(PR) Thermaltake Announces The Tower 600 Series Chassis with Hidden-Co
Thermaltake, a leading PC DIY brand for premium hardware solutions, is proud to launch The Tower 600 Mid Tower Chassis in Black, Snow, Hydrangea Blue, and Matcha Green. It is a new ATX case of The Tower series with unparalleled aesthetic appeal and hardware compatibility. The Tower 600 is built with a classic vertical case design and comes in a distinctive octagonal prism shape. It supports a hidden-connector motherboard and a special horizontal placement, elevating its visual charm to new heights. Additionally, The Tower 600 can accommodate up to a 420 mm AIO radiator on the right side and a 360 mm AIO radiator on the left side, enabling a superior cooling solution to your high-end PC configuration.
The Tower 600 is compatible with both standard motherboards and the latest hidden-connector motherboards such as ASUS BTF Series, MSI PROJECT ZERO Series, and GIGABYTE PROJECT STEALTH Series. Hidden-connector motherboards can simplify cable routing by directing cables to the back, leading to improved cable management and a more refined look for the interior build. The Tower 600 ensures seamless integration and compatibility with these next-generation motherboards.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
