Re: Octagon SF918 HDTV - Linux Kernel - LAN
are ceva legat de sharing (cred ca e la fel ca echolite sau optibox)..
Octagon SF1018
Key features:
Twin Tuner: 2 x DVB-S2 HD Tuner
Standby power: 1 Watt
2 x Card Reader
2 x CI slot
2 x USB 2.0
SATA internal drive (SATA HDD)
PVR: internally through SATA or externally via USB
Ethernet LAN
HDMI 1.3x
VFD DISPLAY (Alpha numeric)
PIP: Picture in Picture function (2xLIVE programs)
Blind (blind search)
ENIGMA 2 (E2) in preparation
ST71xx Chipset CPU (like qbox HD)
Embedded LINUX
Features: PVR, LAN, multimedia
LAN:
- FTP connect
- File browser, such as HDD PVR etc. and firmware update via PC
- Mgcamd, newcamd, Newcs
- Ccamd, camd3, mbox, gbox in preparation
- Live Streaming
PVR:
- 2 Channel Recording + 2 LIVE Channel View
- 3 Channel Recording + 1 Channel Live View
- 2 Channel Recording + 1 transmitter + 1 LIVE Watch Channel timeshift or PIP
- Timeshift
- Timer Record
- Permanent timeshift always in the background (real-time shift)
Multimedia:
- DiVX Support
- TS Video
- Mp3 + Jpeg viewer
- Other multimedia files support in handling
Scan Options:
- Auto Scan & NIT
- Manual Tuning
- Fast-Scan Search
- Blind (blind search)
LNB + DiseqC Levels:
- DiSEqC 1.0, 1.1, 1.2 and 1.3 USALS
- Unicable Support
se pare ca ultimu soft merge cccam pe el, drept ca e versiunea beta dar de inceput e bine..Octagon SF918HD sw. V10502
Da a iesit.Sa vedem daca e ca la incubus sau ca la cccam care da azbox HD.Eu sper sa fie nativ cccam dar nu am prea mare sperante....
Octagon HD SF918 EMU AU CCAM USB PVR V10534
Octagon HD SF918 EMU AU CCAM USB PVR V10534 18/06/09 HDTV !
ENGLISH :
Readme_Version_18-06-09_EMU_AU_V10534
for Octagon HD SF 918 HDTV :
Changes :
- CCcam function improved (Beta4)
- CleanUp Main SW
--> Improvements for Stability, Database and Reboot bug.
--> Pls. Test long-time
- MCAS update
- WLAN Zigbee preparation Menu :
--> Menu - Module - CAS - ComPort - Homeshare : Zigbee extern, Zigbee intern, RS232
--> Channel 1~16
Advice :
- Display bright Status : Menu - Module - CAS Menu - RS232 Com Port - NONE
- Display dark Status : Menu - Module - CAS Menu - RS232 Com Port - Gbox, Homeshare, HSIC, Xcrypt
- AU update still works ;-)
Please make factory settings after SW update.
EMU and other CAS Setup`s :
Pls. press Menu --> Modules --> RED Button --> Enter 9999
--> CAS menu for EMU and other CAS Setup`s
--> EMU Key for Enter Key and Keyreset (Reset) with Yellow Button
Memory Setup`s :
Menu --> STB Status --> Memory Setup --> Options : Memory Backup and Memory Restore
Update : File --> OCTAGON_HD_SF918_EMU_AU_PVR_USB_e SATA_V10534__18_0 6_09_HDTV.bin --> Pls. copy of USB Stick and update STB !
Programm list & Setups save direct to USB Stick :
--> USB Stick connect to STB,Go Menu - USB Menu --> press INFO Button, Program list + setups save direct to USB Stick
Premiere Portal (Multifeed) - Button --> OPT+ or also AV+
Master Password : 0918
Teletext Parental Lock, Password : 0918
- Advise : For new generation remote Control 2 Buttons changed
--> old Remote control : Fine-Tune and X+ Button
--> new Remote control : Fine Tune with Red Button, X+ with Green Button
- Channel hide/skip (HIDE) aktivate/deaktivate Button change
--> Pls. press OK button to Ch.List - now with REC Button can aktivate/deaktivate HIDE channels
--> Password : 9999
Ethernet LAN / RS232 : CCcam, NewCamd, Gbox, Homeshare, HSIC, Xcrypt etc. ;-)
un pret informativ , cel putin asa cred fiindca nu cred ca-l au in stoc pt. noul :
- Octagon SF 1018 HD : [Only registered and activated users can see links. Click Here To Register...]
Salut , pt. cei interesati de noul model OCTAGON 1018 HD, aveti mai jos manualul acestui receiver in germana/engleze :
