daca dai un search ai gasi un raspuns afirmativ
Daca tot facem studiu comparativ am sintetizat caracteristicile celor trei aparate
atat cele raportate de cpuinfo cat si pdf-urile producatorilor.
IPbox si Kathrein au procesoare ARM produse de STMicroelectronics
din familia STI74xx iar DM800 are Procesor MIPS produs de Broadcom BCM7401.
Am subliniat cu rosu puterea de calcul si cu albastru frecventa de lucru a procesoarelor.
Veti observa ca nu e mare diferenta la acest capitol.
IPBox
[Only registered and activated users can see links. Click Here To Register...] Procesor STI7109 ARM
Kathrein UFS 910Code:CubeRevo:/# more /proc/cpuinfo
machine : DGStation cuberevo board
processor : 0
cpu family : sh4
cpu type : STb710x
cpu flags : fpu
cache type : split (harvard)
icache size : 16KiB (2-way)
dcache size : 32KiB (2-way)
bogomips : 264.60
pll0_clk : 531.00MHz
pll1_clk : 399.93MHz
sh4_clk : 265.50MHz
sh4_ic_clk : 132.75MHz
module_clk : 66.37MHz
slim_clk : 265.50MHz
comms_clk : 99.98MHz
tmu0_clk : 16.59MHz
tmu1_clk : 16.59MHz
CubeRevo:/# more /proc/meminfo
MemTotal: 68968 kB
MemFree: 11204 kB
Buffers: 8 kB
Cached: 26200 kB
SwapCached: 0 kB
Active: 23316 kB
Inactive: 22208 kB
[Only registered and activated users can see links. Click Here To Register...]Procesor STI7100 ARM
DM800 HDCode:ufs910:/# more /proc/cpuinfo
machine : STb7100 Reference board
processor : 0
cpu family : sh4
cpu type : STb710x
cpu flags : fpu
bogomips : 264.60
pll1_clk : 399.00MHz
sh4_clk : 265.50MHz
comms_clk : 99.75MHz
tmu0_clk : 16.59MHz
tmu1_clk : 16.59MHz
ufs910:/# more /proc/meminfo
MemTotal: 46864 kB
MemFree: 4836 kB
Buffers: 448 kB
Cached: 9720 kB
SwapCached: 4 kB
Active: 28644 kB
Inactive: 1812 kB
[Only registered and activated users can see links. Click Here To Register...] Procesor BCM7401 MIPS
La RAM DM800 sta mai bine aparent, in realitate acele resurse sunt folosite ineficient datorita implementarii proaste.Code:dm800:~# more /proc/cpuinfo
system type : BCM97xxx Settop Platform
processor : 0
cpu model : Brcm7401 V0.0
cpu MHz : 295.93
BogoMIPS : 295.93 ( udelay_val : 147968 HZ = 1000 )
wait instruction : yes
microsecond timers : yes
tlb_entries : 32
extra interrupt vector : yes
hardware watchpoint : no
ASEs implemented :
VCED exceptions : not available
VCEI exceptions : not available
RAC setting : I/D-RAC enabled
unaligned access : 2040106
dm800:/proc# cat meminfo
MemTotal: 124904 kB
MemFree: 39532 kB
Buffers: 0 kB
Cached: 37176 kB
SwapCached: 0 kB
Active: 46116 kB
Inactive: 24608 kB
Daca luam secventa de boot cu imagine e2 de flash:
- IPbox 60 sec
- Kathrein 85 sec
- DM 800 peste 150 sec
Am testat kathy un an, DM800 vreo 2 luni si IPbox in ultima luna.
Voi reveni cu studii comparative la detaliu pe fiecare din aparate.
Un post in care sa cuprind tot ar fi greu de scris si mai greu de parcurs.
Enigma 2 nu e ceva perfect, are multe carente, si e mare "mancatoare de resurse" fiind scrisa in python (un fel de java).
Avantajul vine din portabilitatea aplicatiilor python si mai ales a surselor publice.
Sunt multi fani DM la noi, stiu foarte bine sa apese tasta albastra si ceva copy paste in cfg-uri,
si evident sa te apostrofeze ca nu esti in gasca lor.
Astept sa lucreze mai mult si sa comenteze mai putin si poate intr-o zi sa faca
si o imagine romaneassca la receptorul pe care ei il lauda cu atata patima.
Spre bucuria unora ca mine a celor care nu suntem fani pana la moarte DM exista [Only registered and activated users can see links. Click Here To Register...]
unde ne putem exprima civilizat si cu bun simt.
un raspuns scurt si la obiect ! si mai ales perfect documentat !
Dar de Qbox HD nu se poate compara cu nici unu?
IPBox-ul (din semnatura) este de vreo 3 zile primul meu receptor DVB-S cu linux si primul receptor HD. De fapt per total e al doilea receptor, primul fiind conserva digi din semnatura. Nu votez pt ca nu am experienta cu celelalte doua receptoare candidate, dar sunt foarte incantat de receptorul asta HD. Si inca nici nu am apucat sa-i pun toate capacitatile in valoare (deh.. paradoxul "cand ajungi sa iti permiti multe lucruri foarte dorite, deja esti atat de ocupat incat nu poti sa te bucuri de ele pe atat pe cat ti-ai dori de mult").
La ipbox si kathy e valabil lucrul asta doar daca esti conectat la cccam. Cu mbox functioneaza independent. Poate fi atat server cat si client fara probleme.*
Odata cu lansarea qboxlui hd, vor aparea si mai multe facilitati pentru primele doua tipuri de receptoare
depinde de cantitate si volum!Quote:
...avem de carat nisip . ne luam un autoturism cu remorca sau ne luam o aututilitare ?
dm800 a avut multe probleme si va avea in continuare!
