Oscam-1.00-svn4425
r4425 | _network | 2011-01-12 16:36:51 +0100 (Wed, 12 Jan 2011) | 2 lines
stapi: use protocol=stapi for internal cardreader with stapi driver
r4424 | schlocke | 2011-01-12 14:55:48 +0100 (Wed, 12 Jan 2011) | 3 lines
cleaned oscam-simples.c
webif/XMLAPI fix APISTATUSBITS
Oscam-1.00-svn4428
r4428 | alno | 2011-01-12 20:05:30 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: Configuration Buttons 'ok'->'Save'
r4427 | alno | 2011-01-12 19:43:22 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: remove redundant code by implementing a function sec2timeformat()
r4426 | _network | 2011-01-12 19:28:17 +0100 (Wed, 12 Jan 2011) | 2 lines
WebIf: add support for new cardreader framework
r4432 | alno | 2011-01-12 20:55:42 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: Improve with defaults sec2timeformat function
r4431 | dingo35 | 2011-01-12 20:52:14 +0100 (Wed, 12 Jan 2011) | 1 line
sc8in1: remove compiler warning
Oscam-1.00-svn4438
r4438 | schlocke | 2011-01-12 23:49:53 +0100 (Wed, 12 Jan 2011) | 2 lines
client cleanup now reverse
r4437 | alno | 2011-01-12 22:52:14 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: fix format issue 00: in times
r4436 | schlocke | 2011-01-12 22:17:42 +0100 (Wed, 12 Jan 2011) | 2 lines
cleanup clients on exit
r4435 | alno | 2011-01-12 22:14:48 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: further try to fix the crash in user view on some systems. Unfortunately I cannot reproduce the issue on my system
r4434 | alno | 2011-01-12 21:54:09 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: fix possible issue with sprintf
r4433 | alno | 2011-01-12 21:41:57 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: fix possible issue with to small malloc
r4439 | Admin | 2011-01-12 23:54:59 +0100 (Wed, 12 Jan 2011) | 1 line
WebIf: Fix remaining source indents and some small HTML faults.
r4440 | Admin | 2011-01-13 00:22:19 +0100 (Thu, 13 Jan 2011) | 1 line
Fix: Linked list crashes when NULL is given to ll_clear_data (like ac_clear may do)
r4441 | _network | 2011-01-13 22:25:31 +0100 (Thu, 13 Jan 2011) | 2 lines
camd35tcp: add workaround for cmd05
Oscam-1.00-svn4443
r4443 | schlocke | 2011-01-13 23:10:37 +0100 (Thu, 13 Jan 2011) | 2 lines
oscam stop: cleaning first clients, then readers
r4442 | schlocke | 2011-01-13 23:02:14 +0100 (Thu, 13 Jan 2011) | 3 lines
cccam: speed up by using less locks
cccam: passwd length enlarged to 64
Oscam-1.00-svn4445
r4445 | alno | 2011-01-14 02:40:42 +0100 (Fri, 14 Jan 2011) | 1 line
WebIf: restore Javascript tag in pagehead
r4444 | alno | 2011-01-14 02:09:12 +0100 (Fri, 14 Jan 2011) | 1 line
XMLAPI: fix missing space in cccam cards
r4446 | alno | 2011-01-13 21:21:13 +0100 (Thu, 13 Jan 2011) | 1 line
WebIf: fix Javascript tag in pagehead
r4447 | alno | 2011-01-13 22:35:51 +0100 (Thu, 13 Jan 2011) | 1 line
XMLAPI: add host/port to reader tag in cccam entitlement
Oscam-1.00-svn4450
r4450 | schlocke | 2011-01-14 11:54:06 +0100 (Fri, 14 Jan 2011) | 2 lines
cccam: mimizedcards=2 now also reports providers
r4449 | schlocke | 2011-01-14 11:40:52 +0100 (Fri, 14 Jan 2011) | 2 lines
garbage collector fix
r4448 | schlocke | 2011-01-14 10:57:10 +0100 (Fri, 14 Jan 2011) | 3 lines
waitcardsforinit - try fix?
Oscam-1.00-svn4460
r4460 | schlocke | 2011-01-14 16:23:59 +0100 (Fri, 14 Jan 2011) | 2 lines
misses commit
r4459 | schlocke | 2011-01-14 16:23:06 +0100 (Fri, 14 Jan 2011) | 5 lines
dyndnsclient/resolvedelay parameter removed because not longer used.
resolvedelay-thread has been removed long time ago and
dyndnsclient-option now not nessesary, dyndns is used if account has a
dyndns address
r4458 | dingo35 | 2011-01-14 16:12:02 +0100 (Fri, 14 Jan 2011) | 1 line
revert 4177 since it causes problems on several platforms
r4457 | schlocke | 2011-01-14 16:01:33 +0100 (Fri, 14 Jan 2011) | 2 lines
cccam typo fix
r4456 | schlocke | 2011-01-14 15:57:05 +0100 (Fri, 14 Jan 2011) | 2 lines
changed malloc to cs_malloc
r4455 | dingo35 | 2011-01-14 15:33:22 +0100 (Fri, 14 Jan 2011) | 1 line
oscam.c Small code optimizations
r4454 | dingo35 | 2011-01-14 15:29:07 +0100 (Fri, 14 Jan 2011) | 1 line
reader-irdeto.c, reader-seca.c : Retry ECM when unexpected result occurs
r4453 | dingo35 | 2011-01-14 15:28:01 +0100 (Fri, 14 Jan 2011) | 1 line
icc_async.c : Retry ECM when read error (timeout) occurred
r4452 | dingo35 | 2011-01-14 15:14:40 +0100 (Fri, 14 Jan 2011) | 1 line
modules* reinstall card_status for proxy handling thanks to Schlocke
r4451 | dingo35 | 2011-01-14 14:26:22 +0100 (Fri, 14 Jan 2011) | 1 line
Fix waitforcards; card_status may only be set by the physical reader, NOT any client! Also calling checkhealth before reader thread is started is not a good idea
Oscam-1.00-svn4462
r4462 | alno | 2011-01-14 20:01:06 +0100 (Fri, 14 Jan 2011) | 1 line
Log: Fix related Ticket #1350 (wrong order of IP Addresses)
r4461 | landlord | 2011-01-14 19:53:57 +0100 (Fri, 14 Jan 2011) | 1 line
Removed 'resolvedelay' parameter from documentation.
Oscam-1.00-svn4468
r4468 | Admin | 2011-01-14 22:03:57 +0100 (Fri, 14 Jan 2011) | 1 line
WebIf: Add total ecm count output like suggested in #1231. Fix crash when requested reader doesn't exist in readerstats
r4467 | alno | 2011-01-14 21:44:00 +0100 (Fri, 14 Jan 2011) | 1 line
Config: add parameter 'user' to readerconfig. Please use 'user' AND 'password' instead of 'account' to avoid issues with coma in one of both. WebIf will save the account data in the two separate fields too from now
r4465 | Admin | 2011-01-14 21:27:09 +0100 (Fri, 14 Jan 2011) | 1 line
Add missing file for wrt350
r4464 | Admin | 2011-01-14 21:25:59 +0100 (Fri, 14 Jan 2011) | 1 line
Add support for WRT350Nv2. Thanks to Madmaxx in #1288.
r4463 | Admin | 2011-01-14 21:12:49 +0100 (Fri, 14 Jan 2011) | 1 line
Add possibility to split long lines in config files by adding a \ before the line break. Thanks to "nder" in #1325
