Re: Nabilosat Enigma2 Black Hole - DM8000 v0.11
New:CVS Virtual Keyboard: introduced by the CVS, this new feature offers an alternative solution to enter data where required. Nabilosat Team chose to use the Virtual Keyboard for the CCcam Setup, Inadyn Setup, Cron Manager custom command
NewSkin Army Ghost HD: awesome HD skin with large size fonts and panels
New:
New Boot logo by ^^MaXiMoII^^
New
MyTube plugin: this plugin has been included by default.
Enigma2 CVS date
29 June 2009 2.6 experimental
Drivers date
25 June 2009
Second Stage #73-pr0
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button 1x Green + 1x Red = CCcam Info
Button Red = Start Record
Button Yellow = Time Shift
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Setup
Black Hole Cron Manager
Black Hole EPG Panel
OSD Settings
Devices Manager
Kernel Modules Manager
LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
Select EMU by Channel
2) Green Panel
CCcam Info
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
Scripts
Many thanks to the Beta Testers Team
Credits
E2 Sky Epg loader integration by MaxZ4.
Army for the new Ghost HD skin.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not supported!
WARNING.
Nabilosat Team highly reccomends to install this image to flash. It will be perform at its best, and you will fully enjoy all the features. Else, if you install it to multiboot, you must install the Nabilosat Pure Flash DM 8000 dated 01 July 2009..
download :
[Only registered and activated users can see links. Click Here To Register...] | 52181 KB
Milo image Dm8000 17/07/09
New in this release:
* Just updated Enigma2 and drivers
Features:
* LCD screen: Blinking R when recording, changed layout
* EPG Search works for non-UTF8 encodings like Freesat
* NETcaster that does not crash
* Standard Dutch favourites list instead of German
* Rearranged settings menu
* Upgraded tuxtxt which enables teletext cache
* Plugin download screen gets server list no more than once per hour
* Symlinks in /var to satisfy some softcams
* Driver updates for DM8000
* Experimental switch to enable a "home page" service
* MovieList enhancements: Auto-tagging, playback state icons (beta), directory selection
* Picons can be downloaded from feed to CF, USB or HDD
* Dutch translations
* Downloadable skins
* Mount manager
* DVD player
* Mediaplayer
* Auto-recovers CCCam.cfg, .ssh dir and dropbear_rsa_key from /hdd/backup
* Enigma2 (and other components) from 2009-07-17
* CCcam 2.1.1
* Freesat EPG
* Mediahighway EPG
* EPG import patch
* NZBGet in feed (commandline, use "ipkg install nzbget")
* ctorrent in feed (commandline)
* djmount in feed (commandline)
Newnigma2 release v2.6 -- DM8000
Das Newnigma2-Team präsentiert:
Newnigma2 V2.6
Grundlagen:
* Enigma2 2.6 Stand 20.7.2009
* Enigma2 Plugins 2.6 Stand 20.7.2009
* Newnigma2 Plugins Stand 20.7.2009
* Standard EMU: CCcam 2.1.2
DM 8000 HD PVR
* dm8000 Treiber: 20.7.2009
* dm8000 secondstage: 73
Neuigkeiten und Veränderungen:
* curlftpfs 0.9.1 hinzugefugt
* openvpn 2.0.9 hinzugefugt
* nzbget 0.6.0 hinzugefugt
* busybox ipv6 Support hinzugefugt
* uberarbeitete cron Installroutine/tmpfs
* projectx - neue Version
* libdvdcss - neuer Source
* neue Version vobcopy 1.2.0
* neue Version libreaddvd 0.9.7
* udev fix Regeln, udevstart
* DM8000: sysvinit, Fix serieller Port
* DM500plus: kleine Fernbedienung wird nun unterstutzt
* libdreamdvd.bb: bessere HW-scaling Support
* dreambox-dvb-tools: Update auf V1.6/Fix showiframe return code
* neue Settings fur DVB-S1 & DVB-S2
* dm8000: einige mkv Fixes
newnigma2-Plugins
* NEUER SKIN: brushed alu
* NEUER SKIN: DMM HD
* dreamtv-HD skin Fx
* kerni-HD skin Fix
* CF Installer Update
* DeviceManager Update
* Init-scripts Update
* default timer Option bei remote-timer hinzugefugt
* neutrino-half Belegung bei Play Video gefixt
* Spanische Sprache hinzugefugt
* Onlineinstaller: Man kann nun Picons auf allen USB Geräten installieren ohne auf /media/foo zu verlinken
* Onlineinstaller: einige Fixes fur Stabilität und Sicherheit
* Menu: Picons-Pfad einstellbar fur jedes Gerät
* Devicemanager: es konnen nun USB-Geräte mit mehr als 1 Partition geloscht und neu installiert werden
* Devicemanager: Swap-Große wird begrenzt, damit die Device-Große nicht uberschritten wird
* ExtendedInfoBar: Fix Bluescreens bei einigen wenigen Ausnahmefällen
* Webradio: Anzeige Songtexte
* erweiterte Image Info
* Update boxspezifische satellites.xml
* Neue newnigma2 Spinner
* Fix Übersetzungsfehler
* vsftpd: um RAM zu sparen, wird keine /tmp/foo logfile mehr geschrieben
* Nur gemountete Geräte sind fur Picon-Installation verfugbar
* Fix HDDinfo fur udev Support
* CFinstaller Übersetzungsfehler gefixt
* ConfigSaver: Picon Installationspfand gefixt
* ConfigSaver ist nur auf Deutsch und Englisch ubersetzt verfugbar
* Keymanager: einige URL's ersetzt mit funktionsfähigen
* viele Logos upgedated und online verfugbar
ACHTUNG:
Aufgrund Änderungen beim Configsaver ist ein fehlerfreies Online Update nicht moglich, bitte Komplett-Images flashen, da
KEIN SUPPORT FÜR UPDATES!
[Only registered and activated users can see links. Click Here To Register...]=
LT-Fifth.image dm8000 26.07.2009
Sunday, 26 July 2009
LT Fifth - Another Edition
Yes, we still been busy and not finished LT6 image but DMM has been productive and developed lots of things so we thought that we at least could do a little upgrade on LT5 for all of you users.
For LT part we have only followed some changes from Enigma2 into our LT code and restored our default settings which we managed to remove somehow...
Otherwise this image has followed all changes in Enigma2 and OE done by DMM.
Enigma2 20090724
Drivers
- dm7025 20090717
- dm800 20090720
- dm8000 20090720
secondstage
- dm7025 61
- dm800 73
- dm8000 73
Download 50 MB
Nabilosat Enigma2 Black Hole - DM8000 v0.12
Nabilosat Enigma2 Black Hole - DM8000 v0.12http://rapidshare.com/files/295178557/NabiloBlackHole_DM8000_012.zip
LT6 The Sixth Sense Dm 8000
yes, we are still alive
We have nearly rewritten the complete LT Image, so it took us some time. Our
priorities has always been our real life and this is also one reason why it
took some time for LT6.
The new image is not dictatorial any more. We have splitted all the LT
plugins from the base image... so YOU can now use this and that LT plugin or
not.
We have a new built in skin for the HD boxes named LT6.HD. We hope, you will
like it like we do.
As a note on the skin, we have left rather much PiG in it for dm800 box and
this might make the skin feel little slow. For future upgrades the dm800
skin might use less PiG to speed it up. For you who likes PiG and do not
care about speed you can change the skin to full PiG.
As you know us, we have again a few new plugins for you.
The first new plugin is named LT Install Wizard. It will be executed the
first time you boot our image. You can remove or add any LT plugin inside
it. After the first boot it will not be shown again on bootup, but you can
reach it in the system menu again.
We have also a new plugin that allows you to switch the PiP channel without
a big patch to DMM's code that some other images are using. After the PiP is
enabled you can toggle between the main window and PiP with the following
buttons:
-New remote control (DM8000): SHIFT+PLAY/PAUSE
-old remote control: SHIFT+TV
Some user didn't find their location in our Weatherman plugin, so we created
a new one: Weather-Channel with some new options and an other look.
We have changed a lot of stuff in many plugins, so we will try to pick only
the important things for the release text:
-Remove LT center screen functions and use DMM's code instead
-Made SNR configurable in the skin (percent or dB)
-New weather icons and new look for Weatherman plugin
-Added possibility to show infos about next event in the channelselection
-Move LT-Configs to dmm-config menu (menu => configuration => system)
-Added reload autofs function to autofs editor
-Made info-button also configurable (not only long-holding info-button)
-Added 'Play CD/DVD' entry to main-menu
-Remove entry DVD Player from main-menu
-Added FileScanner for Audio-CD's
-After starting 'Play CD/DVD' check CD/DVD. Open DVD-Player if a DVD, open
MC-Audio-Player if an Audio-CD and open MC-DVD-Browser if nothing of them
(for DATA-CD's with pics, mp3 or movies)
-InfoBarPositioner: added posibility to move the MoviePlayer InfoBar
-Allow skin to show following things in the ChannelSelection screen:
ServiceName, Orbital, ServiceNameOrbital
-Allow to edit ConfigText configs with the VirtualKeyboard
-Bootup Music plugin uses now gstreamer instead of mpg321
-Many other changes and fixes
Changes MediaCenter:
-Show/play iso files using the DVD-Player plugin
-Calculate some sizes in the media-list
-Added possibility to SHOUTcast to navigate with the number buttons to the
genres (like the channelselection)
-Added some podcast stations. Thx to Zeranovsky
-Show mp4 in media-list and new config: transcode mp4 (yes/no)
Changes QuickMenu:
-Add plugin
-Add script
-Remove entry
-Restore defaults
-Select pre-configured setup
-Save current menu
-Toggle script show type (hidden or shown)
-Add plugin to extensions-menu
-Remove plugin from extensions-menu (this one needs an e2 restart)
-Added move entry function
New in LTEpgGrabber
-AutoGrab - grab from bouquets instead of configs. Select preferred grabbers
and languages and AutoGrab will do the rest.
-The grabber now autodetects when daylight-savings time (DST) changes and
clears cache (no need to edit configs anymore)
-new timezone rules (Use GMT-zone where you are grabbing from...)
-Encoding support for all ISO-8859 standards and utf-8 (first-third byte of
all descriptors text fields)
-Comply with ETSI EN 300 468 v1.9.1 Annex A.2 regarding encoding
-Added support for one-based index (OD) for grabbers
-added possibility to provide "shortInfo" from external grabbers
-support for shortInfo (experimental) in: dagenstv_no and drdk
-new format for grabber-configs
Changes in LTEpgGrabber
-Insert the appropriate language-code in descriptors (not always "swe")
-added execution-time in print-outs and logs
-fixed bug in almost all grabbers were zero-sized file was written in /tmp
and not deleted
-removed init 4 & 3 from grabber-scripts (uses web-if instead)
-ExternalEpg-plugin now uses eEPGCache.load() instead of TryQuitMainloop
(much faster )
-renamed "tvguide.co.uk.xml" to "uk_tvguide.xml"
-renamed "radiotimes.com.xml" to uk_radiotimes.xml
new grabbers:
-xmltv_bleb
-html_dagenstv_no
-html_tvplaneten
new configs:
-nordic_mspc.xml
-nordic_dagenstv_no.xml
-nordic_tvplaneten.xml
-it_ambrosa.xml
New in LTEpgGrab plugin
-Option to save log-file to CF/USB
-Option to grab every (n) days (updates crontab)
-Option to use AutoGrab
-Blue button:
Clear Cache
Edit AutoGrab config
Create Grabber config
you can download the image at home board [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...]
we would like to express our thanks to ghost, tmbinc, and acid_burn
and also all the beta testers for their hard work
We hope, you will enjoy the new LT6 The Sixth Sense images and we wish you a happy new year.
boxman-image-dm8000-15.01.10
ein neues, aktuelles OE-Image von heute Nachmittag fur die 8000er:
Treiber vom 04.01.2010
SecondStage-Version: 76
Frontprozessor-Version: 5
satellites.xml - enigma² by Reinh@rd vom 13.01.2010
- with WebIF: Ver. 1.6rc3
Gracias a boxman
Dream Elite BH 1,2 OE1.6 DM8000 Multiboot
Dies ist ein Bild fur DM8000hd mit neuen OE 1.6 und neuer Kernel 2.6.18-7.3
Dieses Bild ist sehr schnell, da neue Treiber und Kernel arbeitet in SMP (2. CPU-Kern)
Spezifikationen:
Oe-Version: 1.6
Kernel-Version: 2.6.18-7.3
Dreambox secondstageloader: # 76
Dreambox DVB-Treiber: 20100324
Enigma2 CVS: Experimentelle 20. März 2010
MeoBoot Version: 0.96xDm8000HD nur
Bootlogos: von Army
Neu: Device Panel mit Geräten Mapping
Behoben: EPG-Suche (nicht mehr mit VirtualKeyboard).
Behoben: NFS-Server (Auto-Neustart)
Meoboot: Diese Version von Meoboot kann auch auf USB, CF, SD und auf der Festplatte installiert werden kann.
Skin: Army Acqua HD awesome HD Haut mit Großformat-Schriftarten und Panels
Warnung:Alte Plugins fur OE 1.5 kann nicht in œ 1,6 arbeiten, mussen Sie bitten, Autoren zu aktualisieren Plugin. Dies ist kein Image-Problem. Nicht melden Sie HIER fur Plugins. WIR SIND NICHT PLUGINS AUTOREN
Warning2: DIESES Bild haben den neuen Kernel und KANN NICHT IN MultiBoot installiert werden. THIS IMAGE mussen im Flash installiert BE
Warning3: After Image INSTALLATION GOTO DEVICES PANEL und MAP Ihrer Geräte. REMEMBER TO MEOBOOT erst, nachdem Sie Ihre Geräte MAPPED INSTALL.
Warnig4: Sobald Sie MEOBOOT INSTALLED NICHT BEWEGEN Gerät, bei dem MEOBOOT installiert ist. (Wie zum Beispiel USB-IF MEOBOOT ON installiert ist NICHT ReMap Das Gerät von MEOBOOT ON USB2)
Warning5: Sie konnen in MultiBoot mit diesem Bild INSTALL Nur Bilder OE 1.6 mit dem neuen Kernel.
NEU NEU NEU: NEW Bedienfeld MIT Mountpunkte fur die Device-Mapping
Kurzanleitung
1.Map/mount Device (roter Knopf)
(Beispiel1: fur Multiboot als / media / usb)
(Beispiel2: wie hdd / media / hdd)
2.Format Device (gelbe Taste)
3.Map/Mount Device nach Format (roter Knopf)
Nach jedem Schritt
Wir brauchen image starten
Dieses Bild ist eine endgultige Black Hole Serie, komplett umgeschrieben und uberarbeitet, um maximale Stabilität und Performance haben.
Wir erinnern uns an das schwarze Loch Serie geben die besten EPG-System zur Verfugung zu haben:
- Integrierte Openepg fur Sky-it Sky Sky-uk-Au
- Aktuelle CVS Enigma2 EPG-Funktionen
- Neue externe epg.dat System.
Daher kann jedes Board oder Community erstellen seinen Lieblingsplatz EPG-Daten-Dateien und laden Sie sie auf einen Webspace. Mitglieder der Community konnen dann laden Sie es von diesem Server.
Dieses Feature bietet zusätzliche Vorteile, wie:
EPG erhohten Download-Geschwindigkeit
EPG von jedem Kanal Download
EPG geplante Download auch im Standby-Modus
User gesetzt EPG-Anbieter hinzufugen / entfernen
Warnung: Dieses Bild wird der neue Kernel 2.6.18-7.3. Aus diesem Grund konnen mussen in MultiBoot INSTALL nur neueste Dateien basierend auf OE 1.6 mit neuen Kernel.
Main Funktionstasten
Button 1xOK = Light Skin Info
Button Blue Dream = Elite Blue Panel
Button 1x blau + 1x rot = Dream Elite Epg Panel
Button 1x blau + 1x Gelb = New System Monitor Panel
Button Green Dream = Elite Green Panel
Button Green-Long-Push = ROT
Button 1x Green + 1x Rot = CCcam Info
Button Gelb = Time Shift
Addons
Dedicated Server Addons
Download und Installation zusätzlicher Pakete aus Dream Elite-Server
Infobar / OSD
SNR Signal, BER
Infobar Picons
LCD / OLED Picons
Erweiterte Informationen WWU
Dream Elite Panels Features
1) Blue Panel
Setup
OSD-Einstellungen
Geräte-Manager
Kernel-Module-Manager
Fast Plugin-Einstellungen
Inadyn Einstellungen
Swap File Settings
Hard Disk Setup
Hola Mount Black Wizard
OpenVPN Panel
Samba / CIFS-Panel
NFS Server Panel
Telnet Panel
FTP-Panel
CCcam Info
Info Service
Enigma2 Settings
Über
Speicher
Raum
CPU
Prozess
AutoCam
Wählen WWU Channel
2) Green Panel
CCcam Info
Manual Install Del Pakete
Manual Install IPK Pakete
Dream Elite Statistik
Scripts
Vielen Dank an die Betatester Team.
Vielen Dank an Rytec fur alle EPG-Servern, die vorkompilierte Epg.dat fur Dream Elite Image (add skyIta und SkyDe).
Credits
Vielen Dank an Rytec fur externe EPG
E2 Sky Epg loader Integration durch MaxZ4.
Vielen Dank an lukkino (VDR-Italia) fur OpenTV Quellcode.
Vielen Dank an Reinh @ fur die Satellites.xml Datei rd.
Vielen Dank an Seddi fur Grab Update
ACHTUNG!
THIS IMAGE mussen in FLASH installiert werden.
Dieses Bild kann nicht IN ARBEIT MultiBoot mit unterschiedlichen Bildern in Flash. DREAM TEAM ELITE nicht unterstutzen werden Bilder nicht in Flash installiert.
Bekannte Fehler:
HDD Temperature funktioniert nicht in OE 1.6 und das Ergebnis ist unberechenbar
Ecm mal nicht in DMM-Treiber behoben .... Warten auf DMM fix
Backups oder sonstige modifizierten Images sind nicht unterstutzt!
Diese Bilder enthält keinerlei Keys oder Softcams.
The Gemini2 Project 5.0 DM8000
Gemini2 v5.0
Enigma vom 29.04.2010
Die meisten Funktionen sind im Gemini-Wiki nachzulesen.
Gemini-Wiki
Funktion Buttons:
* BLAU - Blue Panel (BP)
* lang BLAU - Bild in Bild (DM7025, DM8000)
* 2x BLAU - BP -> Gemini Extras
* BLAU ROT - Datei-Manager
* ROT - Aufnahme (nicht fur die DM8000)
* GRÜN - Quickbutton / Subservices
* GELB - Timeshift (nicht fur die DM8000)
Extras:
* Addon und Plugin Server
* Cryptinfos der Sender oder Cams, Zuordnung der Sender zu einzelnen Cam's
* Manager um viele Daemons / Server zu verwalten (BP->Dienste/Daemons)
* optische Verbesserungen wie HD-Skin, zusätzliche Icons oder Anpassungen der Senderliste
* Manager zum Formatieren, Einrichten oder Einbinden von Geräten (BP->Geräte-Manager)
* zusätzliche EPG-Funktionen, wie Autosave, Refresh oder Zuschalten verschiedener EPG-Formate
* eigene Addons z.B. Dreamnetcast, Jukebox, Kalender, eMail oder eTorrent um nur Einige zu nennen
* Quickbutton, um die Funktion der grunen Taste per Menu zu bestimmen
* ausfuhrliche Infos uber deine Dreambox (Menu->Informationen)
* Datei-Manager, handelt alle moglichen Formate, egal ob nun Bild-, Ton-, Filmmaterial, Playlisten, Torrents, Scripte oder DVDs (BP->Datei-Manager)
* Komplettes Handling von Festplatten, DVD-Laufwerken, USB-Sticks auf "udev" umgestellt (System kummert sich selbstständig um das Einbinden solcher Medien)
Viele weitere Funktionen konnen im IHAD-Board oder unserem Wiki nachgelesen werden.
Neu:
* Anpassungen fur 500HD
* Wechsel auf OE1.6, neue Kernel fur die Boxen
* FTP-Mount - bindet FTP-Server als Ordner ins System ein (BP->Extras->FTP-Mount)
* neues Widget, Animationen (Gif's) im Skin
* ext2 oder ext3 beim Initialisieren auswählbar
* Expertline in der Infobar kann jetzt konfiguriert werden
* Standby fur externe USB-Festplatten (Vorsicht funktioniert nicht mit allen Controllern)
* Geräte-Manager teilweise stark uberarbeitet.
Fix + Update:
* Email-Checker gefixt, kommt wieder mit Google-Konten klar und Absturz von Enigma wenn keine SSL-Verbindung zum Server zustande kommt
* Stream-Traffic-Info sollte jetzt besser mit HD-Sendern klar kommen
* Wetter
* siehe CVS
* wählbare Quickbuttonfunktionen erweitert
Wichtig:
ACHTUNG bei einige Festplatten soll es unter den neuen Kernel Probleme geben.
* Bei den DM8000 der Betaserie kann es aufgrund eines Securitychipupdates beim Start einen zweiten Startversuch benotigen.
Dieses Image enthält keinerlei Keys oder Softcams.
Backups und sonstige modifizierten Images sind nicht
von uns und werden somit auch nicht supportet!!!
Download uber Database
Vielen Dank und viel Spass
Euer Gemini-Team
Gemini2 v5.0
Enigma from 29.04.2010
An overview over most functions can be found here
Gemini-Wiki
Function Buttons:
* BLUE - Blue Panel (BP)
* BLUE long - Picture in Picture (DM7025, DM8000)
* 2x BLUE - BP -> Gemini Extras
* BLUE RED - File-Manager
* RED - Recording (not for DM8000)
* GREEN - Quickbutton / Subservices
* YELLOW - Timeshift (not for DM8000)
Extras:
* Addon and Plugin Server
* Cryptinfos of the channel or Cam, Stick Cam to certain channels
* Function for managing many daemons / server (BP -> Services/Daemons)
* optical enhancements like HD-skin, additional icons or modification of the channel list
* Manager for format, setup or mount devices (BP -> Device-manager)
* Additional EPG-functionality like Autosave, Refresh or different EPG-format view
* Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
* Quickbutton, to define functionality of the Green button via menun
* Detailled information about your Dreambox (Menu -> Information)
* File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
* complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
Information about many other functions can be found at the IhaD-Board or our Wiki.
New:
* Adaptions for 500HD
* Change to OE1.6, new kernel version
* FTP-Mounts - Mounts FTP-Servers as directories into the system (BP->Extras->FTP-Mount)
* new widget, animations (GIFs) in the skin
* ext2 or ext3 selectable if initialize
* The expert line in the infobar can be configured now
* Standby for USB-Harddisks (Attention: Doesn't work with all conrtolers)
* Device-Manager partially very strong revised
Fixes + Updates:
* Email-Checker fixed, can handle Googlemail accounts again, and no Enigma2 crash if no SSL-Connection can be done.
* The Stream-Traffic-Info should work better now on HD-Channels
* Selectable quickbuttonfunctions extended
* Weather
* see CVS
Important:
Attention on some harddisks the new kernel may cause problems.
* On the DM8000 from the beta-series, a security chip update will maybe make a second boot necessary.
This image doesn't contain any keys or softcams!
Backups or other modified images are not released by us
and won't be supported in any way!!!
Thank you and have fun
Your Gemini-Team
Backup OpenBlackHole DM800 by Abot
O combinatie superba. O folosesc de o saptamana si sunt la fel de incantat cum am fost de aparitia DE 133D !! :) Recomand skinul infinity_hd pe care-l gasiti la downloaduri. Imaginea e testata doar cu oscam. Client cccam si server.
Imaginea este pe stick cu Oozoon in flash si Meoboot.
Detalii despre imagine [Only registered and activated users can see links. Click Here To Register...]
EDG Nemesis 2.2 HD DM 8000
Info Tecniche Italiano:
• OE git repo opendreambox-1.6 of: 11-02-2011
• Enigma git repo Experimental of: 23-02-2011
• Enigma2-Plugins git repo of: 14-02-2011
• Linux version 2.6.18-7.4-r9.0 (r9.1 for DM8000)
• Web Interface: 1.6.6
• Busybox 1.15.3-r24.6
• Date image SVN(073), 25-02-2011
• Bitbake 1.8-dream
• Secondstage #82
• Drivers date Last
Function keys:
• BLUE - Panel Nemesis
• BLUE> 1s Extensions
• 2x BLUE - Addons
• Yellow - Timeshift
• YELLOW> 1s Plugin
• GREEN-EPG Control Center
• GREEN> 1s subservices
• RED - Record Menu
Main features:
• Panel Nemesis 2.2
• No reboot after installing the enigma settings from Blue Panel
• Reduced reboots after installation of enigma Blue Panel
• New ADDONS Management (the old Repository will be stopped)
• Skin Based on HD-Glass 15 by shamann
• Shortcut for Package Manager IPK on Blue Panel (Blue->Blue)
• Shortcut for Software Update on Blue Panel (Blue->Blue)
• Shortcut for Extansions Manager on Blue Panel (Blue->Blue)
• Shortcut for Network Browsing on Blue Panel (Blue->Red)
• Improvement/Fixed Extansions Manager
• Improvement/Fixed Software Update
• Improvement/Fixed OPKG Package Manager
• Manage Panel for OPKG Package Manager
• Fade Management for InfoBar (On Show, On Hide, On Zap)
• Full support for e2_loadepg
• Support for your own scripts
• Manage Start / Stop Services
• Manage Start / Stop Services on boot
• Manage kernel modules
• New Information System
• Separate Management Third Party Programs
• Support for a private server addons
• Picon support for OSD channel name or reference
• Support for LCD Picon name or reference channel (800 and 8000)
• OLED Picon support for name or reference channel (800se)
• Mode Vision LCD
• Support for swap files
• Support for EZ-Inadyn IpUpdate
• Support Proxy
• Support OpenVPN
• Replaced with OpenSSH Dropbear
• Support for SFTP
• Support for readers Smargo
• Support for readers Omnikey
• Support for USB WiFi (500hd, 800 and 800se)
• Samba server, Samba client, NFS Server
• Running Linux commands
• Choice InputBox (default) or VirtulaKeyBoard (experimental), for EPG Search and Run Command
• Fixed Mediaset EPG
• EPG black list, excluding channel MHW epg (see / etc/enigma2/epg.blacklist)
• Support for DVD writer external
• Support for mkv files
• Support for formatting USB Device
• Support for most of the pens DVB/T USB on the market
• New Management Panel to Manage/Install DVB/T USB Drivers
• Updating image directly from the Software Update
Extra Info Bar:
• Manual or Automatic
• Setting Auto show delay
• Set delay information ECM
• Set delay information EMM
• Picon SAT
• Picon Provider
• Picon Encoding
• Add management for new 4 encoding
• Info Orbital position for most of the SAT
• Show / Hide Network
• More Info
EPG Control Center:
• Setting path EPG USB, CF or HDD
• Integrated CrossEPG loader directly form Sat, by Skamania
• Integrated CrossEPG plugin by Skamania
• Manual EPG download
• Scheduled EPG download, via Enigma 2 Timer
• Load EPG directly into the cache without restarting enigma2 enigma2
• Backup EPG Cache enigma2
• Clearing the Cache enigma2 EPG
• Log scheduled download CrossEPG
• EPG Search
• History Research EPG
Kernel Modules:
• OpenVpn (tun)
• Usb To Serial (usbserial, ftdi-sio, pl2303)
• Nfs Server (nfsd)
• smbfs
• udf
• Wifi
• USB DVB/T
• And more
Bug Conosciuti:
• Display dm800se
• Gestione periferiche DM8000 (cmq risolvibile manualmente)
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NO EMULATORS, NO URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG-NEMESIS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
NON DIAMO SUPPORTO ALLE IMG CARICATE IN MULTIBOOT-WE DO NOT SUPPORT THE LOAD IMG MULTIBOOT
DM 8000 HD PVR: Newnigma2 v3.1.6
Newnigma2 team proudly presents:
Newnigma2 v3.1.6
Basics:
- Enigma2 2.6: 03.03.2011
- Enigma2 Plugins 2.6: 03.03.2011
- Newnigma2 Plugins: 03.03.2011
Changes:
- Bugfix: configsaver crashed with SD skins
- Bugfix: webradio shoutcast search
- Bugfix: some ecamdctrl fix
- Bugfix: some small things Kerni-HD1R2 fixed
- Update: DMConcinnity-HDpicon_default.png changed
- Added: a new version of bitrateviewer
Änderungen:
- configsaver: fix crash on SD skins
- webradio: fix shoutcast suche
- bitrateviewer: neue Version
- ecamdctrl: bugfix
- DMConcinnity-HD: neues picon_default.png
- Kerni-HD1R2: einige bugfixe
Multiboot: No support for multiboot. Not planned. No need for such a tool.
G3wizard: No support for g3wizard. Probably not running. Not needed in Newnigma2 enviroment.
Onlineupdate from v3.1(.x) is possible.
Ein Update von v3.1(.x) ist per Softwareverwaltung moglich.
Hinweis: Sollte es beim Update zu Problemen kommen und beim Neustart Error im Display stehen dann muss der SecondStage mit Dreamup neu geflasht werden.
Notice: If u have problems after update and the display shows "Error", then u have to flash the SecondStage with dreamup.
Image:
