Newnigma2 v3.1.4 DM 7025(+)
Basics:
•Enigma2 2.6: 22.01.11
•Enigma2 Plugins 2.6: 22.01.11
•Newnigma2 Plugins: 22.01.11
DM 7025(+)
•driver: 08.12.2010
•secondstage: 76
•kernel 2.6.12
Changes:
•Feature: EPGCacheSelector (choose the file and location of the epg cache file)
•Feature: User can now decide if manual activated infobar should be hidden automatically (settings can be found in system settings)
•Feature: Installer checks now every x hours or on system startup for updates (settings can be found in system settings)
•Feature: Devicemanager internal routines changed from hotplug to udev netlink
•Feature: Now with slovakian translation on feed.
•Feature: Oled now with number of the currently running channel and improved layout
•Feature: Simplified picon installation
•Bugfix: camd menu, camd list wasn't visible sometimes
•Bugfix: systeminfo crashes in some strange cases
•Bugfix: dvd speed settings have not an affect
•Bugfix: dvdhandling improved
•Bugfix: menu -> plugins (german: erweiterungen) now linked to our onlineinstaller
•Bugfix: large file support for FAT32 (now its possible to create partitions and files >1GB)
•Bugfix: dvdbackup .iso image creation
•Update: nl, lt and fr translations updated
•Update: dvdread and dvdnav updated
•Update: satellites.xml by Reinh@rd 15.01.2011
•Update: dosfstools to 3.0.11
•Added: enigma2-plugin-extensions-easymedia to feed
•Added: enigma2-plugin-extensions-fancontrol2 to feed
•Added: enigma2-plugin-extensions-reconstructapsc to feed
•Added: enigma2-plugin-extensions-seekbar to feed
•Removed: dvdburn and depends removed from image (dm8000). Saves 8MB flash
Infos for skinners:
•You don't have to use skindir/newnigma2 folder for icons, they are now integrated. If you want to use your own png's, dont delete this folder in your skin
•extInfoBarSkins.xml is removed. Dont use this file anymore, it is no longer available, but you can activate the ecm info screen still via osd preferences
Änderungen:
•Feature: Mit dem EPGCacheSelector kann der Dateiname und Speicherort der EPG Cache Datei definiert werden.
•Feature: Die Nutzer konnen nun wählen ob eine manuell aktivierte Infobar automatisch geschlossen werden soll ( NN2 System Einstellungen)
•Feature: Es kann nun aller X-Stunden oder bei System-Start auf Updates gepruft werden ( NN2 System Einstellungen)
•Feature: Die internen Routinen des Devicemananer wurden von hotplug auf netlink umgestellt.
•Feature: Jetzt mit slowakischer Übersetzung auf den feeds.
•Feature: Einige Verbesserungen der OLED Anzeige, anzeige der Kanalnummer.
•Feature: Vereinfachte Picon Installation.
•Bugfix: camd Menu, camd Liste wurde manchmal nicht angezeigt.
•Bugfix: Absturz beim Aufruf der Systeminformationen.
•Bugfix: DVD Geschwindigkeitseinstellungen hatten manchmal keinen Effekt.
•Bugfix: Verbessertes DVD-Handling.
•Bugfix: Über "Menu > Erweiterungen" ließen sich keine Plugins installieren / deinstallieren.
•Bugfix: LargeFileSupport fur FAT32 ( Es konnten keine Dateisysteme und Dateien > 1GB erstellt werden )
•Bugfix: Mit DVDbackup konnten keine ISO-Images erzeugt werden.
•Update: Folgende Übersetzungen wurden ergänzt NL, LT, FR
•Update: dvdread und dvdnav wurden aktualisiert
•Update: Neue satellite.xml von Reinh@rd 15.01.2011
•Update: dosfstools wurde auf Version 3.0.11 aktualisiert
•Added: enigma2-plugin-extensions-easymedia zum feed hinzugefugt
•Added: enigma2-plugin-extensions-fancontrol2 zum feed hinzugefugt
•Added: enigma2-plugin-extensions-reconstructapsc zum feed hinzugefugt
•Added: enigma2-plugin-extensions-seekbar zum feed hinzugefugt
•Removed: dvdburn wurde aus dem 8k Image entfernt ( gibt 8mb an Flash Speicher frei )
Information an die Skinner:
•Die Icons in /skinname/newnigma2 werden nicht länger benotigt, unsere Icons befinden sich nun im Verzeichnis des jeweiligen Plugins.
Ihr konnt das Verzeichnis jedoch weiterhin fur eure individuellen Icons verwenden.
•Bitte benutzt die extInfoBarSkins.xml nicht mehr, die Datei wurde aus dem Image entfernt.
Der ECM Info Screen kann jedoch weiterhin in den OSD-Einstellungen aktiviert werden.
Multiboot: No support for multiboot. Not planned. No need for such a tool.
G3wizard: No support for g3wizard. Probably not running. Not needed in Newnigma2 enviroment.
Onlineupdate from v3.1(.x) is possible.
Ein Update von v3.1(.x) ist per Softwareverwaltung moglich.
DM 7025(+): Newnigma2 v3.1.6
Newnigma2 team proudly presents:
Newnigma2 v3.1.6
Basics:
- Enigma2 2.6: 03.03.2011
- Enigma2 Plugins 2.6: 03.03.2011
- Newnigma2 Plugins: 03.03.2011
Changes:
- Bugfix: configsaver crashed with SD skins
- Bugfix: webradio shoutcast search
- Bugfix: some ecamdctrl fix
- Bugfix: some small things Kerni-HD1R2 fixed
- Update: DMConcinnity-HDpicon_default.png changed
- Added: a new version of bitrateviewer
Änderungen:
- configsaver: fix crash on SD skins
- webradio: fix shoutcast suche
- bitrateviewer: neue Version
- ecamdctrl: bugfix
- DMConcinnity-HD: neues picon_default.png
- Kerni-HD1R2: einige bugfixe
Hinweis: Sollte es beim Update zu Problemen kommen und beim Neustart Error im Display stehen dann muss der SecondStage mit Dreamup neu geflasht werden.
Notice: If u have problems after update and the display shows "Error", then u have to flash the SecondStage with dreamup.
Image:
