(PR) Alphacool Announces Eiswolf 2 AIO for Gigabyte RTX 3080/3090 & Sa
Alphacool today presents the Eiswolf 2 "All-in-One" solution for Geforce RTX 3080/3090 Gigabyte Aorus Master/Xtreme and Radeon RX 6800XT/6900XT Sapphire Nitro+graphics cards. The Eiswolf 2 uses the Alphacool 360 mm NexXxoS ST30 full copper radiator. For the fans, we use the 120 mm Alphacool Aurora Rise. This impressive fan with a max. static pressure of 3.17 mm/H2O, offers a max. air flow of 119.8m³/h. The speed range of the fan, from 0-2500rpm, is adjustable via PWM. The AIO is completed by the Eisblock Aurora water cooler. This not only cools the GPU chip, but actively cools all relevant components such as the memory and VRAM. It also has brilliant aRGB lighting. <br />
<br />
All components used (radiator, fan, cooler, DC-LT 2 pump) including fittings and tubing are part of the Alphacool DIY range and are therefore available separately. The combination of all components results in a solution that is as easy to install as an AIO, but offers the performance of a pre-assembled and pre-filled custom loop. Only the pump housing for the DC-LT 2 pump is a custom-made item that is only part of the scope of delivery of the AIO solution and is therefore not available separately.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/HBwWJP5nj3FUshIe.jpg" target="_blank" data-width="1200" data-height="800" ><img src="https://tpucdn.com/img/HBwWJP5nj3FUshIe_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3yQ7dTvQ1gDAX2Iv.jpg" target="_blank" data-width="1200" data-height="800" ><img src="https://tpucdn.com/img/3yQ7dTvQ1gDAX2Iv_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DCqBMVziS2a2vu6A.jpg" target="_blank" data-width="1200" data-height="800" ><img src="https://tpucdn.com/img/DCqBMVziS2a2vu6A_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2LjvqGvCYNvYWPX9.jpg" target="_blank" data-width="1200" data-height="800" ><img src="https://tpucdn.com/img/2LjvqGvCYNvYWPX9_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288424/alphacool-announces-eiswolf-2-aio-for-gigabyte-rtx-3080-3090-sapphire-rx-6800xt-6900xt">Read full story</a></div>
(PR) Scythe Announces Mugen 5 S CPU Cooler
Scythe announces the release of the new Mugen 5 S CPU cooler (SCMG-5100W). Equipped with a new Wonder Snail 120 fan, the Mugen 5 S offers greater cooling performance and less noise compared with the Mugen 5 Rev.B cooler. The Mugen 5 S comes with a new mounting system (H.P.M.S.III-S), which provides straightforward installation and optimal contact pressure. The Mugen 5 S cooler has an of 54.99 USD.<br />
<br />
With a new WS-120 fan, the Mugen 5 S offers greater cooling performance and less noise than the Rev.B. The new mounting system (H.P.M.S.III-S) supports most modern sockets on the market, and provides more straightforward installation and optimal contact pressure. With a new WS-120 fan, the Mugen 5 S offers greater cooling performance and less noise than the Rev.B. The new mounting system (H.P.M.S.III-S) supports most modern sockets on the market, and provides more straightforward installation and optimal contact pressure.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/THGc5vttX7V6RvHf.jpg" target="_blank" data-width="958" data-height="960" ><img src="https://tpucdn.com/img/THGc5vttX7V6RvHf_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XAc4iP5POzYtk1mx.jpg" target="_blank" data-width="961" data-height="960" ><img src="https://tpucdn.com/img/XAc4iP5POzYtk1mx_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CMl6qTHfGowplZ09.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/CMl6qTHfGowplZ09_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/9gDfjBQCvFZ3uV0U.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/9gDfjBQCvFZ3uV0U_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/d4uLbLXGNpPY81lJ.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/d4uLbLXGNpPY81lJ_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288423/scythe-announces-mugen-5-s-cpu-cooler">Read full story</a></div>
(PR) Raspberry Pi Zero 2 W on sale now at $15
It's been nearly six years since we unleashed the $5 Raspberry Pi Zero on an unsuspecting world. Of all the products we've launched, Zero is still the one I'm proudest of: it most perfectly embodies our mission to give people access to tools, and to eliminate cost as a barrier. We've sold nearly four million units of Zero, and its $10 wireless-enabled big brother Zero W, and they've made their way into everything from smart speakers to hospital ventilators. But where our larger products have grown steadily more powerful over the years, we've never found a way to pack more performance into the Zero form factor. Until today.<br />
<br />
Priced at $15, Raspberry Pi Zero 2 W uses the same Broadcom BCM2710A1 SoC die as the launch version of Raspberry Pi 3, with Arm cores slightly down-clocked to 1GHz, bundled into a single space-saving package alongside 512 MB of LPDDR2 SDRAM. The exact performance uplift over Zero varies across workloads, but for multi-threaded sysbench it is almost exactly five times faster.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2iR6f3ssoTX1UR9l.jpg" target="_blank" data-width="1280" data-height="627" ><img src="https://tpucdn.com/img/2iR6f3ssoTX1UR9l_thm.jpg" width="265" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/S1Qbi73DI6aknX45.jpg" target="_blank" data-width="1280" data-height="866" ><img src="https://tpucdn.com/img/S1Qbi73DI6aknX45_thm.jpg" width="192" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288396/raspberry-pi-zero-2-w-on-sale-now-at-usd-15">Read full story</a></div>
(PR) Linsoul Introduces the Peacock Flight: Hand-Crafted Professional True Wireless Stereo (TWS) Earphones
Linsoul Audio has been striving to bring the acoustic performance of professional in-ear monitors to the public. After two years of putting passion for perfection to the test and engineering, Linsoul has worked in conjunction with Peacock Audio to introduce the Peacock Flight, which is a superior hand-crafted set of true wireless earphones. Each Peacock Flight unit is handcrafted from start to finish, from the shell molding process to the wiring of the drivers. This is a bespoke design, which makes the earphones be a true one-of-a-kind artwork. The engineering and tuning process is meticulously conducted, and strict testing of each driver component ensures the greatest precision and quality control. <br />
<br />
Acoustic performance always comes first on priorities for earphones. Equipped with a Qualcomm aptX HD-compatible chipset, the Peacock Flight supports aptX codecs, which ensures crystal clear sound production with extremely low latency. What's more, the Qualcomm QCC3040 Bluetooth chipset brings a stable connection to achieve the most coherent connection and listening experience. On top of that, the Peacock Flight is also equipped with Qualcomm's latest Clear Voice Capture (CVC) 8.0, which is a noise reduction algorithm that effectively filters out background noise to reduce up to 30 dB of unwanted ambient sound during phone calls. By accurately calculating the position of the caller in relation to environmental sounds, CVC 8.0 allows a pure sound transmission for cleaner and more audible calls.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ufGTOxR8j7OkHXca.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/ufGTOxR8j7OkHXca_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/a5TueKlss0kUwOxS.jpg" target="_blank" data-width="1562" data-height="960" ><img src="https://tpucdn.com/img/a5TueKlss0kUwOxS_thm.jpg" width="212" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IQpJrYtGmu85qWrn.jpg" target="_blank" data-width="1529" data-height="960" ><img src="https://tpucdn.com/img/IQpJrYtGmu85qWrn_thm.jpg" width="207" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Sdp2CL0Q0rqbvxII.jpg" target="_blank" data-width="1456" data-height="960" ><img src="https://tpucdn.com/img/Sdp2CL0Q0rqbvxII_thm.jpg" width="197" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/yORoZ0dFS95hX1uh.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/yORoZ0dFS95hX1uh_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288386/linsoul-introduces-the-peacock-flight-hand-crafted-professional-true-wireless-stereo-tws-earphones">Read full story</a></div>
(PR) Beauty Meets Brawn: Unleashing the New XPS Desktop
XPS is one of the most coveted brands in the PC industry, lauded for its seamless convergence of elegant design and cutting-edge technology - but there's always more to an XPS device than meets the eye. Nearly 42% larger than its predecessor (27L vs 19L), the new XPS desktop ushers in an expansive suite of next-gen performance technologies and a more robust cooling architecture, making this the most powerful XPS desktop ever made.<br />
<br />
With heavy hitter performance cloaked by an understated minimalist design, creators, gamers and virtually anyone who wants to amplify their passions can now own a sophisticated PC with workhorse performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/5dKFQ8G2YFSiefU0.jpg" target="_blank" data-width="1280" data-height="1055" ><img src="https://tpucdn.com/img/5dKFQ8G2YFSiefU0_thm.jpg" width="158" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3GeTMzu1Iq0IVJ7X.jpg" target="_blank" data-width="616" data-height="1280" ><img src="https://tpucdn.com/img/3GeTMzu1Iq0IVJ7X_thm.jpg" width="63" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KmagXIhQA5ThJqH8.jpg" target="_blank" data-width="1280" data-height="1074" ><img src="https://tpucdn.com/img/KmagXIhQA5ThJqH8_thm.jpg" width="155" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288392/beauty-meets-brawn-unleashing-the-new-xps-desktop">Read full story</a></div>
Intel Aurora Supercomputer Will Touch 2 ExaFLOPs of Computational Powe
Intel's Aurora supercomputer is a $500 million contract with the US Department of Energy to deliver an exascale supercomputer for Argonne National Laboratory. The project aims to build a machine capable of cranking over one ExaFLOP of computing at sustained workloads. The supercomputer aims to reach two ExaFLOPs of computing power once the installation system is completed and powered. The contract bound Intel to create accelerators that are powerful enough to achieve this magical number. However, they left Intel with room to do a little bit extra. With Ponte Vecchio GPU behind the project, it seems like the GPU is performing better than expected.<br />
<br />
According to Intel's CEO, Pat Gelsinger, the system will reach over 2 ExaFLOPs at peak and a bit below in sustained workloads. As per preliminary calculations done by The Next Platform, the system's estimations point towards 2.43 ExaFLOPs peak and around 1.7 ExaFLOPs in sustained workloads at Double-precision floating-point format math, aka FP64. The system will utilize Intel Xeon Sapphire Rapids processors with HBM memory and the powerful Ponte Vecchio GPU with 47 tiles and over 100 billion transistors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/s06zT53qDGQ7i9wn.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/s06zT53qDGQ7i9wn_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AjEZUjuQzmc34KIq.jpg" target="_blank" data-width="1706" data-height="960" ><img src="https://tpucdn.com/img/AjEZUjuQzmc34KIq_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DA30jxKRzIl86qy1.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/DA30jxKRzIl86qy1_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) SiPearl Partners With Intel to Deliver Exascale Supercomputer in Europe
SiPearl, the designer of the high computing power and low consumption microprocessor that will be the heart of European supercomputers, has entered into a partnership with Intel in order to offer a common offer dedicated to the first exascale supercomputers in Europe. This partnership will offer their European customers the possibility of combining Rhea, the high computing power and low consumption microprocessor developed by SiPearl, with Intel's Ponte Vecchio accelerator, thus creating a high performance computing node that will promote the deployment of the exascale supercomputing in Europe.<br />
<br />
To enable this powerful combination, SiPearl plans to use and optimize for its Rhea microprocessor the open and unified programming interface, oneAPI, created by Intel. Using this single solution across the entire heterogeneous compute node, consisting of Rhea and Ponte Vecchio, will increase developer productivity and application performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/0BG5ZPiZoKZWVhP1.jpg" target="_blank" data-width="650" data-height="425" ><img src="https://tpucdn.com/img/0BG5ZPiZoKZWVhP1_thm.jpg" width="199" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288382/sipearl-partners-with-intel-to-deliver-exascale-supercomputer-in-europe">Read full story</a></div>
Intel's Next-Generation "Raptor Lake-S" Could Carry Over DDR4 Platform
With Intel's Alder Lake processor generation launch, the platform merges support of two different DDR memory standards: DDR4 and DDR5. While there are motherboards that offer the latest DDR5 standard, there are boards that provide users to use the cheaper DDR4 memory option in their builds as we transition to the newer standard and newer memory becomes more available. The DDR5 products are currently on the expensive side, and DDR4 represents a good choice for creating a PC build in the following years, at least in the transition to DDR5 standard's better availability and lower prices.<br />
<br />
According to Moore's Law is Dead Twitter account, the DDR4 support may reside for a little longer on Intel's platforms. As per their sources, Intel's 13th generation Core processors, codenamed Raptor Lake, will carry over DDR4 platform support and possibly retain compatibility with the 12th generation Alder Lake platform. That means that the Z690 and future H670/B660/H610 boards could be compatible with Raptor Lake-S and also carry support for the DDR4 memory protocol for it. This could indicate that Alder Lake-S buyers that build PCs with DDR4 memory could have a viable processor upgrade path without upgrading the memory. Of course, information like this should be taken with a grain of salt.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/809bG77nZUg3FlW8.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/809bG77nZUg3FlW8_thm.jpg" width="231" height="130" alt="" /></a></div>
AMD Could Use Infinity Cache Branding for Chiplet 3D Vertical Cache
AMD in its Computex 2021 presentation showed off its upcoming "Zen 3" CCD (CPU complex dies) featuring 64 MB of "3D vertical cache" memory on top of the 32 MB L3 cache. The die-on-die stacked contraption, AMD claims, provides an up to 15% gaming performance uplift, as well as significant improvements for enterprise applications that can benefit from the 96 MB of total last-level cache per chiplet. Ahead of the its debut later today in the company's rumored EPYC "Milan-X" enterprise processor reveal, we're learning that AMD could brand 3D Vertical Cache as "3D Infinity Cache."<br />
<br />
This came to light when Greymon55, a reliable source with AMD and NVIDIA leaks, used the term "3D IFC," and affirmed it to be "3D Infinity Cache." AMD realized that its GPUs and CPUs have a lot of untapped performance potential with use of large on-die caches that can make up for much of the hardware's memory-management optimization. The RDNA2 family of gaming GPUs feature up to 128 MB of on-die Infinite Cache memory operating at bandwidths as high as 16 Tbps, allowing AMD to stick to narrower 256-bit wide GDDR6 memory interfaces even on its highest-end RX 6900 XT graphics cards. For CCDs, this could mean added cushioning for data transfers between the CPU cores and the centralized memory controllers located in the sIOD (server I/O die) or cIOD (client I/O die in case of Ryzen parts).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jiTQW2isG1yhqCoU.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/jiTQW2isG1yhqCoU_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) GIGABYTE Z690 AORUS Breaks Overclocking Records of Dual 8GHz on i9-12900K+DDR5
GIGABYTE Technology, one of the top global manufacturers of motherboards, graphics cards, and hardware solutions, announces today Z690 AORUS TACHYON motherboard with the latest 12th generation Intel Core i9 12900K processor and LN2 liquid nitrogen heat dissipation set the world-leading overclocking records of dual 8 GHz, which is 8000 MHz on i9-12900K CPU and 8300 MHz on DDR5 memories. GIGABYTE Z690 AORUS TACHYON motherboard designed by world-famous overclocker equips with plenty functions exclusively for extreme overclockers, which promise overclockers higher scores with easier operation, establishing GIGABYTE's leading role in overclocking on the Z690 motherboards.<br />
<br />
"GIGABYTE demonstrate its determination of returning to the overclocking glory with the launch of the Z590 AORUS TACHYON motherboard, and the release of the Z690 AORUS TACHYON further verified the continuation of GIGABYTE's overclocking pedigree on motherboards." said Jackson Hsu, Director of the GIGABYTE Channel Solutions Product Development Division. "Z690 AORUS TACHYON proves GIGABYTE's strong R&D strength on LN2 overclocking by the world records it created. We will definitely use Z690 AORUS TACHYON to create better overclocking performance, and can't wait to see that overclockers around the world use this motherboard to break more world records.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/EJUer0pljAXXmAaM.jpg" target="_blank" data-width="1200" data-height="660" ><img src="https://tpucdn.com/img/EJUer0pljAXXmAaM_thm.jpg" width="236" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ozKzYegQUyMsSqJh.jpg" target="_blank" data-width="1200" data-height="569" ><img src="https://tpucdn.com/img/ozKzYegQUyMsSqJh_thm.jpg" width="274" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288748/gigabyte-z690-aorus-breaks-overclocking-records-of-dual-8ghz-on-i9-12900k-ddr5">Read full story</a></div>
(PR) Xiaomi Introduces New Water Cooling Technology for Mobile Devices
Xiaomi today unveiled its latest breakthrough in heat dissipation - Loop LiquidCool Technology. Inspired by cooling solutions used in the aerospace industry, Loop LiquidCool Technology utilizes a capillary effect which draws liquid cooling agent to the heat source, vaporizes, and then disperses the heat efficiently towards a cooler area, until the agent condenses and is captured via a unidirectional closed looped channel. Compared to conventional vapor chambers solutions, this new technology has twice the cooling capabilities and ranks as the most efficient smartphone cooling solution. Xiaomi aims to bring Loop LiquidCool Technology to its products in H2 2022.<br />
<br />
This new technology features an annular heat pipe system that is composed of an evaporator, a condenser, a refill chamber, as well as gas and liquid pipes. Placed at heat sources, the evaporator has refrigerant that evaporates to gas when the smartphone is under high workload. The gas and airflow is then diffused to the condenser, where the gas condenses into liquid again. These liquids are absorbed and collected through tiny fibers in the refill chamber—which refills the evaporator—making it a self-sustaining system.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/AP5du0WMdu66AGnK.jpg" target="_blank" data-width="734" data-height="511" ><img src="https://tpucdn.com/img/AP5du0WMdu66AGnK_thm.jpg" width="187" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ulOK7NEyi264px0P.jpg" target="_blank" data-width="1412" data-height="625" ><img src="https://tpucdn.com/img/ulOK7NEyi264px0P_thm.jpg" width="294" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Wd51zHJbMMakUpcg.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/Wd51zHJbMMakUpcg_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288746/xiaomi-introduces-new-water-cooling-technology-for-mobile-devices">Read full story</a></div>
Intel Core i5-12400F Allegedly Offers Ryzen 5 5600X Performance for 200 USD
Intel has recently released their first 12th Gen Core desktop processors with the 125 W TDP K-Series and they appear to be preparing to launch the mid-range 65 W TDP chips in the coming months. The i5-12400F is set to feature 6 cores and threads consisting entirely of high-performance cores without any efficiency cores as found in the existing lineup. The processor features a peak single-core clock speed of 4.4 GHz, while multi-core speeds are 4.0 GHz and 3.4 GHz at PL2 and PL1 power limits respectively. The chip features a 65 W TDP/PL1 power rating and an apparent Maximum Turbo Power PL2 value of 117 W.<br />
<br />
This processor has reportedly been tested by French publication Comptoir Hardware where it consistently matched or surpassed the Ryzen 5 5600X in synthetic and gaming benchmarks. These benchmarks were run on Windows 11 with DDR5 memory running at an unspecified speed and an AMD Radeon RX 6900 XT GPU. We have recently seen a listing for the processor at a Canadian retailer which lists the i5-12400F for 249 CAD (200 USD) which if true would be a sizable jump from the 157 USD price of its predecessor but still significantly under the 280 USD Ryzen 5 5600X. The Intel Core i5-12400F is expected to be officially announced sometime in January 2022 possibly at CES 2022.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/SDuLJBfUfv2jwNlp.jpg" target="_blank" data-width="1606" data-height="960" ><img src="https://tpucdn.com/img/SDuLJBfUfv2jwNlp_thm.jpg" width="217" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lZ0vN2Vq68YPlukj.jpg" target="_blank" data-width="1209" data-height="402" ><img src="https://tpucdn.com/img/lZ0vN2Vq68YPlukj_thm.jpg" width="391" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Nn3KNRoH5kdA3K8D.jpg" target="_blank" data-width="1153" data-height="960" ><img src="https://tpucdn.com/img/Nn3KNRoH5kdA3K8D_thm.jpg" width="156" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LFh2xd7WfLFB1NfG.jpg" target="_blank" data-width="1153" data-height="960" ><img src="https://tpucdn.com/img/LFh2xd7WfLFB1NfG_thm.jpg" width="156" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lDleb3x9Sv3b3hFb.jpg" target="_blank" data-width="1153" data-height="960" ><img src="https://tpucdn.com/img/lDleb3x9Sv3b3hFb_thm.jpg" width="156" height="130" alt="" /></a></div>
(PR) NZXT Announces CRFT Mass Effect Puck
NZXT, a community-driven provider of PC hardware, software, and services today announces a new Puck in NZXT's CRFT series of fan-inspired licensed products based on the iconic space opera series, Mass Effect. This year NZXT is celebrating N7 Day in style. N7 day lands on November 7th each year and is aptly named after the Systems Alliance rank from the Mass Effect Trilogy.<br />
<br />
The NZXT Mass Effect Puck features the seal of the N7 special forces and designates each Puck owner's achievement of completing the training program of the highly sought-after special class. Not only is this special edition Puck a great way to showcase N7 Day pride, it's also a stylish way to store headsets, VR headsets, or cables magnetically on a PC case.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vkoFEFIsRK0srL4n.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/vkoFEFIsRK0srL4n_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HAXlXsTqDLfwlMXZ.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/HAXlXsTqDLfwlMXZ_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/mqmobHR1j48zQeAY.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/mqmobHR1j48zQeAY_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/arwkvh7v6eJz2Yzw.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/arwkvh7v6eJz2Yzw_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288744/nzxt-announces-crft-mass-effect-puck">Read full story</a></div>
Early Signs of AMD Ryzen 5000 Series Price Cuts Emerge
Performance reviews of the Intel 12th Gen Core "Alder Lake-S" processors are out, and spell big trouble for AMD Ryzen 5000 series processors at their current prices. Until the company can refresh these processors, it must content with price-cuts. Early signs of these are already out. American retailer Micro Center just put out a sub-$300 price for the Ryzen 7 5800X, at $299. Prices of the Ryzen 9 5900X and Ryzen 5 5600X remain unchanged, at $500 and $280, respectively, but it's only conceivable that these too will change. At current prices, the Core i7-12700K offers <a href="https://www.techpowerup.com/review/intel-core-i7-12700k-alder-lake-12th-gen/23.html" target="_blank">15% higher performance per Dollar</a> than the Ryzen 7 5800X.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LZI7TuAYvBYS426w.jpg" target="_blank" data-width="772" data-height="514" ><img src="https://tpucdn.com/img/LZI7TuAYvBYS426w_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/2aFY2F7GHTNkNXBP.jpg" target="_blank" data-width="799" data-height="446" ><img src="https://tpucdn.com/img/2aFY2F7GHTNkNXBP_thm.jpg" width="233" height="130" alt="" /></a></div>
(PR) Introducing Aonic Free: Shure's First True Wireless Earphones
Shure is unveiling the latest addition to its AONIC listening portfolio—AONIC FREE True Wireless Sound Isolating Earphones. Following up on the heels of the launch of AONIC 215 GEN 2, the AONIC FREE earphones introduce a new hook-free, pocketable design and unite it with the same unmatched studio quality sound that artists, audiophiles, commuters, technophiles, and music lovers have relied on from Shure's AONIC line. AONIC FREE boasts top-notch call performance in a sleek, lightweight, and compact design with long-lasting battery life, meaning these earphones are ready for an on-the-go lifestyle and the adventure that lies ahead.<br />
<br />
Engineered from decades of experience supporting legendary performers, AONIC FREE provides clear, studio-quality sound with deep bass. This class-leading sound is powered by a premium amplifier and driver combination that was rigorously tested and tuned together—providing an unparalleled listening experience tailored to user preferences. In a world where personalization is expected, listeners can express their musical identity by customizing their audio experience with the ShurePlus Play app's custom multi-band EQ and pre-sets.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/HByOxsE0icduv9mn.jpg" target="_blank" data-width="1600" data-height="900" ><img src="https://tpucdn.com/img/HByOxsE0icduv9mn_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5PNa6QnJcnNVOIBP.jpg" target="_blank" data-width="963" data-height="1263" ><img src="https://tpucdn.com/img/5PNa6QnJcnNVOIBP_thm.jpg" width="99" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288683/introducing-aonic-free-shures-first-true-wireless-earphones">Read full story</a></div>
Intel Disables DirectX 12 API Loading on Haswell Processors
Intel's fourth-generation Core processors, codenamed Haswell, are subject to new security exploits. According to the company, a vulnerability exists inside the graphics controller of 4th generation Haswell processors, happening once the DirectX 12 API loading occurs. To fix the problem, Intel has found that disabling this API results in a fix. Starting with Intel graphics driver 15.40.44.5107 applications that run exclusively on DirectX 12 API no longer work with the following Intel Graphics Controllers: Intel Iris Pro Graphics 5200/5100, HD Graphics 5000/4600/4400/4200, and Intel Pentium and Celeron Processors with Intel HD Graphics based on 4th Generation Intel Core.<br />
<br />
"A potential security vulnerability in Intel Graphics may allow escalation of privilege on 4th Generation Intel Core processors. Intel has released a software update to mitigate this potential vulnerability. In order to mitigate the vulnerability, DirectX 12 capabilities were deprecated." says the Intel page. If a user with a Haswell processor has a specific need to run the DirectX 12 application, they can downgrade their graphics driver to version 15.40.42.5063 or older.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OJDdh1JFKeOzSKww.jpg" target="_blank" data-width="640" data-height="539" ><img src="https://tpucdn.com/img/OJDdh1JFKeOzSKww_thm.jpg" width="154" height="130" alt="" /></a></div>
(PR) Annual DRAM Revenue for 2022 Expected to Reach US$91.5 Billion, with Prices Likely to Rally in 2H22, Says TrendForce
Despite the forecasted 18.6% YoY growth in total DRAM bit supply next year, the global DRAM market is still expected to shift from a shortage situation to an oversupply, according to TrendForce's latest investigations. This shift can primarily be attributed to the fact that, not only are most buyers now carrying a relatively high level of DRAM inventory, but DRAM bit demand is also expected to increase by only 17.1% YoY in 2022. On the price front, the oversupply situation will result in a drop in DRAM ASP in 2022 but not a major decline in annual DRAM revenue, thanks to the oligopolistic nature of the DRAM industry. Annual DRAM revenue for 2022 is expected to reach US$91.54 billion, which represents a slight YoY increase of 0.3%.<br />
<br />
Based on an analysis of DRAM sufficiency ratio (which refers to the surplus of supply in comparison with demand) for each quarter in 2022, TrendForce forecasts a 15% YoY decrease in DRAM ASP for 2022, with prices undergoing the more noticeable declines during the first half of the year. Heading into 2H22, however, owing to the rise in DDR5 penetration rate, as well as the arrival of peak seasonal demand, the decline in DRAM ASP will likely narrow. TrendForce does not rule out the possibility that DRAM ASP may even hold flat or undergo an increase in 2H22.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dPaGEhuGoHJz5Yps.jpg" target="_blank" data-width="586" data-height="252" ><img src="https://tpucdn.com/img/dPaGEhuGoHJz5Yps_thm.jpg" width="302" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288667/annual-dram-revenue-for-2022-expected-to-reach-ususd-91-5-billion-with-prices-likely-to-rally-in-2h22-says-trendforce">Read full story</a></div>
(PR) MSI's Business & Productivity Series DT, All-in-One PC, and Monitor are Ready to Be Your Strongest Foundation
MSI, a world leader in high performance and innovative computing solutions, announced the brand new Business & Productivity product lines which support the latest 12th generation Intel Core processors and the latest Summit & Modern series monitors. The new Business & Productivity product lines are developed for a safer and more ergonomic working environment and designed with eye care technology in mind to enhance users' efficiency and productivity.<br />
<br />
The MSI Modern AM242 and Modern AM272 Series All-in-One PCs are the best products to style a desk at home, an office, or even a home office. They are both aesthetically pleasing and completely functional for learning, working, or cooking. The innovative Modern AM Series All-in-One PC is designed to stylishly increase visual comfort while performing computer tasks at home or in the office. Both models support the latest 12th generation Intel Core i processors and Windows 11 and come with MSI's Anti-Flicker technology, which eliminates flickering and effectively reduces eye fatigue caused by prolonged use time. The Less Blue Light Mode filters visual exposure of the blue light during daily use and brings you the most comfortable viewing experiences. The Modern AM242 & AM272 ensure you the best video conference quality with a built-in webcam and the exclusive MSI Sound Tune software which supports noise cancellation technology. Modern AM242 and AM272 Series are both designed with efficiency and productivity in mind.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FBNHswmQIpFjpyz7.jpg" target="_blank" data-width="600" data-height="550" ><img src="https://tpucdn.com/img/FBNHswmQIpFjpyz7_thm.jpg" width="142" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Egpurj9Rs2XIPdQo.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/Egpurj9Rs2XIPdQo_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288666/msis-business-productivity-series-dt-all-in-one-pc-and-monitor-are-ready-to-be-your-strongest-foundation">Read full story</a></div>
(PR) MSI unveils 12th Gen Intel Core gaming desktop and definition the new standard of gaming monitor
For those who do not familiar with PC DIY users, MSI also offers pre-built systems. The only thing that customers should worry about is what games you should play and MSI will take over the rest parts. MSI desktop line-up fully implements the concept of G.A.M.E. unlimited into the products, including performance, aesthetics, connectivity, and experience. A prebuild PC user only just enjoys the plug-and-play experience, the rest of the software and hardware integrated MSI will help you to complete the processing, while you get the product.<br />
<br />
The new MSI gaming desktops are equipped with Intel's latest 12th Gen Alder Lake processors. The advanced Intel 7 process technology with hybrid architecture combining P-Core (Performance) and E-Core (Efficiency) increases multi-thread performance by up to 47%. The gaming performance also has more than 13% increase compared to the previous generation. The full lineup of K Series gaming desktops adopted DDR5 memory with read speed up to 60% higher than the previous generation equipped with DDR4. This can provide players with faster data reading. In addition, the MSI 12th Gen gaming desktops are all equipped with Windows 11. The Direct Storage technology can help players quickly read the games while the Auto HDR function can even improve SDR game scenes to HDR quality. This time MSI launched the all new 12th Gen Series Intel unlocked processors models including MEG Aegis Ti5, MEG Trident X and MAG Codex X5. All of these models embody the G.A.M.E. Unlimited sprit to bring gamers to the new era of gaming.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/xfxw43F8sdd2B3i7.jpg" target="_blank" data-width="1200" data-height="500" ><img src="https://tpucdn.com/img/xfxw43F8sdd2B3i7_thm.jpg" width="312" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288665/msi-unveils-12th-gen-intel-core-gaming-desktop-and-definition-the-new-standard-of-gaming-monitor">Read full story</a></div>
(PR) Sharkoon Unveils SKILLER SGK50 S4 60% Keyboard
Sharkoon Technologies, an international supplier of high-performance quality PC components and peripherals, now presents the SKILLER SGK50 S4 - Sharkoon's first mechanical 60 percent keyboard. Its hot-swap function allows switches to be installed and removed easily, and all switches with 3 and 5 pins are supported. The Kailh switches that are typical of Sharkoon are already pre-installed on the keyboard: The linear red switches, the tactile brown switches or the clicky blue switches. But if the factory-lubricated Gateron switches are preferred, these can be purchased separately with the Sharkoon Switch Set. The keyboard has two pairs of feet and can therefore be positioned at up to three different angles. In addition, two macros with up to 16 macro actions can be recorded or overwritten without the use of any separate software. <br />
<br />
The compact layout of 60 percent saves a considerable amount of space on the desk, allowing the mouse to be moved more freely, while the keyboard can be positioned more conveniently while gaming. Thanks to the multiple assignment of the keys, all the functions of a TKL keyboard are provided. This means that the SKILLER SGK50 S4 can still demonstrate full functionality with its handy and compact size.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/mJ5aLQ1KAf4jVe0S.jpg" target="_blank" data-width="1000" data-height="766" ><img src="https://tpucdn.com/img/mJ5aLQ1KAf4jVe0S_thm.jpg" width="170" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/KkDsjmoDyR3cFwdm.jpg" target="_blank" data-width="1000" data-height="750" ><img src="https://tpucdn.com/img/KkDsjmoDyR3cFwdm_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TlgJRuyZWjwdgdqx.jpg" target="_blank" data-width="1000" data-height="744" ><img src="https://tpucdn.com/img/TlgJRuyZWjwdgdqx_thm.jpg" width="175" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dYGsfmjJjASAF6RP.jpg" target="_blank" data-width="1000" data-height="732" ><img src="https://tpucdn.com/img/dYGsfmjJjASAF6RP_thm.jpg" width="178" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Rq5h8Zf94PWUY96G.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/Rq5h8Zf94PWUY96G_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288664/sharkoon-unveils-skiller-sgk50-s4-60-keyboard">Read full story</a></div>
(PR) G.SKILL Trident Z5 Breaks DDR5-8704 World Record with ASUS ROG Z690 Apex
G.SKILL International Enterprise Co., Ltd., the world's leading manufacturer of extreme performance memory and gaming peripherals, is excited to claim yet another world record, in close partnership with the ASUS ROG motherboard team, for the fastest memory frequency of an incredible DDR5-8704. This incredible feat was achieved with the G.SKILL Trident Z5 DDR5 memory on the latest Intel Core i7-12700KF processor and ASUS ROG Maximus Z690 APEX motherboard. <br />
<br />
Laying claim to the world record for the fastest memory frequency with the latest DDR5 memory, G.SKILL and ASUS worked closely together to achieve an incredible DDR5-8704, using liquid nitrogen to cool the system to subzero temperatures. Solidifying DDR5 memory as the new extreme performance standard, this memory frequency world record was achieved with the new Trident Z5 RGB memory on the ASUS ROG Maximus Z690 APEX motherboard. See below for a screenshot of the world record, achieved by the extreme overclocker "hocayu":<div class="imgcontainer"><a href="https://www.techpowerup.com/img/xnNoyCnUqjT2rOnW.jpg" target="_blank" data-width="922" data-height="845" ><img src="https://tpucdn.com/img/xnNoyCnUqjT2rOnW_thm.jpg" width="142" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fmjzrEyU2IJkhF9E.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/fmjzrEyU2IJkhF9E_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288663/g-skill-trident-z5-breaks-ddr5-8704-world-record-with-asus-rog-z690-apex">Read full story</a></div>
(PR) AMD EPYC Processors Expand Performance and Security Innovation Across Microsoft Azure Virtual Machines Portfolio
Today, AMD announced its continued momentum and collaboration with Microsoft Azure, who is offering the 3rd Gen AMD EPYC processor in the latest generation of Dasv5 and Easv5 Azure Virtual Machines (VMs). Azure is also introducing new confidential VMs, DCasv5 and ECasv5, which use the latest advanced security features available in 3rd Gen EPYC processors, including Secure Encrypted Virtualization-Secure Nested Paging (SEV-SNP).<br />
<br />
The new Azure confidential VMs, DCasv5 and ECasv5, the first EPYC processor-based confidential VMs at Azure and the first confidential VMs to use SEV-SNP, will enable customers to have the data in their security focused applications encrypted in use, in transit and at rest. The updated Dasv5 VMs, optimized for general purpose workloads, and the Easv5 VMs, optimized for memory-based workloads, deliver better price-performance for most general purpose and memory intensive workloads compared to prior EPYC processor-based Microsoft Azure VMs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/QWYXdSPdAFF7mo9z.jpg" target="_blank" data-width="1260" data-height="500" ><img src="https://tpucdn.com/img/QWYXdSPdAFF7mo9z_thm.jpg" width="328" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288662/amd-epyc-processors-expand-performance-and-security-innovation-across-microsoft-azure-virtual-machines-portfolio">Read full story</a></div>
(PR) PNY Announces Specifications and Availability of XLR8 Gaming and Performance DDR5 Desktop Memory
PNY today announces specifications and availability for its upcoming Desktop Performance and XLR8 Gaming DDR5 memory products. The three models include the overclocked XLR8 Gaming MAKO and MAKO RGB models, running at 5600 MHz and a CAS latency of 36, as well as the PNY Performance model that follows JEDEC standards.<br />
<br />
The XLR8 Gaming MAKO and MAKO RGB modules have been designed to meet the needs of gamers and enthusiasts. The designs for both modules feature aluminium heat spreaders with elements inspired by the powerful, fast and aggressive Mako shark from which they get their name. An XLR8 logo and GAMING text is proudly emblazoned on the side of the module and silver angled relief lines are machined into the heatspreader to reflect other components' lighting and provide unmatched flair and style.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/xJI93Yje6sGe5ixD.jpg" target="_blank" data-width="800" data-height="450" ><img src="https://tpucdn.com/img/xJI93Yje6sGe5ixD_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288661/pny-announces-specifications-and-availability-of-xlr8-gaming-and-performance-ddr5-desktop-memory">Read full story</a></div>
(PR) HyperX Ships Over One Million USB Microphones
HyperX, the gaming peripherals team at HP Inc. and brand leader in gaming and e-sports, today announced it has surpassed the one million shipping milestone with its line of USB microphones. Initially introduced into the microphone market in 2019, the HyperX QuadCast USB microphone became a popular choice for gamers, streamers and influencers. As demand for microphones increased, HyperX expanded its portfolio with the customizable QuadCast S and affordable SoloCast to fulfill the need for gamers, content creators, students, and WFH pros to be heard and stay active in their communities and productive at work.<br />
<br />
"HyperX is pleased to support a thriving community of content creators, influencers and gamers with the highest quality gaming products to meet their individual setup needs," said Kevin Hague, general manager, HyperX. "Our continued efforts have created a lineup of microphones that deliver clear and consistent sound not only for gamers, streamers, and casters, but also students and business professionals alike."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Q2EsDKbhF5rrd6Cm.jpg" target="_blank" data-width="1000" data-height="610" ><img src="https://tpucdn.com/img/Q2EsDKbhF5rrd6Cm_thm.jpg" width="213" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288660/hyperx-ships-over-one-million-usb-microphones">Read full story</a></div>
GIGABYTE Prepares AORUS Z690 First Look Event to Showcase the Launch of the new Intel Alder Lake Platform
The launch of Intel's Alder Lake processsors has opened an exciting chapter for team blue and motherboard makers who are finally transitioning to new technologies like DDR5 and PCIe Gen5 standards. Today, GIGABYTE AORUS has prepared a complete lineup of motherboards designed to satisfy all kinds of workloads powered by Alder Lake processors as these AORUS Z690 motherboards are about to hit the market. These new boards include an upgraded feature set like 16+ phases power delivery on all boards, upgraded heatsinks to keep VRM temperatures under control, and built-in DDR5 overclocking features.<br />
<br />
The event will be live-streamed on YouTube, so tune in to the First Look Event as the AORUS team gives an in-depth overview and cover the performance increase you can experience with Intel 12th gen CPU and DDR5 memory on the AORUS Z690 platform. They will be going over the new platform's entire lineup and feature set, so make sure you get to the event on time. It will start at 18:00 UTC zone, and you can tune in to watch here: <a rel="nofollow" href="https://www.youtube.com/watch?v=sZ_403wElyo" target="_blank">AORUS Z690 First Look Event</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cghGVoomCSCGVbR4.jpg" target="_blank" data-width="1956" data-height="960" ><img src="https://tpucdn.com/img/cghGVoomCSCGVbR4_thm.jpg" width="265" height="130" alt="" /></a></div>
AMD Radeon PRO V620 GPU Delivers Powerful, Multi-Purpose Data Center Visual Performance for Today's Demanding Cloud Workloads
AMD announced the AMD Radeon PRO V620 GPU, built with the latest AMD RDNA 2 architecture which delivers high-performance GPU acceleration for today's demanding cloud workloads including immersive AAA game experiences, intensive 3D workloads and modern office productivity applications at scale in the cloud.<br />
<br />
With its innovative GPU-partitioning capabilities, multi-stream hardware accelerated encoders and 32 GB GDDR6 memory, the AMD Radeon PRO V620 offers dedicated GPU resources that scale to multiple graphics users, helping ensure cost-effective graphics acceleration for a range of workloads. Built using the same GPU architecture that powers the latest generation game consoles and PC game experiences, the AMD Radeon PRO V620 GPU is also designed to develop and deliver immersive AAA game experiences.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DACj38as6Wy6G1T3.jpg" target="_blank" data-width="992" data-height="558" ><img src="https://tpucdn.com/img/DACj38as6Wy6G1T3_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/288634/amd-radeon-pro-v620-gpu-delivers-powerful-multi-purpose-data-center-visual-performance-for-todays-demanding-cloud-workloads">Read full story</a></div>
Truck Full of EVGA Graphics Cards Gets Stolen in California
Unexpected events tend to happen in the world of graphics cards, and today seems like no exception. According to the public announcement on EVGA forums, a truck delivery full of the latest NVIDIA GeForce RTX 30 series graphics cards got stolen. The truck was going on its route from San Francisco to the EVGA Southern California distribution center. Inside the vehicle, countless GPUs were ranging in MSRP from $329.99 up to $1959.99. However, the company doesn't specify how many GPUs are now missing. It is important to note that any sale of these stolen GPUs is considered a felony, and if you have any information regarding this, please get in touch with EVGA at [Only registered and activated users can see links. Click Here To Register...] email address.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KVCRh9ep62SgdTqj.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/KVCRh9ep62SgdTqj_thm.jpg" width="130" height="130" alt="" /></a> </div>Here is the full announcement from EVGA's forum:<div class="readmore"><a href="https://www.techpowerup.com/288619/truck-full-of-evga-graphics-cards-gets-stolen-in-california">Read full story</a></div>
(PR) LG To Bring NVIDIA GeForce NOW Cloud Gaming To webOS Smart TVs
LG Electronics (LG) announced a partnership with NVIDIA to be the first TV manufacturer to develop a Smart TV app of GeForce NOW, the premier cloud game-streaming service, for LG TVs running webOS. Boasting large screen sizes, lifelike picture quality and high refresh rates, LG's OLED TVs are a perfect match for GeForce NOW. Currently available on NVIDIA SHIELD, Windows PC, macOS, Chrome OS, Android and Safari browser for iPhone and iPad, GeForce NOW allows gamers to start playing on their LG TVs and continue on nearly any device they own.<br />
<br />
The app will be available in beta starting this week in the LG Content Store on select 2021 LG 4K OLED, QNED Mini LED and NanoCell TV models in 80 markets. The app will enable LG TV owners with compatible TVs to instantly enjoy over 35 free-to-play games with just a compatible controller, no additional hardware required. Games include Rocket League and Destiny 2 plus hit titles such as Marvel's Guardians of the Galaxy and Crysis Remastered Trilogy, all playable at up to 1080p resolution and 60 frames per second. GeForce NOW Priority members get access to the most advanced platform for ray tracing and AI technologies, streaming from NVIDIA RTX-powered servers in data centers worldwide for the most responsive gameplay and gorgeous, high-quality graphics.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/j0wxVUJvKEOs4wgq.jpg" target="_blank" data-width="800" data-height="465" ><img src="https://tpucdn.com/img/j0wxVUJvKEOs4wgq_thm.jpg" width="224" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289132/lg-to-bring-nvidia-geforce-now-cloud-gaming-to-webos-smart-tvs">Read full story</a></div>
MediaTek Announces Flagship Dimensity 9000 5G SoC on TSMC 4 nm
A few years ago, MediaTek decided to leave the high-end mobile device SoC space as it decided to focus on the mid-range and entry level market, but as of today, that is no longer the case. The company has announced its new flagship Dimensity 9000 SoC and it packs all the latest cutting edge mobile SoC features you'd expect to see.<br />
<br />
The Dimensity 9000 is based entirely on the new Arm v9 architecture and the chip itself is built in TSMC's 4 nm node, which gives MediaTek a lead on all its competitors, but Apple. As for the Arm cores in question, the main core is a Cortex-X2 at 3.05 GHz, which is accompanied by three Cortex-A710 cores at 2.85 GHz and four power efficient Cortex-A510 cores at 1.8 GHz. All of these new Arm cores were only announced at the end of May this year, so MediaTek has clearly been burning the midnight oil to get the Dimensity 9000 out before its competitors' new chips based on the Arm v9 architecture.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NpUikKYhON8DENUk.jpg" target="_blank" data-width="563" data-height="553" ><img src="https://tpucdn.com/img/NpUikKYhON8DENUk_thm.jpg" width="132" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/f151XiSBYlltiyqg.jpg" target="_blank" data-width="526" data-height="551" ><img src="https://tpucdn.com/img/f151XiSBYlltiyqg_thm.jpg" width="124" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xDaZa3neEh2uG3F1.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/xDaZa3neEh2uG3F1_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289130/mediatek-announces-flagship-dimensity-9000-5g-soc-on-tsmc-4-nm">Read full story</a></div>
Keysfan Announces Week of Black Friday Sale, Great Deals on Genuine Software
Keysfan is a new merchant of genuine, globally-valid software, bringing to you some great deals on genuine software in the run up to Black Friday. With our new "Buy 1 Get 1" offer, get the latest Windows 11 Pro free when you buy Office 2021 Professional, Office 2019 Professional, or Office 2016 Professional. At much lower prices, you can also get Windows 10 Pro free. If you're just interested in either of the two, check out our great deals, with up to 50% off using a special coupon. Most other editions of Windows and Office can be had at jaw-dropping prices. <br />
<br />
<a rel="nofollow" href="https://www.keysfan.com/windows-11-pro-and-office-2021-pro-plus-key.html?ksf=skf23" target="_blank">Buy Office 2021 Professional with Windows 11 Pro at $51.24</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-pro-and-office-2019-pro-plus-key.html?ksf=skf23" target="_blank">Buy Office 2019 Professional with Windows 11 Pro at $37.91</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-office-2016-professional-plus-windows-11-professional.html?ksf=skf23" target="_blank">Buy Office 2016 Professional with Windows 11 Pro at $31.76</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-pro-and-office-2021-pro-plus-key.html?ksf=skf23" target="_blank">Buy Office 2021 Professional with Windows 10 Pro at $44.06</a> |<a rel="nofollow" href="https://www.keysfan.com/microsoft-office-2019-professional-plus-windows-10-professional.html?ksf=skf23" target="_blank">Buy Office 2019 Professional with Windows 10 Pro at $30.74</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-windows-10-pro-microsoft-office-2016-pro-plus.html?ksf=skf23" target="_blank">Buy Office 2016 Professional with Windows 10 Pro at $23.56</a><br />
<br />
Please use the coupon code <b>SKF50</b> on the following items at check-out.<br />
<a rel="nofollow" href="https://www.keysfan.com/windows-10-professional.html?ksf=skf23" target="_blank">Buy Windows 10 Pro at $7.59</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-pro-professional-cd-key-2-pcs.html?ksf=skf23" target="_blank">Buy Windows 10 Pro 2-PC at $12.43</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-professional-key.html?ksf=skf23" target="_blank">Buy Windows 11 Pro at $17.71</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-home-1-pc.html?ksf=skf23" target="_blank">Buy Windows 11 Home at $16.91</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-home.html?ksf=skf23" target="_blank">Buy Windows 10 Home at $8.16</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-home-2-pcs.html?ksf=skf23" target="_blank">Buy Windows 10 Home 2-PC at $13.57</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-11-home-key-5-pcs.html?ksf=skf23" target="_blank">Buy Windows 11 Pro 5-PC at $40.94</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-10-enterprise-ltsc-2019-1-pc.html?ksf=skf23" target="_blank">Buy Windows 10 Enterprise 2019 LTSC at $9.13</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-server-2019-standard.html?ksf=skf23" target="_blank">Buy Windows Server 2019 Standard at $16.06</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-server-2022-standard-key.html?ksf=skf23" target="_blank">Buy Windows Server 2022 Standard at $25.62</a> | <a rel="nofollow" href="https://www.keysfan.com/windows-server-2022-datacenter-key.html?ksf=skf23" target="_blank">Buy Windows Server 2022 Datacenter at $27.16</a><br />
<br />
Please use the coupon code <b>SKF62</b> on the following items.<br />
<a rel="nofollow" href="https://www.keysfan.com/microsoft-office-2021-professional-plus-key-5pcs.html?ksf=skf23" target="_blank">Buy Office 2021 Professional Plus 5-PC at $77.90</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-project-professional-2021.html?ksf=skf23" target="_blank">Buy Project Professional 2021 at $25.70</a> |<a rel="nofollow" href="https://www.keysfan.com/microsoft-visio-professional-2021-key.html?ksf=skf23" target="_blank">Buy Visio Professional 2021 at $22.97</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-project-professional-2019-1pc.html?ksf=skf23" target="_blank">Buy Project Professional 2019 at $22.15</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-visio-professional-2019-1pc.html?ksf=skf23" target="_blank">Buy Visio Professional 2019 at $19.37</a> | <a rel="nofollow" href="https://www.keysfan.com/office-2019-home-and-business-for-mac.html?ksf=skf23" target="_blank">Buy Office 2019 Home and Business for Mac at $103.33</a> | <a rel="nofollow" href="https://www.keysfan.com/microsoft-office-2019-home-and-student-1-user.html?ksf=skf23" target="_blank">Buy Office 2019 Home and Student at $31.15</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/HDrdkO7ZKY7Ud2b8.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/HDrdkO7ZKY7Ud2b8_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) Neat Microphones Reveals the Versatile Worker Bee II Condenser Microphone - Ideal for Recording and Streaming Vocals and Instruments
Neat Microphones, the innovative brand of high-quality digital USB and analog microphones from Turtle Beach Corporation, today revealed the Worker Bee II, the ideal creation tool for recording, podcasting, and streaming applications. The latest microphone added to Neat's all-new line-up, the Worker Bee II is heir to their original Worker Bee that was often noted by performers and engineers as an ideal mic for capturing richly detailed vocals, as well as the precision of plucked and percussive instruments - all at an exceptional MSRP of $99.99. The Worker Bee II launches December 6, 2021 and is available for pre-order now from participating retailers, including Amazon, American Music Supply, Sweetwater, and zZounds.<br />
<br />
"We're extremely proud that we can deliver such an accurate recording instrument at $99.99. What the Worker Bee II hears, it reproduces truthfully," said Skipper Wise, Founder of Neat Microphones and Vice President at Turtle Beach. "We're excited to offer such a faithful sound at a high value price." The Worker Bee II's capsule captures every nuance and transient it hears, giving an open and natural sonic signature. It features solid-state cardioid condenser microphone technology with an internally shockmounted, medium-sized 25 mm capsule and discrete Class A electronics that can handle high sound pressure levels with a wide frequency and dynamic range. It sounds great on guitar amps, brass, live recordings, and drums, while retaining a level of detail that brings out the nuances in vocals and spoken voice.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/heONcTS6a0CaXtNZ.jpg" target="_blank" data-width="839" data-height="1280" ><img src="https://tpucdn.com/img/heONcTS6a0CaXtNZ_thm.jpg" width="85" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289124/neat-microphones-reveals-the-versatile-worker-bee-ii-condenser-microphone-ideal-for-recording-and-streaming-vocals-and-instruments">Read full story</a></div>
Innosilicon's Fenghua GPU Based on Imagination Technologies IMG-B Series GPU Cores
The somewhat surprise announcement of the <a href="https://www.techpowerup.com/289116/chinese-innosilicon-fenghua-no-1-graphics-card-supports-pcie-4-0-hdmi-2-1-gddr6x-directx" target="_blank">Innosilicon Fenghua No.1</a> server graphics card took many by surprise, but it seems like much of the tech media, us included, weren't paying attention, as there were hints about this card over a year ago. It came from no-one other than Imagination Technologies CMO, David Harold, in an official blog post that was posted on the 13th of October 2020.<br />
<br />
The blog post was titled "Back in the high-performance game" and in it David Harold was reminiscing about his close to 20 years at Imigationation Technologies and how the company had started out in the 3D accelerator business with the Kyro "GPU". He goes on to mention last year's IMG A-Series GPU and then moves on to the new IMG-B Series and mentions how it's the 11th generation of the PowerVR architecture and how it has 70 percent higher compute density compared to existing desktop GPUs. He also mentions that Imagination Technologies has five customers working on products for the desktop, performance laptop and "cloud spaces" based on the PowerVR architecture and then goes on to mention Innosilicon by name and pointing out that they have just launched an IMG-B Series BXT multi-core GPU in an add-in card form-factor.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/rikMSXzYd7PjgDQA.jpg" target="_blank" data-width="750" data-height="415" ><img src="https://tpucdn.com/img/rikMSXzYd7PjgDQA_thm.jpg" width="235" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289123/innosilicons-fenghua-gpu-based-on-imagination-technologies-img-b-series-gpu-cores">Read full story</a></div>
(PR) India PC Market Ships 4.5 Million Units in 3Q21, Reports All-Time High Shipments, According to IDC
The India traditional PC market (inclusive of desktops, notebooks, and workstations) continued its growth momentum despite ongoing supply and logistical challenges. The traditional PC shipments witnessed a 30% year-over-year (YoY) growth in 3Q21 (Jul-Sep), marking the fifth consecutive quarter of growth in India, according to new data from the International Data Corporation 's (IDC) Worldwide Quarterly Personal Computing Device Tracker. A total of 4.5 million PCs were shipped during the quarter, making it India's biggest-ever single quarter. To put this in perspective, it is bigger than the total yearly consumer shipments in 2019, a year before the pandemic hit us. As a result, many brands also reported their biggest quarter of PC shipments.<br />
<br />
Notebook PCs continue to dominate the overall category with more than 80% share. Enterprise and consumer demand helped the Notebook category to reach over 3 million units for the first time, and the desktop category also continued its upward momentum as it grew by 30.5% YoY in 3Q21.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/TdHbDsIWJxmBpAvb.jpg" target="_blank" data-width="1301" data-height="363" ><img src="https://tpucdn.com/img/TdHbDsIWJxmBpAvb_thm.jpg" width="466" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289121/india-pc-market-ships-4-5-million-units-in-3q21-reports-all-time-high-shipments-according-to-idc">Read full story</a></div>
Intel Core i7-12700H Beats Ryzen 9 5900HX by 47% In Leaked Cinebench Scores
Intel is expected to announce their Alder Lake mobile processors in Q1 2022 with rumors and leaks for several of these chips already surfacing. The i7-12700H has recently been spotted running Cinebench on what could possibly be an MSI GE76 Raider 12UH with the results showing impressive performance gains. The processor features six Golden Cove (P) cores and eight Gracemont (E) cores for a total of 14 cores and 20 threads. <br />
<br />
The i7-12700H includes a configurable base TDP of 35 W - 45 W and this specific sample was running at a reported base frequency of 2.9 GHz during testing. The processor scored 689 points in Cinebench R20 single-core which places it 12% faster than the Core i9-11950H and 21% faster than AMD's flagship Ryzen 9 5900HX. The processor widens this gap in Cinebench R20 multi-core with a score of 7158 points placing it 47% above the 8-core, 16-thread Ryzen 9 5900HX. We can also see that multi-core performance is 49% faster than the recently released Apple M1 Max in Cinebench R23. AMD is preparing their Ryzen 6000 processors for an early 2022 launch which will be competing with these Alder Lake chips but we have yet to see many performance leaks for them to compare with.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wYEweWuUCBEiZbXl.jpg" target="_blank" data-width="1280" data-height="764" ><img src="https://tpucdn.com/img/wYEweWuUCBEiZbXl_thm.jpg" width="218" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/C7aHKD6Z1oYPY85N.jpg" target="_blank" data-width="1280" data-height="763" ><img src="https://tpucdn.com/img/C7aHKD6Z1oYPY85N_thm.jpg" width="218" height="130" alt="" /></a></div>
AMD to Steer Motherboard Partners Away from Intel WLAN, Toward MediaTek Co-branded Ones
Intel has dominated the client Wi-Fi + Bluetooth network adapter market in the PC space for some time now, particularly with WiFi 6 and WiFi 6E interfaces integrated with motherboards. Even on the AMD platform, motherboard vendors have extensively packaged not just Intel-branded WiFi + Bluetooth modules, but also their wired LAN controllers. In the commercial desktop and commercial notebook markets, Intel leverages this position to push its vPro management suite, with Intel WLAN controllers featuring vPro support. This is something felt lacking in the rival AMD PRO ecosystem, and something the company is looking to change with its collaboration with MediaTek. <br />
<br />
AMD RZ660 will be the first controller based on this partnership. Based on the MediaTek Filogic 330P chipset, the controller combines WiFi 6E (6 GHz), with the latest generation Bluetooth (at least Bluetooth 5.2). Driver software and support for this solution will be handled by AMD, as would distribution. MediaTek stated that the first notebooks and desktop PCs (includes DIY motherboards) featuring the AMD RZ660 will debut in 2022. The AMD-supplied driver software would also enable the company to create special "PRO" variants of the RZ660 to bundle with its Ryzen PRO SoCs for the commercial PC and workstation markets. There doesn't appear to be any such collaboration with wired Ethernet, as there is an even competition between Intel and Realtek over the 2.5 GbE PHY market, with both companies offering gaming-specific variants—Intel Killer and Realtek DragonLAN.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NMc7tD6Hw2vdL0Um.jpg" target="_blank" data-width="768" data-height="1024" ><img src="https://tpucdn.com/img/NMc7tD6Hw2vdL0Um_thm.jpg" width="98" height="130" alt="" /></a></div>
Chinese Innosilicon Fenghua No.1 Graphics Card Supports PCIe 4.0, HDMI 2.1, GDDR6X, & DirectX
Chinese company Innosilicon Technology has recently announced their Fenghua No.1 high-performance server graphics card. The card features a dual-fan cooling design with HDMI 2.1 and Embedded DisplayPort 1.4 video connectors. The card will utilize a PCIe 4.0 connector and features GDDR6X memory developed by Innosilicon Technology with potential speeds of 21 Gbps. We have seen announcements from Chinese companies with similar products in the past but this recent announcement is the first to include support for a variety of graphics APIs including DirectX. The press release from the company didn't specify the DirectX version supported but also noted that the card will support OpenGL, OpenGLES, OpenCL, and Vulkan which will enable VR, AR, and AI applications.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/2Cxg0p4XFknmJhLa.jpg" target="_blank" data-width="1080" data-height="720" ><img src="https://tpucdn.com/img/2Cxg0p4XFknmJhLa_thm.jpg" width="195" height="130" alt="" /></a></div>
TCL CSOT Teases 32-Inch 4K 240 Hz Gaming Monitor at DTC 2021
TCL China Star Optoelectronics Technology Co have recently announced plans to release a 4K 32-inch 240 Hz curved panel for use in gaming monitors at the Global Display Tech-Ecosystem Conference (DTC 2021). This new panel would be the fastest available in any 4K gaming monitor, while details are limited the 32" UD 240Hz R800 Gaming Display is expected to include 1 ms response times and a proprietary image compression algorithm. The monitor is unlikely to be sold directly by TCL as the company usually sells unbranded monitors to OEMs for customization such as with their current 144 Hz 4K monitors. The pricing and availability details were also not announced by TCL so it could be some time until you can purchase one of these monitors.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/oeDfow7IWEhBd4Gd.jpg" target="_blank" data-width="980" data-height="704" ><img src="https://tpucdn.com/img/oeDfow7IWEhBd4Gd_thm.jpg" width="181" height="130" alt="" /></a></div>
(PR) MediaTek Announces New Filogic 130 and Filogic 130A WiFi 6 + Bluetooth 5.2 Controllers
MediaTek today announced the new MediaTek Filogic 130 and Filogic 130A system-on-chips (SoCs) which both integrate a microprocessor (MCU), AI engine, Wi-Fi 6 and Bluetooth 5.2 subsystems, and a power management unit (PMU) into a single chip. Filogic 130A also integrates an audio digital signal processor to allow device makers to easily add voice assistants and other services into their products. These all-in-one solutions deliver energy-efficient, reliable and high performance connectivity in small form factor designs that are ideal for a wide range of IoT devices.<br />
<br />
"In the coming years, advanced connectivity technologies like Wi-Fi 6 and Bluetooth 5.2 will become a must-have for smart home devices with the increasing need for more AI processing power, energy efficiency and robust security. MediaTek's Filogic 130 and Filogic 130A solutions offer the perfect combination of features to help drive this transition," said Alan Hsu, Corporate Vice President & General Manager, Intelligent Connectivity at MediaTek. "Each solution has a highly integrated design that packs the latest on-chip processing and power-management technologies into an ultra-small design no bigger than the size of a thumbnail."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qfySE5L906F8h00v.jpg" target="_blank" data-width="1163" data-height="786" ><img src="https://tpucdn.com/img/qfySE5L906F8h00v_thm.jpg" width="192" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289114/mediatek-announces-new-filogic-130-and-filogic-130a-wifi-6-bluetooth-5-2-controllers">Read full story</a></div>
Intel "Meteor Lake" Chips Already Being Built at the Arizona Fab
With its 12th Gen Core "Alder Lake-P" mobile processors still on the horizon, Intel is already building test batches of the 14th Gen "Meteor Lake" mobile processors, at its Fab 42 facility in Chandler, Arizona. "Meteor Lake" is a multi-chip module that leverages Intel's Foveros packaging technology to combine "tiles" (purpose built dies) based on different silicon fabrication processes depending on their function and transistor-density/power requirements. It combines four distinct tiles across a single package—the compute tile, with the CPU cores; the graphics tile with the iGPU: the SoC I/O tile, which handles the processor's platform I/O; and a fourth tile, which is currently unknown. This could be a memory stack with similar functions as the HBM stacks on "Sapphire Rapids," or something entirely different.<br />
<br />
The compute tile contains the processor's various CPU core types. The P cores are "Redwood Cove," which are two generations ahead of the current "Golden Cove." If Intel's 12-20% generational IPC uplift cadence holds, we're looking at cores with up to 30% higher IPC than "Golden Cove" (50-60% higher than "Skylake."). "Meteor Lake" also debuts Intel's next-generation E-core, codenamed "Crestmont." The compute tile is rumored to be fabricated on the Intel 4 node (optically a 7 nm-class node, but with characteristics similar to TSMC N5).<div class="imgcontainer"><a href="https://www.techpowerup.com/img/qZti6E7TQZxoEgX5.jpg" target="_blank" data-width="768" data-height="520" ><img src="https://tpucdn.com/img/qZti6E7TQZxoEgX5_thm.jpg" width="192" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Rt7SRhbBk5Mct5PO.jpg" target="_blank" data-width="768" data-height="526" ><img src="https://tpucdn.com/img/Rt7SRhbBk5Mct5PO_thm.jpg" width="190" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Dt3Seuy60B2T8e9L.jpg" target="_blank" data-width="768" data-height="511" ><img src="https://tpucdn.com/img/Dt3Seuy60B2T8e9L_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dNTFxgAHYDeqtUcz.jpg" target="_blank" data-width="768" data-height="403" ><img src="https://tpucdn.com/img/dNTFxgAHYDeqtUcz_thm.jpg" width="248" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289111/intel-meteor-lake-chips-already-being-built-at-the-arizona-fab">Read full story</a></div>
Report: DDR5 Already Facing Production Issues In Wake of Global Chip Shortages
DDR5 may soon have reason to be an even more expensive early-adopter piece of tech than it currently is, according to electronic component supplier 12chip. While semiconductor manufacturers worldwide grapple with logistics and components shortages, the DRAM market has been left somewhat unscathed - up to now. DRAM fabrication - even DDR5 - isn't done on leading-edge nodes but on older, more mature ones (such as 14 nm). According to 12chip, manufacturers are having no problem in scaling their DRAM manufacturing on these older nodes to meet demand.<br />
<br />
However, DDR5 is being directly impacted by the current logistics issues due to lack of adequate Power Management Integrated Circuit (PMIC) chips - which DDR5 has integrated in the DIMM proper. Currently, lead times for PMIC orders are estimated at 35 weeks, placing additional strain on system assemblers and DRAM manufacturers - and forcing delays and bottlenecks throughout the supply chain. Additionally, the fact that PMIC chips for DDR5 are ten times as expensive as equivalent DDR4 power management solutions doesn't bode well for future price action on DDR. Should this situation continue, higher prices for DDR5 modules are to be expected due to a deteriorating supply/demand ratio - particularly relevant if you're thinking about putting together a build based on Intel's Alder Lake platform. As always, take this report with a grain of salt.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/LQVxx1YMGZm3KKkz.jpg" target="_blank" data-width="1800" data-height="1395" ><img src="https://tpucdn.com/img/LQVxx1YMGZm3KKkz_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4bVESss6TNl19qGZ.jpg" target="_blank" data-width="800" data-height="365" ><img src="https://tpucdn.com/img/4bVESss6TNl19qGZ_thm.jpg" width="285" height="130" alt="" /></a></div>
(PR) LG Announces Pricing And Availability Of UltraGear 34GP950G
LG Electronics USA announces the nationwide rollout of the 34-inch LG UltraGear Curved Display (model 34GP950G-B), UltraWide QHD (3440x1440) IPS 1 millisecond Gray-to-Gray (GtG) gaming monitor with NVIDIA G-SYNC ULTIMATE. The latest addition to LG's #1 gaming-designed monitor brand in the U.S., the 34GP950G delivers a next-level sensory experience and retails for $1299 at LG.com and select LG-authorized retailers.<br />
<br />
The latest offering from LG UltraGear (the official gaming monitor of North American eSports team Evil Geniuses), the 34GP950G is a CES 2021 Innovation Award-winning UltraWide Nano IPS display that delivers an immersive gaming experience for all enthusiasts. Thanks to its 180 Hz Overclock and an IPS 1 ms (GtG) response time, the UltraGear 34GP950G delivers highly sought-after picture quality without sacrificing input lag and refresh rate. With VESA DisplayHDR 600 certification (56 Block Local Dimming) the UltraGear 34GP950G guarantees outstanding color, dynamic contrast, high luminance, and a wide color gamut. Covering 98 percent of the DCI-P3 color spectrum, the monitor has a 1,000:1 contrast ratio, capable of reproducing vivid scenes in true-to-life color.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/eWXaXRZGCEAixsXc.jpg" target="_blank" data-width="1190" data-height="858" ><img src="https://tpucdn.com/img/eWXaXRZGCEAixsXc_thm.jpg" width="180" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UXHIn2XsRwCGP2zr.jpg" target="_blank" data-width="510" data-height="924" ><img src="https://tpucdn.com/img/UXHIn2XsRwCGP2zr_thm.jpg" width="72" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/l9SW5GTIw86zStLB.jpg" target="_blank" data-width="1078" data-height="916" ><img src="https://tpucdn.com/img/l9SW5GTIw86zStLB_thm.jpg" width="153" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289094/lg-announces-pricing-and-availability-of-ultragear-34gp950g">Read full story</a></div>
(PR) OWC Announces miniStack STX World's First Thunderbolt 4 Certified Storage and Hub Expansion Solution
OWC, the premier zero-emissions Mac and PC technology company, and a respected provider of Memory, External Drives, SSDs, Mac & PC Docking Solutions, Network Attached Storage, and Performance Upgrade Kits, announces the OWC miniStack STX, the world's first Thunderbolt 4 Certified storage and hub expansion solution that seamlessly stacks with the Mac mini. It is also a Plug and Play expansion companion for Thunderbolt or USB-equipped Macs, PCs, iPads, Chromebooks, and Android tablets. <br />
<br />
Three Thunderbolt 4 (USB-C compatible) ports connect to millions of Thunderbolt, USB-C and future USB4 devices and accessories. A universal HDD/SSD bay and an NVMe M.2 SSD slot provide massive storage capacity expansion and can be combined in a RAID 1 configuration. With up to 770 MB/s of storage performance, the OWC miniStack STX is great for bandwidth-intensive video editing, photography, audio, virtual machines, and everyday data backup and access tasks. Its heat-dissipating aircraft-grade aluminium with an internal heat sink and high-efficiency fan provides cool, nearly silent operation.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kPt4E2JXigTKDBvy.jpg" target="_blank" data-width="800" data-height="513" ><img src="https://tpucdn.com/img/kPt4E2JXigTKDBvy_thm.jpg" width="203" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289093/owc-announces-ministack-stx-worlds-first-thunderbolt-4-certified-storage-and-hub-expansion-solution">Read full story</a></div>
AMD Radeon Software Adrenalin 21.11.3 Released
AMD today released the latest version of Radeon Software. Version 21.11.3 beta comes with optimization for Microsoft Flight Simulator: GOTY Edition, and Farming Simulator 22. Additional extensions of the Vulkan API are added. The drivers also fix driver-timeouts or game crashes noticed with "Battlefield 2042" on graphics cards such as the RX 6900 XT. Stuttering or poor performance with "DayZ" on RX 5700 XT was fixed. Also fixed is elevated disk usage by the Multimedia Athena dumps folder. Grab the driver from the link below.<br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/amd-radeon-graphics-drivers/" target="_blank">AMD Radeon Software Adrenalin 21.11.3</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/IPwj4mTvJQOvUTZP.jpg" target="_blank" data-width="1536" data-height="864" ><img src="https://tpucdn.com/img/IPwj4mTvJQOvUTZP_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ofhJOhIGqloHRMxn.jpg" target="_blank" data-width="2000" data-height="1125" ><img src="https://tpucdn.com/img/ofhJOhIGqloHRMxn_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289092/amd-radeon-software-adrenalin-21-11-3-released">Read full story</a></div>
(PR) NVIDIA Announces Financial Results for Third Quarter Fiscal 2022
NVIDIA today reported record revenue for the third quarter ended October 31, 2021, of $7.10 billion, up 50 percent from a year earlier and up 9 percent from the previous quarter, with record revenue from the company's Gaming, Data Center and Professional Visualization market platforms. GAAP earnings per diluted share for the quarter were $0.97, up 83 percent from a year ago and up 3 percent from the previous quarter. Non-GAAP earnings per diluted share were $1.17, up 60 percent from a year ago and up 13 percent from the previous quarter.<br />
<br />
"The third quarter was outstanding, with record revenue," said Jensen Huang, founder and CEO of NVIDIA. "Demand for NVIDIA AI is surging, driven by hyperscale and cloud scale-out, and broadening adoption by more than 25,000 companies. NVIDIA RTX has reinvented computer graphics with ray tracing and AI, and is the ideal upgrade for the large, growing market of gamers and creators, as well as designers and professionals building home workstations.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/M4vO0HlBEY6oMdve.jpg" target="_blank" data-width="832" data-height="523" ><img src="https://tpucdn.com/img/M4vO0HlBEY6oMdve_thm.jpg" width="207" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289083/nvidia-announces-financial-results-for-third-quarter-fiscal-2022">Read full story</a></div>
(PR) Team Group Announces N75-series Industrial Grade M.2 NVMe SSDs
Leading global memory provider TEAMGROUP has been actively expanding in the industrial field for many years. In response to the development of 5G communication and the increasing demand for smart edge computing, TEAMGROUP today has announced two industrial-grade M.2 PCIe solid-state drives equipped with patented heat dissipating modules, the N75A-M80 and N75G-M80. The two products can be used in a limited space environment and provide excellent cooling performance during 24-hour high-speed operation, overcoming the extreme environments and ever-changing challenges of industrial applications.<br />
<br />
To solve the issue of heat generated by SSDs under heavy workloads, TEAMGROUP launched two industrial M.2 PCIe SSDs that feature patented heat dissipating modules: N75A-M80, which comes with an aluminium fin heat sink (Taiwan Utility Model Patent No.: M541645), and N75G-M80, fitted with a graphene copper foil (Taiwan Invention Patent No.: I703921; US Invention Patent No.: US11051392B2). The two patented heat dissipating modules effectively reduce SSD slowdowns caused by high operating temperatures and significantly improve stability. The graphene heat sink of the N75G-M80 has a thickness of less than 1 mm, allowing for the SSD to be easily installed without interference. Even in 5G and IoT equipment, where installation space is limited, it can provide excellent cooling performance. The N75G-M80's outstanding technical performance was recognized in COMPUTEX d&i Awards 2021 and the Taiwan Excellence Awards 2022, winning awards from both.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/AE0pNsTaVVwp24B8.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/AE0pNsTaVVwp24B8_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZtSYdpoOvR0qUNsu.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/ZtSYdpoOvR0qUNsu_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3pChpR7E7Ph7uuFk.jpg" target="_blank" data-width="800" data-height="435" ><img src="https://tpucdn.com/img/3pChpR7E7Ph7uuFk_thm.jpg" width="239" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289082/team-group-announces-n75-series-industrial-grade-m-2-nvme-ssds">Read full story</a></div>
(PR) KIOXIA Unveils the EXCERIA PLUS Portable SSD Series
KIOXIA, a worldwide leader in memory solutions, today announced the launch of the EXCERIA PLUS Portable SSD Series, scheduled to be released in November. The portable SSD series fits up to 2 TB of data in a new compact palm-size and rounded design. Compatible out-of-the-box with multiple host devices including PCs, smartphones, tablets and game consoles, making these portable SSDs suitable for on-the-go users and content creators seeking high-speed transfer of large data files.<br />
<br />
The EXCERIA PLUS Portable SSD Series utilizes KIOXIA's BiCS FLASH 3D flash memory and offers a line-up of capacities in 500 GB, 1 TB and 2 TB. With a maximum sequential read speed of 1,050 MB/s, the new series features a USB Type-C connector with a USB 3.2 Gen2 interface enabling fast transferring of 4K videos and high-resolution photos. Each EXCERIA PLUS Portable SSD also includes cables of both Type-C to A and Type-C to C to ensure the drive works on both current and legacy systems.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/agCapW1Pk7g0BrrO.jpg" target="_blank" data-width="800" data-height="532" ><img src="https://tpucdn.com/img/agCapW1Pk7g0BrrO_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289081/kioxia-unveils-the-exceria-plus-portable-ssd-series">Read full story</a></div>
AMD Expected to See 65 Percent Growth Rate in Sales for 2021, Intel Down One Percent
According to an industry report by IC Insights, AMD will see a yearly growth rate of no less than 65 percent this year, compared to 2020, whereas Intel is expected to have a slightly negative growth rate of one percent. The report includes the top 25 semiconductor sales leaders, ranked by growth rate, although it should be pointed out that some of them are foundries and not just semiconductor companies.<br />
<br />
AMD is closely followed by MediaTek, which is expected to reach a 60 percent growth rate this year, followed by Nvidia at 54 percent and Qualcomm and 51 percent growth. The only surprise in the top five is PRC based SMIC, which saw a 39 percent growth this year, despite, or maybe because of the US sanctions against various Chinese IC makers.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6bBQCtaGRrv5YEFP.jpg" target="_blank" data-width="409" data-height="641" ><img src="https://tpucdn.com/img/6bBQCtaGRrv5YEFP_thm.jpg" width="83" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289080/amd-expected-to-see-65-percent-growth-rate-in-sales-for-2021-intel-down-one-percent">Read full story</a></div>
(PR) Imagination launches RISC-V CPU family
Imagination Technologies announces Catapult, a RISC-V CPU product line designed from the ground-up for next-generation heterogeneous compute needs. Based on RISC-V, the open-source CPU architecture, which is transforming processor design, Imagination's Catapult CPUs can be configured for performance, efficiency, or balanced profiles, making them suitable for a wide range of markets.<br />
<br />
Leveraging Imagination's 20 years of experience in delivering complex IP solutions, the new CPUs are supported by the rapidly expanding open-standard RISC-V ecosystem, which continues to shake up the embedded CPU industry by offering greater choice. Imagination's entry will enable the rapidly expanding RISC-V ecosystem to add a greater range of product offerings, especially for heterogeneous systems. Now customers have an even wider choice of solutions built on the open RISC-V ISA, avoiding lock-in with proprietary architectures.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4beBkncNJT1BkhHR.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/4beBkncNJT1BkhHR_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZAHT0etfBWJu1D1Q.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/ZAHT0etfBWJu1D1Q_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/vaJvn4EL5FrfwqOn.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/vaJvn4EL5FrfwqOn_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/opR6KGIJetlQCenY.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/opR6KGIJetlQCenY_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289656/imagination-launches-risc-v-cpu-family">Read full story</a></div>
(PR) 2021 Annual Global Power Management IC Prices Jump 10%, Supply Remains Tight for 1H22, Says TrendForce
Due to material shortages caused by insufficient semiconductor supply, to date, power management IC (PMIC) prices remain on an upward trend, according to TrendForce's latest investigations. Average selling price (ASP) for 1H22 is forecast to increase by nearly 10%, reaching a record six year high.<br />
<br />
In terms of the global supply chain, in addition to the production capacity of major IDM manufacturers including TI, Infineon, ADI, STMicroelectronics, NXP, ON Semiconductor, Renesas, Microchip, ROHM (Maxim has been acquired by ADI and Dialog by Renesas), IC design houses such as Qualcomm and MediaTek (MTK) have obtained a certain level of production capacity from foundries. Of these, TI is in a leadership position and the aforementioned companies possess a combined market share of over 80%.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Pb2GGOYjpo2qvdyA.jpg" target="_blank" data-width="540" data-height="354" ><img src="https://tpucdn.com/img/Pb2GGOYjpo2qvdyA_thm.jpg" width="198" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289655/2021-annual-global-power-management-ic-prices-jump-10-supply-remains-tight-for-1h22-says-trendforce">Read full story</a></div>
(PR) Omni Remotes launches "perpetual" remote control
Omni Remotes, a global leader in home control solutions, today announced a new remote that requires no battery replacement or recharging over its entire product lifetime. The solar-powered Model P has the potential to significantly reduce the use and disposal of alkaline batteries. Leveraging Omni' low-power hardware platform, Model P supports standard voice commands as well as Bluetooth and infrared keypresses, while drawing virtually no current while in standby. Coupled with advancements in solar harvesting, Model P can essentially operate in perpetuity, given 8 hours of daily indoor lighting. Even in complete darkness, its built-in power reserves can sustain 4 months of regular use.<br />
<br />
Designed without a battery compartment or charging port, Model P measures just 10 mm thick. Its solar panel is seamlessly designed into the rest of the remote, defying the utilitarian look of conventional solar devices. Currently offered to leading pay TV operators, it is compatible with Android TV, RDK and other popular set-top box systems.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DugO8diZ5OhWpzSr.jpg" target="_blank" data-width="566" data-height="768" ><img src="https://tpucdn.com/img/DugO8diZ5OhWpzSr_thm.jpg" width="96" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1Ufzj0jN4K4rwgl5.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/1Ufzj0jN4K4rwgl5_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289653/omni-remotes-launches-perpetual-remote-control">Read full story</a></div>
AOC Launches 43-inch 4K 144 Hz HDR 1000 Gaming Display
The large screen gaming market has grown by yet another model in the shape of the AOC G4309VX/D, which is built around a 43-inch VA panel with a resolution of 3840 x 2160. The display is rated at HDR 1000, although the peak SDR brightness lands at 720 cd/m², which is still very bright considering the size of the display. <br />
<br />
The refresh rate tops out at 144 Hz and the response time is said to be 1 ms, via the DP 1.4 port using DSC or the two HDMI 2.1 ports. There's support for adaptive sync and motion blur reduction, which should make this a good choice for both PC and console gaming. The G4309VX/D also features four USB 3.0 ports, or USB 3.2 gen 1 if you prefer. It should be noted that there appears to be two different versions of this display, with the G4309VX currently selling for around US$1,300 in Taiwan, but it lacks HDMI 2.1, although the rest of the spec appears to be near identical. No word on pricing for the G4309VX/D as yet, but we'd expect it to end up in a similar price bracket.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CndToJwfDOZ4TfLX.jpg" target="_blank" data-width="886" data-height="824" ><img src="https://tpucdn.com/img/CndToJwfDOZ4TfLX_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XzzaoB93AEGV3EHp.jpg" target="_blank" data-width="794" data-height="570" ><img src="https://tpucdn.com/img/XzzaoB93AEGV3EHp_thm.jpg" width="181" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ctpKEuIEKAXH97eY.jpg" target="_blank" data-width="806" data-height="594" ><img src="https://tpucdn.com/img/ctpKEuIEKAXH97eY_thm.jpg" width="176" height="130" alt="" /></a></div>
Qualcomm CEO Expects Chip Shortage To Ease in 2022
Qualcomm CEO Cristiano Amon has claimed that the global chip shortage is easing with the situation expected to improve further in 2022. The availability of chips in 2022 should be significantly improved compared to 2020 Cristiano Amon told reporters in South Korea on Thursday. Qualcomm has struggled to meet the demand for its smartphone processors which has resulted in reduced smartphone production. The next-generation Qualcomm Snapdragon 8 Gen 1 processor recently <a href="https://www.techpowerup.com/289486/qualcomm-announces-worlds-most-advanced-mobile-platform-the-snapdragon-8-gen-1" target="_blank">announced</a> by the company will be manufactured on Samsung Foundry's 4 nm node with the yield rate ultimately determining Qualcomm's ability to meet demand in 2022. This prediction is slightly more optimistic than other companies including Intel and IBM who don't expect the shortage to be resolved until 2023.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/XjSxc34qs75DSwhI.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/XjSxc34qs75DSwhI_thm.jpg" width="231" height="130" alt="" /></a></div>
Valve Unveils Steam Deck Final Packaging & Carry Case
Valve has recently completed the final Design Validation (DV) prototype for the Steam Deck incorporating improvements from the previous EV2 builds. This latest design revision also sees the confirmation of retail packaging for the device which consists of a simple cardboard box with a region-specific power supply, Steam Deck, carry case, and setup instructions. The portable carrying case for the 64 GB and 256 GB models was also shown with the 512 GB version set to receive a unique version. The Valve Steam Deck features an AMD Zen 2 processor with integrated RDNA 2 graphics and is available to pre-order at 399 USD for the 64 GB base model with new orders not expected to ship until Q2 2022. Valve will begin shipping these DV kits to game developers shortly allowing them to optimize their titles for the device before it begins shipping in February 2022.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/IljDyaKv9gM0dSRy.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/IljDyaKv9gM0dSRy_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rPFSaRgAlAugmt27.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/rPFSaRgAlAugmt27_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/RaYEhL7wCrLvVLwh.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/RaYEhL7wCrLvVLwh_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Kicas5EcBzT37e0z.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/Kicas5EcBzT37e0z_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4weizF05pRNMu8xP.jpg" target="_blank" data-width="1440" data-height="960" ><img src="https://tpucdn.com/img/4weizF05pRNMu8xP_thm.jpg" width="195" height="130" alt="" /></a></div>
AMD and Intel Announce Online Press Events on January 4, 2022
January 4, 2022 could be a date of major product announcements by both AMD and Intel as part of their International CES 2022 plans. Both companies will host virtual press-meets on that day, and are expected to unveil several product lines. AMD could shed more like on its Ryzen "Vermeer-S" Socket AM4 desktop processors, possible updates to its Ryzen 5000 mobile product stack; as well as put out some juicy nuggets of info on its future "Zen 4" processors; while Intel will significantly expand its 12th Gen Core "Alder Lake" family across both its desktop and mobile segments, along with more info on its Arc "Alchemist" gaming GPU. The AMD event is slated for 8 AM Pacific, while the Intel one goes up two hours later, at 10 AM Pacific. We will be live-blogging both.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/VMDv4f4UllTqg4dY.jpg" target="_blank" data-width="1132" data-height="637" ><img src="https://tpucdn.com/img/VMDv4f4UllTqg4dY_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kfghZjCZcDs1cOp3.jpg" target="_blank" data-width="1661" data-height="960" ><img src="https://tpucdn.com/img/kfghZjCZcDs1cOp3_thm.jpg" width="225" height="130" alt="" /></a></div>
Intel Prepares Raptor Lake Designs With 24 Cores and 32 Threads, More E-Cores This Time
With the launch of Intel's Alder Lake processors, Intel has switched from a homogeneous to a heterogeneous design of processors, where smaller, high-efficiency cores are mixed with high-performance cores to create a highly efficient and high-performance processor for all kinds of workloads. And it seems like Intel is not over with adding more E-cores to its future products, as the latest leaks suggest. According to the BAPCO's Crossmark benchmark database, Intel's upcoming Raptor Lake processors will feature more E-cores than the high-performance P-cores in the SoC design. As to why this design choice is present, we are not sure and don't have a definitive answer.<br />
<br />
E-Cores are suitable for background tasks, and adding more would potentially leave space for P-cores to do heavier workloads. In the benchmark submission, which is now offline, the samples used were a configuration with eight P-cores and sixteen E-cores. Since the big cores are hyperthreaded, it makes up for a total composition of 24 cores with 32 threads. The platform "RPL-S ADP-S DDR5 UDIMM OC CRB" was used with DDR5-4800 memory, indicating an early stage engineering sample with a probably unfinished memory controller. The Raptor Lake generation will also use LGA 1700 socket, DDR5 memory and be present in the desktop and mobile sector once it launches in Q4 of 2022. It will also use Intel's 7 semiconductor manufacturing process, similar to Alder Lake. The only difference with the next-generation design is the updated Raptor Cove core design that brings a significant IPC uplift.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/FlpC6FmwOVEq0ICl.jpg" target="_blank" data-width="1170" data-height="780" ><img src="https://tpucdn.com/img/FlpC6FmwOVEq0ICl_thm.jpg" width="195" height="130" alt="" /></a></div>
AeroCool Intros Raven 4 ARGB Cooler
AeroCool today introduced the Raven 4 ARGB, a tower-type CPU cooler that relies on a custom design 120 mm fan. The cooler uses a typical aluminium fin-stack heatsink design. Four 6 mm-thick nickel-plated copper heat pipes make direct contact with the CPU at the base, conveying heat through the aluminium fin-stack. This is ventilated by the 120 mm fan, with a unique frame design that guides airflow such that it envelopes the fin-stack along all sides. <br />
<br />
The fan takes in a 4-pin PWM connection for its main function, and 3-pin ARGB for its lighting. The fan turns at speeds ranging between 900 to 1,800 RPM, pushing 24.1 to 58 CFM of airflow, with a noise output ranging between 18 to 27 dBA. The fan uses a hydraulic bearing rated for 60,000 hours. The cooler measures 125 mm x 80 mm x 135 mm (WxDxH). Among the CPU socket types supported are LGA1700, LGA1200, LGA115x, and AM4.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dl6IxR4VGV6mC2PY.jpg" target="_blank" data-width="710" data-height="584" ><img src="https://tpucdn.com/img/dl6IxR4VGV6mC2PY_thm.jpg" width="158" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/TuPV7ySDkUlv63Xy.jpg" target="_blank" data-width="751" data-height="584" ><img src="https://tpucdn.com/img/TuPV7ySDkUlv63Xy_thm.jpg" width="167" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/obw7xoJhcNa9wRhX.jpg" target="_blank" data-width="736" data-height="584" ><img src="https://tpucdn.com/img/obw7xoJhcNa9wRhX_thm.jpg" width="164" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/6IGbAOQQY3lLHdIg.jpg" target="_blank" data-width="668" data-height="584" ><img src="https://tpucdn.com/img/6IGbAOQQY3lLHdIg_thm.jpg" width="149" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/hfIeCHWc8D0a5fQN.jpg" target="_blank" data-width="701" data-height="584" ><img src="https://tpucdn.com/img/hfIeCHWc8D0a5fQN_thm.jpg" width="156" height="130" alt="" /></a></div>
MSI MEG Z690 GODLIKE Motherboard to Bundle AIO Cooler and Memory Sticks
The retail version of MSI MEG Z690 GODLIKE, the company's flagship Socket LGA1700 motherboard, will include an all-in-one liquid CPU cooler, and DDR5 memory sticks. Snapped at a PC retailer, the front-face of the retail box of the motherboard reads that the contents include an MSI <a href="https://www.techpowerup.com/287210/msi-announces-meg-coreliquid-s-series-high-end-aio-cpu-coolers" target="_blank">MEG CoreLiquid S360</a> cooler, and Kingston <a href="https://www.techpowerup.com/288372/kingston-announce-fury-beast-ddr5-memory-modules" target="_blank">FURY Beast DDR5</a> memory. The size and speed of the memory is not mentioned. What's also unknown at this point, is whether the board comes in retail packages that don't bundle the cooler or memory. Assuming the bundled memory is a 32 GB (2x 16 GB) kit of decent specs, such as DDR5-6000, this motherboard could easily command a four-figure price, with speculative prices averaging $1,500.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ooAEbhLaCe4fI7VG.jpg" target="_blank" data-width="1600" data-height="1200" ><img src="https://tpucdn.com/img/ooAEbhLaCe4fI7VG_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OHNr2yu1cjwwHfJx.jpg" target="_blank" data-width="900" data-height="1200" ><img src="https://tpucdn.com/img/OHNr2yu1cjwwHfJx_thm.jpg" width="98" height="130" alt="" /></a></div>
AMD Radeon Software Adrenalin 21.12.1 Released
AMD today released Radeon Software Adrenalin 21.12.1. These drivers add optimization for "Halo Infinite," with up to 17% increase in frame-rates measured on the RX 6900 XT, at 4K Ultra settings over the previous driver version; up to 19% increase measured with the RX 6800 XT, and up to 16% measured with the RX 6700 XT. Optimization is also added for "Icarus" and Blender 3.0 on RX 6000 series graphics cards. Among the fixes include a SteamVR Home noticed on the Radeon VII; driver time-outs noticed with the RX 5500 XT in "Marvel's Guardians of the Galaxy;" Radeon Software becoming unresponsive with PUBG on multi-display mode with extended display; and artifacting noticed in "Forza Horizon 5" with the car models on cards such as the RX 500 series. <br />
<br />
<b>DOWNLOAD:</b> <a href="https://www.techpowerup.com/download/amd-radeon-graphics-drivers/" target="_blank">AMD Radeon Software Adrenalin 21.12.1</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/9xCn2EG6jmUWx5dR.jpg" target="_blank" data-width="1200" data-height="800" ><img src="https://tpucdn.com/img/9xCn2EG6jmUWx5dR_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XE8iCNWrScWFSsQs.jpg" target="_blank" data-width="1400" data-height="700" ><img src="https://tpucdn.com/img/XE8iCNWrScWFSsQs_thm.jpg" width="260" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289597/amd-radeon-software-adrenalin-21-12-1-released">Read full story</a></div>
(PR) AZZA Announces a Luxurious Cube Case with Infinity Mirror ARGB - REGIS 902
AZZA, a leading brand of computer cases and accessories, introduces the REGIS 902. This luxury case is uniquely designed with a cube form factor, elevated above the surface by a premium aluminium stand, and has an infinity mirror addressable RGB front panel. The exterior is complemented with black tinted tempered glass panels and two brushed aluminium mesh panels with a touch of gold trim on the edges. ATX motherboard compatible, the REGIS supports up to 336 mm long GPUs and dual 240/280 radiators.<br />
<br />
The REGIS has 3-sided black tinted tempered glass panels, two sides for displaying the system, and the front for featuring an infinity mirror addressable RGB which uses an ultra-thin lighting module. The addressable RGB can be controlled via the case button, or synchronized with any motherboard software. At the bottom, two anodized and brushed aluminium panels with large mesh openings complete the frame of the Regis. Each panel is mounted on snap pins for tool-less removal. In addition, golden trims on 4 of the edges highlight the luxurious look of the cube.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4WknqppVzdseH7bZ.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/4WknqppVzdseH7bZ_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LC1Flaqk8FrswQp3.jpg" target="_blank" data-width="800" data-height="901" ><img src="https://tpucdn.com/img/LC1Flaqk8FrswQp3_thm.jpg" width="115" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/YhpwAUb9a9qS5G0t.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/YhpwAUb9a9qS5G0t_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XNKyi5Zs0XidYJlI.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/XNKyi5Zs0XidYJlI_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/OToiFATAdJJALBht.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/OToiFATAdJJALBht_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/r29jXxXnUybznXNF.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/r29jXxXnUybznXNF_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dZx74joyrcKhzNiO.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/dZx74joyrcKhzNiO_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289592/azza-announces-a-luxurious-cube-case-with-infinity-mirror-argb-regis-902">Read full story</a></div>
(PR) Chieftec Unveils Stallion 3 ARGB Case
Today CHIEFTEC is proud to introduce the new iteration of the highly successful Stallion gaming tower series: The Stallion 3. The latest version comes with many upgraded features, such as a mesh front, 4x A-RGB rainbow fans from the Tornado series, a slide-in tempered glass side panel for easy installation, as well as a more elegant and slimmer GPU holder on the inside.<br />
<br />
The technical specifications of the chassis itself remains unchanged with E-ATX M/B support, 360 mm radiator support in the front, 240 mm radiator support in the top, 2x 3.5" HDD and 4x 2.5" SSD support. We are excited to offer our customers overall modernized version of an already well-received chassis.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kXs8nWU1q5hWPMEZ.jpg" target="_blank" data-width="600" data-height="616" ><img src="https://tpucdn.com/img/kXs8nWU1q5hWPMEZ_thm.jpg" width="127" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DGZhoDKttsVElboW.jpg" target="_blank" data-width="652" data-height="574" ><img src="https://tpucdn.com/img/DGZhoDKttsVElboW_thm.jpg" width="148" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/te3dmjHTiMAtQHT4.jpg" target="_blank" data-width="692" data-height="586" ><img src="https://tpucdn.com/img/te3dmjHTiMAtQHT4_thm.jpg" width="154" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/5P41FUolXPhanTfC.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/5P41FUolXPhanTfC_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/oCdhPc6O2Ay2ZTUS.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/oCdhPc6O2Ay2ZTUS_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289577/chieftec-unveils-stallion-3-argb-case">Read full story</a></div>
UMC is Feeling the Pressure from Chinese Foundries
The chip shortage discussion has been very focused on TSMC for some reason and although the company is without a doubt the world's leading foundry, the company is making its living from being a cutting edge foundry, whereas much of the components that there's a shortage of are made on far older nodes at many different foundries. Taiwanese UMC is one of the foundries that makes many of the automotive semiconductors, as well as key components when it comes to power regulation and is considered the world's third largest foundry. <br />
<br />
Until 2018, UMC was competing head on with TSMC, although the company was always about a node behind TSMC, which led to a management team decision to slow down its node transition and instead to focus on speciality technologies. The company has done well in this niche, with a revenue of about US$6.2 billion in 2020. However, UMC is starting to feel the pressure from its competitors in China, as the PRC government is making a push for local production of local IC designs.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JesS9wWJAICbN3GS.jpg" target="_blank" data-width="800" data-height="600" ><img src="https://tpucdn.com/img/JesS9wWJAICbN3GS_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289576/umc-is-feeling-the-pressure-from-chinese-foundries">Read full story</a></div>
Intel Negotiates 3nm Allocation with TSMC Even as Pat Gelsinger Cautions Against Investing in Taiwan
Intel is reportedly in talks with TSMC to secure foundry allocation to meet its product roadmap execution. The company is sending an executive delegation to meet with TSMC later this month, to secure foundry capacity for the N3 (3 nm) silicon fabrication node, and ensure that Intel's allocation isn't affected by other customers such as Apple. As part of its IDM 2.0 strategy, Intel has decided to build its products essentially as multi-chip modules with each block of IP built on a silicon fabrication node most optimal to it, so the company maximizes cutting-edge foundry nodes only on the technology that benefits from it the most. N3 will play a vital role with logic/compute tiles in products bound for 2023, as N3 hits critical volume in the first half of the year.<br />
<br />
In related news, Intel CEO Pat Gelsinger speaking at the Fortune Brainstorm Tech conference, stressed on the importance for American chip designers to seek out semiconductor manufacturing in America, and cautioned against investing in Taiwan (without naming TSMC). This comes in the wake of geopolitical uncertainty in the region. In response to this statement issued to DigiTimes, TSMC CEO Mark Liu downplayed the matter, and said that Gelsinger's statement wasn't worth responding to, and that he doesn't slander industry colleagues. TSMC and Samsung have each announced multi-billion Dollar foundry investments in the US, in attempts to make the global semiconductor supply chains resilient to any security situation that may emerge in East Asia.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Bn0X0RiwWa3CiyYR.jpg" target="_blank" data-width="600" data-height="466" ><img src="https://tpucdn.com/img/Bn0X0RiwWa3CiyYR_thm.jpg" width="167" height="130" alt="" /></a></div>
(PR) Graphics add-in board market reached $13.7 billion for Q3'21 showing double-digit growth year-2-year
According to a new research report from the analyst firm Jon Peddie Research, unit shipments of add-in boards increased in Q3'21 from last year. AMD saw a one-percent increase in market share while Nvidia remained the dominant market share leader with 78.2%. Year over year, total AIB shipments increased by 25.7% this quarter compared to last year at 12.7 million units, and up quarter-to-quarter from 11.47 million units in Q2'21.<br />
<br />
Add-in boards (AIBs) use discrete GPUs (dGPU) with dedicated memory. Desktop PCs, workstations, servers, rendering and mining farms, and scientific instruments use AIBs. Consumers and enterprises buy AIBs from resellers or OEMs. They can be part of a new system or installed as an upgrade to an existing system. Systems with AIBs represent the higher end of the graphics industry. Entry-level systems use integrated GPUs (iGPU) in CPUs that share slower system memory.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/csJFe3LxdUiOxBmT.jpg" target="_blank" data-width="447" data-height="415" ><img src="https://tpucdn.com/img/csJFe3LxdUiOxBmT_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QAiTbfDlohAK9tLL.jpg" target="_blank" data-width="443" data-height="523" ><img src="https://tpucdn.com/img/QAiTbfDlohAK9tLL_thm.jpg" width="110" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289574/graphics-add-in-board-market-reached-usd-13-7-billion-for-q321-showing-double-digit-growth-year-2-year">Read full story</a></div>
Synology Teases RT6600ax Router With 5.9 GHz UNII-4 Support
When it comes to routers, Synology might not be the first brand that springs to mind, but the company has produced some interesting routers, especially when you take into account its custom OS, the Synology Router Manager, or SRM for short. The company has teased a new addition to its small family of routers, which should launch at some point in the first quarter of next year, that brings with it a few interesting features.<br />
<br />
The RT6600ax as it's called, will be one of the first routers to support the UNII-4 WiFi band, also known as the 5.9 GHz band. This is an extension of the 802.11ax/WiFi 6 band and it's not related to WiFi 6E which uses the 6 GHz band. UNII-4 only adds a total of four 20 MHz WiFi channels, but the key here is that it allows for a third 160 MHz wide channel, something that could be handy in congested locations. For now, UNII-4 is only going to be usable in the US, although more countries are likely to be considering opening up the extra frequencies for WiFi usage. That said, it's unlikely that Europe and Japan will allow it, since neither region supports the UNII-3 frequency band.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/O3Nz65p9mKp6gItj.jpg" target="_blank" data-width="1280" data-height="1232" ><img src="https://tpucdn.com/img/O3Nz65p9mKp6gItj_thm.jpg" width="135" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Ta4OHhByXjPJO7q8.jpg" target="_blank" data-width="1280" data-height="526" ><img src="https://tpucdn.com/img/Ta4OHhByXjPJO7q8_thm.jpg" width="316" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LrrQFCbAj31tkzgF.jpg" target="_blank" data-width="1280" data-height="582" ><img src="https://tpucdn.com/img/LrrQFCbAj31tkzgF_thm.jpg" width="286" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289573/synology-teases-rt6600ax-router-with-5-9-ghz-unii-4-support">Read full story</a></div>
(PR) Team Group Launches TEAMGROUP Launches the Upgraded SIREN GD240E AIO ARGB CPU Liquid Cooler and M200 Portable SSD
Global memory brand TEAMGROUP has been leading the industry with its groundbreaking DDR5 memory products. Today, its gaming sub-brand T-FORCE announced the new SIREN GD240E All-In-One ARGB CPU Liquid Cooler, which comes with a mounting bracket for the latest LGA 1700 socket and fully supports 12th Generation Intel processors and Z690 motherboards, making it a must-have cooling solution for gamers. Launched alongside the CPU cooling system is the M200 Portable SSD, winner of Japan's 2021 GOOD DESIGN Award. Hardcore gamers around the world can look forward to both products when they are released globally this December.<br />
<br />
The newly upgraded SIREN GD240E AIO ARGB CPU Liquid Cooler not only supports various older Intel and AMD sockets but also provides a mounting kit for the latest LGA 1700 socket. The specially selected base plate, support screws, and mounting brackets enable the water block to fit snugly with the processor. The full and even contact between the surfaces aids heat transfer swiftly to the high-density jet fin heat sink, greatly increasing the heat dissipation area and quickly removing heat from the CPU. To optimize efficiency and the path of heat transfer, the SIREN GD240E is equipped with an ultra-fast 4000RPM water pump that's installed on the radiator to reduce wear and noise on the CPU caused by water pump vibrations. These features allow the system to deliver 1.5 times higher cooling performance than typical liquid-cooled products while also providing the best protection for the next-gen Intel processors. The SIREN GD240E is an all-in-one liquid cooler system with top-notch heat dissipation and visual flair thanks to the water block's elegant mirror finish and high-speed ARGB fans that support all major motherboard lighting software.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/7xfskzYXO4trsObi.jpg" target="_blank" data-width="992" data-height="779" ><img src="https://tpucdn.com/img/7xfskzYXO4trsObi_thm.jpg" width="166" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/CYUEgFKZNiwzQTaN.jpg" target="_blank" data-width="992" data-height="838" ><img src="https://tpucdn.com/img/CYUEgFKZNiwzQTaN_thm.jpg" width="154" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/e1gE3Tx3BTAspnRd.jpg" target="_blank" data-width="800" data-height="435" ><img src="https://tpucdn.com/img/e1gE3Tx3BTAspnRd_thm.jpg" width="239" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289571/team-group-launches-teamgroup-launches-the-upgraded-siren-gd240e-aio-argb-cpu-liquid-cooler-and-m200-portable-ssd">Read full story</a></div>
BadgerDAO Sees $120 Million Crypto Heist via Cloudflare Hack
BadgerDAO, "one of the most security-minded DAOs in operation", has been hit with a cryptocurrency heist enabled via a JavaScript hack on their website. BadgerDAO enables Bitcoin holders to "bridge" their cryptocurrency over to the smart-contract and DeFi-enabled Ethereum platform via its token, thus allowing access to the world of decentralized finance. After preliminary investigations aided by blockchain security and data analytics Peckshield, it seems that the bad actors inserted a malicious script in the BadgerDAO website - in turn intercepting Web 3.0 transactions and inserting a request to transfer the victim's tokens to the attacker's chosen address. It's currently estimated that around $120 million were siphoned off via this attack. A single transfer saw 896 Bitcoin being diverted this way - a cool $50 million.<br />
<br />
As soon as BadgerDAO became aware of suspect wallet activity, the company immediately froze all smart contracts running in its platform - a way to stem the bleeding until the security audit could be conducted. Thursday night, BadgerDAO announced it had "retained data forensics experts Chainalysis to explore the full scale of the incident & authorities in both the US & Canada have been informed & Badger is cooperating fully with external investigations as well as proceeding with its own."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fWHmK4SEjJjfdUkP.jpg" target="_blank" data-width="1469" data-height="836" ><img src="https://tpucdn.com/img/fWHmK4SEjJjfdUkP_thm.jpg" width="228" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PyM16ID8eFiN9aXN.jpg" target="_blank" data-width="1231" data-height="1210" ><img src="https://tpucdn.com/img/PyM16ID8eFiN9aXN_thm.jpg" width="132" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/kB0MHnffHTU35WsO.jpg" target="_blank" data-width="2302" data-height="1312" ><img src="https://tpucdn.com/img/kB0MHnffHTU35WsO_thm.jpg" width="228" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/289569/badgerdao-sees-usd-120-million-crypto-heist-via-cloudflare-hack">Read full story</a></div>
Windows 11 a Flop, Survey Claims Less Than 1% Upgraded, Microsoft Improves Start Menu
Microsoft Windows 11, now nearing its third month since release, is for all intents and purposes, a flop. Market research by Lansweeper, which surveyed over 10 million PCs across the commercial and personal market segments, reports that less than 0.21% of the users it surveyed, had upgraded from Windows 10 to the newer operating system. The upgrade is free of charge. There may be several factors contributing to this lukewarm market response, but one of them is certain to he the steep hardware requirements. Windows 11 requires a trusted platform module (TPM 2.0), which disqualifies PCs older than 2018 for upgrades, unless the user is willing to try out workarounds to the limitation. Another factor could be the clunky user interface (UI), a less functional Start menu than Windows 10, and several UI-related bugs.<br />
<br />
According to Lansweeper's data, there could be more people running outdated Windows XP, Vista, Windows 8, etc., than Windows 11, and this poses a great security risk, as these operating systems are no longer supported by Microsoft for regular security updates. Windows 10, on the other hand, is eligible for them until mid-2025—plenty of time for people to upgrade hardware to meet Windows 11 system requirements, or to simply make up their mind on switching over to the new operating system. In related news, Microsoft could give the Windows 11 Start menu a functional update. Test build 22509 introduces the ability to add more pins to the menu, or make room for more recommendations. The UI could see many such minor updates.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/uLC2Q3RIFsM3bP7C.jpg" target="_blank" data-width="1170" data-height="469" ><img src="https://tpucdn.com/img/uLC2Q3RIFsM3bP7C_thm.jpg" width="324" height="130" alt="" /></a></div>
(PR) COLORFUL Launches Warhalberd CN600 NVMe M.2 SSD
Colorful Technology Company Limited, a professional manufacturer of graphics cards, motherboards, all-in-one gaming and multimedia solutions, and high-performance storage, proudly presents its first-ever PCIe 3.0 NVMe solid-state drive - the COLORFUL WarHalberd CN600. COLORFUL collaborated with Yangtze Memory (YMTC) and Maxio Technology for the CN600 SSD. The cooperation between the companies will ensure the quality and performance of the flash components and the NVMe controller.<br />
<br />
The COLORFUL WarHalberd CN600 NVMe SSD is a low-profile NVMe SSD in a standard 2280 M.2 form factor, designed for desktop PCs, laptops, ultrabooks, and mini-PCs. Using PCIe 3.0 X4 interface, the WarHalberd CN600 delivers speeds of up to 3300 MB/s read and up to 2600 MB/s write. The SSD will be offered in 256 GB and 512 GB capacities.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/dV1RzPENqIGvOY46.jpg" target="_blank" data-width="547" data-height="539" ><img src="https://tpucdn.com/img/dV1RzPENqIGvOY46_thm.jpg" width="132" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290261/colorful-launches-warhalberd-cn600-nvme-m-2-ssd">Read full story</a></div>
Researchers at TU Wien have Developed Adaptive Transistor Using Germanium
Transistors as we know them appear to be in for a big change, at least if the latest development by researchers at TU Wien has anything to say about it. The group of researchers have developed what they call an adaptive transistor, or in other words, a transistor that can do more than hold a 0 or a 1. This has huge implications and although they're currently at a very early stage, the working proof of concept could allow for a whole new range of applications for microchips.<br />
<br />
It would appear that the new transistors are tricky to manufacture, based on the explanation by the researchers "We connect two electrodes with an extremely thin wire made of germanium, via extremely clean high-quality interfaces. Above the germanium segment, we place a gate electrode like the ones found in conventional transistors. What is decisive is that our transistor features a further control electrode, which is placed on the interfaces between germanium and metal. It can dynamically program the function of the transistor". The researchers are confident that this should be fairly straightforward to overcome, especially as their transistor doesn't require any "doping", something that is common with more complex transistors today.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/gB4rWpZOB1wohrtD.jpg" target="_blank" data-width="1280" data-height="1189" ><img src="https://tpucdn.com/img/gB4rWpZOB1wohrtD_thm.jpg" width="140" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290217/researchers-at-tu-wien-have-developed-adaptive-transistor-using-germanium">Read full story</a></div>
Intel Bans Chinese Components from Xinjiang Province, Turns Around and Apologises to China
In a very confusing move, Intel has informed its suppliers that it won't accept components that have been made in or by labour from the Xinjiang Province in China, only to turn around almost instantly and apologise to China for the fact that it has done so. That said, Intel doesn't appear to have changed its mind, the company simply apologised due to the backlash from Chinese citizens, who are threatening to boycott Intel products.<br />
<br />
Part of the reasoning behind the ban of components from the Xinjiang Province is said to be due to US laws and is apparently not entirely in line with Intel's own views on the situation. A statement from Intel said "We apologize for the distress caused to our esteemed Chinese customers, partners and the general public," although it's unclear if this is going to be enough to calm the Chinese public, which tend to be able to stir up quite a lot of trouble for foreign companies in China that are seem to be anti China.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/COepAt9OUhOU1KCF.jpg" target="_blank" data-width="1920" data-height="1280" ><img src="https://tpucdn.com/img/COepAt9OUhOU1KCF_thm.jpg" width="195" height="130" alt="" /></a></div>
Intel Said to be Considering Italy for European Chip Packaging Plant
Although Intel has already announced that it won't be making any decision with regards to its investments in Europe this year, new rumours courtesy of Reuters are now suggesting that Intel is eyeing Italy for an investment of €4 to €8 billion for a new, advanced semiconductor chip packaging plant. This largely leaves Germany and France as the options for Intel's so called "megafab" that the company is planning to build in Europe over the next few years.<br />
<br />
Intel has already said it would invest around US$7 billion for a similar chip packaging plan in Penang, Malaysia, a location where Intel already has a chip packaging facility. When contacted by Reuters, Intel said "We are encouraged by the many possibilities to support the EU's digital agenda and 2030 semiconductor ambitions. While current negotiations are ongoing and confidential, we plan to make an announcement as soon as possible." The Italian government is also said to have some concerns with regards to how many jobs the plant will actually create, as well as what the energy costs will be, which could throw a spanner in the works if Intel doesn't provide the right answers.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OAHdcbS4Ltnu99VB.jpg" target="_blank" data-width="514" data-height="259" ><img src="https://tpucdn.com/img/OAHdcbS4Ltnu99VB_thm.jpg" width="258" height="130" alt="" /></a></div>
AMD and GlobalFoundries Renew Wafer Supply Agreement
AMD in its 8-K filing with the SEC, disclosed that it has updated its wafer supply agreement (WSA) with GlobalFoundries. Under the latest agreement, AMD commits to buy $2.1 billion worth wafers from GlobalFoundries between 2022 and 2025. The previous version of the WSA saw commitments up to 2024, and wafers worth $1.6 billion. The update hence adds another year and $500 million worth supply. <br />
<br />
AMD currently sources 12 nm and 14 nm wafers from GlobalFoundries, which go into making cIOD and sIOD components in its processors, and motherboard chipsets. The move to extend the WSA indicates that the company may continue to use 12 nm-class I/O dies in its processors for the foreseeable future. It will be very interesting to see if 12 nm-class I/O dies make it to next-generation products such as "Genoa" and "Rapael," which integrate the latest IP blocks such as PCI-Express Gen 5 root-complexes, DDR5 memory controllers, and 3rd Gen Infinity Fabric. Processors with 12 nm I/O dies, such as "Milan" and "Vermeer" could be retired only by 2023-24, as AMD will use 2022 to spread across its next-gen product launches.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ddwW2trkTm1OBrJV.jpg" target="_blank" data-width="1260" data-height="709" ><img src="https://tpucdn.com/img/ddwW2trkTm1OBrJV_thm.jpg" width="231" height="130" alt="" /></a></div>
(PR) Club 3D Announces USB Gen 2 Type-C Triple Display Smart PD Charging Dock
The Club 3D CSV-1568 USB Gen2 Type-C Triple Display DP Alt mode + Smart PD Charging Dock with 120 Watt PSU, is an integrated solution combining Video, Data, Power, Ethernet and Audio. It has 4 videos (output 3 videos simultaneously under MST mode) for video transmission, 4 USB data ports (2 USB-A 10G, 1 Type-C 10G, 1 USB-A 5G) for data transmission, 1 USB-A smart charging port for quick charging, 1 Gigabit Ethernet for super fast Ethernet, 2 audio ports (3.5 mm audio, Toslink) for enjoying music. Besides, this dock is equipped with dual power jack (Type-C PD Charging or 120 W DC power supply). <br />
<br />
It supports all DP Alt mode 1.4/1.2 supported Type-C and Thunderbolt 3 host (PC, laptop, mobile phone, etc.) under Windows and under MacOS X based on Intel you will only get limited SST Function or Single display Only. This new dock will be available from first week of January 2022.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ddsa7h6SXpO5l8pO.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/ddsa7h6SXpO5l8pO_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/YcEkNpwoEW5FlIu9.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/YcEkNpwoEW5FlIu9_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Zky4xl46hReJEqcy.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/Zky4xl46hReJEqcy_thm.jpg" width="130" height="130" alt="" /></a></div>
(PR) Chuwi Announces MiniBook X Laptop with Hole-Punch Camera
MiniBook X comes loaded with the latest generation Intel 11th Celeron N5100 processor, including 10 nm process technology, quad-core and four threads, new Tremont microarchitecture, and a 10 W thermal power consumption design that ups the power while lowering the consumption. MiniBook X handles document editing, basic video production, and modern gaming with increased efficiency, while next-gen Intel UHD Graphics makes it easy to decode 4K video and fluidly handle online games.<br />
<br />
As an enhanced and upgraded version of MiniBook, MiniBook X introduces a 10.8-inch hole-punch display with 2K retina resolution, 90% screen-to-body ratio and a 16:10 aspect ratio for a shockingly immersive viewing experience. Chuwi has also added YOGA Mode to MiniBook X, giving it the 2 in 1 functionality of both a laptop and tablet and the ability to switch back and forth as needed quickly.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6ZxTxX8iDFzUD0xJ.jpg" target="_blank" data-width="1280" data-height="640" ><img src="https://tpucdn.com/img/6ZxTxX8iDFzUD0xJ_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Sn21xqQ3KAk8kGmf.jpg" target="_blank" data-width="1280" data-height="640" ><img src="https://tpucdn.com/img/Sn21xqQ3KAk8kGmf_thm.jpg" width="260" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1axdIgQHOdP0vVAL.jpg" target="_blank" data-width="1280" data-height="640" ><img src="https://tpucdn.com/img/1axdIgQHOdP0vVAL_thm.jpg" width="260" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290177/chuwi-announces-minibook-x-laptop-with-hole-punch-camera">Read full story</a></div>
(PR) European Processor Initiative (EPI) Completes Phase One of The Project
The European Processor Initiative (EPI), a project with 28 partners from 10 European countries aiming to make the EU achieve independence in high-performance computing (HPC) chip technologies and infrastructure, is proud to present key results achieved in phase one (2018-2021).<br />
<br />
These results stem from three major research and innovation domains, the General-Purpose Processor (GPP), Accelerator (EPAC) and Automotive streams, complemented by a number of common activities.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Haq9rPlarHnfx1y8.jpg" target="_blank" data-width="768" data-height="438" ><img src="https://tpucdn.com/img/Haq9rPlarHnfx1y8_thm.jpg" width="228" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290165/european-processor-initiative-epi-completes-phase-one-of-the-project">Read full story</a></div>
Leaked Document Confirms That MSI GeForce RTX 3090 Ti SUPRIM X Graphics Card Launches January 27th
In the past few months, we have heard rumors of NVIDIA launching an upgraded version of the GA102 silicon called <a href="https://www.techpowerup.com/gpu-specs/geforce-rtx-3090-ti.c3829" target="_blank">GeForce RTX 3090 Ti</a>. The upgraded version is supposed to max out the chip and bring additional performance to the table. According to anonymous sources of VideoCardz, MSI, one of NVIDIA's add-in board (AIB) partners, is preparing to update its SUPRIM X lineup of graphics cards with the MSI GeForce RTX 3090 Ti SUPRIM X GPU, scheduled for January 27th launch date. This suggests that the official NDA lifts for these RTX 3090 Ti GPUs on January 27th, meaning that we could see AIBs teasing their models very soon.<br />
<br />
As a general reminder, the GeForce RTX 3090 Ti graphics card should use a GA102-350 silicon SKU with 84 SMs, 10752 CUDA cores, 336 TMUs, 24 GB of GDDR6X memory running on a 384-bit bus at 21 Gbps speed with 1008 GB/s bandwidth, and a TBP of a whopping 450 Watts. If these specifications remain valid, the GPU could become the top contender in the market, however, with a massive drawback of pulling nearly half a KiloWatt of power.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/saFNUGTPzJaBQ5DN.jpg" target="_blank" data-width="1200" data-height="900" ><img src="https://tpucdn.com/img/saFNUGTPzJaBQ5DN_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LzDC7iR2cEgG79Gh.jpg" target="_blank" data-width="850" data-height="418" ><img src="https://tpucdn.com/img/LzDC7iR2cEgG79Gh_thm.jpg" width="264" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/incU6NXStFDzSiUs.jpg" target="_blank" data-width="1280" data-height="519" ><img src="https://tpucdn.com/img/incU6NXStFDzSiUs_thm.jpg" width="321" height="130" alt="" /></a></div>
CES Organizer Claims Chip Shortage, Not Covid is Keeping Exhibitors at Home
January 5th is when CES 2022 is set to kick off and we've already seen reports of several big brands cancelling their attendance, but according to the Consumer Technology Association (CTA) who are the organisers behind CES, it's not because of Covid, but rather due to the chip shortage. The fact that most countries have imposed travel restrictions and even gone into fairly strict lockdowns seems to have eluded the CTA as its CEO claims exhibitors aren't overly concerned about the virus.<br />
<br />
Instead, the reasoning by the CTA CEO goes along the lines of the chip shortage causing issues with prototypes and product samples, so the companies that were planning to attend CES won't have any products to showcase. This seems like some very strange logic, since from what we've seen so far, prototypes and product samples don't seem to be a major concern. That said, the CTA is correct that logistics are going to be a nightmare this year, as shipping delays are not uncommon and are likely to cause bigger problems for the exhibitors this year than anything else. TPU is still expecting to be on location in Las Vegas for next year's show, unless something changes drastically in the next week and half.
AMD Threadripper Pro 5000 Series Spec Leaks
There has been some discussion as to whether or not AMD would launch any Zen 3 based Threadripper processors or not, considering that the desktop processors have been out for well over a year by now. According to igor's Lab, we now know that AMD is very close to launching some new 5000-series Threadripper Pro CPU's—codename Chagall—that fits into AMD's sWRX8 socket, which is intended for high-end workstations and servers.<br />
<br />
It appears AMD is planning to launch five new CPUs, namely the 5995WX, 5975WX, 5965WX, 5955WX and 5945WX. All of the CPUs appear to have a maximum, single core boost clock of 4550 MHz and range from 12 to 64 cores, with a TDP of 280 W and a power range of 170 to 260 Watts. Up to eight channels of DDR4 3200 MHz is supported and up to 128 PCIe 4.0 are expected to be featured as well. For those hoping there would be an HEDT version, we have bad news, as based on what we've found out independently and the information provided by igor's Lab, there won't be any HEDT Chagall CPUs, at least not at this point in time. This means that the upgrade path for sTRX4 motherboards ended up being as bad as for the older TR4 motherboards, as AMD has now abandoned two HEDT platforms in a row.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/lPLMJUW7i6Qt7MIA.jpg" target="_blank" data-width="980" data-height="755" ><img src="https://tpucdn.com/img/lPLMJUW7i6Qt7MIA_thm.jpg" width="169" height="130" alt="" /></a></div>
(PR) Thermaltake Unveils TOUGHFAN 12 and 14 High Static-Pressure Radia
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, unveils the new TOUGHFAN 12/14 High Static Pressure Radiator Fan White to add some flair to the original TOUGHFAN series while continuing to achieve superlative cooling results. The multicolored TOUGHFAN series become more comprehensive with a series of colors including Black, Turquoise, Racing Green and White for the TOUGHFAN 12, and Black and White for the TOUGHFAN 14.<br />
<br />
Alike all the TOUGHFAN series products, the TOUGHFAN 12/14 High Static Pressure Radiator Fan White Edition guarantees quiet cooling performance, outstanding stability, and superior lifespan. The TOUGHFAN 12/14 White features a high static pressure fan with PWM-control, allowing the fan to perform at a maximum operating speed of up to 2000 RPM while maintaining a low audio noise level of only 22.3 dB-A. The centerpiece of the TOUGHFAN 12/14's motor hub is made of full steel and copper housing that reinforces the shaft, which can help to enhance the stability and durability as well as lower noise level while the fan is operating. The anti-vibration rubber pads attached to the corners also helps dampen the vibration and protect the fan as well as the case. Besides, an optimized second-generation hydraulic bearing in a unique structure design allows lubricant to concentrate in lubricating the critical areas, better reducing friction and further extending the fan's lifespan.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UiWpGc8lowdUiUvy.jpg" target="_blank" data-width="943" data-height="1000" ><img src="https://tpucdn.com/img/UiWpGc8lowdUiUvy_thm.jpg" width="123" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8mL5xnMJMeJ2Q9tA.jpg" target="_blank" data-width="1028" data-height="1000" ><img src="https://tpucdn.com/img/8mL5xnMJMeJ2Q9tA_thm.jpg" width="134" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZeLHdDK7JAtr9gX1.jpg" target="_blank" data-width="1379" data-height="1000" ><img src="https://tpucdn.com/img/ZeLHdDK7JAtr9gX1_thm.jpg" width="179" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/RR34N9O2LIAg1HHG.jpg" target="_blank" data-width="937" data-height="552" ><img src="https://tpucdn.com/img/RR34N9O2LIAg1HHG_thm.jpg" width="221" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JPbl1cGZHLx1jFT1.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/JPbl1cGZHLx1jFT1_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290157/thermaltake-unveils-toughfan-12-and-14-high-static-pressure-radiator-fan-white-edition">Read full story</a></div>
(PR) XPG to Showcase Latest Breadth and Depth of Products at CES 2022
XPG, a fast-growing provider of systems, components, and peripherals for Gamers, Esports Pros, and Tech Enthusiasts, today announces it will be on location in Las Vegas during the 2022 CES show (Jan. 5-8). Under the theme of 'Dawn of a New Xtreme,' it will be showing off the latest products from XPG and ADATA including gaming systems, peripherals, accessories, and components, such as the newest DDR5 memory, PCIe 5.0 solid state drives (SSD) and the latest state-of-the-art Platinum PSU.<br />
<br />
XPG's and ADATA are gearing up to bring next-generation performance to gamers and other users with its latest PCIe Gen5x 4 SSDs and DDR5 DRAM. At the booth, visitors will get a first look at the XPG LANCER RGB DDR5 and CASTER RGB DDR5 that deliver next-level performance of up to 6000 MT/s and 7000 MT/s, respectively. ADATA's industrial-grade DDR5-4800 U/SO/R-DIMM memory with on-die ECC & PMIC will also be on display.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jLLTzNg5XBPbqkEV.jpg" target="_blank" data-width="1280" data-height="1131" ><img src="https://tpucdn.com/img/jLLTzNg5XBPbqkEV_thm.jpg" width="147" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/EOwmNuLdYZNZQiCH.jpg" target="_blank" data-width="1280" data-height="1198" ><img src="https://tpucdn.com/img/EOwmNuLdYZNZQiCH_thm.jpg" width="139" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AIaIb1NBYZQPobvq.jpg" target="_blank" data-width="1280" data-height="1169" ><img src="https://tpucdn.com/img/AIaIb1NBYZQPobvq_thm.jpg" width="142" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cblyha9Qtkh5F4vt.jpg" target="_blank" data-width="1280" data-height="1276" ><img src="https://tpucdn.com/img/cblyha9Qtkh5F4vt_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290156/xpg-to-showcase-latest-breadth-and-depth-of-products-at-ces-2022">Read full story</a></div>
(PR) Samsung Electronics Announces HDR10+ GAMING Standard Support for Its New Screens
Samsung Electronics announced today that select 2022 4K and 8K TVs and gaming monitors will support the new HDR10+ GAMING standard, delivering the immersive, ultra-responsive HDR gaming experience to gamers. The new, cutting-edge HDR gameplay will be unveiled at CES 2022 along with a list of 4K and 8K game titles, all powered by NVIDIA GPUs.<br />
<br />
"We are extremely proud to announce that the new HDR10+ GAMING standard will be adopted by Samsung's 2022 Neo QLED line up with the Q70 TV series and above and gaming monitors, allowing users to enjoy a game-changing experience through cutting-edge visuals and richer, life-like images," said Seokwoo Yong, Executive Vice President and Head of R&D Team, Visual Display Business at Samsung Electronics. "Samsung will continue to invest in users' viewing experiences as technology continues to advance and provide enhanced new features and capabilities."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3pkz3PiCWTLrzyHc.jpg" target="_blank" data-width="1000" data-height="563" ><img src="https://tpucdn.com/img/3pkz3PiCWTLrzyHc_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290151/samsung-electronics-announces-hdr10-gaming-standard-support-for-its-new-screens">Read full story</a></div>
(PR) SK hynix Receives Merger Clearances for Intel NAND and SSD Business Acquisition
SK hynix Inc. today announced that it has received merger clearance from the Chinese antitrust authority, State Administration for Market Regulation (SAMR) for its acquisition of Intel NAND and SSD business. With SAMR's merger clearance SK hynix has received all required merger clearances in eight jurisdictions from the relevant competition authorities.<br />
<br />
SK hynix will continue to prepare to close the transaction including achieving all of the closing conditions. The consideration for the 1st Closing is USD 7 billion. Upon the 1st Closing, SK hynix will acquire the Intel SSD business (including SSD-associated IP and employees) and Dalian facility. SK hynix sincerely welcomes and appreciates SAMR's merger clearance for the deal. SK hynix will enhance its competitiveness of NAND Flash and SSD business by continuing the remaining post-merger integration process.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/iqyfjvXTmxedEddM.jpg" target="_blank" data-width="1441" data-height="960" ><img src="https://tpucdn.com/img/iqyfjvXTmxedEddM_thm.jpg" width="195" height="130" alt="" /></a></div>
(PR) FORESEE Launches Commercial DDR5 to Empower Big Data Era
Since 2020, data centers have seen additional development opportunities driven by new infrastructure. For this reason, DDRs have been developed to become faster and more efficient. On July 14, 2020, JEDEC released the DDR5 SDRAM standard, marking the industry-wide transition to DDR5 server dual in-line memory modules (DIMMs). In China, mainstream manufacturers are gradually focusing on DDR5, striving to promote its widespread commercialization. DDR5 brings with it a series of crucial improvements to help empower next-gen servers with better performance and lower power consumption.<br />
<br />
With 22 years of experience in the storage industry, Longsys is constantly accumulating industrial experience while remaining centered on R&D technology. As the first company in China to do so, it has made multiple DDR5 test data items publicly available. FORESEE, the industrial storage brand of Longsys, has recently launched commercial DDR5 U-DIMM, available in 16 GB and 32 GB options.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UtRB42yd3ERP4JZF.jpg" target="_blank" data-width="600" data-height="360" ><img src="https://tpucdn.com/img/UtRB42yd3ERP4JZF_thm.jpg" width="217" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290149/foresee-launches-commercial-ddr5-to-empower-big-data-era">Read full story</a></div>
(PR) Samsung Develops PM1743 High-Performance PCIe 5.0 SSD for Enterprise Servers
Samsung Electronics Co., Ltd., the world leader in advanced memory technology, today announced that it has developed the PM1743 SSD for enterprise servers, integrating the PCIe (Peripheral Component Interconnect Express) 5.0 interface with Samsung's advanced sixth-generation V-NAND.<br />
<br />
"For over a decade, Samsung has been delivering SATA, SAS and PCIe-based SSDs that have been recognized for outstanding performance and reliability by leading enterprise server customers including corporations, governments and financial institutions," said Yong Ho Song, Executive Vice President and Head of the Memory Controller Development Team at Samsung Electronics. "The introduction of our PCIe 5.0 SSD, along with PCIe 6.0-based product developments that are underway, will further solidify our technological leadership in the enterprise server market."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ilrRJSQaKcEK3yr9.jpg" target="_blank" data-width="1326" data-height="1000" ><img src="https://tpucdn.com/img/ilrRJSQaKcEK3yr9_thm.jpg" width="172" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290148/samsung-develops-pm1743-high-performance-pcie-5-0-ssd-for-enterprise-servers">Read full story</a></div>
(PR) Intel Releases oneAPI 2022 Toolkits to Developers
Intel today released oneAPI 2022 toolkits. Newly enhanced toolkits expand cross-architecture features to provide developers greater utility and architectural choice to accelerate computing. "I am impressed by the breadth of more than 900 technical improvements that the oneAPI software engineering team has done to accelerate development time and performance for critical application workloads across Intel's client and server CPUs and GPUs. The rich set of oneAPI technologies conforms to key industry standards, with deep technical innovations that enable applications developers to obtain the best possible run-time performance from the cloud to the edge. Multi-language support and cross-architecture performance acceleration are ready today in our oneAPI 2022 release to further enable programmer productivity on Intel platforms," said Greg Lavender, Intel chief technology officer, senior vice president and general manager of the Software and Advanced Technology Group.<br />
<br />
New capabilities include the world's first unified compiler implementing C++, SYCL and Fortran, data parallel Python for CPUs and GPUs, advanced accelerator performance modeling and tuning, and performance acceleration for AI and ray tracing visualization workloads. The <a rel="nofollow" href="https://www.oneapi.io/" target="_blank">oneAPI cross-architecture programming model</a> provides developers with tools that aim to improve the productivity and velocity of code development when building cross-architecture applications.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/iRsXqunPGMffGq8H.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/iRsXqunPGMffGq8H_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290147/intel-releases-oneapi-2022-toolkits-to-developers">Read full story</a></div>
(PR) Akasa Unveils Gecko Pro M.2 SSD Heatsink
Akasa, a leading provider of SSD accessories has just released a new heatsink for M.2 drives, called the Gecko Pro. Working from their previous SSD heatsink, the new Smart Fin design improves airflow over the fins and allows optimum heat dissipation. The Gecko Pro is compatible with 2280 sized SATA and NVMe M.2 drives.<br />
<br />
M.2 drives are increasingly becoming more important in PC builds, being a popular option for both laptops, tablets, and tower PCs. As the technology improves over time, they have become an essential in fast, reliable data storage. One problem that occurs when continuously reading and writing data to the drive is overheating; data transfer speeds are reduced at high temperatures.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/aKwhkU5erxBpeiKl.jpg" target="_blank" data-width="590" data-height="395" ><img src="https://tpucdn.com/img/aKwhkU5erxBpeiKl_thm.jpg" width="194" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/e3HSf0Etf7rAHjzv.jpg" target="_blank" data-width="841" data-height="370" ><img src="https://tpucdn.com/img/e3HSf0Etf7rAHjzv_thm.jpg" width="295" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290146/akasa-unveils-gecko-pro-m-2-ssd-heatsink">Read full story</a></div>
Access to Xbox Game Pass Worth $6,300 in Games for 2021
Microsoft is well on its way towards becoming the Netflix of videogames, considering the running success of its Game Pass subscription service. The idea is simple: players pay a monthly fee (starting at $9,99 for PC or Xbox-specific subscriptions) and they receive access to a curated portfolio of game experiences. The platform is bolstered by the fact that Microsoft's first-party titles are made available day-one for Games Pass subscribers. In 2021 alone, this approach by Microsoft gave gamers access to games like Halo Infinite, Age of Empires 4, Forza Horizon 5, and the incredibly quirky Psychonauts 2. But is it worth it to have a Games Pass subscription, thus waiving ownership of those actual games?<br />
<br />
Your mileage will certainly vary; but in pure dollar terms, it's difficult to argue against the idea. According to The Loadout, Games Pass subscribers were given access to around $6,300 worth of games throughout 2021 - that's how much a consumer would have to pay, day one, to own all of the games that Microsoft included (and sometimes rotated out) of its Game Pass library. A yearly Game Pass Ultimate subscription (for PC and Xbox games) would give you access to the same cadre of titles for a much more modest $15 a month - $180 in total. In March alone, Games Pass subscribers saw the floodgates open to around $960 worth of games (and potentially thousands of hours of gameplay) with the addition of Bethesda Softwork's titles to the service, following the <a href="https://www.techpowerup.com/272391/microsoft-announces-acquisition-of-bethesda-parent-company-zenimax-media" target="_blank">$7,5 billion Microsoft acquisition</a> of parent company Zenimax Media.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8KAjFvCPTKZ3JOoi.jpg" target="_blank" data-width="1918" data-height="844" ><img src="https://tpucdn.com/img/8KAjFvCPTKZ3JOoi_thm.jpg" width="295" height="130" alt="" /></a></div>
AMD Explores Adding Ryzen 5000-series Support to 300-series Chipsets
One of the most debated questions surrounding AMD's AM4 platform has been the lack of support for AMD's Ryzen 5000-series CPUs on the company's 300-series chipsets. Now, in an interview with Tom's Hardware, AMD's Corporate VP and GM of the Client Channel business, David McAfee, has thrown some cautious words into the hellish debate on platform fragmentation (some even say artificial segmentation). "It's definitely something we're working through," David said. "And it's not lost on us at all that this would be a good thing to do for the community, and we're trying to figure out how to make it happen." It's not a promise, but it seems that AMD is indeed contemplating solutions that would enable first-generation AM4 chipsets to support AMD's latest Ryzen 5000 series CPUs.<br />
<br />
The problem has mostly to do with storage space: there are only so much available bits to be used in AM4 motherboards' 16 MB SPI ROM, the read-only memory bank that stores BIOS configurations and the necessary instructions for processor support. As AM4 is one of the longest-lived consumer platforms ever, the number of CPUs has ballooned, which has led to difficult decisions as to which CPUs to support. However, some more creative board partners have resorted to interesting techniques that allowed them to free up space in the SPI ROM that could be used to add support for otherwise incompatible CPUs, such as simplifying the BIOS GUI and falling back on more traditional text-based UIs. That and other practices resulted in a number of vendors adding support for AMD's Ryzen 5000 chips on the most <a href="https://www.techpowerup.com/288911/asus-and-gigabyte-enable-amd-ryzen-5000-series-processor-support-on-a320-chipsets" target="_blank">entry-level A320</a> motherboards, which left consumers that had opted for the more technically accomplished X370 motherboards high and dry - barring a few lucky, <a href="https://www.techpowerup.com/275786/ryzen-5000-series-processor-support-comes-to-asrock-x370-motherboards-in-leaked-bios-update" target="_blank">ASRock-toting exceptions</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/RW1DPlo6KfWE9WMg.jpg" target="_blank" data-width="1200" data-height="675" ><img src="https://tpucdn.com/img/RW1DPlo6KfWE9WMg_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290674/amd-explores-adding-ryzen-5000-series-support-to-300-series-chipsets">Read full story</a></div>
MSI Teases RadiX AXE6600 Router at CES
Although not much is known about MSI's upcoming router, the company was teasing the RadiX AXE6600 during its virtual CES event. It's said to be a WiFi 6E router based on an unspecified 1.8 GHz Qualcomm SoC. The AXE6600 in the model name should break down to 600 Mbps in the 2.4 GHz band, 1200 Mbps in the 5 GHz band and 4800 MHz in the 6 GHz band, if routers with the same speed rating are anything to go by. In fact, the specs seem to be similar to the Linksys Hydra Pro 6E, as it seems to be based on the same or at least a similar SoC from Qualcomm. <br />
<br />
The one thing that is obvious, especially from MSI's teaser on Twitter, is that the router will have plenty of RGB bling built into the antennas. The MSI dragon logo on the router, is a button according to Tom's hardware, that is said to cycle through various "AI" QoS presets. How useful or practical this will be in reality, is up for debate. The router is still a good few months out, with an expected launch sometime in the second half of this year. And if you're wondering, yes, MSI have made routers before, but it was quite some time ago and they weren't particularly popular.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ihcjmeN2MNmgBTcG.jpg" target="_blank" data-width="1280" data-height="949" ><img src="https://tpucdn.com/img/ihcjmeN2MNmgBTcG_thm.jpg" width="175" height="130" alt="" /></a></div>
(PR) Tobii Horizon will be available in the new Lenovo Legion 5 Pro Series gaming laptops
Tobii, the global leader in eye tracking and pioneer of attention computing, is pleased to announce that Tobii Horizon will be available in the new Lenovo Legion 5 Pro series gaming laptops starting in the first quarter of 2022. Tobii Horizon detects and tracks natural head movements via the built-in camera, extending the player's instincts and senses in several games. It allows the user to take control of the in-game camera by using head movements and experience a seamless expansion of their field of view. <br />
<br />
"Tobii is pushing boundaries and relentlessly innovating to take game immersion to new levels by creating innovative game interfaces," said Ulrica Wikström, VP of PC Segment at Tobii. "With this collaboration, we will enable millions more gamers to take their first step into next-level gaming."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/TNY12NcN9uySacpQ.jpg" target="_blank" data-width="847" data-height="916" ><img src="https://tpucdn.com/img/TNY12NcN9uySacpQ_thm.jpg" width="120" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290669/tobii-horizon-will-be-available-in-the-new-lenovo-legion-5-pro-series-gaming-laptops">Read full story</a></div>
(PR) ViewSonic Releases Line-up of ELITE Monitors with Mini-LED Backlight Technology
ViewSonic Corp., a leading global provider of visual solutions announces several ViewSonic ELITE professional gaming monitors with leading-edge Mini-LED technology. Ranging from 27" to 34", the ELITE XG272G-2K, ELITE XG321UG, and ELITE XG341C-2K transform gaming with Mini-LED technology for optimized contrasts and greater details even in dimly lit environments.<br />
<br />
"In gaming, image quality is king. As gamers demand more advanced in-game details and extreme clarity, our Mini-LED ELITE monitors surpass current gaming landscapes by delivering enhanced gaming features and innovative technology. We hope to push the boundaries of gaming displays to the next level." said Oscar Lin, General Manager of the Monitor Business at ViewSonic.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/AN6j7MglQUgV0KSz.jpg" target="_blank" data-width="934" data-height="636" ><img src="https://tpucdn.com/img/AN6j7MglQUgV0KSz_thm.jpg" width="191" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290668/viewsonic-releases-line-up-of-elite-monitors-with-mini-led-backlight-technology">Read full story</a></div>
(PR) j5create Teams Up with Intel to Develop the Next Generation USB4 Peripherals
j5create, a world leader in high tech computer accessories, and Intel, the world's largest manufacturer of semiconductor chips, are working together to develop one of the worlds' first USB4 multi-port adapters. USB4 is the latest USB specification offering several improvements over legacy USB-C adapters including higher transfer speeds, more efficient bandwidth allocation between data and display protocols, as well as backward compatibility with older USB and Thunderbolt specifications.<br />
<br />
"We're thrilled to work with Intel to bring the latest USB peripherals to market." said Steven Lyu, Chief Operating Officer at j5create. "We are always innovating to deliver high-performance solutions users have been anticipating through a variety of products, technologies, and design collaborations." The USB4 multi-port adapters will be one of the first to incorporate the latest Intel USB4 controller, offering Thunderbolt compatibility and USB legacy support. Set to release in Q1 2022, these USB4 multi-port adapters provide efficient and dynamic bandwidth allocation up to 20 Gbps and dual 4K video support in addition to high-speed peripheral ports.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/GjrgXsxqZMZcp5B7.jpg" target="_blank" data-width="596" data-height="414" ><img src="https://tpucdn.com/img/GjrgXsxqZMZcp5B7_thm.jpg" width="187" height="130" alt="" /></a></div>
(PR) Streamplify Enters the Market with Affordable Live Streaming Gear
As the internet becomes our primary place to chill, chat and play, Streamplify, a new German-based designer and manufacturer of affordable live streaming products, is making its global debut in stores and online retailers around Europe and the US. Streamplify wants to share the joy of live streaming by making it easier to share your passion in high quality with the world. <br />
<br />
"Many established streamers have told us that, when they first started, they wished there had been a brand providing reliable, budget-friendly equipment to help them get off the ground. That's the gap we are trying to fill now with our product line," - Nils Klakow, Business Development Manager at Streamplify. The people behind the brand all hail from the gaming and PC hardware industries, and have been in the business of developing products for gamers - and being devoted gamers themselves - for upwards of 20 years. There is over two years of development, testing, and revision behind the line of products being presented today, with input from streamers, musicians, content creators, technicians, and video and photography professionals.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/IWRSyiHqPF07jDkY.jpg" target="_blank" data-width="800" data-height="480" ><img src="https://tpucdn.com/img/IWRSyiHqPF07jDkY_thm.jpg" width="217" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LdqYSOFu9Zy1VBJt.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/LdqYSOFu9Zy1VBJt_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290666/streamplify-enters-the-market-with-affordable-live-streaming-gear">Read full story</a></div>
E3 2022 to Occur in Digital-Only Space Once Again as Omicron Surges
The Entertainment Software Association (ESA) has announced that the 2022 edition of the famous Electronics Entertainment Expo (E3) show will once again occur in a digital venue. The decision has been justified due to the current Omicron infection waves sweeping across most of the world, and while recent studies place Omicron as a less severe variant, its extremely high infection rates should still give decision makers pause.<br />
<br />
Interestingly, the ESA still hasn't confirmed the date in which this digital E3 is to take place - something the association always did at the close of each edition. Reports state that the decision to hold a digital-only event for 2022 might have been taken even before the current Omicron surge, and perhaps as early as last year. Should E3 2022 occur in an online format, this will be the second time this happens since the event's first edition back in 1995. In all these years, E3 has only ever been fully canceled in 2020, the year that COVID-19 was declared a pandemic.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/EuMdRf6YDA2uNeGk.jpg" target="_blank" data-width="1024" data-height="512" ><img src="https://tpucdn.com/img/EuMdRf6YDA2uNeGk_thm.jpg" width="260" height="130" alt="" /></a></div>
AMD Radeon RX 6500 XT Limited To PCIe 4.0 x4 Interface
The recently announced AMD Radeon RX 6500 XT only features a PCIe 4.0 x4 interface according to specifications and images of the card published on the ASRock site. This is equivalent to a PCIe 3.0 x8 link or a PCIe 2.0 x16 connection and is a step down from the Radeon 6600 XT which features a PCIe 4.0 x8 interface and the Radeon 6700 XT with a PCIe 4.0 x16 interface. This fact is only specified by ASRock with AMD, Gigabyte, ASUS, and MSI not mentioning the PCIe interface on their respective pages. The RX 6500 XT also lacks some of the video processing capabilities of other RX 6000 series cards including the exclusion of H264/HEVC encoding and AV1 decoding.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/IDnwlYK2Tu4Ezfcu.jpg" target="_blank" data-width="1280" data-height="960" ><img src="https://tpucdn.com/img/IDnwlYK2Tu4Ezfcu_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/rY7JVzAf9SNh9BsI.jpg" target="_blank" data-width="1747" data-height="898" ><img src="https://tpucdn.com/img/rY7JVzAf9SNh9BsI_thm.jpg" width="253" height="130" alt="" /></a></div>
(PR) Thermaltake Announces ARGENT K6 RGB Gaming Keyboard and Damysus RGB Gaming Mice
Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals and enthusiast memory solutions, aims at providing better gaming experiences to users by offering more advanced gaming peripherals. This time, the latest gaming peripherals ARGENT K6 RGB Low-Profile Mechanical Gaming Keyboard, Damysus Wireless RGB Ergonomic Gaming Mouse, and Damysus RGB Ergonomic Gaming Mouse were presented at the 2022 Thermaltake EXPO January Virtual Exhibition.<br />
<br />
To give a more comfortable typing experience, Thermaltake introduces the first Low-Profile Mechanical Gaming Keyboard of the product line. The ARGENT K6 RGB Low-Profile Mechanical Gaming Keyboard features an aluminium top plate with a floating keycap design, incorporating Cherry MX Low-Profile RGB Red and Silver mechanical switches rated at 50 million keystrokes, offering the most durable, precise, and responsive tactile feedback. Moreover, the ARGENT K6 Keyboard comes with a wrist rest made with synthetic leather to give comfort support to your wrists.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/D3jJ0yGbtpibNWfL.jpg" target="_blank" data-width="1370" data-height="1000" ><img src="https://tpucdn.com/img/D3jJ0yGbtpibNWfL_thm.jpg" width="178" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/1PfyTsbsgXkZLK7f.jpg" target="_blank" data-width="1560" data-height="1000" ><img src="https://tpucdn.com/img/1PfyTsbsgXkZLK7f_thm.jpg" width="203" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gSvFaaNqaefdOsN1.jpg" target="_blank" data-width="1563" data-height="1000" ><img src="https://tpucdn.com/img/gSvFaaNqaefdOsN1_thm.jpg" width="203" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3wpwbGYAoGco1Y3Q.jpg" target="_blank" data-width="1659" data-height="1000" ><img src="https://tpucdn.com/img/3wpwbGYAoGco1Y3Q_thm.jpg" width="216" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/e01o8tuMLtYvWPdU.jpg" target="_blank" data-width="783" data-height="1000" ><img src="https://tpucdn.com/img/e01o8tuMLtYvWPdU_thm.jpg" width="102" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290657/thermaltake-announces-argent-k6-rgb-gaming-keyboard-and-damysus-rgb-gaming-mice">Read full story</a></div>
(PR) Mad Catz Announces New Gaming Products
Mad Catz, is announcing an extensive array of gaming hardware due for release in Q2 2022. Products to be released include the S.T.R.I.K.E. 6 gaming keyboard, the P.I.L.O.T. gaming headset series, the S.U.R.F. RGB mouse pad, the G.Y.R.A. gaming chair, the C.A.T. 9 game controller, and a new fight sick—the T.E. 3.<br />
<br />
The S.T.R.I.K.E. 6 mechanical keyboard combines the space-saving convenience of the compact 60% form factor with extreme customization and functionality. Built for gamers, Mad Catz's mechanical switches provide for a precise linear actuation, last up to 80 million keystrokes, and can be hot-swapped to match your personal preference. The S.T.R.I.K.E. 6 also has powerful RGB illumination with 26 RGB effects including sound effect synchronization.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/bnFFtH7xzW8LolCa.jpg" target="_blank"><img src="https://tpucdn.com/img/bnFFtH7xzW8LolCa_thm.jpg" alt="" /></a> <a href="https://www.techpowerup.com/img/8QaFPxIcZVvnGVB8.jpg" target="_blank"><img src="https://tpucdn.com/img/8QaFPxIcZVvnGVB8_thm.jpg" alt="" /></a> <a href="https://www.techpowerup.com/img/AZZqpuYfsW8jBI55.jpg" target="_blank"><img src="https://tpucdn.com/img/AZZqpuYfsW8jBI55_thm.jpg" alt="" /></a> <a href="https://www.techpowerup.com/img/Zq8RxRG9rgfDxRyS.jpg" target="_blank" data-width="1360" data-height="960" ><img src="https://tpucdn.com/img/Zq8RxRG9rgfDxRyS_thm.jpg" width="184" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bdI0K4A3chhGlnD1.jpg" target="_blank" data-width="960" data-height="960" ><img src="https://tpucdn.com/img/bdI0K4A3chhGlnD1_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290656/mad-catz-announces-new-gaming-products">Read full story</a></div>
TechPowerUp KIOXIA Exceria SSD Worldwide Giveaway Ending Soon, Hurry!
TechPowerUp and KIOXIA partner to bring our readers from across the world a golden opportunity to win one of three KIOXIA Exceria SSDs across a selection of form-factors. As the technology-pioneer in NAND flash, KIOXIA brings experience and quality to the table with their Exceria line of client-segment SSDs and flash-storage products. Up for grabs are a 2 TB Exceria Plus G2 NVMe SSD, a 1 TB Exceria NVMe SSD, and a 960 GB Exceria SATA 2.5-inch SSD. Entries close on January 9th, so hurry, all you need to do is fill in a short form to help us get back to you if you've won!<br />
<br />
For more information, and to participate, <a href="https://www.techpowerup.com/contests/kioxia-hardware-giveaway-dec-21" target="_blank">visit this page</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jDc0NilUMpGTnq2q.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/jDc0NilUMpGTnq2q_thm.jpg" width="130" height="130" alt="" /></a></div>
Curious-looking Core i5-12490F Surfaces in China with Additional L3 Cache
Intel released the substantive portion of its 12th Generation Core, Pentium, and Celeron desktop processors to the retail market, based on the latest "Alder Lake" architecture. The part that's making the most waves is the Core i5-12400, a 6-core/12-thread part that only features "Golden Cove" P-cores (no E-cores or the software-optimization issues they bring). The i5-12400/F, i5-12500, and i5-12600, are based on the "H0" die of "Alder Lake-S," which physically only features six "Golden Cove" P-cores, no "Gracemont" E-core clusters, and only has 18 MB of L3 cache. The larger "C0" die is used across the i5-12600K, Core i7 and Core i9 chips, physically has 8 "Golden Cove" P-cores, 8 "Gracemont" E-cores across two E-core clusters, and 30 MB of L3 cache. It's important to lay out this piece of information to understand what Intel did with the new Core i5-12490F processor that's spotted in markets across Asia.<br />
<br />
Apparently Intel is sitting on a pile of "C0" dies, and decided to create the i5-12490F. This chip has 6 "Golden Cove" P-cores, no E-cores, but 20 MB of L3 cache; and is based on a heavily cut-down "C0" silicon. As an "F" SKU, it also disables the iGPU on the silicon. The clocks set are 3.00 GHz nominal, and 4.60 GHz boost, compared to 2.50 GHz nominal, and 4.40 GHz boost of the i5-12400/F, and identical clock speeds to the i5-12500. It's quite puzzling how the "H0" based i5-12500 is differentiated from this chip, given its lower 18 MB L3 cache amount. The base power value is set at 65 W, with maximum turbo power at 117 W. The i5-12490F can hence be simulated using an i5-12600K.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/8OmMaZHhIzGM0Td5.jpg" target="_blank" data-width="1079" data-height="810" ><img src="https://tpucdn.com/img/8OmMaZHhIzGM0Td5_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ZA1KbCBUWXAbYjut.jpg" target="_blank" data-width="1079" data-height="810" ><img src="https://tpucdn.com/img/ZA1KbCBUWXAbYjut_thm.jpg" width="173" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DiyFnqzafWYU9bWo.jpg" target="_blank" data-width="750" data-height="1000" ><img src="https://tpucdn.com/img/DiyFnqzafWYU9bWo_thm.jpg" width="98" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/saNXhocvdydwQNqM.jpg" target="_blank" data-width="1333" data-height="1000" ><img src="https://tpucdn.com/img/saNXhocvdydwQNqM_thm.jpg" width="173" height="130" alt="" /></a></div>
GoDeal24 2022 New Year Sale: Incredible Pricing on Genuine Software
GoDeal24 welcomes New Year 2022 with incredible new prices on genuine software. Get the very latest Office 2021 Professional Plus at just $30.98, and a 5-PC pack for just $74.03 (that's $14.80 per PC)! We have also slashed prices on Office 2019 and Office 2016. Pair the latest Office with the most powerful new operating system, Windows 11 Pro, at just $15.36. Better yet, combine the two at just $45.65. Check out other great deals on your preferred editions of Windows and Office. <br />
<br />
<a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2021-pro-plus-1pc.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus at $30.98</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-office-2021-pro-plus-5pcs.html?g24=sgo23" target="_blank">Buy Office 2021 Professional Plus 5-PC at $74.03</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2019-professional-plus.html?g24=sgo23" target="_blank">Buy Office 2019 Professional Plus at $25.85</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2016-pro-plus.html?g24=sgo23" target="_blank">Buy Office 2016 Professional Plus at $18.68</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-10-professional-32-64-bit.html?g24=sgo23" target="_blank">Buy Windows 10 Pro at $7.50</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-professional-2-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Pro 2-PC at $11.40</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-windows-11-pro-cd-key.html?g24=sgo23" target="_blank">Buy Windows 11 Pro at $15.36</a> | <a rel="nofollow" href="https://www.godeal24.com/ms-windows-10-home-cd-key-32-64-bit.html?g24=sgo23" target="_blank">Buy Windows 10 Home at $8.12</a> <br />
<br />
Please use the coupon code <b>SGO62</b> on the following items at check-out, to avail the prices you see here.<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-10-pro-office-2021-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $37.65</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2021-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2021 Professional Plus at $45.65</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-pro-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $31.74</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-home-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Home + Office 2019 Professional at $35.52</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-10-home-office-2016-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 10 Pro + Office 2016 Professional Plus at $25.90</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2019-pro-bundle.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2019 Professional Plus at $40.11</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-pro-office-2016-pro-bundle-key.html?g24=sgo23" target="_blank">Buy Windows 11 Pro + Office 2016 Professional Plus at $34.39</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-project-professional-2019-1-user.html?g24=sgo23" target="_blank">Buy Project Professional 2019 at $22.15</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-visio-professional-2019-1-user.html?g24=sgo23" target="_blank">Buy Visio Professional 2019 at $19.37</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-project-professional-2021.html?g24=sgo23" target="_blank">Buy Project Professional 2021 at $25.70</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-visio-professional-2021-key.html?g24=sgo23" target="_blank">Buy Visio Professional 2021 at $22.97</a> | <a rel="nofollow" href="https://www.godeal24.com/microsoft-office-2019-home-and-student-1-user.html?g24=sgo23" target="_blank">Buy Office 2019 Home and Student at $31.15</a> | <a rel="nofollow" href="https://www.godeal24.com/office-2021-home-and-business-for-mac.html?g24=sgo23" target="_blank">Buy Office 2021 Home and Business for Mac at $68.66</a> | <a rel="nofollow" href="https://www.godeal24.com/office-2019-home-and-business-for-pc-1-user.html?g24=sgo23" target="_blank">Buy Office 2019 Home and Business at $47.76</a><br />
<br />
Please use the coupon code <b>SGO50</b> on the following items.<br />
<a rel="nofollow" href="https://www.godeal24.com/windows-10-home-cd-key-32-64-bit-2-pc.html?g24=sgo23" target="_blank">Buy Windows 10 Home at $13.57</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-11-professional-cd-key-5-pc.html?g24=sgo23" target="_blank">Buy Windows 11 Pro 5-PC at $41.91</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-server-2022-standard.html?g24=sgo23" target="_blank">Buy Windows Server 2022 Standard at $26.13</a> | <a rel="nofollow" href="https://www.godeal24.com/windows-server-2022-datacenter.html?g24=sgo23" target="_blank">Buy Windows Server 2022 Datacenter at $30.75</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/6rjfDAXhDJR0Lbwf.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/6rjfDAXhDJR0Lbwf_thm.jpg" width="231" height="130" alt="" /></a></div>
AMD Socket AM5 a "Long-lived Platform": CEO
AMD is designing its upcoming Socket AM5 platform to be a "long-lived platform," not unlike AM4. CEO Dr Lisa Su, responding to a question on the longevity of AM5, by Paul Alcorn from Tom's Hardware, said that she's very happy with AM4 being the company's long-lived desktop socket; and while she doesn't have an exact number of years to share, one could expect AM5 to be a "long-lived platform" of a similar kind.<br />
<br />
AMD Socket AM4 was debuted alongside the company's very first Ryzen processors, in March 2017. It has remained AMD's mainstream desktop socket for close to five years; and AMD continues to launch new products for the socket. Even in 2022, the company is expected to give the socket its swansong, with the Ryzen 5000X3D processors. AM4 was designed keeping in mind dual-channel DDR4 and up to 28 lanes of PCIe Gen 3 (later Gen 4) in mind. The change to Socket AM5 is driven by next-generation I/O, namely DDR5 memory (four 40-bit channels), and PCIe Gen 5.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/rOEDQul3B7STy8Sz.jpg" target="_blank" data-width="1778" data-height="1000" ><img src="https://tpucdn.com/img/rOEDQul3B7STy8Sz_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290648/amd-socket-am5-a-long-lived-platform-ceo">Read full story</a></div>
Corsair Readies AMD "Rembrandt" Ryzen 6000H-powered Xenomorph Gaming Device
Corsair is readying a gaming device it calls "Xenomorph." At this point we don't know its exact form-factor, but given its display resolution of 2560 x 1600 pixels, and the fact that desktop monitors with it are hard to come by; this is very likely a 16-inch gaming notebook with a 16:10 display with that resolution. A UserBenchmark submission sheds light on the hardware specs of the device, which includes an AMD Ryzen 6000 series "Rembrandt" mobile processor. Built on the 6 nm node, "Rembrandt" combines an 8-core/16-thread "Zen 3+" CPU with an iGPU based on the latest RDNA2 graphics architecture. The iGPU features 768 stream processors, full DirectX 12 Ultimate support, including ray tracing; and the ability to share rendering workloads with an RDNA2-based discrete GPU, such as the Radeon RX 6800M. <br />
<br />
The name "Xenomorph" sparks a lot of speculation, mainly around the form-factor. Could this be a gaming notebook with a killer hardware feature such as an integrated touchscreen? Something with a foldable screen? A convertible that turns into a tablet? Another possibility is a device that looks otherworldly enough to be a tribute to HR Giger, the artist who created the Xenomorph alien. We don't know if Xenomorph is an internal codename, or an actual product name, as that might require some legal understanding with 20th Century Fox.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/jT5QIg99Ghln3J6p.jpg" target="_blank" data-width="1400" data-height="577" ><img src="https://tpucdn.com/img/jT5QIg99Ghln3J6p_thm.jpg" width="315" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LxcDB5vXWh7nUM6O.jpg" target="_blank" data-width="700" data-height="482" ><img src="https://tpucdn.com/img/LxcDB5vXWh7nUM6O_thm.jpg" width="189" height="130" alt="" /></a></div>
(PR) GIGABYTE AORUS Delivers DDR5 6000 MHz 32 GB Memory Kit With RGB Lighting
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of motherboards, graphics cards, and hardware solutions today announced AORUS RGB DDR5 6000 MHz 32 GB Memory Kit, which uplift frequency to 6000 MHz with RGB lighting for performance boost and striking accents. Enhanced by DDR5 XMP Booster and XMP 3.0 User Profile of GIGABYTE Z690 motherboards, and copper-aluminium heat spreaders with nano-carbon coating thermal design, the new memory kit promises the next-level performance with stability while dissipating heat efficiently under high-speed operation.<br />
<br />
AORUS RGB DDR5 6000 MHz 32 GB Memory Kit features high clock speed and low power consumption by two 16 GB DDR5 XMP 6000 MHz dual-channel designs with 40-40-40-76 timings, which fit the support of DDR5 memory on Intel Z690 platform. Along with GIGABYTE Z690 AORUS motherboards, AORUS RGB DDR5 6000 MHz 32 GB memory kit can enable "DDR5 XMP Booster" function which detect the brand of memory IC in the BIOS setting to allow users to choose promptly from multiple built-in memory overclocking profiles, boosting the native DDR5 or XMP DDR5 memory speed. Furthermore, "XMP 3.0 User Profile" enables users to create and store XMP profiles of their own to unleash the extreme performance of memories.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DgO0WmXEUJQNm2NG.jpg" target="_blank" data-width="1346" data-height="586" ><img src="https://tpucdn.com/img/DgO0WmXEUJQNm2NG_thm.jpg" width="299" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290643/gigabyte-aorus-delivers-ddr5-6000-mhz-32-gb-memory-kit-with-rgb-lighting">Read full story</a></div>
(PR) Thermaltake Presents New Custom Liquid Cooling Products
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, is elated to present new custom cooling products, including a new cooling kit, a liquid cooling system dashboard for monitoring, and three new water blocks. Thermaltake strives to provide a better and more user-friendly cooling experience to all PC enthusiasts and DIY cooling lovers by providing a wide range of cooling components. This time, Pacific TF3 Liquid Cooling Dashboard, Pacific W8 CPU Water Block Full Copper, Pacific W9 CPU Water Block Acrylic, Pacific MX2 CPU Water Block, and Pacific CLM360 Ultra Liquid Cooling Kit were presented at the 2022 Thermaltake Expo January Virtual Exhibition.<br />
<br />
The Pacific TF3, a 3-in-1 system monitoring dashboard, allows users to monitor the system's liquid pressure, liquid temperature and chassis ambient temperature simultaneously. Inspired by mechanical watches, the pointer-design display shows the results vividly at a glance, and can be synchronized with the TTG RGB PLUS 2.0 Software to show real-time status and to control its digital RGB backlight. The detection range of fluid temperatures is from 0°C to 99°C (32°F to 210°F), and there is also a warning alert for abnormal temperature and high-pressure changes.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/rmnVcTc7ooQbpHnS.jpg" target="_blank" data-width="1090" data-height="1000" ><img src="https://tpucdn.com/img/rmnVcTc7ooQbpHnS_thm.jpg" width="142" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/P2b6HQyhA8tjf1oj.jpg" target="_blank" data-width="1047" data-height="1000" ><img src="https://tpucdn.com/img/P2b6HQyhA8tjf1oj_thm.jpg" width="136" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DM0nrj9C2G5c6S3x.jpg" target="_blank" data-width="1171" data-height="1000" ><img src="https://tpucdn.com/img/DM0nrj9C2G5c6S3x_thm.jpg" width="152" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/In4TJQmSpM4DxZPQ.jpg" target="_blank" data-width="1055" data-height="1000" ><img src="https://tpucdn.com/img/In4TJQmSpM4DxZPQ_thm.jpg" width="137" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/YTMmDdokaIuLVDEW.jpg" target="_blank" data-width="1536" data-height="952" ><img src="https://tpucdn.com/img/YTMmDdokaIuLVDEW_thm.jpg" width="210" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290642/thermaltake-presents-new-custom-liquid-cooling-products">Read full story</a></div>
(PR) Lenovo Legion Launches Four New Gaming Notebooks at CES
From its inception, Lenovo Legion wanted to make the modern gaming experience immersive, as well as more inclusive. At CES 2022, Lenovo Legion once again delivers on its pursuit of unyielding play and productivity to gamers of every generation and content creators, who can now all universally enjoy premium entertainment and play from home battle stations, dorms, esports arenas - or practically anywhere, and look good doing it too.<br />
<br />
Lenovo's first batch of 2022 battle-ready PCs, monitors, accessories and gamer-focused software and services unveiled today, which include the powerful 16-inch Lenovo Legion 5i Pro and Lenovo Legion 5 Pro laptops and the polished 15-inch Lenovo Legion 5i and Lenovo Legion 5 laptops. The new gaming laptops come available with Windows 11 gaming performance, next-gen AMD Ryzen processors, or latest 12th Gen Intel Core processors and up to latest fully powered NVIDIA GeForce RTX Laptop GPUs. Inspired by gamer research, these new devices celebrate 'magical minimalism' design and denote a leap towards a contemporary aesthetic with purposeful detailing like an uncluttered wordmark, expressive venting, and immersive lighting. A top-placed camera bump with eShutter kill switch and rear port protection convey a sleek look of power and performance that helps to create a more inclusive experience focused on player enjoyment and winning, not labels. Paired with exclusives beloved by Legion fans such as the advanced thermals of next-level Legion Coldfront 4.0, the hair-trigger speeds and improved ergonomics of Legion TrueStrike keyboard, and optimized tuning via Lenovo Vantage for gaming.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/NMk7wYPmvvAyffxD.jpg" target="_blank" data-width="1172" data-height="1280" ><img src="https://tpucdn.com/img/NMk7wYPmvvAyffxD_thm.jpg" width="119" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/IArfmN0plTIYoY5h.jpg" target="_blank" data-width="1280" data-height="1157" ><img src="https://tpucdn.com/img/IArfmN0plTIYoY5h_thm.jpg" width="144" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ifQ21kHUXwxJOKPY.jpg" target="_blank" data-width="1280" data-height="1080" ><img src="https://tpucdn.com/img/ifQ21kHUXwxJOKPY_thm.jpg" width="154" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Y3txT4oLNxvwuc32.jpg" target="_blank" data-width="1108" data-height="1276" ><img src="https://tpucdn.com/img/Y3txT4oLNxvwuc32_thm.jpg" width="113" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/tkLUEWpbd4Os7qVn.jpg" target="_blank" data-width="1110" data-height="1263" ><img src="https://tpucdn.com/img/tkLUEWpbd4Os7qVn_thm.jpg" width="114" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290639/lenovo-legion-launches-four-new-gaming-notebooks-at-ces">Read full story</a></div>
ASRock Announces Two Z690 Aqua Motherboards, One with Extra OC Creds
At the launch of the Z690 chipset, ASRock didn't reveal its flagship Aqua model, but now the company has finally announced not just one, but two Z690 Aqua models, one "regular" SKU and one OC SKU. The main difference between the two is that the OC SKU only has two DIMM slots, since as we know, DDR5 is extra finicky when it comes to running at high clock speeds and two DIMM boards allow for higher DRAM clock speeds, This also means that all the major board makers have now launched a two DIMM product geared towards overclockers.<br />
<br />
The two boards are mostly identical in terms of features otherwise, but there are some minor differences that we'll point out later. As expected, both boards feature a large, nicely integrated liquid cooling plate for the CPU and the 20 phase 105 A SPS VRM setup. ASRock has gone for a 12 layer PCB, not something you see in a lot of consumer motherboards and it's unclear if it'll bring any real benefits, but as this is a premium motherboard, it's a nice touch. The heatsink of the top-most M.2 drive is home to a small OLED display, but ASRock hasn't listed the size on its website.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cbiDI2m6QLhxh3rt.jpg" target="_blank" data-width="844" data-height="950" ><img src="https://tpucdn.com/img/cbiDI2m6QLhxh3rt_thm.jpg" width="115" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Qvn2GmUUxaJWkUbt.jpg" target="_blank" data-width="844" data-height="950" ><img src="https://tpucdn.com/img/Qvn2GmUUxaJWkUbt_thm.jpg" width="115" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/4WCozGzfH1Ib4K9b.jpg" target="_blank" data-width="1056" data-height="950" ><img src="https://tpucdn.com/img/4WCozGzfH1Ib4K9b_thm.jpg" width="145" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Inqk2aZeoelrge6O.jpg" target="_blank" data-width="1056" data-height="950" ><img src="https://tpucdn.com/img/Inqk2aZeoelrge6O_thm.jpg" width="145" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XA5kk2hTLQJMSzTZ.jpg" target="_blank" data-width="844" data-height="950" ><img src="https://tpucdn.com/img/XA5kk2hTLQJMSzTZ_thm.jpg" width="115" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290636/asrock-announces-two-z690-aqua-motherboards-one-with-extra-oc-creds">Read full story</a></div>
(PR) ASRock Launches 8-Liter DeskMeet Desktops Powered by Intel B660 and AMD X300
The leading global motherboard, graphics card, and small form factor PC manufacturer, ASRock, proudly announces its 8-liter desktop barebone DeskMeet B660 and X300 at CES 2022. DeskMeet B660 supports the latest 12th Generation Intel Core processors, while DeskMeet X300 supports a full range of AMD AM4 desktop processors.<br />
<br />
The DeskMeet is a revolutionary design of the Mini-ITX platform. ASRock not only optimizes its motherboard to minimize internal cables, but also optimizes its power supply for better cable management and airflow. The most eye-catching thing is the chassis design of DeskMeet. Users can easily build a small form factor PC in just a few minutes. DeskMeet's incredible scalability, offering plenty of space to extend or upgrade your build.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UcSwUSSEirbQwJTm.jpg" target="_blank" data-width="1782" data-height="742" ><img src="https://tpucdn.com/img/UcSwUSSEirbQwJTm_thm.jpg" width="312" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/q2OSgcS9gy6rk0I4.jpg" target="_blank" data-width="1346" data-height="742" ><img src="https://tpucdn.com/img/q2OSgcS9gy6rk0I4_thm.jpg" width="236" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/DI695lxtlmX9bZu2.jpg" target="_blank" data-width="1595" data-height="742" ><img src="https://tpucdn.com/img/DI695lxtlmX9bZu2_thm.jpg" width="279" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/290635/asrock-launches-8-liter-deskmeet-desktops-powered-by-intel-b660-and-amd-x300">Read full story</a></div>
TechPowerUp and 1More Present Comfobuds 2 True-wireless Headphones Giv
The 1More Comfobuds 2 are a gorgeous-looking pair of wireless headphones with a design focus on comfort without compromising on audio quality or battery life. Each of these weighs just 4.3 g, but pack 13.4 mm drivers, support for AAC streams, which means it pairs with your iPhone perfectly, the latest Bluetooth 5.2 wireless technology, and 6 hours of battery life, with the case adding another 18 hours on top. These are also IP5X-rated for water-resistance. TechPowerUp and 1More are collaborating on a giveaway that's open to 185 countries around the world. Ten lucky winners chosen at random, stand a chance to win a pair of Comfobuds 2 Mica White headphones. The giveaway is open from today until February 24. To participate, simply drop in your name and e-mail, so we can get back to you if you've won. All the best.<br />
<br />
For more information and to participate, <a href="https://www.techpowerup.com/contests/1more-headphone-giveaway-jan-22" target="_blank">visit this page</a>.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/wg1M0e4CpGYXWiqi.jpg" target="_blank" data-width="800" data-height="800" ><img src="https://tpucdn.com/img/wg1M0e4CpGYXWiqi_thm.jpg" width="130" height="130" alt="" /></a></div>
Alder Lake-N Makes an Appearance, Features Only Gracemont Cores
Intel's Alder Lake family is apparently still growing and the latest leaks suggest that a new addition is on its way in the shape of the Alder Lake-N. This should be the most basic SKU of Alder Lake CPUs, as it'll only have "small" Gracemont cores and no Golden Cove cores at all, unlike all of its other siblings. The oddities don't stop here though, as these new CPUs won't even have any PCIe lanes from the CPU itself, beyond the chipset interconnect. <br />
<br />
It's possible that these will be some kind of embedded parts, as Alder Lake-N is said to come with up to eight cores. The limitation of PCIe lines, of which apparently only a total of nine will be offered, is something that might make it less appealing for embedded systems, especially if it requires a separate chipset. It's possible that Intel has designed these new SKUs for Chromebooks or other budget notebooks, but they'd have to be priced extremely affordably to be appealing, considering how cheap Chromebooks already are. The chips are also said to feature a full GT1 Gen 12.2 GPU with up to 32 EUs, so graphics performance should at least be comparable to Alder Lake-S desktop parts. We'd hazard a guess that the GPU clocks will be a lot lower though.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/iXTaPx17FX6QyD9v.jpg" target="_blank" data-width="526" data-height="382" ><img src="https://tpucdn.com/img/iXTaPx17FX6QyD9v_thm.jpg" width="179" height="130" alt="" /></a></div>
Alienware's 34-inch QD-OLED Monitor Gets a Price
Remember that <a href="https://www.techpowerup.com/290623/alienware-demos-34-inch-qd-oled-monitor-at-ces" target="_blank">34-inch QD-OLED monitor</a> that Alienware announced at CES earlier this year? The company has finally worked out how much it's going to charge for it, although there is still no fixed availability date. At US$1,299 the AW3423DW is going to be a $100 pricier than the AW3821DW, which sports a 38-inch Nano IPS panel with a resolution of 3840x1600, rather than the 34-inch QD-OLED panel with a resolution of 3440x1440 of the AW3423DW.<br />
<br />
Obviously the two display technologies aren't comparable, but it's at least an indication of how pricy QD-OLED will be initially, compared to more traditional display technologies. Both displays feature G-Sync Ultimate, so it's not as if Dell has tried to cut any corners here. The AW3423DW does offer a higher refresh rate of 175 Hz vs 144 Hz for the AW3821DW, which may be an advantage to some, but the official HDR certification is oddly enough only HDR 400 vs HDR 600, despite the fact that Dell claims it can deliver up to 1000 cd/m². That said, the black levels of the AW3423DW should be vastly superior, as should the colour gamut. The display is said to be available sometime early this spring, presumably in the US market first.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/3WeZk10QXCVlSZim.jpg" target="_blank" data-width="1920" data-height="748" ><img src="https://tpucdn.com/img/3WeZk10QXCVlSZim_thm.jpg" width="334" height="130" alt="" /></a></div>
Intel Sapphire Rapids Xeon with DDR5 Memory Spotted in AIDA64 and Cinebench R15
Intel's next-generation Xeon processors code-named Sapphire Rapids are on track to hit the market this year. These new processors are supposed to bring a wide array of new and improved features and a chance for Intel to show off its 10 nm SuperFin manufacturing process in the server market. Thanks to the Twitter user YuuKi_AnS, we have some of the first tests run in AIDA64 and Cinebench R15 benchmark suites. Yuuki managed to get ahold of DDR5-enabled Sapphire Rapids Xeon with 48 cores and 96 threads, equipped with a base frequency of 2.3 GHz and boost speeds of 3.3 GHz. The processor tested was an engineering sample with a Q-SPEC designation of "QYFQ" and made for Intel Socket E (LGA-4677). This CPU sample was locked at 270 Watt TDP.<br />
<br />
Below, you can see the performance results of this processor, tested in the AIDA64 cache and memory benchmark and Cinebench R15 bench test. There is a comparison between AMD's Milan-X and Xeon Platinum 8380, so the numbers are more in check of what you can expect from the final product.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/aUzpwnzRwB8ruFPc.jpg" target="_blank" data-width="1092" data-height="765" ><img src="https://tpucdn.com/img/aUzpwnzRwB8ruFPc_thm.jpg" width="186" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/X5e6KUyGWdnYHAz6.jpg" target="_blank" data-width="979" data-height="554" ><img src="https://tpucdn.com/img/X5e6KUyGWdnYHAz6_thm.jpg" width="230" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291967/intel-sapphire-rapids-xeon-with-ddr5-memory-spotted-in-aida64-and-cinebench-r15">Read full story</a></div>
KeysOff Valentine's Day Sale: Roses Fade Away, Genuine Software Lasts Forever
Give your significant-other genuine, globally-valid software this Valentine's. Free them from annual payments to 365, by simply choosing the latest and greatest Office 2021, Office 2019, or Office 2016 editions. If you're giving them a new PC or notebook, be sure to save on one that comes without software, and choose from our broad selection of Genuine Windows 10 and Windows 11 editions. Better yet, pair them with your preferred Office edition, to save even more!<br />
<br />
<a rel="nofollow" href="https://www.keysoff.com/windows-11-professional-cd-key-1-pc.html?kso=sks11" target="_blank">Buy Windows 11 Pro at $15.60</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-home-key-1-pc.html?kso=sks11" target="_blank">Buy Windows 11 Home at $16.63</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-32-64-bit-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro at $7.40</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-professional-32-64-bit-2-pc.html?kso=sks11" target="_blank">Buy Windows 10 Pro 2-PC at $11.50</a> | <a rel="nofollow" href="https://www.keysoff.com/office-2016-professional-plus-1-pc.html?kso=sks11" target="_blank">Buy Office 2016 Professional Plus at $21.75</a> | <a rel="nofollow" href="https://www.keysoff.com/office-2019-professional-plus-1-pc.html?kso=sks11" target="_blank">Buy Office 2019 Professional Plus at $28.93</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2021-pro-plus-key-1pc.html?kso=sks11" target="_blank">Buy Office 2021 Professional Plus at $35.08</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2021-pro-plus-key-5-pcs.html?kso=sks11" target="_blank">Buy Office 2021 Professional Plus 5-PC at $74.02</a><br />
<br />
Please use the coupon-code <b>SKK50</b> at check-out to avail the prices you see below.<br />
<a rel="nofollow" href="https://www.keysoff.com/windows-10-home-32-64-bit.html?kso=sks11" target="_blank">Buy Windows 10 Home at $8.16</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-home-cd-key-32-64-bit-2-pc.html?kso=sks11" target="_blank">Buy Windows 10 Home 2-PC at $13.57</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-enterprise-2019-ltsc-microsoft-cd-key-1-pc.html?kso=sks11" target="_blank">Buy Windows 10 Enterprise 2019 LTSC at $9.13</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-server-2019-standard.html?kso=sks11" target="_blank">Buy Windows Server 2019 Standard at $16.06</a><br />
<br />
Please use the coupon-code <b>SKK60</b> on the following items.<br />
<a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2016-home-and-student.html?kso=sks11" target="_blank">Buy Office 2016 Home and Student at $31.48</a> | <a rel="nofollow" href="https://www.keysoff.com/microsoft-office-2019-home-and-student-1-user.html?kso=sks11" target="_blank">Buy Office 2019 Home and Student at $32.79</a> | <a rel="nofollow" href="https://www.keysoff.com/office-home-and-business-2019-for-mac-cd-key-global.html?kso=sks11" target="_blank">Buy Office 2019 Home and Business for Mac at $103.73</a> | <a rel="nofollow" href="https://www.keysoff.com/office-home-and-business-2019-for-pc.html?kso=sks11" target="_blank">Buy Office 2019 Home and Business at $45.10</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-pro-office-2019-pro-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2019 Professional Plus at $34.38</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-10-pro-office-2021-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 10 Pro + Office 2021 Professional Plus at $43.05</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-office-2019-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 11 Pro + Office 2019 Professional Plus at $41.41</a> | <a rel="nofollow" href="https://www.keysoff.com/windows-11-pro-office-2021-pro-plus-package.html?kso=sks11" target="_blank">Buy Windows 11 Pro + Office 2021 Professional Plus at $51.49</a><div class="imgcontainer"><a href="https://www.techpowerup.com/img/E8K0W9MdW17m32cv.jpg" target="_blank" data-width="1280" data-height="720" ><img src="https://tpucdn.com/img/E8K0W9MdW17m32cv_thm.jpg" width="231" height="130" alt="" /></a> </div>Check out our unmissable deals on system software.<div class="readmore"><a href="https://www.techpowerup.com/291966/keysoff-valentines-day-sale-roses-fade-away-genuine-software-lasts-forever">Read full story</a></div>
NVIDIA GA107-based GeForce RTX 3050 is Real, Comes with 11% Lower TDP, Same Specs
When NVIDIA launched the GeForce RTX 3050 "Ampere" based on the "GA106" silicon with specifications that could be fulfilled with the smaller "GA107," we knew that the company could eventually start making RTX 3050 boards with the smaller chip, and they did. Igor's Lab reports that RTX 3050 cards based on GA107 come with a typical board power of 115 W, which is about 11 percent lower than that of the GA106-based cards (130 W). <br />
<br />
There's no difference in specifications between the two cards. Both feature 2,560 CUDA cores across 20 streaming multiprocessors, 80 Tensor cores, 20 RT cores, and a 128-bit wide GDDR6 memory interface, holding 8 GB of memory that ticks at 14 Gbps data-rate (224 GB/s bandwidth). The GA106 and GA107 ASICs share a common fiberglass substrate, and hence are pin-compatible for the convenience of board partners, with the latter having a smaller die, so any cooling solution designed for the launch-day RTX 3050 should work perfectly fine with those based on GA107.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/VsxsrsISX62nP1ar.jpg" target="_blank" data-width="959" data-height="720" ><img src="https://tpucdn.com/img/VsxsrsISX62nP1ar_thm.jpg" width="173" height="130" alt="" /></a></div>
(PR) Akasa Intros a Trio of LGA1700-compatible CPU Coolers
Akasa, a leading provider of cooling and thermal solutions for the global electronics industry, has released new variants of their classic CPU coolers, updated for the Alder Lake processors (LGA 1700 mounting system). The three coolers are designed for unlocked desktop CPUs (AK-CC6606BP01), F-Series desktop CPUs (AK-CC6603EP01), and T-Series desktop CPUs (AK-CC6601EP01). These coolers will work at the TDP set by Intel, and will follow the official thermal and mechanical design guide, improving heat dissipation from the Alder Lake processors.<br />
<br />
The 12th generation of Intel Core processors will be using the LGA1700 mounting system, launching with a host of technological advances. Intel's new hybrid core design allows for efficient data processing, with the introduction of Performance and Efficiency cores (P-cores and E-cores respectively). P-cores are dedicated to the faster processing tasks, whilst E-cores have been built to work through background processes, therefore increasing the multitasking capabilities of the CPU. Due to the new sizes of these cores, the shape of the CPU's integrated heatspreader (IHS) has changed to accommodate this, with its rectangular dimensions of 37.5 mm x 45 mm.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/ThYZkwdslxKGMQ0Q.jpg" target="_blank" data-width="1349" data-height="397" ><img src="https://tpucdn.com/img/ThYZkwdslxKGMQ0Q_thm.jpg" width="442" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291963/akasa-intros-a-trio-of-lga1700-compatible-cpu-coolers">Read full story</a></div>
TSMC Reports Record January Revenues
Based on TSMC's official January 2022 revenue report, it looks like the company is set for another great year. Month-on-month revenues are up by 10.8 percent compared to December of last year and year-on-year revenues are up a whopping 35.8 percent. In actual money, that corresponds to a revenue of NT$172.18 billion, or roughly US$6.18 billion, so we're not talking about small potatoes here.<br />
<br />
TSMC is forecasting a growth in sales of between 25 to 29 percent this year, assuming they can continue to deliver as expected to their customers. The first quarter sales are expected to land between US$16.6 and 17.2 billion, or around a 7.4 percent increase compared to last quarter. Its closest competitor in Taiwan also announced record profits, although at a mere NT$20.47 billion or about US$735 million. This is a month-to-month increase of a mere 0.95 percent, but an annual increase of a healthy 31.83 percent. UMC is expecting to be operating at full capacity for the remainder of this year, although no additional production capacity is expected. The company is said to be increasing its prices by five percent this year.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/apWif2lTZUVSWmCJ.jpg" target="_blank" data-width="754" data-height="200" ><img src="https://tpucdn.com/img/apWif2lTZUVSWmCJ_thm.jpg" width="490" height="130" alt="" /></a></div>
(PR) Intel Announces a Roadmap of Energy-efficient Blockchain Accelerators
Digital computing continues to enrich our lives in more ways than we can imagine. We acquire, consume, and create content and services with a few clicks or taps of our fingertips. Exponential increases in compute performance, enabled by Moore's Law, play a significant role in making these experiences seamless. Moore's Law is also enabling us to democratize access to this enormous pool of processing power. Amazing things happen when a lot of compute is available to a lot of people without much friction.<br />
<br />
Blockchain is a technology that has the potential to enable everyone to own much of the digital content and services they create. Some even call it an inflection point in computing, fundamentally disrupting the way we store, process and transact our digital assets as we usher in the era of metaverse and Web 3.0. No matter how the future evolves, it is certain the availability of a lot more compute to everyone will play a central role.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6JdansHumKigltf0.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/6JdansHumKigltf0_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291904/intel-announces-a-roadmap-of-energy-efficient-blockchain-accelerators">Read full story</a></div>
(PR) Lian Li 2022 Digital Expo Teases with New Prototypes and Soon-to-be-Released Products
LIAN LI Industrial Co. Ltd., a leading manufacturer of aluminium chassis and PC accessories, premieres the LIAN LI 2022 DIGITAL EXPO at 9 am EST on YouTube (here). A 2-part video series, LIAN LI gives further updates on Lancool III, V3000 PLUS, and UNI FAN SL INFINITY, and unveils 2 prototypes with the UNI FAN P28, STRIMER PLUS V2, and L-Connect 3 with a complete tour of the new ARGB software.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/grQuI1wu2pm5Wiva.jpg" target="_blank" data-width="754" data-height="426" ><img src="https://tpucdn.com/img/grQuI1wu2pm5Wiva_thm.jpg" width="230" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QWfxw6F1zHX0xb3G.jpg" target="_blank" data-width="382" data-height="426" ><img src="https://tpucdn.com/img/QWfxw6F1zHX0xb3G_thm.jpg" width="117" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/3uuwDZBuzOOqBqRe.jpg" target="_blank" data-width="800" data-height="430" ><img src="https://tpucdn.com/img/3uuwDZBuzOOqBqRe_thm.jpg" width="242" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/e0Xcn5FYyVDZKB9o.jpg" target="_blank" data-width="736" data-height="426" ><img src="https://tpucdn.com/img/e0Xcn5FYyVDZKB9o_thm.jpg" width="225" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uSOeI6d33nk7galn.jpg" target="_blank" data-width="689" data-height="426" ><img src="https://tpucdn.com/img/uSOeI6d33nk7galn_thm.jpg" width="210" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291900/lian-li-2022-digital-expo-teases-with-new-prototypes-and-soon-to-be-released-products">Read full story</a></div>
(PR) NAND Flash Pricing Set to Spike 5-10% in Q2 Due to Material Contamination at WDC and Kioxia, Says TrendForce
WDC recently stated that certain materials were contaminated in late January at NAND Flash production lines in Yokkaichi and Kitakami, Japan which are joint ventures with Kioxia, according to TrendForce's investigations. Before this incident, TrendForce had forecast that the NAND Flash market will see a slight oversupply the entire year and average price from Q1 to Q2 will face downward pressure. However, the impact of WDC's material contamination issue is significant and Samsung's experience during the previous lockdown of Xi'an due to the pandemic has also retarded the magnitude of the NAND Flash price slump. Therefore, the Q1 price drop will diminish to 5~10%. In addition, according to TrendForce, the combined WDC/Kioxia NAND Flash market share in the 3Q21 was as high as 32.5%. The consequences of this latest incident may push the price of NAND Flash in Q2 to spike 5~10%.<br />
<br />
The contaminated products in this incident are concentrated in 3D NAND (BICS) with an initial estimate of 6.5exabytes (approximately 6,500M GB) affected. According to TrendForce, damaged bits account for 13% of the group's output in 1Q22 and approximately 3% of the total output for the year. The normal production schedule for the entire line has yet to be confirmed. It is worth noting that the damages announced by WDC likely do not account for total losses stemming for this event and the number of damaged Kioxia parts has not been aggregated, so the total number of affected bits may increase further.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/EBl7clLqM2eVa6ox.jpg" target="_blank" data-width="684" data-height="400" ><img src="https://tpucdn.com/img/EBl7clLqM2eVa6ox_thm.jpg" width="222" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/aaMz55fRFaCUXdkW.jpg" target="_blank" data-width="1610" data-height="501" ><img src="https://tpucdn.com/img/aaMz55fRFaCUXdkW_thm.jpg" width="418" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291899/nand-flash-pricing-set-to-spike-5-10-in-q2-due-to-material-contamination-at-wdc-and-kioxia-says-trendforce">Read full story</a></div>
Peculiar Sony LinkBuds Leak, Appears to be Open Back
When it comes to headphones, Sony is not a company to shy away from trying new things and the leaked LinkBuds are unlike anything else currently in the market. What we're looking at seems to be a set of open back in-ear TWS earbuds, although it's highly unlikely that we'll see any form of noise cancelling support here. Sony did make something similar under its Xperia brand some years ago, although the Xperia Ear Duo XEA20 as they were called, weren't nearly as compact, but it's the only other open back in-ear type headphones we're aware of.<br />
<br />
The LinkBuds, also known as the WF-L900 appear to be sitting entirely inside your ears and according to the leaked information, they lack any kind of physical buttons. This might not be a huge issue, as the LinkBuds are said to feature automatic volume control, based on the listening environment. They're supposedly built around Sony's V1 processor and are said to feature support for Sony's DSEE (Digital Sound Enhancement Engine). Although noise cancelling for the listener might be missing, AI noise suppression for voice is apparently present and is meant to be activated by touching the ear, rather than the earbuds. Other features should include support for voice assistants, Google Fast Pair and multi-pairing.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CxQcDsA6hXiunnOi.jpg" target="_blank" data-width="1280" data-height="850" ><img src="https://tpucdn.com/img/CxQcDsA6hXiunnOi_thm.jpg" width="196" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nwJtk5BJcSXYFqDe.jpg" target="_blank" data-width="1280" data-height="650" ><img src="https://tpucdn.com/img/nwJtk5BJcSXYFqDe_thm.jpg" width="256" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/wHI56kGm0sCiSmVL.jpg" target="_blank" data-width="1010" data-height="1280" ><img src="https://tpucdn.com/img/wHI56kGm0sCiSmVL_thm.jpg" width="103" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XmdskU2PwpEJeohU.jpg" target="_blank" data-width="791" data-height="1280" ><img src="https://tpucdn.com/img/XmdskU2PwpEJeohU_thm.jpg" width="80" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291898/peculiar-sony-linkbuds-leak-appears-to-be-open-back">Read full story</a></div>
(PR) BIOSTAR Announces the TZ590-BTC Motherboard for Mining
BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today, unveils the brand new TZ590-BTC motherboard. Designed based on the Intel Z590 chipset that runs Intel 10th and 11th gen processors, BIOSTAR's new TZ590-BTC motherboard targets the mid-range audience of casual gamers, content creators, and users looking to build an HTPC for casual-content consumption. The TZ590-BTC also specializes in crypto mining with native inbuilt functionality to support this claim.<br />
<br />
Available in a full-ATX form factor, the new TZ590-BTC motherboard provides a strong feature-rich base for users, with functionality such as PCIe 4.0, PCIe M.2 4.0. An 11 Phase power design controlled by BIOSTAR's signature DIGITAL PWM technology keeps everything running smooth and safe. 4x DDR4 RAM slots that support up to 3600 (OC) with a maximum capacity of 128 GB come in handy for all purposes. The TZ590-BTC has 8x PCIe 3.0x1 Slots, ideal for BITCOIN and ETHEREUM mining, as well as a single PCIe 4.0 x16 Slot targeting exceptional performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/UajgMQcTDNW3D1zM.jpg" target="_blank" data-width="1024" data-height="683" ><img src="https://tpucdn.com/img/UajgMQcTDNW3D1zM_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cF44rXoxhY9tVfNr.jpg" target="_blank" data-width="1024" data-height="683" ><img src="https://tpucdn.com/img/cF44rXoxhY9tVfNr_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/lWdNKP4np7RDbRjq.jpg" target="_blank" data-width="1024" data-height="656" ><img src="https://tpucdn.com/img/lWdNKP4np7RDbRjq_thm.jpg" width="203" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291897/biostar-announces-the-tz590-btc-motherboard-for-mining">Read full story</a></div>
(PR) Fanttik Launches Versatile New Generation Portable Power Station EVO 300
Fanttik, a young and fast-growing brand that creates tech-driven solutions for real-world problems, has announced the launch of its New-Gen EVO 300 portable power station in the United States which boasts a large LCD display and is ideal for outdoor users who need both power and versatility. It is a must-have backup for camping parties or road trips that demand numerous power connections and a reliable and long battery life.<br />
<br />
"In an era when everyone is concerned about the environment, traditional gas-powered devices are being criticized for their noise and noxious emissions. As a company dedicated to providing outdoor products that combine advanced technology with down-to-earth practicality for the younger generation, we believe that this new generation portable power station, which is electric-powered and emission-free, will provide greater value and a superior experience to our customers," said Bo Du, CEO of Fanttik.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/kv4msxA2YKE6EPLh.jpg" target="_blank" data-width="1280" data-height="1149" ><img src="https://tpucdn.com/img/kv4msxA2YKE6EPLh_thm.jpg" width="145" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291896/fanttik-launches-versatile-new-generation-portable-power-station-evo-300">Read full story</a></div>
(PR) TerraMaster Introduces 9-Bay T9-423 High-Performance NAS
TerraMaster, a professional brand that specializes in providing innovative storage products for home, businesses and enterprises, introduces the all-new T9-423 9-bay high-performance NAS designed for small- and medium-sized businesses. The TerraMaster T9-423 is ideal for enterprise applications such as file storage servers, mail servers, web servers, FTP servers, virtual machine hosts, and other enterprise-level applications.<br />
<br />
The TerraMaster T9-423 is powered by a quad-core 2.00 GHz (2.90 GHz boost) Intel Core processor and comes with two 2.5 GbE ports with support for Link Aggregation, delivering speeds of up to 283 MB/s. It supports multi-user and high-concurrent file access. Its compact chassis can be mounted vertically and horizontally to provide builders flexibility of use.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/aj68HPrQGmbVc5En.jpg" target="_blank" data-width="977" data-height="552" ><img src="https://tpucdn.com/img/aj68HPrQGmbVc5En_thm.jpg" width="230" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AuStHe6fHA9qO2lA.jpg" target="_blank" data-width="977" data-height="552" ><img src="https://tpucdn.com/img/AuStHe6fHA9qO2lA_thm.jpg" width="230" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/GsJfTQhLFxDkICSb.jpg" target="_blank" data-width="977" data-height="552" ><img src="https://tpucdn.com/img/GsJfTQhLFxDkICSb_thm.jpg" width="230" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291892/terramaster-introduces-9-bay-t9-423-high-performance-nas">Read full story</a></div>
(PR) ADATA Unveils XPG CyberCore Modular Power Supply
XPG, a fast-growing provider of systems, components, and peripherals for Gamers, Esports Pros, and Tech Enthusiasts, today announces a very exciting addition to its power supply family, the XPG CYBERCORE modular power supply, which comes in 1000 W and 1300 W variants with PLATINUM efficiency verified by industry experts at Cybenetics. Equipped with the XPG VENTO PRO 120 PWM fan and high precision Japanese dual bearings, XPG CYBERCORE takes things up a notch to offer gamers the ultimate stability. <br />
<br />
XPG CYBERCORE is the latest XPG and Nidec collaboration. It is equipped with an XPG VENTO PRO 120 PWM fan powered by Nidec for unmatched cooling efficiency. The Nidec fans feature a curved design that offers maximum effectiveness. The fans begin spinning with a zero RPM low-load mode until around 30% power load to initiate the fan spin. The design has two main benefits - prolonged fan life expectancy and most importantly it enables a compact form factor at only 160 mm length, one of the smallest in the Platinum category.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/D8fEmlmMkqEo4I1k.jpg" target="_blank" data-width="992" data-height="830" ><img src="https://tpucdn.com/img/D8fEmlmMkqEo4I1k_thm.jpg" width="155" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291890/adata-unveils-xpg-cybercore-modular-power-supply">Read full story</a></div>
(PR) Toshiba Reports 2021 HDD Shipment & Sales Figures
Toshiba Electronic Components Taiwan Corporation announced HDD shipment unit and Exabyte grew 4% and 61%, respectively in 2021. The company shipped 54.68 million units equaling 187.24 Exabytes for the year. Nearline, Mission Critical, Desktop/CE segments posted higher unit and Exabyte results for the year with Nearline HDDs leading all applications with units surging 73% and Exabytes skyrocketing 114%. Toshiba set a new shipment record for Nearline HDDs in 4CQ21, as units grew to 2.90 million units totaling 33.93 Exabytes for the quarter and was up over 94% from a year ago. Toshiba led the industry in Y-Y growth in eight categories for the year, and holds a unique position as an HDD company posting unit growth in 2021.<br />
<br />
"Toshiba continues to execute in the Nearline space, and this is reflected in the company's new Nearline unit shipment record in 4CQ21," stated Ed Burns, Research Director at IDC. "Toshiba's cutting-edge technology such as FC-MAMR (Flux-Controlled - Microwave-Assisted Magnetic Recording) and MAS-MAMR (Microwave Assisted Switching - Microwave-Assisted Magnetic Recording) should further their competitiveness in the Nearline HDD market."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Kt11oPeHcM7CDreH.jpg" target="_blank" data-width="1382" data-height="922" ><img src="https://tpucdn.com/img/Kt11oPeHcM7CDreH_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/UDK2ZqZVbo8GoXHe.jpg" target="_blank" data-width="544" data-height="306" ><img src="https://tpucdn.com/img/UDK2ZqZVbo8GoXHe_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291888/toshiba-reports-2021-hdd-shipment-sales-figures">Read full story</a></div>
(PR) Acer Reports January Consolidated Revenues of NT$25.16 Billion
Acer Inc. announced today its consolidated revenues for January 2022 at NT$25.16 billion to reach an eight-year high for the same period. The January revenues grew by 7.1% year-on-year (YoY), and declined by 14.8% month-on-month due to seasonality. Logistics issues continue to be a bottleneck, while semi-conductor shortages are easing.<br />
<br />
Acer's strategy to build multiple business engines continues to gain momentum. Meanwhile, businesses other than PCs and displays contributed to 19.0% of total revenues, compared to 16.1% contribution in January 2021. Among the Acer Group subsidiaries, the publicly-listed companies have all announced their January revenues, while Acer Gaming's revenues grew by 29.3% YoY and Acer Gadget's revenues grew by 24.9% YoY.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/JP897FQ2RYF0KzOD.jpg" target="_blank" data-width="1260" data-height="710" ><img src="https://tpucdn.com/img/JP897FQ2RYF0KzOD_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291887/acer-reports-january-consolidated-revenues-of-ntusd-25-16-billion">Read full story</a></div>
(PR) Qualcomm Expands XR & Metaverse Investment With The Formation of XR Labs Europe
Qualcomm Technologies, Inc. today announced the company has opened Extended Reality (XR) Labs in Europe. Europe already has a thriving augmented and virtual reality (AR/VR) community and Qualcomm Technologies is committed to making XR the future of mobile computing. The XR Labs will focus activities on XR R&D, engineering and key technology development areas such as advanced hand tracking and gesture control, 3D Mapping and SLAM/Localization services, multi-user experiences, and image recognition. Also, XR SDKs providing access to foundational XR technology including object and geo-tracking.<br />
<br />
The new labs in Europe build on Qualcomm Technologies' commitment to make XR accessible to the masses and will be located across six cities in Europe initially, with the intention to add more in the future. The goal is to help design lightweight, sleek headworn glasses and make innovative technology available for developers through Snapdragon Spaces XR Developer Platform to build experiences that will transform everyday consumer, retail, industrial, enterprise, education and healthcare. Qualcomm Technologies is pushing the boundaries and charting its course to everyday use through continued R&D advancements.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/SyCGCfwrk4xk2zdU.jpg" target="_blank" data-width="1024" data-height="576" ><img src="https://tpucdn.com/img/SyCGCfwrk4xk2zdU_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291886/qualcomm-expands-xr-metaverse-investment-with-the-formation-of-xr-labs-europe">Read full story</a></div>
(PR) Congatec Launches COM-HPC Carrier Design Guide Compliant Ecosystem
congatec welcomes the publication of the COM-HPC Carrier Board Design Guide by the PCI Industrial Computer Manufacturers Group (PICMG) with the launch of a fully specification compliant ecosystem for engineers of COM-HPC Client and Server module based designs. From now on, engineers can dive right in and start to develop fully compliant designs by picking their appropriate Computer-on-Module, add a COM-HPC Server or COM-HPC Client evaluation carrier and appropriate cooling solution, install their application and run programming, debugging and test routines on this new high-performance embedded computing standard.<br />
<br />
The congatec COM-HPC ecosystem is fully compliant to the entire range of new PICMG COM-HPC specifications, namely the COM-HPC Module Base Specification, the brand new Carrier Board Design Guide, the Embedded EEPROM specification and the Platform Management Interface specification. Supported by all leading embedded computing vendors, including congatec, this set of PICMG standards offers engineers the benefits of best in class design security.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/mC0nSULfNYeCiFqD.jpg" target="_blank" data-width="1000" data-height="500" ><img src="https://tpucdn.com/img/mC0nSULfNYeCiFqD_thm.jpg" width="260" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/291885/congatec-launches-com-hpc-carrier-design-guide-compliant-ecosystem">Read full story</a></div>
Qualcomm wants Consortium to Keep Arm Independent
After the failed NVIDIA-Arm acquisition attempt, which saw regulators burn up NVIDIA's $66 billion acquisition dreams of the UK chip designer, industry players are now mulling ways to insulate Arm from similar acquisition tactics that could upend the company's market neutrality. Speaking with the Financial Times, Qualcomm CEO Cristiano Amon said he favors a consortium approach to acquiring Arm from parent company SoftBank. The Japanese conglomerate paid around $26 billion for Arm in 2016, and is now planning to capitalize on its investment with an IPO of the UK-based company that's expected to occur before the end of 2023.<br />
<br />
Being a fabless design company, Arm has become one of the de-facto cornerstones for the technology industry. Its processor designs are easily the most ubiquitous worldwide, and can be found in everything from mobile phones (where Qualcomm, Samsung, and other companies' interests lay) through automotive, IOT, and even the world's now second-fastest supercomputer, Japan's Fugaku. Qualcomm's posture regarding the chip design company has been previously echoed by Intel CEO Pat Gelsinger, who said he too saw value in an industry-led consortium pooling together resources to acquire Arm from Softbank in a way that would keep the company's crucial IP at arm's length from weaponization by any single tech industry player.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/URYnJr5nt3AuO5Fv.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/URYnJr5nt3AuO5Fv_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/fihLoOyp0qQtz7q2.jpg" target="_blank" data-width="900" data-height="490" ><img src="https://tpucdn.com/img/fihLoOyp0qQtz7q2_thm.jpg" width="239" height="130" alt="" /></a></div>
(PR) Razer Announces New Barracuda Headsets
Razer, the leading global lifestyle brand for gamers, today announced the new Barracuda and Barracuda Pro, along with a refresh of the existing Barracuda X. The new family of street-styled gaming headsets comes packed with cutting edge technologies to bring gamers the purest sound whether at home or out and about. Featuring Hybrid Active Noise Cancellation Technology (ANC) the Barracuda Pro provides the user with an uninterrupted audio experience in all surroundings, ideal for intense gaming sessions requiring maximum focus, as well as for anyone wanting to enjoy their music outdoors while muting any distractions from the outside world.<br />
<br />
Using Razer SmartSwitch Dual Wireless, the Barracuda Pro can be connected to two devices at the same time, switching seamlessly between the two as needed. This allows a user to game on their PC, and with a single button press, switch the Barracuda Pro to take a call without the need to unpair and pair between devices. All Barracuda models support both Razer HyperSpeed Wireless (2.4 GHz) and Bluetooth 5.2 connectivity, for high-speed gaming performance and mobile-friendly Bluetooth convenience. "The Barracuda Pro is the hybrid headset that does it all," said Chris Mitchell, Head of the PC Gaming Division at Razer. "Whether it's your main gaming setup at home or your favorite music playlists on the go, the Barracuda Pro combines the fuss-free convenience of lifestyle headphones along with the high-performance gaming features you'd expect in a Razer gaming headset, to create a no-compromise experience, packaged in a sleek, premium design."<div class="imgcontainer"><a href="https://www.techpowerup.com/img/BiXUlPBgONKjz5zq.jpg" target="_blank" data-width="1280" data-height="885" ><img src="https://tpucdn.com/img/BiXUlPBgONKjz5zq_thm.jpg" width="188" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Vu2DiCbpccCVPahP.jpg" target="_blank" data-width="1280" data-height="853" ><img src="https://tpucdn.com/img/Vu2DiCbpccCVPahP_thm.jpg" width="195" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Kd30B2d6K3bD5YBO.jpg" target="_blank" data-width="825" data-height="1025" ><img src="https://tpucdn.com/img/Kd30B2d6K3bD5YBO_thm.jpg" width="105" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MVn7rdB6oDgkzi4t.jpg" target="_blank" data-width="1046" data-height="1280" ><img src="https://tpucdn.com/img/MVn7rdB6oDgkzi4t_thm.jpg" width="106" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/gVm1nPag1Z0QRBXz.jpg" target="_blank" data-width="1280" data-height="809" ><img src="https://tpucdn.com/img/gVm1nPag1Z0QRBXz_thm.jpg" width="206" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/QJzXIdMBNxQ7Et7t.jpg" target="_blank" data-width="1280" data-height="892" ><img src="https://tpucdn.com/img/QJzXIdMBNxQ7Et7t_thm.jpg" width="187" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295437/razer-announces-new-barracuda-headsets">Read full story</a></div>
Australia Installs First Room-Temperature Diamond Quantum Computer
Quantum computing is an upcoming acceleration aiding classical computational methods to achieve monumental speed-ups at a few select problems. Unlike classical computers, quantum systems usually require sub-ambient cooling to make them work. At Quantum Brilliance, an Australian-Germany startup company, researchers have been developing quantum accelerators based on diamonds. Today, we got the world's first installation of room-temperature on-premises quantum computers at Australia's Pawsey Supercomputing Centre. While we don't have much information about the computational capability of the system, we know that it is paired with HPE Setonix, Pawsey's HPE Cray EX supercomputer.<br />
<br />
In a brief YouTube video shared by Pawsey, it is highlighted that the benefits of using quantum accelerators are real, and they are figuring out ways to integrate it with the center's hardware and software stack for better usage. Meanwhile, Quantum Brilliance diamond accelerators are still a black box of some sort as the technology is known to the startup and its collaborating Australian universities. All we know is that the company is harnessing nitrogen-vacancy (NV) center in diamonds, which supposedly have the longest coherence time of any room temperature quantum state. This translates to a qubit that can operate anywhere a classical computer can.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/zuNmArrsflsW2D5z.jpg" target="_blank" data-width="1388" data-height="781" ><img src="https://tpucdn.com/img/zuNmArrsflsW2D5z_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pxuog5UW5o95Gj4k.jpg" target="_blank" data-width="1291" data-height="762" ><img src="https://tpucdn.com/img/pxuog5UW5o95Gj4k_thm.jpg" width="220" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/MeOLyPEnd52KaKhE.jpg" target="_blank" data-width="1570" data-height="777" ><img src="https://tpucdn.com/img/MeOLyPEnd52KaKhE_thm.jpg" width="263" height="130" alt="" /></a></div>
(PR) Thermaltake Launches the ARGENT K6 RGB Keyboard with MX Red, MX Speed Silver
Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals and enthusiast memory solutions, is excited to announce the launch of the first Low-Profile Mechanical Gaming Keyboard of the product line, the ARGENT K6 RGB Low Profile Mechanical Gaming Keyboard Cherry MX Red and Speed Silver, which are available for purchase now. <br />
<br />
Thermaltake always strives to deliver better gaming experiences for users by offering more advanced gaming peripherals. We are also proud to announce that the ARGENT K6 RGB Low-Profile Mechanical Gaming Keyboard is the winner of the 2022 Red Dot Design Award. With the ARGENT K6 RGB Low-Profile Mechanical Gaming Keyboard Cherry MX Red/ Speed Silver, users can enjoy a comfortable typing experience thanks to its particularly low overall height. Cherry MX Low Profile RGB switches are rated at 100-million keystrokes, offering the most durable, precise, and responsive tactile feedback. Moreover, the ARGENT K6 RGB Low Profile Mechanical Gaming Keyboard Cherry MX Red/ Speed Silver come with a magnetic wrist rest to give maximum wrist support and comfort.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/KYgErUiTKvciS8A5.jpg" target="_blank" data-width="1460" data-height="1000" ><img src="https://tpucdn.com/img/KYgErUiTKvciS8A5_thm.jpg" width="190" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ydhRTC6BobvCJTgT.jpg" target="_blank" data-width="1481" data-height="1000" ><img src="https://tpucdn.com/img/ydhRTC6BobvCJTgT_thm.jpg" width="193" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/XLAYDiIE5glAlpPq.jpg" target="_blank" data-width="1577" data-height="1000" ><img src="https://tpucdn.com/img/XLAYDiIE5glAlpPq_thm.jpg" width="205" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/FnpwpAVubfzvZ97R.jpg" target="_blank" data-width="1367" data-height="1000" ><img src="https://tpucdn.com/img/FnpwpAVubfzvZ97R_thm.jpg" width="178" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/dP0SdPKbZQjCH1wJ.jpg" target="_blank" data-width="1498" data-height="1000" ><img src="https://tpucdn.com/img/dP0SdPKbZQjCH1wJ_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295433/thermaltake-launches-the-argent-k6-rgb-keyboard-with-mx-red-mx-speed-silver">Read full story</a></div>
(PR) ADATA XPG Unveils VALOR AIR Mid-Tower Chassis
XPG, a fast-growing provider of systems, components, and peripherals for Gamers, Esports Pros, and Tech Enthusiasts, today announced the VALOR AIR mid-tower PC chassis. As the name implied, VALOR AIR is a PC chassis that emphasizes optimized airflow. What's more, it sports a tempered-glass side panel for showing off the flair of the interior components. Although compact in size, VALOR AIR provides ample interior space to support and accommodate hardware and components. The mid-tower chassis is suitable for all types of gamers and PC enthusiasts. With optimized airflow dynamics, ample space, and design flair, it offers the perfect balance between form and function. <br />
<br />
The XPG VALOR AIR mid-tower chassis sports a sleek, clean look with a streamlined design that effectively pulls cool air from outside to be drawn in via x3 pre-installed 120 mm fans at the front, and a 120 mm fan at the rear to exhaust heated air. Though it has space-saving dimensions, it remains capable to accommodating graphics cards with a length of up to 335 mm. It can support power supplies with lengths from 160 mm-180 mm, including the 80 PLUS GOLD certified XPG CORE REACTOR and 80 PLUS PLATINUM certified XPG CYBERCORE. The XPG VALOR AIR is a simple and elegantly designed mid-tower chassis, deliver excellent airflow, space, and performance for a manageable price.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/4RQRDaLtKzqnZkPH.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/4RQRDaLtKzqnZkPH_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uj40oijXtNkKzcFW.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/uj40oijXtNkKzcFW_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Vjl5gVXIJvY9jOsb.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/Vjl5gVXIJvY9jOsb_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/ctvqiiRniAIWqTMQ.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/ctvqiiRniAIWqTMQ_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/iYUhPgbBy8ktH4ep.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/iYUhPgbBy8ktH4ep_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295432/adata-xpg-unveils-valor-air-mid-tower-chassis">Read full story</a></div>
(PR) Philips Launches Momentum Series 27M1F5500P and 27M1F5800 Monitors
The premium Momentum 5000 gaming line by Philips monitors is welcoming two new 27" (68.5 cm) gaming monitors: The Momentum 27M1F5500P and 27M1F5800. Designed to offer today's gamers the thrilling, immersive experience they seek and give them a real competitive advantage over other players, the Momentum line is packed with cutting-edge features guaranteed to amaze. To offer a more complete experience, and meet the needs of all gamers, these models are also great tools to improve user's productivity while working long hours.<br />
<br />
"Our new Philips gaming monitors from the Momentum line are jam-packed with features specifically designed to offer gamers everything they need to get the most out of even the most dynamic and visually rich video games on the market. With the 27M1F5500P and the 27M1F5800, gamers are certain to enjoy the highest intensity gameplay available thanks to an array of peak-performance features that deliver stunning graphics and smooth, ultra-fast, low latency gameplay. This is gaming as it is meant to be experienced." - says César Acosta, Gaming Product Manager for Europe at MMD Monitors & Displays.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Ur6CtXv8ljnWMFep.jpg" target="_blank" data-width="1117" data-height="1000" ><img src="https://tpucdn.com/img/Ur6CtXv8ljnWMFep_thm.jpg" width="145" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/cMYGwoxDhTW55oGK.jpg" target="_blank" data-width="1181" data-height="975" ><img src="https://tpucdn.com/img/cMYGwoxDhTW55oGK_thm.jpg" width="157" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eiblakcZEyTynfKf.jpg" target="_blank" data-width="1237" data-height="1000" ><img src="https://tpucdn.com/img/eiblakcZEyTynfKf_thm.jpg" width="161" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/PfoQexrzOUXP3OyW.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/PfoQexrzOUXP3OyW_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/eJodr1nMRZTuXlW0.jpg" target="_blank" data-width="1050" data-height="1000" ><img src="https://tpucdn.com/img/eJodr1nMRZTuXlW0_thm.jpg" width="137" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295431/philips-launches-momentum-series-27m1f5500p-and-27m1f5800-monitors">Read full story</a></div>
(PR) Sharkoon Announces TK5M RGB Compact ATX Case
Sharkoon Technologies, an international supplier of high-quality, high-performance PC components and peripherals, now presents the TK5M RGB. With its modern mesh front panel, four pre-installed 120-millimeter fans and a port for fast USB-C Type-C Gen 2, this compact ATX case been developed for users who value usability, affordability and maximum performance.<br />
<br />
With the TK5M RGB, Sharkoon focuses in particular on a well-thought-out airflow. At the core of this is the combination of an air-permeable mesh front and four pre-installed, addressable RGB 120-millimeter fans. Three of these fans provide an optimized air intake behind the front panel, while another fan is responsible for removing the heated air through the rear of the case. If the user wishes to expand the airflow, two more 120-millimeter fans or two larger 140-millimeter fans can be installed under the top panel to provide an additional discharge of used air.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/CpCIxFTXB67o5V1Z.jpg" target="_blank" data-width="1041" data-height="1000" ><img src="https://tpucdn.com/img/CpCIxFTXB67o5V1Z_thm.jpg" width="135" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/xiB9AugnkP7yeF3H.jpg" target="_blank" data-width="1082" data-height="1000" ><img src="https://tpucdn.com/img/xiB9AugnkP7yeF3H_thm.jpg" width="141" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nraMb6cj0i38FsHB.jpg" target="_blank" data-width="1075" data-height="1000" ><img src="https://tpucdn.com/img/nraMb6cj0i38FsHB_thm.jpg" width="140" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/uuUYehsfv6J1u5r2.jpg" target="_blank" data-width="1024" data-height="1000" ><img src="https://tpucdn.com/img/uuUYehsfv6J1u5r2_thm.jpg" width="133" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/nHHHXdPPpfveByJD.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/nHHHXdPPpfveByJD_thm.jpg" width="130" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295430/sharkoon-announces-tk5m-rgb-compact-atx-case">Read full story</a></div>
(PR) Corsair Dominator Platinum DDR5 Achieves DDR5-6600
CORSAIR, a world leader in enthusiast components for gamers, creators, and PC builders, today announced new kits of its acclaimed DOMINATOR PLATINUM RGB DDR5 high-performance memory, now boasting speeds up to a screaming-fast 6,600MT/s. At time of writing, these are the fastest DDR5 kits available to buy in the world, achieving remarkably tight timings of 32-39-39-76. Available in kits of 2x16 GB, DOMINATOR PLATINUM RGB continues to break frequency barriers with unprecedented speeds, and stay on the cutting-edge of performance.<br />
<br />
The frequency ceiling for DDR5 performance has risen again on CORSAIR's flagship DRAM, joining high-frequency DOMINATOR PLATINUM RGB offerings of DDR5-6000, DDR5-6200, and DDR5-6400. With 6,600 MHz, DOMINATOR PLATINUM RGB memory now clocks phenomenal speeds on systems leveraging 12th Generation Intel Core processors and Intel Z690 motherboard chipsets, such as the ASUS ROG STRIX Z690-F and ROG MAXIMUS Z690 HERO. With a speedy 32 CAS timing and tight 32-39-39-76 overall timings on these new modules, DOMINATOR PLATINUM RGB pushes the envelope of enthusiast DRAM performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/6CUXxRj23srPeq8E.jpg" target="_blank" data-width="1401" data-height="1000" ><img src="https://tpucdn.com/img/6CUXxRj23srPeq8E_thm.jpg" width="182" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/snDG4wr0i0WJUWPL.jpg" target="_blank" data-width="1292" data-height="1000" ><img src="https://tpucdn.com/img/snDG4wr0i0WJUWPL_thm.jpg" width="168" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Cs64gY5mcf6ol6Hs.jpg" target="_blank" data-width="1547" data-height="1000" ><img src="https://tpucdn.com/img/Cs64gY5mcf6ol6Hs_thm.jpg" width="201" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/G8xAwmEHcrnN148z.jpg" target="_blank" data-width="1174" data-height="1000" ><img src="https://tpucdn.com/img/G8xAwmEHcrnN148z_thm.jpg" width="153" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/Y6Se1XC84CWPwhkL.jpg" target="_blank" data-width="1500" data-height="1000" ><img src="https://tpucdn.com/img/Y6Se1XC84CWPwhkL_thm.jpg" width="195" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295428/corsair-dominator-platinum-ddr5-achieves-ddr5-6600">Read full story</a></div>
(PR) Kingston Launches IronKey Vault Privacy 50 with FIPS 197 Certific
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., a world leader in memory products and technology solutions, today announced the release of its latest encrypted USB drive, IronKey Vault Privacy 50 (VP50) with FIPS 197 certification and AES 256-bit hardware-encryption in XTS mode for data security. Kingston IronKey Vault Privacy 50 supports Admin, User, and One-Time Recovery passwords with Complex or Passphrase modes. This multi-password option enhances the ability to recover access to data on the drive should one of the passwords be forgotten. While traditional Complex mode allows for passwords from 6-16 characters using 3 out of 4 character sets, the new passphrase mode gives users the ability to have a numeric PIN, sentence, list of words, or even lyrics from 10 to 64 characters long that's unique, yet memorable to them. To aid in password entry, the "eye" symbol can be enabled to reveal the typed-in password to reduce failed login attempts. <br />
<br />
Admin can also enable a User and a One-Time Recovery password or reset the User password to restore data access. In addition, VP50 protects against Brute Force attacks by locking out User or One-Time Recovery passwords upon 10 invalid entries in a row and crypto-erases the drive if the Admin password is entered incorrectly 10 times in a row. So, while data is lost, there's no fear of a breach.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/pOnpSR7TalKhJYLW.jpg" target="_blank" data-width="1280" data-height="800" ><img src="https://tpucdn.com/img/pOnpSR7TalKhJYLW_thm.jpg" width="208" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295425/kingston-launches-ironkey-vault-privacy-50-with-fips-197-certification-and-xts-aes-256-bit-encryption">Read full story</a></div>
(PR) Edifier continues search for perfection by reviving the legendary audio brand STAX
Innovative audio specialists Edifier have released the S3, the brand's first premium Hi-fi headphone designed for audiophiles and the first product in their new STAX SPIRIT product line - which brings absolute audio fidelity firmly to the foreground for Hi-fi enthusiasts, music lovers, musicians, and producers alike. For those who may not be familiar, STAX was a legendary Japanese audio brand which Edifier acquired in 2012. Best known for developing the first ever electrostatic headphones, or "EARSPEAKERS", the name 'STAX' has been at the forefront of every major sonic innovation since 1938. The S3 continues in this tradition and builds upon the name's renowned legacy and pursuit of faithfully reproducing a 'live' sound.<br />
<br />
Inspired by the delicacy of exceedingly more precise electrostatic technology, the Edifier STAX SPIRIT S3 achieves a level of audio fidelity previously unheard of at this consumer level ($399.99). Designed with audio professionals and enthusiasts in mind, the S3 set a high technical threshold using finely tuned Planar technology. Planar combines both the benefits of Dynamic and Electrostatic Driver to achieve exceedingly detailed lower frequencies and clearer, more consistent high frequency performance. Utilizing a combination of Snapdragon audio technology; three patented planar driver solutions; Hi-Res Audio technology and innovative acoustic-friendly materials, the S3 delivers a truly memorable, lossless, and low distortion audio experience.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/cm7x2addPm6TsObK.jpg" target="_blank" data-width="731" data-height="549" ><img src="https://tpucdn.com/img/cm7x2addPm6TsObK_thm.jpg" width="173" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295424/edifier-continues-search-for-perfection-by-reviving-the-legendary-audio-brand-stax">Read full story</a></div>
(PR) STEPVR Released the World's First Metaverse Gate
On May 26, STEPVR, an innovative company focusing on VR technology research and development, released VR Gates to the metaverse called Gates01 in Beijing. This product is similar to the "Oasis" in the movie Ready Player One. The omnidirectional motion system and the technical equipment that restores five senses allow users to enter the virtual world for sports, entertainment, education, and work. Being the world's first company to achieve MMO games in the VR world, STEPVR has surpassed companies such as Meta and taken the lead in launching software and hardware systems that enter the metaverse. The commercial version of VR Gates released by STEPVR is named Gates01. The product covers an area of approximately 3m2. The deck is a self-developed omnidirectional motion system where users can run freely and achieve running and instant stopping movements. In addition, Gates01 can also restore the sense of vision, hearing, touch, smell, and vestibular balance in the virtual world, allowing users to experience the real and immersive virtual world in a small and convenient space.<br />
<br />
STEPVR was founded in 2013. Its founder, Guo Cheng, studied at Delft University of Technology in the Netherlands and obtained a doctorate degree. The company focuses on the research and development of laser positioning technology and virtual human motion capture technology. In 2019, STEPVR launched an ultra-space free-roam VR esports brand, Future Battle, in China. In less than a year, Future Battle has opened more than 140 stores through brand authorization and franchising. Despite the impact of the epidemic, there are still more than 60 partner stores to be opened. The number of users that have signed up for membership has reached 70%, and 22% of the partners have opened a second store. Through the operation of free-roam VR stores, STEPVR has gained more than 1 million users, becoming one of the brands with the most VR users in the world.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/DLYJpZ4TWmlmlvOn.jpg" target="_blank" data-width="1920" data-height="1080" ><img src="https://tpucdn.com/img/DLYJpZ4TWmlmlvOn_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295423/stepvr-released-the-worlds-first-metaverse-gate">Read full story</a></div>
AMD Zen 4 & Socket AM5 Explained: PCIe Lanes, Chipsets, Connectivity
There has been a fair bit of confusion about AMD's upcoming AM5 platform when it comes to connectivity and we're going to break things down and explain what the difference is between the B650 and X670 boards. We're also going to cover the processor connectivity, since that's an integral part of any motherboard these days. All the information in this article is based on what we've been told by various sources during Computex.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Q0bedndLzq1kjyU0.jpg" target="_blank" data-width="1265" data-height="960" ><img src="https://tpucdn.com/img/Q0bedndLzq1kjyU0_thm.jpg" width="171" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295394/amd-zen-4-socket-am5-explained-pcie-lanes-chipsets-connectivity">Read full story</a></div>
Micron Moving to EUV Lithography in Taiwan
Although Micron is a predominantly US company, it also has some fabs in Japan, Singapore, the PRC and Taiwan, many of which became part of Micron after it bought other companies. Based on Micron's Computex presentation, it's getting ready to upgrade one of its three fabs in Taichung with extreme ultraviolet (EUV) lithography technology later this year. This is in preparation for the company to move to what it calls its 1-gamma process node for DRAM. Initially this seems to be a R&D node to help the company prepare for a wider rollout of EUV technology. Micron's current DRAM is based on its 1-alpha node and it's planning to move its 1-beta node into volume production next year, in its Taiwan fabs.<br />
<br />
Micron's current 1-alpha node is based on DUV technology and was introduced last year, with the company claiming it had a 40 percent improvement in memory density over its previous 1Z node. Micron no longer mentions its die size in the commonly used nanometer measurement, but its 1Z node is said to have been around 11 to 13 nm, so it's likely that the 1-beta node will end up below 10 nm, if its 1-alpha node isn't already below 10 nm. Micron's longer term roadmap also includes a 1-delta node, which was meant to be its first EUV product, but this now seems to have been moved forward to its 1-gamma node. It's likely that Micron will be moving its other fabs to EUV in due time as well, but DRAM has so far not benefitted as much from node shrinks compared to most other types of integrated circuits, so it'll be interesting to see what gains EUV might bring.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/v2fMmuoFMQ45bZLy.jpg" target="_blank" data-width="950" data-height="554" ><img src="https://tpucdn.com/img/v2fMmuoFMQ45bZLy_thm.jpg" width="223" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/0BnGTkW62CzgXOJ1.jpg" target="_blank" data-width="1336" data-height="686" ><img src="https://tpucdn.com/img/0BnGTkW62CzgXOJ1_thm.jpg" width="253" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295419/micron-moving-to-euv-lithography-in-taiwan">Read full story</a></div>
After TSMC, Intel May be Edging Closer to Samsung for Collaboration
Intel's revamped IDM 2.0 strategy has seen the company revise its stance in both in-house and outsourced silicon fabrication. While we're already seeing the fruits of <a href="https://www.techpowerup.com/289575/intel-negotiates-3nm-allocation-with-tsmc-even-as-pat-gelsinger-cautions-against-investing-in-taiwan" target="_blank">Intel's collaboration with TSMC</a> (albeit at the relatively slow pace of introduction for Intel's Arc Alchemist graphics), it seems that Intel is willing to go much farther than just TSMC as a source of chips for its product portfolio.<br />
<br />
That's the backdrop to which Intel CEO Pat Gelsinger recently took a trip to South Korea's capital of Seoul. According to the Korea Herald, Gelsinger met several key Samsung executives, including Samsung Electronics Vice Chairman Lee Jae-yong, co-CEO and chip business boss Kyung Kye-hyun, and head of Samsung Mobile Roh Tae-moon. More than enough executive grunt to ignite talks of a deepening collaboration between both companies. While the reporting source doesn't provide any quotes or actionable intel from the meeting, Samsung remains one of the key semiconductor manufacturers alongside Intel itself and TSMC, with a particularly strong portfolio in memory-related technologies.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/fETjK3fXpWxQy8xN.jpg" target="_blank" data-width="1590" data-height="927" ><img src="https://tpucdn.com/img/fETjK3fXpWxQy8xN_thm.jpg" width="223" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295406/after-tsmc-intel-may-be-edging-closer-to-samsung-for-collaboration">Read full story</a></div>
ORNL Frontier Supercomputer Officially Becomes the First Exascale Machine
Supercomputing game has been chasing various barriers over the years. This has included MegaFLOP, GigaFLOP, TeraFLOP, PetaFLOP, and now ExaFLOP computing. Today, we are witnessing for the first time an introduction of an Exascale-level machine contained at Oak Ridge National Laboratory. Called the Frontier, this system is not really new. We have known about its upcoming features for months now. What is new is the fact that it was completed and is successfully running at ORNL's facilities. Based on the HPE Cray EX235a architecture, the system uses 3rd Gen AMD EPYC 64-core processors with a 2 GHz frequency. In total, the system has 8,730,112 cores that work in conjunction with AMD Instinct MI250X GPUs.<br />
<br />
As of today's TOP500 supercomputers list, the system is overtaking Fugaku's spot to become the fastest supercomputer on the planet. Delivering a sustained HPL (High-Performance Linpack) score of 1.102 Exaflop/s, it features a 52.23 GigaFLOPs/watt power efficiency rating. In the HPL-AI metric, dedicated to measuring the system's AI capabilities, the Frontier machine can output 6.86 exaFLOPs at reduced precisions. This alone is, of course, not a capable metric for Exascale machines as AI works with INT8/FP16/FP32 formats, while the official results are measured in FP64 double-precision form. Fugaku, the previous number one, scores about 2 ExaFLOPs in HPL-AI while delivering "only" 442 PetaFlop/s in HPL FP64 benchmarks.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/bkyDUqu8zuisQYOp.jpg" target="_blank" data-width="700" data-height="450" ><img src="https://tpucdn.com/img/bkyDUqu8zuisQYOp_thm.jpg" width="202" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/jzkLFKKIeAlWGHyx.jpg" target="_blank" data-width="700" data-height="450" ><img src="https://tpucdn.com/img/jzkLFKKIeAlWGHyx_thm.jpg" width="202" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/NnnnqwKmRyWvx9fz.jpg" target="_blank" data-width="700" data-height="450" ><img src="https://tpucdn.com/img/NnnnqwKmRyWvx9fz_thm.jpg" width="202" height="130" alt="" /></a></div>
AYANEO Announces Air Plus with AMD Mendocino APU & RDNA2 Graphics
AYANEO have recently announced the Air Plus handheld gaming console featuring the <a href="https://www.techpowerup.com/295146/amd-announces-new-ultrathin-notebook-design-wins-new-mendocino-mobile-processor" target="_blank">new</a> Mendocino processor from AMD with an expected retail price of 289 USD. The Mendocino processor features the same Zen 2 and RDNA 2 cores found in the Steam Deck however the exact configuration and performance figures are currently unknown with rumors suggested that the processor will only include 2 Compute Units. The AYANEO Air Plus can run the Linux-based AYA Neo OS, Windows, or Steam OS and features a 6" 1080p display in addition to a M.2 2280 expansion slot. The console will retail for 289 USD undercutting the Steam Deck by 60 USD while a limited early run of units will be available for 200 USD later this year.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/sP22bAaMZC33p34C.jpg" target="_blank" data-width="1164" data-height="759" ><img src="https://tpucdn.com/img/sP22bAaMZC33p34C_thm.jpg" width="199" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/pmcFnIbddpbs5ddG.jpg" target="_blank" data-width="1419" data-height="679" ><img src="https://tpucdn.com/img/pmcFnIbddpbs5ddG_thm.jpg" width="272" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/AGW9gx5uKEuqdIRm.jpg" target="_blank" data-width="1120" data-height="498" ><img src="https://tpucdn.com/img/AGW9gx5uKEuqdIRm_thm.jpg" width="292" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/sZHcUBgDWWC3vkKe.jpg" target="_blank" data-width="1199" data-height="551" ><img src="https://tpucdn.com/img/sZHcUBgDWWC3vkKe_thm.jpg" width="283" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295391/ayaneo-announces-air-plus-with-amd-mendocino-apu-rdna2-graphics">Read full story</a></div>
(PR) Respawn and Lucasfilm Games Unveil Star Wars Jedi: Survivor
Today at Star Wars Celebration, Respawn Entertainment, Electronic Arts, and Lucasfilm Games unveiled Star Wars Jedi: Survivor, the next chapter of the beloved Star Wars action-adventure series chronicling the journey of Jedi Cal Kestis. Developed by the veteran team at Respawn under the leadership of game director Stig Asmussen, Star WarsJedi: Survivor will expand upon the iconic Star Wars stories, worlds, characters, and thrilling combat first experienced in the series' debut title, Star Wars Jedi: Fallen Order. Star Wars Jedi: Survivor is being built for the current generation of gaming hardware to create a deeper and more expansive Star Wars experience for players worldwide when the game launches in 2023.<br />
<br />
Star Wars Jedi: Survivor picks up five years after the events of Jedi: Fallen Order. Cal must stay one step ahead of the Empire's constant pursuit as he begins to feel the weight of being one of the last remaining Jedi in the galaxy. Accompanied by his trusty companion BD-1, Cal will meet and ally himself with an array of unique and interesting characters on his journey. Jedi: Survivor will expand on the series' dynamic combat in new and innovative ways. In order to survive, Cal must learn new skills and grow his connection with the Force.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/OCYd15wnjNuprFq7.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/OCYd15wnjNuprFq7_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/LosGcktS1yfanw9o.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/LosGcktS1yfanw9o_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/SyXHlY4yXdTovdkD.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/SyXHlY4yXdTovdkD_thm.jpg" width="231" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/8kkTqR7RHvwbxkTT.jpg" target="_blank" data-width="1707" data-height="960" ><img src="https://tpucdn.com/img/8kkTqR7RHvwbxkTT_thm.jpg" width="231" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295389/respawn-and-lucasfilm-games-unveil-star-wars-jedi-survivor">Read full story</a></div>
(PR) GIGABYTE Launches the New Gaming Case—AORUS C500 GLASS
GIGABYTE, the world's leading premium gaming hardware manufacturer, today announced the new mid-tower gaming case - AORUS C500 GLASS is designed for outstanding cooling, it provides optimized airflow design and supports motherboards up to E-ATX. Also, it supports up to 420 mm water cooling system solutions which enables the entire case to achieve extreme cooling and performance. In terms of assembly, AORUS offers friendly and convenient ideas, such as excellent cable management, the swing door front panel, and the drop protection tempered glass panel, etc., all of which add convenience for users during use. In addition, users can download the RGB FUSION 2.0 software to customize the various RGB lighting effects and colors to make the gaming case perfect to perform all AORUS devices and be collected as a marvelous artwork.<br />
<br />
The airflow design of the chassis is one of the factors to affect the internal thermal performance. AORUS C500 GLASS is mainly designed with large-area mesh and vent design on the front and top panels. Increasing the ventilated surface can bring more airflow into the case to achieve better heat dissipation, which allows users to make the system cooler and enjoy a stable performance.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/vs8YIGPiV3RenNOD.jpg" target="_blank" data-width="1200" data-height="630" ><img src="https://tpucdn.com/img/vs8YIGPiV3RenNOD_thm.jpg" width="248" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/bPmbLW2wXTUfHL8g.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/bPmbLW2wXTUfHL8g_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/HIY2YqCsfGPnCIrF.jpg" target="_blank" data-width="1000" data-height="1000" ><img src="https://tpucdn.com/img/HIY2YqCsfGPnCIrF_thm.jpg" width="130" height="130" alt="" /></a> <a href="https://www.techpowerup.com/img/JPDfLgkQsSueH9c5.jpg" target="_blank" data-width="2560" data-height="1021" ><img src="https://tpucdn.com/img/JPDfLgkQsSueH9c5_thm.jpg" width="326" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295384/gigabyte-launches-the-new-gaming-case-aorus-c500-glass">Read full story</a></div>
(PR) Seasonic Launches ARCH Q503 Chassis with Connect Capability, and Glass Panels on Both Sides
The Seasonic ARCH Q503 with the integrated CONNECT power supply is a mid-tower ATX chassis that features a sturdy steel body and tempered glass panels on both sides. The Seasonic ARCH Series creates an interplay and connection between two important pillars or product group integration; the Seasonic CONNECT Module and the Seasonic SYNCRO Q70 Case. Timeless appearance, modern design, and user-friendly functions make this case a logical choice for users, who want convenience, easy assembly, and hassle-free cable management with the Seasonic CONNECT.<br />
<br />
The Seasonic ARCH Q503 with the integrated CONNECT power supply is a mid-tower ATX chassis that features a sturdy steel body and tempered glass panels on both sides. This cutting-edge chassis greatly simplifies system building and cable routing to create an unmatched user experience. The removable glass panels make it easy to install the components while offering a clear view to the system configuration. The Seasonic CONNECT Module is in essence a cable management hub, to which the components are directly connected with generally shorter cables. This new way of power supply integration significantly improves ventilation and the look of the system by reducing cable clutter.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/nq06JixtNeJWaVHK.jpg" target="_blank" data-width="1140" data-height="852" ><img src="https://tpucdn.com/img/nq06JixtNeJWaVHK_thm.jpg" width="174" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295382/seasonic-launches-arch-q503-chassis-with-connect-capability-and-glass-panels-on-both-sides">Read full story</a></div>
(PR) BIOSTAR Socket AM4 Motherboards Get AGESA V2 1.2.0.7 Update
BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today announces the launch of the latest AMD AGESA 1.2.0.7 BIOS firmware update. BIOSTAR's latest firmware rollout targets their AM4-based 500, 400, and 300-series motherboards with the latest AMD AGESA 1.2.0.7 BIOS firmware update. The new BIOS patch comprehensively resolves all the major and minor issues of the AMD AM4 lineup, including the stuttering issue with fTPM on the AMD Ryzen platform. Furthermore, the BIOS update also adds full compatibility to the latest Ryzen 2022 releases, including the brand new Ryzen 7 5800X3D CPU. BIOSTAR's B550/A520/B450/A320 series motherboards currently get full AGESA 1.2.0.7 BIOS update, and BIOSTAR plans to further extend the BIOS support to their X570/X470/X370/B350 series motherboards soon.<div class="imgcontainer"><a href="https://www.techpowerup.com/img/Pi4y8DGD9DAf25ej.jpg" target="_blank" data-width="1200" data-height="600" ><img src="https://tpucdn.com/img/Pi4y8DGD9DAf25ej_thm.jpg" width="260" height="130" alt="" /></a> </div><div class="readmore"><a href="https://www.techpowerup.com/295381/biostar-socket-am4-motherboards-get-agesa-v2-1-2-0-7-update">Read full story</a></div>
