HD Glass16 ver. 6.92
- added support-autodetect for BH 1.7.1 - 1.7.9
HD Glass16 ver. 6.93
- fix autodetect for BH 1.7.1 - 1.7.9
deci merge si pe BH 1.79?
Asa zice. Eu am Black Pole OE2.0.
daca pui ultimu skin nu merge , dar daca faci un work around merge:
solutia e mai jos luata de pe un forum extern
in BH 1.7.6, but you must first remove the original skin selector plugin and then replace it with the attached SkinSelector.zip in path "/usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/". Then restart enigma2, then install hdglass, select it and it will then work.
All this does is just comment out 3 lines,but this is enough to ensure the skin works with BH.
i cant add attachments to this site so ive uploaded the file to the link bellow.
HD Glass16 ver. 6.95
- fix oscam version detection
- added/changed forced install via online update
HD Glass16 ver. 6.97
- joined mips and sh4 version to one universal ipk
- added autodetection of the architecture (mips/sh4) to set supported binary
files
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al translations
- added screen 77, 78
- previews and extrascreens graphics updated in download
Note: this is first universal ipk for all architecture (sh4, mipsel), before installing in SH4 uninstall old version first then install this one
HD Glass16 ver. 7.01
- added detection MPEG1/MPEG2/MPEG4/H.264 (tuner info line), if option "Show
Satellite position in TP info only" is enabled
- added new option: Disable Tuner error messages in setup
- help updated in download
HD Glass16 ver. 7.06
- fix autoinstall and patch for old IPbox images (SH4 only)
- fix DVB-T info in TP infoline
- fix detection plugin browser for ViX images OE 2.0 (VU+)
- removed some screens definition to get default screen defined in plugins
Update is available online via setup
HD Glass16 ver. 7.11
- fix neutrino keymap option
- main code optimalisation and unused files cleanup
- fix latest newnigma2 images
- added new options in setup: "Enable ChannelSel. percent" and "Enable ChannelSel. doubleline list" with autocheck and autobackup original of patched system files
Warning: "Enable ChannelSel. percent" and "Enable ChannelSel. doubleline list" works in open images only!!!!! in others activate failed!!!!
HD Glass16 ver. 7.13
- added autodetection for the plugin: bitrateviewer, if exists skin use binary from bitrateviewer and options "Enable full bitrate info" and "Bitrate auto stop limit(kb/s):" are ignored
- fix GP3 support
HD Glass16 ver. 7.14
- added support for latest Dream Elite image 4.0 (001-r3) - older removed
HD Glass16 ver. 7.15
- updated pl translation (thx kosmacz)
- fix bitrate info if bitrateviewer binary is used
HD Glass16 ver. 7.16
- bitrate info: blocked old bitrateviewer binary
- fix some screens of the latest ViX image (VU+)
HD Glass16 ver. 7.18
- added new option in download menu: Download picon - OLED (cz/sk and dm800se colored picons only, piconOled by nandi11 thx)
- fix screen ScriptExecuter
HD Glass16 ver. 7.21
- fix infoECM plugin by Duri
- fix detection plugin browser for BH OE 2.0 (VU+) and autoenabling all skins
- added new OLED type: Picon and Time (switching in 10s)
HD Glass16 ver. 7.22
- fix Menu type: "Icons" in BH OE 2.0 (VU+)
- Menu Icons updated in download menu
HD Glass16 ver. 7.23
- added Picon in channelselection - "doubleline"
HD Glass16 ver. 7.24
- fix installer to "py" cleaned images
- added new Channelsel. type: PIG(+act,next,left)
HD Glass16 ver. 7.27
- fix DVB-C info in TP infoline
- fix support for HDBOX - changed PIG resolution in all needed screens
- fix Channelselection 2xOK
HD Glass16 ver. 7.28
- fix EMC Selection screen
- added new option: PIG type with options: with frame, big PIG
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, all translations
