Zettlab Brings its D4 and D6 AI NAS to CES 2026
Over the past couple of years, we've seen a lot of new entries into the NAS market and another new player is Zettlab. The company ran a successful Kickstarter campaign, raising over US$1.48 million from 1820 backers. The company brought base tier D4 and D6 models to CES and these models have started to arrive with its backers about six months late, whereas the more powerful Ultra models seem to have ended up stuck in development hell, partially due to increased DRAM prices.
The D4 and D6 are based on the Rockchip RK3588 Arm SoC with four Cortex-A76 and four Cortex-A55 CPU cores, a 6 TOPS NPU and an Arm Mali G610 MC4 GPU. Zettlab has paired the RK3588 with 16 GB of LPDDR4x memory and 32 GB eMMC for the OS. Both SKUs have a 1 Gbps and a 2.5 Gbps Ethernet port, one NVMe slot, and HDMI port, one Type-C and one Type-A USB 3.0 port, two USB 2.0 ports, one full-size SD card slot and one microSD card slot, as well as a 3.49-inch information display around the front. As the model name suggests, the D4 has four 3.5-inch drive bays and the D6 has six. Zettlab provides its own ZettOS which is said to be an AI first OS and the company was demoing its ZettAI at CES, but outside of that, it seems like ZettOS is a fairly basic NAS OS at the moment.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
j5create Shows Docks with Built-In Displays, 8K 144 Hz Support, and AI
j5create dedicated its CES 2026 booth to high-end connectivity solutions that enhance modern IT infrastructure, particularly in video streaming at high resolutions and refresh rates. All new products are based on the Thunderbolt 5 series, offering 120 Gbps bandwidth, which is three times the capacity of the previous generation. The JTP5172 Triple 8K60 Docking Station supports 8K at 144 Hz and delivers 140 W of power. For those in need of an eGPU, the JTD5175 enclosure is compatible with NVIDIA's GeForce RTX 5090 for gaming and AI applications. Real-time monitoring is featured in two products: the JCD3195 Dashboard Dock and JCDP3140 Powerbase Docking Station, both equipped with built-in displays for performance and power status checks.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Acemagic Shows AMD "Gorgon Point" and Intel "Panther Lake" Mini-PCs at
At the CES 2026 International Show, Acemagic was one of the few companies to showcase mini PCs with the newly announced AMD "Gorgon Point" and Intel "Panther Lake" chips. In a Board 3 Dual-C mini PC inspired by the old retro aesthetic, Acemagic has crammed an AMD Ryzen AI 9 HX 470 chip with 12 cores and 24 threads, featuring an embedded Radeon 890M GPU with 16 compute units. With up to 64 GB of system memory, the Board 3 supports up to two 4 TB M.2 PCIe 5.0 NVMe drives, packing quite the punch in a body smaller than an ITX motherboard. At just 140x128x40.8 mm in size, the system is 0.73 liters in volume.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Iqunix Previews Upcoming Q101 "Ultra-Lightweight" Magnesium Gaming Mou
Iqunix is known for its Hall effect and mechanical keyboards, many of which have a unique aesthetics or some sort of neat feature like the magnetic dongle storage and custom mounting style of the Magi65 Pro. The brand appears to be bringing these design touches to a new lightweight gaming mouse soon enough. At CES 2026, the peripherals brand showed off a new gaming mouse called the Q101, which it bills as "coming soon." Not much is known about the Q101, although Iqunix has confirmed that it will be made from an aluminium alloy.
The new mouse, which has a symmetrical shape, foregoes the typical hole pattern often used to make gaming mice lighter, instead opting for an almost chaotic asymmetrical lattice structure. The shell itself will be made of a lightweight magnesium alloy, but part of the magnesium shell can be removed by the user and replaced with a translucent plastic window, giving the mouse a solid back and an interesting visual look. Not much is known about what sensor or MCU will be used, but Iqunix claims that the mouse will have 24,000 DPI and an "ultra-lightweight body," although again no weight specs were provided.[Only registered and activated users can see links. Click Here To Register...]
Keychron Unveils Nape Pro Wireless Trackball Mouse and New Keyboards a
When you think of Keychron, you immediately associate them with premium keyboards. But before we got to the keyboards, their CES booth this year caught our attention with a truly unique product: the Keychron Nape Pro Wireless Trackball Mouse. This compact device is designed to sit alongside keyboards or function as a standalone trackball with macro pad capabilities. The "mouse" measures 35.2 x 34.7 mm and features a 25 mm thumb trackball, six buttons, and a scroll wheel. It uses a Realtek chip with 1 kHz polling rate and a PixArt PAW3222 sensor for tracking, Bluetooth, 2.4 GHz wireless dongle, or USB-C wired connection. The device runs the ZMK open-source keyboard firmware, enabling extensive customization with multiple layers, shortcuts, and programmable macros.
However, the key innovation is Keychron OctaShift system, which detects the device orientation and automatically remaps button functions accordingly. Whether positioned horizontally next to a keyboard like a laptop pointing system or vertically as a standalone trackball, the M1 and M2 buttons at each end adapt to serve as primary clicks (or whatever functions have been assigned). This allows the Nape Pro to switch between a precision input device and a full macro pad depending on placement.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Minisforum Shows Intel "Panther Lake" Mini PC and More at CES 2026
Minisforum had a quite a presence at CES 2026 with mini PCs ranging from Intel to AMD solutions, even with a mix of Arm-based SoCs. Interestingly, the systems come in various shapes and sizes, but our focus starts with the M2 Pro mini PC. Shaped like a NUC, the mini PC is powered by top-of-the-line Intel Core Ultra X9 388H "Panther Lake" processor with 16 cores, and Arc B390 integrated GPU for new gaming performance tier in the iGPU space. The system is equipped with a maximum of 96 GB of LPDDR5X memory, which runs at the 9,600 MT/s transfer rate, making the system run incredibly fast and feeding the powerful CPU+iGPU configuration.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Thunderobot Launches ZERO Air Gaming Laptops with Intel Panther Lake a
Thunderobot is well known in the Chinese market and in recent years seems to be determined to make its way worldwide with products that stand out from the usual ones. At CES 2026, Thunderobot officially unveiled its ZERO Air gaming laptop series, something the company had [Only registered and activated users can see links. Click Here To Register...] in the weeks leading up to the show. The new lineup focuses on thin-and-light gaming systems built around Intel Core Ultra Series 3 "Panther Lake" processors and NVIDIA RTX 50 Laptop GPUs. Measuring just 15.9 mm thick and weighing around 1.58 kg, the ZERO Air is clearly a lightweight gaming laptop. It is powered by an Intel Core Ultra 9 386H (16-core, 16-thread) CPU with boost clocks up to 4.9 GHz. For graphics, it sports the GeForce RTX 5070 GPU. As for cooling, it features a dual-fan cooling system and a vapor chamber. The laptop has a 15.3-inch QHD+ OLED display with a 165 Hz refresh rate. Memory support goes up to 32 GB of DDR5, alongside dual PCIe Gen 4 SSD slots for storage expansion.
Alongside the ZERO Air, Thunderobot also showed the ZERO 18 Pro, its high-end flagship model. This larger system uses Intel Core Ultra HX Series processors and can be configured with up to a GeForce RTX 5090 Laptop GPU. It features an 18-inch QHD display running at 240 Hz, supports up to 64 GB of DDR5 memory, PCIe Gen 5 storage up to 2 TB, and includes RGB lighting and a 99 Wh battery.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
More pictures follow.[Only registered and activated users can see links. Click Here To Register...]
Huion at CES 2026 Shows Kamvas Gen 3 Tablets for Digital Artwork
Huion has surprised digital artists at CES 2026 with Kamvas Pro 27 and Kamvas 22, built on Huion's Gen 3 display technology. The "smaller" 22-inch Kamvas display comes with 2560x1440 resolution in 16:9 aspect ratio with 90 Hz refresh rate. The panel features 16,384 pressure levels and comes with PenTech 4.0 technology. The tablet also includes 12-color ambient lighting to make your creative work immersive. The screen has anti-glare etched glass screen. For the larger Pro 27 model, Huion bumps the screen size to 27 inches while also bumping the resolution to 4K with 144 Hz refresh rate. Finally, these tablets also have feet that help adjust the angle and point the screen toward the artists, so it becomes much easier to do drawing work at an angled screen. To help with precision drawing, Huion PenTech 4.0 delivers ergonomic hold and precise pointing.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GPD Mini Laptops and Handhelds Powered by AMD "Strix Halo/Point" Arriv
GPD, a well-known manufacturer of mini PCs with unique form factors, showcased its entire lineup of systems powered by AMD "Strix Halo" and "Strix Point" at CES 2026. Leading the lineup is the GPD WIN 5, a handheld device featuring the AMD Ryzen AI Max+ 395 processor. It offers up to 128 GB of LPDDR5X system memory running at 8,000 MT/s, supporting the 16-core/32-thread CPU and Radeon 8060S integrated graphics. The system provides up to 4 TB of SSD storage, with ports including USB4, USB 3.2 Gen 2 Type-C, USB 3.2 Gen 2 Type-A, and slots for microSD and Mini SSD for additional storage. It features a 7-inch 1080p display and an 80 Wh battery.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Tianma Introduces 27-inch QHD 610 Hz Oxide Display at CES 2026
Tianma, a leading global manufacturer of flat panel displays, is introducing a 27-inch Oxide TFT-LCD display with QHD resolution (2560×1440) and an industry-leading 610 Hz refresh rate for ultra-smooth motion in competitive gaming. Leveraging advanced Oxide technology, this Tianma display reaches its ultra-high refresh rate through three core panel enhancements: positive-mode liquid crystal material; an optimized alignment layer; and a refined TFT structure.
Tianma's 27" QHD 610 Hz Oxide Display delivers 1 ms GTG response time to minimize motion blur and an anti-glare, anti-reflection design for visual comfort during extended use. This panel offers 350 nits brightness, a 1200:1 contrast ratio, and 100% DCI-P3 wide color gamut, ensuring vivid color and sharp detail for high-performance gaming.[Only registered and activated users can see links. Click Here To Register...]
(PR) GL.iNet Unveils Next-Gen Travel Routers at CES 2026
GL.iNet, a leading developer specializing in OpenWrt-based networking and remote access solutions, unveiled its latest product lineup scheduled for release at Spring 2026 at the Consumer Electronics Show (CES) 2026 in Las Vegas.
"GL.iNet strives to develop innovation that solves our users' biggest challenges, and that mission guides our way forward," said GL.iNet CEO Mason Zhao. "We are constantly thinking of new ways to deliver a premium user experience, our ultimate goal is to create an ecosystem of products that will improve everyone's lives."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
KTC Gaming Monitors at 2026 International CES
KTC started out as a discount gaming display upstart from Shenzhen, but has, over the years, grown to become a major player in the space. The company now has wide market presence in the US, and brought their latest gaming monitors to the 2026 International CES. The star attraction in the booth is the Q4966REC, an ultrawide format curved display with 49-inch diagonal size, an insane 32:9 aspect ratio, along with 5120 x 1440 pixels native resolution. The display has a steep curvature of 1000R, and uses a fast VA panel that offers 240 Hz refresh rate, 1 ms response time, 3000:1 static contrast ratio, and 178°/178° viewing angles. Also on offer are DisplayHDR 400 and 95% DCI-P3 wide color gamut.
The KTC Q2783SXC is a fast 27-inch planar monitor with WQHD resolution (2560 x 1440 pixels), and up to 400 Hz refresh rate, with 1 ms response time. The Q2717RDC is a 27-inch, 16:9 aspect ratio monitor with 1500R curvature. It offers 2560 x 1440 pixels resolution with 200 Hz refresh rate, and uses a fast VA panel. The KTC U2720SUQ is a premium 27-inch planar monitor with 4K Ultra HD resolution (3840 x 2160 pixels), and 160 Hz refresh rate. You can use this to beam Full HD at 360 Hz. The U2767SC is a more conventional 27-inch planar monitor with 4K Ultra HD resolution at 60 Hz. Signing things off from the KTC booth is the U3282SEL, a high-end 32-inch planar monitor with 4K Ultra HD at 240 Hz, which can also be used for Full HD at 480 Hz.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
My Arcade at 2026 CES: Retro Games Consoles, Mini-Arcade Machines and
The arcade era may be long gone, however, My Arcade continues to lean into nostalgia. At CES 2026 we visited My Arcade colorful booth filled with retro-inspired hardware aimed at collectors and fans of classic games. The new Gamestation Retro Go is a handheld console with over 200 built-in games. It features a refreshed color option and slightly revised controls compared to the original [Only registered and activated users can see links. Click Here To Register...] released in September 2025. Pricing is expected to be around $199. Also on display was the Gamestation Retro Pro, a home console variant that also comes preloaded with more than 200 games. Unlike the original version, this model drops the arcade sticks in favor of two standard console controllers, outputs at 1080p, and is expected to retail for about $149.
For those who prefer a physical arcade feel, My Arcade showed the Gamestation Retro Mega, a compact tabletop arcade cabinet featuring Bandai Namco titles and other retro games. It uses mechanical joysticks and buttons and is expected to cost $299. My Arcade also showcased its upcoming SEGA-themed mini cabinets, first announced last year. The lineup includes titles such as [Only registered and activated users can see links. Click Here To Register...], Street Fighter II, and a Pac-Man with a special [Only registered and activated users can see links. Click Here To Register...]. These come in several cabinet formats, ranging from compact joystick-based units to more unusual designs such as the Sonic cabinet variant that features a longer control deck with full-size buttons and a full-size joystick. My Arcade rounded out its CES 2026 booth with its full range of retro gaming hardware, including compact handhelds designed for quick nostalgia hits.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
More images follow.[Only registered and activated users can see links. Click Here To Register...]
Hisense Powers Home Cinema with 4K Laser Projectors at CES 2026
Hisense at CES 2026 showcased its most advanced home cinema solutions, hoping to satisfy even the most demanding users. Hisense a new flagship laser projectors called the XR10. The XR10 SKU runs an LPU 3.0 Digital Laser Engine with a pure RGB triple laser light source to output 6,000 ANSI lumens. It uses a 16-element all-glass lens system and an IRIS system that automatically adjusts aperture to achieve 6,000:1 contrast. Color coverage hits the BT.2020 gamut with speckle suppressed to 6 percent. The optical zoom spans 0.84x to 2.0x, projecting screens from 65 to 300 inches, while a 4-camera plus dual TOF sensor array enables lossless correction of side-projected images up to ±15°. The unit also features lens-shift positioning and a sealed microchannel liquid cooling system.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) TSMC Reports Fourth Quarter 2025 Results
TSMC (TWSE: 2330, NYSE: TSM) today announced consolidated revenue of NT$1,046.09 billion, net income of NT$505.74 billion, and diluted earnings per share of NT$19.50 (US$3.14 per ADR unit) for the fourth quarter ended December 31, 2025. Year-over-year, fourth quarter revenue increased 20.5% while net income and diluted EPS both increased 35.0%. Compared to third quarter 2025, fourth quarter results represented a 5.7% increase in revenue and an 11.8% increase in net income. All figures were prepared in accordance with TIFRS on a consolidated basis.
In US dollars, fourth quarter revenue was $33.73 billion, which increased 25.5% year-over-year and increased 1.9% from the previous quarter. Gross margin for the quarter was 62.3%, operating margin was 54.0%, and net profit margin was 48.3%. In the fourth quarter, shipments of 3-nanometer accounted for 28% of total wafer revenue; 5-nanometer accounted for 35%; 7-nanometer accounted for 14%. Advanced technologies, defined as 7-nanometer and more advanced technologies, accounted for 77% of total wafer revenue.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) MSI Motherboards Deliver Full Support for AMD Ryzen 7 9850X3D Pro
MSI is pleased to announce support for the upcoming AMD Ryzen 7 9850X3D processor, built on the Zen 5 architecture and powered by the latest AMD 3D V-Cache technology from AMD. Compatible with MSI motherboards supporting AMD's AM5 platform, this processor features 8 cores and 16 threads with a massive 104 MB total cache, delivering boost clock speeds of up to 5.60 GHz with a max TDP of 120 W. Designed for outstanding performance and efficiency, it effortlessly handles the most demanding gaming and content creation workloads, setting a new standard for high-performance computing.
At the same time, we also unveil the new flagship MEG X870E UNIFY-X MAX during CES 2026. It is engineered for ultra-high performance, featuring a specialized 2-DIMM layout and OC Engine for extreme overclocking enthusiasts. It is powered by a robust 18+2+1 power phase (110 A SPS) and cooled by an advanced thermal solution, incorporating a Direct Touch Cross Heat-pipe and double-sided EZ M.2 Shield Frozr II. By fully optimizing for AMD Ryzen 9000 Series Processors with AMD 3D V-Cache Technology, integrating cutting-edge Wi-Fi 7 and 5G LAN to ensure peak efficiency and low-latency connectivity for data-intensive applications, MEG X870E UNIFY-X MAX is ready for the challenge. An exclusive Tuning Controller provides instant, hands-on control for enthusiasts, enabling quick access to overclocking adjustments and CMOS clearing, all with a single press.[Only registered and activated users can see links. Click Here To Register...]
CannonKeys Reveals Bullet Train '40%-ish' Mechanical Keyboard Price an
CannonKeys is no stranger to peculiar mechanical keyboards, like the cutesy [Only registered and activated users can see links. Click Here To Register...] previously, and one of the company's upcoming releases stays true to that enthusiast nature. The Bullet Train is another small form factor keyboard, this time opting for a low-profile design and what has become known as the V4N4G0N layout—effectively a 40% layout with half a num row, 1-6, along the top left edge of the keyboard. The [Only registered and activated users can see links. Click Here To Register...] to be a compact portable keyboard in a 40% form factor with enthusiast touches and a layout that works for gaming, hence the odd combination of a low-profile design with a num row and an aluminium case. The default plate will be FR4, allegedly for wireless signal integrity, but there will be optional aluminium and PC plates when extras become available.
The Bullet Train will support both wired and wireless connectivity, although the wireless protocol has not yet been confirmed. Given CannonKeys's affinity for ZMK firmware, it seems likely that the Bullet Train will be limited to Bluetooth for wireless. A wired-only version will also be available with QMK firmware, and both versions will support hot-swap switches and compatibility with Gateron KS-33 (low-profile V2) switches. One of the more interesting aspects of the keyboard is its 0° typing angle, but the split space bar with a 1.25 u middle key is also an unorthodox choice, although almost a necessity for a 40% layout. It will be available in black, dark green, lilac, pink, and silver color options, all off which will be anodized finishes. The Bullet Train will launch as a group buy on February 5, with a starting price of $170 for the wired hot-swap version and $200 for the wireless keyboard. The keyboard will be sold as a DIY kit, meaning users will have to supply both the keycaps and switches, although CannonKeys often offers discounted bundle deals on compatible keycaps and switches when launching keyboards.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Stop Paying Annual Fees and Own Microsoft Office 2021 Outright for Jus
Stop paying renewal fees and get a [Only registered and activated users can see links. Click Here To Register...] Professional 2021 for Windows for $34.97 (MSRP $219.99). For many Windows users, Microsoft Office remains the most dependable [Only registered and activated users can see links. Click Here To Register...]. If you work with data, manage reports, or simply need consistent productivity tools day-to-day, having a stable version you fully own [Only registered and activated users can see links. Click Here To Register...] can make a difference. That's where Microsoft Office Professional 2021 for Windows comes in—a one-time purchase currently available for $34.97 instead of the usual $219.99.
Office 2021 Professional includes the core applications most teams still rely on: [Only registered and activated users can see links. Click Here To Register...]. It's built for Windows 10 and 11 and offers the familiar ribbon interface along with updated features for cleaner formatting, easier customization, and improved handling of larger files. Whether you're assembling complex spreadsheets or building client-ready presentations, the tools focus on stability, compatibility, and predictable performance.[Only registered and activated users can see links. Click Here To Register...]
Poor Monster Hunter Wilds Performance Chalked Up to Aggressive DLC Che
Monster Hunter Wilds has earned itself a reputation for poor performance and optimization, and, while successive post-launch updates have helped improve things somewhat, it appears as though part of the problem, especially when it comes to mid-range hardware, is related to how Monster Hunter Wilds checks for DLC content. According to Reddit user u/de_Tylmarande, after significant testing and comparing performance in two different Steam accounts, the user discovered that Capcom has a DLC ownership check constantly running in the background that accounts for at least some of the performance degradation. According to the redditor's testing, the more DLC registered to a user's account, the less performance degradation there is.
u/de_Tylmarande validated their testing by implementing a mod that disables the check. In their specific case, using the mod resulted in an astounding performance increase of upwards of 75%—26 FPS with the mod disabled and 46 FPS with the mod enabled in the same busy hub scene. Crucially, this mod and bug admittedly seem to have the biggest impact on performance when using mid-range hardware, since allowing for the extra CPU overhead seems to minimize the impact of the bug. It's unclear whether this is simply a bug, or if Capcom is deliberately being aggressive with the checks for some reason, but a number of performance-oriented patches have been issued for the game since its February 2025 launch, without any fixes for the aforementioned DLC check, so it seems unlikely that Capcom is unaware of a potential bug that was discovered by an enterprising redditor in their free time. More performance optimizations are promised for the game in 2026, and the Reddit user has promised to publish their mod that disables the DLC check if Capcom doesn't fix the performance problems related to the check.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Schenker Teases Element 16 Modular Gaming Laptop Slated for 2026 Launc
Schenker isn't exactly a household name, but the company is known for making decent enthusiast-class gaming laptops that often come with a reasonable price point and without too much fuss when it comes to design. With its latest design, the Element 16, Schenker seems to be leaning into the recent resurgence in upgradeable and repairable laptops—not unlike the [Only registered and activated users can see links. Click Here To Register...], although with less of an emphasis on customization. Schenker designed the Element 16 in collaboration with Intel, and although it has not yet launched properly, it is based on Intel's new [Only registered and activated users can see links. Click Here To Register...]. This means that when it eventually launches sometime in 2026, the Element 16 will be powered by Intel's Core Ultra 7 356H CPU and up to 64 GB of RAM.
The Element 16 features the components that are typically upgradeable or replaceable in gaming laptops—RAM, SSD storage, fans, and the battery—but it makes those upgrades easier with a toolless bottom panel and minimal screws to access and replace those internal components. The Element 16 also takes things a step further with a replaceable keyboard and a modular port design not entirely unlike that of the Framework laptops but with its own twist: instead of replacing one port at a time, the side-mounted ports on the Element 16 are part of a single module that can be replaced with a different module that has different ports. Schenker also says the motherboard is designed to be replaced when necessary, as well, although it's unclear if both AMD and Intel CPUs will be supported or if those motherboard replacements will be limited to Intel CPUs. There are still questions surrounding pricing, parts availability, and just how open Schenker will be about the parts on the Element 16, but for now we know that it will be sold by [Only registered and activated users can see links. Click Here To Register...] in the EU.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
