, leading Fortune 500 businesses and cutting-edge scientific research institutions around the world rely on AMD technology daily to improve how they live, work and play. AMD employees are focused on building leadership high-performance and adaptive products that push the boundaries of what is possible. Analog Devices, Inc. operates at the center of the modern digital economy, converting real-world phenomena into actionable insight with its comprehensive suite of analog and mixed signal, power management, radio frequency (RF), and digital and sensor technologies. ADI serves 125,000 customers worldwide with more than 75,000 products in the industrial, communications, automotive, and consumer markets. ADI is headquartered in Wilmington, MA.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/E729UXziL63s89tE.jpg" target="_blank" data-width="677" data-height="480" ><img src="https://tpucdn.com/img/E729UXziL63s89tE_thm.jpg" width="183" height="130" alt="" /></a></div>
(PR) ECS Launches LEET Z790H7-A Motherboard and LEET B660 Barebone Gaming PC
ECS Industrial Computer Co., Ltd., also known as ECS IPC, is the subsidiary of leading motherboard and computer manufacturer Elitegroup Computer Systems (ECS). ECS IPC has joined hands with Intel to announce a new generation of Intel Raptor Lake Z790 series for LEET Z790H7-A motherboard and the other product of the latest LEET B660 gaming PC to satisfy gamers' passionate gaming experience and enhance the passionate gaming soul.<br />
<br />
The Z790H7-A motherboard provides excellent performance for gamers and professionals. It is compatible with Intel 12th and 13th generation Core processors (Raptor Lake-S & Alder Lake-S) as well as supports Windows 11 64-bit. With the Intel Z790 chipset as the strong backing for development, the Z790 chipset has further improved the overclocking function, which can support the performance requirements of one-click overclocking, and the Z790 chipset also supports the powerful performance of DDR5 memory and PCIe 5 transfer. DDR5 provides 50% higher bandwidth than DDR4 and also PCIe 5.0 increases the data rate from 16GT/s to 32GT/s, which is twice faster than PCIe 4.0.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Vl6QHsGBhktZH3aA.jpg" target="_blank" data-width="1082" data-height="1000" ><img src="https://tpucdn.com/img/Vl6QHsGBhktZH3aA_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/prFEI17DpTjJhVru.jpg" target="_blank" data-width="851" data-height="1000" ><img src="https://tpucdn.com/img/prFEI17DpTjJhVru_thm.jpg" width="111" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xkcMmHbC8X2h5guF.jpg" target="_blank" data-width="1498" data-height="1000" ><img src="https://tpucdn.com/img/xkcMmHbC8X2h5guF_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3WbtpUw7KfCw0B4A.jpg" target="_blank" data-width="1498" data-height="1000" ><img src="https://tpucdn.com/img/3WbtpUw7KfCw0B4A_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301333/ecs-launches-leet-z790h7-a-motherboard-and-leet-b660-barebone-gaming-pc">Read full story</a></div>
NVIDIA GeForce RTX 3060 Ti with GDDR6X to Replace Standard Model with GDDR6
NVIDIA recently updated its product stack with an 8 GB 128-bit GDDR6 variant of the GeForce RTX 3060 (originally 12 GB 192-bit GDDR6), and the RTX 3060 Ti with faster 19 Gbps 256-bit GDDR6X memory (originally 14 Gbps 256-bit GDDR6). We're getting to learn that the new RTX 3060 Ti GDDR6X variant is designed to replace the older GDDR6 variant. NVIDIA's add-in card (AIC) partners are reportedly winding down orders of the original RTX 3060 Ti in favor of the newer GDDR6X variant. Perhaps the most striking aspect of the GDDR6X variant isn't that its memory bandwidth is 35% higher than that of the original RTX 3060 Ti; but that it sells at the same price.<br />
<br />
The new GeForce RTX 3060 Ti GDDR6X is based on the 8 nm "GA104" silicon, and has the same core-configuration as the original RTX 3060 Ti, with 4,864 CUDA cores, 152 Tensor cores, 38 RT cores, 152 TMUs, and 80 ROPs; the same GPU boost frequency of 1665 MHz, and interestingly, the same typical board power of 200 W. What's changed is the switch to 19 Gbps GDDR6X memory compared to the original's 14 Gbps GDDR6, which results in a memory bandwidth of 608 GB/s, compared to the original's 448 GB/s.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/IWLpauuHu1fek57J.jpg" target="_blank" data-width="1024" data-height="707" ><img src="https://tpucdn.com/img/IWLpauuHu1fek57J_thm.jpg" width="188" height="130" alt="" /></a></div>
(PR) AAEON Launches NanoCOM-EHL SBC Powered by Intel "Elkhart Lake" Processors
AAEON, a leading Computer-on-Modules developer, has launched the NanoCOM-EHL, a COM Express Type 10 CPU Module, to its multiplatform range of products powered by Intel Atom x6000E, Celeron, and Pentium N and J series processors (formerly Elkhart Lake). The NanoCOM-EHL utilizes power-efficient 12 W Intel Atom, Pentium, and Celeron processors with onboard LPDDR4 system memory of up to 16 GB on the compact 3.31" x 2.17" (84 mm x 55 mm) COM Express Type 10 form factor. The module also has the option of 64 GB of onboard eMMC storage.<br />
<br />
An impressive feat considering its small size is the NanoCOM-EHL's capacity to host multiple expansion modules via its four PCIe slots, which when combined with its processing power and small form factor makes it suitable for semiconductor test equipment use. In addition to its power and expandability are the I/O features it contains, with two high-speed (10 Gbps) USB 3.2 slots, eight USB 2.0 slots, and a dual LVDS/eDP display output complimenting 2.5GbE and a high-definition audio output interface.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/U6NGdnm3Wm58y2pI.jpg" target="_blank" data-width="600" data-height="400" ><img src="https://tpucdn.com/img/U6NGdnm3Wm58y2pI_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301331/aaeon-launches-nanocom-ehl-sbc-powered-by-intel-elkhart-lake-processors">Read full story</a></div>
TSMC's Morris Chang Says Arizona Fab Will Produce 3 nm Chips in the Fu
Although Morris Chang is no longer in charge of the day to day business at TSMC, the founder of the company is still getting his hands dirty. Chang attended the APEC Economic Leaders Meeting last week, as part of Taiwan's delegation and was questioned by the media about TSMC's future plans. The specific question was about TSMC's Arizona fab, which will initially produce chips using a 5 nm node. The US$12 billion plant is scheduled to kick off production at some point in 2024, by which time the 5 nm node should be a commonly used node rather than close to cutting edge. <br />
<br />
When questioned about the future of the Arizona fab, Morris Chang answered that it will be moving to a 3 nm node, which is currently TSMC's most cutting edge node, that has gone into volume production earlier this year with th N3 node, which is set to be followed by the N3E node. According to Chang, there's interest by several countries to have TSMC set up fabs there, but apparently this is not something TSMC is considering at the moment. One potential reason for this would be a suitable labour force, something that has already proven to be tough for the Arizona fab.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ZuicaLsEKczwxCM4.jpg" target="_blank" data-width="1024" data-height="711" ><img src="https://tpucdn.com/img/ZuicaLsEKczwxCM4_thm.jpg" width="187" height="130" alt="" /></a></div>
(PR) Horror VR Project: Nightlight Coming Q1 2023
Fringe Realities are pleased to announce that their atmospheric horror VR game Project: Nightlight is planning to be released on Steam VR with a release window of Q1 2023. Project: Nightlight sees the player take control of a nightguard, unravelling the mysteries of The Department and the secrets it's trying to keep from going public. When something is amiss with the contained Artifact, the player will be guided by the distressed co-worker Dave over the walkie-talkie.<br />
<br />
Project: Nightlight aims to provide a whole new level of immersion thanks to the unique capabilities of virtual reality. The game allows the player to interact with objects with an acute attention to real-life accuracy, such as handling bolt cutters or melting locks with a blowtorch. Further details will be provided in the leadup to the launch of Project: Nightlight on Steam VR in Q1 2023. For more information and future updates, they'll be available on the official Twitter page @FringeRealities.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/5E4lwJfaFrHWOUhl.jpg" target="_blank" data-width="832" data-height="468" ><img src="https://tpucdn.com/img/5E4lwJfaFrHWOUhl_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jCLgXdNloD3kLBCD.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/jCLgXdNloD3kLBCD_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vXi4cbkaehUrWAlY.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/vXi4cbkaehUrWAlY_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KzukhCAhFJsNYln9.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/KzukhCAhFJsNYln9_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301312/horror-vr-project-nightlight-coming-q1-2023">Read full story</a></div>
(PR) Philips Unveils 27B1U7903 Mini-LED Monitor with Thunderbolt 4 Support
Creative professionals and artists work in multifarious ways and look for solutions that meet their individual and specific needs to fully express their creativity. To support them in their work they require a powerful monitor that can ensure performance-boosting features, high-quality visuals, and comfortable connectivity.<br />
<br />
MMD, the leading display specialist and brand license partner for Philips monitors, today launches the Philips 27B1U7903, a 4K MiniLED Thunderbolt 4 monitor that combines outstanding picture performance with secure one-cable docking, uses sustainable materials in its components and packaging, and comes in a stylish design. Packed with high-performance features to enable professionals to reach new levels of productivity, the Philips 27B1U7903 is also the first Philips monitor to feature Thunderbolt 4 technology for a next-generation connectivity.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/38seYiPKl6kH4g3O.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/38seYiPKl6kH4g3O_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/swhpNqU6IUbRDLrc.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/swhpNqU6IUbRDLrc_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/g3VZErtddowWqyot.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/g3VZErtddowWqyot_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nfYo0T9TSm3SnGUz.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/nfYo0T9TSm3SnGUz_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a0sedTZMUonebi1X.jpg" target="_blank" data-width="1791" data-height="1000" ><img src="https://tpucdn.com/img/a0sedTZMUonebi1X_thm.jpg" width="233" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301311/philips-unveils-27b1u7903-mini-led-monitor-with-thunderbolt-4-support">Read full story</a></div>
LG Launches the UltraGear OLED With 240 Hz Refresh Rate
The first flat OLED gaming monitor is here and it's unsurprisingly from LG and part of its UltraGear range of gaming products. Although it's being touted as a 27-inch display, the screen size is only 26.5-inches, which is a bit unusual. The resolution is 2560 x 1440, with a pixel pitch of 110.8 PPI and the refresh rate goes up to 240 Hz. The OLED panel is capable of delivering 1.07 billion colours and delivers a colour gamut of 98.5 percent of the DCI-P3 standard. LG claims the display has a GtG response time of 0.03 ms which is so far unheard of on a consumer display. LG doesn't supply a brightness rating, nor does the UltraGear OLED appear to have any kind of HDR certification, but supports HDR10, although considering it's an OLED panel, this shouldn't be much of a concern. <br />
<br />
There's support for FreeSync Premium and VRR, with the display being G-Sync compatible as well. Other gaming related features include the typical things you'd find on most gaming displays today, such as an FPS counter, a built in crosshair and of course some RGB lighting features. Connectivity wise the UltraGear OLED comes with two unspecified HDMI ports and one unspecified DisplayPort input, as well as one upstreams USB 3.0 port (Type-B) and two downstreams USB 3.0 ports (Type-A). The monitor also has an S/PDIF out and a headset jack, which suggests that it does audio over USB. Finally there's a barrel plug for the 19 V power brick. The display also has support for DTS HP:X where HP stands for headphones, but there are no built in speakers. The stand supports tilt, height, swivel and pivot adjustments and can be adjusted up to 11 cm in height. LG is asking US$999.99 for the UltraGear OLED, which might be a bit more than what most people would be willing to pay for it, but it's at least a first step towards a range of new OLED gaming monitors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/0CcsorwUCWkVEbcp.jpg" target="_blank" data-width="816" data-height="764" ><img src="https://tpucdn.com/img/0CcsorwUCWkVEbcp_thm.jpg" width="139" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/si7hf2H9rsBiE25I.jpg" target="_blank" data-width="758" data-height="750" ><img src="https://tpucdn.com/img/si7hf2H9rsBiE25I_thm.jpg" width="131" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nmrY3SlLmgWu5KsV.jpg" target="_blank" data-width="390" data-height="762" ><img src="https://tpucdn.com/img/nmrY3SlLmgWu5KsV_thm.jpg" width="67" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JV2761hL851eIvRv.jpg" target="_blank" data-width="1446" data-height="960" ><img src="https://tpucdn.com/img/JV2761hL851eIvRv_thm.jpg" width="196" height="130" alt="" /></a></div>
AMD Ryzen 7000 Series Processors Get their First Round of Price Cuts, 7950X at $574
AMD Ryzen 7000-series "Zen 4" desktop processors got their first round of price-cuts on leading retailer Newegg, as the company has a hard time justifying their launch-prices in the wake of Intel's 13th Gen Core "Raptor Lake" and declining demand in the PC components market. The new pricing sees the top Ryzen 9 7950X 16-core/32-thread chip priced at USD $574, down from $700 (an 18% price-cut). The 12-core/24-thread Ryzen 9 7900X sees its price go down from $550 to $474 (down 14%). <br />
<br />
The 8-core/16-thread Ryzen 7 7700X gets a $50 price-cut sending its price down from $400 to roughly $350. The 6-core/12-thread Ryzen 5 7600X gets a similar $50 cut, which means the chip can now be had for roughly $250, down from its $300 launch price. All four SKUs face stiff competition from the aggressively priced 13th Gen Core SKUs, which include the i9-13900K, the i7-13700K, and the i5-13600K. Prices of Socket AM5 motherboards are another big put-off as they're a major contributor to platform costs, which is restricted to DDR5 memory. The Intel platform currently includes entry-level chipset options, as well as motherboards with DDR4 support.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/21XIsSq8Jy7Yqspo.jpg" target="_blank" data-width="2139" data-height="895" ><img src="https://tpucdn.com/img/21XIsSq8Jy7Yqspo_thm.jpg" width="311" height="130" alt="" /></a></div>
(PR) EK Releases Water Blocks for Zotac RTX 4090 and RTX 4080 AMP AIRO and Trinity
EK, the premium liquid cooling gear manufacturer, is now introducing the ultimate water cooling solution for Zotac AMP Extreme AIRO and Trinity GeForce RTX 4080 and 4090 graphics cards. Zotac's RTX 4090 cards get a water block with a passive backplate or a cooling solution with an active backplate that's sandwiching the card between two water blocks for the best possible cooling results. Zotac's RTX 4080 AMP Extreme and Trinity graphics cards get only a standard water block solution with a passive backplate and no active backplate.<br />
<br />
The EK-Quantum Vector² AMP/Trinity RTX 4090 and EK-Quantum Vector² AMP/Trinity RTX 4080 are single-package liquid cooling solutions consisting of a Vector² series water block and a black-anodized aluminium backplate. As with the previous 30-series Vector² water blocks, its aesthetics are dominated by minimalistic straight lines and the backplate coming around the side of the GPU to cover the PCB completely.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/IjjVDl6l7HmIFBFY.jpg" target="_blank" data-width="1600" data-height="1067" ><img src="https://tpucdn.com/img/IjjVDl6l7HmIFBFY_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SmGLwIOlCcnp7ZW8.jpg" target="_blank" data-width="1600" data-height="1067" ><img src="https://tpucdn.com/img/SmGLwIOlCcnp7ZW8_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mqIRkvDzmZs2LdpI.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/mqIRkvDzmZs2LdpI_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/301301/ek-releases-water-blocks-for-zotac-rtx-4090-and-rtx-4080-amp-airo-and-trinity">Read full story</a></div>
