Enigma2 for Anaconda
Baietii de la PKT au scos o imagine care ruleaza pe Optibox Anaconda.
Optibox Anaconda fiind identic cu Octagon 1008SE+ ([Only registered and activated users can see links. Click Here To Register...])
Dupa primele teste imaginea se comporta foarte bine. Diacriticele din epg la pachetul f**s apar stranii si aici. Imaginea si instructiunile de instalare le gasiti in forumul PKT. Atentie la stickul folosit, se pare ca boxul are aceleasi mofturi ca si Alien :(
Enigma2 OpenSource SH4 Duckbox Project GIT-2946 PKT SVN-1228 HAARP v3 Image
PKT introduce first E2 Image for SF1008+ (hs7810a)
Image is designed for installation in USB device
Support receiver: Octagon SF1008+
Added by sh4 Duckbox Team:
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [eplayer3] playback aac-he streams with aac-lc
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- new BusyBox 1.19.2 (stable) config and patches
- use utf8 as python default
- adapt wrong page_offset and improve mem
Added by PKT:
- add new WebInterface v 1.6.7
- new function "live ecm" in infobar
- show Channel Number on Front Pannel + ON/OFF in setup menu
- fast switching channel
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6: add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- Add Auto 3D Skin Switch by Dr.Best
- add support for fake cccam
+ change only in HAARP V3 version
- picons update
- added BPanel activation in MoviePlayer ( key blue )
- added compatibility to standard non PKTeams skins
- fix dot on VFD if channel number is not available
- fix for radio mode wallpaper
- fix showing picons on channels list, when are located in /hdd/picon folder
- added /media/usb/picon to picons search folders
- 2nd generation of speed up channels zap
- add standby smooth extingushing TV
- channel list update 28-10-11
- display quality improvement
- new BluePanel 2D v3.1.19 with graphic interface: (rewrite from 0)
-- added function to check update is needed
-- added color & numeric keys actions support to immidiate plugin/function/menu activation
-- 1st row - keys: 1, 2, 3, 4
-- 2nd row - keys: 5, 6, 7, 8
-- 3rd row - keys: red, green, yellow, blue
-- added menu key action support
-- added changelog information menu
-- added synchronization of local time and date from NTP server
-- added on/Off the smooth extinguish TV while switching to standby mode
-- add Enable/Disable cardreader for 1008+ in Blue Panel (default: OFF)
Known issue:
- cardreader driver broke sound after restart GUI
FTP login: user: root, passwd: pkteam
Special THX to octagon88, spiderworld and all sh4 community
O veste foarte buna pentru ANACONDA.
Probabil ca MOSU va aduce si RSP e2, va fi un castig pentru utilizatori si pentru forum.
Am un Anaconda, primit de la firma producatoare, timp si si inspiratie mai trebuie.
nfsboot
O chestie interesanta pentru testarea imaginilor: [Only registered and activated users can see links. Click Here To Register...]
Incercand sa pornesc e2 pe acest aparat am avut neplacuta surpriza ca dupa update sa intre in balarii.
Dupa cercetari indelungi pe net, am descoperit ca ... exista un hop in istoria upgarde-urilor:
-ca sa treceti la versiunile de imagine 2.xx, e musai sa scrieti in aparat:
Code:
This software must be used only if You're trying to upgrade your receiver to v2.09.49 (or higher) and get an error during the update.
After installing this bootbridge software, you shall be able to use the higher versions.
Daca ati trecut la versiuni cu 2.xx fara sa treceti prin 1.99.xx veti avea surpriza sa nu mai mearga nimic.
Metoda de update imagine aparat direct din procedura de boot:
Imaginea 1.99.99_bootbridge se pune pe un stick (dezarhivata), introducem stickul in aparat,
Power OFF
apasati pe UP si tineti asa
Power ON
si asteptati pana scrie SCan, apoi luati mana
Cand termina procedura de scriere, afiseaza un mesaj, apoi Power off .
La Power ON continua (nu cred ca se scoate stickul inca).
Acum aveti iarasi un aparat functional.
Usb
Vad ca spuneti ca are 3 USB-uri. am si eu acest receptor dar vad numa' doua, unul pe fata si unul pe spate. al treilea unde este?
optibox
sal mhai respect te rog am cumparat anconda
vreau sa stii in ce director sa pune oscam ?
var/etc sau ///plz sa pot da drumul la optibox
