Re: Receptii Terestre-Pareri Vechi Si Actuale
The romanian citizen say in european clusters
sesions sporadic-e starts in other day with low low signals .. Yesterday captured this fenomen .
my antnena is a 56mhz dipole closed with 1 reflector , and 1 amplifier with bfw16a calculed in 50-80mhz with capacitors and inductors
73's
[Only registered and activated users can see links. Click Here To Register...] btv de la dorbici canal 28
[Only registered and activated users can see links. Click Here To Register...] propagare cu buzau
[Only registered and activated users can see links. Click Here To Register...] pro tv novaci
iata si galerie foto noua
[Only registered and activated users can see links. Click Here To Register...] sa zicem tvr2 cobadin 23
[Only registered and activated users can see links. Click Here To Register...] party tv
[Only registered and activated users can see links. Click Here To Register...] tvr 1 cozia perfect si cu nova de gat
[Only registered and activated users can see links. Click Here To Register...] tvr1 zoia patrea 2
[Only registered and activated users can see links. Click Here To Register...] tvr 2 cozia p1
[Only registered and activated users can see links. Click Here To Register...] tvr 2 cozia p2
[Only registered and activated users can see links. Click Here To Register...] pro tv novaci ...
propagarea e in urcare daca cu 6dB amplificare + antena cu 2 elemente rezulta receptie din zona de sub elevatie normal la peste 200km inseamna ca a inceput primavara .
propagation is UP in south romania , my antena is with 2 elements and 2 element , on my zone with sub elevaton receeived signals tv of the 200+km , on this moment afferin .. it's spring time !!
INCREDIBIL , imposibil de realizat , dupa o portie buna de propagare sa scada propagarea in UHF si in 3M de sa ajung sa scriu acest mesaj ca in prag de iarna cu zapada de jumate de metru langa casa .
UN fenomen ce este tipic ierni , producanduse cand frigul si gerul si norii blocheaza stratul D in totalitate si mai ales uneori de la zapada abundenta ce face impracticabila urcarea semnaleor propagarii in strat D , in momentul producerii se produc zone MOARTE fara propagare adica in cazurile scris in carti adica propagarea =0% , 0dB fata de normal , adica nimic .. cazul unui emitator pus in zona fara obscole acopera exact cat au calculat inginerii adica daca 1w scris in carte = acopera decent 800M , la km acesta se va auzi foarte prost chiar execrabil deoarece cazul fundamemntal "0dB" il traieste statia radio . In acest moment cand va scriu aceasta scurta povestioara va dau exemple concrete :
in bucuresti depolarizarea a lovit de 2 ori pana acu grosolan , in decembrie 2007 ian 2008 , si in ianuarie 2009 , fenomenul acesta in 2007 a cazut fix desupra bucurestiului , eu stand sub elevattia orasului am simtit exact cu antena de pe casa diferenta scazand semnalul exagerat de la ACTV FM la 38dB fatza de 54db , si 102.2 de pe costila la 34dV fatza de 67dB cat e normal , si incheiand cu 103.0 care de lka 60 ajunsese la 37dB ..
In anul 2008 acesta sa plimbat in spre pliesti spre ruse si spre calarasi , identic a fost in 2009 cand crapase propagarea cu oltenita si nitel din ruse , maia les cu calarasiul si dobrogea sud mergea ... etc
DEPOLARIZAREA - fenomen cunoscut sub denumirea de scaderea mesei de protoni pe centimetrul patrat in decurs de 30min , si acesta intinzadu-se pe o portine de cuprinsa intre 30km si maixm 50km .
se poate clasifica ca NEGURA de pe cer , varcolacul care maninca din tropo sau BERUL ALUNGATOR DE PROPAGARE , sau mai bine zis PROPAGARE CU DINTI SAU INGHETATA .
NOI ROMANIA mai ales bulgaria putem avea asemenea fenomene si in toamna .
ACEST FENOMEN ESTE INCREDBIL deoarece nu sa mai intamplat pana acum .
22:40
OVERLOAD TEST , si rceptia DX in zona celo 7kw par de la 3 gorile bananiere .
luati si va bucurati
[Only registered and activated users can see links. Click Here To Register...] greek radio
[Only registered and activated users can see links. Click Here To Register...] greek radio and oltenia 105.0
[Only registered and activated users can see links. Click Here To Register...] vacareni and ukr radio !
[Only registered and activated users can see links. Click Here To Register...] mixing tvr + bulgaria
[Only registered and activated users can see links. Click Here To Register...] prima receptie btv in fata instabilitati
[Only registered and activated users can see links. Click Here To Register...] nova tv luata ca local o perioada mica de timp 2Min
[Only registered and activated users can see links. Click Here To Register...] instabilitate tipica ch27
[Only registered and activated users can see links. Click Here To Register...] power tropo in a morning near 3 local 7kw transmitters
the clicks is from the antena transmitters , problem is when start clicks add noise or stop reception from the seconds a low level signals tropo!
FULL RANGE TROPO IN ROMANIA .... and receptions near 7kw 3 transmitters
and my dedication from RVIC ... [Only registered and activated users can see links. Click Here To Register...] .. signal favorite !!!
receptie extrema , slab pe UIF .. moldova 1 .. aprox 378km :gathering:
SUPER SUPER SUPER :cheers:
NOVA TV - ziua 1
ziua 2
ziua 3
acu alea cu antenele
si iata si cu btv-u
sau
sau
si in aceeasi dimineata pe 24
si recordul de 1 ora continuu ch27 luat ca local a doua zi
in the 13'st of april .. NIGHT TURK IN ROMANIA IN FM .. TV DX
[Only registered and activated users can see links. Click Here To Register...] btv network partea 1
[Only registered and activated users can see links. Click Here To Register...] btv network p2
[Only registered and activated users can see links. Click Here To Register...] btv burgas color
[Only registered and activated users can see links. Click Here To Register...] nova de la silistra ch50
[Only registered and activated users can see links. Click Here To Register...] semnal turk neidentificat
from international DX clusters area dxfmerurope UK say:
2 DX-ers from romania receive simultanous in night 13 april , night tropo of the turk signal bulgarian tv ch26 burgas in cityes Bucuresti and Buzau .
zvartoshu reception :
and
paco6667 reception :
it's a good tv dx from 220km and 268km in UHF
73's
[Only registered and activated users can see links. Click Here To Register...] when start turk propagation .. test maxim reception indoor with directive antena [Only registered and activated users can see links. Click Here To Register...]
