Barocco Mistel Showcases Innovative New Ergonomic Keyboards at Compute
Mistel brought some of its latest ergonomic gaming and productivity mechanical keyboards to Computex 2024. The Alpha Rhino MD600 is a true-wireless Split Alice compound keyboard. The set connects to your PC as two keyboards, each with half the keyset. You even get two separate palm-rests. As a keyboard set the MD600 has a 60% layout. You can join the two halves and lock them in place; or you can split them to your preferred angle for the best possible ergonomics. There's no cable running between the two halves. In terms of hardware, the MD600 with several variants of Cherry MX key switches that are hot-swappable, topped with PBT double-shot keycaps. The well of the keyset has sound absorbing foam. In terms of connectivity, you have a choice between USB, Bluetooth, and 2.4 GHz RF. The keyboard packs a 2,000 mAh lithium battery, which should give it several weeks of heavy usage on a charge.
The MD750 Delight is a conventional (single piece) 75% format mechanical wireless keyboard, with 87 keys, a programmable rotary knob, and a 2-inch LED screen. The keyboard features RGB backlighting, and its 4,000 mAh battery lasts up to 60 days of heavy use. You get hot-swappable Cherry MX keys with PBT Double Shot keycaps, three connectivity modes, and support for Cherry Profile. The AirOne is an ultra low-profile keyboard that's just 9 to 14 mm thick, and uses Cherry MX ULP tactile-click key switches. It comes in a 65% (68-key) layout, with a CNC milled aluminium body. The switches are topped by a super-slim ABS keycap set. You can carry the AirOne in its provided zipper pouch, or accessorize it with a wood dock that lets you mount tablets such as the iPad Pro on it.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
