Am incercat si cu Rufus si cu Etcher si tot degeaba. Eu cred ca pur si simplu hardware-ul e diferit si imi trebuie alta imagine. Am gasit specificatiile astea pe net.
A5 Combo
Main Processor: AMlogic S905D Quad-Core Cortex A53 64bit 1.53 GHz
Gpu: Penta-core Mali 450MP Gpu
Flash Memory: 16GB NAND Flash
DDR SDRAM: 2GB DDR3
A5 t2/cable
Main CPU: 64bit Quad Core
2.0GHZ Processor
Main GPU: Octo-core Mali 450MP GPU
(600MHz)
DDR: 1GB DDR3
EMMC: 8GB
Imaginea a fost facuta pentru Combo ! s-ar putea sa se agatze la initializarea driverelor
de tuner care difera ! asa ca asta-i caz de final trist ...
Am inteles. Multumesc mult pentru ajutor tuturor.
La A5 eu scriam cu asta: balenaEtcher-Portable-1.4.9-x86. Vad ca e si un update la accesare, deci o varianta mai noua. Fa o incercare de scriere si cu asta.
Nu merge pe boxul asta am primit raspuns pe alt forum
All images are for Amiko A5 Combo with S2 and T2/C tuner but these images does not work for Amiko A5 T2/C without S2 tuner. All images frozen (stuck) when started because missing S2 tuner and software is unable resolve problem. This forum is for sat STB not for STB for Cable with cryptoguard reader. STB Amiko A5 t2/C is made for providers which control googleplay store with no options use different paid card and Enigma2 is unable to start on this device. Card is paired with STB. I have same problem. Cryptoguard in Android can read card NagraVison CA with report "MissingBoxCey and RSABoxKey" becose provider blocks another cards and Enigma is unable to start .
Au băgat protecție in kernel nesimtitii de chinezi.
