| VB-S/S2 specificati-ons |
System standard |
ETS 302 307 |
| Frequency Range |
950~2150MHz for DVB-S/S2/S2X baseband demodulator |
| LNB Power and Polarization |
DiSEqC1.0/1.1/1.2/USALS Motor fully support,
Support Unicable, 13/18V DC @ 400mA MAX, 22KHz±0.4KHz(0.6V±0.2V)tone,Overload Protection |
| Input Level Range |
-80dBm ~ -20dBm (average power) |
| Symbol Rates |
DVB-S QPSK,DVB-S2 QPSK/8PSK/16APSK/32APSK,
DVB-S2X QPSK/8PSK/16APSK/32APSK/64APSK |
| Forward error correction rate |
1/4,1/3,2/5,3/5,2/3,3/4,4/5,5/6,8/9,9/10 |
| Carrier frequency acquisition range |
±5MHz for symbol rates above 3 Msps and ±3MHz for the remaining symbol rates |
| Symbol Rates |
Symbol rate range:
QPSK/8PSK/16APSK 56M, 32APSK 49.6M, 64APSK 41.3M |
| Roll-off factors |
Roll-off factors for pulse shaping: 0.2, 0.25 and 0.35 |
| Code Rates |
1/2,2/3,3/4,5/6,7/8 for DVB-S, 1/4,1/3,2/5,1/2,3/5,2/3,3/4,5/6
,8/9,9/10 for DVB-S2,
DVB-S2X Normal Frame and Short Frame FEC code rates |
| Features |
Supporting CCM/VCM/ACM
Supporting PLHEADER Scrambling (AMC)
Integrating LDPC and BCH decoders |
| ANT. Connector |
Connector:IEC TYPE F Input Impedance:75 Ω |
| DVB-T/T2 specificati-ons |
System standard |
ETSIEN 302 755 |
| Frequency Range |
VHF: 174~230mhz, UHF: 470~862mhz for DVB-T/T2 |
| Demodulation |
COFDM,16QAM,64QAM,256QAM |
| Bandwidth model |
6MHZ,7MHZ and 8MHZ |
| Country |
Italy, Poland, Russia, Spanish, Sweden, United Kingdom, Germany,Greek, Slovenia, Argentina, Australia, Denmark, Finland, France, England, Brazil, Chile, Peru, Colombia, India, Georgia, Indonesia. |
| FEC Code Rate |
1/2, 3/5, 2/3, 3/4, 4/5, 5/6 |
| FFT |
2K and 8K |
| Guard interval |
1/4, 19/256, 1/8, 19/128, 1/16, 1/32, 1/128 |
| Input Signal level: |
Min -80dbm max -20dbm (64QAM,8K 1/8,7/8) |
| Antenna Power |
5V DC @ 150mA MAX |
| ANT. Connector |
IEC 169-2, female. Input Impedance:75 Ω |
| ISDB-T specificati-ons |
System standard |
ISDB-T broadcast (1, 3, 13 segment),MPEG-2/MPEG-4 AVC/H.264 HD/SD Video , DiVX |
| Frequency Range |
VHF:177.143~213.143 MHz:UHF 473.143~803.143MHz |
| Country |
Brazil and Japan |
| FFT |
2K/ 8K/32K |
| Demodulation |
QPSK / 16QAM / 64QAM/QPSK or DQPSK |
| FEC Code Rate |
1/ 2, 2/3, 3/4, 5/6, 7/8 Automatic |
| Guard interval |
1/4,1/8,1/16,1/32 |
| DVB-Cable specificati-ons |
Frequency Range |
50--858MHz For DVB-Cable (J.83A/B/C) |
| Demodulation |
16QAM,32QAM,64QAM,128QAM,256QAM |
| FEC Code Rate |
1/2 , 2/3 , 3/4 , 5/6 , 6/7 or 7/8 |
| Input Signal level |
Min -80dbm max -20dbm |
| Country (ATSC-C) |
U.S.ATSC Cable STD/U.S.ATSC Cable IRC/U.S.ATSC Cable HRC for ATSC-C |
| Sortware Features |
Standard |
Fully comply with DVB-S/S2/S2X (SCPC and MCPC receivable from C/Ku band satellite), DVB-T/T2/Cable(J83.A/B/C)/ISDBT, MPEG-2/4 H.265 Standard |
| Channel Search |
Supports Automatic network search for newly added transponders, and Supports NIT Search for DVB-T/Cable. |
| Channels Number |
6000+ channels TV and Radio programmable |
| Channel Play Type |
Can choose All, Free and Scrambled. |
| Channel |
You can switch to any other channel while recording the channel;
Various channel editing unction(favorite,move,lock,skip,delete,rename,find,sort); |
| Favorites |
32 different favorite groups selection |
| OSD Language |
English,French,German,Italian,Spanish,Portuguese,Russian,Turkish,Polish,Arabic,Persian,Thai,Vietnam, Czech,Armenian,Georgian,Ukrainian,Albanian,Hungary,Malay,Indonesisch,Dansk,Greek,Serbian. |
| OSD Color |
32-bits OSD with anti-flickering, |
| OSD Setting |
Support OSD Timeout and Transparency, Subtitle Display, Channel list displays pages 1-3.
Support menu in the small window to play programs |
| Other Setting |
Sets up multiple habitual operation Settings |
| Parental Ctrl |
Parental control for channels |
| Easy Menu |
Plug and Play installation, with an easy to use Menu System |
| EPG |
Fully support to 7 days Electronic Program Guide(EPG) |
| Subtitle |
support DVB EN300743 and EBU |
| Teletext |
support DVB ETS300472 by VBI |
| Auto Standby |
Can open STB to enter play auto standby. |
| SoftUpgrade |
Software upgrades through USB port, or FTP upgrade. |
| Time Set |
Time set by GMT offset automatic and manual,Summer Time support |
| Timer |
8 event timers,off/Once/Daily Mode |
| USB Decode |
USB 2.0 |
Support FAT/FAT32/NTFS big capacity hard disk |
| PVR Option |
USB 2.0 for PVR,TIMESHIFT,media files playback |
| Media Codec |
TS,mkv, mp4, avi, flv, f4v, ts, m2ts, mov, 3gp files |
| Audio Codec |
WMA,MP3 |
| Photo Codec |
JPG, BMP, PNG, GIF |
| Packing |
Product Dimension |
205*80*140MM(L*W*H) |
| Packaged Size |
205*150*88MM |
| Carton Size |
510*460*305mm (20pcs/ctn) |
| Unit Weight |
0.75 Kg with gift box |
| Carton Qty&Weight |
20 pcs/Carton, 15.5 kgs |
| Accessories |
Gift Box, Adapter, IR remote control, HDMI Cable, User Manual,Warranty card |
| Physicals |
Power Supply |
AC 100V ~250V, 50/60Hz |
| Power Consumption |
12W in operation
<=1 W Standby Power Mode |
| Temperature |
Operation 0~+45ºC; Storage -10~+60ºC |
| Humidity |
20~90%, non-condensed |
