Re: Enigma2 SifTeam Flash Version 0.1.0
Pentru cei care se pricep si care vor mai mult de la imaginea lor (enigma) va postez mai jos o bucata dintr-un dialog purtat pe alt forum. Atentie pentru cei care inca nu sunteti obisnuit cu imaginile clasice, va sfatuiesc sa nu va bagati la asa ceva. De asemeni am sa-i acord un premiul celui care reuseste cea mai buna aplicare. Parca vad ca trebuie sa-i cer adresa lui zildan*:)
zbigzbig20:*PKT panel works very well
snow2133:*on 900/910 not working very well. you have to delete picons folder, second skin and also part of pkt panel beacuse is not enought space in flash. I let only mbox and incubus. but anyaway you'll have problem with loading settings.
it's a step but the image still have problems.*
team duck tales release few days ago a new image fot kathy who work very good and stabel. even dvb subtitles works. it will be good if somebody could ported this image
dexter:*if you download AAF for Katrein box, and do the following you can use update in their image,
1. copy /usr/lib/enigma2/python/keyids.* /tmp (from sif image)
2. copy /usr/share/fonts/* from AAF image to /usr/share/fonts/ (sif image)
3. copy the /usr/lib/enigma2/* from AAF image to Sif image location.
and you get the new E2 updates including AAF bluepanel
4. copy the /usr/local/share/enigma2 folder from AAF team, if you also want AAF settings plus skins.
5. copy back /tmp/keyids.* to your new /usr/lib/enigma2/python folder
this will fix the assignment of keys
6. copy /usr/local/bin/enigma2 binary application from AAF image to your sif installation in /usr/local/bin/
and you got plugins and DVB Subtitles working. i am watching German ZDF with DVB subs now. so it works fine.
Only seen one issue for now, the starting of*
/usr/lib/enigma2/python/Plugins/Extensions/Softcam/emustarter.sh
so you have to do this by hand in AAF panel.
snow2133:*.......
it's working only with aaf ar also with tdt 474 by PKT?
dexter:*assume both...
it does have small issues.. it seems the keymapping of 0-9 on remote is not working, although all other keys work. so in manual satscan i cannot enter satfreq... but it works..
Matic:*change on IPBox keyids.py
work perfectly
keyids.py
KEYIDS = {*
"KEY_RESERVED": 0,*
"KEY_ESC": 1,*
"KEY_1": 2,*
"KEY_2": 3,*
"KEY_3": 4,*
"KEY_4": 5,*
"KEY_5": 6,*
"KEY_6": 7,*
"KEY_7": 8,*
"KEY_8": 9,*
"KEY_9": 10,*
"KEY_0": 11,*
"KEY_MINUS": 12,*
"KEY_EQUAL": 13,*
"KEY_BACKSPACE": 14,*
"KEY_TAB": 15,*
"KEY_Q": 16,*
"KEY_W": 17,*
"KEY_E": 18,*
"KEY_R": 19,*
"KEY_T": 20,*
"KEY_Y": 21,*
"KEY_U": 22,*
"KEY_I": 23,*
"KEY_O": 24,*
"KEY_P": 25,*
"KEY_LEFTBRACE": 26,*
"KEY_RIGHTBRACE": 27,*
"KEY_ENTER": 28,*
"KEY_LEFTCTRL": 29,*
"KEY_A": 30,*
"KEY_S": 31,*
"KEY_D": 32,*
"KEY_F": 33,*
"KEY_G": 34,*
"KEY_H": 35,*
"KEY_J": 36,*
"KEY_K": 37,*
"KEY_L": 38,*
"KEY_SEMICOLON": 39,*
"KEY_APOSTROPHE": 40,*
"KEY_GRAVE": 41,*
"KEY_LEFTSHIFT": 42,*
"KEY_BACKSLASH": 43,*
"KEY_Z": 44,*
"KEY_X": 45,*
"KEY_C": 46,*
"KEY_V": 47,*
"KEY_B": 48,*
"KEY_N": 49,*
"KEY_M": 50,*
"KEY_COMMA": 51,*
"KEY_DOT": 52,*
"KEY_SLASH": 53,*
"KEY_RIGHTSHIFT": 54,*
"KEY_KPASTERISK": 55,*
"KEY_LEFTALT": 56,*
"KEY_SPACE": 57,*
"KEY_CAPSLOCK": 58,*
"KEY_F1": 59,*
"KEY_F2": 60,*
"KEY_F3": 61,*
"KEY_F4": 62,*
"KEY_F5": 63,*
"KEY_F6": 64,*
"KEY_F7": 65,*
"KEY_F8": 66,*
"KEY_F9": 67,*
"KEY_F10": 68,*
"KEY_NUMLOCK": 69,*
"KEY_SCROLLLOCK": 70,*
"KEY_KP7": 71,*
"KEY_KP8": 72,*
"KEY_KP9": 73,*
"KEY_KPMINUS": 74,*
"KEY_KP4": 75,*
"KEY_KP5": 76,*
"KEY_KP6": 77,*
"KEY_KPPLUS": 78,*
"KEY_KP1": 79,*
"KEY_KP2": 80,*
"KEY_KP3": 81,*
"KEY_KP0": 82,*
"KEY_KPDOT": 83,*
"KEY_103RD": 84,*
"KEY_F13": 85,*
"KEY_102ND": 86,*
"KEY_F11": 87,*
"KEY_F12": 88,*
"KEY_F14": 89,*
"KEY_F15": 90,*
"KEY_F16": 91,*
"KEY_F17": 92,*
"KEY_F18": 93,*
"KEY_F19": 94,*
"KEY_F20": 95,*
"KEY_KPENTER": 96,*
"KEY_RIGHTCTRL": 97,*
"KEY_KPSLASH": 98,*
"KEY_SYSRQ": 99,*
"KEY_RIGHTALT": 100,*
"KEY_LINEFEED": 101,*
"KEY_HOME": 102,*
"KEY_UP": 103,*
"KEY_PAGEUP": 104,*
"KEY_LEFT": 105,*
"KEY_RIGHT": 106,*
"KEY_END": 107,*
"KEY_DOWN": 108,*
"KEY_PAGEDOWN": 109,*
"KEY_INSERT": 110,*
"KEY_DELETE": 111,*
"KEY_MACRO": 112,*
"KEY_MUTE": 113,*
"KEY_VOLUMEDOWN": 188,*
"KEY_VOLUMEUP": 187,*
"KEY_POWER": 116,*
"KEY_KPEQUAL": 117,*
"KEY_KPPLUSMINUS": 118,*
"KEY_PAUSE": 119,*
"KEY_F21": 120,*
"KEY_F22": 121,*
"KEY_F23": 122,*
"KEY_F24": 123,*
"KEY_KPCOMMA": 124,*
"KEY_LEFTMETA": 125,*
"KEY_RIGHTMETA": 126,*
"KEY_COMPOSE": 127,*
"KEY_STOP": 128,*
"KEY_AGAIN": 129,*
"KEY_PROPS": 130,*
"KEY_UNDO": 131,*
"KEY_FRONT": 132,*
"KEY_COPY": 133,*
"KEY_OPEN": 134,*
"KEY_PASTE": 135,*
"KEY_FIND": 136,*
"KEY_CUT": 137,*
"KEY_HELP": 138,*
"KEY_MENU": 139,*
"KEY_CALC": 140,*
"KEY_SETUP": 141,*
"KEY_SLEEP": 142,*
"KEY_WAKEUP": 143,*
"KEY_FILE": 144,*
"KEY_SENDFILE": 145,*
"KEY_DELETEFILE": 146,*
"KEY_XFER": 147,*
"KEY_PROG1": 148,*
"KEY_PROG2": 149,*
"KEY_WWW": 150,*
"KEY_MSDOS": 151,*
"KEY_COFFEE": 152,*
"KEY_DIRECTION": 153,*
"KEY_CYCLEWINDOWS": 154,*
"KEY_MAIL": 155,*
"KEY_BOOKMARKS": 156,*
"KEY_COMPUTER": 157,*
"KEY_BACK": 174,*
"KEY_FORWARD": 208,*
"KEY_CLOSECD": 160,*
"KEY_EJECTCD": 161,*
"KEY_EJECTCLOSECD": 162,*
"KEY_NEXTSONG": 208,*
"KEY_PLAYPAUSE": 207,*
"KEY_PREVIOUSSONG": 168,*
"KEY_STOPCD": 166,*
"KEY_RECORD": 167,*
"KEY_REWIND": 168,*
"KEY_PHONE": 169,*
"KEY_ISO": 170,*
"KEY_CONFIG": 171,*
"KEY_HOMEPAGE": 172,*
"KEY_REFRESH": 173,*
"KEY_EXIT": 158,*
"KEY_MOVE": 175,*
"KEY_EDIT": 176,*
"KEY_SCROLLUP": 177,*
"KEY_SCROLLDOWN": 178,*
"KEY_KPLEFTPAREN": 179,*
"KEY_KPRIGHTPAREN": 180,*
"KEY_INTL1": 181,*
"KEY_INTL2": 182,*
"KEY_INTL3": 183,*
"KEY_INTL4": 184,*
"KEY_INTL5": 185,*
"KEY_INTL6": 186,*
"KEY_INTL7": 187,*
"KEY_INTL8": 188,*
"KEY_INTL9": 189,*
"KEY_LANG1": 190,*
"KEY_LANG2": 191,*
"KEY_LANG3": 192,*
"KEY_LANG4": 193,*
"KEY_LANG5": 194,*
"KEY_LANG6": 195,*
"KEY_LANG7": 196,*
"KEY_LANG8": 197,*
"KEY_LANG9": 198,*
"KEY_PLAYCD": 200,*
"KEY_PAUSECD": 201,*
"KEY_PROG3": 202,*
"KEY_PROG4": 203,*
"KEY_SUSPEND": 205,*
"KEY_CLOSE": 206,*
"KEY_PLAY": 207,*
"KEY_FASTFORWARD": 208,*
"KEY_BASSBOOST": 209,*
"KEY_PRINT": 210,*
"KEY_HP": 211,*
"KEY_CAMERA": 212,*
"KEY_SOUND": 213,*
"KEY_QUESTION": 214,*
"KEY_EMAIL": 215,*
"KEY_CHAT": 216,*
"KEY_SEARCH": 217,*
"KEY_CONNECT": 218,*
"KEY_FINANCE": 219,*
"KEY_SPORT": 220,*
"KEY_SHOP": 221,*
"KEY_ALTERASE": 222,*
"KEY_CANCEL": 223,*
"KEY_BRIGHTNESSDOWN": 224,*
"KEY_BRIGHTNESSUP": 225,*
"KEY_MEDIA": 226,*
"KEY_UNKNOWN": 240,*
"KEY_OK": 352,*
"KEY_SELECT": 353,*
"KEY_GOTO": 354,*
"KEY_CLEAR": 355,*
"KEY_POWER2": 356,*
"KEY_OPTION": 357,*
"KEY_INFO": 358,*
"KEY_TIME": 359,*
"KEY_VENDOR": 360,*
"KEY_ARCHIVE": 361,*
"KEY_PROGRAM": 362,*
"KEY_CHANNEL": 363,*
"KEY_FAVORITES": 364,*
"KEY_EPG": 365,*
"KEY_PVR": 366,*
"KEY_MHP": 367,*
"KEY_LANGUAGE": 368,*
"KEY_TITLE": 369,*
"KEY_SUBTITLE": 370,*
"KEY_ANGLE": 371,*
"KEY_ZOOM": 372,*
"KEY_MODE": 373,*
"KEY_KEYBOARD": 374,*
"KEY_SCREEN": 375,*
"KEY_PC": 376,*
"KEY_TV": 150,*
"KEY_TV2": 378,*
"KEY_VCR": 379,*
"KEY_VCR2": 380,*
"KEY_SAT": 381,*
"KEY_SAT2": 382,*
"KEY_CD": 383,*
"KEY_TAPE": 384,*
"KEY_RADIO": 59,*
"KEY_TUNER": 386,*
"KEY_PLAYER": 193,*
"KEY_TEXT": 370,*
"KEY_DVD": 389,*
"KEY_AUX": 390,*
"KEY_MP3": 391,*
"KEY_AUDIO": 61,*
"KEY_VIDEO": 393,*
"KEY_DIRECTORY": 394,*
"KEY_LIST": 395,*
"KEY_MEMO": 396,*
"KEY_CALENDAR": 397,*
"KEY_RED": 398,*
"KEY_GREEN": 399,*
"KEY_YELLOW": 400,*
"KEY_BLUE": 401,*
"KEY_CHANNELUP": 402,*
"KEY_CHANNELDOWN": 403,*
"KEY_FIRST": 404,*
"KEY_LAST": 405,*
"KEY_AB": 406,*
"KEY_NEXT": 208,*
"KEY_RESTART": 408,*
"KEY_SLOW": 409,*
"KEY_SHUFFLE": 410,*
"KEY_BREAK": 411,*
"KEY_PREVIOUS": 138,*
"KEY_DIGITS": 413,*
"KEY_TEEN": 414,*
"KEY_TWEN": 415,*
"KEY_DEL_EOL": 448,*
"KEY_DEL_EOS": 449,*
"KEY_INS_LINE": 450,*
"KEY_DEL_LINE": 451,*
"KEY_ASCII": 510,
"KEY_MAX": 511,*
"BTN_0": 256,*
"BTN_1": 257,*
"BTN_2": 258,*
"BTN_3": 259,*
"BTN_4": 260,*
:drinks:
ca sa inteleg...putem sa folosim pe update care iese pt Kathrein la ipbox?Tu ai reusit sa faci asta?Cu spatiu liber la flash care e mic cum rezolvam.Ca pina acuma nu putem sa instalam prea multe lucruri din cauza asta.
Se poate si pe flash, trebuie sa ai grija sa te incadrezi in proportii.
Asta e premiul pe care il dau pentru cea mai reusita portarea.
Lnb INVERTO Single BLACK ULTRA
parea mea, cel mai bun la ora actuala
Stie careva sa fi aparut imagine de release_033_cuberevo-mini2_flash cu PKT inclus pentru IPbox910HD? Am instalat imaginea merge, mai are inca bug-uri dar merge, nu are inclus nodul PKT, am cautat la cei de la PKT dar nu am gasit decat vesiunea pentru USB si eu caut pentru flash. Si inca ceva, am incercat ...asa mai ciobaneste sa adaug un PKT 1.14 a mers dar e in in limba poloneza, am incercat si cu o varianta eng dar imi da o eroare de scriere la rcS si nu e activ emu. Ce am mai reusit sa introduc in imagine EMU manager care nu aparea in imagine.
Daca imi poate da careva niste idei, astept..... e interesant sa incerci ceva ce acum 3 zile era cu absolut totul nou..
