Cred ca cea mai buna setare este la loadbalancer setezi pe 1 atunci se fac cereri de pe readerul cel mai rapid.Quote:
Originally Posted by iannys [Only registered and activated users can see links. Click Here To Register...]
aloooo meseriasu,cine ti a raspuns TI-E cu ironii????Quote:
deocamdata scriam eu cu ovidiu si nu erai cam deloc implicat
revenind ontopic,pai daca tu stai cu un asemenea dvb.api eu nu mai am cuvinte si ti am dat 3 sfaturi,nici macar untr un config default oscam api nu scrie ce ai tu prin dvb,api,le ai pus tu sau ti le a pus altu??
1.in cazu de fata cu un api asa grozav si fara cunostinte elemetare despre oscam te am intrumad spre 3c ca e mai simplu,insa am uitat ca esti pe alien
2.cumpara alt receptor pe care sa te poti juca cu mai multe emulatoare
3.sterge linia aia cu focusu din hop 2,de ce?ptr ca daca focusu in hop 2 iti blocheaza sau iti face freez e de toata jena,adica e fake(facatura,reprodusa,cum vrei tu sa i zici)sau macar blocheaza caidu de focus
la 17 posturi cu un join date recent si cu 2 linii in alien tind sa cred ca esti client pay
un an nou bun sa fie
Changeset 9184
In constcw module, we are now supporting the standard format again which is CAID:PROVIDER:SID:PMTPID:ECMPID::CW.
For Enigma2 receivers, we are parsing the PMTPid so that the standard files should work correctly even for problematic channels which only differ by PMTPid.
For other receivers which don't provide the PMTPid and thus have it set to 0000 (or if PMTPid would not be enough to distinguish), there is an extended format for constcw where you can put the VPID inside (you can obtain it from OSCam log). However, this should only be used for problematic channels and not for the majority.
The extended (OSCam-specific) format is: CAID:PROVIDER:SID:PMTPID:ECMPID:VPID:CW.
Code:[reader]
label = austar
enable = 1
protocol = internal
device = /dev/sci0
services =
caid = 0604
tk0 = 8DEC1C9BDF0A497B
tk1 = 4C96976BB2B88CB4
rsakey = 00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
detect = cd
mhz = 600
cardmhz = 600
ident = 0604:000000
group = 1
emmcache = 1,1,2
blockemm-g = 1
lb_weight = 100
auprovid = 000604
Code:[reader]
label = tntsat
protocol = internal
device = /dev/sci0
services = csatsd
caid = 0500
detect = cd
mhz = 500
ident = 0500:030B00
aeskeys = 0500@030B00:0,0,0,0,0,0,0,0,0,0,0,0,0,2504B382B16D8C6758DB960E311E9351
group = 1
lb_weight = 1000
cccreshare = 1
.....secretosilorCode:[reader]
label = hdplus
enable = 1
protocol = internal
device = /dev/sci0
services =
fallback = 1
caid = 1843
rsakey = 84A5C9E066B9B19FD8C5E0FC2337176B8BE536287A718F4DBB6E9C1C35CA0ADEA1B1C059B0BEB1BAB9A5CE4BE5A5F9E07CCDBE2FA931DBACD602A8895EBFF777
boxkey = 061D895574AED2B0
detect = cd
mhz = 500
cardmhz = 500
ident =
group = 1
emmcache = 1,1,2
ecmcache = 1
lb_weight = 100
---------- Post added at 14:38 ---------- Previous post was at 14:33 ----------
Code:[reader]
label = ctecka
enable = 1
protocol = internal
device = /dev/sci0
device_out_endpoint = 0x 0 wtf???
key =
password =
pincode = none
readnano =
services =
smargopatch = 0
showcls = 10
fallback = 0
logport = 0
caid =
boxid =
fix9993 = 0
rsakey =
force_irdeto = 0
boxkey =
atr =
ecmwhitelist =
detect = cd
nagra_read = 0
mhz = 500
cardmhz = 0
ident =
chid =
aeskeys =
showcls = 10
group = 1
emmcache = 1,5,2
blockemm-unknown = 0
blockemm-u = 0
blockemm-s = 0
blockemm-g = 0
lb_weight = 100
savenano =
blocknano =
deprecated = 0
audisabled = 0
auprovid =
ndsversion = 0
ratelimitecm = 0
ratelimitseconds = 0
Aes-ul de tntsat nu e functional.
setarile respective(TNTsat) erau pe
DOSCAM V0.17
Mda, poate stie ala sa deschida. In oscam arata la fel, zice ca deschide, ecm ok dar ... ecran negru.
O sa probez si eu un doscam, se pare ca ala deschide.
Code:[reader]
label = hd01-weiss_oben
enable = 0
protocol = internal
device = /dev/sci1
caid = 1830
fix9993 = 0
rsakey = BF358B5461863130686FC933FB541FFCED682F3680F09DBC1A23829FB3B2F766B9DD1BF3B3ECC9AD6661B753DCC3A9624156F9EB64E8168EF09E4D9C5CCA4DD5
boxkey = A7642F57BC96D37C
detect = cd
mhz = 368
cardmhz = 368
group = 2
emmcache = 1,3,2
lb_weight = 100
poate e careva interesat si de 1830Code:[reader]
label = hdplus
protocol = internal
detect = CD
device = /dev/sci1
group = 2
emmcache = 1,3,2
caid = 1830
n3_rsakey = BF358B5461863130686FC933FB541FFCED682F3680F09DBC1A23829FB3B2F766B9DD1BF3B3ECC9AD6661B753DCC3A9624156F9EB64E8168EF09E4D9C5CCA4DD5
n3_boxkey = A7642F57BC96D37C
bulgari
nc+Code:[reader]
label = bulsat-bulcrypt
protocol = internal
device = /dev/sci0
caid = 5581,4AEE
force_irdeto = 1
ecmwhitelist = 5581:4F;4AEE:4F
detect = cd
mhz = 500
group = 1
emmcache = 1,3,-1
polsatCode:[reader]
label = p2c
enable = 1
protocol = internal
device = /dev/sci0
services =
caid =
rsakey = 849D312EB63A0A68919EC75CFF6699180CB0B191B0CE4A6CE42BDD4E716432A0C2C76E08F3434D81F64410FABB8DD0D89276D0C74559B3E35591850D17494A55
boxkey = 6C0670E7019573B5
detect = cd
mhz = 500
cardmhz = 368
ident =
group = 1
blockemm-unknown = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
lb_weight = 100
Code:[reader]
label = dream
description = polsat,
protocol = internal
device = /dev/sci0
caid = 1801,1803,1803:1801
rsakey = 840BE0747533632AE4CA2F24CE8126C5A21977A8897AE6A0DA4AF4A00621ECE98C699E659564FD4A893E8C8EEF11FDA62C2E0186517ECF0F5FF295400DC689E7
boxkey = 2763A5A1E88DB31A
detect = cd
mhz = 368
cardmhz = 368
group = 1
emmcache = 1,3,2
lb_weight = 500
dropbadcws = 1
audisabled = 1
auprovid = 001803
Code:[reader]
label = hdplus_schwarz_hd03_>Slot_oben<
protocol = internal
device = /dev/sci0
caid = 1860
rsakey = 901E595152E67DFD5B134E1D195C4141B3BB1394A8AF4D6BF1D1085DCC4D9CBA5C73A06ED21FC3556B685498030BB1185766117565E39995EFBF72135C2817B7
detect = cd
mhz = 368
cardmhz = 368
group = 1
emmcache = 1,1,2
[reader]
label = hdplus_schwarz_hd03_>Slot_unten<
protocol = internal
device = /dev/sci1
caid = 1860
detect = cd
mhz = 368
cardmhz = 368
group = 2
emmcache = 1,1,2
PHP Code:[reader]
#Power = DTR
#PTS = 1
Label = Tauta
Protocol = internal
Device = /dev/sci0
boxid = aaaaaa
Fallback = 0
Group = 1
CAID = 093e
#IDENT = 093e:000000
EMMCache = 1,1,2
#CLASS = 06 60 07 08 3C ???
[reader]
label = ZON
Protocol = internal
detect = CD
device = /dev/sci0
group = 1
emmcache = 1,3,2
rsakey = aaa
boxkey = aaa
mhz = 368
cardmhz = 368
[reader]
label = TVCABO
Protocol = internal
detect = CD
device = /dev/sci0
Group = 1
EMMCache = 1,3,2
CAID = 1802
ident = 1802:004801,004901,000000
Cei care au locale de YT pot incerca [Only registered and activated users can see links. Click Here To Register...]:
Pare poveste !Quote:
For who have 09CD cards.
On oscam.server add this:
caid = 093B:09CD
or
caid = 0919:09CD
This remaps CAID 09cd to 093b or 0919 and should decrypt SD channels.
:spam: Evident nu s-a confirmat !
[Only registered and activated users can see links. Click Here To Register...] vad ca ticketul e inchis si problema rezolvata...se pare ca functioneaza.
Citeste mai atent !
FAKE
It is not possible to map Caid 09CD to 0919,093B becouse the Servid, PID are diffrent between this Caids
So please dont kill your Cards whit Avviso 08
Problem is that Sky has introduced some new INS for initialisation of the card and whitout this the Payload for SD Channels will be wrong or empty
greetings
Luca1234
Cineva ma poate ajuta si pe mine cu setarile cele mai indicate pentru FREESAT ? Am incercat pana acum din 2 locuri niste teste si sincer se blocheaza foarte foarte des. As vrea sa fiu sigur ca nu e din cauza setarilor din decodorul meu . Momentan folosesc Oscam-9705/cccam213. Daca gresesc cu aceasta intrebare in acest topic imi cer scuze sunt incepator in domeniu si ...
Greu, nu? Sigur e din cauza setarilor tale. Apropo, ce card e? Si ar fi si mai simplu daca ai posta configul si logul, sa ne dam seama ce nu e bine. Unde conteaza si un spatiu vrei sa ghicim ce ai tu acolo?
O întrebare, unde trebuie setat in oscam pentru ignore card, per exemplu un card de SKY DE de la un user. Mulţumesc.
Faci un service cu caid si ce siduri vrei, apoi ii pui bifa la ce reader sau user doresti la not services in webif
