r4367 | Admin | 2011-01-07 23:37:27 +0100 (Fri, 07 Jan 2011) | 1 line
Licence file for GPL v3 added and readme updated. According to dukat, mpcs was released under GPL. As OSCam is derived from mpcs, OSCam code is released under GPL, too.
r4366 | schlocke | 2011-01-07 23:20:54 +0100 (Fri, 07 Jan 2011) | 3 lines
loadbalancer: new parameter lb_retrylimit, reopen reader only if
responsetime > lb_retrylimit
Oscam-1.00-svn4371
r4371 | alno | 2011-01-08 08:47:20 +0100 (Sat, 08 Jan 2011) | 1 line
Config: correct some defaults
r4370 | alno | 2011-01-08 08:39:40 +0100 (Sat, 08 Jan 2011) | 1 line
WebIf: Add parameter Retry Limit to loadbalancer settings
r4369 | alno | 2011-01-08 08:31:16 +0100 (Sat, 08 Jan 2011) | 1 line
WebIf: simplify some casting of IP's
r4368 | landlord | 2011-01-08 00:30:56 +0100 (Sat, 08 Jan 2011) | 1 line
Removed old GPL.
r4373 | alno | 2011-01-08 09:41:58 +0100 (Sat, 08 Jan 2011) | 1 line
WebIf: fix cosmetic issue with reader stats subheadline 'not found'
r4372 | alno | 2011-01-08 09:37:22 +0100 (Sat, 08 Jan 2011) | 1 line
Loadbalancer: Retry limit default 2200ms seems a bit high set to 800
r4376 | landlord | 2011-01-08 14:26:57 +0100 (Sat, 08 Jan 2011) | 1 line
New default for 'lb_retrylimit'.
r4375 | landlord | 2011-01-08 14:25:24 +0100 (Sat, 08 Jan 2011) | 1 line
Documentation for new parameter 'lb_retrylimit'.
r4374 | landlord | 2011-01-08 14:19:26 +0100 (Sat, 08 Jan 2011) | 1 line
Some README updates.
Oscam-1.00-svn4377
r4377 | lattjo | 2011-01-08 14:58:12 +0100 (Sat, 08 Jan 2011) | 1 line
Fixes for smartreader high CPU load
r4378 | landlord | 2011-01-08 15:44:37 +0100 (Sat, 08 Jan 2011) | 1 line
Update documentation for 'lb_retrylimit'.
Oscam-1.00-svn4379
r4379 | Admin | 2011-01-08 19:07:01 +0100 (Sat, 08 Jan 2011) | 1 line
WebIf: If hideclients_to is set, users with ECMs within hideclients_to seconds will be highlighted and a sum shown on standard page (not on "hide idle" page). Thanks to leloup for this suggestion.
Oscam-1.00-svn4381
r4381 | Admin | 2011-01-08 21:05:46 +0100 (Sat, 08 Jan 2011) | 1 line
WebIf: Fix oscam crash when user with name longer than 64 trying to be added. Use garbage collector for account refresh.
r4380 | Admin | 2011-01-08 19:34:36 +0100 (Sat, 08 Jan 2011) | 1 line
Small fix for last commit
r4384 | Admin | 2011-01-09 05:28:48 +0100 (Sun, 09 Jan 2011) | 1 line
Fix small bug from last commit: malloc=>realloc
r4383 | Admin | 2011-01-09 04:18:40 +0100 (Sun, 09 Jan 2011) | 1 line
Add sulge's patch from [Only registered and activated users can see links. Click Here To Register...] to fix compilation warning on module-serial for PPC plattforms.
Oscam-1.00-svn4385
r4385 | alno | 2011-01-09 12:07:22 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: partially revert #4369
Oscam-1.00-svn4386
r4386 | alno | 2011-01-09 15:12:27 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: restart cardreader in reader view. Could be have sideeffects on different readertypes
r4387 | alno | 2011-01-09 15:43:43 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: fix mirored IP in monitor config
Oscam-1.00-svn4390
r4390 | alno | 2011-01-09 18:06:29 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: remove complete debug selector code and template if binary is build without debug.
r4389 | alno | 2011-01-09 17:31:57 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: method for killing readerthread if reader disabled from reader overview (THX Schlocke for hint)
r4388 | Admin | 2011-01-09 16:27:26 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: Sending errors wasn't previously completely possible as the headers were already sent before. Fix bug in cccam entitlements display. Do some cleanup.
Oscam-1.00-svn4392
r4392 | Admin | 2011-01-09 20:20:00 +0100 (Sun, 09 Jan 2011) | 1 line
WebIf: Fix: Info page wasn't displayed anymore on shutdown/restart because of missing header output.
r4391 | Admin | 2011-01-09 20:12:19 +0100 (Sun, 09 Jan 2011) | 1 line
Fix #1458
r4393 | Sulge | 2011-01-09 21:09:50 +0100 (Sun, 09 Jan 2011) | 1 line
Fix #1451
